[参考译文] TPS82085:TPS82085原理图
Guru**** 2506035 points
Other Parts Discussed in Thread: TPS82085
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1312808/tps82085-tps82085-schematic-diagram
器件型号:TPS82085
TPS82085的设计原理图如下所示。 您能帮助检查一下是否有任何问题吗? 或提供良好建议?
