[参考译文] BQ25792:BQ25792
Guru**** 2387080 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1297715/bq25792-bq25792
器件型号:BQ25792
对于此公式、您能否对其进行
RTH COLD 和 HOT 来自热敏电阻在 COLD 和 HOT 点的电阻值是正确的吗?
我需要查找示例 RT1和 RT2
使用此 NTC  B (25/85)[K]: 3435±1%
https://www.vishay.com/en/thermistors/ntc-rt-calculator/
RTHCOLD   0
RTHHOT 55
1/VT1 0.300264 0.28422 0.269541779
%->V 3.3304 3.5184 3.71
Vt1_RISE 72.4 73.3 74.2
VT1_FALL 71.5 72 72.5
%->V 3.289 3.456 3.625
1/VT1 0.304044 0.289352 0.275862069
1/VT5 0.645078 0.609162 0.57636876
%->V 1.5502 1.6416 1.735
VT5_RISE 33.7 34.2 34.7
VT5_FALL 35 35.5 36
%->V 1.61 1.704 1.8
1/VT5 0.621118 0.586854 0.5555556
VREG 4.6 4.8 5
