[参考译文] UCC28711:UCC28711不提供驱动脉冲、即使处于开路状态、NTC 引脚也无电压
Guru**** 2502205 points
Other Parts Discussed in Thread: UCC28711
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1385437/ucc28711-ucc28711-is-not-giving-drive-pulses-and-no-voltage-at-ntc-pin-even-it-is-kept-open
器件型号:UCC28711
UCC28711不提供驱动脉冲、NTC 引脚上无电压、即使保持开路也是如此。VS 引脚无电压、RS1=110k Ω RS2=31.6K
