[参考译文] BQ25895:驱动器可以#39;t 探测设备、返回-22
Guru**** 2767065 points
Other Parts Discussed in Thread: BQ25890, BQ25895
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1227304/bq25895-driver-can-t-probe-the-device-returns--22
器件型号:BQ25895
主题中讨论的其他器件:BQ25890
我正在尝试在 Armbian 上设置 BQ25890 Linux 驱动程序、我使用 Orange PI PC Plus 以及定制的扩展板、该扩展板具有 Zigbee 和使用 BQ25895芯片的备用电池
我已经重新编译了包括驱动程序在内的内核、但当我运行 dmesg | grep bq 时、我总是会得到此响应
[   2.152205] bq25890-充电器:0-006a 探针失败,错误-22
我已按如下方式设置器件树重叠:
// Overlay for bq25890
// bq25895.overlay.dts
/dts-v1/;
/plugin/;
        compatible = "allwinner,sun8i-h3";
        fragment@0 {
                target = <&i2c0>;
                __overlay__ {
                        #address-cells = <0x01>;
                        #size-cells = <0x00>;
        		status = "okay";
			ds1307: ds1307@68 {
                		compatible = "dallas,ds1307";
                		reg = <0x68>;
                		status = "okay";
                        bq25890  {
                                compatible = "ti,bq25895";
                                reg = <0x6a>;
				//status = "okay";
                                interrupts = <0 20 2>;
                                ti,charge-current = <1024000>;
                                ti,battery-regulation-voltage = <4208000>;
                                ti,termination-current = <64000>;
                                ti,precharge-current = <128000>;
                                ti,minimum-sys-voltage = <3500000>;
                                ti,boost-voltage = <5126000>;
                                ti,boost-max-current = <10000000>;
                                ti,thermal-regulation-threshold = <80>;
我在这里遗漏了什么吗?
