[参考译文] CSD18543Q3A:进给方向和链轮-胶带孔端
Guru**** 2766765 points
Other Parts Discussed in Thread: CSD18543Q3A
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1230073/csd18543q3a-feed-direction-and-sprocket-hole-side-of-tape
器件型号:CSD18543Q3A
CSD18543Q3A 进纸方向和胶带的链轮孔侧是否与下图相同?
如果没有、您能否提供 SON 封装的相关材料?
https://www.ti.com/lit/an/slza001/slza001.pdf
Nishie.
