[参考译文] TPS630250:TPS630250 ->能否并联 x2个 IC 以获得更高的输出电流?
Guru**** 2589280 points
Other Parts Discussed in Thread: TPS630250
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/692028/tps630250-tps630250---can-x2-ic-s-be-placed-in-parallel-to-obtain-higher-output-current
器件型号:TPS630250
TPS630250 IC 的两个(x2)能否并联放置以在升压和降压模式下获得更高的输出电流?
    这两个 IC 可并联设计以提供更多电流
