[参考译文] BQ28Z610:为通过 bq24630的2S 应用充电电压、但不充电
Guru**** 2609285 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/596334/bq28z610-applying-a-charging-voltage-for-2s-trough-bq24630-and-not-charging
器件型号:BQ28Z610
这是数据存储 器 e2e.ti.com/.../New-folder.zip
