[参考译文] TDA4VH-Q1:串行器/解串器 2 上的两个 USXGMII 和两个 SGMII 接口不能同时使用
Guru**** 2988540 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1640353/tda4vh-q1-the-two-usxgmii-and-two-sgmii-interfaces-on-serdes-2-cannot-be-used-simultaneously
器件型号: TDA4VH-Q1
Thread 中讨论的其他器件: TDA4VH
你(们)好
在 SDK 9.2 中、串行器/解串器 2 上的两个 USXGMII 和两个 SGMII 接口不能同时使用。
我正在使用以下设备树:
&main_cpsw0 {
	status = "okay";
	pinctrl-names = "default";
 &main_cpsw0_port1 {
	status = "okay"; //"okay"; //"okay";
	phy-mode = "usxgmii";
	mac-address = [00 00 00 00 00 00];
	phys = <&cpsw0_phy_gmii_sel 1>, <&serdes2_usxgmii12_link>;
	phy-names = "mac", "serdes";
	fixed-link {
		speed = <10000>;
		full-duplex;
&main_cpsw0_port2 {
	status = "okay";
	phys = <&cpsw0_phy_gmii_sel 2>, <&serdes2_usxgmii12_link>;
	fixed-link {
		speed = <10000>;
		full-duplex;
&main_cpsw0_port5 {
	status = "okay";// "disabled";//
	phy-mode = "sgmii";
 	phys = <&cpsw0_phy_gmii_sel 5>, <&serdes2_sgmii56_link>;
	fixed-link {
		speed = <1000>;
		full-duplex;
&main_cpsw0_port6 {
	status = "okay";
	phy-mode = "sgmii";
 	phys = <&cpsw0_phy_gmii_sel 6>, <&serdes2_sgmii56_link>;
	fixed-link {
		speed = <1000>;
		full-duplex;
&serdes_wiz2 {
	status = "okay";
	assigned-clock-parents = <&k3_clks 406 10>;
&serdes2 {
	status = "okay";
	#address-cells = <1>;
	#size-cells = <0>;
	assigned-clock-parents = <&k3_clks 406 5>,
				 <&k3_clks 406 6>,
				 <&k3_clks 406 6>;
	serdes2_usxgmii12_link: phy@2 {
		reg = <2>;
		cdns,num-lanes = <2>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_USXGMII>;
		resets = <&serdes_wiz2 3>, <&serdes_wiz2 4>;
	serdes2_sgmii56_link: phy@1 {
		reg = <1>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_SGMII>;
		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>;
&serdes_ln_ctrl {
	idle-states =
		<J784S4_SERDES0_LANE0_PCIE1_LANE0>, <J784S4_SERDES0_LANE1_IP1_UNUSED>,
		<J784S4_SERDES0_LANE2_PCIE3_LANE0>, <J784S4_SERDES0_LANE3_IP4_UNUSED>,
		<J784S4_SERDES1_LANE0_PCIE0_LANE0>, <J784S4_SERDES1_LANE1_QSGMII_LANE4>,
		<J784S4_SERDES1_LANE2_PCIE2_LANE0>, <J784S4_SERDES1_LANE3_IP4_UNUSED>,
		<J784S4_SERDES2_LANE0_QSGMII_LANE5>, <J784S4_SERDES2_LANE1_QSGMII_LANE6>,
		<J784S4_SERDES2_LANE2_QSGMII_LANE1>, <J784S4_SERDES2_LANE3_QSGMII_LANE2>,
		<J784S4_SERDES4_LANE0_IP3_UNUSED>, <J784S4_SERDES4_LANE1_IP3_UNUSED>,
		<J784S4_SERDES4_LANE2_QSGMII_LANE7>, <J784S4_SERDES4_LANE3_QSGMII_LANE8>;
日志:
 CDN-torrent-phy 5020000.serdes:等待 CMN 就绪超时
 PHY phy-5020000.serdes.14: phy 加电失败-->–110
 am65-cpsw-nuss:c000000.ethernet 探测失败、错误为–110
USXGMII 在专门启用时正常工作。 这同样适用于单独启用时的 SGMII。
USXGMII 在以下设备树中正常工作。
&main_cpsw0 {
	status = "okay";
 &main_cpsw0_port1 {
	fixed-link {
		speed = <10000>;
		full-duplex;
&main_cpsw0_port2 {
	status = "okay";
	fixed-link {
		speed = <10000>;
		full-duplex;
&serdes_wiz2 {
	status = "okay";
&serdes2 {
	status = "okay";
	#size-cells = <0>;
				 <&k3_clks 406 6>,
				 <&k3_clks 406 6>;
		reg = <2>;
		#phy-cells = <0>;
&serdes_ln_ctrl {
	idle-states =
SGMII 可与以下器件树正常工作。
&main_cpsw0 {
	status = "okay";
&main_cpsw0_port5 {
	phy-mode = "sgmii";
	fixed-link {
		speed = <1000>;
		full-duplex;
&main_cpsw0_port6 {
	status = "okay";
	phy-mode = "sgmii";
	fixed-link {
		speed = <1000>;
		full-duplex;
&serdes_wiz2 {
	status = "okay";
&serdes2 {
	status = "okay";
	#size-cells = <0>;
		reg = <1>;
		#phy-cells = <0>;
&serdes_ln_ctrl {
	idle-states =
James
    您好、
    您能  通过以下 串行器/解串器时钟配置进行检查吗?
    &serdes_wiz2 {
        assigned-clocks = <&k3_clks 407 6>, <&k3_clks 407 5>;
        assigned-clock-parents = <&k3_clks 407 10> /* Use 100MHz clock for SGMII */, <&k3_clks 406 9>; /* Use 156.25 MHz clock for USXGMII */
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    	assigned-clock-parents = <&k3_clks 406 6>,
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    Sudhee
    你(们)好
    此配置
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    没有错误日志、但 10G 和 1G 链路均无法 ping 通。
    MDIO_ALIVE_REG (0x0c000f08) = 0x00000000
    MDIO_LINK_REG (0x0c000f0c) = 0x00000000
    please input your port: 1-8 6
    CTRLMMR_ENET 6 CTRL (0x00104058) = 0x00000003
            PORT_MODE_SEL          : 3h SGMII
            RGMII_ID_MODE          : 0h Internal Transmit Desaly
    CPSW SS RGMII 6 STATUS (0x0c000044) = 0x00000000
            FULLDUPLEX           : 0h Half duplex
            SPEED                : 0h 10Mbps
            LINK                 : 0h Links is down
    CPSW_SS_STATUS_SGMII_LINK_REG (0x0c000078) = 0x00000000
            SGMII1_LINK          : 0h No
    CPSW_SS_SGMII_CONTROL_REG_ 6 (0x0c000610) = 0x00000020
            TEST_PATTERN_EN      : 0h operation
            MASTER               : 1h Master Mode
            LOOPBACK             : 0h Not in internal loopback mode
            MR_NP_LOADED         : 0h --------
            FAST_LINK_TIMER      : 0h link timer 10ms in FIBER mode and 1.6ms in SGMII mode
            MA_AN_RESTART        : 0h Write 1h and tehn 0h to this bit caused the auto negotiation
            MR_AN_ENABLE         : 0h wirte 1 to this bit enbales the auto negotiation progess
    CPSW_SS_SGMII_STATUS_REG_ 6 (0x0c000614) = 0x0000003C
            LOCK                  : 1h SERDES PLL is locked.
            MR_AN_COMPLETE        : 1h AUTO negotiation completed.
            AN_EEROR              : 0h no negotiation error
            LINK                  : 0h link is not up
    usxgmii 和 SGMII
    root@j784s4-evm:~# ethtool   eth1
    Settings for eth1:
            Supported ports: [ MII ]
            Supported link modes:   10000baseCR/Full
            Supported pause frame use: Symmetric Receive-only
            Supports auto-negotiation: Yes
            Supported FEC modes: Not reported
            Advertised link modes:  10000baseCR/Full
            Advertised pause frame use: Symmetric
            Advertised auto-negotiation: Yes
            Advertised FEC modes: Not reported
            Link partner advertised link modes:  10000baseCR/Full
            Link partner advertised pause frame use: No
            Link partner advertised auto-negotiation: No
            Link partner advertised FEC modes: Not reported
            Speed: 10000Mb/s
            Duplex: Full
            Auto-negotiation: on
            Port: MII
            PHYAD: 0
            Transceiver: internal
            Supports Wake-on: d
            Wake-on: d
            Current message level: 0x000020f7 (8439)
                                   drv probe link ifdown ifup rx_err tx_err hw
            Link detected: yes
    Settings for eth3:
            Supported link modes:   1000baseT/Full
            Advertised link modes:  1000baseT/Full
            Link partner advertised link modes:  1000baseT/Full
            Speed: 1000Mb/s
            Duplex: Full
            Port: MII
            PHYAD: 0
            Supports Wake-on: d
            Wake-on: d
            Link detected: no
    James
    您好、
    您能否使用 k3conf 工具共享 SerDes4 时钟转储。
    此外、还应提供完整的 Linux 终端日志。
    Sudheer
    您好、
    串行器/解串器时钟配置看起来正常。
    您能按以下方式更改串行器/解串器节点并选中一次吗?
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    	serdes2_sgmii56_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <2>;
    		#phy-cells = <0>;
    Sudheer
    你(们)好
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <2>;
    		#phy-cells = <0>;
    		reg = <0>;
    		#phy-cells = <0>;
     root@j784s4-evm:~# ./j7_devmem2_cpsw9g_check_status.sh
        Platform: J7 TDA4VM
        Command:  k3conf
            SPEED                : 0h 10Mbps
            SGMII1_LINK          : 0h No
    CPSW_SS_SGMII_STATUS_REG_ 6 (0x0c000614) = 0x00000030
            MR_AN_COMPLETE        : 0h no AUTO Negotiation is not complete
    仍然无法 ping。
     如果我移除该 &serdes_wiz2 节点并仅保留 &serdes2 配置、系统将进入连续循环、输出以下日志。
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <2>;
    		#phy-cells = <0>;
    		reg = <0>;
    		#phy-cells = <0>;
    日志:
    [  191.426759] hwmon hwmon2: temp1_input not attached to any thermal zone
    [  191.437916] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver Marvell 88Q2112
    [  191.463452] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirk0
    [  191.477120] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [  191.522679] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [  191.542770] hwmon hwmon0: temp1_input not attached to any thermal zone
    [  191.566761] hwmon hwmon1: temp1_input not attached to any thermal zone
    [  191.590761] hwmon hwmon2: temp1_input not attached to any thermal zone
    [  191.601914] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver Marvell 88Q2112
    [  191.627446] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirk0
    [  191.641112] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [  191.686680] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [  191.706773] hwmon hwmon0: temp1_input not attached to any thermal zone
    [  191.730760] hwmon hwmon1: temp1_input not attached to any thermal zone
    [  191.754761] hwmon hwmon2: temp1_input not attached to any thermal zone
    [  191.765916] davinci_mdio c000f00.mdio: phy[3]: device c000f00.mdio:03, driver Marvell 88Q2112
    [  191.791454] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirk0
    [  191.805115] davinci_mdio c000f00.mdio: Configuring MDIO in manual mode
    [  191.850680] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    James
    您好、
     如果我删除 &serdes_wiz2 节点并仅保留 &serdes2 配置、系统将进入连续循环、输出以下日志。
    时钟配置需要 SERDES_wiz2 节点。
    [引用 userid=“689907“ url=“~/support/processors-group/processors/f/processors-forum/1640353/tda4vh-q1-the-two-usxgmii-and-two-sgmii-interfaces-on-serdes-2-cannot-be-used-simultaneously/6327322
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    仍然无法 ping。
    这与我建议用于 SerDes2 节点的设备树配置不同。
    您能否请查看我的建议、第一个节点是 SGMII、然后是 USXGMII、但在器件树中、第一个节点是 USXGMII、然后是 SGMII。
    请查看建议的配置并告知我们结果。
    Sudheer
    你好、Sudheer
      使用此配置时、Ping 仍失败。
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <2>;
    		#phy-cells = <0>;
        Platform: J7 TDA4VM
        Command:  k3conf
            SPEED                : 0h 10Mbps
            SGMII1_LINK          : 0h No
    CPSW_SS_SGMII_STATUS_REG_ 6 (0x0c000614) = 0x00000032
            AN_EEROR              : 1h AUTO negotiation error
    James
    您好、
    您能否共享以下文档中列出的 SerDes 和 CPSW 寄存器。
    https://www.ti.com/lit/ab/sprads2/sprads2.pdf
    Sudheer
    您好、Sudheer
    这是在冷启动期间使用的配置:
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <2>;
    		#phy-cells = <0>;
    错误日志:
    [ 2.863423] CDNs-torrent-phy 5020000.serdes:等待 CMN 就绪超时
    [ 2.870286] phy phy-5020000.serdes.13: phy power on failed -->–110
    [ 2.876908] am65-cpsw-Nuss:c000000.ethernet 探测失败、错误为–110
    我找到了一个涉及两步引导过程的解决方法:
    1. 步骤 1: 使用简化的配置进行引导(只启用 USXGMII、Wiz 使用不同的时钟父级)。
    2. 步骤 2: 通过设备树覆盖 (dtso) 应用完整配置(如上所示)并 重新引导。
    完成此序列后、系统将成功引导、而不会出现“CMN 就绪“超时。
    步骤 1 配置(中间引导):
    &serdes_wiz2 {
        assigned-clock-parents = <&k3_clks 406 10> ;
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 6>,
    				 <&k3_clks 406 6>;
    		reg = <2>;
    		#phy-cells = <0>;
    我在通过两步流程引导后读取寄存器值。
    CTRL_MMR_CFG0_SERDES2_LNx_CTRL:
    root@j784s4-evm:~# devmem2 0x001040a0
    Read at address  0x001040A0 (0xffff9faf20a0): 0x00000000
    root@j784s4-evm:~# devmem2 0x001040a4
    Read at address  0x001040A4 (0xffff803300a4): 0x00000000
    root@j784s4-evm:~# devmem2 0x001040a8
    Read at address  0x001040A8 (0xffff9631e0a8): 0x00000001
    root@j784s4-evm:~# devmem2 0x001040ac
    Read at address  0x001040AC (0xffffaf7160ac): 0x00000001
    CTRL_MMR_CFG0_SERDES4_LNx_CTRL:
    root@j784s4-evm:~# devmem2 0x001040c0
    Read at address  0x001040C0 (0xffff8d00d0c0): 0x00000002
    root@j784s4-evm:~# devmem2 0x001040c4
    Read at address  0x001040C4 (0xffff895db0c4): 0x00000002
    root@j784s4-evm:~# devmem2 0x001040c8
    Read at address  0x001040C8 (0xffffa137a0c8): 0x00000001
    root@j784s4-evm:~# devmem2 0x001040cc
    Read at address  0x001040CC (0xffffb34540cc): 0x00000001
    CTRL_MMR_CFG0_ENETx_CTRL_PROXY:
    root@j784s4-evm:~# devmem2 0x00106044
    Read at address  0x00106044 (0xffffb496f044): 0x00000005
    root@j784s4-evm:~# devmem2 0x00106048
    Read at address  0x00106048 (0xffff852ed048): 0x00000005
    root@j784s4-evm:~# devmem2 0x0010604c
    Read at address  0x0010604C (0xffffbf6e704c): 0x00000002
    root@j784s4-evm:~# devmem2 0x00106050
    Read at address  0x00106050 (0xffff8af24050): 0x00000003
    root@j784s4-evm:~# devmem2 0x00106054
    Read at address  0x00106054 (0xffff81649054): 0x00000003
    root@j784s4-evm:~# devmem2 0x00106058
    Read at address  0x00106058 (0xffffafebd058): 0x00000003
    root@j784s4-evm:~# devmem2 0x0010605c
    Read at address  0x0010605C (0xffff8231505c): 0x00000003
    root@j784s4-evm:~# devmem2 0x00106060
    Read at address  0x00106060 (0xffffad917060): 0x00000003
    CTRL_MMR_SERDESx_CLKSEL:
    root@j784s4-evm:~# devmem2  0x00108410
    Read at address  0x00108410 (0xffffa011e410): 0x00000003
    root@j784s4-evm:~# devmem2  0x00108420
    Read at address  0x00108420 (0xffff962bb420): 0x00000003
    root@j784s4-evm:~# devmem2  0x00108440
    Read at address  0x00108440 (0xffff981e5440): 0x00000003
    CTRL_MMR_SERDESx_CLK1SEL:
    root@j784s4-evm:~# devmem2  0x00108414
    Read at address  0x00108414 (0xffffbec53414): 0x00000000
    root@j784s4-evm:~# devmem2  0x00108424
    Read at address  0x00108424 (0xffffa2bfd424): 0x00000000
    CPSW Port Link Control and Status Registers:
    root@j784s4-evm:~# devmem2 0x0c000110
    Read at address  0x0C000110 (0xffff91d6f110): 0x00000000
    root@j784s4-evm:~# devmem2 0x0c000210
    Read at address  0x0C000210 (0xffffa4200210): 0x00000000
    root@j784s4-evm:~# devmem2 0x0c000610
    Read at address  0x0C000610 (0xffffbbd84610): 0x00000020
    root@j784s4-evm:~# devmem2 0x0c000114
    Read at address  0x0C000114 (0xffff933f8114): 0x00000020
    Memory mapped at address 0xffff97dbf000.
    Read at address  0x0C000214 (0xffff97dbf214): 0x00000020
    root@j784s4-evm:~# devmem2 0x0c000614
    Read at address  0x0C000614 (0xffff86a75614): 0x0000003C
    root@j784s4-evm:~# devmem2 0x0c000118
    Read at address  0x0C000118 (0xffffb433e118): 0x00000000
    root@j784s4-evm:~# devmem2 0x0c000218
    Read at address  0x0C000218 (0xffffb891d218): 0x00000000
    root@j784s4-evm:~# devmem2 0x0c000618        .
    Read at address  0x0C000618 (0xffffa8264618): 0x00009801
    root@j784s4-evm:~# devmem2 0x0c000074
    Read at address  0x0C000074 (0xffffae35f074): 0x00000000
    root@j784s4-evm:~# devmem2 0x0C022330
    Read at address  0x0C022330 (0xffff9f060330): 0x00002121
    root@j784s4-evm:~# devmem2 0x0C023330
    Read at address  0x0C023330 (0xffff898e4330): 0x00002121
    root@j784s4-evm:~# devmem2 0x0C027330
    Read at address  0x0C027330 (0xffff835c6330): 0x000400A1
     SerDes Lane Configuration and PLL Mapping Registers:
    root@j784s4-evm:~#  devmem2 0x05020000
    Read at address  0x05020000 (0xffff83c30000): 0x00007364
    root@j784s4-evm:~#  devmem2 0x05020408
    Read at address  0x05020408 (0xffff9a0f3408): 0x18100000
    root@j784s4-evm:~#  devmem2 0x0502040c
    Read at address  0x0502040C (0xffffa6a8d40c): 0xA2C00000
    root@j784s4-evm:~#
    root@j784s4-evm:~#  devmem2 0x0502e000
    Read at address  0x0502E000 (0xffffb32ed000): 0x00C30051
    root@j784s4-evm:~#  devmem2 0x05020480
    Read at address  0x05020480 (0xffff83fac480): 0x70800000
    root@j784s4-evm:~#  devmem2 0x05020484
    Read at address  0x05020484 (0xffffaf51a484): 0x00010002
    root@j784s4-evm:~#  devmem2 0x0502048c
    Read at address  0x0502048C (0xffffa8baa48c): 0x00000002
    root@j784s4-evm:~#
    root@j784s4-evm:~#  devmem2 0x050204c0
    Read at address  0x050204C0 (0xffffb5dea4c0): 0x70800000
    root@j784s4-evm:~#  devmem2 0x050204c4
    Read at address  0x050204C4 (0xffff82fe94c4): 0x00010002
    root@j784s4-evm:~#  devmem2 0x050204c8
    Read at address  0x050204C8 (0xffff80cd34c8): 0x00000000
    root@j784s4-evm:~#  devmem2 0x050204cc
    Read at address  0x050204CC (0xffffbd30e4cc): 0x00000002
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~#  devmem2 0x05020500
    Read at address  0x05020500 (0xffffb07fa500): 0x713800C0
    root@j784s4-evm:~#  devmem2 0x05020504
    Read at address  0x05020504 (0xffff82966504): 0x00010002
    root@j784s4-evm:~#  devmem2 0x05020508
    Read at address  0x05020508 (0xffff9a4e4508): 0x00000000
    root@j784s4-evm:~#  devmem2 0x0502050c
    Read at address  0x0502050C (0xffff8059050c): 0x00000012
    root@j784s4-evm:~#
    root@j784s4-evm:~#  devmem2 0x05020540
    Read at address  0x05020540 (0xffffb885b540): 0x713800C0
    root@j784s4-evm:~#  devmem2 0x05020544
    Read at address  0x05020544 (0xffffacdf5544): 0x00010002
    root@j784s4-evm:~#  devmem2 0x05020548
    Read at address  0x05020548 (0xffffb810f548): 0x00000000
    root@j784s4-evm:~#  devmem2 0x0502054c
    Read at address  0x0502054C (0xffffa411954c): 0x00000012
    James
    您好、
    [引用 userid=“689907“ url=“~/support/processors-group/processors/f/processors-forum/1640353/tda4vh-q1-the-two-usxgmii-and-two-sgmii-interfaces-on-serdes-2-cannot-be-used-simultaneously/6329121
    步骤 1 配置(中间引导):
    [/报价]
    不需要执行两步引导过程。
    [quote userid=“689907“ url=“~/support/processors-group/processors/f/processors-forum/1640353/tda4vh-q1-the-two-usxgmii-and-two-sgmii-interfaces-on-serdes-2-cannot-be-used-simultaneously/6329121 通过两步流程引导后读取寄存器值。
    是否在单引导模式下 启用 SGMII + USXGMII 时串行器/解串器寄存器值相同。
    Sudheer
    你(们)好  Sudheer
    是否在单引导模式下使用相同的串行器/解串器寄存器值并且 启用 SGMII + USXGMII。
    启用 usxgmii SGMII 将导致以下错误
    错误日志:
    James
    你好 Sudherr
      TDA4VH LSDK9.2 本机驱动程序 Serdes2 是否也使用 USXGMII 和 SGMII?
    James
    您好、
    我已经在我这边尝试过同样的方法,并观察到同样的问题。
    我会检查我这边的问题、并尽快回复您。
    Sudheer
    您好、
    抱歉、上面的器件树配置出错、我在时钟映射中给出了错误的器件 ID。
    请通过以下配置进行检查。
    &serdes_wiz2 {
        assigned-clocks = <&k3_clks 406 6>, <&k3_clks 406 5>;
        assigned-clock-parents = <&k3_clks 406 10> /* Use 100MHz clock for SGMII */, <&k3_clks 406 9>; /* Use 156.25 MHz clock for USXGMII */
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <2>;
    		#phy-cells = <0>;
    		reg = <0>;
    		#phy-cells = <0>;
    &serdes_ln_ctrl {
    	idle-states =
    Sudheer
    您好、
    今天、我进行了另一项测试、这种配置仍然无法 ping 通、无论是 USXGMII 还是 SGMII。
    读取寄存器值:
    [/报价]
    在有两个以上引导工作函数的情况下、寄存器值进行了关键操作。
    您能否在下面添加 突出的更改并进行一次检查。
    Sudheer
    你(们)好
    我已添加并使用以下器件树
    仍然无法 ping。
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <2>;
    		#phy-cells = <0>;
    		reg = <0>;
    		#phy-cells = <0>;
    &serdes_ln_ctrl {
    	idle-states =
    /dev/mem opened.
    Memory mapped at address 0xffffacbb6000.
    Read at address  0x001040A0 (0xffffacbb60a0): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffb7f68000.
    Read at address  0x001040A4 (0xffffb7f680a4): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffb23a5000.
    Read at address  0x001040A8 (0xffffb23a50a8): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0xffff9bd2e000.
    Read at address  0x001040AC (0xffff9bd2e0ac): 0x00000001
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff89237000.
    Read at address  0x001040C0 (0xffff892370c0): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffff82000000.
    Read at address  0x001040C4 (0xffff820000c4): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffff7f7a6000.
    Read at address  0x001040C8 (0xffff7f7a60c8): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0xffff83236000.
    Read at address  0x001040CC (0xffff832360cc): 0x00000001
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffac5b5000.
    Read at address  0x00106044 (0xffffac5b5044): 0x00000005
    /dev/mem opened.
    Memory mapped at address 0xffffb3048000.
    Read at address  0x00106048 (0xffffb3048048): 0x00000005
    /dev/mem opened.
    Memory mapped at address 0xffff8d170000.
    Read at address  0x0010604C (0xffff8d17004c): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffff8ab40000.
    Read at address  0x00106050 (0xffff8ab40050): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffffaec1a000.
    Read at address  0x00106054 (0xffffaec1a054): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff96ecd000.
    Read at address  0x00106058 (0xffff96ecd058): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff8722d000.
    Read at address  0x0010605C (0xffff8722d05c): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffffb98e2000.
    Read at address  0x00106060 (0xffffb98e2060): 0x00000003
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~# devmem2  0x00108400
    /dev/mem opened.
    Memory mapped at address 0xffff81a52000.
    Read at address  0x00108400 (0xffff81a52400): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff90fba000.
    Read at address  0x00108410 (0xffff90fba410): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff9682f000.
    Read at address  0x00108420 (0xffff9682f420): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff9fed9000.
    Read at address  0x00108440 (0xffff9fed9440): 0x00000003
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff7f722000.
    Read at address  0x00108414 (0xffff7f722414): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffff8cc9a000.
    Read at address  0x00108424 (0xffff8cc9a424): 0x00000000
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffba68a000.
    Read at address  0x0C023330 (0xffffba68a330): 0x00002121
    /dev/mem opened.
    Memory mapped at address 0xffff97f20000.
    Read at address  0x0C027330 (0xffff97f20330): 0x000400A1
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff81401000.
    Read at address  0x05020000 (0xffff81401000): 0x00007364
    /dev/mem opened.
    Memory mapped at address 0xffffae254000.
    Read at address  0x05020408 (0xffffae254408): 0x18100000
    /dev/mem opened.
    Memory mapped at address 0xffff9dc20000.
    Read at address  0x0502040C (0xffff9dc2040c): 0xA2C00000
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffa45b2000.
    Read at address  0x0502E000 (0xffffa45b2000): 0x00C30051
    /dev/mem opened.
    Memory mapped at address 0xffff9fec1000.
    Read at address  0x05020480 (0xffff9fec1480): 0x70800000
    /dev/mem opened.
    Memory mapped at address 0xffffa51ec000.
    Read at address  0x05020484 (0xffffa51ec484): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffffb8476000.
    Read at address  0x0502048C (0xffffb847648c): 0x00000002
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff94f3e000.
    Read at address  0x050204C0 (0xffff94f3e4c0): 0x70800000
    /dev/mem opened.
    Memory mapped at address 0xffffaf163000.
    Read at address  0x050204C4 (0xffffaf1634c4): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffff9fb70000.
    Read at address  0x050204C8 (0xffff9fb704c8): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffff8ba30000.
    Read at address  0x050204CC (0xffff8ba304cc): 0x00000002
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff88517000.
    Read at address  0x05020500 (0xffff88517500): 0x713800C0
    /dev/mem opened.
    Memory mapped at address 0xffff8d1c0000.
    Read at address  0x05020504 (0xffff8d1c0504): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffffac5ec000.
    Read at address  0x05020508 (0xffffac5ec508): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffa0233000.
    Read at address  0x0502050C (0xffffa023350c): 0x00000012
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffb4088000.
    Read at address  0x05020540 (0xffffb4088540): 0x713800C0
    /dev/mem opened.
    Memory mapped at address 0xffffb7573000.
    Read at address  0x05020544 (0xffffb7573544): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffff87b7e000.
    Read at address  0x05020548 (0xffff87b7e548): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffa63b4000.
    Read at address  0x0502054C (0xffffa63b454c): 0x00000012
    James
    您好、
    抱歉、串行器/解串器节点必须遵循 SGMII 的顺序并遵循 USXGMII。
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <2>;
    		#phy-cells = <0>;
    此外、根据上述寄存器值、建议的更改没有反映。 如果反映、则串行器/解串器 SGMII 通道的通道控制寄存器的值将为 0x70A00000、内部为 0x70800000。
    Sudheer
    您好、
    我已进行了修改、但仍然无法 ping 通
    &serdes_wiz2 {
        status = "okay";
    &serdes2 {
    	status = "okay";
    	#size-cells = <0>;
    				 <&k3_clks 406 5>,
    				 <&k3_clks 406 6>;
    		reg = <0>;
    		#phy-cells = <0>;
    		reg = <2>;
    		#phy-cells = <0>;
    &serdes_ln_ctrl {
    	idle-states =
    /dev/mem opened.
    Memory mapped at address 0xffffbeb67000.
    Read at address  0x001040A0 (0xffffbeb670a0): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffa18cc000.
    Read at address  0x001040A4 (0xffffa18cc0a4): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffa17ad000.
    Read at address  0x001040A8 (0xffffa17ad0a8): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0xffffa1e6b000.
    Read at address  0x001040AC (0xffffa1e6b0ac): 0x00000001
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffbed39000.
    Read at address  0x001040C0 (0xffffbed390c0): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffffb7fb9000.
    Read at address  0x001040C4 (0xffffb7fb90c4): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffffb5cb4000.
    Read at address  0x001040C8 (0xffffb5cb40c8): 0x00000001
    /dev/mem opened.
    Memory mapped at address 0xffffb0774000.
    Read at address  0x001040CC (0xffffb07740cc): 0x00000001
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff9f6d1000.
    Read at address  0x00106044 (0xffff9f6d1044): 0x00000005
    /dev/mem opened.
    Memory mapped at address 0xffffaf078000.
    Read at address  0x00106048 (0xffffaf078048): 0x00000005
    /dev/mem opened.
    Memory mapped at address 0xffffa24b7000.
    Read at address  0x0010604C (0xffffa24b704c): 0x00000002
    /dev/mem opened.
    Memory mapped at address 0xffffb53f8000.
    Read at address  0x00106050 (0xffffb53f8050): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff9fc6c000.
    Read at address  0x00106054 (0xffff9fc6c054): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff8f34c000.
    Read at address  0x00106058 (0xffff8f34c058): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffffae3be000.
    Read at address  0x0010605C (0xffffae3be05c): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffffa7390000.
    Read at address  0x00106060 (0xffffa7390060): 0x00000003
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff94c8f000.
    Read at address  0x00108400 (0xffff94c8f400): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff851c4000.
    Read at address  0x00108410 (0xffff851c4410): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffffb5731000.
    Read at address  0x00108420 (0xffffb5731420): 0x00000003
    /dev/mem opened.
    Memory mapped at address 0xffff8fe91000.
    Read at address  0x00108440 (0xffff8fe91440): 0x00000003
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffa0997000.
    Read at address  0x00108414 (0xffffa0997414): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffffa38fb000.
    Read at address  0x00108424 (0xffffa38fb424): 0x00000000
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffade7d000.
    Read at address  0x0C022330 (0xffffade7d330): 0x00002121
    /dev/mem opened.
    Memory mapped at address 0xffff7fdce000.
    Read at address  0x0C023330 (0xffff7fdce330): 0x00002121
    /dev/mem opened.
    Memory mapped at address 0xffff9a122000.
    Read at address  0x0C027330 (0xffff9a122330): 0x000400A1
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffbd079000.
    Read at address  0x05020000 (0xffffbd079000): 0x00007364
    /dev/mem opened.
    Memory mapped at address 0xffffaa218000.
    Read at address  0x05020408 (0xffffaa218408): 0x18100000
    /dev/mem opened.
    Memory mapped at address 0xffff86654000.
    Read at address  0x0502040C (0xffff8665440c): 0xA2C00000
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff8074e000.
    Read at address  0x0502E000 (0xffff8074e000): 0x00C30051
    /dev/mem opened.
    Memory mapped at address 0xffffbd95e000.
    Read at address  0x05020480 (0xffffbd95e480): 0x70A00000
    /dev/mem opened.
    Memory mapped at address 0xffff93ef7000.
    Read at address  0x05020484 (0xffff93ef7484): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffffbd5a7000.
    Read at address  0x0502048C (0xffffbd5a748c): 0x00000002
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffff8b610000.
    Read at address  0x050204C0 (0xffff8b6104c0): 0x70A00000
    /dev/mem opened.
    Memory mapped at address 0xffffaed1d000.
    Read at address  0x050204C4 (0xffffaed1d4c4): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffffb37fb000.
    Read at address  0x050204C8 (0xffffb37fb4c8): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffff92e83000.
    Read at address  0x050204CC (0xffff92e834cc): 0x00000002
    root@j784s4-evm:~#
    /dev/mem opened.
    Memory mapped at address 0xffffb5e57000.
    Read at address  0x05020500 (0xffffb5e57500): 0x713800C0
    /dev/mem opened.
    Memory mapped at address 0xffff9bf59000.
    Read at address  0x05020504 (0xffff9bf59504): 0x00010002
    /dev/mem opened.
    Memory mapped at address 0xffffaa8dd000.
    Read at address  0x05020508 (0xffffaa8dd508): 0x00000000
    /dev/mem opened.
    Memory mapped at address 0xffff94160000.
    Read at address  0x0502050C (0xffff9416050c): 0x00000012
    root@j784s4-evm:~#
    root@j784s4-evm:~#
    root@j784s4-evm:~# ./j7_cpsw9g_check_status.sh
        Platform: J7 TDA4VM
        Command:  k3conf
        Command:  k3conf
    CTRLMMR_ENET 6 CTRL (0x00104058) = 0x3
            SPEED                : 0h 10Mbps
            SGMII1_LINK          : 0h No
    CPSW_SS_SGMII_CONTROL_REG_j (0x0c000610) = 0x20
    CPSW_SS_SGMII_STATUS_REG_j (0x0c000614) = 0x3c
    James
    您好、
    您意味着即使有上述配置、也无法从 SGMII 和 USXGMII ping 通。
    让我在内部检查一次、然后返回给您。
    Sudheer
    您好、
    您表示即使使用上述配置、也无法同时从 SGMII 和 USXGMII ping。
    是的、
        Platform: J7 TDA4VM
        Command:  k3conf
        Command:  k3conf
            SPEED                : 0h 10Mbps
            SGMII1_LINK          : 0h No
    James
    您好、
    [引用 userid=“689907“ url=“~/support/processors-group/processors/f/processors-forum/1640353/tda4vh-q1-the-two-usxgmii-and-two-sgmii-interfaces-on-serdes-2-cannot-be-used-simultaneously/6337923
    是的、
    [/报价]
    我懂了。
    让我在内部进行检查、并在内部验证/验证后告知您一次。
    Sudheer
    你好 Sudheer,
       希望您度过一周愉快的时光。
       我只是在关注这一问题的现状。 您是否有机会完成内部验证?
       如果您需要我方面的进一步信息、请告诉我。
    James
    您好、
    抱歉耽误您的时间、我们正在处理一些高优先级问题。
    我们的同事 Tanmay 正在   最后验证这一点 请等待他的答复。
    Sudheer
    你好 Sudheer,
    感谢您的更新。 我完全理解您的团队目前正在处理高优先级问题。
    由于这个问题已有相当长一段时间未决,您能否告诉我们,如果有任何来自 Tanmay 的验证的初步发现?
    我们面临着推进我们的发展的巨大压力。 如果您能分享一个粗略的预计时间线或此修复的预期完成日期、我们将非常感激。 这将帮助我们相应地管理内部计划。
    期待尽快收到您的答复。
    James
    您好、
    很抱歉耽误你的时间。
    您可以查看下面串行器/解串器节点中的重要变化。
    Sudheer
