[参考译文] TPS61235P:TPS61235和 TPS61235P 之间有何差异?
Guru**** 2519870 points
Other Parts Discussed in Thread: TPS61235P
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/567575/tps61235p-what-the-difference-between-tps61235-and-tps61235p
器件型号:TPS61235P
您能帮您确认一下。
TPS61235和 TPS61235P 有何区别?
    你好
    电气性能是相同的。 我们改进了 TPS61235P 中的封装材料
