[参考译文] TPS65132:规格检查
Guru**** 2797355 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1364879/tps65132-spec-check
器件型号:TPS65132
您好
请按以下方式建议合适的产品规格
e2e.ti.com/.../GV070.pdf
