[参考译文] DIDn't 响应来自 MCU 的 I2C 地址请求(无 ACK)
Guru**** 2608905 points
Other Parts Discussed in Thread: BQ25121
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/590691/didn-t-response-on-i2c-address-request-from-mcu-no-ack
主题中讨论的其他器件:BQ25121
你(们)好 我的代码与 BQ25121通信
#define BQ25121_ADDR0x6A
I2C_GenerateSTART (BQ_I2C、ENABLE);
while (!I2C_CheckEvent (BQ_I2C、I2C_EVENT_MASTER_MODE_SELECT)}}
I2C_SendData (BQ_I2C、0xD4);
while (!I2C_CheckEvent (BQ_I2C、I2C_EVENT_MASTER_BYTE_TRANSAD){}
// I2C_Send7bitAddress (BQ_I2C、BQ25121_ADDR、I2C_DIRECT_Transmitter);
// while (!I2C_CheckEvent (BQ_I2C、I2C_EVENT_MASTER_TRANSMIT_SELECTED){\f429
)}、GenerateI2C (BQ_ETOP_MODE_MODE_SELECTED);}while (生成 I2C_ENABLE
发送地址后、程序未响应。
CD 设置为高电平、以在从 BAT 工作时激活 i2c。 BQ25121的最小连接是什么?
