[参考译文] TPS62745:此器件在-55摄氏度下是否有效工作
Guru**** 2694555 points
Other Parts Discussed in Thread: TPS62745, LMR36015S, TPS54362-HT
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1211222/tps62745-is-this-part-works-effectively-in--55-degree-celsius
器件型号:TPS62745
主题中讨论的其他器件: LMR36015STPS54362-HT
TPS62745的工作温度范围是否为-55摄氏度。 请尽快确认
