[参考译文] 三相415VAC,50Hz 输入至250V 电池充电器,4kW 输出
Guru**** 2583825 points
Other Parts Discussed in Thread: TIDA-01606, PMP21999
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1352614/3ph-415vac-50hz-input-to-250v-battery-charger-4kw-output
器件型号:
输入:三相输入415VAC,50Hz,
输出:230-255 VDC 可变
应用:电池充电器、4kW 输出。
EMI/EMC:MIL-STD-461F
温度:-30至+55 C
请向我们推荐任何适合上述规格的参考设计?
