[参考译文] TPS62912:TPS6291x 用作反相降压/升压转换器?
Guru**** 2811595 points
Other Parts Discussed in Thread: TPS62913, TPS62912, TPS62918, TPS62914, TPS62916
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1469189/tps62912-tps6291x-used-as-inverting-buck-boost-converter
器件型号:TPS62912
主题中讨论的其他器件: TPS62918TPS62914TPS62916、TPS62913
您好、TI 专家!
 TPS6291x 系列的同步降压转换器 (TPS62912、TPS62913、TPS62914、TPS62916和 TPS62918)是否可用作 反相降压/升压转换器?
https://www.ti.com/lit/an/snva856b/snva856b.pdf?ts = 1738589258649&ref_url=https%253A%252F%252Fwww.ti.com%252Fproduct%252FLMR33630
Fabio
