[参考译文] UCC21710-Q1:如何计算以下原理图(R2和 R14)中的分流电阻值
Guru**** 2533550 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1377015/ucc21710-q1-how-to-calculate-the-value-of-the-shunt-resistance-in-the-below-schematic-r2-and-r14
器件型号:UCC21710-Q1
如何在以下原理图(R2和 R14)中针对故障 SIGNALe2e.ti.com/.../DUAL--SIC_2D00_RS485-DRIVER_2D002800_15A_29005F00_R006.pdf 计算分流电阻值
UCC21710Q1
