[参考译文] CSD19537Q3:是在外壳顶部还是在底部测量结至外壳热阻?
Guru**** 2814245 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1284870/csd19537q3-is-the-junction-to-case-thermal-resistance-measured-at-the-top-of-the-case-or-at-the-bottom
器件型号:CSD19537Q3
是在外壳顶部或外壳底部(即散热焊盘)测量的 R_THETAJC in 5.2
提前感谢您、Kurt
