[参考译文] TPS25983:您可以帮助查看 PCB 吗? 谢谢。
Guru**** 2526700 points
Other Parts Discussed in Thread: TPS25983
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1442271/tps25983-could-you-pls-help-review-the-pcb-thanks
器件型号:TPS25983
Dears、
  客户希望 TI 工程师帮助查看 TPS25983.coud 您可以帮助吗? 谢谢。
e2e.ti.com/.../SCH_5F00_PCB1773_2D00_001-PCLEX4-RevB.pdfe2e.ti.com/.../SCH_5F00_PCB1773_2D00_002-PCLEX5-RevB.pdf
e2e.ti.com/.../PCB_5F00_PCB1773_2D00_001-PCLEX4-RevB.pdfe2e.ti.com/.../PCB_5F00_PCB1773_2D00_002-PCLEX5-RevB.pdf
