[参考译文] TPS56A37:是否有将 TPS56A37用于反相降压/升压转换器(IBB)的文档?
Guru**** 2503715 points
Other Parts Discussed in Thread: TPS56A37
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1427324/tps56a37-is-there-any-doc-using-the-tps56a37-for-an-inverting-buck-boost-ibb
器件型号:TPS56A37
能否 在 IBB 拓扑中配置 TPS56A37降压电源模块以生成负输出 电压?
