[参考译文] TPS54325:EN 引脚输入电流
Guru**** 2502205 points
Other Parts Discussed in Thread: TPS54325
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1365964/tps54325-en-pin-input-current
器件型号:TPS54325
TPS54325 EN 引脚的输入电流是多少?
    如果 EN 引脚为5V、则输入电流约为12uA。 谢谢。
    石屏市
