[参考译文] BQSTUDIO:无法在 bqStudio 1.3.80中加载 GPCPackager 插件
Guru**** 2589265 points
Other Parts Discussed in Thread: BQSTUDIO, BQ34110, EV2400
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/666739/bqstudio-gpcpackager-plugin-fails-to-load-in-bqstudio-1-3-80
器件型号:BQSTUDIO
主题中讨论的其他器件: BQ34110EV2400
使用 bqStudio 1.3.80
Windows 7 Pro x64
通过 EV2400 v0.18连接到 bq34110 [0110_0_02]
尝试打开 GPCPackager 选项卡会导致抛出以下错误:
插件 com.ti.evswsdk.gpcager 无法加载类 com.ti.evswsdk.gpcpackagerviews.gPCPackagerView。
堆栈跟踪
org.eclipse.core.runtime.CoreException:插件 com.ti.evswsdk.gpcager 无法加载类 com.ti.evswsdk.gpcpackagerviews.gPCPackagerView。
   org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
   org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:178)
   org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
   org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
   org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
   org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:58)
   org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:101)
   org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:279)
   org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:317)
   sun.reflect.NativeMethodAccessorImpl.invoke0(Native 方法)
   sun.reflect.NativeMethodAccessorImpl.invoke(Unknown 来源)
   sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown 来源)
   java.lang.reflect.Method.invoke(Unknown 来源)
   org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
   org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
   org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
   org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
   org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
   org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
   位于 org.eclipse.e4.core.contextProjectionFactory.make (ContextInjectionFactory.Java:162)
   org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
   org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
   org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
   在 org.eclipse.e4.ui.workbench.renders.swt.ContributedPartRenderer.createWidget (ContributedPartRenderer.Java:129)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:525)
   org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:509)
   在 org.eclipse.e4.ui.workbench.renders.swt.ElementReferenceRenderer.createWidget (ElementReferenceRenderer.Java:69)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:142)
   org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:83)
   org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
   org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
   org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
   org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
   org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
   org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
   org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
   org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
   org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
   org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
   org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
   org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:303)
   org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:567)
   org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:536)
   org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
   org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:701)
   org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:639)
   org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:634)
   org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1157)
   org.eclipse.ui.internal.WorkbenchPage.showPart(WorkbenchPage.java:1276)
   org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1267)
   org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.java:4238)
   在 org.eclipse.swt.custom.BusyIndicator.showWhile (BusyIndicator.Java:70)
   org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4234)
   org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:4214)
   在 com.ti.evswsdk.gpcpackager.views.GPCPackagerHandlerexec.execute (未知来源)
   org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
   org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
   org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
   org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
   org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
   org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
   org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
   org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
   org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
   org.eclipse.e4.ui.workbench.renders.swt.HandledContributionItem.executeItem(HandledContributionItem.Java:799)
   org.eclipse.e4.ui.workbench.renders.swt.HandledContributionItem.handleWidgetSelection (HandledContributionItem.Java:675)
   org.eclipse.e4.ui.workbench.renders.swt.HandledContributionItem.access$7 (HandledContributionItem.Java:659)
   org.eclipse.e4.ui.workbench.renders.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.Java:592)
   org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
   org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
   org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
   org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
   在 org.eclipse.swt.widget.Display.readAndDispatch (Display.java:3769)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
   org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
   org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
   org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
   org.eclipse.ui.internal.Workbench$5.run(Workbench.java:694)
   org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:606)
   在 org.eclipse.ui.PlatformUI.createAndRunWorkbench (PlatformUI.Java:150)
   位于 com.ti.evswsdk.Application.start (未知源)
   org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
   org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
   org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
   org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
   org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
   在 org.eclipse.equinox.launcher.Main.basicRun (Main.java:608)
   org.eclipse.equinox.launcher.Main.run(Main.java:1515)
原因:java.lang.NoClassDefFoundError:com/ti/evswsdk/projectmode/IProjectPlugin
   java.lang.ClassLoader.defineClass1(Native 方法)
   java.lang.ClassLoader.defineClass(Unknown 来源)
   org.eclipse.osgi.internal.loader.ModuleClassLoader.defineClass(ModuleClassLoader.java:272)
   org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:632)
   org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:588)
   org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:540)
   org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:527)
   org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
   org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:327)
   org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:402)
   org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:352)
   org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:344)
   org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
   在 java.lang.classloader.loader.loadClass (未知来源)
   org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:573)
   org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
   (笑声) 112个以上
原因:java.lang.ClassNotFoundException:com.ti.evswsdk.gpcpackager_1.0.1.1找不到 com.ti.evswsdk.projectmode.IProjectPlugin
   org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:439)
   (笑声) 128个以上
    您好、Kyle、
    您可以尝试从工具的产品文件夹下载的早期 bqStudio 版本吗?
    Onyx
    谢谢 Onyx、较旧版本现在已经清除了它。
