Thread 中讨论的其他器件:可扩展 PMIC-GUI、 USB2ANY
你好
尝试使用新配置参数重新编程 EVM 时遇到同样的问题。
它会显示消息
"EEPROM 解锁失败"和"请验证程序"。
您能否为初始设置提供 NVM 配置文件并帮助我解决问题
Harsha
你好
它会显示消息
Harsha
您好、Harsha、
写入寄存器不会自动更改器件上的非易失性 EEPROM。 有关更新 NVM 的信息、请参阅链接的指南
https://www.ti.com/lit/pdf/slvaf93
Daniel W
Daniel、您好!
"details": {
"name": "sample_template",
"description": "description for sample template",
"revision": "0.4.0"
"content": {
"staticConfig": [
"name": "TPS6594x_2p0",
"devices": [
"alias": "TPS65940",
"type": "TPS6594x_2p0",
"masterOrSlave": "master",
"master": true,
"staticConfigJSON": {
"groups": [
"name": "Buck",
"blocks": [
"name": "Buck1_2_3_4",
"type": "hidden",
"registers": [
"regID": "BUCK1_CTRL",
"fixedFields": [
"fieldID": "BUCK1_EN",
"value": 0
"fieldID": "BUCK1_PLDN",
"value": 1
"fieldID": "BUCK1_VMON_EN",
"value": 0
"hideFields": [
"BUCK1_EN",
"BUCK1_PLDN",
"BUCK1_VMON_EN"
"fields": [
"BUCK1_EN",
"BUCK1_FPWM",
"BUCK1_FPWM_MP",
"BUCK1_VSEL",
"BUCK1_VMON_EN",
"BUCK1_PLDN",
"BUCK1_RV_SEL"
"regID": "BUCK1_CONF",
"fields": [
"BUCK1_SLEW_RATE",
"BUCK1_ILIM"
"regID": "BUCK1_VOUT_1",
"fields": [
"BUCK1_VSET1"
"regID": "BUCK1_VOUT_2",
"fields": [
"BUCK1_VSET2"
"regID": "BUCK1_PG_WINDOW",
"fields": [
"BUCK1_OV_THR",
"BUCK1_UV_THR"
"regID": "RAIL_SEL_1",
"fields": [
"BUCK1_GRP_SEL"
"regID": "BUCK_RESET_REG",
"fixedFields": [
"fieldID": "BUCK1_RESET",
"value": 0
"hideFields": [
"BUCK1_RESET"
"fields": [
"BUCK1_RESET"
"regID": "FREQ_SEL",
"hideFields": [
"BUCK1_FREQ_SEL"
"fields": [
"BUCK1_FREQ_SEL"
"regID": "BUCK_CONFIG_ANALOG_1",
"hideFields": [
"BUCK1_SEL_NEG_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_1",
"hideFields": [
"BUCK1_SEL_POS_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_ANALOG_3",
"hideFields": [
"BUCK1_SEL_ISENSE_SLOPE_COMPENSATION",
"BUCK1_SEL_VOUT_ADC_LEVEL"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_0",
"fixedFields": [
"fieldID": "BUCK1_SEL_PHASE_ADD",
"value": 1
"fieldID": "BUCK1_SEL_PHASE_SHEDD",
"value": 0
"fieldID": "EN_LOAD_COMP_BLANK",
"value": 1
"hideFields": [
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_4",
"hideFields": [
"BUCK1_SEL_OUTPUT_CAPS"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_6",
"hideFields": [
"BUCK1_SEL_RAMP"
"fields": [
"BUCK1_SEL_RAMP"
"regID": "BUCK_CONFIG_DIGITAL_12",
"hideFields": [
"BUCK1_FREQ_8MHZ"
"fields": [
"BUCK1_FREQ_8MHZ"
"regID": "BUCK_CONFIG_DIGITAL_13",
"hideFields": [
"BUCK1_EN_P_10M_BODY_DIODE"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_14",
"hideFields": [
"BUCK1_DOUBLE_PFM_PULSE"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_15",
"hideFields": [
"BUCK1_CHANGE_2MHZ_BELOW_0V5"
"fields": [
"regID": "BUCK_CONFIG_RADAR",
"hideFields": [
"BUCK1_EN_RADAR_MODE"
"fields": [
"regID": "BUCK1_DTEST_REG_0",
"fixedFields": [
"fieldID": "swc_buck_hiz_1",
"value": 0
"hideFields": [
"swc_buck_hiz_1"
"fields": [
"swc_buck_hiz_1"
"name": "Buck1_2_3",
"type": "hidden",
"registers": [
"fixedFields": [
"value": 0
"value": 1
"value": 0
"hideFields": [
"BUCK1_EN",
"BUCK1_PLDN",
"BUCK1_VMON_EN"
"fields": [
"BUCK1_EN",
"BUCK1_FPWM",
"BUCK1_FPWM_MP",
"BUCK1_VSEL",
"BUCK1_VMON_EN",
"BUCK1_PLDN",
"BUCK1_RV_SEL"
"fields": [
"BUCK1_SLEW_RATE",
"BUCK1_ILIM"
"fields": [
"BUCK1_VSET1"
"fields": [
"BUCK1_VSET2"
"fields": [
"BUCK1_OV_THR",
"BUCK1_UV_THR"
"fields": [
"BUCK1_GRP_SEL"
"fixedFields": [
"value": 0
"hideFields": [
"BUCK1_RESET"
"fields": [
"BUCK1_RESET"
"hideFields": [
"BUCK1_FREQ_SEL"
"fields": [
"BUCK1_FREQ_SEL"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 1
"value": 0
"value": 1
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"BUCK1_SEL_RAMP"
"fields": [
"BUCK1_SEL_RAMP"
"hideFields": [
"BUCK1_FREQ_8MHZ"
"fields": [
"BUCK1_FREQ_8MHZ"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 0
"hideFields": [
"swc_buck_hiz_1"
"fields": [
"swc_buck_hiz_1"
"name": "Buck1_2",
"type": "visible",
"registers": [
"fixedFields": [
"value": 0
"value": 1
"value": 0
"hideFields": [
"BUCK1_EN",
"BUCK1_PLDN",
"BUCK1_VMON_EN"
"fields": [
"BUCK1_EN",
"BUCK1_FPWM",
"BUCK1_FPWM_MP",
"BUCK1_VSEL",
"BUCK1_VMON_EN",
"BUCK1_PLDN",
"BUCK1_RV_SEL"
"fields": [
"BUCK1_SLEW_RATE",
"BUCK1_ILIM"
"fields": [
"BUCK1_VSET1"
"fields": [
"BUCK1_VSET2"
"fields": [
"BUCK1_OV_THR",
"BUCK1_UV_THR"
"fields": [
"BUCK1_GRP_SEL"
"fixedFields": [
"value": 0
"hideFields": [
"BUCK1_RESET"
"fields": [
"BUCK1_RESET"
"hideFields": [
"BUCK1_FREQ_SEL"
"fields": [
"BUCK1_FREQ_SEL"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 1
"value": 0
"value": 1
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"BUCK1_SEL_RAMP"
"fields": [
"BUCK1_SEL_RAMP"
"hideFields": [
"BUCK1_FREQ_8MHZ"
"fields": [
"BUCK1_FREQ_8MHZ"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 0
"hideFields": [
"swc_buck_hiz_1"
"fields": [
"swc_buck_hiz_1"
"regConfig": {
"question": "Is this rail used for VTT?",
"id": "vtt_config",
"selectedOption": "no",
"options": [
"name": "yes",
"configurationDisplayName": "2.2MHz Single Phase for DDR Termination",
"configuration": "DDR VTT (SP)",
"inductor": "470nH",
"isTouched": false
"name": "no",
"question": "What is this rail's switching frequency?",
"id": "switching_frequency_config",
"selectedOption": "4.4MHz",
"options": [
"name": "4.4MHz",
"question": "Does this rail want to be optimized for multiphase configuration?",
"id": "multiphase_config",
"selectedOption": "yes",
"options": [
"name": "yes",
"configurationDisplayName": "4.4MHz Multiphase Configuration",
"configuration": "4.4MHz HiCur (MP)",
"inductor": "220nH",
"isTouched": false
"name": "no",
"question": "What is the output of this rail?",
"id": "output_rail_config",
"selectedOption": "1.8V or less",
"options": [
"name": "1.8V or less",
"question": "What is the output capacitance on this rail?",
"id": "output_capacitance_config",
"selectedOption": "greater than 100 uF",
"options": [
"name": "greater than 100 uF",
"isTouched": false
"name": "less than 100uF",
"configurationDisplayName": "4.4MHz Single Phase Low Output Voltage",
"configuration": "4.4MHz LoCur (SP)",
"isTouched": false
"isTouched": false
"name": "greater than 1.8V",
"configurationDisplayName": "4.4MHz Single Phase High Output Voltage",
"configuration": "4.4MHz HiVolt (SP)",
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "2.2MHz",
"options": [
"name": "yes",
"configurationDisplayName": "2.2MHz Multiphase with Full Range VIN",
"configuration": "2.2MHz (MP)",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"name": "full range",
"question": "What is the input voltage of this rail?",
"id": "input_voltage_config",
"selectedOption": "Only greater than 4.5V",
"options": [
"name": "Only greater than 4.5V",
"configurationDisplayName": "2.2MHz Single Phase with 5.0V VIN",
"configuration": "5Vin (SP)",
"inductor": "1000nH",
"isTouched": false
"name": "Supports full input voltage range",
"configurationDisplayName": "2.2MHz Single Phase with Full Range VIN",
"configuration": "2.2MHz (SP)",
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false
"isTouched": true,
"highlight": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "Buck3_4",
"type": "hidden",
"registers": [
"regID": "BUCK3_CTRL",
"fixedFields": [
"fieldID": "BUCK3_EN",
"value": 0
"fieldID": "BUCK3_PLDN",
"value": 1
"fieldID": "BUCK3_VMON_EN",
"value": 0
"hideFields": [
"BUCK3_EN",
"BUCK3_PLDN",
"BUCK3_VMON_EN"
"fields": [
"BUCK3_EN",
"BUCK3_FPWM",
"BUCK3_FPWM_MP",
"BUCK3_VSEL",
"BUCK3_VMON_EN",
"BUCK3_PLDN",
"BUCK3_RV_SEL"
"regID": "BUCK3_CONF",
"fields": [
"BUCK3_SLEW_RATE",
"BUCK3_ILIM"
"regID": "BUCK3_VOUT_1",
"fields": [
"BUCK3_VSET1"
"regID": "BUCK3_VOUT_2",
"fields": [
"BUCK3_VSET2"
"regID": "BUCK3_PG_WINDOW",
"fields": [
"BUCK3_OV_THR",
"BUCK3_UV_THR"
"fields": [
"BUCK3_GRP_SEL"
"fixedFields": [
"fieldID": "BUCK3_RESET",
"value": 0
"hideFields": [
"BUCK3_RESET"
"fields": [
"BUCK3_RESET"
"hideFields": [
"BUCK3_FREQ_SEL"
"fields": [
"BUCK3_FREQ_SEL"
"hideFields": [
"BUCK3_SEL_NEG_OCP_HYST"
"fields": [
"hideFields": [
"BUCK3_SEL_POS_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_ANALOG_5",
"hideFields": [
"BUCK3_SEL_ISENSE_SLOPE_COMPENSATION",
"BUCK3_SEL_VOUT_ADC_LEVEL"
"fields": [
"fixedFields": [
"fieldID": "BUCK3_SEL_PHASE_SHEDD",
"value": 0
"fieldID": "BUCK3_SEL_PHASE_ADD",
"value": 1
"hideFields": [
"fields": [
"hideFields": [
"BUCK3_SEL_OUTPUT_CAPS"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_7",
"hideFields": [
"BUCK3_SEL_RAMP"
"fields": [
"BUCK3_SEL_RAMP"
"hideFields": [
"BUCK3_FREQ_8MHZ"
"fields": [
"BUCK3_FREQ_8MHZ"
"hideFields": [
"BUCK3_EN_P_10M_BODY_DIODE"
"fields": [
"hideFields": [
"BUCK3_DOUBLE_PFM_PULSE"
"fields": [
"hideFields": [
"BUCK3_CHANGE_2MHZ_BELOW_0V5"
"fields": [
"hideFields": [
"BUCK3_EN_RADAR_MODE"
"fields": [
"regID": "BUCK3_DTEST_REG_0",
"fixedFields": [
"fieldID": "swc_buck_hiz_3",
"value": 0
"hideFields": [
"swc_buck_hiz_3"
"fields": [
"swc_buck_hiz_3"
"name": "Buck3 Monitor",
"type": "hidden",
"registers": [
"fields": [
"BUCK3_VSEL",
"BUCK3_RV_SEL"
"fields": [
"BUCK3_SLEW_RATE"
"fields": [
"BUCK3_VSET1"
"fields": [
"BUCK3_VSET2"
"fields": [
"BUCK3_OV_THR",
"BUCK3_UV_THR"
"fields": [
"BUCK3_GRP_SEL"
"name": "Buck4 Monitor",
"type": "hidden",
"registers": [
"regID": "BUCK4_CTRL",
"fields": [
"BUCK4_VSEL",
"BUCK4_RV_SEL"
"regID": "BUCK4_CONF",
"fields": [
"BUCK4_SLEW_RATE"
"regID": "BUCK4_VOUT_1",
"fields": [
"BUCK4_VSET1"
"regID": "BUCK4_VOUT_2",
"fields": [
"BUCK4_VSET2"
"regID": "BUCK4_PG_WINDOW",
"fields": [
"BUCK4_OV_THR",
"BUCK4_UV_THR"
"fields": [
"BUCK4_GRP_SEL"
"name": "Buck1",
"registers": [
"fixedFields": [
"value": 0
"value": 1
"value": 0
"hideFields": [
"BUCK1_EN",
"BUCK1_PLDN",
"BUCK1_VMON_EN"
"fields": [
"BUCK1_EN",
"BUCK1_FPWM",
"BUCK1_FPWM_MP",
"BUCK1_VSEL",
"BUCK1_VMON_EN",
"BUCK1_PLDN",
"BUCK1_RV_SEL"
"fields": [
"BUCK1_SLEW_RATE",
"BUCK1_ILIM"
"fields": [
"BUCK1_VSET1"
"fields": [
"BUCK1_VSET2"
"fields": [
"BUCK1_OV_THR",
"BUCK1_UV_THR"
"fields": [
"BUCK1_GRP_SEL"
"fixedFields": [
"value": 0
"hideFields": [
"BUCK1_RESET"
"fields": [
"BUCK1_RESET"
"hideFields": [
"BUCK1_FREQ_SEL"
"fields": [
"BUCK1_FREQ_SEL"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 1
"value": 0
"value": 1
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"BUCK1_SEL_RAMP"
"fields": [
"BUCK1_SEL_RAMP"
"hideFields": [
"BUCK1_FREQ_8MHZ"
"fields": [
"BUCK1_FREQ_8MHZ"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 0
"hideFields": [
"swc_buck_hiz_1"
"fields": [
"swc_buck_hiz_1"
"type": "hidden",
"regConfig": {
"id": "vtt_config",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"name": "4.4MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "2.2MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false
"isTouched": true,
"highlight": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "Buck2",
"registers": [
"regID": "BUCK2_CTRL",
"fixedFields": [
"fieldID": "BUCK2_EN",
"value": 0
"fieldID": "BUCK2_PLDN",
"value": 1
"fieldID": "BUCK2_VMON_EN",
"value": 0
"hideFields": [
"BUCK2_EN",
"BUCK2_PLDN",
"BUCK2_VMON_EN"
"fields": [
"BUCK2_EN",
"BUCK2_FPWM",
"BUCK2_VSEL",
"BUCK2_VMON_EN",
"BUCK2_PLDN",
"BUCK2_RV_SEL"
"regID": "BUCK2_CONF",
"fields": [
"BUCK2_SLEW_RATE",
"BUCK2_ILIM"
"regID": "BUCK2_VOUT_1",
"fields": [
"BUCK2_VSET1"
"regID": "BUCK2_VOUT_2",
"fields": [
"BUCK2_VSET2"
"regID": "BUCK2_PG_WINDOW",
"fields": [
"BUCK2_OV_THR",
"BUCK2_UV_THR"
"fields": [
"BUCK2_GRP_SEL"
"fixedFields": [
"fieldID": "BUCK2_RESET",
"value": 0
"hideFields": [
"BUCK2_RESET"
"fields": [
"BUCK2_RESET"
"hideFields": [
"BUCK2_FREQ_SEL"
"fields": [
"BUCK2_FREQ_SEL"
"hideFields": [
"BUCK2_SEL_NEG_OCP_HYST"
"fields": [
"hideFields": [
"BUCK2_SEL_POS_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_ANALOG_4",
"hideFields": [
"BUCK2_SEL_ISENSE_SLOPE_COMPENSATION",
"BUCK2_SEL_VOUT_ADC_LEVEL"
"fields": [
"hideFields": [
"BUCK2_SEL_OUTPUT_CAPS"
"fields": [
"hideFields": [
"BUCK2_SEL_RAMP"
"fields": [
"BUCK2_SEL_RAMP"
"hideFields": [
"BUCK2_FREQ_8MHZ"
"fields": [
"BUCK2_FREQ_8MHZ"
"hideFields": [
"BUCK2_EN_P_10M_BODY_DIODE"
"fields": [
"hideFields": [
"BUCK2_DOUBLE_PFM_PULSE"
"fields": [
"hideFields": [
"BUCK2_CHANGE_2MHZ_BELOW_0V5"
"fields": [
"hideFields": [
"BUCK2_EN_RADAR_MODE"
"fields": [
"regID": "BUCK2_DTEST_REG_0",
"fixedFields": [
"fieldID": "swc_buck_hiz_2",
"value": 0
"hideFields": [
"swc_buck_hiz_2"
"fields": [
"swc_buck_hiz_2"
"type": "hidden",
"regConfig": {
"id": "vtt_config",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"name": "4.4MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "2.2MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": true,
"isTouched": false
"isTouched": true,
"highlight": false
"disabled": true,
"isTouched": false,
"highlight": false
"name": "Buck3",
"registers": [
"fixedFields": [
"value": 0
"value": 1
"value": 0
"hideFields": [
"BUCK3_EN",
"BUCK3_PLDN",
"BUCK3_VMON_EN"
"fields": [
"BUCK3_EN",
"BUCK3_FPWM",
"BUCK3_FPWM_MP",
"BUCK3_VSEL",
"BUCK3_VMON_EN",
"BUCK3_PLDN",
"BUCK3_RV_SEL"
"fields": [
"BUCK3_SLEW_RATE",
"BUCK3_ILIM"
"fields": [
"BUCK3_VSET1"
"fields": [
"BUCK3_VSET2"
"fields": [
"BUCK3_OV_THR",
"BUCK3_UV_THR"
"fields": [
"BUCK3_GRP_SEL"
"fixedFields": [
"value": 0
"hideFields": [
"BUCK3_RESET"
"fields": [
"BUCK3_RESET"
"hideFields": [
"BUCK3_FREQ_SEL"
"fields": [
"BUCK3_FREQ_SEL"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 0
"value": 1
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"BUCK3_SEL_RAMP"
"fields": [
"BUCK3_SEL_RAMP"
"hideFields": [
"BUCK3_FREQ_8MHZ"
"fields": [
"BUCK3_FREQ_8MHZ"
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"hideFields": [
"fields": [
"fixedFields": [
"value": 0
"hideFields": [
"swc_buck_hiz_3"
"fields": [
"swc_buck_hiz_3"
"type": "visible",
"regConfig": {
"id": "vtt_config",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"name": "4.4MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": false,
"isTouched": false
"name": "2.2MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": false,
"isTouched": false
"isTouched": false
"isTouched": true,
"highlight": false
"name": "Buck4",
"registers": [
"fixedFields": [
"fieldID": "BUCK4_EN",
"value": 0
"fieldID": "BUCK4_PLDN",
"value": 1
"fieldID": "BUCK4_VMON_EN",
"value": 0
"hideFields": [
"BUCK4_EN",
"BUCK4_PLDN",
"BUCK4_VMON_EN"
"fields": [
"BUCK4_EN",
"BUCK4_FPWM",
"BUCK4_VSEL",
"BUCK4_VMON_EN",
"BUCK4_PLDN",
"BUCK4_RV_SEL"
"fields": [
"BUCK4_SLEW_RATE",
"BUCK4_ILIM"
"fields": [
"BUCK4_VSET1"
"fields": [
"BUCK4_VSET2"
"fields": [
"BUCK4_OV_THR",
"BUCK4_UV_THR"
"fields": [
"BUCK4_GRP_SEL"
"fixedFields": [
"fieldID": "BUCK4_RESET",
"value": 0
"hideFields": [
"BUCK4_RESET"
"fields": [
"BUCK4_RESET"
"hideFields": [
"BUCK4_FREQ_SEL"
"fields": [
"BUCK4_FREQ_SEL"
"hideFields": [
"BUCK4_SEL_NEG_OCP_HYST"
"fields": [
"hideFields": [
"BUCK4_SEL_POS_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_ANALOG_6",
"hideFields": [
"BUCK4_SEL_ISENSE_SLOPE_COMPENSATION",
"BUCK4_SEL_VOUT_ADC_LEVEL"
"fields": [
"hideFields": [
"BUCK4_SEL_OUTPUT_CAPS"
"fields": [
"hideFields": [
"BUCK4_SEL_RAMP"
"fields": [
"BUCK4_SEL_RAMP"
"hideFields": [
"BUCK4_FREQ_8MHZ"
"fields": [
"BUCK4_FREQ_8MHZ"
"hideFields": [
"BUCK4_EN_P_10M_BODY_DIODE"
"fields": [
"hideFields": [
"BUCK4_DOUBLE_PFM_PULSE"
"fields": [
"hideFields": [
"BUCK4_CHANGE_2MHZ_BELOW_0V5"
"fields": [
"hideFields": [
"BUCK4_EN_RADAR_MODE"
"fields": [
"regID": "BUCK4_DTEST_REG_0",
"fixedFields": [
"fieldID": "swc_buck_hiz_4",
"value": 0
"hideFields": [
"swc_buck_hiz_4"
"fields": [
"swc_buck_hiz_4"
"type": "visible",
"regConfig": {
"id": "vtt_config",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"name": "4.4MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": false,
"isTouched": false,
"highlight": true
"name": "2.2MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"disabled": false,
"isTouched": false
"isTouched": false,
"highlight": true
"isTouched": true,
"highlight": false
"name": "Buck5",
"type": "visible",
"registers": [
"regID": "BUCK5_CTRL",
"fixedFields": [
"fieldID": "BUCK5_EN",
"value": 0
"fieldID": "BUCK5_PLDN",
"value": 1
"fieldID": "BUCK5_VMON_EN",
"value": 0
"hideFields": [
"BUCK5_EN",
"BUCK5_PLDN",
"BUCK5_VMON_EN"
"fields": [
"BUCK5_EN",
"BUCK5_FPWM",
"BUCK5_VSEL",
"BUCK5_VMON_EN",
"BUCK5_PLDN",
"BUCK5_RV_SEL"
"regID": "BUCK5_CONF",
"fields": [
"BUCK5_SLEW_RATE",
"BUCK5_ILIM"
"regID": "BUCK5_VOUT_1",
"fields": [
"BUCK5_VSET1"
"regID": "BUCK5_VOUT_2",
"fields": [
"BUCK5_VSET2"
"regID": "BUCK5_PG_WINDOW",
"fields": [
"BUCK5_OV_THR",
"BUCK5_UV_THR"
"regID": "RAIL_SEL_2",
"fields": [
"BUCK5_GRP_SEL"
"fixedFields": [
"fieldID": "BUCK5_RESET",
"value": 0
"hideFields": [
"BUCK5_RESET"
"fields": [
"BUCK5_RESET"
"hideFields": [
"BUCK5_FREQ_SEL"
"fields": [
"BUCK5_FREQ_SEL"
"hideFields": [
"BUCK5_SEL_NEG_OCP_HYST"
"fields": [
"hideFields": [
"BUCK5_SEL_POS_OCP_HYST"
"fields": [
"regID": "BUCK_CONFIG_ANALOG_7",
"hideFields": [
"BUCK5_SEL_ISENSE_SLOPE_COMPENSATION",
"BUCK5_SEL_VOUT_ADC_LEVEL"
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_5",
"hideFields": [
"BUCK5_SEL_OUTPUT_CAPS"
"fields": [
"hideFields": [
"BUCK5_SEL_RAMP"
"fields": [
"BUCK5_SEL_RAMP"
"hideFields": [
"BUCK5_FREQ_8MHZ"
"fields": [
"BUCK5_FREQ_8MHZ"
"hideFields": [
"BUCK5_EN_P_10M_BODY_DIODE"
"fields": [
"hideFields": [
"BUCK5_DOUBLE_PFM_PULSE"
"fields": [
"hideFields": [
"BUCK5_CHANGE_2MHZ_BELOW_0V5"
"fields": [
"hideFields": [
"BUCK5_EN_RADAR_MODE"
"fields": [
"regID": "BUCK5_DTEST_REG_0",
"fixedFields": [
"fieldID": "swc_buck_hiz_5",
"value": 0
"hideFields": [
"swc_buck_hiz_5"
"fields": [
"swc_buck_hiz_5"
"regConfig": {
"id": "vtt_config",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"name": "4.4MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false,
"disabled": false
"name": "2.2MHz",
"options": [
"name": "yes",
"isTouched": false
"name": "no",
"options": [
"isTouched": false
"options": [
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false
"isTouched": false,
"disabled": false
"isTouched": false
"isTouched": false
"name": "Miscellaneous Buck",
"type": "visible",
"registers": [
"regID": "BUCK_CONFIG_ANALOG_0",
"fixedFields": [
"fieldID": "SEL_LOOP_NEG_HYST",
"value": 2
"fieldID": "SEL_GATE_EARLY_SENSE",
"value": 0
"fieldID": "SEL_TRAD_NON_OVERLAP",
"value": 0
"hideFields": [
"fields": [
"fixedFields": [
"fieldID": "SEL_FB_FILTER",
"value": 3
"hideFields": [
"SEL_FB_FILTER"
"fields": [
"SEL_FB_FILTER"
"regID": "BUCK_CONFIG_ANALOG_2",
"fixedFields": [
"fieldID": "SEL_RAMP_ARTIF",
"value": 1
"hideFields": [
"SEL_RAMP_ARTIF"
"fields": [
"SEL_RAMP_ARTIF"
"regID": "BUCK_CONFIG_ANALOG_8",
"fixedFields": [
"fieldID": "EN_SW_RT_SHORT_DETECTORS",
"value": 0
"fieldID": "EN_IAVE_LOOP_INJECTOR",
"value": 0
"hideFields": [
"fields": [
"fixedFields": [
"fieldID": "EN_PLL_PROP_EXTEND",
"value": 1
"fieldID": "EN_SMART_OCP_BLANK",
"value": 1
"hideFields": [
"fields": [
"regID": "BUCK_CONFIG_DIGITAL_2",
"fixedFields": [
"fieldID": "SEL_HS_DETECTOR",
"value": 1
"fieldID": "EN_LONG_PFM_EXIT_CNTR",
"value": 1
"hideFields": [
"SEL_HS_DETECTOR",
"fields": [
"SEL_HS_DETECTOR",
"regID": "BUCK_CONFIG_DIGITAL_3",
"fixedFields": [
"fieldID": "EN_NEG_OCP",
"value": 1
"fieldID": "EN_POS_OCP",
"value": 1
"fieldID": "EN_PFM_LOAD",
"value": 1
"fieldID": "EN_DOT_MODE",
"value": 1
"hideFields": [
"DOUBLE_PFM_PULSE",
"EN_P_10M_BODY_DIODE",
"EN_NEG_OCP",
"EN_POS_OCP",
"EN_PFM_LOAD",
"EN_DOT_MODE"
"fields": [
"EN_DOT_MODE",
"EN_PFM_LOAD",
"DOUBLE_PFM_PULSE",
"EN_POS_OCP",
"EN_NEG_OCP"
"fixedFields": [
"fieldID": "EN_AUTO_LOOP_COEFFS",
"value": 1
"fieldID": "LOOP_COEFF_FB_MSB",
"value": 1
"fieldID": "LOOP_COEFF_I_BALANCE",
"value": 1
"fieldID": "SEL_ZERO_CROSS_FILTER_AVE",
"value": 1
"fieldID": "EN_LONG_ZERO_CROSS_FILTER",
"value": 0
"hideFields": [
"fields": [
"fixedFields": [
"fieldID": "EN_PFM_PULSE_WAIT_LS_OCP",
"value": 1
"fieldID": "EN_SLOW_PLL_COEFFS",
"value": 0
"fieldID": "FORCE_SS_ADAPT",
"value": 0
"hideFields": [
"FORCE_SS_ADAPT"
"fields": [
"FORCE_SS_ADAPT"
"fixedFields": [
"fieldID": "EN_FAST_PLL_0P7",
"value": 1
"fieldID": "EN_SW_SHORT_DETECTORS",
"value": 1
"hideFields": [
"EN_FAST_PLL_0P7",
"fields": [
"EN_FAST_PLL_0P7",
"regID": "BUCK_CONFIG_DIGITAL_8",
"fixedFields": [
"fieldID": "EN_FAST_VOUT_INTEGRATION",
"value": 1
"fieldID": "EN_I_BALANCE_INTEGRATOR",
"value": 1
"fieldID": "DIS_PFM_WAITS_LS_DETECTOR",
"value": 0
"fieldID": "DIS_PFM_WAITS_HS_DETECTOR",
"value": 0
"fieldID": "DIS_DVS_WAIT_COMPARATORS",
"value": 0
"fieldID": "EN_SLOW_PLL_0P3",
"value": 1
"fieldID": "EN_CONSTANT_PLL_DVS_COEFF",
"value": 0
"hideFields": [
"EN_SLOW_PLL_0P3"
"fields": [
"EN_SLOW_PLL_0P3"
"regID": "BUCK_CONFIG_DIGITAL_9",
"fixedFields": [
"fieldID": "EN_M_10M_TRAN_DETECTOR",
"value": 1
"fieldID": "EN_LS_AFTER_HIZ",
"value": 0
"fieldID": "EN_PWM_LS_DETECTION",
"value": 0
"fieldID": "I_COEFF",
"value": 1
"fieldID": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES",
"value": 1
"hideFields": [
"EN_LS_AFTER_HIZ",
"I_COEFF",
"fields": [
"EN_LS_AFTER_HIZ",
"I_COEFF",
"regID": "BUCK_CONFIG_DIGITAL_10",
"fixedFields": [
"fieldID": "BUCK_NEG_ILIM",
"value": 1
"fieldID": "EN_ADAPTIVE_SINGLE_SHOT",
"value": 1
"hideFields": [
"BUCK_NEG_ILIM",
"fields": [
"BUCK_NEG_ILIM",
"regID": "BUCK_CONFIG_DIGITAL_11",
"fixedFields": [
"fieldID": "FIXED_SS_LENGTH",
"value": 24
"fieldID": "LONG_SINGLE_SHOT",
"value": 1
"hideFields": [
"FIXED_SS_LENGTH",
"LONG_SINGLE_SHOT"
"fields": [
"FIXED_SS_LENGTH",
"LONG_SINGLE_SHOT"
"registerJSON": {
"regblocks": [
"id": "UserRegisters1-user_mem",
"registers": [
"id": "DEV_REV",
"value": 0,
"fields": [
"id": "ASIL_QM",
"value": "0",
"staticConfig": true,
"isTouched": false
"id": "DEVICE_GPN",
"value": "0",
"isTouched": false
"id": "GRADE",
"value": "0",
"isTouched": false
"id": "NVM_CODE_1",
"value": 0,
"fields": [
"id": "TI_NVM_ID",
"value": "0",
"isTouched": false
"id": "NVM_CODE_2",
"value": 0,
"fields": [
"id": "TI_NVM_REV",
"value": "0",
"isTouched": false
"id": "BUCK1_CTRL",
"value": 38,
"fields": [
"id": "BUCK1_EN",
"value": 0,
"isTouched": false
"id": "BUCK1_FPWM",
"value": "1",
"isTouched": false
"id": "BUCK1_FPWM_MP",
"value": "1",
"isTouched": false
"id": "BUCK1_VMON_EN",
"value": 0,
"isTouched": false
"id": "BUCK1_VSEL",
"value": "0",
"isTouched": false
"id": "BUCK1_PLDN",
"value": 1,
"isTouched": false
"id": "BUCK1_RV_SEL",
"value": "0",
"isTouched": false
"id": "BUCK1_CONF",
"value": 26,
"fields": [
"id": "BUCK1_SLEW_RATE",
"value": "2",
"isTouched": false
"id": "BUCK1_ILIM",
"value": "3",
"isTouched": false
"id": "BUCK2_CTRL",
"value": 34,
"fields": [
"id": "BUCK2_EN",
"value": 0,
"isTouched": false
"id": "BUCK2_FPWM",
"value": 1,
"isTouched": false
"id": "BUCK2_VMON_EN",
"value": 0,
"isTouched": false
"id": "BUCK2_VSEL",
"value": 0,
"isTouched": false
"id": "BUCK2_PLDN",
"value": 1,
"isTouched": false
"id": "BUCK2_RV_SEL",
"value": 0,
"isTouched": false
"id": "BUCK2_CONF",
"value": 26,
"fields": [
"id": "BUCK2_SLEW_RATE",
"value": 2,
"isTouched": false
"id": "BUCK2_ILIM",
"value": 3,
"isTouched": false
"id": "BUCK3_CTRL",
"value": 34,
"fields": [
"id": "BUCK3_EN",
"value": 0,
"isTouched": false
"id": "BUCK3_FPWM",
"value": "1",
"isTouched": false
"id": "BUCK3_FPWM_MP",
"value": "0",
"isTouched": false
"id": "BUCK3_VMON_EN",
"value": 0,
"isTouched": false
"id": "BUCK3_VSEL",
"value": "0",
"isTouched": false
"id": "BUCK3_PLDN",
"value": 1,
"isTouched": false
"id": "BUCK3_RV_SEL",
"value": "0",
"isTouched": false
"id": "BUCK3_CONF",
"value": 27,
"fields": [
"id": "BUCK3_SLEW_RATE",
"value": "3",
"isTouched": false
"id": "BUCK3_ILIM",
"value": "3",
"isTouched": false
"id": "BUCK4_CTRL",
"value": 34,
"fields": [
"id": "BUCK4_EN",
"value": 0,
"isTouched": false
"id": "BUCK4_FPWM",
"value": "1",
"isTouched": false
"id": "BUCK4_VMON_EN",
"value": 0,
"isTouched": false
"id": "BUCK4_VSEL",
"value": "0",
"isTouched": false
"id": "BUCK4_PLDN",
"value": 1,
"isTouched": false
"id": "BUCK4_RV_SEL",
"value": "0",
"isTouched": false
"id": "BUCK4_CONF",
"value": 33,
"fields": [
"id": "BUCK4_SLEW_RATE",
"value": "1",
"isTouched": false
"id": "BUCK4_ILIM",
"value": "4",
"isTouched": false
"id": "BUCK5_CTRL",
"value": 32,
"fields": [
"id": "BUCK5_EN",
"value": 0,
"isTouched": false
"id": "BUCK5_FPWM",
"value": "0",
"isTouched": false
"id": "BUCK5_VMON_EN",
"value": 0,
"isTouched": false
"id": "BUCK5_VSEL",
"value": "0",
"isTouched": false
"id": "BUCK5_PLDN",
"value": 1,
"isTouched": false
"id": "BUCK5_RV_SEL",
"value": "0",
"isTouched": false
"id": "BUCK5_CONF",
"value": 18,
"fields": [
"id": "BUCK5_SLEW_RATE",
"value": "2",
"isTouched": false
"id": "BUCK5_ILIM",
"value": "2",
"isTouched": false
"id": "BUCK1_VOUT_1",
"value": 125,
"fields": [
"id": "BUCK1_VSET1",
"value": "125",
"isTouched": false
"id": "BUCK1_VOUT_2",
"value": 0,
"fields": [
"id": "BUCK1_VSET2",
"value": "0",
"isTouched": false
"id": "BUCK2_VOUT_1",
"value": 125,
"fields": [
"id": "BUCK2_VSET1",
"value": 125,
"isTouched": false
"id": "BUCK2_VOUT_2",
"value": 0,
"fields": [
"id": "BUCK2_VSET2",
"value": 0,
"isTouched": false
"id": "BUCK3_VOUT_1",
"value": 15,
"fields": [
"id": "BUCK3_VSET1",
"value": "15",
"isTouched": false
"id": "BUCK3_VOUT_2",
"value": 0,
"fields": [
"id": "BUCK3_VSET2",
"value": "0",
"isTouched": false
"id": "BUCK4_VOUT_1",
"value": 178,
"fields": [
"id": "BUCK4_VSET1",
"value": "178",
"isTouched": false
"id": "BUCK4_VOUT_2",
"value": 0,
"fields": [
"id": "BUCK4_VSET2",
"value": "0",
"isTouched": false
"id": "BUCK5_VOUT_1",
"value": 0,
"fields": [
"id": "BUCK5_VSET1",
"value": "0",
"isTouched": false
"id": "BUCK5_VOUT_2",
"value": 0,
"fields": [
"id": "BUCK5_VSET2",
"value": "0",
"isTouched": false
"id": "BUCK1_PG_WINDOW",
"value": 0,
"fields": [
"id": "BUCK1_OV_THR",
"value": "0",
"isTouched": false
"id": "BUCK1_UV_THR",
"value": "0",
"isTouched": false
"id": "BUCK2_PG_WINDOW",
"value": 0,
"fields": [
"id": "BUCK2_OV_THR",
"value": 0,
"isTouched": false
"id": "BUCK2_UV_THR",
"value": 0,
"isTouched": false
"id": "BUCK3_PG_WINDOW",
"value": 0,
"fields": [
"id": "BUCK3_OV_THR",
"value": "0",
"isTouched": false
"id": "BUCK3_UV_THR",
"value": "0",
"isTouched": false
"id": "BUCK4_PG_WINDOW",
"value": 0,
"fields": [
"id": "BUCK4_OV_THR",
"value": "0",
"isTouched": false
"id": "BUCK4_UV_THR",
"value": "0",
"isTouched": false
"id": "BUCK5_PG_WINDOW",
"value": 0,
"fields": [
"id": "BUCK5_OV_THR",
"value": "0",
"isTouched": false
"id": "BUCK5_UV_THR",
"value": "0",
"isTouched": false
"id": "LDO1_CTRL",
"value": 0,
"fields": [
"id": "LDO1_EN",
"value": 0,
"isTouched": false
"id": "LDO1_PLDN",
"value": "0",
"isTouched": true
"id": "LDO1_VMON_EN",
"value": 0,
"isTouched": false
"id": "LDO1_RV_SEL",
"value": "0",
"isTouched": false
"id": "LDO1_SLOW_RAMP",
"value": "0",
"isTouched": false
"id": "LDO2_CTRL",
"value": 0,
"fields": [
"id": "LDO2_EN",
"value": 0,
"isTouched": false
"id": "LDO2_PLDN",
"value": "0",
"isTouched": false
"id": "LDO2_VMON_EN",
"value": 0,
"isTouched": false
"id": "LDO2_RV_SEL",
"value": "0",
"isTouched": false
"id": "LDO2_SLOW_RAMP",
"value": "0",
"isTouched": false
"id": "LDO3_CTRL",
"value": 0,
"fields": [
"id": "LDO3_EN",
"value": 0,
"isTouched": false
"id": "LDO3_PLDN",
"value": "0",
"isTouched": false
"id": "LDO3_VMON_EN",
"value": 0,
"isTouched": false
"id": "LDO3_RV_SEL",
"value": "0",
"isTouched": false
"id": "LDO3_SLOW_RAMP",
"value": "0",
"isTouched": false
"id": "LDO4_CTRL",
"value": 0,
"fields": [
"id": "LDO4_EN",
"value": 0,
"isTouched": false
"id": "LDO4_PLDN",
"value": "0",
"isTouched": false
"id": "LDO4_VMON_EN",
"value": 0,
"isTouched": false
"id": "LDO4_RV_SEL",
"value": "0",
"isTouched": false
"id": "LDO4_SLOW_RAMP",
"value": "0",
"isTouched": false
"id": "LDOINT_CTRL",
"value": "0",
"fields": [
"id": "LDOINT_DIS",
"value": "0",
"isTouched": false
"id": "LDORTC_CTRL",
"value": "0",
"fields": [
"id": "LDORTC_DIS",
"value": "0",
"isTouched": false
"id": "LDO1_VOUT",
"value": 84,
"fields": [
"id": "LDO1_VSET",
"value": "42",
"isTouched": false
"id": "LDO1_BYPASS",
"value": "0",
"isTouched": false
"id": "LDO2_VOUT",
"value": 56,
"fields": [
"id": "LDO2_VSET",
"value": "28",
"isTouched": false
"id": "LDO2_BYPASS",
"value": "0",
"isTouched": false
"id": "LDO3_VOUT",
"value": 8,
"fields": [
"id": "LDO3_VSET",
"value": "4",
"isTouched": false
"id": "LDO3_BYPASS",
"value": "0",
"isTouched": false
"id": "LDO4_VOUT",
"value": 32,
"fields": [
"id": "LDO4_VSET",
"value": "32",
"isTouched": false
"id": "LDO1_PG_WINDOW",
"value": 0,
"fields": [
"id": "LDO1_OV_THR",
"value": "0",
"isTouched": false
"id": "LDO1_UV_THR",
"value": "0",
"isTouched": false
"id": "LDO2_PG_WINDOW",
"value": 0,
"fields": [
"id": "LDO2_OV_THR",
"value": "0",
"isTouched": false
"id": "LDO2_UV_THR",
"value": "0",
"isTouched": false
"id": "LDO3_PG_WINDOW",
"value": 0,
"fields": [
"id": "LDO3_OV_THR",
"value": "0",
"isTouched": false
"id": "LDO3_UV_THR",
"value": "0",
"isTouched": false
"id": "LDO4_PG_WINDOW",
"value": 0,
"fields": [
"id": "LDO4_OV_THR",
"value": "0",
"isTouched": false
"id": "LDO4_UV_THR",
"value": "0",
"isTouched": false
"id": "VCCA_VMON_CTRL",
"value": 1,
"fields": [
"id": "VCCA_VMON_EN",
"value": "1",
"staticConfig": false,
"isTouched": false
"id": "VMON_DEGLITCH_SEL",
"value": "0",
"isTouched": false
"id": "VCCA_PG_WINDOW",
"value": 0,
"fields": [
"id": "VCCA_OV_THR",
"value": "0",
"isTouched": false
"id": "VCCA_UV_THR",
"value": "0",
"isTouched": false
"id": "VCCA_PG_SET",
"value": "0",
"isTouched": false
"id": "GPIO1_CONF",
"value": 8,
"fields": [
"id": "GPIO1_OD",
"value": "0",
"isTouched": true
"id": "GPIO1_DIR",
"value": "0",
"isTouched": false
"id": "GPIO1_SEL",
"value": "0",
"isTouched": true
"id": "GPIO1_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO1_PU_PD_EN",
"value": "1",
"isTouched": true
"id": "GPIO1_DEGLITCH_EN",
"value": "0",
"isTouched": true
"id": "GPIO2_CONF",
"value": 8,
"fields": [
"id": "GPIO2_OD",
"value": "0",
"isTouched": false
"id": "GPIO2_DIR",
"value": "0",
"isTouched": false
"id": "GPIO2_SEL",
"value": "0",
"isTouched": true
"id": "GPIO2_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO2_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO2_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO3_CONF",
"value": 8,
"fields": [
"id": "GPIO3_OD",
"value": "0",
"isTouched": false
"id": "GPIO3_DIR",
"value": "0",
"isTouched": false
"id": "GPIO3_SEL",
"value": "0",
"isTouched": false
"id": "GPIO3_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO3_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO3_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO4_CONF",
"value": 8,
"fields": [
"id": "GPIO4_OD",
"value": "0",
"isTouched": false
"id": "GPIO4_DIR",
"value": "0",
"isTouched": false
"id": "GPIO4_SEL",
"value": "0",
"isTouched": false
"id": "GPIO4_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO4_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO4_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO5_CONF",
"value": 8,
"fields": [
"id": "GPIO5_OD",
"value": "0",
"isTouched": false
"id": "GPIO5_DIR",
"value": "0",
"isTouched": false
"id": "GPIO5_SEL",
"value": "0",
"isTouched": false
"id": "GPIO5_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO5_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO5_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO6_CONF",
"value": 8,
"fields": [
"id": "GPIO6_OD",
"value": "0",
"isTouched": false
"id": "GPIO6_DIR",
"value": "0",
"isTouched": false
"id": "GPIO6_SEL",
"value": "0",
"isTouched": false
"id": "GPIO6_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO6_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO6_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO7_CONF",
"value": 8,
"fields": [
"id": "GPIO7_OD",
"value": "0",
"isTouched": false
"id": "GPIO7_DIR",
"value": "0",
"isTouched": false
"id": "GPIO7_SEL",
"value": "0",
"isTouched": false
"id": "GPIO7_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO7_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "GPIO7_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO8_CONF",
"value": 0,
"fields": [
"id": "GPIO8_OD",
"value": "0",
"isTouched": false
"id": "GPIO8_DIR",
"value": "0",
"isTouched": false
"id": "GPIO8_SEL",
"value": "0",
"isTouched": true
"id": "GPIO8_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO8_PU_PD_EN",
"value": "0",
"isTouched": false
"id": "GPIO8_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO9_CONF",
"value": 32,
"fields": [
"id": "GPIO9_OD",
"value": "0",
"isTouched": false
"id": "GPIO9_DIR",
"value": "0",
"isTouched": false
"id": "GPIO9_SEL",
"value": "1",
"isTouched": true
"id": "GPIO9_PU_SEL",
"value": "0",
"isTouched": false
"id": "GPIO9_PU_PD_EN",
"value": "0",
"isTouched": false
"id": "GPIO9_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO10_CONF",
"value": 0,
"fields": [
"id": "GPIO10_OD",
"value": "0",
"isTouched": false
"id": "GPIO10_DIR",
"value": "0",
"isTouched": false
"id": "GPIO10_SEL",
"value": "0",
"isTouched": true
"id": "GPIO10_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO10_PU_PD_EN",
"value": "0",
"isTouched": false
"id": "GPIO10_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "GPIO11_CONF",
"value": 64,
"fields": [
"id": "GPIO11_OD",
"value": "0",
"isTouched": false
"id": "GPIO11_DIR",
"value": "0",
"isTouched": false
"id": "GPIO11_SEL",
"value": "2",
"isTouched": true
"id": "GPIO11_PU_SEL",
"value": "0",
"isTouched": true
"id": "GPIO11_PU_PD_EN",
"value": "0",
"isTouched": true
"id": "GPIO11_DEGLITCH_EN",
"value": "0",
"isTouched": true
"id": "NPWRON_CONF",
"value": 12,
"fields": [
"id": "NPWRON_SEL",
"value": "0",
"isTouched": false
"id": "ENABLE_PU_SEL",
"value": "1",
"isTouched": false
"id": "ENABLE_PU_PD_EN",
"value": "1",
"isTouched": false
"id": "ENABLE_DEGLITCH_EN",
"value": "0",
"isTouched": false
"id": "ENABLE_POL",
"value": "0",
"isTouched": false
"id": "NRSTOUT_OD",
"value": "0",
"isTouched": false
"id": "GPIO_OUT_1",
"value": 0,
"fields": [
"id": "GPIO1_OUT",
"value": 0,
"isTouched": false
"id": "GPIO2_OUT",
"value": 0,
"isTouched": false
"id": "GPIO3_OUT",
"value": 0,
"isTouched": false
"id": "GPIO4_OUT",
"value": 0,
"isTouched": false
"id": "GPIO5_OUT",
"value": 0,
"isTouched": false
"id": "GPIO6_OUT",
"value": 0,
"isTouched": false
"id": "GPIO7_OUT",
"value": 0,
"isTouched": false
"id": "GPIO8_OUT",
"value": 0,
"isTouched": false
"id": "GPIO_OUT_2",
"value": 0,
"fields": [
"id": "GPIO9_OUT",
"value": 0,
"isTouched": false
"id": "GPIO10_OUT",
"value": 0,
"isTouched": false
"id": "GPIO11_OUT",
"value": 0,
"isTouched": false
"id": "GPIO_IN_1",
"value": "0",
"fields": [
"id": "GPIO1_IN",
"value": "0",
"isTouched": false
"id": "GPIO2_IN",
"value": "0",
"isTouched": false
"id": "GPIO3_IN",
"value": "0",
"isTouched": false
"id": "GPIO4_IN",
"value": "0",
"isTouched": false
"id": "GPIO5_IN",
"value": "0",
"isTouched": false
"id": "GPIO6_IN",
"value": "0",
"isTouched": false
"id": "GPIO7_IN",
"value": "0",
"isTouched": false
"id": "GPIO8_IN",
"value": "0",
"isTouched": false
"id": "GPIO_IN_2",
"value": "0",
"fields": [
"id": "GPIO9_IN",
"value": "0",
"isTouched": false
"id": "GPIO10_IN",
"value": "0",
"isTouched": false
"id": "GPIO11_IN",
"value": "0",
"isTouched": false
"id": "NPWRON_IN",
"value": "0",
"isTouched": false
"id": "RAIL_SEL_1",
"value": 0,
"fields": [
"id": "BUCK1_GRP_SEL",
"value": "0",
"isTouched": false
"id": "BUCK2_GRP_SEL",
"value": 0,
"isTouched": false
"id": "BUCK3_GRP_SEL",
"value": 0,
"isTouched": false
"id": "BUCK4_GRP_SEL",
"value": 0,
"isTouched": false
"id": "RAIL_SEL_2",
"value": 0,
"fields": [
"id": "BUCK5_GRP_SEL",
"value": "0",
"isTouched": false
"id": "LDO1_GRP_SEL",
"value": "0",
"isTouched": false
"id": "LDO2_GRP_SEL",
"value": "0",
"isTouched": false
"id": "LDO3_GRP_SEL",
"value": "0",
"isTouched": false
"id": "RAIL_SEL_3",
"value": 0,
"fields": [
"id": "LDO4_GRP_SEL",
"value": "0",
"isTouched": false
"id": "VCCA_GRP_SEL",
"value": "0",
"isTouched": false
"id": "FSM_TRIG_SEL_1",
"value": 0,
"fields": [
"id": "MCU_RAIL_TRIG",
"value": "0",
"isTouched": false
"id": "SOC_RAIL_TRIG",
"value": "0",
"isTouched": false
"id": "OTHER_RAIL_TRIG",
"value": "0",
"isTouched": false
"id": "SEVERE_ERR_TRIG",
"value": "0",
"isTouched": false
"id": "FSM_TRIG_SEL_2",
"value": 0,
"fields": [
"id": "MODERATE_ERR_TRIG",
"value": "0",
"isTouched": false
"id": "FSM_TRIG_MASK_1",
"value": 0,
"fields": [
"id": "GPIO1_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO1_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO2_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO2_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO3_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO3_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO4_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO4_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "FSM_TRIG_MASK_2",
"value": 0,
"fields": [
"id": "GPIO5_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO5_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO6_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO6_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO7_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO7_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO8_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO8_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "FSM_TRIG_MASK_3",
"value": 0,
"fields": [
"id": "GPIO9_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO9_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO10_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO10_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "GPIO11_FSM_MASK",
"value": "0",
"isTouched": false
"id": "GPIO11_FSM_MASK_POL",
"value": "0",
"isTouched": false
"id": "MASK_BUCK1_2",
"value": 0,
"fields": [
"id": "BUCK1_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "BUCK1_OV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK1_UV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK2_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "BUCK2_OV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK2_UV_MASK",
"value": "0",
"isTouched": false
"id": "MASK_BUCK3_4",
"value": 0,
"fields": [
"id": "BUCK3_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "BUCK3_OV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK3_UV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK4_OV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK4_UV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK4_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "MASK_BUCK5",
"value": 0,
"fields": [
"id": "BUCK5_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "BUCK5_OV_MASK",
"value": "0",
"isTouched": false
"id": "BUCK5_UV_MASK",
"value": "0",
"isTouched": false
"id": "MASK_LDO1_2",
"value": 0,
"fields": [
"id": "LDO1_OV_MASK",
"value": "0",
"isTouched": false
"id": "LDO1_UV_MASK",
"value": "0",
"isTouched": false
"id": "LDO2_OV_MASK",
"value": "0",
"isTouched": false
"id": "LDO2_UV_MASK",
"value": "0",
"isTouched": false
"id": "LDO1_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "LDO2_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "MASK_LDO3_4",
"value": 0,
"fields": [
"id": "LDO3_OV_MASK",
"value": "0",
"isTouched": false
"id": "LDO3_UV_MASK",
"value": "0",
"isTouched": false
"id": "LDO4_OV_MASK",
"value": "0",
"isTouched": false
"id": "LDO4_UV_MASK",
"value": "0",
"isTouched": false
"id": "LDO3_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "LDO4_ILIM_MASK",
"value": "0",
"isTouched": false
"id": "MASK_VMON",
"value": 0,
"fields": [
"id": "VCCA_OV_MASK",
"value": "0",
"isTouched": false
"id": "VCCA_UV_MASK",
"value": "0",
"isTouched": false
"id": "MASK_GPIO1_8_FALL",
"value": 0,
"fields": [
"id": "GPIO1_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO2_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO3_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO4_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO5_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO6_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO7_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO8_FALL_MASK",
"value": "0",
"isTouched": false
"id": "MASK_GPIO1_8_RISE",
"value": 0,
"fields": [
"id": "GPIO1_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO2_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO3_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO4_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO5_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO6_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO7_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO8_RISE_MASK",
"value": "0",
"isTouched": false
"id": "MASK_GPIO9_11",
"value": 0,
"fields": [
"id": "GPIO9_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO9_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO10_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO11_FALL_MASK",
"value": "0",
"isTouched": false
"id": "GPIO10_RISE_MASK",
"value": "0",
"isTouched": false
"id": "GPIO11_RISE_MASK",
"value": "0",
"isTouched": false
"id": "MASK_STARTUP",
"value": 0,
"fields": [
"id": "NPWRON_START_MASK",
"value": "0",
"isTouched": false
"id": "ENABLE_MASK",
"value": "0",
"isTouched": false
"id": "FSD_MASK",
"value": "0",
"isTouched": false
"id": "SOFT_REBOOT_MASK",
"value": "0",
"isTouched": false
"id": "MASK_MISC",
"value": 0,
"fields": [
"id": "TWARN_MASK",
"value": "0",
"isTouched": false
"id": "BIST_PASS_MASK",
"value": "0",
"isTouched": false
"id": "EXT_CLK_MASK",
"value": "0",
"isTouched": false
"id": "MASK_MODERATE_ERR",
"value": 0,
"fields": [
"id": "BIST_FAIL_MASK",
"value": "0",
"isTouched": false
"id": "REG_CRC_ERR_MASK",
"value": "0",
"isTouched": false
"id": "SPMI_ERR_MASK",
"value": "0",
"isTouched": false
"id": "NPWRON_LONG_MASK",
"value": "0",
"isTouched": false
"id": "NINT_READBACK_MASK",
"value": "0",
"isTouched": false
"id": "NRSTOUT_READBACK_MASK",
"value": "0",
"isTouched": false
"id": "MASK_FSM_ERR",
"value": 0,
"fields": [
"id": "IMM_SHUTDOWN_MASK",
"value": "0",
"isTouched": false
"id": "MCU_PWR_ERR_MASK",
"value": "0",
"isTouched": false
"id": "SOC_PWR_ERR_MASK",
"value": "0",
"isTouched": false
"id": "ORD_SHUTDOWN_MASK",
"value": "0",
"isTouched": false
"id": "MASK_COMM_ERR",
"value": 0,
"fields": [
"id": "COMM_FRM_ERR_MASK",
"value": "0",
"isTouched": false
"id": "COMM_CRC_ERR_MASK",
"value": "0",
"isTouched": false
"id": "COMM_ADR_ERR_MASK",
"value": "0",
"isTouched": false
"id": "I2C2_CRC_ERR_MASK",
"value": "0",
"isTouched": false
"id": "I2C2_ADR_ERR_MASK",
"value": "0",
"isTouched": false
"id": "MASK_READBACK_ERR",
"value": 0,
"fields": [
"id": "EN_DRV_READBACK_MASK",
"value": "0",
"isTouched": false
"id": "NRSTOUT_SOC_READBACK_MASK",
"value": "0",
"isTouched": false
"id": "MASK_ESM",
"value": 0,
"fields": [
"id": "ESM_SOC_PIN_MASK",
"value": "0",
"isTouched": false
"id": "ESM_SOC_RST_MASK",
"value": "0",
"isTouched": false
"id": "ESM_SOC_FAIL_MASK",
"value": "0",
"isTouched": false
"id": "ESM_MCU_PIN_MASK",
"value": "0",
"isTouched": false
"id": "ESM_MCU_RST_MASK",
"value": "0",
"isTouched": false
"id": "ESM_MCU_FAIL_MASK",
"value": "0",
"isTouched": false
"id": "INT_TOP",
"value": "0",
"fields": [
"id": "MODERATE_ERR_INT",
"value": "0",
"isTouched": false
"id": "GPIO_INT",
"value": "0",
"isTouched": false
"id": "SEVERE_ERR_INT",
"value": "0",
"isTouched": false
"id": "BUCK_INT",
"value": "0",
"isTouched": false
"id": "LDO_VMON_INT",
"value": "0",
"isTouched": false
"id": "FSM_ERR_INT",
"value": "0",
"isTouched": false
"id": "STARTUP_INT",
"value": "0",
"isTouched": false
"id": "MISC_INT",
"value": "0",
"isTouched": false
"id": "INT_BUCK",
"value": "0",
"fields": [
"id": "BUCK1_2_INT",
"value": "0",
"isTouched": false
"id": "BUCK3_4_INT",
"value": "0",
"isTouched": false
"id": "BUCK5_INT",
"value": "0",
"isTouched": false
"id": "INT_BUCK1_2",
"value": "0",
"fields": [
"id": "BUCK1_OV_INT",
"value": "0",
"isTouched": false
"id": "BUCK1_UV_INT",
"value": "0",
"isTouched": false
"id": "BUCK1_ILIM_INT",
"value": "0",
"isTouched": false
"id": "BUCK1_SC_INT",
"value": "0",
"isTouched": false
"id": "BUCK2_OV_INT",
"value": "0",
"isTouched": false
"id": "BUCK2_UV_INT",
"value": "0",
"isTouched": false
"id": "BUCK2_SC_INT",
"value": "0",
"isTouched": false
"id": "BUCK2_ILIM_INT",
"value": "0",
"isTouched": false
"id": "INT_BUCK3_4",
"value": "0",
"fields": [
"id": "BUCK3_OV_INT",
"value": "0",
"isTouched": false
"id": "BUCK3_UV_INT",
"value": "0",
"isTouched": false
"id": "BUCK3_ILIM_INT",
"value": "0",
"isTouched": false
"id": "BUCK3_SC_INT",
"value": "0",
"isTouched": false
"id": "BUCK4_OV_INT",
"value": "0",
"isTouched": false
"id": "BUCK4_UV_INT",
"value": "0",
"isTouched": false
"id": "BUCK4_SC_INT",
"value": "0",
"isTouched": false
"id": "BUCK4_ILIM_INT",
"value": "0",
"isTouched": false
"id": "INT_BUCK5",
"value": "0",
"fields": [
"id": "BUCK5_OV_INT",
"value": "0",
"isTouched": false
"id": "BUCK5_UV_INT",
"value": "0",
"isTouched": false
"id": "BUCK5_ILIM_INT",
"value": "0",
"isTouched": false
"id": "BUCK5_SC_INT",
"value": "0",
"isTouched": false
"id": "INT_LDO_VMON",
"value": "0",
"fields": [
"id": "LDO1_2_INT",
"value": "0",
"isTouched": false
"id": "LDO3_4_INT",
"value": "0",
"isTouched": false
"id": "VCCA_INT",
"value": "0",
"isTouched": false
"id": "INT_LDO1_2",
"value": "0",
"fields": [
"id": "LDO1_OV_INT",
"value": "0",
"isTouched": false
"id": "LDO1_UV_INT",
"value": "0",
"isTouched": false
"id": "LDO1_SC_INT",
"value": "0",
"isTouched": false
"id": "LDO2_OV_INT",
"value": "0",
"isTouched": false
"id": "LDO2_UV_INT",
"value": "0",
"isTouched": false
"id": "LDO2_SC_INT",
"value": "0",
"isTouched": false
"id": "LDO2_ILIM_INT",
"value": "0",
"isTouched": false
"id": "LDO1_ILIM_INT",
"value": "0",
"isTouched": false
"id": "INT_LDO3_4",
"value": "0",
"fields": [
"id": "LDO3_OV_INT",
"value": "0",
"isTouched": false
"id": "LDO3_UV_INT",
"value": "0",
"isTouched": false
"id": "LDO3_SC_INT",
"value": "0",
"isTouched": false
"id": "LDO4_OV_INT",
"value": "0",
"isTouched": false
"id": "LDO4_UV_INT",
"value": "0",
"isTouched": false
"id": "LDO4_SC_INT",
"value": "0",
"isTouched": false
"id": "LDO4_ILIM_INT",
"value": "0",
"isTouched": false
"id": "LDO3_ILIM_INT",
"value": "0",
"isTouched": false
"id": "INT_VMON",
"value": "0",
"fields": [
"id": "VCCA_OV_INT",
"value": "0",
"isTouched": false
"id": "VCCA_UV_INT",
"value": "0",
"isTouched": false
"id": "INT_GPIO",
"value": "0",
"fields": [
"id": "GPIO1_8_INT",
"value": "0",
"isTouched": false
"id": "GPIO9_INT",
"value": "0",
"isTouched": false
"id": "GPIO10_INT",
"value": "0",
"isTouched": false
"id": "GPIO11_INT",
"value": "0",
"isTouched": false
"id": "INT_GPIO1_8",
"value": "0",
"fields": [
"id": "GPIO1_INT",
"value": "0",
"isTouched": false
"id": "GPIO2_INT",
"value": "0",
"isTouched": false
"id": "GPIO3_INT",
"value": "0",
"isTouched": false
"id": "GPIO4_INT",
"value": "0",
"isTouched": false
"id": "GPIO5_INT",
"value": "0",
"isTouched": false
"id": "GPIO6_INT",
"value": "0",
"isTouched": false
"id": "GPIO7_INT",
"value": "0",
"isTouched": false
"id": "GPIO8_INT",
"value": "0",
"isTouched": false
"id": "INT_STARTUP",
"value": "0",
"fields": [
"id": "FSD_INT",
"value": "0",
"isTouched": false
"id": "NPWRON_START_INT",
"value": "0",
"isTouched": false
"id": "RTC_INT",
"value": "0",
"isTouched": false
"id": "ENABLE_INT",
"value": "0",
"isTouched": false
"id": "SOFT_REBOOT_INT",
"value": "0",
"isTouched": false
"id": "INT_MISC",
"value": "0",
"fields": [
"id": "EXT_CLK_INT",
"value": "0",
"isTouched": false
"id": "TWARN_INT",
"value": "0",
"isTouched": false
"id": "BIST_PASS_INT",
"value": "0",
"isTouched": false
"id": "INT_MODERATE_ERR",
"value": "0",
"fields": [
"id": "TSD_ORD_INT",
"value": "0",
"isTouched": false
"id": "BIST_FAIL_INT",
"value": "0",
"isTouched": false
"id": "SPMI_ERR_INT",
"value": "0",
"isTouched": false
"id": "REG_CRC_ERR_INT",
"value": "0",
"isTouched": false
"id": "NPWRON_LONG_INT",
"value": "0",
"isTouched": false
"id": "RECOV_CNT_INT",
"value": "0",
"isTouched": false
"id": "NINT_READBACK_INT",
"value": "0",
"isTouched": false
"id": "NRSTOUT_READBACK_INT",
"value": "0",
"isTouched": false
"id": "INT_SEVERE_ERR",
"value": "0",
"fields": [
"id": "TSD_IMM_INT",
"value": "0",
"isTouched": false
"id": "VCCA_OVP_INT",
"value": "0",
"isTouched": false
"id": "PFSM_ERR_INT",
"value": "0",
"isTouched": false
"id": "INT_FSM_ERR",
"value": "0",
"fields": [
"id": "IMM_SHUTDOWN_INT",
"value": "0",
"isTouched": false
"id": "MCU_PWR_ERR_INT",
"value": "0",
"isTouched": false
"id": "SOC_PWR_ERR_INT",
"value": "0",
"isTouched": false
"id": "ORD_SHUTDOWN_INT",
"value": "0",
"isTouched": false
"id": "COMM_ERR_INT",
"value": "0",
"isTouched": false
"id": "READBACK_ERR_INT",
"value": "0",
"isTouched": false
"id": "ESM_INT",
"value": "0",
"isTouched": false
"id": "WD_INT",
"value": "0",
"isTouched": false
"id": "INT_COMM_ERR",
"value": "0",
"fields": [
"id": "COMM_FRM_ERR_INT",
"value": "0",
"isTouched": false
"id": "COMM_CRC_ERR_INT",
"value": "0",
"isTouched": false
"id": "COMM_ADR_ERR_INT",
"value": "0",
"isTouched": false
"id": "I2C2_CRC_ERR_INT",
"value": "0",
"isTouched": false
"id": "I2C2_ADR_ERR_INT",
"value": "0",
"isTouched": false
"id": "INT_READBACK_ERR",
"value": "0",
"fields": [
"id": "NRSTOUT_SOC_READBACK_INT",
"value": "0",
"isTouched": false
"id": "EN_DRV_READBACK_INT",
"value": "0",
"isTouched": false
"id": "INT_ESM",
"value": "0",
"fields": [
"id": "ESM_MCU_RST_INT",
"value": "0",
"isTouched": false
"id": "ESM_MCU_FAIL_INT",
"value": "0",
"isTouched": false
"id": "ESM_MCU_PIN_INT",
"value": "0",
"isTouched": false
"id": "ESM_SOC_PIN_INT",
"value": "0",
"isTouched": false
"id": "ESM_SOC_RST_INT",
"value": "0",
"isTouched": false
"id": "ESM_SOC_FAIL_INT",
"value": "0",
"isTouched": false
"id": "STAT_BUCK1_2",
"value": "0",
"fields": [
"id": "BUCK1_OV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK1_UV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK1_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "BUCK2_OV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK2_UV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK2_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "STAT_BUCK3_4",
"value": "0",
"fields": [
"id": "BUCK3_OV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK3_UV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK3_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "BUCK4_OV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK4_UV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK4_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "STAT_BUCK5",
"value": "0",
"fields": [
"id": "BUCK5_OV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK5_UV_STAT",
"value": "0",
"isTouched": false
"id": "BUCK5_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "STAT_LDO1_2",
"value": "0",
"fields": [
"id": "LDO1_OV_STAT",
"value": "0",
"isTouched": false
"id": "LDO1_UV_STAT",
"value": "0",
"isTouched": false
"id": "LDO2_OV_STAT",
"value": "0",
"isTouched": false
"id": "LDO2_UV_STAT",
"value": "0",
"isTouched": false
"id": "LDO1_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "LDO2_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "STAT_LDO3_4",
"value": "0",
"fields": [
"id": "LDO3_OV_STAT",
"value": "0",
"isTouched": false
"id": "LDO3_UV_STAT",
"value": "0",
"isTouched": false
"id": "LDO4_OV_STAT",
"value": "0",
"isTouched": false
"id": "LDO4_UV_STAT",
"value": "0",
"isTouched": false
"id": "LDO3_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "LDO4_ILIM_STAT",
"value": "0",
"isTouched": false
"id": "STAT_VMON",
"value": "0",
"fields": [
"id": "VCCA_OV_STAT",
"value": "0",
"isTouched": false
"id": "VCCA_UV_STAT",
"value": "0",
"isTouched": false
"id": "STAT_STARTUP",
"value": "0",
"fields": [
"id": "ENABLE_STAT",
"value": "0",
"isTouched": false
"id": "STAT_MISC",
"value": "0",
"fields": [
"id": "EXT_CLK_STAT",
"value": "0",
"isTouched": false
"id": "TWARN_STAT",
"value": "0",
"isTouched": false
"id": "STAT_MODERATE_ERR",
"value": "0",
"fields": [
"id": "TSD_ORD_STAT",
"value": "0",
"isTouched": false
"id": "STAT_SEVERE_ERR",
"value": "0",
"fields": [
"id": "TSD_IMM_STAT",
"value": "0",
"isTouched": false
"id": "VCCA_OVP_STAT",
"value": "0",
"isTouched": false
"id": "STAT_READBACK_ERR",
"value": "0",
"fields": [
"id": "NRSTOUT_SOC_READBACK_STAT",
"value": "0",
"isTouched": false
"id": "EN_DRV_READBACK_STAT",
"value": "0",
"isTouched": false
"id": "NINT_READBACK_STAT",
"value": "0",
"isTouched": false
"id": "NRSTOUT_READBACK_STAT",
"value": "0",
"isTouched": false
"id": "PGOOD_SEL_1",
"value": 85,
"fields": [
"id": "PGOOD_SEL_BUCK1",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_BUCK2",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_BUCK3",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_BUCK4",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_2",
"value": 0,
"fields": [
"id": "PGOOD_SEL_BUCK5",
"value": "0",
"isTouched": false
"id": "PGOOD_SEL_3",
"value": 5,
"fields": [
"id": "PGOOD_SEL_LDO1",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_LDO2",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_LDO3",
"value": "0",
"isTouched": false
"id": "PGOOD_SEL_LDO4",
"value": "0",
"isTouched": false
"id": "PGOOD_SEL_4",
"value": 145,
"fields": [
"id": "PGOOD_SEL_VCCA",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_TDIE_WARN",
"value": "0",
"isTouched": false
"id": "PGOOD_SEL_NRSTOUT",
"value": "1",
"isTouched": false
"id": "PGOOD_SEL_NRSTOUT_SOC",
"value": "0",
"isTouched": false
"id": "PGOOD_POL",
"value": "0",
"isTouched": false
"id": "PGOOD_WINDOW",
"value": "1",
"isTouched": false
"id": "PLL_CTRL",
"value": 0,
"fields": [
"id": "EXT_CLK_FREQ",
"value": "0",
"isTouched": false
"id": "CONFIG_1",
"value": 0,
"fields": [
"id": "TWARN_LEVEL",
"value": "0",
"isTouched": false
"id": "I2C1_HS",
"value": "0",
"isTouched": false
"id": "I2C2_HS",
"value": "0",
"isTouched": false
"id": "EN_ILIM_FSM_CTRL",
"value": "0",
"isTouched": false
"id": "NSLEEP1_MASK",
"value": "0",
"isTouched": false
"id": "NSLEEP2_MASK",
"value": "0",
"isTouched": false
"id": "TSD_ORD_LEVEL",
"value": "0",
"isTouched": false
"id": "CONFIG_2",
"value": 0,
"fields": [
"id": "BB_CHARGER_EN",
"value": "0",
"isTouched": false
"id": "BB_VEOC",
"value": "0",
"isTouched": false
"id": "BB_ICHR",
"value": "0",
"isTouched": false
"id": "BB_EOC_RDY",
"value": "0",
"isTouched": false
"id": "ENABLE_DRV_REG",
"value": "0",
"fields": [
"id": "ENABLE_DRV",
"value": "0",
"isTouched": false
"id": "MISC_CTRL",
"value": "0",
"fields": [
"id": "NRSTOUT",
"value": "0",
"isTouched": false
"id": "NRSTOUT_SOC",
"value": "0",
"isTouched": false
"id": "LPM_EN",
"value": "0",
"isTouched": false
"id": "CLKMON_EN",
"value": "0",
"isTouched": false
"id": "AMUXOUT_EN",
"value": "0",
"isTouched": false
"id": "SEL_EXT_CLK",
"value": "0",
"isTouched": false
"id": "SYNCCLKOUT_FREQ_SEL",
"value": "0",
"isTouched": false
"id": "ENABLE_DRV_STAT",
"value": "0",
"fields": [
"id": "EN_DRV_IN",
"value": "0",
"isTouched": false
"id": "NRSTOUT_IN",
"value": "0",
"isTouched": false
"id": "NRSTOUT_SOC_IN",
"value": "0",
"isTouched": false
"id": "FORCE_EN_DRV_LOW",
"value": "0",
"isTouched": false
"id": "SPMI_LPM_EN",
"value": "0",
"isTouched": false
"id": "RECOV_CNT_REG_1",
"value": "0",
"fields": [
"id": "RECOV_CNT",
"value": "0",
"isTouched": false
"id": "RECOV_CNT_REG_2",
"value": 0,
"fields": [
"id": "RECOV_CNT_THR",
"value": "0",
"isTouched": false
"id": "RECOV_CNT_CLR",
"value": "0",
"isTouched": false
"id": "FSM_I2C_TRIGGERS",
"value": "0",
"fields": [
"id": "TRIGGER_I2C_1",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_2",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_3",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_4",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_5",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_6",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_7",
"value": "0",
"isTouched": false
"id": "TRIGGER_I2C_0",
"value": "0",
"isTouched": false
"id": "FSM_NSLEEP_TRIGGERS",
"value": "0",
"fields": [
"id": "NSLEEP1B",
"value": "0",
"isTouched": false
"id": "NSLEEP2B",
"value": "0",
"isTouched": false
"id": "BUCK_RESET_REG",
"value": 0,
"fields": [
"id": "BUCK1_RESET",
"value": 0,
"isTouched": false
"id": "BUCK2_RESET",
"value": 0,
"isTouched": false
"id": "BUCK3_RESET",
"value": 0,
"isTouched": false
"id": "BUCK4_RESET",
"value": 0,
"isTouched": false
"id": "BUCK5_RESET",
"value": 0,
"isTouched": false
"id": "SPREAD_SPECTRUM_1",
"value": 0,
"fields": [
"id": "SS_EN",
"value": "0",
"isTouched": false
"id": "SS_DEPTH",
"value": "0",
"isTouched": false
"id": "FREQ_SEL",
"value": 11,
"fields": [
"id": "BUCK1_FREQ_SEL",
"value": 1,
"isTouched": false
"id": "BUCK2_FREQ_SEL",
"value": 1,
"isTouched": false
"id": "BUCK3_FREQ_SEL",
"value": 0,
"isTouched": false
"id": "BUCK4_FREQ_SEL",
"value": 1,
"isTouched": false
"id": "BUCK5_FREQ_SEL",
"value": 0,
"isTouched": false
"id": "FSM_STEP_SIZE",
"value": 9,
"fields": [
"id": "PFSM_DELAY_STEP",
"value": 9,
"isTouched": false
"id": "LDO_RV_TIMEOUT_REG_1",
"value": 0,
"fields": [
"id": "LDO1_RV_TIMEOUT",
"value": "0",
"isTouched": false
"id": "LDO2_RV_TIMEOUT",
"value": "0",
"isTouched": false
"id": "LDO_RV_TIMEOUT_REG_2",
"value": 0,
"fields": [
"id": "LDO3_RV_TIMEOUT",
"value": "0",
"isTouched": false
"id": "LDO4_RV_TIMEOUT",
"value": "0",
"isTouched": false
"id": "USER_SPARE_REGS",
"value": 0,
"fields": [
"id": "USER_SPARE_1",
"value": 0,
"isTouched": false
"id": "USER_SPARE_2",
"value": 0,
"isTouched": false
"id": "USER_SPARE_3",
"value": 0,
"isTouched": false
"id": "USER_SPARE_4",
"value": 0,
"isTouched": false
"id": "ESM_MCU_START_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_START",
"value": "0",
"isTouched": false
"id": "ESM_MCU_DELAY1_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_DELAY1",
"value": "0",
"isTouched": false
"id": "ESM_MCU_DELAY2_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_DELAY2",
"value": "0",
"isTouched": false
"id": "ESM_MCU_MODE_CFG",
"value": 0,
"fields": [
"id": "ESM_MCU_ERR_CNT_TH",
"value": "0",
"isTouched": false
"id": "ESM_MCU_ENDRV",
"value": "0",
"isTouched": false
"id": "ESM_MCU_EN",
"value": 0,
"isTouched": false
"id": "ESM_MCU_MODE",
"value": "0",
"isTouched": false
"id": "ESM_MCU_HMAX_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_HMAX",
"value": "0",
"isTouched": false
"id": "ESM_MCU_HMIN_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_HMIN",
"value": "0",
"isTouched": false
"id": "ESM_MCU_LMAX_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_LMAX",
"value": "0",
"isTouched": false
"id": "ESM_MCU_LMIN_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_LMIN",
"value": "0",
"isTouched": false
"id": "ESM_MCU_ERR_CNT_REG",
"value": "0",
"fields": [
"id": "ESM_MCU_ERR_CNT",
"value": "0",
"isTouched": false
"id": "ESM_SOC_START_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_START",
"value": "0",
"isTouched": false
"id": "ESM_SOC_DELAY1_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_DELAY1",
"value": "0",
"isTouched": false
"id": "ESM_SOC_DELAY2_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_DELAY2",
"value": "0",
"isTouched": false
"id": "ESM_SOC_MODE_CFG",
"value": 0,
"fields": [
"id": "ESM_SOC_ERR_CNT_TH",
"value": "0",
"isTouched": false
"id": "ESM_SOC_ENDRV",
"value": "0",
"isTouched": false
"id": "ESM_SOC_EN",
"value": 0,
"isTouched": false
"id": "ESM_SOC_MODE",
"value": "0",
"isTouched": false
"id": "ESM_SOC_HMAX_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_HMAX",
"value": "0",
"isTouched": false
"id": "ESM_SOC_HMIN_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_HMIN",
"value": "0",
"isTouched": false
"id": "ESM_SOC_LMAX_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_LMAX",
"value": "0",
"isTouched": false
"id": "ESM_SOC_LMIN_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_LMIN",
"value": "0",
"isTouched": false
"id": "ESM_SOC_ERR_CNT_REG",
"value": "0",
"fields": [
"id": "ESM_SOC_ERR_CNT",
"value": "0",
"isTouched": false
"id": "REGISTER_LOCK",
"value": "0",
"fields": [
"id": "REGISTER_LOCK_STATUS",
"value": "0",
"isTouched": false
"id": "USER_EE_CTRL_1",
"value": "0",
"fields": [
"id": "USER_EE_PROG_UNLOCK_SEQ",
"value": "0",
"isTouched": false
"id": "USER_EE_CTRL_2",
"value": "0",
"fields": [
"id": "USER_PROG_ALLOWED",
"value": 1,
"isTouched": false
"id": "USER_PROG_UNLOCKED",
"value": 1,
"isTouched": false
"id": "EE_PROG_USER",
"value": 0,
"isTouched": false
"id": "EE_PROG_PFSM",
"value": 0,
"isTouched": false
"id": "EE_PROG_STATUS",
"value": 0,
"isTouched": false
"id": "EE_PROG_MODE",
"value": 0,
"isTouched": false
"id": "SRAM_ADDR_CTRL",
"value": 0,
"fields": [
"id": "SRAM_SEL",
"value": 0,
"isTouched": false
"id": "RECOV_CNT_PFSM_INCR",
"value": "0",
"fields": [
"id": "INCREMENT_RECOV_CNT",
"value": "0",
"isTouched": false
"id": "MANUFACTURING_VER",
"value": "0",
"fields": [
"id": "SILICON_REV",
"value": "0",
"isTouched": false
"id": "CUSTOMER_NVM_ID_REG",
"value": 18,
"fields": [
"id": "CUSTOMER_NVM_ID",
"value": 18,
"isTouched": false
"id": "SOFT_REBOOT_REG",
"value": "0",
"fields": [
"id": "SOFT_REBOOT",
"value": "0",
"isTouched": false
"id": "UserRegisters2-user_mem",
"registers": [
"id": "RTC_SECONDS",
"value": "0",
"fields": [
"id": "SECOND_0",
"value": "0",
"isTouched": false
"id": "SECOND_1",
"value": "0",
"isTouched": false
"id": "RTC_MINUTES",
"value": "0",
"fields": [
"id": "MINUTE_0",
"value": "0",
"isTouched": false
"id": "MINUTE_1",
"value": "0",
"isTouched": false
"id": "RTC_HOURS",
"value": "0",
"fields": [
"id": "HOUR_0",
"value": "0",
"isTouched": false
"id": "HOUR_1",
"value": "0",
"isTouched": false
"id": "PM_NAM",
"value": "0",
"isTouched": false
"id": "RTC_DAYS",
"value": "0",
"fields": [
"id": "DAY_0",
"value": "0",
"isTouched": false
"id": "DAY_1",
"value": "0",
"isTouched": false
"id": "RTC_MONTHS",
"value": "0",
"fields": [
"id": "MONTH_0",
"value": "0",
"isTouched": false
"id": "MONTH_1",
"value": "0",
"isTouched": false
"id": "RTC_YEARS",
"value": "0",
"fields": [
"id": "YEAR_0",
"value": "0",
"isTouched": false
"id": "YEAR_1",
"value": "0",
"isTouched": false
"id": "RTC_WEEKS",
"value": "0",
"fields": [
"id": "WEEK",
"value": "0",
"isTouched": false
"id": "ALARM_SECONDS",
"value": "0",
"fields": [
"id": "ALR_SECOND_0",
"value": "0",
"isTouched": false
"id": "ALR_SECOND_1",
"value": "0",
"isTouched": false
"id": "ALARM_MINUTES",
"value": "0",
"fields": [
"id": "ALR_MINUTE_0",
"value": "0",
"isTouched": false
"id": "ALR_MINUTE_1",
"value": "0",
"isTouched": false
"id": "ALARM_HOURS",
"value": "0",
"fields": [
"id": "ALR_HOUR_0",
"value": "0",
"isTouched": false
"id": "ALR_HOUR_1",
"value": "0",
"isTouched": false
"id": "ALR_PM_NAM",
"value": "0",
"isTouched": false
"id": "ALARM_DAYS",
"value": "0",
"fields": [
"id": "ALR_DAY_0",
"value": "0",
"isTouched": false
"id": "ALR_DAY_1",
"value": "0",
"isTouched": false
"id": "ALARM_MONTHS",
"value": "0",
"fields": [
"id": "ALR_MONTH_0",
"value": "0",
"isTouched": false
"id": "ALR_MONTH_1",
"value": "0",
"isTouched": false
"id": "ALARM_YEARS",
"value": "0",
"fields": [
"id": "ALR_YEAR_0",
"value": "0",
"isTouched": false
"id": "ALR_YEAR_1",
"value": "0",
"isTouched": false
"id": "RTC_CTRL_1",
"value": "0",
"fields": [
"id": "STOP_RTC",
"value": "0",
"isTouched": false
"id": "ROUND_30S",
"value": "0",
"isTouched": false
"id": "AUTO_COMP",
"value": "0",
"isTouched": false
"id": "MODE_12_24",
"value": "0",
"isTouched": false
"id": "SET_32_COUNTER",
"value": "0",
"isTouched": false
"id": "GET_TIME",
"value": "0",
"isTouched": false
"id": "RTC_V_OPT",
"value": "0",
"isTouched": false
"id": "RTC_CTRL_2",
"value": 104,
"fields": [
"id": "XTAL_EN",
"value": "0",
"isTouched": false
"id": "LP_STANDBY_SEL",
"value": "1",
"isTouched": false
"id": "FAST_BIST",
"value": "0",
"isTouched": false
"id": "STARTUP_DEST",
"value": "3",
"isTouched": false
"id": "FIRST_STARTUP_DONE",
"value": "0",
"isTouched": false
"id": "XTAL_SEL",
"value": "0",
"isTouched": false
"id": "RTC_STATUS",
"value": "0",
"fields": [
"id": "RUN",
"value": "0",
"isTouched": false
"id": "TIMER",
"value": "0",
"isTouched": false
"id": "ALARM",
"value": "0",
"isTouched": false
"id": "POWER_UP",
"value": "0",
"isTouched": false
"id": "RTC_INTERRUPTS",
"value": "0",
"fields": [
"id": "EVERY",
"value": "0",
"isTouched": false
"id": "IT_TIMER",
"value": "0",
"isTouched": false
"id": "IT_ALARM",
"value": "0",
"isTouched": false
"id": "RTC_COMP_LSB",
"value": "0",
"fields": [
"id": "COMP_LSB_RTC",
"value": "0",
"isTouched": false
"id": "RTC_COMP_MSB",
"value": "0",
"fields": [
"id": "COMP_MSB_RTC",
"value": "0",
"isTouched": false
"id": "RTC_RESET_STATUS",
"value": "0",
"fields": [
"id": "RESET_STATUS_RTC",
"value": "0",
"isTouched": false
"id": "SCRATCH_PAD_REG_1",
"value": "0",
"fields": [
"id": "SCRATCH_PAD_1",
"value": "0",
"isTouched": false
"id": "SCRATCH_PAD_REG_2",
"value": "0",
"fields": [
"id": "SCRATCH_PAD_2",
"value": "0",
"isTouched": false
"id": "SCRATCH_PAD_REG_3",
"value": "0",
"fields": [
"id": "SCRATCH_PAD_3",
"value": "0",
"isTouched": false
"id": "SCRATCH_PAD_REG_4",
"value": "0",
"fields": [
"id": "SCRATCH_PAD_4",
"value": "0",
"isTouched": false
"id": "PFSM_DELAY_REG_1",
"value": 0,
"fields": [
"id": "PFSM_DELAY1",
"value": "0",
"isTouched": false
"id": "PFSM_DELAY_REG_2",
"value": 0,
"fields": [
"id": "PFSM_DELAY2",
"value": "0",
"isTouched": false
"id": "PFSM_DELAY_REG_3",
"value": 0,
"fields": [
"id": "PFSM_DELAY3",
"value": "0",
"isTouched": false
"id": "PFSM_DELAY_REG_4",
"value": 0,
"fields": [
"id": "PFSM_DELAY4",
"value": "0",
"isTouched": false
"id": "RTS_SPARE_REG",
"value": 0,
"fields": [
"id": "RTC_SPARE_0",
"value": "0",
"isTouched": false
"id": "RTC_SPARE_1",
"value": "0",
"isTouched": false
"id": "RTC_SPARE_2",
"value": "0",
"isTouched": false
"id": "RTC_SPARE_3",
"value": "0",
"isTouched": false
"id": "CRCRegisters-user_mem",
"registers": [
"id": "CRC_CALC_CONTROL",
"value": "0",
"fields": [
"id": "RUN_CRC_BIST",
"value": "0",
"isTouched": false
"id": "RUN_CRC_UPDATE",
"value": "0",
"isTouched": false
"id": "CRC_1",
"value": 0,
"fields": [
"id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_2",
"value": 0,
"fields": [
"id": "REGMAP_USER_INCLUDE_PERSIST_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_3",
"value": 0,
"fields": [
"id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_4",
"value": 0,
"fields": [
"id": "REGMAP_USER_EXCLUDE_PERSIST_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_5",
"value": 0,
"fields": [
"id": "REGMAP_CONFIG_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_6",
"value": 0,
"fields": [
"id": "REGMAP_CONFIG_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_7",
"value": 0,
"fields": [
"id": "SRAM_BANK0_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_8",
"value": 0,
"fields": [
"id": "SRAM_BANK0_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_9",
"value": 0,
"fields": [
"id": "SRAM_BANK1_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_10",
"value": 0,
"fields": [
"id": "SRAM_BANK1_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_11",
"value": 0,
"fields": [
"id": "SRAM_BANK2_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_12",
"value": 0,
"fields": [
"id": "SRAM_BANK2_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "CRC_15",
"value": 0,
"fields": [
"id": "REGMAP_TRIM_CRC16_LOW",
"value": "0",
"isTouched": false
"id": "CRC_16",
"value": 0,
"fields": [
"id": "REGMAP_TRIM_CRC16_HIGH",
"value": "0",
"isTouched": false
"id": "ConfigRegisters-user_mem",
"registers": [
"id": "BUCK_CONFIG_ANALOG_0",
"value": 2,
"fields": [
"id": "SEL_LOOP_NEG_HYST",
"value": 2,
"isTouched": false
"id": "SEL_GATE_EARLY_SENSE",
"value": 0,
"isTouched": false
"id": "SEL_TRAD_NON_OVERLAP",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_1",
"value": 83,
"fields": [
"id": "SEL_FB_FILTER",
"value": 3,
"isTouched": false
"id": "BUCK1_SEL_NEG_OCP_HYST",
"value": 0,
"isTouched": false
"id": "BUCK2_SEL_NEG_OCP_HYST",
"value": 0,
"isTouched": false
"id": "BUCK3_SEL_NEG_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK4_SEL_NEG_OCP_HYST",
"value": 0,
"isTouched": false
"id": "BUCK5_SEL_NEG_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_2",
"value": 1,
"fields": [
"id": "SEL_RAMP_ARTIF",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_3",
"value": 3,
"fields": [
"id": "BUCK1_SEL_ISENSE_SLOPE_COMPENSATION",
"value": 3,
"isTouched": false
"id": "BUCK1_SEL_VOUT_ADC_LEVEL",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_4",
"value": 3,
"fields": [
"id": "BUCK2_SEL_ISENSE_SLOPE_COMPENSATION",
"value": 3,
"isTouched": false
"id": "BUCK2_SEL_VOUT_ADC_LEVEL",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_5",
"value": 2,
"fields": [
"id": "BUCK3_SEL_ISENSE_SLOPE_COMPENSATION",
"value": 2,
"isTouched": false
"id": "BUCK3_SEL_VOUT_ADC_LEVEL",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_6",
"value": 3,
"fields": [
"id": "BUCK4_SEL_ISENSE_SLOPE_COMPENSATION",
"value": 3,
"isTouched": false
"id": "BUCK4_SEL_VOUT_ADC_LEVEL",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_7",
"value": 2,
"fields": [
"id": "BUCK5_SEL_ISENSE_SLOPE_COMPENSATION",
"value": 2,
"isTouched": false
"id": "BUCK5_SEL_VOUT_ADC_LEVEL",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_ANALOG_8",
"value": 0,
"fields": [
"id": "EN_SW_RT_SHORT_DETECTORS",
"value": 0,
"isTouched": false
"id": "EN_IAVE_LOOP_INJECTOR",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_RADAR",
"value": 0,
"fields": [
"id": "BUCK1_EN_RADAR_MODE",
"value": 0,
"isTouched": false
"id": "BUCK2_EN_RADAR_MODE",
"value": 0,
"isTouched": false
"id": "BUCK3_EN_RADAR_MODE",
"value": 0,
"isTouched": false
"id": "BUCK4_EN_RADAR_MODE",
"value": 0,
"isTouched": false
"id": "BUCK5_EN_RADAR_MODE",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_0",
"value": 84,
"fields": [
"id": "BUCK1_SEL_PHASE_SHEDD",
"value": 0,
"isTouched": false
"id": "BUCK1_SEL_PHASE_ADD",
"value": 1,
"isTouched": false
"id": "BUCK3_SEL_PHASE_SHEDD",
"value": 0,
"isTouched": false
"id": "BUCK3_SEL_PHASE_ADD",
"value": 1,
"isTouched": false
"id": "EN_LOAD_COMP_BLANK",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_1",
"value": 127,
"fields": [
"id": "EN_PLL_PROP_EXTEND",
"value": 1,
"isTouched": false
"id": "EN_SMART_OCP_BLANK",
"value": 1,
"isTouched": false
"id": "BUCK1_SEL_POS_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK2_SEL_POS_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK3_SEL_POS_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK4_SEL_POS_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK5_SEL_POS_OCP_HYST",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_2",
"value": 12,
"fields": [
"id": "SEL_HS_DETECTOR",
"value": 1,
"isTouched": false
"id": "EN_LONG_PFM_EXIT_CNTR",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_3",
"value": 51,
"fields": [
"id": "EN_NEG_OCP",
"value": 1,
"isTouched": false
"id": "EN_POS_OCP",
"value": 1,
"isTouched": false
"id": "EN_PFM_LOAD",
"value": 1,
"isTouched": false
"id": "EN_DOT_MODE",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_4",
"value": 85,
"fields": [
"id": "BUCK1_SEL_OUTPUT_CAPS",
"value": 1,
"isTouched": false
"id": "BUCK2_SEL_OUTPUT_CAPS",
"value": 1,
"isTouched": false
"id": "BUCK3_SEL_OUTPUT_CAPS",
"value": 1,
"isTouched": false
"id": "BUCK4_SEL_OUTPUT_CAPS",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_5",
"value": 109,
"fields": [
"id": "BUCK5_SEL_OUTPUT_CAPS",
"value": 1,
"isTouched": false
"id": "LOOP_COEFF_I_BALANCE",
"value": 1,
"isTouched": false
"id": "SEL_ZERO_CROSS_FILTER_AVE",
"value": 1,
"isTouched": false
"id": "EN_AUTO_LOOP_COEFFS",
"value": 1,
"isTouched": false
"id": "LOOP_COEFF_FB_MSB",
"value": 1,
"isTouched": false
"id": "EN_LONG_ZERO_CROSS_FILTER",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_6",
"value": 42,
"fields": [
"id": "FORCE_SS_ADAPT",
"value": 0,
"isTouched": false
"id": "BUCK1_SEL_RAMP",
"value": 1,
"isTouched": false
"id": "BUCK2_SEL_RAMP",
"value": 1,
"isTouched": false
"id": "EN_PFM_PULSE_WAIT_LS_OCP",
"value": 1,
"isTouched": false
"id": "EN_SLOW_PLL_COEFFS",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_7",
"value": 213,
"fields": [
"id": "BUCK3_SEL_RAMP",
"value": 1,
"isTouched": false
"id": "BUCK4_SEL_RAMP",
"value": 1,
"isTouched": false
"id": "BUCK5_SEL_RAMP",
"value": 1,
"isTouched": false
"id": "EN_SW_SHORT_DETECTORS",
"value": 1,
"isTouched": false
"id": "EN_FAST_PLL_0P7",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_8",
"value": 131,
"fields": [
"id": "EN_FAST_VOUT_INTEGRATION",
"value": 1,
"isTouched": false
"id": "EN_I_BALANCE_INTEGRATOR",
"value": 1,
"isTouched": false
"id": "DIS_PFM_WAITS_LS_DETECTOR",
"value": 0,
"isTouched": false
"id": "DIS_PFM_WAITS_HS_DETECTOR",
"value": 0,
"isTouched": false
"id": "DIS_DVS_WAIT_COMPARATORS",
"value": 0,
"isTouched": false
"id": "EN_CONSTANT_PLL_DVS_COEFF",
"value": 0,
"isTouched": false
"id": "EN_SLOW_PLL_0P3",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_9",
"value": 35,
"fields": [
"id": "EN_M_10M_TRAN_DETECTOR",
"value": 1,
"isTouched": false
"id": "EN_FAST_INTEGRATION_BYPASS_RAMP_RES",
"value": 1,
"isTouched": false
"id": "EN_LS_AFTER_HIZ",
"value": 0,
"isTouched": false
"id": "EN_PWM_LS_DETECTION",
"value": 0,
"isTouched": false
"id": "I_COEFF",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_10",
"value": 9,
"fields": [
"id": "BUCK_NEG_ILIM",
"value": 1,
"isTouched": false
"id": "EN_ADAPTIVE_SINGLE_SHOT",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_11",
"value": 56,
"fields": [
"id": "FIXED_SS_LENGTH",
"value": 24,
"isTouched": false
"id": "LONG_SINGLE_SHOT",
"value": 1,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_12",
"value": 0,
"fields": [
"id": "BUCK1_FREQ_8MHZ",
"value": 0,
"isTouched": false
"id": "BUCK2_FREQ_8MHZ",
"value": 0,
"isTouched": false
"id": "BUCK3_FREQ_8MHZ",
"value": 0,
"isTouched": false
"id": "BUCK4_FREQ_8MHZ",
"value": 0,
"isTouched": false
"id": "BUCK5_FREQ_8MHZ",
"value": 0,
"isTouched": false
"id": "GENERAL_REG_0",
"value": 1,
"fields": [
"id": "EN_OVP",
"value": 1,
"isTouched": false
"id": "DIS_UVLO_OVP_RESET",
"value": 0,
"isTouched": false
"id": "DIS_TSD",
"value": 0,
"isTouched": false
"id": "FAST_BOOT_BIST",
"value": "0",
"isTouched": false
"id": "VSYS_DEAD_LOCK_EN",
"value": "0",
"isTouched": false
"id": "PFSM_ERR_RESET_DIS",
"value": 0,
"isTouched": false
"id": "VMON_ABIST_EN",
"value": "0",
"isTouched": false
"id": "ABIST_ERROR_MASK",
"value": 0,
"isTouched": false
"id": "GENERAL_REG_1",
"value": 5,
"fields": [
"id": "MAX_ILIM",
"value": 5,
"isTouched": false
"id": "FREQ_SEL_UNLOCK",
"value": 0,
"isTouched": false
"id": "REG_CRC_EN",
"value": "0",
"isTouched": false
"id": "EN_INITIALIZE_DPLL_RESTART",
"value": 0,
"isTouched": false
"id": "PFSM_ERR_MASK",
"value": 0,
"isTouched": false
"id": "FAST_VCCA_OVP",
"value": "0",
"isTouched": false
"id": "GENERAL_REG_2",
"value": 128,
"fields": [
"id": "DIS_NRSTOUT_MCU_I2C_SPI_RESET",
"value": 0,
"isTouched": false
"id": "SLOW_AUTOZERO_SEL",
"value": 0,
"isTouched": false
"id": "EN_FIXED_DPLL_FREQ",
"value": 0,
"isTouched": false
"id": "SEL_RC_OSC",
"value": 0,
"isTouched": false
"id": "DISABLE_VM_NARROW_LIMITS",
"value": 0,
"isTouched": false
"id": "DISABLE_CHANGE_BG",
"value": 0,
"isTouched": false
"id": "DISABLE_USE_TRIMS",
"value": 0,
"isTouched": false
"id": "WD_EN_EE",
"value": 1,
"isTouched": false
"id": "SERIAL_IF_CONFIG",
"value": 2,
"fields": [
"id": "I2C_SPI_SEL",
"value": "0",
"isTouched": true
"id": "I2C1_SPI_CRC_EN",
"value": "1",
"isTouched": true
"id": "I2C2_CRC_EN",
"value": "0",
"isTouched": true
"id": "SPMI_CONFIG_1",
"value": 11,
"fields": [
"id": "SPMI_CRC_EN",
"value": 1,
"isTouched": false
"id": "SPMI_MASTER_SEL",
"value": 1,
"isTouched": false
"id": "SPMI_CLK_SEL",
"value": 2,
"isTouched": false
"id": "SPMI_SLAVE_PASSIVE",
"value": 0,
"isTouched": false
"id": "SPMI_CONFIG_2",
"value": 22,
"fields": [
"id": "SPMI_IF_SEL",
"value": 0,
"isTouched": false
"id": "SPMI_RETRY_LIMIT",
"value": 3,
"isTouched": false
"id": "SPMI_SLAVE_ASR_HOLD",
"value": 0,
"isTouched": false
"id": "SPMI_WD_AUTO_BOOT",
"value": 1,
"isTouched": false
"id": "SPMI_EN",
"value": 0,
"isTouched": false
"id": "SPMI_WD_EN",
"value": 0,
"isTouched": false
"id": "SPMI_WAKEUP_EN",
"value": 0,
"isTouched": false
"id": "SPMI_CONFIG_3",
"value": 136,
"fields": [
"id": "SPMI_WD_BOOT_INTERVAL",
"value": 8,
"isTouched": false
"id": "SPMI_WD_RUNTIME_INTERVAL",
"value": 8,
"isTouched": false
"id": "SPMI_CONFIG_4",
"value": 136,
"fields": [
"id": "SPMI_WD_RESPONSE_TIMEOUT",
"value": 8,
"isTouched": false
"id": "SPMI_PFSM_RESPONSE_TIMEOUT",
"value": 8,
"isTouched": false
"id": "SPMI_CONFIG_5",
"value": 136,
"fields": [
"id": "SPMI_WD_BOOT_BIST_TIMEOUT",
"value": 8,
"isTouched": false
"id": "SPMI_WD_RUNTIME_BIST_TIMEOUT",
"value": 8,
"isTouched": false
"id": "SPMI_CONFIG_6",
"value": 0,
"fields": [
"id": "BOOT_DELAY",
"value": 0,
"isTouched": false
"id": "SPMI_ID",
"value": 5,
"fields": [
"id": "SPMI_SID",
"value": 5,
"isTouched": false
"id": "SPMI_MID",
"value": 0,
"isTouched": false
"id": "I2C1_ID_REG",
"value": 72,
"fields": [
"id": "I2C1_ID",
"value": "72",
"isTouched": true
"id": "I2C2_ID_REG",
"value": 18,
"fields": [
"id": "I2C2_ID",
"value": "18",
"isTouched": false
"id": "CLOCK_REQS",
"value": 0,
"fields": [
"id": "FORCE_CLK_GATE",
"value": 0,
"isTouched": false
"id": "INT_LDO_PD_FORCE",
"value": 0,
"isTouched": false
"id": "LDO1_PD_FORCE",
"value": 0,
"isTouched": false
"id": "LDO2_PD_FORCE",
"value": 0,
"isTouched": false
"id": "LDO3_PD_FORCE",
"value": 0,
"isTouched": false
"id": "LDO4_PD_FORCE",
"value": 0,
"isTouched": false
"id": "PHASE_CONFIG",
"value": 2,
"fields": [
"id": "MP_CONFIG",
"value": "2",
"isTouched": false
"id": "SPMI_SLAVE_COUNT",
"value": 1,
"fields": [
"id": "SPMI_SLAVE_CNT",
"value": 1,
"isTouched": false
"id": "PFSM_CONFIG",
"value": 9,
"fields": [
"id": "PFSM_SEQ_MIN_TIME",
"value": 1,
"isTouched": false
"id": "SRAM_RELOAD_LIMIT",
"value": 2,
"isTouched": false
"id": "PFSM_PROXY_BRANCH_DIS",
"value": 0,
"isTouched": false
"id": "GENERAL_REG_3",
"value": 1,
"fields": [
"id": "LPM_EN_DISABLES_VCCA_VMON",
"value": 1,
"isTouched": false
"id": "XCOORD_REG",
"value": "0",
"fields": [
"id": "XCOORD",
"value": "0",
"isTouched": false
"id": "YCOORD_REG",
"value": "0",
"fields": [
"id": "YCOORD",
"value": "0",
"isTouched": false
"id": "WAFERNUM_REG",
"value": "0",
"fields": [
"id": "WAFERNUM",
"value": "0",
"isTouched": false
"id": "WAFERLOTNUM_REG_1",
"value": "0",
"fields": [
"id": "WAFERLOTNUM_23_16",
"value": "0",
"isTouched": false
"id": "WAFERLOTNUM_REG_2",
"value": "0",
"fields": [
"id": "WAFERLOTNUM_15_8",
"value": "0",
"isTouched": false
"id": "WAFERLOTNUM_REG_3",
"value": "0",
"fields": [
"id": "WAFERLOTNUM_7_0",
"value": "0",
"isTouched": false
"id": "WAFERFAB_REG",
"value": "0",
"fields": [
"id": "WAFERFAB",
"value": "0",
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_13",
"value": 11,
"fields": [
"id": "BUCK1_EN_P_10M_BODY_DIODE",
"value": 1,
"isTouched": false
"id": "BUCK2_EN_P_10M_BODY_DIODE",
"value": 1,
"isTouched": false
"id": "BUCK3_EN_P_10M_BODY_DIODE",
"value": 0,
"isTouched": false
"id": "BUCK4_EN_P_10M_BODY_DIODE",
"value": 1,
"isTouched": false
"id": "BUCK5_EN_P_10M_BODY_DIODE",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_14",
"value": 0,
"fields": [
"id": "BUCK1_DOUBLE_PFM_PULSE",
"value": 0,
"isTouched": false
"id": "BUCK2_DOUBLE_PFM_PULSE",
"value": 0,
"isTouched": false
"id": "BUCK3_DOUBLE_PFM_PULSE",
"value": 0,
"isTouched": false
"id": "BUCK4_DOUBLE_PFM_PULSE",
"value": 0,
"isTouched": false
"id": "BUCK5_DOUBLE_PFM_PULSE",
"value": 0,
"isTouched": false
"id": "BUCK_CONFIG_DIGITAL_15",
"value": 20,
"fields": [
"id": "BUCK1_CHANGE_2MHZ_BELOW_0V5",
"value": 0,
"isTouched": false
"id": "BUCK2_CHANGE_2MHZ_BELOW_0V5",
"value": 0,
"isTouched": false
"id": "BUCK3_CHANGE_2MHZ_BELOW_0V5",
"value": 1,
"isTouched": false
"id": "BUCK4_CHANGE_2MHZ_BELOW_0V5",
"value": 0,
"isTouched": false
"id": "BUCK5_CHANGE_2MHZ_BELOW_0V5",
"value": 1,
"isTouched": false
"id": "SPREAD_SPECTRUM_CONFIG_1",
"value": 1,
"fields": [
"id": "SS_MODE",
"value": 1,
"isTouched": false
"id": "SPREAD_SPECTRUM_CONFIG_2",
"value": 199,
"fields": [
"id": "SS_PARAM1",
"value": 7,
"isTouched": false
"id": "SS_PARAM2",
"value": 12,
"isTouched": false
"id": "USER_EE_PROG_UNLOCK",
"value": 0,
"fields": [
"id": "USER_EE_PROG_UNLOCK_CODE",
"value": "0",
"isTouched": false
"id": "INT_CONFIG_0",
"value": 0,
"fields": [
"id": "refsys_bg_buf_hi_bw",
"value": 0,
"isTouched": false
"id": "refsys_sel_ibias",
"value": 0,
"isTouched": false
"id": "SAFETY_CONFIG_0",
"value": 1,
"fields": [
"id": "safety_speedup",
"value": 1,
"isTouched": false
"id": "safety_sel_ibias",
"value": 0,
"isTouched": false
"id": "safety_bg_buf_hi_bw",
"value": 0,
"isTouched": false
"id": "VM_VSYS_CONFIG_0",
"value": "0",
"fields": [
"id": "vm_vsys_dummy_bit",
"value": "0",
"isTouched": false
"id": "RTC_CONFIG_0",
"value": 83,
"fields": [
"id": "xtal_amp_reg_en",
"value": 1,
"isTouched": false
"id": "xtal_amp_reg_mode",
"value": 1,
"isTouched": false
"id": "xtal_comp_bias_lvl",
"value": 0,
"isTouched": false
"id": "xtal_bias_fine",
"value": 10,
"isTouched": false
"id": "LDO1_3_FILT_CONFIG_0",
"value": 0,
"fields": [
"id": "vbg_filt_config",
"value": 0,
"isTouched": false
"id": "LDO1_CONFIG_0",
"value": 0,
"fields": [
"id": "ldo1_en_short_cp",
"value": 0,
"isTouched": false
"id": "ldo1_dis_short_prot",
"value": 0,
"isTouched": false
"id": "ldo1_dis_ilim",
"value": 0,
"isTouched": false
"id": "ldo1_dis_cp_leak_comp",
"value": 0,
"staticConfig": true,
"isTouched": false
"id": "ldo1_en_cp_low_sr",
"value": 0,
"isTouched": false
"id": "ldo1_dis_ov_pldn",
"value": 0,
"isTouched": false
"id": "LDO2_CONFIG_0",
"value": 0,
"fields": [
"id": "ldo2_en_short_cp",
"value": 0,
"isTouched": false
"id": "ldo2_dis_short_prot",
"value": 0,
"isTouched": false
"id": "ldo2_dis_ilim",
"value": 0,
"isTouched": false
"id": "ldo2_dis_cp_leak_comp",
"value": 0,
"isTouched": false
"id": "ldo2_en_cp_low_sr",
"value": 0,
"isTouched": false
"id": "ldo2_dis_ov_pldn",
"value": 0,
"isTouched": false
"id": "LDO3_CONFIG_0",
"value": 0,
"fields": [
"id": "ldo3_en_short_cp",
"value": 0,
"isTouched": false
"id": "ldo3_dis_short_prot",
"value": 0,
"isTouched": false
"id": "ldo3_dis_ilim",
"value": 0,
"isTouched": false
"id": "ldo3_dis_cp_leak_comp",
"value": 0,
"isTouched": false
"id": "ldo3_en_cp_low_sr",
"value": 0,
"isTouched": false
"id": "ldo3_dis_ov_pldn",
"value": 0,
"isTouched": false
"id": "LDO4_CONFIG_0",
"value": 6,
"fields": [
"id": "ldo4_sel_low_ilim",
"value": 0,
"isTouched": false
"id": "ldo4_filter_current",
"value": 3,
"isTouched": false
"id": "TestRegisters-tm_mem",
"registers": [
"id": "TEST_MODE_LOCK",
"value": "0",
"fields": [
"id": "TM_UNLOCK_CODE",
"value": "0",
"isTouched": false
"id": "TEST_MODE_STATUS",
"value": "0",
"fields": [
"id": "debug_mode",
"value": "0",
"isTouched": false
"id": "test_mode",
"value": "0",
"isTouched": false
"id": "TEST_SET_SCAN_MODE",
"value": "0",
"fields": [
"id": "SET_SCAN_MODE",
"value": "0",
"isTouched": false
"id": "SET_SCAN_OVST_MODE",
"value": "0",
"isTouched": false
"id": "DMUX1_CTRL_1",
"value": "0",
"fields": [
"id": "TM_DMUX1_MAIN_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX1_INV",
"value": "0",
"isTouched": false
"id": "TM_DMUX1_MODE",
"value": "0",
"isTouched": false
"id": "DMUX1_CTRL_2",
"value": "0",
"fields": [
"id": "TM_DMUX1_SUB_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX1_DIV",
"value": "0",
"isTouched": false
"id": "DMUX2_CTRL_1",
"value": "0",
"fields": [
"id": "TM_DMUX2_MAIN_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX2_INV",
"value": "0",
"isTouched": false
"id": "TM_DMUX2_MODE",
"value": "0",
"isTouched": false
"id": "DMUX2_CTRL_2",
"value": "0",
"fields": [
"id": "TM_DMUX2_SUB_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX2_DIV",
"value": "0",
"isTouched": false
"id": "DMUX3_CTRL_1",
"value": "0",
"fields": [
"id": "TM_DMUX3_MAIN_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX3_INV",
"value": "0",
"isTouched": false
"id": "TM_DMUX3_MODE",
"value": "0",
"isTouched": false
"id": "DMUX3_CTRL_2",
"value": "0",
"fields": [
"id": "TM_DMUX3_SUB_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX3_DIV",
"value": "0",
"isTouched": false
"id": "DMUX4_CTRL_1",
"value": "0",
"fields": [
"id": "TM_DMUX4_MAIN_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX4_INV",
"value": "0",
"isTouched": false
"id": "TM_DMUX4_MODE",
"value": "0",
"isTouched": false
"id": "DMUX4_CTRL_2",
"value": "0",
"fields": [
"id": "TM_DMUX4_SUB_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX4_DIV",
"value": "0",
"isTouched": false
"id": "DMUX5_CTRL_1",
"value": "0",
"fields": [
"id": "TM_DMUX5_MAIN_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX5_INV",
"value": "0",
"isTouched": false
"id": "TM_DMUX5_MODE",
"value": "0",
"isTouched": false
"id": "DMUX5_CTRL_2",
"value": "0",
"fields": [
"id": "TM_DMUX5_SUB_SEL",
"value": "0",
"isTouched": false
"id": "TM_DMUX5_DIV",
"value": "0",
"isTouched": false
"id": "TEST_REG_8",
"value": "0",
"fields": [
"id": "NINT_TX_DIS",
"value": "0",
"isTouched": false
"id": "USE_TRIMS",
"value": "0",
"isTouched": false
"id": "VM_NARROW_LIMITS",
"value": "0",
"isTouched": false
"id": "NINT_TX",
"value": "0",
"isTouched": false
"id": "CHANGE_BG",
"value": "0",
"isTouched": false
"id": "START_ABIST",
"value": "0",
"isTouched": false
"id": "TEST_REG_9",
"value": "0",
"fields": [
"id": "BUCK1_MODE",
"value": "0",
"isTouched": false
"id": "TEST_REG_10",
"value": "0",
"fields": [
"id": "BUCK2_MODE",
"value": "0",
"isTouched": false
"id": "TEST_REG_11",
"value": "0",
"fields": [
"id": "BUCK3_MODE",
"value": "0",
"isTouched": false
"id": "TEST_REG_12",
"value": "0",
"fields": [
"id": "BUCK4_MODE",
"value": "0",
"isTouched": false
"id": "TEST_REG_13",
"value": "0",
"fields": [
"id": "BUCK5_MODE",
"value": "0",
"isTouched": false
"id": "TEST_REG_14",
"value": "0",
"fields": [
"id": "BUCK1_VSET_MSB",
"value": "0",
"isTouched": false
"id": "TEST_SINGLE_SHOT",
"value": "0",
"isTouched": false
"id": "BUCK2_VSET_MSB",
"value": "0",
"isTouched": false
"id": "BUCK3_VSET_MSB",
"value": "0",
"isTouched": false
"id": "BUCK4_VSET_MSB",
"value": "0",
"isTouched": false
"id": "BUCK5_VSET_MSB",
"value": "0",
"isTouched": false
"id": "TEST_REG_15",
"value": "0",
"fields": [
"id": "LDO_EE_EN",
"value": "0",
"isTouched": false
"id": "LDO_EE_PLDN",
"value": "0",
"isTouched": false
"id": "BG_XMON_EN",
"value": "0",
"isTouched": false
"id": "SAFETY_EN_REFS",
"value": "0",
"isTouched": false
"id": "TEST_WLBI_MODE",
"value": "0",
"isTouched": false
"id": "TEST_RTC_LDO_UVLO_DIS",
"value": "0",
"isTouched": false
"id": "TEST_REG_16",
"value": "0",
"fields": [
"id": "TSD_FORCE",
"value": "0",
"isTouched": false
"id": "TSD_SEL_THRESHOLD",
"value": "0",
"isTouched": false
"id": "TSD_SEL_SENSOR",
"value": "0",
"isTouched": false
"id": "TEST_SPMI_1",
"value": "0",
"fields": [
"id": "TM_SPMI_TX_PAYLOAD",
"value": "0",
"isTouched": false
"id": "TEST_SPMI_2",
"value": "0",
"fields": [
"id": "TM_SPMI_TX_ADDRESS",
"value": "0",
"isTouched": false
"id": "TEST_SPMI_5",
"value": "0",
"fields": [
"id": "TM_SPMI_TEST_MODE",
"value": "0",
"isTouched": false
"id": "TM_SPMI_TX_REQ",
"value": "0",
"isTouched": false
"id": "TM_SPMI_TX_REQ_HIGH",
"value": "0",
"isTouched": false
"id": "TM_SPMI_TX_SLAVE_SEL",
"value": "0",
"isTouched": false
"id": "SPMI_TX_DONE",
"value": "0",
"isTouched": false
"id": "SPMI_RX_DONE",
"value": "0",
"isTouched": false
"id": "TEST_SPMI_6",
"value": "0",
"fields": [
"id": "SPMI_RX_CMD",
"value": "0",
"isTouched": false
"id": "TEST_SPMI_7",
"value": "0",
"fields": [
"id": "SPMI_RX_PAYLOAD",
"value": "0",
"isTouched": false
"id": "TEST_PFSM_0",
"value": "0",
"fields": [
"id": "pfsm_debug_trigger_id",
"value": "0",
"isTouched": false
"id": "pfsm_branch_self",
"value": "0",
"isTouched": false
"id": "op_ready",
"value": "0",
"isTouched": false
"id": "op_end",
"value": "0",
"isTouched": false
"id": "TEST_PFSM_1",
"value": "0",
"fields": [
"id": "FREEZE_PFSM",
"value": "0",
"isTouched": false
"id": "TM_PFSM_SINGLE_STEP_EN",
"value": "0",
"isTouched": false
"id": "TM_PFSM_SINGLE_STEP_PULSE",
"value": "0",
"isTouched": false
"id": "TM_PFSM_BREAKPOINT_EN",
"value": "0",
"isTouched": false
"id": "op_debug_halt",
"value": "0",
"isTouched": false
"id": "op_breakpoint_match",
"value": "0",
"isTouched": false
"id": "TEST_PFSM_2",
"value": "0",
"fields": [
"id": "TM_PFSM_BREAKPOINT_ADDRESS_12_8",
"value": "0",
"isTouched": false
"id": "TEST_PFSM_3",
"value": "0",
"fields": [
"id": "TM_PFSM_BREAKPOINT_ADDRESS_7_0",
"value": "0",
"isTouched": false
"id": "TEST_FFSM_1",
"value": "0",
"fields": [
"id": "fixed_fsm_state",
"value": "0",
"isTouched": false
"id": "TEST_FFSM_2",
"value": "0",
"fields": [
"id": "next_fixed_fsm_state",
"value": "0",
"isTouched": false
"id": "force_fixed_fsm_state",
"value": "0",
"isTouched": false
"id": "TEST_REG_29",
"value": "0",
"fields": [
"id": "LDO1_PD_DISABLE",
"value": "0",
"isTouched": false
"id": "LDO2_PD_DISABLE",
"value": "0",
"isTouched": false
"id": "LDO3_PD_DISABLE",
"value": "0",
"isTouched": false
"id": "LDO4_PD_DISABLE",
"value": "0",
"isTouched": false
"id": "LDO_INT_PLDN",
"value": "0",
"isTouched": false
"id": "TM_LDOINT_DIS",
"value": "0",
"isTouched": false
"id": "FORCE_AUTOZERO_LOW",
"value": "0",
"isTouched": false
"id": "FORCE_AUTOZERO_HIGH",
"value": "0",
"isTouched": false
"id": "TEST_REG_30",
"value": "0",
"fields": [
"id": "OSC_128KHZ_EN",
"value": "0",
"isTouched": false
"id": "DPLL_EN",
"value": "0",
"isTouched": false
"id": "OSC_52M8HZ_EN",
"value": "0",
"isTouched": false
"id": "OSC_20MHZ_EN",
"value": "0",
"isTouched": false
"id": "OSC_MONITOR_20MHZ_EN",
"value": "0",
"isTouched": false
"id": "TEST_SRAM_1",
"value": "0",
"fields": [
"id": "TM_SRAM_MARGIN0",
"value": "0",
"isTouched": false
"id": "TM_SRAM_MARGIN1",
"value": "0",
"isTouched": false
"id": "TEST_RTC_CAL_0",
"value": "0",
"fields": [
"id": "RTC_TEST_MODE1",
"value": "0",
"isTouched": false
"id": "RTC_TEST_MODE2",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_0",
"value": "0",
"fields": [
"id": "test_en_nint_cp_osc",
"value": "0",
"isTouched": false
"id": "test_en_atab_loop_cp",
"value": "0",
"isTouched": false
"id": "test_en_atab_loop_cp_current",
"value": "0",
"isTouched": false
"id": "test_en_drv_tx_dis",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_1",
"value": "0",
"fields": [
"id": "test_en_atab_1v8",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_3",
"value": "0",
"fields": [
"id": "test_en_atab_5v",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_4",
"value": "0",
"fields": [
"id": "test_en_kelvin_12_8",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_5",
"value": "0",
"fields": [
"id": "test_en_kelvin_7_0",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_6",
"value": "0",
"fields": [
"id": "test_en_atab_loop_rc",
"value": "0",
"isTouched": false
"id": "TEST_PADRING_7",
"value": "0",
"fields": [
"id": "TEST_PADRING_SPARE",
"value": "0",
"isTouched": false
"id": "test_dis_nint_cp_pd",
"value": "0",
"isTouched": false
"id": "TEST_VMVCCA_0",
"value": "0",
"fields": [
"id": "test_vmvcca_bg",
"value": "0",
"isTouched": false
"id": "test_vmvcca_vref_1v2",
"value": "0",
"isTouched": false
"id": "test_vmvcca_iptat",
"value": "0",
"isTouched": false
"id": "TEST_VMPVIN_0",
"value": "0",
"fields": [
"id": "test_vmpvin_bg",
"value": "0",
"isTouched": false
"id": "test_vmpvin_vref_1v2",
"value": "0",
"isTouched": false
"id": "test_vmpvin_iptat",
"value": "0",
"isTouched": false
"id": "TEST_INT_0",
"value": "0",
"fields": [
"id": "test_refsys_ibias",
"value": "0",
"isTouched": false
"id": "test_refsys_bg",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_en_vout_kelvin",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_en_ovst",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_pupd_hiz",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_en_ilim",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_en_ilim2",
"value": "0",
"isTouched": false
"id": "test_refsys_iptat",
"value": "0",
"isTouched": false
"id": "TEST_INT_1",
"value": "0",
"fields": [
"id": "test_refsys_bg_buffer",
"value": "0",
"isTouched": false
"id": "test_refsys_bg_buffer_en_hiz",
"value": "0",
"isTouched": false
"id": "test_refsys_amux_buffer_en_hiz",
"value": "0",
"isTouched": false
"id": "test_refsys_ldo_int_out_stage_dis",
"value": "0",
"isTouched": false
"id": "TEST_SAFETY_0",
"value": "0",
"fields": [
"id": "test_tsd",
"value": "0",
"isTouched": false
"id": "test_vmon_buck",
"value": "0",
"isTouched": false
"id": "TEST_SAFETY_1",
"value": "0",
"fields": [
"id": "test_safety_ibias",
"value": "0",
"isTouched": false
"id": "test_vmon_ldo",
"value": "0",
"isTouched": false
"id": "test_vmon_vcca",
"value": "0",
"isTouched": false
"id": "test_safety_bg_buffer_en_hiz",
"value": "0",
"isTouched": false
"id": "TEST_SAFETY_2",
"value": "0",
"fields": [
"id": "test_safety_bias_dist",
"value": "0",
"isTouched": false
"id": "test_safety_vref_1v2",
"value": "0",
"isTouched": false
"id": "test_tsd2",
"value": "0",
"isTouched": false
"id": "TEST_VM_VSYS_0",
"value": "0",
"fields": [
"id": "test_vsys_en_ovst",
"value": "0",
"isTouched": false
"id": "test_vsys_vdda_voltage",
"value": "0",
"isTouched": false
"id": "test_vsys_bg",
"value": "0",
"isTouched": false
"id": "test_vsys_ibias",
"value": "0",
"isTouched": false
"id": "test_vsys_cp_voltage",
"value": "0",
"isTouched": false
"id": "test_vsys_en_cp_osc",
"value": "0",
"isTouched": false
"id": "test_vsys_vref_ramp",
"value": "0",
"isTouched": false
"id": "test_vsys_dis_osc_and_vcca_pd",
"value": "0",
"isTouched": false
"id": "TEST_RTC_0",
"value": "0",
"fields": [
"id": "test_rtc_bg",
"value": "0",
"isTouched": false
"id": "test_rtc_force_int_on",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_en_ovst",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_pupd_hiz",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_en_ilim",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_en_ilim2",
"value": "0",
"isTouched": false
"id": "test_rtc_iptat",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_pldn",
"value": "0",
"isTouched": false
"id": "TEST_RTC_1",
"value": "0",
"fields": [
"id": "test_rtc_xtal",
"value": "0",
"isTouched": false
"id": "test_rtc_ldo_out_stage_dis",
"value": "0",
"isTouched": false
"id": "TEST_LDO1_3_FILT_0",
"value": "0",
"fields": [
"id": "vbg_filt_test",
"value": "0",
"isTouched": false
"id": "TEST_LDO1_0",
"value": "0",
"fields": [
"id": "ldo1_en_ovst",
"value": "0",
"isTouched": false
"id": "ldo1_en_unity_gain",
"value": "0",
"isTouched": false
"id": "ldo1_dis_ilim1",
"value": "0",
"isTouched": false
"id": "ldo1_dis_ilim2",
"value": "0",
"isTouched": false
"id": "ldo1_en_hiz",
"value": "0",
"isTouched": false
"id": "ldo1_en_ldo_vref",
"value": "0",
"isTouched": false
"id": "ldo1_en_ldo_vref_hiz",
"value": "0",
"isTouched": false
"id": "ldo1_en_ilim_trim",
"value": "0",
"isTouched": false
"id": "TEST_LDO1_1",
"value": "0",
"fields": [
"id": "ldo1_cp_test_sel",
"value": "0",
"isTouched": false
"id": "ldo1_en_cp_test_mode",
"value": "0",
"isTouched": false
"id": "TEST_LDO2_0",
"value": "0",
"fields": [
"id": "ldo2_en_ovst",
"value": "0",
"isTouched": false
"id": "ldo2_en_unity_gain",
"value": "0",
"isTouched": false
"id": "ldo2_dis_ilim1",
"value": "0",
"isTouched": false
"id": "ldo2_dis_ilim2",
"value": "0",
"isTouched": false
"id": "ldo2_en_hiz",
"value": "0",
"isTouched": false
"id": "ldo2_en_ldo_vref",
"value": "0",
"isTouched": false
"id": "ldo2_en_ldo_vref_hiz",
"value": "0",
"isTouched": false
"id": "ldo2_en_ilim_trim",
"value": "0",
"isTouched": false
"id": "TEST_LDO2_1",
"value": "0",
"fields": [
"id": "ldo2_cp_test_sel",
"value": "0",
"isTouched": false
"id": "ldo2_en_cp_test_mode",
"value": "0",
"isTouched": false
"id": "TEST_LDO3_0",
"value": "0",
"fields": [
"id": "ldo3_en_ovst",
"value": "0",
"isTouched": false
"id": "ldo3_en_unity_gain",
"value": "0",
"isTouched": false
"id": "ldo3_dis_ilim1",
"value": "0",
"isTouched": false
"id": "ldo3_dis_ilim2",
"value": "0",
"isTouched": false
"id": "ldo3_en_hiz",
"value": "0",
"isTouched": false
"id": "ldo3_en_ldo_vref",
"value": "0",
"isTouched": false
"id": "ldo3_en_ldo_vref_hiz",
"value": "0",
"isTouched": false
"id": "ldo3_en_ilim_trim",
"value": "0",
"isTouched": false
"id": "TEST_LDO3_1",
"value": "0",
"fields": [
"id": "ldo3_cp_test_sel",
"value": "0",
"isTouched": false
"id": "ldo3_en_cp_test_mode",
"value": "0",
"isTouched": false
"id": "TEST_LDO4_0",
"value": "0",
"fields": [
"id": "ldo4_test_en_ilim",
"value": "0",
"isTouched": false
"id": "ldo4_test_en_ilim2",
"value": "0",
"isTouched": false
"id": "ldo4_en_ovst",
"value": "0",
"isTouched": false
"id": "ldo4_en_kelvin",
"value": "0",
"isTouched": false
"id": "ldo4_en_hiz",
"value": "0",
"isTouched": false
"id": "ldo4_en_ovst2",
"value": "0",
"isTouched": false
"id": "ldo4_test_en_faster_trim",
"value": "0",
"isTouched": false
"id": "TEST_EE_LDO_0",
"value": "0",
"fields": [
"id": "test_dft_iddq_scale",
"value": "0",
"isTouched": false
"id": "test_en_tmux1_in",
"value": "0",
"isTouched": false
"id": "test_en_tmux2_in",
"value": "0",
"isTouched": false
"id": "TEST_BB_0",
"value": "0",
"fields": [
"id": "TEST_BB_SPARE",
"value": "0",
"isTouched": false
"id": "BUCK1_ATEST_REG_0",
"value": "0",
"fields": [
"id": "buck_atab_sel_1",
"value": "0",
"isTouched": false
"id": "test_integ_dac_short_output_1",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_1",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_pd_1",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_1",
"value": "0",
"isTouched": false
"id": "BUCK1_ATEST_REG_1",
"value": "0",
"fields": [
"id": "test_iave_1",
"value": "0",
"isTouched": false
"id": "test_hs_gate_1",
"value": "0",
"isTouched": false
"id": "test_ovst_1",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_pd_1",
"value": "0",
"isTouched": false
"id": "test_sw_short_detector_1",
"value": "0",
"isTouched": false
"id": "BUCK1_ATEST_REG_2",
"value": "0",
"fields": [
"id": "test_spare_1",
"value": "0",
"isTouched": false
"id": "BUCK1_DTEST_REG_0",
"value": 0,
"fields": [
"id": "buck_dtab0_sel_1",
"value": "0",
"staticConfig": false,
"isTouched": false
"id": "swc_buck_hs_1",
"value": "0",
"isTouched": false
"id": "swc_buck_hiz_1",
"value": 0,
"isTouched": false
"id": "force_pfm_1",
"value": "0",
"isTouched": false
"id": "BUCK1_DTEST_REG_1",
"value": "0",
"fields": [
"id": "buck_dtab1_sel_1",
"value": "0",
"isTouched": false
"id": "test_iave_pd_1",
"value": "0",
"isTouched": false
"id": "test_sample_izero_1",
"value": "0",
"isTouched": false
"id": "test_pulse_generator_1",
"value": "0",
"isTouched": false
"id": "BUCK1_DTEST_REG_2",
"value": "0",
"fields": [
"id": "test_buck_weak_driver_1",
"value": "0",
"isTouched": false
"id": "dis_loop_comp_hyst_1",
"value": "0",
"isTouched": false
"id": "dis_vref_filter_1",
"value": "0",
"isTouched": false
"id": "test_blank_1",
"value": "0",
"isTouched": false
"id": "test_single_shot_1",
"value": "0",
"isTouched": false
"id": "test_bypass_ramp_bias_res_1",
"value": "0",
"isTouched": false
"id": "BUCK1_DTEST_REG_3",
"value": "0",
"fields": [
"id": "test_integrator_word_1",
"value": "0",
"isTouched": false
"id": "BUCK1_DTEST_REG_4",
"value": "0",
"fields": [
"id": "test_carousel_ctrl_1",
"value": "0",
"isTouched": false
"id": "test_bypass_sw_latches_1",
"value": "0",
"isTouched": false
"id": "test_dis_autozero_1",
"value": "0",
"isTouched": false
"id": "test_pulse_gen_fixed_1",
"value": "0",
"isTouched": false
"id": "BUCK2_ATEST_REG_0",
"value": "0",
"fields": [
"id": "buck_atab_sel_2",
"value": "0",
"isTouched": false
"id": "test_integ_dac_short_output_2",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_2",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_pd_2",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_2",
"value": "0",
"isTouched": false
"id": "BUCK2_ATEST_REG_1",
"value": "0",
"fields": [
"id": "test_iave_2",
"value": "0",
"isTouched": false
"id": "test_hs_gate_2",
"value": "0",
"isTouched": false
"id": "test_ovst_2",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_pd_2",
"value": "0",
"isTouched": false
"id": "test_sw_short_detector_2",
"value": "0",
"isTouched": false
"id": "BUCK2_ATEST_REG_2",
"value": "0",
"fields": [
"id": "test_spare_2",
"value": "0",
"isTouched": false
"id": "BUCK2_DTEST_REG_0",
"value": 0,
"fields": [
"id": "buck_dtab0_sel_2",
"value": 0,
"isTouched": false
"id": "swc_buck_hs_2",
"value": 0,
"isTouched": false
"id": "swc_buck_hiz_2",
"value": 0,
"isTouched": false
"id": "force_pfm_2",
"value": 0,
"isTouched": false
"id": "BUCK2_DTEST_REG_1",
"value": "0",
"fields": [
"id": "buck_dtab1_sel_2",
"value": "0",
"isTouched": false
"id": "test_iave_pd_2",
"value": "0",
"isTouched": false
"id": "test_sample_izero_2",
"value": "0",
"isTouched": false
"id": "test_pulse_generator_2",
"value": "0",
"isTouched": false
"id": "BUCK2_DTEST_REG_2",
"value": "0",
"fields": [
"id": "dis_loop_comp_hyst_2",
"value": "0",
"isTouched": false
"id": "dis_vref_filter_2",
"value": "0",
"isTouched": false
"id": "test_blank_2",
"value": "0",
"isTouched": false
"id": "test_single_shot_2",
"value": "0",
"isTouched": false
"id": "test_buck_weak_driver_2",
"value": "0",
"isTouched": false
"id": "test_bypass_ramp_bias_res_2",
"value": "0",
"isTouched": false
"id": "BUCK2_DTEST_REG_3",
"value": "0",
"fields": [
"id": "test_integrator_word_2",
"value": "0",
"isTouched": false
"id": "BUCK2_DTEST_REG_4",
"value": "0",
"fields": [
"id": "test_carousel_ctrl_2",
"value": "0",
"isTouched": false
"id": "test_bypass_sw_latches_2",
"value": "0",
"isTouched": false
"id": "test_dis_autozero_2",
"value": "0",
"isTouched": false
"id": "test_pulse_gen_fixed_2",
"value": "0",
"isTouched": false
"id": "BUCK3_ATEST_REG_0",
"value": "0",
"fields": [
"id": "buck_atab_sel_3",
"value": "0",
"isTouched": false
"id": "test_integ_dac_short_output_3",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_3",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_pd_3",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_3",
"value": "0",
"isTouched": false
"id": "BUCK3_ATEST_REG_1",
"value": "0",
"fields": [
"id": "test_iave_3",
"value": "0",
"isTouched": false
"id": "test_hs_gate_3",
"value": "0",
"isTouched": false
"id": "test_ovst_3",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_pd_3",
"value": "0",
"isTouched": false
"id": "test_sw_short_detector_3",
"value": "0",
"isTouched": false
"id": "BUCK3_ATEST_REG_2",
"value": "0",
"fields": [
"id": "test_spare_3",
"value": "0",
"isTouched": false
"id": "BUCK3_DTEST_REG_0",
"value": 0,
"fields": [
"id": "buck_dtab0_sel_3",
"value": "0",
"isTouched": false
"id": "swc_buck_hs_3",
"value": "0",
"isTouched": false
"id": "swc_buck_hiz_3",
"value": 0,
"isTouched": false
"id": "force_pfm_3",
"value": "0",
"isTouched": false
"id": "BUCK3_DTEST_REG_1",
"value": "0",
"fields": [
"id": "buck_dtab1_sel_3",
"value": "0",
"isTouched": false
"id": "test_iave_pd_3",
"value": "0",
"isTouched": false
"id": "test_sample_izero_3",
"value": "0",
"isTouched": false
"id": "test_pulse_generator_3",
"value": "0",
"isTouched": false
"id": "BUCK3_DTEST_REG_2",
"value": "0",
"fields": [
"id": "dis_loop_comp_hyst_3",
"value": "0",
"isTouched": false
"id": "dis_vref_filter_3",
"value": "0",
"isTouched": false
"id": "test_blank_3",
"value": "0",
"isTouched": false
"id": "test_single_shot_3",
"value": "0",
"isTouched": false
"id": "test_buck_weak_driver_3",
"value": "0",
"isTouched": false
"id": "test_bypass_ramp_bias_res_3",
"value": "0",
"isTouched": false
"id": "BUCK3_DTEST_REG_3",
"value": "0",
"fields": [
"id": "test_integrator_word_3",
"value": "0",
"isTouched": false
"id": "BUCK3_DTEST_REG_4",
"value": "0",
"fields": [
"id": "test_carousel_ctrl_3",
"value": "0",
"isTouched": false
"id": "test_bypass_sw_latches_3",
"value": "0",
"isTouched": false
"id": "test_dis_autozero_3",
"value": "0",
"isTouched": false
"id": "test_pulse_gen_fixed_3",
"value": "0",
"isTouched": false
"id": "BUCK4_ATEST_REG_0",
"value": "0",
"fields": [
"id": "buck_atab_sel_4",
"value": "0",
"isTouched": false
"id": "test_integ_dac_short_output_4",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_4",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_pd_4",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_4",
"value": "0",
"isTouched": false
"id": "BUCK4_ATEST_REG_1",
"value": "0",
"fields": [
"id": "test_iave_4",
"value": "0",
"isTouched": false
"id": "test_hs_gate_4",
"value": "0",
"isTouched": false
"id": "test_ovst_4",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_pd_4",
"value": "0",
"isTouched": false
"id": "test_sw_short_detector_4",
"value": "0",
"isTouched": false
"id": "BUCK4_ATEST_REG_2",
"value": "0",
"fields": [
"id": "test_spare_4",
"value": "0",
"isTouched": false
"id": "BUCK4_DTEST_REG_0",
"value": 0,
"fields": [
"id": "buck_dtab0_sel_4",
"value": "0",
"isTouched": false
"id": "swc_buck_hs_4",
"value": "0",
"isTouched": false
"id": "swc_buck_hiz_4",
"value": 0,
"isTouched": false
"id": "force_pfm_4",
"value": "0",
"isTouched": false
"id": "BUCK4_DTEST_REG_1",
"value": "0",
"fields": [
"id": "buck_dtab1_sel_4",
"value": "0",
"isTouched": false
"id": "test_iave_pd_4",
"value": "0",
"isTouched": false
"id": "test_sample_izero_4",
"value": "0",
"isTouched": false
"id": "test_pulse_generator_4",
"value": "0",
"isTouched": false
"id": "BUCK4_DTEST_REG_2",
"value": "0",
"fields": [
"id": "dis_loop_comp_hyst_4",
"value": "0",
"isTouched": false
"id": "dis_vref_filter_4",
"value": "0",
"isTouched": false
"id": "test_blank_4",
"value": "0",
"isTouched": false
"id": "test_single_shot_4",
"value": "0",
"isTouched": false
"id": "test_buck_weak_driver_4",
"value": "0",
"isTouched": false
"id": "test_bypass_ramp_bias_res_4",
"value": "0",
"isTouched": false
"id": "BUCK4_DTEST_REG_3",
"value": "0",
"fields": [
"id": "test_integrator_word_4",
"value": "0",
"isTouched": false
"id": "BUCK4_DTEST_REG_4",
"value": "0",
"fields": [
"id": "test_carousel_ctrl_4",
"value": "0",
"isTouched": false
"id": "test_bypass_sw_latches_4",
"value": "0",
"isTouched": false
"id": "test_dis_autozero_4",
"value": "0",
"isTouched": false
"id": "test_pulse_gen_fixed_4",
"value": "0",
"isTouched": false
"id": "BUCK5_ATEST_REG_0",
"value": "0",
"fields": [
"id": "buck_atab_sel_5",
"value": "0",
"isTouched": false
"id": "test_integ_dac_short_output_5",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_5",
"value": "0",
"isTouched": false
"id": "test_ramp_artif_pd_5",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_5",
"value": "0",
"isTouched": false
"id": "BUCK5_ATEST_REG_1",
"value": "0",
"fields": [
"id": "test_iave_5",
"value": "0",
"isTouched": false
"id": "test_hs_gate_5",
"value": "0",
"isTouched": false
"id": "test_ovst_5",
"value": "0",
"isTouched": false
"id": "test_ramp_emu_pd_5",
"value": "0",
"isTouched": false
"id": "test_sw_short_detector_5",
"value": "0",
"isTouched": false
"id": "BUCK5_ATEST_REG_2",
"value": "0",
"fields": [
"id": "test_spare_5",
"value": "0",
"isTouched": false
"id": "BUCK5_DTEST_REG_0",
"value": 0,
"fields": [
"id": "buck_dtab0_sel_5",
"value": "0",
"isTouched": false
"id": "swc_buck_hs_5",
"value": "0",
"isTouched": false
"id": "swc_buck_hiz_5",
"value": 0,
"isTouched": false
"id": "force_pfm_5",
"value": "0",
"isTouched": false
"id": "BUCK5_DTEST_REG_1",
"value": "0",
"fields": [
"id": "buck_dtab1_sel_5",
"value": "0",
"isTouched": false
"id": "test_iave_pd_5",
"value": "0",
"isTouched": false
"id": "test_sample_izero_5",
"value": "0",
"isTouched": false
"id": "test_pulse_generator_5",
"value": "0",
"isTouched": false
"id": "BUCK5_DTEST_REG_2",
"value": "0",
"fields": [
"id": "dis_loop_comp_hyst_5",
"value": "0",
"isTouched": false
"id": "dis_vref_filter_5",
"value": "0",
"isTouched": false
"id": "test_blank_5",
"value": "0",
"isTouched": false
"id": "test_single_shot_5",
"value": "0",
"isTouched": false
"id": "test_buck_weak_driver_5",
"value": "0",
"isTouched": false
"id": "test_bypass_ramp_bias_res_5",
"value": "0",
"isTouched": false
"id": "BUCK5_DTEST_REG_3",
"value": "0",
"fields": [
"id": "test_integrator_word_5",
"value": "0",
"isTouched": false
"id": "BUCK5_DTEST_REG_4",
"value": "0",
"fields": [
"id": "test_carousel_ctrl_5",
"value": "0",
"isTouched": false
"id": "test_bypass_sw_latches_5",
"value": "0",
"isTouched": false
"id": "test_dis_autozero_5",
"value": "0",
"isTouched": false
"id": "test_pulse_gen_fixed_5",
"value": "0",
"isTouched": false
"id": "BuckStatus-tm_mem",
"registers": [
"id": "BUCK1_STATE",
"value": "0",
"fields": [
"id": "buck_state_1",
"value": "0",
"isTouched": false
"id": "BUCK2_STATE",
"value": "0",
"fields": [
"id": "buck_state_2",
"value": "0",
"isTouched": false
"id": "BUCK3_STATE",
"value": "0",
"fields": [
"id": "buck_state_3",
"value": "0",
"isTouched": false
"id": "BUCK4_STATE",
"value": "0",
"fields": [
"id": "buck_state_4",
"value": "0",
"isTouched": false
"id": "BUCK5_STATE",
"value": "0",
"fields": [
"id": "buck_state_5",
"value": "0",
"isTouched": false
"id": "BUCK1_INTEGRATOR",
"value": "0",
"fields": [
"id": "buck_integrator_word_1",
"value": "0",
"isTouched": false
"id": "BUCK2_INTEGRATOR",
"value": "0",
"fields": [
"id": "buck_integrator_word_2",
"value": "0",
"isTouched": false
"id": "BUCK3_INTEGRATOR",
"value": "0",
"fields": [
"id": "buck_integrator_word_3",
"value": "0",
"isTouched": false
"id": "BUCK4_INTEGRATOR",
"value": "0",
"fields": [
"id": "buck_integrator_word_4",
"value": "0",
"isTouched": false
"id": "BUCK5_INTEGRATOR",
"value": "0",
"fields": [
"id": "buck_integrator_word_5",
"value": "0",
"isTouched": false
"id": "BUCK_STATUS",
"value": "0",
"fields": [
"id": "buck1_active",
"value": "0",
"isTouched": false
"id": "buck2_active",
"value": "0",
"isTouched": false
"id": "buck3_active",
"value": "0",
"isTouched": false
"id": "buck4_active",
"value": "0",
"isTouched": false
"id": "buck5_active",
"value": "0",
"isTouched": false
"id": "EEPROMProgControl-tm_mem",
"registers": [
"id": "EEPROM_CONTROL_1",
"value": "0",
"fields": [
"id": "TM_EE_CFG_BULK_PROG",
"value": "0",
"isTouched": false
"id": "TM_EE_CFG_CKB_PROG",
"value": "0",
"isTouched": false
"id": "TM_EE_CFG_MARGIN_READ",
"value": "0",
"isTouched": false
"id": "TM_EE_CFG_BULK_ERASE",
"value": "0",
"isTouched": false
"id": "TM_EE_CFG_SHADOW_WRITE_DIS",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_2",
"value": "0",
"fields": [
"id": "TM_EE_CFG_BANK_DIS",
"value": "0",
"isTouched": false
"id": "TM_EE_CFG_SINGLE",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_3",
"value": "0",
"fields": [
"id": "TM_EE_ADDR",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_8",
"value": "0",
"fields": [
"id": "TM_EE_WRITE_DATA3",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_9",
"value": "0",
"fields": [
"id": "TM_EE_WRITE_DATA2",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_10",
"value": "0",
"fields": [
"id": "TM_EE_WRITE_DATA1",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_11",
"value": "0",
"fields": [
"id": "TM_EE_WRITE_DATA0",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_12",
"value": "0",
"fields": [
"id": "TM_EE_READ_DATA3",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_13",
"value": "0",
"fields": [
"id": "TM_EE_READ_DATA2",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_14",
"value": "0",
"fields": [
"id": "TM_EE_READ_DATA1",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_15",
"value": "0",
"fields": [
"id": "TM_EE_READ_DATA0",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_16",
"value": "0",
"fields": [
"id": "TM_EE_CMD_PROG",
"value": "0",
"isTouched": false
"id": "TM_EE_CMD_READ",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_17",
"value": "0",
"fields": [
"id": "TM_EE_FORCE_CP_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_FORCE_IP_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_FORCE_ERASE",
"value": "0",
"isTouched": false
"id": "TM_EE_FORCE_PROG",
"value": "0",
"isTouched": false
"id": "TM_EE_FORCE_READ",
"value": "0",
"isTouched": false
"id": "TM_EE_FORCE_EN",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_18",
"value": "0",
"fields": [
"id": "TM_EE_FAST_ERASE_PROG_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_BULK_ODD_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_BULK_EVEN_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_MARGIN_READ_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_MARGIN_OVR_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_HV_BIAS_WEAK_RATIO_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_OSC_MON_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_CELL_CURRENT_MON_EN",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_19",
"value": "0",
"fields": [
"id": "TM_EE_MARGIN_TRIM",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_VTUN_MON_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_TEST_V1V_MON_OVR_EN",
"value": "0",
"isTouched": false
"id": "TM_EE_PROG_SERIAL",
"value": "0",
"isTouched": false
"id": "EEPROM_CONTROL_20",
"value": "0",
"fields": [
"id": "tm_ee_ready",
"value": "0",
"isTouched": false
"id": "ee_active",
"value": "0",
"isTouched": false
"id": "tm_ee_read_fail",
"value": "0",
"isTouched": false
"id": "Trim_ocore",
"registers": [
"id": "TRIM_VMVCCA_0",
"value": "0",
"fields": [
"id": "trim_vmvcca_bg",
"value": "0",
"isTouched": false
"id": "TRIM_VMVCCA_1",
"value": "0",
"fields": [
"id": "trim_vmvcca_rdiv_1v2",
"value": "0",
"isTouched": false
"id": "TRIM_VMVCCA_2",
"value": "0",
"fields": [
"id": "trim_vmvcca_rdiv_0v6",
"value": "0",
"isTouched": false
"id": "TRIM_VMPVIN_0",
"value": "0",
"fields": [
"id": "trim_vmpvin_bg",
"value": "0",
"isTouched": false
"id": "TRIM_VMPVIN_1",
"value": "0",
"fields": [
"id": "trim_vmpvin_rdiv_1v2",
"value": "0",
"isTouched": false
"id": "TRIM_INT_0",
"value": "0",
"fields": [
"id": "trim_refsys_bg",
"value": "0",
"isTouched": false
"id": "TRIM_INT_1",
"value": "0",
"fields": [
"id": "trim_refsys_rdiv_1v2",
"value": "0",
"isTouched": false
"id": "TRIM_INT_2",
"value": "0",
"fields": [
"id": "trim_refsys_ibias",
"value": "0",
"isTouched": false
"id": "TRIM_INT_3",
"value": "0",
"fields": [
"id": "trim_ldo_int",
"value": "0",
"isTouched": false
"id": "TRIM_INT_4",
"value": "0",
"fields": [
"id": "trim_osc_20mhz",
"value": "0",
"isTouched": false
"id": "TRIM_INT_5",
"value": "0",
"fields": [
"id": "trim_osc_128khz",
"value": "0",
"isTouched": false
"id": "TRIM_INT_6",
"value": "0",
"fields": [
"id": "trim_osc_52mhz",
"value": "0",
"isTouched": false
"id": "TRIM_INT_7",
"value": "0",
"fields": [
"id": "trim_amux_buffer",
"value": "0",
"isTouched": false
"id": "TRIM_INT_8",
"value": "0",
"fields": [
"id": "trim_monitor_osc_20mhz",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_0",
"value": "0",
"fields": [
"id": "trim_safety_ibias",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_1",
"value": "0",
"fields": [
"id": "trim_vmon_buck1_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_2",
"value": "0",
"fields": [
"id": "trim_vmon_buck1_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_3",
"value": "0",
"fields": [
"id": "trim_vmon_buck1_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_4",
"value": "0",
"fields": [
"id": "trim_vmon_buck1_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_5",
"value": "0",
"fields": [
"id": "trim_vmon_buck2_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_6",
"value": "0",
"fields": [
"id": "trim_vmon_buck2_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_7",
"value": "0",
"fields": [
"id": "trim_vmon_buck2_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_8",
"value": "0",
"fields": [
"id": "trim_vmon_buck2_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_9",
"value": "0",
"fields": [
"id": "trim_vmon_buck3_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_10",
"value": "0",
"fields": [
"id": "trim_vmon_buck3_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_11",
"value": "0",
"fields": [
"id": "trim_vmon_buck3_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_12",
"value": "0",
"fields": [
"id": "trim_vmon_buck3_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_13",
"value": "0",
"fields": [
"id": "trim_vmon_buck4_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_14",
"value": "0",
"fields": [
"id": "trim_vmon_buck4_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_15",
"value": "0",
"fields": [
"id": "trim_vmon_buck4_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_16",
"value": "0",
"fields": [
"id": "trim_vmon_buck4_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_17",
"value": "0",
"fields": [
"id": "trim_vmon_buck5_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_18",
"value": "0",
"fields": [
"id": "trim_vmon_buck5_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_19",
"value": "0",
"fields": [
"id": "trim_vmon_buck5_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_20",
"value": "0",
"fields": [
"id": "trim_vmon_buck5_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_21",
"value": "0",
"fields": [
"id": "trim_vmon_ldo1_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_22",
"value": "0",
"fields": [
"id": "trim_vmon_ldo1_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_23",
"value": "0",
"fields": [
"id": "trim_vmon_ldo1_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_24",
"value": "0",
"fields": [
"id": "trim_vmon_ldo1_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_25",
"value": "0",
"fields": [
"id": "trim_vmon_ldo2_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_26",
"value": "0",
"fields": [
"id": "trim_vmon_ldo2_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_27",
"value": "0",
"fields": [
"id": "trim_vmon_ldo2_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_28",
"value": "0",
"fields": [
"id": "trim_vmon_ldo2_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_29",
"value": "0",
"fields": [
"id": "trim_vmon_ldo3_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_30",
"value": "0",
"fields": [
"id": "trim_vmon_ldo3_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_31",
"value": "0",
"fields": [
"id": "trim_vmon_ldo3_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_32",
"value": "0",
"fields": [
"id": "trim_vmon_ldo3_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_33",
"value": "0",
"fields": [
"id": "trim_vmon_ldo4_lshift_ov",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_34",
"value": "0",
"fields": [
"id": "trim_vmon_ldo4_lshift_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_35",
"value": "0",
"fields": [
"id": "trim_vmon_ldo4_vref_dac",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_36",
"value": "0",
"fields": [
"id": "trim_vmon_ldo4_rdiv_uv",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_37",
"value": "0",
"fields": [
"id": "trim_tsd_offset",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_38",
"value": "0",
"fields": [
"id": "trim_tsd_gain",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_39",
"value": "0",
"fields": [
"id": "trim_tsd_offset2",
"value": "0",
"isTouched": false
"id": "TRIM_SAFETY_40",
"value": "0",
"fields": [
"id": "trim_tsd_gain2",
"value": "0",
"isTouched": false
"id": "TRIM_VM_VSYS_0",
"value": "0",
"fields": [
"id": "trim_vsys_mon_bg",
"value": "0",
"isTouched": false
"id": "TRIM_VM_VSYS_1",
"value": "0",
"fields": [
"id": "trim_vsys_mon_rdiv_1v2",
"value": "0",
"isTouched": false
"id": "TRIM_RTC_0",
"value": "0",
"fields": [
"id": "trim_rtc_bg",
"value": "0",
"isTouched": false
"id": "TRIM_RTC_1",
"value": "0",
"fields": [
"id": "trim_rtc_rdiv_1v2",
"value": "0",
"isTouched": false
"id": "TRIM_RTC_2",
"value": "0",
"fields": [
"id": "trim_rtc_ldo",
"value": "0",
"isTouched": false
"id": "TRIM_DPLL_0",
"value": "0",
"fields": [
"id": "trim_dco",
"value": "0",
"isTouched": false
"id": "TRIM_LDO1_0",
"value": "0",
"fields": [
"id": "trim_ldo1_ref",
"value": "0",
"isTouched": false
"id": "TRIM_LDO1_1",
"value": "0",
"fields": [
"id": "trim_ldo1",
"value": "0",
"isTouched": false
"id": "TRIM_LDO1_2",
"value": "0",
"fields": [
"id": "trim_ldo1_ilim1",
"value": "0",
"isTouched": false
"id": "TRIM_LDO1_3",
"value": "0",
"fields": [
"id": "trim_ldo1_ilim2",
"value": "0",
"isTouched": false
"id": "TRIM_LDO2_0",
"value": "0",
"fields": [
"id": "trim_ldo2_ref",
"value": "0",
"isTouched": false
"id": "TRIM_LDO2_1",
"value": "0",
"fields": [
"id": "trim_ldo2",
"value": "0",
"isTouched": false
"id": "TRIM_LDO2_2",
"value": "0",
"fields": [
"id": "trim_ldo2_ilim1",
"value": "0",
"isTouched": false
"id": "TRIM_LDO2_3",
"value": "0",
"fields": [
"id": "trim_ldo2_ilim2",
"value": "0",
"isTouched": false
"id": "TRIM_LDO3_0",
"value": "0",
"fields": [
"id": "trim_ldo3_ref",
"value": "0",
"isTouched": false
"id": "TRIM_LDO3_1",
"value": "0",
"fields": [
"id": "trim_ldo3",
"value": "0",
"isTouched": false
"id": "TRIM_LDO3_2",
"value": "0",
"fields": [
"id": "trim_ldo3_ilim1",
"value": "0",
"isTouched": false
"id": "TRIM_LDO3_3",
"value": "0",
"fields": [
"id": "trim_ldo3_ilim2",
"value": "0",
"isTouched": false
"id": "TRIM_LDO4_0",
"value": "0",
"fields": [
"id": "trim_ldo4_low",
"value": "0",
"isTouched": false
"id": "TRIM_LDO4_1",
"value": "0",
"fields": [
"id": "trim_ldo4_high",
"value": "0",
"isTouched": false
"id": "TRIM_LDO4_2",
"value": "0",
"fields": [
"id": "trim_ldo4_ilim",
"value": "0",
"isTouched": false
"id": "TRIM_LDO4_3",
"value": "0",
"fields": [
"id": "trim_ldo4_sr_fast",
"value": "0",
"isTouched": false
"id": "TRIM_LDO4_4",
"value": "0",
"fields": [
"id": "trim_ldo4_sr_slow",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_0",
"value": "0",
"fields": [
"id": "trim_vref_dac_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_1",
"value": "0",
"fields": [
"id": "trim_level_shift_gain_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_2",
"value": "0",
"fields": [
"id": "trim_loop_comp_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_3",
"value": "0",
"fields": [
"id": "trim_vout_adc_gain_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_4",
"value": "0",
"fields": [
"id": "trim_vout_adc_offset_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_5",
"value": "0",
"fields": [
"id": "trim_vout_adc_ptat_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_6",
"value": "0",
"fields": [
"id": "trim_emu_ramp_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_7",
"value": "0",
"fields": [
"id": "trim_artif_ramp_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_8",
"value": "0",
"fields": [
"id": "trim_hs_replica_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_9",
"value": "0",
"fields": [
"id": "trim_ls_replica_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_10",
"value": "0",
"fields": [
"id": "trim_fb_gain_stage_offset_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_11",
"value": "0",
"fields": [
"id": "trim_integ_dac_gain_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_12",
"value": "0",
"fields": [
"id": "trim_slope_1",
"value": "0",
"isTouched": false
"id": "BUCK1_TRIM_REG_13",
"value": "0",
"fields": [
"id": "trim_spare_1",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_0",
"value": "0",
"fields": [
"id": "trim_vref_dac_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_1",
"value": "0",
"fields": [
"id": "trim_level_shift_gain_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_2",
"value": "0",
"fields": [
"id": "trim_loop_comp_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_3",
"value": "0",
"fields": [
"id": "trim_vout_adc_gain_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_4",
"value": "0",
"fields": [
"id": "trim_vout_adc_offset_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_5",
"value": "0",
"fields": [
"id": "trim_vout_adc_ptat_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_6",
"value": "0",
"fields": [
"id": "trim_emu_ramp_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_7",
"value": "0",
"fields": [
"id": "trim_artif_ramp_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_8",
"value": "0",
"fields": [
"id": "trim_hs_replica_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_9",
"value": "0",
"fields": [
"id": "trim_ls_replica_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_10",
"value": "0",
"fields": [
"id": "trim_fb_gain_stage_offset_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_11",
"value": "0",
"fields": [
"id": "trim_integ_dac_gain_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_12",
"value": "0",
"fields": [
"id": "trim_slope_2",
"value": "0",
"isTouched": false
"id": "BUCK2_TRIM_REG_13",
"value": "0",
"fields": [
"id": "trim_spare_2",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_0",
"value": "0",
"fields": [
"id": "trim_vref_dac_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_1",
"value": "0",
"fields": [
"id": "trim_level_shift_gain_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_2",
"value": "0",
"fields": [
"id": "trim_loop_comp_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_3",
"value": "0",
"fields": [
"id": "trim_vout_adc_gain_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_4",
"value": "0",
"fields": [
"id": "trim_vout_adc_offset_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_5",
"value": "0",
"fields": [
"id": "trim_vout_adc_ptat_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_6",
"value": "0",
"fields": [
"id": "trim_emu_ramp_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_7",
"value": "0",
"fields": [
"id": "trim_artif_ramp_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_8",
"value": "0",
"fields": [
"id": "trim_hs_replica_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_9",
"value": "0",
"fields": [
"id": "trim_ls_replica_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_10",
"value": "0",
"fields": [
"id": "trim_fb_gain_stage_offset_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_11",
"value": "0",
"fields": [
"id": "trim_integ_dac_gain_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_12",
"value": "0",
"fields": [
"id": "trim_slope_3",
"value": "0",
"isTouched": false
"id": "BUCK3_TRIM_REG_13",
"value": "0",
"fields": [
"id": "trim_spare_3",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_0",
"value": "0",
"fields": [
"id": "trim_vref_dac_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_1",
"value": "0",
"fields": [
"id": "trim_level_shift_gain_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_2",
"value": "0",
"fields": [
"id": "trim_loop_comp_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_3",
"value": "0",
"fields": [
"id": "trim_vout_adc_gain_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_4",
"value": "0",
"fields": [
"id": "trim_vout_adc_offset_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_5",
"value": "0",
"fields": [
"id": "trim_vout_adc_ptat_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_6",
"value": "0",
"fields": [
"id": "trim_emu_ramp_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_7",
"value": "0",
"fields": [
"id": "trim_artif_ramp_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_8",
"value": "0",
"fields": [
"id": "trim_hs_replica_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_9",
"value": "0",
"fields": [
"id": "trim_ls_replica_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_10",
"value": "0",
"fields": [
"id": "trim_fb_gain_stage_offset_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_11",
"value": "0",
"fields": [
"id": "trim_integ_dac_gain_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_12",
"value": "0",
"fields": [
"id": "trim_slope_4",
"value": "0",
"isTouched": false
"id": "BUCK4_TRIM_REG_13",
"value": "0",
"fields": [
"id": "trim_spare_4",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_0",
"value": "0",
"fields": [
"id": "trim_vref_dac_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_1",
"value": "0",
"fields": [
"id": "trim_level_shift_gain_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_2",
"value": "0",
"fields": [
"id": "trim_loop_comp_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_3",
"value": "0",
"fields": [
"id": "trim_vout_adc_gain_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_4",
"value": "0",
"fields": [
"id": "trim_vout_adc_offset_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_5",
"value": "0",
"fields": [
"id": "trim_vout_adc_ptat_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_6",
"value": "0",
"fields": [
"id": "trim_emu_ramp_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_7",
"value": "0",
"fields": [
"id": "trim_artif_ramp_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_8",
"value": "0",
"fields": [
"id": "trim_hs_replica_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_9",
"value": "0",
"fields": [
"id": "trim_ls_replica_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_10",
"value": "0",
"fields": [
"id": "trim_fb_gain_stage_offset_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_11",
"value": "0",
"fields": [
"id": "trim_integ_dac_gain_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_12",
"value": "0",
"fields": [
"id": "trim_slope_5",
"value": "0",
"isTouched": false
"id": "BUCK5_TRIM_REG_13",
"value": "0",
"fields": [
"id": "trim_spare_5",
"value": "0",
"isTouched": false
"id": "WatchDogRegisters-user_mem",
"registers": [
"id": "WD_ANSWER_REG",
"value": "0",
"fields": [
"id": "WD_ANSWER",
"value": "0",
"isTouched": false
"id": "WD_QUESTION_ANSW_CNT",
"value": "0",
"fields": [
"id": "WD_QUESTION",
"value": "0",
"isTouched": false
"id": "WD_ANSW_CNT",
"value": "0",
"isTouched": false
"id": "WD_WIN1_CFG",
"value": "0",
"fields": [
"id": "WD_WIN1",
"value": "0",
"isTouched": false
"id": "WD_WIN2_CFG",
"value": "0",
"fields": [
"id": "WD_WIN2",
"value": "0",
"isTouched": false
"id": "WD_LONGWIN_CFG",
"value": 0,
"fields": [
"id": "WD_LONGWIN",
"value": "0",
"isTouched": false
"id": "WD_MODE_REG",
"value": "0",
"fields": [
"id": "WD_PWRHOLD",
"value": "0",
"isTouched": false
"id": "WD_MODE_SELECT",
"value": "0",
"isTouched": false
"id": "WD_RETURN_LONGWIN",
"value": "0",
"isTouched": false
"id": "WD_QA_CFG",
"value": "0",
"fields": [
"id": "WD_QA_FDBK",
"value": "0",
"isTouched": false
"id": "WD_QA_LFSR",
"value": "0",
"isTouched": false
"id": "WD_QUESTION_SEED",
"value": "0",
"isTouched": false
"id": "WD_ERR_STATUS",
"value": "0",
"fields": [
"id": "WD_ANSW_EARLY",
"value": "0",
"isTouched": false
"id": "WD_TIMEOUT",
"value": "0",
"isTouched": false
"id": "WD_SEQ_ERR",
"value": "0",
"isTouched": false
"id": "WD_LONGWIN_TIMEOUT_INT",
"value": "0",
"isTouched": false
"id": "WD_ANSW_ERR",
"value": "0",
"isTouched": false
"id": "WD_TRIG_EARLY",
"value": "0",
"isTouched": false
"id": "WD_RST_INT",
"value": "0",
"isTouched": false
"id": "WD_FAIL_INT",
"value": "0",
"isTouched": false
"id": "WD_THR_CFG",
"value": 191,
"fields": [
"id": "WD_EN",
"value": "0",
"isTouched": false
"id": "WD_RST_EN",
"value": 1,
"isTouched": false
"id": "WD_FAIL_TH",
"value": 7,
"isTouched": false
"id": "WD_RST_TH",
"value": 7,
"isTouched": false
"id": "WD_FAIL_CNT_REG",
"value": "0",
"fields": [
"id": "WD_FAIL_CNT",
"value": "0",
"isTouched": false
"id": "WD_FIRST_OK",
"value": "0",
"isTouched": false
"id": "WD_BAD_EVENT",
"value": "0",
"isTouched": false
"name": "TPS6593x_2p0",
"devices": []
"name": "LP8764x_2p0",
"devices": []
"name": "LP876242x_2p0",
"devices": []
"name": "LP8762x_2p0",
"devices": []
"fsmConfig": {
"states": [
"id": 3,
"title": "PFSM_START",
"x": 133.9068717956543,
"y": -39.89291572570801,
"mandatoryState": true,
"isHardwareState": false,
"isUserDefinedState": true
"id": 4,
"title": "TO_SAFE",
"x": 165.72796726226807,
"y": 353.5653610229492,
"id": 5,
"title": "SAFE_RECOVERY",
"x": -11.091180801391602,
"y": 441.760498046875,
"isHardwareState": true,
"isUserDefinedState": false
"id": 6,
"title": "STATE1_ON",
"x": 337.02020263671875,
"y": 55.88175702095032,
"id": 7,
"title": "STATE1_OFF",
"x": 313.1805114746094,
"y": -132.90836334228516,
"id": 8,
"title": "STATE2_ON",
"x": 530.2363891601562,
"y": 43.636895179748535,
"id": 9,
"title": "STATE2_OFF",
"x": 533.4747619628906,
"y": -137.41798400878906,
"id": 10,
"title": "STATE3_ON",
"x": 744.6345825195312,
"y": 40.360316038131714,
"id": 11,
"title": "STATE3_OFF",
"x": 770.163330078125,
"y": -159.01500701904297,
"id": 12,
"title": "STATE4_ON",
"x": 747.1966552734375,
"y": 261.7301969528198,
"id": 13,
"title": "STATE4_OFF",
"x": 580.817626953125,
"y": 260.73419189453125,
"id": 14,
"title": "STATE5_ON",
"x": 716.3749389648438,
"y": 434.2369089126587,
"id": 15,
"title": "STATE5_OFF",
"x": 470.25457763671875,
"y": 433.30218505859375,
"id": 16,
"title": "STAND_BY",
"x": 203.48936653137207,
"y": 177.1975975036621,
"transitions": [
"source": {
"id": 4,
"title": "TO_SAFE",
"target": {
"id": 5,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"unmaskTriggerList": []
"priority": 0,
"triggers": [
"id": 0
"source": {
"id": 6,
"target": {
"id": 7,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 1
"source": {
"id": 6,
"target": {
"id": 8,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 2
"source": {
"id": 8,
"target": {
"id": 9,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 3
"source": {
"id": 8,
"target": {
"id": 10,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 4
"source": {
"id": 10,
"target": {
"id": 12,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 5
"source": {
"id": 12,
"target": {
"id": 13,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 6
"source": {
"id": 12,
"target": {
"id": 14,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 7
"source": {
"id": 14,
"target": {
"id": 15,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 8
"source": {
"id": 10,
"target": {
"id": 11,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 9
"source": {
"id": 7,
"target": {
"id": 6,
"order": 2,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 10
"source": {
"id": 9,
"target": {
"id": 8,
"order": 2,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 11
"source": {
"id": 11,
"target": {
"id": 10,
"order": 2,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 12
"source": {
"id": 13,
"target": {
"id": 12,
"order": 2,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 13
"source": {
"id": 15,
"target": {
"id": 14,
"order": 2,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 14
"source": {
"id": 16,
"target": {
"id": 4,
"title": "TO_SAFE",
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 15
"source": {
"id": 3,
"target": {
"id": 16,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 16
"source": {
"id": 16,
"target": {
"id": 6,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 17
"id": 18
"source": {
"id": 3,
"target": {
"id": 6,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 19
"source": {
"id": 15,
"target": {
"id": 16,
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 20
"source": {
"id": 15,
"target": {
"id": 4,
"title": "TO_SAFE",
"order": 1,
"label": "",
"sequence": [],
"triggerMask": {
"value": null,
"priority": 0,
"triggers": [
"id": 21
"triggers": [
"trigger": {
"trigSel": 63,
"name": "1"
"type": "HIGH",
"isImmediate": true,
"isEXT": true,
"isAnyDevice": true,
"isReentrant": false,
"devices": [],
"sequence": null,
"showFunctions": false,
"id": 0
"trigger": {
"trigSel": 21,
"name": "GPIO1"
"type": "FALL",
"isImmediate": false,
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 5
"id": 1
"trigger": {
"trigSel": 22,
"name": "GPIO2"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 1
"id": 2
"trigger": {
"trigSel": 22,
"name": "GPIO2"
"type": "FALL",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 6
"id": 3
"trigger": {
"trigSel": 23,
"name": "GPIO3"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 2
"id": 4
"trigger": {
"trigSel": 24,
"name": "GPIO4"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 3
"id": 5
"trigger": {
"trigSel": 24,
"name": "GPIO4"
"type": "FALL",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 8
"id": 6
"trigger": {
"trigSel": 25,
"name": "GPIO5"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 4
"id": 7
"trigger": {
"trigSel": 25,
"name": "GPIO5"
"type": "FALL",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 9
"id": 8
"trigger": {
"trigSel": 23,
"name": "GPIO3"
"type": "FALL",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 7
"id": 9
"trigger": {
"trigSel": 21,
"name": "GPIO1"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 0
"id": 10
"trigger": {
"trigSel": 22,
"name": "GPIO2"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 1
"id": 11
"trigger": {
"trigSel": 23,
"name": "GPIO3"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 2
"id": 12
"trigger": {
"trigSel": 24,
"name": "GPIO4"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 3
"id": 13
"trigger": {
"trigSel": 25,
"name": "GPIO5"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 4
"id": 14
"trigger": {
"trigSel": 0,
"name": "IMMEDIATE_SHUTDOWN"
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 11
"id": 15
"trigger": {
"trigSel": 18,
"name": "SU_STANDBY"
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 10
"id": 16
"trigger": {
"trigSel": 12,
"name": "SU_ACTIVE"
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 0
"id": 17
"trigger": {
"trigSel": 21,
"name": "GPIO1"
"type": "RISE",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 0
"id": 18
"trigger": {
"trigSel": 12,
"name": "SU_ACTIVE"
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 0
"id": 19
"trigger": {
"trigSel": 4,
"name": "FORCE_STANDBY"
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 10
"id": 20
"trigger": {
"trigSel": 0,
"type": "HIGH",
"isEXT": false,
"devices": [
"TPS65940"
"sequence": {
"id": 11
"id": 21
"triggerPriorityList": [
"transition": [
"source": "TO_SAFE",
"target": "SAFE_RECOVERY",
"priority": 0
"triggerBase": {
"id": 0
"transition": [
"source": "STAND_BY",
"target": "STATE1_ON",
"priority": 0
"triggerBase": {
"id": 17
"transition": [
"source": "PFSM_START",
"priority": 0
"triggerBase": {
"id": 19
"transition": [
"target": "STAND_BY",
"priority": 0
"triggerBase": {
"id": 16
"transition": [
"source": "STATE1_OFF",
"priority": 0
"triggerBase": {
"id": 10
"transition": [
"source": "STATE1_ON",
"target": "STATE1_OFF",
"priority": 0
"triggerBase": {
"id": 1
"transition": [
"priority": 0
"triggerBase": {
"id": 18
"transition": [
"target": "STATE2_ON",
"priority": 0
"triggerBase": {
"id": 2
"transition": [
"source": "STATE2_ON",
"target": "STATE2_OFF",
"priority": 0
"triggerBase": {
"id": 3
"transition": [
"source": "STATE2_OFF",
"priority": 0
"triggerBase": {
"id": 11
"transition": [
"target": "STATE3_ON",
"priority": 0
"triggerBase": {
"id": 4
"transition": [
"source": "STATE3_ON",
"target": "STATE3_OFF",
"priority": 0
"triggerBase": {
"id": 9
"transition": [
"source": "STATE3_OFF",
"priority": 0
"triggerBase": {
"id": 12
"transition": [
"target": "STATE4_ON",
"priority": 0
"triggerBase": {
"id": 5
"transition": [
"source": "STATE4_ON",
"target": "STATE4_OFF",
"priority": 0
"triggerBase": {
"id": 6
"transition": [
"source": "STATE4_OFF",
"priority": 0
"triggerBase": {
"id": 13
"transition": [
"target": "STATE5_ON",
"priority": 0
"triggerBase": {
"id": 7
"transition": [
"source": "STATE5_ON",
"target": "STATE5_OFF",
"priority": 0
"triggerBase": {
"id": 8
"transition": [
"source": "STATE5_OFF",
"priority": 0
"triggerBase": {
"id": 14
"transition": [
"triggerBase": {
"id": 20
"transition": [
"target": "TO_SAFE"
"triggerBase": {
"id": 21
"transition": [
"target": "TO_SAFE"
"triggerBase": {
"id": 15
"globalSequences": [
"name": "BUCK4",
"id": 0,
"sequences": [
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"timeoutUnit": "us",
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"conditionType": "LOW",
"delayMode": "ALWAYS",
"resourceControl": "VCTRL",
"resourceControlSelect": 0,
"scratchRegister": null,
"bypass": false,
"outputVoltageUnit": "V",
"outputVoltage": 0,
"voltageTarget": "VSEL1",
"scratchAddress": null,
"scratchMask": null,
"subSequence": null,
"calculatedDelay": 0,
"isSubRoutineAction": false,
"sequences": [],
"destination": null,
"vccaVmon": "unchanged",
"clkmon": "unchanged",
"amuxout": "unchanged",
"buckCtrlResetReg": null,
"enableDRV": 0,
"pfsmDelayStepSize": 0,
"deviceAlias": "TPS65940",
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"scratchRegister": "R0",
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "TRIG_MASK",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 6,
"subRoutineList": [],
"sequenceType": "activate"
"name": "BUCK_12",
"id": 1,
"sequences": [
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 8,
"name": "BUCK3",
"id": 2,
"sequences": [
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 10,
"name": "LDO2",
"id": 3,
"sequences": [
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 12,
"name": "LD01",
"id": 4,
"sequences": [
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 14,
"name": "BUCK4_OFF",
"id": 5,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"command": {
"name": "DEACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 7,
"sequenceType": "deactivate"
"name": "BUCK_12_OFF",
"id": 6,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 9,
"name": "BUCK3_OFF",
"id": 7,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 11,
"name": "LDO2_OFF",
"id": 8,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 13,
"name": "LDO1_OFF",
"id": 9,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 15,
"name": "standby",
"id": 10,
"sequences": [
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "FIRST_STARTUP_DONE",
"address": "C3",
"data": "80",
"mask": "7F"
"visible": false,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "END"
"visible": false,
"name": "Rail2",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 16,
"sequenceType": "others"
"name": "safe",
"id": 11,
"sequences": [
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visible": false,
"name": "Rail3",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ACTIVATE",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "Rail2",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0.3,
"sequences": [],
"vccaVmon": "changed",
"amuxout": "enable",
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "INCREASE_RECOVERY_COUNTER",
"address": "0A5",
"data": "1",
"mask": "FE"
"visible": false,
"name": "Rail5",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"default": {
"sequenceAddress": "0xC3",
"sequenceData": "0x80",
"sequenceMask": "0x7F"
"visibility": true,
"showInSeq": false,
"address": "C3",
"data": "80",
"mask": "7F"
"visible": false,
"name": "Rail4",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "RESET_BUCKs",
"controlReg": "BUCK_RESET_REG",
"visibility": true,
"showInSeq": false
"visible": false,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"sequences": [],
"buckCtrlResetReg": {
"id": "BUCK_RESET_REG",
"name": "BUCK_RESET_REG",
"desc": "",
"anchor": "",
"addr": "0x87",
"mode": "",
"size": "8",
"default": "0",
"value": 15,
"fields": [
"id": "BUCK1_RESET",
"helpTag": "",
"name": "BUCK1_RESET",
"desc": "Reset signal for Buck logic.",
"anchor": "",
"mode": "RW",
"start": "0",
"stop": "0",
"value": 1,
"attrs": {
"isHidden": "0",
"isReserved": "0",
"isLocked": "0"
"isTouched": false
"id": "BUCK2_RESET",
"helpTag": "",
"name": "BUCK2_RESET",
"anchor": "",
"mode": "RW",
"start": "1",
"stop": "1",
"value": 1,
"attrs": {
"isHidden": "0",
"isReserved": "0",
"isLocked": "0"
"isTouched": false
"id": "BUCK3_RESET",
"helpTag": "",
"name": "BUCK3_RESET",
"anchor": "",
"mode": "RW",
"start": "2",
"stop": "2",
"value": 1,
"attrs": {
"isHidden": "0",
"isReserved": "0",
"isLocked": "0"
"isTouched": false
"id": "BUCK4_RESET",
"helpTag": "",
"name": "BUCK4_RESET",
"anchor": "",
"mode": "RW",
"start": "3",
"stop": "3",
"value": 1,
"attrs": {
"isHidden": "0",
"isReserved": "0",
"isLocked": "0"
"staticConfig": true,
"isTouched": false
"id": "BUCK5_RESET",
"helpTag": "",
"name": "BUCK5_RESET",
"anchor": "",
"mode": "RW",
"start": "4",
"stop": "4",
"value": 0,
"attrs": {
"isHidden": "0",
"isReserved": "0",
"isLocked": "0"
"isTouched": false
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail6",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"sequences": [],
"enableDRV": 1,
"trigMask": {
"value": null,
"targetState": {
"id": 4,
"title": "TO_SAFE",
"pfsmSequence": {
"name": "PFSM_START",
"id": 0,
"sequences": [
"command": {
"name": "ENDRV"
"visible": true,
"name": "Rail1",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"command": {
"visibility": true,
"showInSeq": false
"visible": false,
"name": "",
"delay": 0,
"delayUnit": "us",
"timeout": 0,
"waitCondition": {
"condSel": 0,
"condName": "GPIO1"
"bypass": false,
"outputVoltage": 0,
"sequences": [],
"enableDRV": 0,
"trigMask": {
"value": null,
"targetState": {
"id": 3,
"x": 25.69571304321289,
"y": 45.94721984863281,
"pfsmGlobalDelay": 25.6,
"autoShuffle": false,
"overridenStandbyReadyTrigMask": null,
"startState": {
"id": 3,
这是我上次上传的 json 文件。 请告诉我是否需要任何其他文件来解决此问题。
Harsha
您好、Harsha、
我在对该器件进行重新编程时也遇到了一个问题。 使用您提供的 JSON 对其进行编程后、我无法再次对其进行编程、并收到相同的 EEPROM 解锁失败消息。
json、您为 I2C1提供了 I2C CRC。 通过 GUI 连接到器件时、必须为 I2C1启用 I2C CRC。 之后、我能够再次对器件进行重新编程。
在连接到器件之前、请尝试在 GUI 上为 I2C1启用 I2C_CRC。 这将改变您在寄存器映射上看到的内容并允许重新编程。
Daniel W
Daniel、您好!
我已经按照协议操作、可以为 PMIC 上电、但如何确认 I2C 通信已建立。 我已尝试将其连接到可扩展 PMIC GUI 以查看通信、但"未连接硬件"是我收到的消息。 您能不能给它放些光?
我有一条 PFSM 警告、即"TPS65940不存在以 SAFE_RECOVERY 状态结束的触发器"。 我在此附上 PFSM 状态图、您能为制定警告提供帮助
Harsha
