[参考译文] TPS54202:负电压电源
Guru**** 2510695 points
Other Parts Discussed in Thread: TPS54202, LV2862
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1226717/tps54202-negative-voltage-supply
器件型号:TPS54202
主题中讨论的其他器件: LV2862
您可以确认 TPS54202是否 可以满足以下需求吗?
输入:3-18V;
输出:-3至-18V
输出电流为100mA
此致,
海亮
