[参考译文] LMZ31506:使用两个 LMZ31506、唯一的 LMZ31506 PWRGD 引脚可以驱动第二个 LMZ31506 INH/UVLO?
Guru**** 2771055 points
Other Parts Discussed in Thread: LMZ31506
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1272401/lmz31506-used-two-lmz31506-frist-lmz31506-pwrgd-pin-could-drive-the-second-lmz31506-inh-uvlo
器件型号:LMZ31506
使用两个 LMZ31506框式 LMZ31506 PWRGD 引脚可以驱动第二个 LMZ31506 INH/UVLO?
INH/UVLO 引脚可以直接连接 PWRGD 引脚?
