[参考译文] BQ27220:如何设置 BQ27220 dm_reg 设置?
Guru**** 1470880 points
Other Parts Discussed in Thread: BQ27220
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1347234/bq27220-how-to-set-bq27220-dm_reg-setting
器件型号:BQ27220
我们参考该驱动程序的示例代码。
我们应该如何为 bq27220设置 dm 参数?
例如:
static struct bq27xxx_dm_reg bq27500_dm_regs[] = {
	[BQ27XXX_DM_DESIGN_CAPACITY]   = { 48, 10, 2,    0, 65535 },
	[BQ27XXX_DM_DESIGN_ENERGY]     = { }, /* missing on chip */
	[BQ27XXX_DM_TERMINATE_VOLTAGE] = { 80, 48, 2, 1000, 32767 },
