[参考译文] 关于:PROCESSOR-SDK-AM64X:在适用于 AM64X 的 Processor SDK Linux 中删除和添加封装
Guru**** 2457760 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1493716/re-processor-sdk-am64x-removing-and-adding-packages-in-processor-sdk-linux-for-am64x
谢谢您
您好、Andreas、
我在 AM64xx EVM 上遇到 xHCI 主机控制器超时问题。 错误消息如下所示:
[   11.272609] usbcore: registered new interface driver usbfs
[   11.304515] usbcore: registered new interface driver hub
[   11.354920] usbcore: registered new device driver usb
[   11.551351] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   11.557242] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1        am64xx-evm login: [   21.572530] xhci-hcd xhci-hcd.0.auto: can't setup: -110
[   21.577883] xhci-hcd xhci-hcd.0.auto: USB bus 1 deregistered
[   21.586559] xhci-hcd: probe of xhci-hcd.0.auto failed with error -110
我已尝试重新启动系统并检查连接、但问题仍然存在。 您能否提供有关如何解决此错误的指导?
谢谢你
