[参考译文] UCC28056:输入电压 Vin 为180V、Vcomp 引脚饱和、Ton 理论上应达到最大值6.92us、但实际上仅为3.24us (电流未达到 OCP 点)
Guru**** 2510095 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1362574/ucc28056-the-input-voltage-vin-is-180v-the-vcomp-pin-is-saturated-and-the-ton-should-theoretically-reach-a-maximum-of-6-92us-but-in-practice-it-is-only-3-24us-the-current-does-not-reach-the-ocp-point
器件型号:UCC28056
 输入电压 Vin 为180V,Vcomp 引脚饱和,Ton 理论上应达到最大6.92us,但实际上只有3.24us 点)OCP(电流未达到
