[参考译文] BQ28Z610:能否通过向 bq28z610发送 i2c 命令来读取每个电池的电压? 如果我这么做,该怎么做?
Guru**** 2578945 points
Other Parts Discussed in Thread: BQ28Z610
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/854996/bq28z610-can-i-read-each-cell-voltage-by-sending-i2c-command-to-bq28z610-and-if-i-do-how-to-do-it
器件型号:BQ28Z610
我能否通过向 bq28z610发送 i2c 命令来读取每个电池电压?  如果我这么做,该怎么做?
BR、奕迅
