[参考译文] LMZM33606:两个并联以使输出电流加倍?
Guru**** 2493565 points
Other Parts Discussed in Thread: LMZM33606
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/715356/lmzm33606-two-in-parallel-to-double-the-output-current
器件型号:LMZM33606
我能否并行运行两个以使输出电流加倍?
