[参考译文] TLC5929:帮助提供 TLC5929故障诊断参考代码?
Guru**** 2390755 points
Other Parts Discussed in Thread: TLC5929
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1370051/tlc5929-help-to-provide-the-tlc5929-fault-diagnosis-reference-code
器件型号:TLC5929
请帮助提供 TLC5929故障诊断参考代码,谢谢
