[参考译文] TPS22950:焊接工艺
Guru**** 2516170 points
Other Parts Discussed in Thread: TPS22950
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1218087/tps22950-solder-process
器件型号:TPS22950
TPS22950的 SnAgCu 铅涂层/焊球材料。 是否提供含引线焊料器件的可靠性数据?
