[参考译文] TPS62147:动态切换模式引脚?
Guru**** 2589265 points
Other Parts Discussed in Thread: TPS62147
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/756734/tps62147-toggle-mode-pin-on-the-fly
器件型号:TPS62147
TPS62147/48上的 MODE 引脚能否在动态模式之间切换而不会出现问题?
