[参考译文] LM27761:合并两个 LM27761器件的输出以获得500mA 电流
Guru**** 2606725 points
Other Parts Discussed in Thread: LM27761
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/589147/lm27761-combine-outputs-of-two-lm27761-devices-to-get-500ma-current
器件型号:LM27761
是否可以组合两个 LM27761器件的输出以获得500mA 电流?
设计要求如下所示、
输入电压  :5V
输出电压:   -1.8V
输出电流:   500mA
