[参考译文] TPS40422:当 tps40422在两相模式下工作时、如何通过频域分析测试环路稳定性
Guru**** 2605675 points
Other Parts Discussed in Thread: TPS40422
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/639487/tps40422-how-to-test-loop-stability-by-frequency-domain-analysis-when-tps40422-working-at-two-phase-mode
器件型号:TPS40422
  当 tps40422在 两相模式下工作时、如何通过频域分析测试环路稳定性。
