[参考译文] LP2981A:了解将 LP2891引脚4 (NC)连接到3.3V 的问题
Guru**** 2518740 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1185407/lp2981a-to-know-the-concern-of-connect-the-lp2891-pin4-nc-to-3-3v
器件型号:LP2981A
您好:
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/998768/lp2981-to-know-the-concern-of-connect-the-lp2891-pin4-nc-to-ground/3694604
TI 的 LDO LP2981A-50DBVR 和引脚4为 NC。 如果 NC 引脚始终连接到3.3V、问题出在哪。
