[参考译文] TPS548A20:与引脚2引脚兼容部件 TPS53515的 VIN 范围比较
Guru**** 2587345 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/722612/tps548a20-vin-range-comparison-with-pin2pin-compatible-part-tps53515
器件型号:TPS548A20
点击"Resolved"或"TI Thinked Resolved"即可锁定胎面。
