您好团队
我们正在处理 QNX + Altia 应用
我在运行 Altia 应用时得到了错误代码:它调用了 CPU ID 0x10e000f0、但我的 CPU ID 是随机的、为 0x10b000f0 和 0x10c000f0、如何更改 CPU ID?
AM62PX-EVM@QNX:/ti_fs/usr/bin# altia_0815 This is a developmental libary. This is meant for demonstration purposes only. This is a test of the bsp_debugMessage function. Using CPU id as a check 0x10e000f0 Your CPU has an invalid CPU 0x10b000f0 Altia code gen message: Failed to initialize Driver Altia code gen message: GL display device open failed! Failed to start Altia
