[参考译文] BQ40Z50-R1:F4数据闪存格式的浮点转换
Guru**** 2589245 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/594195/bq40z50-r1-floating-point-conversion-for-f4-data-flash-format
器件型号:BQ40Z50-R1
e2e.ti.com/.../Here-is-an-example-of-converting-floating-point-numbers-to-store-in-the-data-flash-on-the-bq40z50.pdf
