[参考译文] TPS40322:TPS40322原理图审阅
Guru**** 2582405 points
Other Parts Discussed in Thread: TPS40322
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/697943/tps40322-tps40322-schematic-review
器件型号:TPS40322
大家好、团队:
您能否帮助查看随附文件中的 TPS40322原理图并发表评论?  工作条件如下:
输入电压:   12V  (__LW_AT__典型值)Ω
VOUT0.85V
Iout (最大值):40A
输出电压纹波:15mV
输出电压过冲:25mVe2e.ti.com/.../TPS40322--CORE-POWER-Design.pdf
