[参考译文] TPS23754:PoE PD 25W 原理图审阅
Guru**** 2386620 points
Other Parts Discussed in Thread: TPS23754
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1301539/tps23754-poe-pd-25w-schematics-review
器件型号:TPS23754
我的客户想要将 TPS23754用于 POE PD 25W (802.3at 2类)应用、您能帮忙查看原理图并提供建议吗? 谢谢!
输入电压:直流42.5~57V;输出电压:直流12V;输出电流:2A
e2e.ti.com/.../SCHEMATIC_5F00_TPS23754-POE-PD-25W.pdf
