[参考译文] TDA2P-ACD:发生 Linux 内核 OMAP-SHIM 错误。
Guru**** 1372610 points
Other Parts Discussed in Thread: TCA6416, TCA8418, LM8333, ADS7846, TSC2004, TSC2005, TSC2007, TPS65218, PCF8574, DRV2665, DRV2667, TPIC2810, TPS65910, LP8727, BQ24190, BQ24257, BQ24735, BQ25890, TPS65090, TPS65217, LM63, LM70, LM73, LM77, LM80, LM83, LM87, LM90, LM92, LM93, LM95234, LM95241, LM95245, ADC128D818, ADS1015, ADS7828, ADS7871, AMC6821, INA209, INA3221, TMP102, TMP103, TMP108, TMP401, TMP421, LP3943, TPS65010, TPS65086, TPS65912, TWL6040, LM3533, LP3971, LP3972, TPS51632, TPS62360, TPS65023, TPS65132, TLV320AIC23B, TVP5150, TVP7002, THS8200, LM3560, THS7303, OPA362, TPD12S015, TFP410, LM3630A, PCM1681, PCM1789, PCM3168A, TAS2552, TAS5086, TLV320AIC23, TS3A227E, TPA6130A2, CDCE706, CDCE925, ADC084S021, ADC108S102, ADC128S052, ADC161S626, ADS7950, ADS8688, TLC4541, DAC082S085, DAC5571, AFE4403, AFE4404, OPT3001, LMP91000, TMP006, TMP007
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/925885/tda2p-acd-linux-kernel-omap_sham-error-occur
器件型号:TDA2P-ACD
主题中讨论的其他器件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
你好。
错误日志如下所示。
# cURL https://www.google.co.kr
omap_sham_xmit_cpu:sg miter 失败。
cryptodev:c卷[869](waitfor:294):异步请求出错:-22
cryptodev:ccur[869](hash-n_crypt:98):CryptoAPI 失败:-22
cURL:(35) error:02015016: system library:ioctl: Invalid arge.(卷曲:(35)错误:02015016:系统库:ioctl:无效
如果我使用 openssl 工具、则没有问题。
# openssl speed -EVP SHA256
在16个大小的块上执行 SHA256 3秒:110004 SHA256在0.71秒内
在64个大小的块上执行 SHA256 3秒:106967 SHA256在0.65秒内完成
对256个大小的块执行 SHA256 3秒操作:42146在0.32秒内 SHA256
在1024个大小的块上执行 SHA256 3秒:32260 SHA256在0.21秒内完成
在8192个大小的块上执行 SHA256 3秒:在0.12秒内执行18416个 SHA256
在16384大小的块上执行 SHA256 3秒:在0.10s 内执行12430 SHA256
OpenSSL 1.1.1g 2020年4月21日
建立于:2020年7月23日10:10:45 UTC
选项:bn (64、32) RC4 (char) des (long) AES (partial) Idea (int) blowfish (ptr)
编译器:arm-tiv83-linux-gcc -fpthread -wa、--noexecstack -i/opt/ti/arm-tiv83-linux/arm-gnueabihf/libc/usr/local.atp/./include -March =armv7-a -DOPENSSL_use_linux-gnueabih/lib_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcp_dcpu_dcp_dcp_dcp_
"数字"以每秒处理的1000s 字节为单位。
类型16字节64字节256字节1024字节8192字节16384字节
SHA256 2478.96k 10532.14k 33716.80k 157305.90k 1257198.93k 2036531.20k
我们的环境如下。
CPU:TDA2PX (定制板)
SDK:processor_sdk_vision_03_08_00_00
Linux:4.19.73
OpenSSL:1.1.1g。 它是为使用 cryptodev 设备驱动程序而构建的。
卷曲:7.71.1。 它是为使用 OpenSSL 而构建的。
密码开发:1.10.
请告诉我发生此错误的原因。
此致。
Yoesik。
    我将咨询 Linux 内核专家并返回。
    加维拉尤
    您好、Yoesik、
    请粘贴完整日志。 根据我预测的信息
    硬件加密由于某种原因失败、并且 openssl 正在采用
    软件加密。 我需要完整的引导日志才能取得更多进展。
    -凯尔西
    大家好、Keerty。
    感谢您的回复。
    我将附上以下信息。
    1.完整引导日志和 lsmod
    2.内核构建配置
    3. omap_sham.c 日志(将 dev_dbg 更改为 dev_err)
    这是 nfsroot 环境。
    1.完整引导日志和 lsmod
    U-Boot 2019.01-svn1168 (2020年7月20日- 14:56:44 +0900)
    CPU:DRA762-GP ES1.0 ACD 封装
    型号:ATP B5MK
    主板:B5MK
    DRAM:2GiB
    MMC:OMAP SD/MMC:0、OMAP SD/MMC:1.
    正在从 MMC 加载环境... 好的
    切换到分区#6,好的
    mmc1 (第6部分)是当前器件
    网络:
    警告:以太网@48484000 MAC 地址不匹配:
    ROM 中的地址为38:0b:3c:0f:e8:80
    环境中的地址为38:8e:7a:29:F7:D8
    eth0:以太网@48484000
    在2秒内自动启动、按"quit"停止。
    NFSROOT:b5mk_yousik,LNXFILE:b5mk/b5mk lnx_yousik.img
    以太网@48484000正在等待 PHY 自动协商完成..... 完成
    端口0、速度100、全双工上的链路
    使用以太网@48484000器件
    来自服务器10.47.2.10的 TFTP;我们的 IP 地址为10.47.24.65
    文件名"b5mk/b5mk lnx_yousik.img"。
    加载地址:0x82000000
    正在加载:############################################################################
    3.2 MIB/s
    完成
    传输的字节= 6173248 (5e3240十六进制)
    cmd> bootm 82000000
    ##从 Legacy Image 中引导内核,地址为82000000...
    图像名称:B5MK-LNX-K72792-R1191-YOUSIK
    映像类型:ARM Linux 内核映像(未压缩)
    数据大小:6173184字节= 5.9 MIB
    加载地址:80008000
    入口点:80008000
    正在加载内核映像... 好的
    正在将设备树加载到83fdc000,结束位置83fff77b... 好的
    正在启动内核...
    在物理 CPU 0x0上引导 Linux
    Linux 版本4.19.73+(yousik@dev.auto-it.co.kr)(gcc 版本8.3.0 (A 配置文件体系结构的 GNU 工具链8.3-2019.03 (ARM-rel-8.36)))#28 SMP 优先于 Mon Jul 27 09:20:03 KST 2020
    CPU:ARMv7处理器[412fc0f2]修订版2 (ARMv7)、CR=30c5387d
    CPU:可用的 div 指令:修补分部代码
    CPU:PIPT/VIPT 非混叠数据高速缓存、PIPT 指令高速缓存
    共:FDT:机器型号:ATP B5MK
    内存策略:数据高速缓存 writealloc
    EFI:从 FDT 获取 EFI 参数:
    EFI:未找到 UEFI。
    保留存储器:创建了0x000040300000、大小为3 MIB 的 DMA 存储器池
    共:保留内存:已初始化节点 cmem@40300000、兼容 ID 共享 dma-pool
    保留存储器:尚未支持无映射的区域
    保留存储器:创建了0x00009d000000的 CMA 存储器池、大小为44 MIB
    共:保留内存:已初始化节点 ipu2-memory@95800000、兼容 id sharedma-pool
    保留存储器:创建了0x00009fc00000 (大小为4 MIB)的 CMA 存储器池
    共:保留内存:已初始化节点 ipu1-memory@9d000000、兼容 id shareddma-pool
    保留存储器:尚未支持无映射的区域
    保留存储器:创建了0x00000000a1000000 (大小为32 MIB)的 CMA 存储器池
    共:保留内存:已初始化节点 dsp1-memory@99000000、兼容 id shared-dma-pool
    保留存储器:创建了0x00000000a3000000 (大小为32 MIB)的 CMA 存储器池
    共:保留内存:已初始化节点 dsp2-memory@9f000000、兼容 id shared-dma-pool
    保留存储器:尚未支持无映射的区域
    保留存储器:创建了大小为0x00000000a9000000、大小为32 MIB 的 DMA 存储器池
    共:保留内存:已初始化节点 cmem@A9000000、兼容 id shared-dma-pool
    保留存储器:尚未支持无映射的区域
    保留存储器:创建了0x00000000c0000000、大小为64 MIB 的 CMA 存储器池
    共:保留内存:已初始化节点 GPU-MEMORY@c0000000、兼容 ID 共享 DMA-POOL
    CMA:保留0x00000000fac00000处的64 MIB
    OMAP4:将0x00000000fed00000映射到 DRAM 隔离层的(ptrval)
    DRA762 ES1.0
    随机:从 start_kernel+0xec/0x4c0调用 get_random_bytes、crng_init=0
    百分比 pu:嵌入式16页/CPU s36364 r8192 d20980 u65536
    构建了1个区域列表、移动分组。 总页数:476736
    内核命令行:console=ttyS0、115200n8 root=/dev/nfs rw nfsroot=10.47.2.10:/nfsroot/b5mk_yousik、TCP IP=10.47.24.65:10.47.2.10:10.47.0.1:255.255.192.0::eth0:off pany=1 vmode=CMA board=020c0040 HDMI=0 cmode=0 NTSC_R570=UTE=247B=0:07:E=UTE=UTE=240720D8:UTE=UTE=24B=0:07:07:07:E=70:E=UTE=24B:0720D8
    DEntry 高速缓存哈希表条目:131072 (顺序:7、524288字节)
    inode 高速缓存哈希表条目:65536 (顺序:6、262144字节)
    内存:1028416K/1913856K (8192K 内核代码、359K rwdata、2600K rodata、2048K init、299K BSS、 639680K 保留、245760K CMA 保留、914432K HIGHMEM)
    虚拟内核内存布局:
    向量:0xff0000-0xff1000 (4KB)
    Fixmap:0xc00000 - 0xc00000 (3072 KB)
    vmalloc:0xf0800000 - 0x800000 (240 MB)
    低内存:0xC0000000-0xf0000000 (768 MB)
    pkmap:bfe00000 - 0xC0000000 (2 MB)
    模块:bbf000000 - bbfe00000 (14 MB)
    .text:0x (ptrval)- 0x (ptrval)(10208 KB)
    init:0x (ptrval)- 0x (ptrval)(2048KB)
    .data:0x (ptrval)- 0x (ptrval)(360KB)
    .bss:0x (ptrval)- 0x (ptrval)(300KB)
    slub:HWalign=64、order=0-3、MinObjects=0、CPU=2、Nodes=1
    RCU:可抢占的分层 RCU 实现。
    启用 RCU 任务。
    NR_IRQ:16、nr_IRQ:16、预分配 IRQ:16
    GIC:使用分离式 EOI/Deactivate 模式
    OMAP 时钟事件源:Timer1为32786Hz
    ARCH_TIMER:以6.14MHz (PHY)运行的 cp15计时器。
    时钟源:arch_sys_counter:mask:0xffffffffffffffffff max_cycles:0x16af5adb9、max_idle_ns:440795202250 ns
    SCHED_CLOCK:6MHz 时为56位、分辨率162ns、每4398046511023ns 换行一次
    切换到基于计时器的延迟环路、分辨率为162ns
    时钟源:32K_COUNTER:MASK:0xFFFFFFFF max_cycles:0xFFFFFFFF、max_idle_ns:58327039986419 ns
    OMAP 时钟源:32768Hz 时32K_COUNTER
    控制台:彩色虚拟设备80x30
    校准延迟环路(跳过)、使用计时器频率计算的值。 12.29茂物剪(lpj=61475)
    PID_max:默认值:32768最小值:301
    挂载缓存哈希表条目:2048 (顺序:1、8192字节)
    mountpoint-cache 哈希表条目:2048 (顺序:1、8192字节)
    CPU:测试写入缓冲区一致性:好的
    CPU0:幽灵 v2:使用 ICIALLUE 变通办法
    /cpus/cpu@0缺少时钟频率属性
    /cpus/cpu@1缺少时钟频率属性
    CPU0:线程-1、CPU 0、套接字0、mpidr 8000000
    为0x80200000-0x80200060设置静态标识映射
    RCU:分层 SRCU 实现。
    EFI 服务将不可用。
    SMP:启动辅助 CPU ...
    CPU1:线程-1、CPU 1、插座0、mpidr 80000001
    CPU1:sp幽灵 v2:使用 ICIALLUE 变通办法
    SMP:提供1个节点、2个 CPU
    SMP:总共激活2个处理器(24.59个 BogoMips)。
    CPU:所有 CPU 在 HYP 模式中启动。
    CPU:可用的虚拟化扩展。
    devtmpfs:已初始化
    VFP 支持 v0.3:实施者41架构4第30部分变体 f rev 0
    时钟源:Jiffies:MASK:0xFFFFFFFF max_cycles:0xFFFFFFFF、max_idle_ns:19112604462750000 ns
    futex 哈希表条目:512 (顺序:3、32768字节)
    pinctrl 内核:已初始化的 pinctrl 子系统
    DMI 不存在或无效。
    NET:注册协议系列16.
    DMA:预分配256 KiB 池、用于原子相干分配
    omap_hwmod:L3_main_2、使用来自 OCP 的断开 dt 数据
    omap_hwmod:GPU:_wait_target_ready 失败:-16
    omap_hwmod:GPU:无法为复位启用(3)
    空闲:使用调速器梯
    空闲:使用调速器菜单
    OMAP GPIO 硬件版本0.1
    Platform 48838000.RTC:无法查找 hwmod 'rtcss'
    硬件断点:找到5个(+1保留)断点和4个观察点寄存器。
    硬件断点:最大观察点大小为8字节。
    OMAP4_SRAM_INIT:无法分配处理勘误表 I688所需的 SRAM
    OMAP4_SRAM_INIT:无法获取处理勘误表 I688所需的 SRAM 池
    OMAP DMA 硬件版本0.0
    密码:Max_cpu_qlen 设置为1000
    流:MEM:(MENC=20 MB)
    DCI:流项目分配(ptrval)->(ptrval)
    流:缓冲区分配(MDEC = 20 MB)
    DCI:添加了"atpb4mk DCI" DCI 适配器
    EDMA 43300000。EDMA:禁用 memcpy
    EDMA 43300000。EDMA:TI EDMA DMA 引擎驱动程序
    OMAP-DMA-ENGINE 4a056000.DMA-CONTROLLER:OMAP DMA 引擎驱动程序(支持 LinkedIn List1/2/3)
    VSYS_5v0:由 VSYS_12v0供电
    VSYS_3V3:由 VSYS_12v0供电
    VIO_3V3:由 VSYS_3V3供电
    VTT_FIXED:由 VSYS_3V3供电
    AIC_DVDD:由 VIO_3V3供电
    OMAP-iommu 40d01000.MMU:40d01000.MMU 已注册
    OMAP-iommu 40d02000.MMU:40d02000.MMU 已注册
    OMAP-iommu 588820.MMU:已注册588820.MMU
    OMAP-iommu 55082000.MMU:55082000.MMU 已注册
    ommu 41501000.MMU:41501000.MMU 已注册
    OMAP-iommu 41500.MMU:41500.MMU 已注册
    IOMMU:将器件5502000.IPU 添加到组2
    IOMMU:将器件40800000.DSP 添加到组0
    IOMMU:将器件41000000.DSP 添加到组3
    已初始化 SCSI 子系统
    usbcore:注册的新接口驱动程序 usbfs
    usbcore:注册的新接口驱动程序集线器
    usbcore:注册了新设备驱动程序 USB
    PALMAS 0-0058:IRQ 缺失:跳过 IRQ 请求
    PALMAS 0-0058:多路复用 GPIO 51、PWM 0、LED 2
    SMPS3:由 VSYS_3V3供电
    SMPS4:由 VSYS_3V3供电
    SMPS5:由 VSYS_3V3供电
    SMPS12:由稳压器仿真提供
    LDO1:由 VSYS_3V3供电
    LDO2:由 VSYS_3V3供电
    LDO3:由 VSYS_5v0供电
    LDO4:由 VSYS_5v0供电
    LDO5:由 VSYS_3V3供电
    omap_i2c 48070000.i2c:400kHz 时的总线0版本0.12
    介质:Linux 介质接口:v0.10
    videodev:Linux 视频捕捉接口:v2.00
    PPS_CORE:LinuxPPS API 版本。 1已注册
    PPS_CORE:软件版本 5.3.6 -版权所有2005-2007 Rodolfo Giometti
    已注册 PTP 时钟支持
    EDAC MC:版本:3.0.0
    OMAP-mailbox 48840000.mailbox:OMAP mailbox 修订版0x400
    OMAP-MAP-MABOO邮 箱48842000.mailbox:OMAP 邮箱修订版0x400
    已初始化高级 Linux 声音架构驱动程序。
    时钟源:切换到时钟源 ARCH_SYS_COUNTER
    NET:注册协议系列2.
    tcp_listen_portaddr_hash 哈希表条目:512 (顺序:0、6144字节)
    TCP 建立哈希表条目:8192 (顺序:3、32768字节)
    TCP 绑定哈希表条目:8192 (顺序:4、65536字节)
    TCP:配置哈希表(建立8192 BIND 8192)
    UDP 哈希表条目:512 (顺序:2、16384字节)
    UP-Lite 哈希表条目:512 (顺序:2、16384字节)
    NET:注册协议系列1
    RPC:注册后命名为 UNIX 套接字传输模块。
    RPC:注册的 UDP 传输模块。
    RPC:注册的 TCP 传输模块。
    RPC:已注册的 TCP NFSv4.1反向通道传输模块。
    硬件性能事件:/PMU 没有中断关联属性、猜测。
    硬件性能事件:通过 armv7_cortex_a15 PMU 驱动程序启用、提供7个计数器
    工作集:timestamp_bits=14 max_order=19 bucke_order=5
    squashfs:版本4.0 (2009/01/31) Phillip Lougher
    NFS:注册 id_resolver 密钥类型
    注册的密钥类型 id_resolver
    注册的密钥类型 id_legacy
    NTFS:驱动程序2.1.32 [Flags:R/O]。
    熔丝初始化(API 版本7.27)
    NET:注册协议系列38.
    退回:池大小:64页
    块层 SCSI 通用(BSG)驱动程序0.4版已加载(主要244)
    已注册 IO 调度程序 NOOP
    已登记 IO 调度程序截止日期
    已注册 IO 调度程序 cfq (默认)
    已注册 IO 调度程序 MQ-截止日期
    已注册 IO 调度程序 kyber
    模块已加载。
    ra8900 0-0032:RTC 内核:将 ra8900ce 注册为 rtc0
    ra8900 0-0032:6字节 NVRAM
    emlog:运行的版本0.41、使用的主要号码是243
    exFAT:文件系统版本2.2.0-3arter97
    PHY phy-4a084000.phy.0:作为消费类产品链接到稳压器.14
    PHY phy-4a085000.phy.1:作为消费类产品链接到稳压器.14
    pinctrl-single 4a003400.pinmux:282引脚、尺寸为1128
    VIO_1v8:由 smps5供电
    串行:8250/16550驱动程序,10个端口,启用 IRQ 共享
    控制台[ttyS0]已禁用
    MMIO 0x4806a000 (IRQ = 41、base_baud = 3000000)处的4806a000.serial: ttyS0为8250
    控制台[ttyS0]已启用
    MMIO 0x4806c000 (IRQ = 42、base_baud = 3000000)处的4806c000.serial: ttyS1为8250
    MMIO 0x48020000处的48020000.serial: ttyS2 (IRQ = 43、base_baud = 3000000)为8250
    MMIO 0x4806e000 (IRQ = 44、base_baud = 3000000)处的4806e000.serial: ttyS3为8250
    omap_rng 48090000.rng:随机数生成器版本 20.
    随机:快速初始化完成
    随机:完成 crng 初始化
    返修:模块已加载
    BUCK10:由 VSYS_3V3供电
    BUCK23:由 VSYS_3V3供电
    vmemexp 器件主要 num = 241
    vmemexp 类已注册
    /dev/vmemexp 器件已注册
    ioctl DBUFIOC_EXPORT_VIRTMEM =-1072899120
    libphy:固定 MDIO 总线:探测
    DaVinci_MDIO 48485000.MDIO:达芬奇 MDIO 修订版本1.6、总线频率1000000
    libphy:48485000.mdio:可编程
    DaVinci_MDIO 48485000.MDIO:PHY[1]:器件48485000.MDIO:01、驱动器 RTL8211E 千兆位以太网
    cpsw 48484000.ethernet:无从器件[1] phy_id、phy-handle 或固定链路属性
    CPsw 48484000以太网:检测到的 MACID = 38:8e:7a:29:F7:D8
    cpsw 48484000.ethernet:初始化 cpsw ale 版本1.4
    cpsw 48484000以太网:ALE 表大小1024
    cpsw 48484000.ethernet:CPT:溢出检查周期500 (jiffies)
    usbcore:注册的新接口驱动程序 r8152
    usbcore:注册了新接口驱动程序 a6
    usbcore:注册的新接口驱动程序 ax88179_178a
    usbcore:注册的新接口驱动程序 smsc95xx
    EHCI_hcd:USB 2.0 "增强型"主机控制器(EHCI)驱动程序
    OHCCI_hcd:USB 1.1 "打开"主机控制器(OHCI)驱动程序
    usbcore:注册的新接口驱动程序 UAS
    usbcore:注册的新接口驱动程序 USB 存储
    I2C /dev/entries 驱动程序
    CPU CPU0:作为消费类产品链接到 reguler.25
    CPU CPU0:作为消费类产品链接到 reguler.21
    sdhci:安全数字主机控制器接口驱动程序
    sdhci:版权所有(c) Pierre Osman
    sddhci-pltfm:SDHCI 平台和驱动程序辅助程序
    OMAP-GPIO 4805d000.GPIO:无法将第27行去抖设置为200000微秒(-22)
    sdhci-OMAP 4809c000.mmc:获得了 CD GPIO
    sdhci-OMAP 4809c000.MMC:以消费类电子产品的身份链接到电脑控制器.20
    sdhci-OMAP 4809c000.MMC:作为消费类产品链接到 reguler.15
    sdhci-OMAP 4809c000.mmc:断开到 reguler.15的链接
    sdhci-OMAP 4809c000.MMC:作为消费类产品链接到 regulator
    sdhci-OMAP 4809c000.mmc:对于 sdr104模式、没有 pinctrl 状态
    sdhci-OMAP 4809c000.mmc:ddr50模式下无 pinctrl 状态
    sdhci-OMAP 4809c000.mmc:sdr50模式没有 pinctrl 状态
    sdhci-OMAP 4809c000.mmc:sdr25模式没有 pinctrl 状态
    sdhci-OMAP 4809c000.mmc:sdr12模式没有 pinctrl 状态
    sdhci-OMAP 4809c000.MMC:DDR_1_8v 模式下无 pinctrl 状态
    sdhci-OMAP 4809c000.MMC:DDR_3_3V 模式下无 pinctrl 状态
    sdhci-OMAP 4809c000.MMC:HS200_1_8v 模式下无 pinctrl 状态
    mmc0:使用 ADMA 在4809c000.MMC [4809c000.mmc]上运行的 SDHCI 控制器
    sdhci-OMAP 480b4000.MMC:以消费类电子产品的身份链接到 reguler.5
    sdhci-OMAP 480b4000.MMC:断开与电脑控制器.5的连接
    mmc1:使用 ADMA 的480b4000.MMC [480b4000.mmC]上的 SDHCI 控制器
    OMAP-AES 4b500000.AES:OMAP AES 硬件加速器版本:3.3
    OMAP-AES 4b500000.AES:将运行具有实时优先级的请求泵
    OMAP-AES 4b700000.AES:OMAP AES 硬件加速器版本:3.3
    OMAP-AES 4b700000.AES:将运行具有实时优先级的请求泵
    OMAP-DES 480a5000.des: OMAP DES 硬件加速器修订版:2.2
    OMAP-DES 480a5000.des:将以实时优先级运行请求泵
    OMAP-SHIM 4b101000.sham:OMAP 版本4.3上的硬件加速器
    usbcore:注册的新接口驱动程序 usbhid
    usbhid:USB HID 内核驱动程序
    OMAP-GPIO 4805d000.GPIO:无法将第29行去抖设置为20000微秒(-22)
    OMAP-GPIO 4805d000.GPIO:无法将第30行去抖设置为20000微秒(-22)
    OMAP-HDMI-AUDIO omap-hdmi-audio.0.auto: snd-so-dummy dai <->58040000.HDMI_AUDIO 映射正常
    OMAP-HDMI-AUDIO omap-hdmi-audio.0.auto: ASOC:无 DMI 供应商名称!
    u32分类器
    输入设备检查打开
    已配置操作
    NET:注册协议系列17.
    注册的密钥类型 DNS_旋 变传感器
    正在注册 SWP/SWPB 仿真处理程序
    OMAP-VOLTGE_LARD_INIT:未添加电压驱动器支持
    TI OMAP4 +器件的电源管理。
    TI-iodelay 4844a000.padconf:设置寄存器0x190延迟(A:384 g:0)、元素(C=0 F=12) 0x2900c
    TI-iodelay 4844a000.padconf:设置寄存器0x194 delay (a:350 g:174)、元素(C=0 F=13) 0x2900d
    TI-iodelay 4844a000.padconf:设置寄存器0x1a8延迟(A:410 g:0)、元素(C=0 F=12) 0x2900c
    TI-iodelay 4844a000.padconf:设置寄存器0x1ac 延迟(A:335 g:0)、元素(C=0 F=10) 0x2900a
    TI-iodelay 4844a000.padconf:设置寄存器0x1b4延迟(A:468 g:0)、元素(C = 1 F = 0) 0x29020
    [DRM]支持 vblank 时间戳缓存修订版2 (2013年10月21日)。
    TI-iodelay 4844a000.padconf:设置寄存器0x1b8延迟(A:339 g:0)、元素(C=0 F=10) 0x2900a
    TI-iodelay 4844a000.padconf:设置寄存器0x1c0 delay (a:676 g:0)、元素(C=1 F=7) 0x29027
    TI-iodelay 4844a000.padconf:设置寄存器0x1c4延迟(A:219 g:0)、元素(C=0 F=6) 0x29006
    TI-iodelay 4844a000.padconf:设置寄存器0x1d0 delay (a:1062 g:154)、元素(C=2 F=8) 0x29048
    [DRM]不支持 vblank 时间戳查询的驱动程序。
    TI-iodelay 4844a000.padconf:设置寄存器0x1d8延迟(A:640 g:0)、元素(C = 1 F = 6) 0x29026
    [DRM]在次要0上为440000.OCP:vDRM@0初始化 vDRM 1.0.0 20191105
    TI-iodelay 4844a000.padconf:设置寄存器0x1dc 延迟(a:150 g:0)、元素(C=0 F=4) 0x29004
    TI-iodelay 4844a000.padconf:设置寄存器0x1e4延迟(A:356 g:0)、元素(C=0 F=11) 0x2900b
    TI-iodelay 4844a000.padconf:设置寄存器0x1e8延迟(A:150 g:0)、元素(C=0 F=4) 0x29004
    TI-iodelay 4844a000.padconf:设置寄存器0x1f0 delay (A:579 g:0)、元素(C=1 F=4) 0x29024
    vDRM 440000.OCP:vDRM@0:fb0:DRM 仿真帧缓冲器件
    TI-iodelay 4844a000.padconf:设置寄存器0x1F4 delay (A:200 g:0)、元素(C=0 F=6) 0x29006
    TI-iodelay 4844a000.padconf:设置寄存器0x1fc 延迟(A:435 g:0)、元素(C=0 F=13) 0x2900d
    DMM 4e000000.DMM:使用中的勘误表 i878的权变措施
    TI-iodelay 4844a000.padconf:设置寄存器0x200 delay (A:236 g:0)、元素(C=0 F=7) 0x29007
    DMM 4e000000.DMM:已初始化所有 PAT 条目
    TI-iodelay 4844a000.padconf:设置寄存器0x364 delay (A:759 g:0)、元素(C = 1 F = 9) 0x29029
    [DRM]为次要版本1上的 omapdrm.0初始化 omapdrm 1.0.0 20110917
    TI-iodelay 4844a000.padconf:设置寄存器0x368 delay (a:372 g:0)、元素(C=0 F=11) 0x2900b
    dwc3 48890000.usb:无法获取 clk 'f':-2
    mmc1:地址0001处的新 HS200 MMC 卡
    xhci-hcd xhci-hcd.3.auto: xHCI 主机控制器
    XHCI-hcd xhci-hcd.3.auto:已注册新 USB 总线、分配总线编号1
    mmcblk1:mmc1:0001 BJTD4R 13.6 GiB
    xhci-hcd xhci-hcd.3.auto: hcc 参数0x0220f04c HCI 版本0x100查询0x0000000002010010
    mmcblk1boot0:mmc1:0001 BJTD4R 分区1 4.00 MIB
    XHCI-hcd xhci-hcd.3.auto: IRQ 170、IO 内存0x48890000
    mmcblk1boot1:mmc1:0001 BJTD4R 分区2 4.00 MIB
    USB USB1:找到新的 USB 器件、idVendor=1d6b、idProduct=0002、bcdDevice=4.19
    mmcblk1gp0:mmc1:0001 BJTD4R 分区4 256 mib
    USB USB1:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    mmcblk1gp1:mmc1:0001 BJTD4R 分区5 256 mib
    USB USB1:产品:XHCI 主机控制器
    mmcblk1gp2:mmc1:0001 BJTD4R 分区6 128 mib
    USB USB1:制造商:Linux 4.19.73+ xhci-hcd
    mmcblk1gp3:mmc1:0001 BJTD4R 分区7 384 MIB
    USB USB1:序列号:xhci-hcd.3.auto
    mmcblk1rpmb:mmc1:0001 BJTD4R 分区3 4.00 MIB、chardev (239:0)
    集线器1-0:1.0:找到 USB 集线器
    集线器1-0:1.0:检测到1个端口
    XHCI-hcd xhci-hcd.3.auto:已注册新 USB 总线、分配总线编号2
    XHCI-hcd xhci-hcd.3.auto:主机支持 USB 3.0超高速
    USB USB2:我们不知道该主机的 LPM 算法、因此禁用了 LPM。
    mmcblk1gp3:P1
    USB USB2:找到新的 USB 设备、idVendor=1d6b、idProduct=0003、bcdDevice=4.19
    mmcblk1gp2:P1 p2 p3 p4 p5
    USB USB2:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    mmcblk1gp1:P1 p2 p3 p4 p5 p6
    USB USB2:产品:XHCI 主机控制器
    mmcblk1gp0:P1 p2 p3 p4 p5 p6
    USB USB2:制造商:Linux 4.19.73+ xhci-hcd
    USB USB2:Serial Number:xhci-hcd.3.auto
    集线器2-0:1.0:找到 USB 集线器
    集线器2-0:1.0:检测到1个端口
    dwc3 488d0000.usb:无法获取 clk 'f':-2
    xhci-hcd xhci-hcd.4.auto: xHCI 主机控制器
    XHCI-hcd xhci-hcd.4.auto:已注册新 USB 总线、分配总线编号3
    xhci-hcd xhci-hcd.4.auto: hcc 参数0x0220f04c HCI 版本0x100查询0x0000000002010010
    XHCI-hcd xhci-hcd.4.auto: IRQ 171、IO 内存0x488d0000
    USB USB3:找到新的 USB 器件、idVendor=1d6b、idProduct=0002、bcdDevice=4.19
    USB USB3:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    USB USB3:产品:XHCI 主机控制器
    USB USB3:制造商:Linux 4.19.73+ xhci-hcd
    USB USB3:Serial Number:xhci-hcd.4.auto
    集线器3-0:1.0:找到 USB 集线器
    集线器3-0:1.0:检测到1个端口
    XHCI-hcd xhci-hcd.4.auto:已注册新 USB 总线、分配总线编号4
    XHCI-hcd xhci-hcd.4.auto:主机支持 USB 3.0超高速
    USB USB4:我们不知道该主机的 LPM 算法、因此禁用了 LPM。
    USB USB4:找到新的 USB 器件、idVendor=1d6b、idProduct=0003、bcdDevice=4.19
    USB USB4:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    USB USB4:产品:XHCI 主机控制器
    USB USB4:制造商:Linux 4.19.73+ xhci-hcd
    USB USB4:Serial Number:xhci-hcd.4.auto
    集线器4-0:1.0:找到 USB 集线器
    集线器4-0:1.0:检测到1个端口
    ASOC-simple-card sound@1:wm8974-hifi <-> 48468000.McASP 映射正常
    ASOC-simple-card sound@1:ASOC:无 DMI 供应商名称!
    ra8900 0-0032:将系统时钟设置为2010-03-10 13:23:10 UTC (1268227390)
    NET eth0:正在初始化 cpsw 版本1.15 (0)
    RTL8211E 千兆位以太网48485000.MDIO:01:连接的 PHY 驱动程序[RTL8211E 千兆位以太网](MII_bus:phy_addr=4848485000.MDIO:01、IRQ=POLL)
    libphy:找不到 PHY
    网络 eth0:从机1上找不到 PHY ""、错误-19
    cpsw 48484000.Ethernet eth0:链路速率高达- 100Mbps/全速-流控 Rx/TX
    IP-Config:完成:
    device=eth0、hwaddr=38:8e:7a:29:F7:D8、ipaddr=10.47.24.65、mask=255.255.192.0、gw=10.47.0.1
    host=10.47.24.65、domain=、nis 域=(无)
    bootserver=10.47.2.10、rootserver=10.47.2.10、rootpath=
    AIC_DVDD:正在禁用
    ALSA 设备列表:
    0:HDMI 58040000.HDMI_AUDIO
    1:ATP
    VFS:在设备0:15上装载根(NFS 文件系统)。
    devtmpfs:已安装
    释放未使用的内核内存:2048K
    运行/sbin/init 作为初始化进程
    内核进入时间215022个周期
    启动 pid 139、tty '':'/etc/init.d/rcS
    启动加载模块:[OK]
    安装本地文件系统:[OK]
    小型 udev 文件系统:e2fsck 1.45.6 (2020年3月20日)
    ext4-fs (mmcblk1gp2p5):已安装文件系统、具有有序数据模式。 OPTS:(空)
    ext4-fs (mmcblk1gp3p1):已安装文件系统、具有有序数据模式。 OPTS:(空)
    [确定]
    更改内核参数:[OK]
    MDRAID (多磁盘 RAID)系统初始化:[OK]
    NET:注册协议系列45
    OMAP-rproc 5502000.IPU:忽略对器件的依赖、假设没有驱动程序
    OMAP-rproc 5502000.IPU:分配的保留存储器节点 ipu2-memory@95800000
    remoteproc remoteproc0:5502000.IPU 可用
    OMAP-rproc 40800000.dsp:忽略对器件的依赖、假设没有驱动程序
    OMAP-rproc 40800000.dsp:分配的保留存储器节点 dsp1-memory@99000000
    remoteproc remoteproc1:可提供40800000.dsp
    OMAP-rproc 41000000.dsp:忽略对器件的依赖、假设没有驱动程序
    OMAP-rproc 41000000.dsp:分配的保留存储器节点 dsp2-memory@9f000000
    remoteproc remoteproc2:41000000.dsp 可用
    remoteproc remoteproc1:启动40800000.dsp
    remoteproc remoteproc1:引导 FW 映像 dra7-dsp1-fw.xe66、大小为1071260
    ommu 40d01000.MMU:40d01000.MMU:版本3.0
    cryptotdev:已加载驱动程序1.10。
    OMAP-iommu 40d02000.MMU:40d02000.MMU:版本3.0
    remoteproc remoteproc 2:启动41000000.dsp
    remoteproc remoteproc2:引导 FW 映像 dra7-dsp2-fw.xe66、大小为1071260
    ommu 41501000.MMU:41501000.MMU:版本3.0
    ommu 41500.MMU:41500.MMU:版本3.0
    virtio_rpmsg_bus virtio0:rpmsg 主机处于联机状态
    remoteproc remoteproc1:注册的 virtio0 (类型7)
    remoteproc remoteproc1:远程处理器40800000.dsp 现已启动
    virtio_rpmsg_bus virtio1:rpmsg 主机处于联机状态
    remoteproc remoteproc 2:注册的 virtio1 (类型7)
    remoteproc remoteproc2:远程处理器41000000.dsp 现已启动
    pvrsrvkm:加载树外模块会影响内核。
    pvrsrvkm 560000.GPU:分配的保留存储器节点 GPU-memory@c0000000
    pvrsrvkm 560000.GPU:在驱动程序中使用 pm_runtime_put _sync_suspend()?
    PVR_K:(错误):EnableSGXClocks:Pm_Runtime_get_sync 失败(16)
    PVR_K:(错误):SysInitialize:无法启用系统时钟(175)
    pvrsrvkm 560000.GPU:无法注册 SGX DRM 器件
    PVR:(错误):OpenServices:PVRDRMOpenRender 失败[0、]
    PVR:(错误):PVRSRVInitSrvConnect:PVRSRVConnect 失败[0、]
    PVR:(错误):SrvInit:PVRSRVInitSrvConnect 失败(4)[0、]
    /usr/bin/pvrsrvctl:SrvInit 失败(已初始化?) (ERR=PVRSRV_ERROR_INIT_FAILURE)
    remoteproc remoteproc0:加电5502000.IPU
    remoteproc remoteproc0:引导固件映像 dra7-ipu2-fw.xem4,大小为7564944
    OMAP-iommu 55082000.MMU:55082000.MMU:版本2.1
    DMA:模块安装成功、器件主要 num = 237
    DRV:模块安装成功
    virtio_rpmsg_bus virtio2:rpmsg 主机处于联机状态
    remoteproc remoteproc0:注册的 virtio2 (类型7)
    remoteproc remoteproc0:远程处理器5502000.IPU 现已启动
    CMEMK 模块:参考 Linux 版本4.19.73
    cmemk 已初始化
    virtio_rpmsg_bus virtio2:创建通道 rpmsg-proto addr 0x50
    virtio_rpmsg_bus virtio0:创建通道 rpmsg-proto addr 0x50
    virtio_rpmsg_bus virtio1:创建通道 rpmsg-proto addr 0x50
    启动 telnet 守护程序:[OK]
    正在启动 inetd 守护程序:[OK]
    配置网络
    设置环回接口:[OK]
    设置 eth0网络接口:[NFS]
    设置 eth1网络接口:[none]
    检查系统时间验证:[OK]
    启动 pid 751、tty '':'/etc/run_app '
    启动 pid 752、tty '/dev/ttyS0:'/etc/serialtab
    手动 NFS 引导正常
    >>> 登录到 ATP-RSVD 控制台<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    # lsmod
    使用的模块大小
    cmemk 45056 0
    memcache 16384 0
    pvrsrvkm 401408 0
    Cryptodev 49152 0
    omap_remoteproc 20480 0
    rpmsg_proto 16384 0
    rpmsg_RPC 32768 0
    Virtio_rpmsg_BUS 20480 0
    Remoteproc 49152 3 omap_remoteproc、rpmsg_proto、rpmsg_rpc.
    编号
    此致。
    Yoesik。
    2.内核构建配置
    编号
    #自动生成的文件;请勿编辑。
    # Linux/ARM 4.19.73内核配置
    编号
    编号
    #编译器:ARM-TIV83-Linux-gcc (A 配置文件架构的 GNU 工具链8.3-2019.03 (ARM-rel-8.36)) 8.3.0
    编号
    CONFIG_CC_IS _GCC=y
    CONFIG_GCC_VERSION=80300
    CONFIG_CLANG_VERSION=0
    CONFIG_CC_has _ASM_GOTO=y
    CONFIG_IRQ_work = y
    CONFIG_BUILDTIME_EXTABLE_Sort=y
    编号
    #常规设置
    编号
    CONFIG_INIT_ENV_ARG_LIMIT=32
    未设置# CONFIG_COMPILE_TEST
    CONFIG_LOCALVERSION=""
    # CONFIG_LOCALVERSION_AUTO 未设置
    CONFIG_BUIL_SALT =""
    CONFIG_WARE_kernel_GZIP = y
    CONFIG_have 内核_LZMA=y
    CONFIG_have 内核_XZ=y
    CONFIG_have 内核_LZO=y
    CONFIG_have 内核_LZ4=y
    未设置# CONFIG_kernel_GZIP
    未设置# CONFIG_kernel_LZMA
    未设置# CONFIG_kernel_XZ
    CONFIG_kernel_LZO=y
    未设置# CONFIG_kernel_LZ4
    CONFIG_DEFAULT_HOSTNAME="(无)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE = y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    CONFIG_cross_memory_attach=y
    未设置# CONFIG_USELIB
    未设置# CONFIG_audit
    CONFIG_HASE_ARCH_AUDITSYSCALL=y
    编号
    # IRQ 子系统
    编号
    CONFIG_GENERIC_IRQ_PROBLE=y
    CONFIG_general_IRQ_show=y
    CONFIG_general_IRQ_show_level=y
    CONFIG_GENERIC_IRQ_effical_AFF_MASK=y
    CONFIG_GENERIC_IRQ_migration=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_IRQ_DOMAIN_RULLE= y
    CONFIG_Handle_DOMAIN_IRQ=y
    CONFIG_IRQ_Forced_Threading=y
    CONFIG_SPARE_IRQ=y
    未设置# CONFIG_GENERIC_IRQ_DebugFS
    CONFIG_general_IRQ_MULTI_handler = y
    CONFIG_ARCH_CLOCKSOURCE_DATA=y
    CONFIG_GENERIC_TIME_VSYSCALL=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    CONFIG_ARCH_has _tick_broadcast=y
    CONFIG_GENERIC_CLOCKEEVENTS_broadcast=y
    编号
    #计时器子系统
    编号
    CONFIG_TICK _OneShot=y
    CONFIG_NO_Hz_common=y
    未设置# CONFIG_Hz_CONperiodic
    CONFIG_NO_Hz_IDEL=y
    未设置# CONFIG_NO_Hz_FULL
    CONFIG_NO_Hz=y
    CONFIG_HIGH_RES_TIMERs=y
    未设置# CONFIG_PRETER_NONE
    未设置# CONFIG_PRETER_INVUATION
    CONFIG_PRETER=y
    CONFIG_PRETER_COUNT=y
    编号
    # CPU/任务时间和统计信息
    编号
    CONFIG_TICK CPU_accounting=y
    未设置# CONFIG_virt_CPU_accounting_GEN
    未设置# CONFIG_IRQ_TIME_accounting
    CONFIG_BSD_PROCESS_ACCT=y
    未设置# CONFIG_BSD_PROCESS_ACCT_V3
    # CONFIG_TASKSTATS 未设置
    CONFIG_CPU_isolation=y
    编号
    # RCU 子系统
    编号
    CONFIG_PRETER_RCU=y
    未设置# CONFIG_RCU_Expert
    CONFIG_SRCU=y
    CONFIG_TRE_SRCU=y
    CONFIG_Tasks_RCU=y
    CONFIG_RCU_STALL_COMON=y
    CONFIG_RCU_Need_SEGCBLIST=y
    CONFIG_BUIL_BIN2C=y
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    CONFIG_LOG_BUF_SHIFT = 17
    CONFIG_LOG_CPU_MAX_BUF_SHIF=12
    CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT = 13
    CONFIG_GENERIC_SCHED_CLOCK = y
    CONFIG_Cgroups=y
    CONFIG_PAGE_COUNTER=y
    CONFIG_MEMG=y
    CONFIG_MEMCG_SWAP=y
    CONFIG_MEMCG_SWAP_ENABLED = y
    CONFIG_MEMCG_kmem=y
    CONFIG_BLK_CGROUP=y
    未设置# CONFIG_DEBUG_BLK_CGROUP
    CONFIG_CGROUP_writeBack = y
    CONFIG_CGROUP_SCHED=y
    CONFIG_FER_Group_SCHED=y
    CONFIG_CFG_bandwidth = y
    未设置# CONFIG_RT_Group_Sched
    CONFIG_CGROUP_PIDS=y
    # CONFIG_CGROUP_RDMA 未设置
    CONFIG_CGROUP_RECONCERAS=y
    CONFIG_CPUSETs=y
    CONFIG_PROC_PID_CPUSET=y
    CONFIG_CGROUP_DEVICE=y
    CONFIG_CGROUP_CPUACCT=y
    CONFIG_CGROUP_PERF=y
    未设置# CONFIG_CGROUP_DEBUG
    CONFIG_namespace=y
    CONFIG_UTS_NS=y
    CONFIG_IPC_NS=y
    未设置# CONFIG_USER_NS
    CONFIG_PID_NS=y
    CONFIG_NET_NS=y
    CONFIG_CHECK_RESTORE = y
    未设置# CONFIG_SCHED_Autogroup
    未设置# CONFIG_SYSFS_DEPRECATED
    未设置# CONFIG_RELAY
    CONFIG_BLK_DEV_initrd=y
    CONFIG_initramfs_source=""
    CONFIG_RD_GZIP = y
    CONFIG_RD_Bzip2=y
    CONFIG_RD_LZMA=y
    CONFIG_RD_XZ=y
    CONFIG_RD_LZO=y
    CONFIG_RD_LZ4=y
    CONFIG_CC_optimize_for_performance=y
    未设置# CONFIG_CC_optimize_for_size
    CONFIG_SYSCTL=y
    CONFIG_AON_INodes = y
    CONFIG_WASE_UID16=y
    CONFIG_BPF=y
    CONFIG_LEGER=y
    CONFIG_UID16=y
    CONFIG_MULTIUSER=y
    # CONFIG_SGETMASK_SYSCALL 未设置
    CONFIG_SYSFS_SYSCALL = y
    未设置# CONFIG_SYSCTL_SYSCALL
    CONFIG_FHANDLE=y
    CONFIG_POSIX_TIMER=y
    CONFIG_PRINTK_=y
    CONFIG_PRINTK_NMI=y
    CONFIG_Bug=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_FUTEX_PI=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO = y
    CONFIG_adviced_SYSCALLS=y
    CONFIG_MEMBARRIE=y
    CONFIG_KALLSYMS=y
    CONFIG_KALLSYMS_ALL=y
    CONFIG_KALLSYMS_BASE_REALIAL=y
    未设置# CONFIG_BPF_SYSCALL
    未设置# CONFIG_USERFAULTFD
    CONFIG_ARCH_HARD_MEMBARRIE_SYNC_CORE=y
    CONFIG_RSEQ=y
    未设置# CONFIG_DEBUG_RSEQ
    CONFIG_embedded=y
    CONFIG_have _PERF_Events=y
    CONFIG_PERF_USE_VMALLOC=y
    未设置# CONFIG_PC104
    编号
    #内核性能事件和计数器
    编号
    CONFIG_PERF_Events=y
    未设置# CONFIG_DEBUG_PERF_USE_VMALLOC
    CONFIG_VM_EVENT_COUNTERs=y
    未设置# CONFIG_slub_debug
    未设置# CONFIG_slub_MEMG_SYSFS_ON
    CONFIG_COMPAT_BRK=y
    未设置# CONFIG_T板
    CONFIG_slub=y
    未设置# CONFIG_slob
    CONFIG_TLOG_MERGE_DEFAULT=y
    未设置# CONFIG_TLO_LEVIST_random
    未设置# CONFIG_LOW_LEVIST_CONSTRADEꆣ
    CONFIG_slub_CPU_PARTILE=y
    未设置# CONFIG_性能 评测
    CONFIG_ARM=y
    CONFIG_ARM_has _sg_chain=y
    CONFIG_M赡_have PCI=y
    CONFIG_SYS_supports_APM_emulation=y
    CONFIG_have _PROC_CPU=y
    CONFIG_stacktrace_support=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPINS=y
    CONFIG_RWSEM_XCHGADD_algoriter= y
    CONFIG_ARCH_has 带隙= y
    CONFIG_FIX_EARLYCON_MEM=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_general_calibration_delay=y
    CONFIG_Zone_DMA=y
    CONFIG_ARCH_supports_UPROBes=y
    CONFIG_ARM_PATCH_PHYS_virt=y
    CONFIG_general_bug=y
    CONFIG_PGTABLE_LEVENS=3
    编号
    #系统类型
    编号
    CONFIG_MMU=y
    CONFIG_ARCH_MMAP_RND_BITS _MIN=8
    CONFIG_ARCH_MMAP_RND_BITS _MAX=16
    CONFIG_ARCH_MULTIplatform=y
    未设置# CONFIG_ARCH_EBSA110
    未设置# CONFIG_ARCH_EP93XX
    未设置# CONFIG_ARCH_Footbridge
    未设置# CONFIG_ARCH_NETX
    未设置# CONFIG_ARCH_IOP13XX
    # CONFIG_ARCH_IOP32X 未设置
    未设置# CONFIG_ARCH_IOP33X
    未设置# CONFIG_ARCH_IXP4XX
    未设置# CONFIG_ARCH_DOve
    未设置# CONFIG_ARCH_KS8695
    未设置# CONFIG_ARCH_W90X900
    未设置# CONFIG_ARCH_LPC32XX
    # CONFIG_ARCH_PXA 未设置
    未设置# CONFIG_ARCH_RPC
    # CONFIG_ARCH_SA1100未设置
    未设置# CONFIG_ARCH_S3C24XX
    未设置# CONFIG_ARCH_DaVinci
    未设置# CONFIG_ARCH_OMAP1
    编号
    #多平台选择
    编号
    编号
    # CPU 内核系列选择
    编号
    未设置# CONFIG_ARCH_MULTI_V6
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    未设置# CONFIG_ARCH_virt
    未设置# CONFIG_ARCH_Actions
    未设置# CONFIG_ARCH_ALPINE
    未设置# CONFIG_ARCH_ARTPEC
    未设置# CONFIG_ARCH_AT91
    未设置# CONFIG_ARCH_AXXIA
    未设置# CONFIG_ARCH_BCM
    未设置# CONFIG_ARCH_Berlin
    # CONFIG_ARCH_DIGICOLOR 未设置
    # CONFIG_ARCH_EXYNOS 未设置
    # CONFIG_ARCH_HIGHBANK 未设置
    未设置# CONFIG_ARCH_HISI
    未设置# CONFIG_ARCH_MXC
    未设置# CONFIG_ARCH_KeyStone
    # CONFIG_ARCH_MediaTek 未设置
    未设置# CONFIG_ARCH_Meson
    未设置# CONFIG_ARCH_MMP
    未设置# CONFIG_ARCH_MVEBU
    未设置# CONFIG_ARCH_NPCM
    CONFIG_ARCH_OMAP=y
    编号
    # TI OMAP 常见特性
    编号
    编号
    # OMAP 功能选择
    编号
    CONFIG_OMAP_RESET_Clocks=y
    CONFIG_OMAP_32K_TIMER=y
    CONFIG_MACH_OMAP_generic=y
    编号
    # TI OMAP-AM/DM/DRA 系列
    编号
    未设置# CONFIG_ARCH_OMAP3
    # CONFIG_ARCH_OMAP4未设置
    未设置# CONFIG_SOC_OMAP5
    未设置# CONFIG_SOC_AM33XX
    未设置# CONFIG_SOC_AM43XX
    CONFIG_SOC_DRA7XX=y
    CONFIG_ARCH_OMAP2PLUS=y
    CONFIG_OMA_INTERNIT_STARE=y
    编号
    # TI OMAP2/3/4特定功能
    编号
    CONFIG_ARCH_OMAP2PLUS_Typic=y
    未设置# CONFIG_SOC_HAS_OMAP2_SDRC
    CONFIG_SOC_FASH_REALY_COUNTER=y
    编号
    # OMAP 传统平台数据板类型
    编号
    未设置# CONFIG_OMAP5_errata_801819
    未设置# CONFIG_ARCH_SiRF
    未设置# CONFIG_ARCH_QCOM
    未设置# CONFIG_ARCH_RealView
    # CONFIG_ARCH_Rockchip 未设置
    未设置# CONFIG_ARCH_S5PV210
    未设置# CONFIG_ARCH_Renesas
    未设置# CONFIG_ARCH_SOCFPGA
    未设置# CONFIG_PLAT_spear
    未设置# CONFIG_ARCH_STI
    未设置# CONFIG_ARCH_STM32
    未设置# CONFIG_ARCH_Sunxi
    未设置# CONFIG_ARCH_Tango
    未设置# CONFIG_ARCH_Tegra
    未设置# CONFIG_ARCH_UNIPHIER
    未设置# CONFIG_ARCH_U8500
    未设置# CONFIG_ARCH_VEXPRESS
    # CONFIG_ARCH_WM8850未设置
    未设置# CONFIG_ARCH_ZX
    未设置# CONFIG_ARCH_Zynq
    编号
    #处理器类型
    编号
    CONFIG_CPU_V7=y
    CONFIG_CPU_THUMBLE_Capable=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_Cache_V7=y
    CONFIG_CPU_Cache_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HASID_y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    编号
    #处理器特性
    编号
    CONFIG_ARM_LPAL=y
    CONFIG_ARM_THUMB=y
    未设置# CONFIG_ARM_THUMBEE
    CONFIG_ARM_virt_EXT=y
    CONFIG_SWP_Emulation=y
    未设置# CONFIG_CPU_ICACHE_DISABLE
    # CONFIG_CPU_BPREPICT_DISABLE 未设置
    CONFIG_CPU_SPECE= y
    CONFIG_Harden_branch_谓 词=y
    CONFIG_KUSER_ALECKES=y
    CONFIG_VDSO=y
    CONFIG_OUTER_CACHE = y
    CONFIG_OUTER_Cache_SYNC=y
    CONFIG_MAN_HASH_Cache_L2X0=y
    CONFIG_Cache_L2X0=y
    未设置# CONFIG_Cache_L2X0_PMU
    未设置# CONFIG_PL310_errata_588369
    未设置# CONFIG_PL310_errata_727915
    未设置# CONFIG_PL310_errata_753970
    未设置# CONFIG_PL310_errata_769419
    CONFIG_ARM_L1_Cache_SHIFT_6=y
    CONFIG_ARM_L1_Cache_shift=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_重_MB=y
    CONFIG_DEBUG_ALIG_RODATA=y
    未设置# CONFIG_ARM_勘 误表_430973
    CONFIG_ARM_勘 误表_643719=y
    未设置# CONFIG_ARM_勘 误表_720789
    未设置# CONFIG_ARM_勘 误表_754322
    未设置# CONFIG_ARM_勘 误表_754327
    未设置# CONFIG_ARM_勘 误表_764369
    未设置# CONFIG_ARM_勘 误表_775420
    CONFIG_ARM_勘 误表_798181=y
    未设置# CONFIG_ARM_勘 误表_773022
    未设置# CONFIG_ARM_勘 误表_818325_852422
    未设置# CONFIG_ARM_勘 误表_821420
    未设置# CONFIG_ARM_勘 误表_825619
    未设置# CONFIG_ARM_勘 误表_852421
    未设置# CONFIG_ARM_勘 误表_852423
    编号
    #总线支持
    编号
    未设置# CONFIG_PCI
    编号
    # PCI 端点
    编号
    CONFIG_PCI_终结 点= y
    CONFIG_PCI_EN终结 点_CONFIGFS=y
    未设置# CONFIG_PCI_EPF_TEST
    未设置# CONFIG_PCI_EPF_NTB
    未设置# CONFIG_PCCard
    编号
    #内核功能
    编号
    CONFIG_FASH_SMP=y
    CONFIG_SMP=y
    CONFIG_SMP_ON_UP=y
    CONFIG_ARM_CPU_topology=y
    未设置# CONFIG_SCHED_MC
    未设置# CONFIG_SCHED_SMT
    CONFIG_WASE_ARM_SCU=y
    CONFIG_FASE_ARM_ARCH_TIMER=y
    未设置# CONFIG_MCPM
    未设置# CONFIG_BIG_Little
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_2G 未设置
    # CONFIG_VMSPLIT_1G 未设置
    CONFIG_PAGE_OFFSET=0xC0000000
    CONFIG_NR_CPU=2
    CONFIG_HOTPLUG_CPU=y
    未设置# CONFIG_ARM_PSCI
    CONFIG_ARCH_NR_GPIO=512
    CONFIG_Hz_FIXED=0
    CONFIG_Hz_100=y
    未设置# CONFIG_Hz_200
    未设置# CONFIG_Hz_250
    未设置# CONFIG_Hz_300
    未设置# CONFIG_Hz_500
    未设置# CONFIG_Hz_1000
    CONFIG_Hz=100
    CONFIG_SCHED_HRTICK = y
    未设置# CONFIG_Thumb2_kernel
    CONFIG_ARM_PATCH_IDIV=y
    CONFIG_AEABI = y
    未设置# CONFIG_OABI
    CONFIG_ARCH_HAS_ING_MEMORYMODEL=y
    CONFIG_VALH_ARCH_PFN_VALLE=y
    CONFIG_have 通用_GUP=y
    CONFIG_HIGHMEM = y
    CONFIG_HIGHPTE=y
    CONFIG_HW_PERF_Events=y
    CONFIG_SYS_supports_HUGETLBFS=y
    CONFIG_HASE_ARCH_TANCE_HUGEPAGE=y
    CONFIG_ARCH_WIT_General_HUGETLB=y
    CONFIG_ARM_MODULE_PLTS=y
    CONFIG_FORCE_MAX_ZONEORDER=11
    CONFIG_ENCEL_TRAC=y
    未设置# CONFIG_UACCESS_带 memcpy
    CONFIG_SECCOMP=y
    未设置# CONFIG_PARAVIRT
    未设置# CONFIG_PARAVIRT_TIME_accounting
    未设置# CONFIG_XEN
    编号
    #引导选项
    编号
    CONFIG_USE_of=y
    # CONFIG_ATAGS 未设置
    CONFIG_ZBOOT_ROM_TEX=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_apped_dtb=y
    CONFIG_ARM_ATAG_dtb_COMPAT=y
    CONFIG_ARM_ATAG_dtb_COMPAT_CMDLINE_FER_BOOTLOADER=y
    未设置# CONFIG_ARM_ATAG_dtb_COMPAT_CMDLINE_extend
    CONFIG_CMDLINE=""
    CONFIG_kexec=y
    未设置# CONFIG_CRACK_Dump
    CONFIG_AUTO_ZRELADDR=y
    CONFIG_EFI_STUE=y
    CONFIG_EFI=y
    CONFIG_DMI=y
    编号
    # CPU 电源管理
    编号
    编号
    # CPU 频率缩放
    编号
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_ATTR_SET=y
    CONFIG_CPU_FREQ_GOV_common=y
    CONFIG_CPU_FREQ_STAT=y
    CONFIG_CPU_FREQ_DEFAULT_GOV_performance=y
    未设置# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE
    未设置# CONFIG_CPU_FREQ_DEFAULT_GOV_userspace
    未设置# CONFIG_CPU_FREQ_DEFAULT_GOV_OnDemand
    未设置# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSTICATION
    未设置# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL
    CONFIG_CPU_FREQ_GOV_performance=y
    CONFIG_CPU_FREQ_GOV_POWERSAVe=y
    CONFIG_CPU_FREQ_GOV_userspace=y
    CONFIG_CPU_FREQ_GOV_OnDemand=y
    CONFIG_CPU_FREQ_GOV_保守= y
    CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
    编号
    #个 CPU 频率调节驱动器
    编号
    CONFIG_cpufreq_DT=y
    CONFIG_cpufreq_DT_PLATDEV=y
    未设置# CONFIG_ARM_BIG_BIT_cpufreq
    未设置# CONFIG_ARM_OMAP2PLUS_cpufreq
    CONFIG_ARM_TI_cpufreq=y
    未设置# CONFIG_QorIQ_cpufreq
    编号
    # CPU 空闲
    编号
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
    CONFIG_CPU_IDLE_GOV_Laddle=y
    CONFIG_CPU_IDLE_GOV_MENU = y
    CONFIG_DT_IDLE_States=y
    编号
    # ARM CPU 空闲驱动器
    编号
    CONFIG_ARM_CPUIDLE=y
    编号
    #浮点仿真
    编号
    编号
    #必须至少选择一个仿真
    编号
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON = y
    CONFIG_kernel_mode_none=y
    编号
    #电源管理选项
    编号
    CONFIG_SUSP=y
    CONFIG_SUSPEND_FERC=y
    未设置# CONFIG_SUSPEND_SKIP_SYNC
    未设置# CONFIG_休眠
    CONFIG_PM_SLEEP=y
    CONFIG_PM_SLEEP_SMP=y
    未设置# CONFIG_PM_AUTOSLEEP
    未设置# CONFIG_PM_WAKELOCKS
    CONFIG_PM=y
    未设置# CONFIG_PM_DEBUG
    未设置# CONFIG_APM_EMULATION
    CONFIG_PM_CLK=y
    未设置# CONFIG_WQ_POWER_efficient 默认值
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND _Possible = y
    CONFIG_ARM_CPU_SUSPEND = y
    CONFIG_ARCH_休眠_Possible = y
    编号
    #固件驱动程序
    编号
    未设置# CONFIG_ARM_SCMI_Protocol
    未设置# CONFIG_ARM_SCPI_Protocol
    未设置# CONFIG_firmware_MEMMAP
    # CONFIG_DMIID 未设置
    未设置# CONFIG_DMI_SYSFS
    未设置# CONFIG_FW_CFG_SYSFS
    CONFIG_have ARM SMCCC=y
    未设置# CONFIG_Google_firmware
    编号
    # EFI (可扩展固件接口)支持
    编号
    未设置# CONFIG_EFI_VARS
    CONFIG_EFI_ESRT=y
    CONFIG_EFI_PARAMS_FDT=y
    CONFIG_EFI_RUNTIME_wrapers=y
    CONFIG_EFI_ARMSTUB=y
    CONFIG_EFI_ARMSTUB_dtb_loader=y
    # CONFIG_EFI_CULL_Loader 未设置
    未设置# CONFIG_EFI_TEST
    未设置# CONFIG_RESET_Attack_还原
    编号
    # Tegra 固件驱动程序
    编号
    CONFIG_ARM_Crypto=y
    CONFIG_crypto_SHA1_ARM=y
    CONFIG_Crypto SHA1_ARM_NEON = y
    CONFIG_crypto_SHA1_ARM_CE=y
    CONFIG_crypto_SHA2_ARM_CE=y
    CONFIG_crypto_SHA256_ARM=y
    CONFIG_crypto_SHA512_ARM=y
    CONFIG_crypto_AES_ARM=y
    CONFIG_crypto_AES_ARM_BS=y
    CONFIG_crypto_AES_ARM_CE=y
    CONFIG_crypto_GHASH_ARM_CE=y
    CONFIG_crypto_CRC32_ARM_CE=y
    CONFIG_crypto_CHACHA20_NEON = y
    未设置# CONFIG_virtualization
    编号
    #一般架构相关选项
    编号
    CONFIG_CRACK_CORE=y
    CONFIG_kexec_core=y
    CONFIG_HOW_OProfile=y
    未设置# CONFIG_KPROBES
    CONFIG_JUK_LABEL=y
    未设置# CONFIG_STATIC_KEYS_SELETEST
    CONFIG_have 高效未对齐的访问= y
    CONFIG_ARCH_USE_BUILTIN_BSWAP=y
    CONFIG_FASE_KPROBES=y
    CONFIG_THASE_KRETPROBES=y
    CONFIG_HOT_OPTPROBES=y
    CONFIG_have _NMI=y
    CONFIG_HASE_ARCH_TRACEHOOK=y
    CONFIG_have DMA 连续=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_Setup=y
    CONFIG_ARCH_has _ foraling_source=y
    CONFIG_ARCH_USE_SET_MEMORY = y
    CONFIG_THK_ARCH_THREAD_STRUCT_WHITELIST = y
    CONFIG_have 寄存器_and_STACK_API=y
    CONFIG_HASE_RSEQ=y
    CONFIG_have _CLK=y
    CONFIG_HASE_HW_breakpoint=y
    CONFIG_have _PERF_regs=y
    CONFIG_have _PERF_USER_STACK_Dump = y
    CONFIG_have _arch_jump 标签=y
    CONFIG_have _RCU_Table_free = y
    CONFIG_ARCH_WIT_IPC_pars_version=y
    CONFIG_HASE_ARCH_SECCOMP_FILTER=y
    CONFIG_SECCOMP_FILTER=y
    CONFIG_THASE_STACKPROTECTOR=y
    CONFIG_CC_has _STACKPROTECTOR_NONE=y
    CONFIG_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR_STRONG=y
    CONFIG_have 上下文跟踪=y
    CONFIG_have 环境 CPU 会计 GEN = y
    CONFIG_HOST_IRQ_TIME_accounting=y
    CONFIG_HOT_MOD_ARCH_specific = y
    CONFIG_MODULS_USE_ELF_REL=y
    CONFIG_ARCH_H_ELF_RANDMIZE = y
    CONFIG_FAST_ARCH_MMAP_RND_Bits=y
    CONFIG_THREAD_EXIT_THREAD=y
    CONFIG_ARCH_MMAP_RND_BITS = 8
    CONFIG_CLING_REACE= y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_sigaction=y
    CONFIG_ARCH_OPTIONAL_kernel_rwx=y
    CONFIG_ARCH_OPTIONAL_kernel_rwx_default=y
    CONFIG_ARCH_WASE_STRICT_kernel_rwx=y
    CONFIG_STRICT_kernel_rwx=y
    CONFIG_ARCH_WASE_STRICT_MODULE_RWX=y
    CONFIG_STRICT_MODULE_RWX=y
    CONFIG_ARCH_hAS_PHYS_TO_DMA=y
    CONFIG_REFCOUNT_FULL=y
    编号
    #基于 GCOV 的内核分析
    编号
    未设置# CONFIG_GCOV_kernel
    CONFIG_ARCH_H_GCOV_PROFILE_ALL = y
    CONFIG_PLUGIN_HOSTCC=""
    CONFIG_have GCC 插件= y
    CONFIG_RT_互 斥量= y
    CONFIG_BASE_Small = 0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD = y
    CONFIG_MODULE_FORCE_UNLOAD = y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL = y
    未设置# CONFIG_MODULE_SIG
    未设置# CONFIG_MODULE_COMpress
    未设置# CONFIG_TRIM_UNUSE_KSYMS
    CONFIG_MODULESS_TRE_Lookup = y
    CONFIG_BLOCK_y
    CONFIG_LBDif=y
    CONFIG_BLK_SCSI_Request=y
    CONFIG_BLK_DEV_BSG = y
    CONFIG_BLK_DEV_BSGLIB=y
    未设置# CONFIG_BLK_DEV_integrity
    未设置# CONFIG_BLK_DEV_CONDED
    未设置# CONFIG_BLK_DEV_TESCing
    CONFIG_BLK_CMDLINE_PARSER = y
    # CONFIG_BLK_WBT 未设置
    # CONFIG_BLK_CROUP_IOLATENCY 未设置
    CONFIG_BLK_DEBUG_FS=y
    未设置# CONFIG_BLK_SED_OPAL
    编号
    #分区类型
    编号
    CONFIG_PARTITION 高级= y
    未设置# CONFIG_AGCOM_PARTITION
    未设置# CONFIG_AIX_PARTITION
    未设置# CONFIG_OSF_PARTITION
    未设置# CONFIG_Amiga_partition
    未设置# CONFIG_ATARI_PARTITION
    未设置# CONFIG_MAC_PARTITION
    CONFIG_MSDOS_PARTITION = y
    未设置# CONFIG_BSD_disklabel
    未设置# CONFIG_MINIX_SUBPARTITION
    未设置# CONFIG_Solaris_x86_64分区
    未设置# CONFIG_UnixWare_disklabel
    未设置# CONFIG_LDM_PARTITION
    未设置# CONFIG_SGI_PARTITION
    未设置# CONFIG_ULTRIX_PARTITION
    未设置# CONFIG_SUN_PARTITION
    未设置# CONFIG_Karma 分区
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION 未设置
    CONFIG_CMDLINE_PARTITION = y
    CONFIG_BLK_MQ_Virtio=y
    编号
    # IO 调度程序
    编号
    CONFIG_iosched_NOOP=y
    CONFIG_iosched_cutime=y
    CONFIG_iosched_CFQ=y
    未设置# CONFIG_CFQ_Group_iosched
    未设置# CONFIG_DEFAULT_DEARDATE
    CONFIG_DEFAULT_CFQ=y
    未设置# CONFIG_DEFAULT_NOOP
    CONFIG_DEFAULT_iosche="cfq"
    CONFIG_MQ_iosched_term=y
    CONFIG_MQ_iosched_KYBER=y
    未设置# CONFIG_iosched_BFQ
    CONFIG_UNINLINE_SPIN_UNLOCK = y
    CONFIG_ARCH_supports_Atom_RMW = y
    CONFIG_mutex_spin_owner=y
    CONFIG_RWSEM_SPINE_ON_OWITY=y
    CONFIG_LOCK_SPIN_ON_owner=y
    CONFIG_RECONCERAC=y
    编号
    #可执行文件格式
    编号
    CONFIG_BINFMT_ELF = y
    # CONFIG_BINFMT_ELF_FDPIC 未设置
    CONFIG_ELFCORE = y
    CONFIG_CORE_Dump_DEFAULT_ELF_HEADER=y
    CONFIG_BINFMT_script=y
    未设置# CONFIG_BINFMT_FLLAT
    未设置# CONFIG_BINFMT_MISC
    CONFIG_coredump = y
    编号
    #内存管理选项
    编号
    CONFIG_FLAATMEM=y
    CONFIG_FLACT_NODE_MEM_MAP=y
    CONFIG_have _MEMBLOCK = y
    CONFIG_NO_BOOTMEM=y
    CONFIG_MEMORY_isolation=y
    CONFIG_SPLIT_PTLOCK_CPU=4
    CONFIG_COMPACTION=y
    CONFIG_migration=y
    CONFIG_PHYS_ADDR_T_64位= y
    CONFIG_BUBON=y
    未设置# CONFIG_KSM
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    # CONFIG_TRANSACY_HUGEPAGE 未设置
    # CONFIG_CLEANCACHE 未设置
    # CONFIG_FRONTSWAP 未设置
    CONFIG_CMA=y
    未设置# CONFIG_CMA_DEBUG
    未设置# CONFIG_CMA_DebugFS
    CONFIG_CMA_ARICS=7
    未设置# CONFIG_ZPOOL
    # CONFIG_ZBUD 未设置
    # CONFIG_ZSMALLOC 未设置
    CONFIG_general_EARLY_IOREMAP=y
    未设置# CONFIG_IDLE_PAGE_TRACKING
    CONFIG_FRAME_Vector=y
    未设置# CONFIG_PERCPU_STATS
    未设置# CONFIG_GUP_Benchmark
    CONFIG_ARCH_USE_PTE_SPECIAL = y
    CONFIG_NET=y
    CONFIG_NET_INOPEN=y
    CONFIG_NET_E出口= y
    编号
    #网络选项
    编号
    CONFIG_PACKE=y
    未设置# CONFIG_PACKE_DIAG
    CONFIG_UNIX=y
    未设置# CONFIG_UNIX_DIAG
    未设置# CONFIG_TLS
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=y
    # CONFIG_XFRM_USER 未设置
    未设置# CONFIG_XFRM_SUB_POLICATE
    未设置# CONFIG_XFRM_migrate
    未设置# CONFIG_XFRM_STATUSICS
    CONFIG_XFRM_IPCOMP=y
    未设置# CONFIG_NET_KEY
    CONFIG_iNet=y
    CONFIG_IP_MULTIP=y
    未设置# CONFIG_IP_advanced_router
    CONFIG_IP_route CLASSID=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    未设置# CONFIG_IP_PNP_RARP
    未设置# CONFIG_NET_IPIP
    未设置# CONFIG_NET_IPGRE_DEMUX
    未设置# CONFIG_IP_MROUTE
    未设置# CONFIG_SYN_Cookie
    未设置# CONFIG_NET_IPVTI
    未设置# CONFIG_NET_Fou
    CONFIG_iNet_AH=y
    CONFIG_iNet_ESP=y
    未设置# CONFIG_iNet_ESP_OFFLOAD
    CONFIG_iNet_IPCOMP=y
    CONFIG_iNet_XFRM_TAN=y
    CONFIG_iNet_Tunning=y
    CONFIG_iNet_XFRM_MODE_transport = y
    CONFIG_iNet_XFRM_MODE_TAN=y
    CONFIG_iNet_XFRM_MODE_BEET=y
    CONFIG_iNet_DIAG=y
    CONFIG_iNet_tcp_DIAG=y
    # CONFIG_iNet_UDP_DIAG 未设置
    未设置# CONFIG_iNet_RAW_DIAG
    未设置# CONFIG_iNet_DIAG_Destroy
    未设置# CONFIG_tcp_Cong_advanced
    CONFIG_TCP_Cong_Cuby=y
    CONFIG_DEFAULT_tcp_Cong="立方 体"
    未设置# CONFIG_tcp_MD5SIG
    未设置# CONFIG_IPv6
    未设置# CONFIG_NETWORK_SECMARK
    CONFIG_NET_PTP_Classe=y
    未设置# CONFIG_NETWORK_PHY_TIMET戳
    未设置# CONFIG_NETFILTER
    # CONFIG_BPFITER 未设置
    未设置# CONFIG_IP_DCCP
    未设置# CONFIG_IP_SCTP
    未设置# CONFIG_RDS
    未设置# CONFIG_TIPC
    未设置# CONFIG_ATM
    未设置# CONFIG_L2TP
    CONFIG_STP=y
    CONFIG_Bridge=y
    CONFIG_Bridge_IGMP_snooping = y
    CONFIG_FAW_NET_DSA=y
    未设置# CONFIG_NET_DSA
    未设置# CONFIG_VLAN_8021q
    未设置# CONFIG_DECnet
    CONFIG_LLC=y
    未设置# CONFIG_LLC2
    未设置# CONFIG_ATALK
    未设置# CONFIG_X25
    未设置# CONFIG_LAPB
    未设置# CONFIG_PHONET
    未设置# CONFIG_IEEE802154
    CONFIG_NET_SCHED=y
    编号
    #排队/调度
    编号
    CONFIG_NET_SCH_CBQ=y
    CONFIG_NET_SCH_HTB=y
    CONFIG_NET_SCH_HFSC=y
    CONFIG_NET_SCH_PRIO=y
    CONFIG_NET_SCH_MULTIq=y
    CONFIG_NET_SCH_RED_y
    CONFIG_NET_SCH_SFB=y
    CONFIG_NET_SCH_SFQ=y
    CONFIG_NET_SCH_TEQL=y
    CONFIG_NET_SCH_TBF=y
    # CONFIG_NET_SCH_CBS 未设置
    未设置# CONFIG_NET_SCH_ETF
    CONFIG_NET_SCH_GRED=y
    CONFIG_NET_SCH_DSMARK=y
    未设置# CONFIG_NET_SCH_NETEM
    CONFIG_NET_SCH_DRR=y
    CONFIG_NET_SCH_MQPRIO=y
    # CONFIG_NET_SCH_SKBPRIO 未设置
    CONFIG_NET_SCH_CHOGAN=y
    CONFIG_NET_SCH_QFQ=y
    CONFIG_NET_SCH_CODEL=y
    CONFIG_NET_SCH_FQ_CODEL=y
    未设置# CONFIG_NET_SCH_Cake
    未设置# CONFIG_NET_SCH_FQ
    未设置# CONFIG_NET_SCH_HHF
    未设置# CONFIG_NET_SCH_PIE
    CONFIG_NET_SCH_INALOW=y
    未设置# CONFIG_NET_SCH_plug
    未设置# CONFIG_NET_SCH_DEFAULT
    编号
    #分类
    编号
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIEN=y
    CONFIG_NET_CLS_TCINDEX=y
    CONFIG_NET_CLS_ROUTE4=y
    CONFIG_NET_CLS_FW=y
    CONFIG_NET_CLS_U32=y
    未设置# CONFIG_CLS_U32_PERF
    CONFIG_CLS_U32_MARG=y
    CONFIG_NET_CLS_RSVP=y
    CONFIG_NET_CLS_RSVP6=y
    CONFIG_NET_CLS_FLOC=y
    # CONFIG_NET_CLS_CROUP 未设置
    未设置# CONFIG_NET_CLS_BPF
    未设置# CONFIG_NET_CLS_FLOW_
    # CONFIG_NET_CLS_MatchAll 未设置
    CONFIG_NET_EMATCH=y
    CONFIG_NET_EMATCH_STACK_32
    CONFIG_NET_EMATCH_CMP=y
    CONFIG_NET_EMATCH_NBYTE=y
    CONFIG_NET_EMATCH_U32=y
    CONFIG_NET_EMATCH_meta=y
    CONFIG_NET_EMATCH_TEX=y
    CONFIG_NET_CLS_ACT_y
    CONFIG_NET_ACT_poly=y
    未设置# CONFIG_NET_ACT_GACT
    # CONFIG_NET_ACT_MIRRED 未设置
    未设置# CONFIG_NET_ACT_SAMPLE
    CONFIG_NET_ACT_NAT=y
    CONFIG_NET_ACT_PEDIT=y
    未设置# CONFIG_NET_ACT_SIMPP
    CONFIG_NET_ACT_SKBEDIT=y
    CONFIG_NET_ACT_CSUM=y
    未设置# CONFIG_NET_ACT_VLAN
    未设置# CONFIG_NET_ACT_BPF
    未设置# CONFIG_NET_ACT_SKBMOD
    未设置# CONFIG_NET_ACT_IFE
    未设置# CONFIG_NET_ACT_TAN_KEY
    CONFIG_NET_CLS_IND=y
    CONFIG_NET_SCH_FIFO=y
    未设置# CONFIG_DCB
    CONFIG_DNS_旋 变传感器= y
    未设置# CONFIG_Batman_ADV
    # CONFIG_OPENSWITCH 未设置
    # CONFIG_VSOCKETS 未设置
    # CONFIG_NetLink_DIAG 未设置
    未设置# CONFIG_MPLS
    未设置# CONFIG_NET_NSH
    未设置# CONFIG_HSR
    # CONFIG_NET_SWITCHDEV 未设置
    未设置# CONFIG_NET_L3_MASTER_DEV
    未设置# CONFIG_NET_NCSI
    CONFIG_RPS=y
    CONFIG_RFS_ACCEL=y
    CONFIG_XPS=y
    # CONFIG_CGROUP_NET_PRIO 未设置
    # CONFIG_CGROUP_NET_CLASSID 未设置
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    未设置# CONFIG_BPF_JIT
    CONFIG_NET_FLOG_LIMIT=y
    编号
    #网络测试
    编号
    未设置# CONFIG_NET_PKTGEN
    # CONFIG_HAMRADIO 未设置
    未设置# CONFIG_CAN
    未设置# CONFIG_BT
    # CONFIG_AF_RXRPC 未设置
    未设置# CONFIG_AF_KCM
    CONFIG_WIRELES=y
    # CONFIG_CFG80211未设置
    编号
    需要为 mac80211启用# CFG80211
    编号
    CONFIG_mac80211_STA_hash-MAX_SIZE=0
    未设置# CONFIG_WiMAX
    # CONFIG_RFKILL 未设置
    未设置# CONFIG_NET_9P
    未设置# CONFIG_CAIF
    CONFIG_RPMSG_PROTO=m
    未设置# CONFIG_Ceph LIB
    未设置# CONFIG_NFC
    未设置# CONFIG_PSAMPLE
    未设置# CONFIG_NET_IFE
    # CONFIG_LWTUNNEL 未设置
    CONFIG_GRO_CEOTERS=y
    # CONFIG_NET_DevLink 未设置
    CONFIG_MOD_USE_DevLink=y
    CONFIG_failover=y
    CONFIG_THASE_EBPF_JIT=y
    编号
    #设备驱动程序
    编号
    编号
    #通用驱动程序选项
    编号
    CONFIG_UEVENT_helper=y
    CONFIG_UEVENT_helper_path=""
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_LOAD=y
    CONFIG_ACONSTALE=y
    CONFIG_Preved_firmware_build=y
    编号
    #固件加载程序
    编号
    CONFIG_FW_LOADER=y
    CONFIG_Extra 固件=""
    未设置# CONFIG_FW_LOADER_USER_Helper
    CONFIG_WIT_DEV_coredump = y
    CONFIG_ALLOW_DEV_coredump = y
    CONFIG_DEV_coredump = y
    未设置# CONFIG_DEBUG_DRIVER
    未设置# CONFIG_DEBUG_DevRes
    未设置# CONFIG_DEBUG_TEST_DRIVER_REMOVE
    未设置# CONFIG_TEST_ASYNC_DRIVER_PROBE
    CONFIG_GENERIC_CPU_AUTOPROBE=y
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_shared_buffer=y
    未设置# CONFIG_DMA_Fence_trace
    CONFIG_vMem_EXP_DMABUF=y
    CONFIG_DMA_CMA=y
    编号
    #默认连续存储器区域大小:
    编号
    CONFIG_CMA_SIZE_MBytes=24
    CONFIG_CMA_SIZE_SEL_Mbytes=y
    未设置# CONFIG_CMA_SIZE SEL_Percentage
    未设置# CONFIG_CMA_SIZE SEL_MIN
    未设置# CONFIG_CMA_SIZE SEL_MAX
    CONFIG_CMA_alignment=8
    CONFIG_general_arch_topology=y
    编号
    #总线设备
    编号
    # CONFIG_BRCMSTB_GISB_ARB 未设置
    CONFIG_OMAP_INTERNIT=y
    CONFIG_OMAP_OCP2SCP=y
    CONFIG_SIMPLE_PM_BUS=y
    CONFIG_TI_SYSC=y
    未设置# CONFIG_VEXPRESS_CONFIG
    未设置# CONFIG_CONNECTOR
    未设置# CONFIG_GNSS
    未设置# CONFIG_MTD
    CONFIG_DTC=y
    CONFIG_of=y
    未设置# CONFIG_ON_UNITTEST
    CONFIG_of_FLAATTREE=y
    CONFIG_of_EARLY_FLAATTREE=y
    CONFIG_of_KOBJ=y
    CONFIG_of_dynamic=y
    CONFIG_of_address=y
    CONFIG_of_IRQ=y
    CONFIG_of_NET=y
    CONFIG_of_MDIO=y
    CONFIG_of_RESERVE_MEM=y
    未设置# CONFIG_ON_OVERLAY
    CONFIG_ARCH_MOR_have PC PARPORT=y
    未设置# CONFIG_PARPORT
    CONFIG_BLK_DEV_y
    # CONFIG_BLK_DEV_NULL_BLK 未设置
    CONFIG_CDROD=y
    未设置# CONFIG_BLK_DEV_LOOP
    未设置# CONFIG_BLK_DEV_DRBD
    未设置# CONFIG_BLK_DEV_NBD
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=65536
    未设置# CONFIG_CDROM_PKTCDVD
    未设置# CONFIG_ATA_OW_ETH
    CONFIG_virtio_blk=y
    未设置# CONFIG_virtio_BLK_SCSI
    未设置# CONFIG_BLK_DEV_RBD
    编号
    # NVMe 支持
    编号
    未设置# CONFIG_NVMe_FC
    未设置# CONFIG_NVMe_TARGET
    编号
    #其他设备
    编号
    CONFIG_AD525X_DPOT=y
    CONFIG_AD525X_DPOT_I2C=y
    # CONFIG_AD525X_DPOT_SPI 未设置
    未设置# CONFIG_Dummy_IRQ
    未设置# CONFIG_ICS932S401
    未设置# CONFIG_CONSTRAL_SERVICES
    CONFIG_APDS9802ALS = y
    CONFIG_ISL29003=y
    # CONFIG_ISL29020未设置
    未设置# CONFIG_SENSORS_TSL2550
    未设置# CONFIG_SENSORS_BH1770
    未设置# CONFIG_SENSORS_APDS990X
    未设置# CONFIG_HMC6352
    未设置# CONFIG_DS1682
    未设置# CONFIG_USB_SWITCH_FSA9480
    未设置# CONFIG_Lattice_ECP3_CONFIG
    CONFIG_SRAM=y
    CONFIG_SRAM_EXEC=y
    CONFIG_DMA_BUF_PHYS=y
    # CONFIG_C2PORT 未设置
    编号
    支持# EEPROM
    编号
    未设置# CONFIG_EEPROM_AT24
    未设置# CONFIG_EEPROM_AT25
    未设置# CONFIG_EEPROM_LEGACe.
    未设置# CONFIG_EEPROM_MAX6875
    未设置# CONFIG_EEPROM_93CX6
    未设置# CONFIG_EEPROM_93XX46
    未设置# CONFIG_EEPROM_IDT_89HPESX
    编号
    #德州仪器共用运输线路
    编号
    未设置# CONFIG_TI_ST
    未设置# CONFIG_SENSORS_LIS3_SPI
    未设置# CONFIG_SENSORS_LIS3_I2C
    # CONFIG_Altera_STOPL 未设置
    编号
    #英特尔 MIC 及相关支持
    编号
    编号
    #英特尔 MIC 总线驱动程序
    编号
    编号
    # SCIF 总线驱动器
    编号
    编号
    # VOP 总线驱动器
    编号
    编号
    #英特尔 MIC 主机驱动程序
    编号
    编号
    #英特尔 MIC 卡驱动程序
    编号
    编号
    # SCIF 驱动程序
    编号
    编号
    # Intel MIC 协处理器状态管理(COSM)驱动程序
    编号
    编号
    # VOP 驱动器
    编号
    未设置# CONFIG_ECHO
    未设置# CONFIG_MISC_RTSX_USB
    编号
    # SCSI 设备支持
    编号
    CONFIG_SCSI_MOD=y
    未设置# CONFIG_RAID_ATTRS
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    CONFIG_SCSI_MQ_DEFAULT=y
    CONFIG_SCSI_PROC_FS=y
    编号
    # SCSI 支持类型(磁盘、磁带、CD-ROM)
    编号
    CONFIG_BLK_DEV_SD=y
    未设置# CONFIG_CHR_DEV_ST
    # CONFIG_CHR_DEV_OSST 未设置
    CONFIG_BLK_DEV_SR=y
    未设置# CONFIG_BLK_DEV_SR_VENDORD
    未设置# CONFIG_CHR_DEV_SG
    # CONFIG_CHR_DEV_SCH 未设置
    未设置# CONFIG_SCSI_constants
    未设置# CONFIG_SCSI_LOGING
    未设置# CONFIG_SCSI_SCAN_ASYNC
    编号
    # SCSI 传输
    编号
    未设置# CONFIG_SCSI_SPI_ATTRS
    未设置# CONFIG_SCSI_FC_ATTRS
    未设置# CONFIG_SCSI_ISC_ATTRS
    未设置# CONFIG_SCSI_SAS_ATTRS
    未设置# CONFIG_SCSI_SAS_LIBSAS
    未设置# CONFIG_SCSI_SRP_ATTRS
    CONFIG_SCSI_lowlevel=y
    未设置# CONFIG_ISC_TCP
    未设置# CONFIG_ISCI_BOOT_SYSFS
    CONFIG_SCSI_UFSHCD=y
    CONFIG_SCSI_UFSHCD_Platform=y
    CONFIG_SCSI_UFS_CDNS_Platform=y
    未设置# CONFIG_SCSI_UFS_DWC_TC_PLANY
    CONFIG_SCSI_UFS_BSG=y
    未设置# CONFIG_SCSI_DEBUG
    未设置# CONFIG_SCSI_Virtio
    未设置# CONFIG_SCSI_DH
    未设置# CONFIG_SCSI_OSD_INITIATOR
    未设置# CONFIG_ATA
    未设置# CONFIG_MD
    未设置# CONFIG_TARGET_CORE
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    未设置# CONFIG_BONCATION
    未设置# CONFIG_DEUGATE
    未设置# CONFIG_均衡 器
    未设置# CONFIG_IFB
    未设置# CONFIG_NET_TEAM
    # CONFIG_MACVLAN 未设置
    未设置# CONFIG_VXLAN
    未设置# CONFIG_GTP
    未设置# CONFIG_MACsec
    # CONFIG_NETCONSOLE 未设置
    未设置# CONFIG_TUN
    未设置# CONFIG_TUN_VNET_Cross_LE
    未设置# CONFIG_VETH
    CONFIG_virtio_NET=y
    未设置# CONFIG_NLMON
    编号
    # CAIF 传输驱动程序
    编号
    编号
    #分布式交换机架构驱动程序
    编号
    CONFIG_ETHERNET=y
    CONFIG_NET_VENDOOR_ALACRITECH=y
    # CONFIG_Altera_TSE 未设置
    未设置# CONFIG_NET_VENDOR_Amazon
    CONFIG_NET_VENDOOR_AQUANTIA=y
    未设置# CONFIG_NET_VENDOR_ARC
    CONFIG_NET_VENDOR_Aurora = y
    未设置# CONFIG_ORAL_NB8800
    未设置# CONFIG_NET_VENDOR_Broadcom
    CONFIG_NET_VENDOOR_CADENS=y
    CONFIG_MACB=y
    CONFIG_MACB_USE_HWSTAMP=y
    未设置# CONFIG_NET_VENDOR_Cavium
    未设置# CONFIG_NET_VENDOR_Cirrus
    CONFIG_NET_VENDOOR_Cortina=y
    未设置# CONFIG_Gemini_Ethernet
    未设置# CONFIG_DM9000
    未设置# CONFIG_DNET
    未设置# CONFIG_NET_VENDOR_EZCHIP
    未设置# CONFIG_NET_VENDOR_Faraday
    未设置# CONFIG_NET_VENDOR_HISILICON
    CONFIG_NET_VENDOOR_HUAWEI=y
    未设置# CONFIG_NET_VENDOR_Intel
    未设置# CONFIG_NET_VENDOR_MARVELL
    未设置# CONFIG_NET_VENDOR_Mellanox
    未设置# CONFIG_NET_VENDOR_Micrel
    未设置# CONFIG_NET_VENDOR_Microchip
    CONFIG_NET_VENDOOR_Microsemi = y
    未设置# CONFIG_NET_VENDOR_NATSEMI
    未设置# CONFIG_NET_VENDOR_NETRONOME
    CONFIG_NET_VENDOOR_NI=y
    未设置# CONFIG_ETHOC
    未设置# CONFIG_NET_VENDOR_QUALCOMM
    未设置# CONFIG_NET_VENDOR_RENESAS
    未设置# CONFIG_NET_VENDOR_摇 臂
    未设置# CONFIG_NET_VENDOR_Samsung
    未设置# CONFIG_NET_VENDOR_SEEQ
    CONFIG_NET_VENDOOR_SOLARFLARE = y
    未设置# CONFIG_NET_VENDOR_SMSC
    CONFIG_NET_VENDOOR_SOCIONEXT=y
    # CONFIG_NET_VENDOR_STMICRO 未设置
    未设置# CONFIG_NET_VENDOR_Synopsys
    CONFIG_NET_VENDOOR_TI=y
    CONFIG_TI_Davinci_MDIO=y
    CONFIG_TI_Davinci_CPDMA=y
    CONFIG_TI_CPSW_PHY_SEL=y
    CONFIG_TI_CPSW_ALE=y
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPTS=y
    CONFIG_TI_CPTS_MOD=y
    未设置# CONFIG_NET_VENDOR_VIA
    未设置# CONFIG_NET_VENDOR_WIZnet
    CONFIG_MDIO_DEVICE=y
    CONFIG_MDIO_BUS=y
    未设置# CONFIG_MDIO_BCM_UNIMAC
    # CONFIG_MDIO_BIDBANG 未设置
    未设置# CONFIG_MDIO_BUS_MUX_GPIO
    未设置# CONFIG_MDIO_BUS_MUX_MMIOREG
    # CONFIG_MDIO_HISI_FEMAC 未设置
    # CONFIG_MDIO_MSCC_MIIM 未设置
    CONFIG_PHYLIB=y
    CONFIG_SWPHY=y
    编号
    # MII PHY 设备驱动程序
    编号
    未设置# CONFIG_AMD_PHY
    # CONFIG_AQUANTIA_PHY 未设置
    未设置# CONFIG_AX88796B_PHY
    CONFIG_AT803X_PHY=y
    未设置# CONFIG_BCM7XXX_PHY
    未设置# CONFIG_BCM87XX_PHY
    未设置# CONFIG_Broadcom_PHY
    未设置# CONFIG_Cicada_PHY
    未设置# CONFIG_CORTINA_PHY
    # CONFIG_DAVICOM_PHY 未设置
    未设置# CONFIG_DP83822_PHY
    未设置# CONFIG_DP83TC811_PHY
    CONFIG_DP83848_PHY=y
    CONFIG_DP83867_PHY=y
    CONFIG_FIXED_PHY=y
    未设置# CONFIG_ICPLUS_PHY
    未设置# CONFIG_Intel_XWAY_PHY
    # CONFIG_LSI_ET1011C_PHY 未设置
    未设置# CONFIG_LXT_PHY
    CONFIG_MARVELL_PHY=y
    # CONFIG_MARVELL_10G_PHY 未设置
    CONFIG_Micrel_PHY=y
    未设置# CONFIG_Microchip_PHY
    未设置# CONFIG_Microchip_T1_PHY
    未设置# CONFIG_Microsemi PHY
    未设置# CONFIG_ENMOY_PHY
    # CONFIG_QSEMI_PHY 未设置
    CONFIG_Realtek_PHY=y
    未设置# CONFIG_RENESS_PHY
    CONFIG_Rockchip_PHY=y
    CONFIG_SMSC_PHY=y
    # CONFIG_STE10XP 未设置
    # CONFIG_TERANETICS_PHY 未设置
    未设置# CONFIG_VITESS_PHY
    未设置# CONFIG_XilINX_GMII2RGMII
    # CONFIG_Micrel_KS8995MA 未设置
    未设置# CONFIG_PPP
    未设置# CONFIG_SLIP
    CONFIG_USB_NET_DRIVERS=y
    未设置# CONFIG_USB_CATC
    # CONFIG_USB_KAWETH 未设置
    未设置# CONFIG_USB_Pegasus
    未设置# CONFIG_USB_RTL8150
    CONFIG_USB_RTL8152=y
    未设置# CONFIG_USB_LAN78XX
    CONFIG_USB_USBnet=y
    CONFIG_USB_NET_AX8817X=y
    CONFIG_USB_NET_AX88179_178A=y
    未设置# CONFIG_USB_NET_CDCETHR
    未设置# CONFIG_USB_NET_CDC_EEM
    未设置# CONFIG_USB_NET_CDC_NCM
    # CONFIG_USB_NET_HUAWEI_CDC_NCM 未设置
    未设置# CONFIG_USB_NET_CDC_MBIM
    未设置# CONFIG_USB_NET_DM9601
    未设置# CONFIG_USB_NET_SR9700
    未设置# CONFIG_USB_NET_SR9800
    未设置# CONFIG_USB_NET_SMSC75XX
    CONFIG_USB_NET_SMSC95XX=y
    未设置# CONFIG_USB_NET_GL620A
    未设置# CONFIG_USB_NET_NET1080
    未设置# CONFIG_USB_NET_PLUSB
    未设置# CONFIG_USB_NET_MCS7830
    未设置# CONFIG_USB_NET_RNDIS_HOST
    未设置# CONFIG_USB_NET_CDC_Subset
    未设置# CONFIG_USB_NET_ZAURUS
    未设置# CONFIG_USB_NET_CX82310_ETH
    未设置# CONFIG_USB_NET_Kalmia
    未设置# CONFIG_USB_NET_QMI_WWAN
    未设置# CONFIG_USB_NET_INT51X1
    未设置# CONFIG_USB_IPHETH
    未设置# CONFIG_USB_Sierra 网络
    未设置# CONFIG_USB_NET_CH9200
    CONFIG_WLAN=y
    未设置# CONFIG_WIRELESS_WDS
    CONFIG_WLAN_VENDOOR_ADMTEK=y
    CONFIG_WLAN_VENDOR_ATH=y
    未设置# CONFIG_ATH_DEBUG
    CONFIG_WLAN_VENDOR_Atmel=y
    CONFIG_WLAN_VENDOOR_Broadcom = y
    CONFIG_WLAN_VENDOR_CISCO = y
    CONFIG_WLAN_VENDOR_Intel=y
    CONFIG_WLAN_VENDOR_Intersil=y
    未设置# CONFIG_hostap
    CONFIG_WLAN_VENDOR_MARVELL=y
    CONFIG_WLAN_VENDOR_MediaTek=y
    CONFIG_WLAN_VENDOR_Ralink=y
    CONFIG_WLAN_VENDOR_Realtek=y
    CONFIG_WLAN_VENDOR_RSI=y
    CONFIG_WLAN_VENDOR_ST=y
    CONFIG_WLAN_VENDOR_TI=y
    CONFIG_WLAN_VENDOR_ZYDAS=y
    CONFIG_WLAN_VENDOOR_QUANTENNA=y
    编号
    #启用 WiMAX (网络选项)以查看 WiMAX 驱动程序
    编号
    未设置# CONFIG_WAN
    # CONFIG_NETDEVSIM 未设置
    CONFIG_NET_failover=y
    未设置# CONFIG_ISDN
    编号
    #输入设备支持
    编号
    CONFIG_INPUT=y
    未设置# CONFIG_INPUT_FF_MEMLESS
    未设置# CONFIG_INPUT_POLDEV
    # CONFIG_INPUT_SPARSEKMAP 未设定
    未设置# CONFIG_INPUT_MATRIXKMAP
    编号
    # userland 接口
    编号
    未设置# CONFIG_INPUT_MOUSEDEV
    未设置# CONFIG_INPUT_Joydev
    CONFIG_INPUT_EVDEV=y
    未设置# CONFIG_INPUT_EVBUG
    编号
    #输入设备驱动程序
    编号
    CONFIG_INPUT 键盘=y
    未设置# CONFIG_KEYBOARD_ADC
    未设置# CONFIG_KEYBOARD_ADP5588
    未设置# CONFIG_KEYBOARD_ADP5589
    未设置# CONFIG_KEYBOARD_ATKBD
    # CONFIG_KEYBOARD_QT1070未设置
    # CONFIG_KEYBOARD_QT2160未设置
    未设置# CONFIG_KEYBOARD_DLINK_DIR685
    未设置# CONFIG_KEYBOARD_LKBD
    CONFIG_KEYBOARD_GPIO=y
    未设置# CONFIG_BACK_GPIO_P巡回 检测
    未设置# CONFIG_KEYBOARD_TCA6416
    未设置# CONFIG_KEYBOARD_TCA8418
    未设置# CONFIG_KEYBOARD_Matrix
    未设置# CONFIG_KEYBOARD_LM8333
    未设置# CONFIG_KEYBOARD_MAX7359
    未设置# CONFIG_KEYBOARD_MCS
    未设置# CONFIG_KEYBOARD_MPR121
    未设置# CONFIG_KEYBOARD_Newton
    未设置# CONFIG_KEYBOARD_OPENCORES
    未设置# CONFIG_KEYBOARD_Samsung
    未设置# CONFIG_KEYBOUARD_FANAWAWAGE
    # CONFIG_KEYBOARD_SUNKBD 未设置
    # CONFIG_KEYBOARD_OMAP4未设置
    未设置# CONFIG_KEYBOARD_XTKBD
    未设置# CONFIG_KEYBOARD_CAP11XX
    未设置# CONFIG_KEYBOL_BCM
    CONFIG_INPUT_MOUST=y
    未设置# CONFIG_LOCK_PS2
    未设置# CONFIG_MOUST_serial
    未设置# CONFIG_MOUST_APPLETOUCH
    未设置# CONFIG_LOCK_BCM5974
    未设置# CONFIG_LOCK_CYAPA
    CONFIG_LOCK_ELAN_I2C=y
    CONFIG_LOCK_ELAN_I2C_I2C=y
    未设置# CONFIG_LOCK_ELAN_I2C_SMBus
    未设置# CONFIG_MOUS_VSXXXAA
    未设置# CONFIG_LOCK_GPIO
    未设置# CONFIG_MOUST_Synaptics_I2C
    未设置# CONFIG_MOUST_Synaptics_USB
    未设置# CONFIG_INPUT_TOICK
    未设置# CONFIG_INPUT_TABLET
    CONFIG_INPUT_Touchscreen = y
    CONFIG_Touchscreen 属性=y
    未设置# CONFIG_Touchscreen _ADS7846
    未设置# CONFIG_Touchscreen _AD7877
    未设置# CONFIG_Touchscreen _AD7879
    未设置# CONFIG_Touchscreen _ADC
    未设置# CONFIG_Touchscreen _AR1021_I2C
    未设置# CONFIG_Touchscreen _Atmel_MXT
    未设置# CONFIG_Touchscreen AUO_PIXCIR
    未设置# CONFIG_Touchscreen BU21013
    未设置# CONFIG_Touchscreen BU21029
    # CONFIG_Touchscreen _CHIPONE_ICN8318未设置
    未设置# CONFIG_Touchscreen CY8CTMG110
    未设置# CONFIG_Touchscreen CYTTSP_CORE
    未设置# CONFIG_Touchscreen CYTTSP4_CORE
    未设置# CONFIG_Touchscreen Dynapro
    未设置# CONFIG_Touchscreen 汉普郡
    未设置# CONFIG_Touchscreen EETI
    # CONFIG_Touchscreen _EGALAX 未设置
    未设置# CONFIG_Touchscreen _EGALAX_serial
    未设置# CONFIG_Touchscreen EXC3000
    未设置# CONFIG_Touchscreen 富士通
    CONFIG_Touchscreen GOODIX=y
    未设置# CONFIG_Touchscreen HIDEEP
    未设置# CONFIG_Touchscreen _ILI210X
    未设置# CONFIG_Touchscreen S6SY761
    未设置# CONFIG_Touchscreen GUNZE
    # CONFIG_Touchscreen _EKTF2127未设置
    未设置# CONFIG_Touchscreen _ELAN
    未设置# CONFIG_Touchscreen ELO
    未设置# CONFIG_Touchscreen _WACOM_W8001
    未设置# CONFIG_Touchscreen _WACOM_I2C
    未设置# CONFIG_Touchscreen MAX11801
    未设置# CONFIG_Touchscreen _MCS5000
    未设置# CONFIG_Touchscreen _MMS114
    # CONFIG_Touchscreen _MELFA_MIP4未设置
    未设置# CONFIG_Touchscreen _mTouch
    # CONFIG_Touchscreen _IMX6UL_TSC 未设置
    未设置# CONFIG_Touchscreen _iNexio
    未设置# CONFIG_Touchscreen MK712
    未设置# CONFIG_Touchscreen _PENMOUNT
    CONFIG_Touchscreen _EDT_FT5X06=y
    # CONFIG_Touchscreen _TOUCHRIGHT 未设置
    未设置# CONFIG_Touchscreen _touchwin
    未设置# CONFIG_Touchscreen PIXCIR
    未设置# CONFIG_Touchscreen _WDT87XX_I2C
    未设置# CONFIG_Touchscreen USB 复合接口
    # CONFIG_Touchscreen _TOUCHIT213未设置
    未设置# CONFIG_Touchscreen TSC_Serio
    未设置# CONFIG_Touchscreen TSC2004
    未设置# CONFIG_Touchscreen TSC2005
    未设置# CONFIG_Touchscreen TSC2007
    未设置# CONFIG_TouchW_RM_TS
    未设置# CONFIG_Touchscreen SILEAD
    未设置# CONFIG_TouchW_SIS_I2C
    未设置# CONFIG_Touchscreen _ST1232
    未设置# CONFIG_Touchscreen SUR40
    # CONFIG_Touchscreen _SURFACE3_SPI 未设置
    未设置# CONFIG_Touchscreen SX8654
    未设置# CONFIG_Touchscreen TPS6507X
    未设置# CONFIG_Touchscreen _ZET6223
    未设置# CONFIG_Touchscreen _ZFORCE
    未设置# CONFIG_Touchscreen ROHM_BU21023
    CONFIG_INPUT_MISC=y
    未设置# CONFIG_INPUT_AD714X
    # CONFIG_INPUT_ATMEL_CAPTOUCH 未设置
    未设置# CONFIG_INPUT_BMA150
    未设置# CONFIG_INPUT_E3X0_Button
    未设置# CONFIG_INPUT_MMA8450
    未设置# CONFIG_INPUT_GP2A
    未设置# CONFIG_INPUT_GPIO_蜂 鸣器
    未设置# CONFIG_INPUT_GPIO_DECODER
    # CONFIG_INPUT_CPCAP_PWRBUTTON 未设置
    未设置# CONFIG_INPUT_ATI_REMOTE2
    未设置# CONFIG_INPUT_Keyspan_REMOTE
    未设置# CONFIG_INPUT_KXTJ9
    未设置# CONFIG_INPUT_Powermate
    未设置# CONFIG_INPUT_YEALINK
    未设置# CONFIG_INPUT_CM109
    未设置# CONFIG_INPUT_CONGER_Haptic
    # CONFIG_INPUT_TPS65218_PWRBUTTON 未设置
    未设置# CONFIG_INPUT_UINPUT
    未设置# CONFIG_INPUT_PALMAS PWRBUTTON
    未设置# CONFIG_INPUT_PCF8574
    未设置# CONFIG_INPUT_PWM_蜂 鸣器
    未设置# CONFIG_INPUT_PWM_VIBRA
    未设置# CONFIG_INPUT_GPIO_ROLED_ENCODER
    未设置# CONFIG_INPUT_ADXL34X
    未设置# CONFIG_INPUT_CMA3000
    未设置# CONFIG_INPUT_SOC_button_array
    未设置# CONFIG_INPUT_DRV260X_Haptics
    未设置# CONFIG_INPUT_DRV2665_Haptics
    未设置# CONFIG_INPUT_DRV2667_Haptics
    未设置# CONFIG_RMIV_CORE
    编号
    #硬件 I/O 端口
    编号
    CONFIG_Serio=y
    CONFIG_SERio_SERPORT=y
    未设置# CONFIG_SERio_LIBPS2
    # CONFIG_SERio_RAW 未设置
    未设置# CONFIG_Serio_Altera_PS2
    未设置# CONFIG_Serio_PS2MULT
    # CONFIG_SERio_ARC_PS2未设置
    # CONFIG_SERio_APBPS2未设置
    未设置# CONFIG_SERio_GPIO_PS2
    未设置# CONFIG_USERIO
    未设置# CONFIG_GAMEPORT
    编号
    #个字符的设备
    编号
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_translations=y
    CONFIG_VT_console=y
    CONFIG_VT_console_sleep=y
    CONFIG_HW_console=y
    未设置# CONFIG_UT_HW_console_binding
    CONFIG_UNITX98_PTYS=y
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=256
    未设置# CONFIG_SERIAL_NONSTANDARD
    未设置# CONFIG_N_GSM
    未设置# CONFIG_TRACE_Sink
    CONFIG_LDISC_AUTOLOAD=y
    CONFIG_DEVMEM=y
    # CONFIG_DEVKMEM 未设置
    编号
    #串行驱动器
    编号
    CONFIG_SERIAL_EARLYCON=y
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATE_OPTIONS=y
    未设置# CONFIG_SERIAL_8250_FINTEK
    CONFIG_SERIAL_8250_console=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_NR_UARTs=10
    CONFIG_SERIAL_8250_RUNTIME_UARTs=10
    CONFIG_SERIAL_8250_DEDELED_y
    未设置# CONFIG_SERIAL_8250_MOUSE_PORTS
    未设置# CONFIG_SERIAL_8250_ASPEED_VUART
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    未设置# CONFIG_SERIAL_8250_DETENT_IRQ
    未设置# CONFIG_SERIAL_8250_RSA
    CONFIG_SERIAL_8250_FSL=y
    未设置# CONFIG_SERIAL_8250_DW
    未设置# CONFIG_SERIAL_8250_EM
    未设置# CONFIG_SERIAL_8250_RT288X
    CONFIG_SERIAL_8250_OMAP=y
    CONFIG_SERIAL_8250_OMAP_TTYO_fixup=y
    CONFIG_SERIAL_of_platform=y
    编号
    #非8250串行端口支持
    编号
    # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST 未设置
    # CONFIG_SERIAL_MAX3100未设置
    # CONFIG_SERIAL_MAX310X 未设置
    未设置# CONFIG_SERIAL_UARTLITE
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    未设置# CONFIG_SERIAL_OMAP
    未设置# CONFIG_SERIAL_SCCNXP
    未设置# CONFIG_SERIAL_SC16IS7XX
    CONFIG_SERIAL_BCM63XX=y
    CONFIG_SERIAL_BCM63XX_console=y
    未设置# CONFIG_SERIAL_Altera_JTAGUART
    未设置# CONFIG_SERIAL_Altera_UART
    未设置# CONFIG_SERIAL_IFX6X60
    未设置# CONFIG_SERIAL_XilINX_PS_UART
    未设置# CONFIG_SERIAL_ARC
    未设置# CONFIG_SERIAL_FSL_LPUART
    # CONFIG_SERIAL_CONEXANT_DIGICOLOR 未设置
    未设置# CONFIG_SERIAL_ST_ASC
    CONFIG_SERIAL_DEV_BUS=y
    CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
    未设置# CONFIG_TTY_PRINTK
    CONFIG_HVC_DRIVER=y
    未设置# CONFIG_HVC_DCC
    CONFIG_virtio_console=y
    未设置# CONFIG_IPMI_handler
    CONFIG_HW_Random=y
    未设置# CONFIG_HW_RROM_TIMERIOMEM
    CONFIG_HW_Random_OMAP-y
    未设置# CONFIG_HW_random_virtiio
    未设置# CONFIG_RAW_DRIVER
    未设置# CONFIG_TCG_TPM
    # CONFIG_XILLYBUS 未设置
    编号
    # I2C 支持
    编号
    CONFIG_I2=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_MUX=y
    编号
    #多路复用器 I2C 芯片支持
    编号
    未设置# CONFIG_I2C_ARB_GPIO_Challenge
    未设置# CONFIG_I2C_MUX_GPIO
    未设置# CONFIG_I2C_MUX_GPMUX
    未设置# CONFIG_I2C_MUX_LTC4306
    未设置# CONFIG_I2C_MUX_PCA9541
    CONFIG_I2C_MUX_PCA954x=y
    CONFIG_I2C_MUX_PINCTRL=y
    未设置# CONFIG_I2C_MUX_REG
    CONFIG_I2C_DEMUX_PINCTRL=y
    # CONFIG_I2C_MUX_MLXCPLD 未设置
    CONFIG_I2C_helper_Auto=y
    CONFIG_I2C_ALGOBIT=y
    编号
    # I2C 硬件总线支持
    编号
    编号
    # I2C 系统总线驱动器(主要是嵌入式/片上系统)
    编号
    未设置# CONFIG_I2C_CBUS_GPIO
    # CONFIG_I2C_DESIGWARE_PLANCE 未设置
    未设置# CONFIG_I2C_EMV2
    未设置# CONFIG_I2C_GPIO
    未设置# CONFIG_I2C_OCORES
    CONFIG_I2C_OMAP=y
    未设置# CONFIG_I2C_PCA_platform
    未设置# CONFIG_I2C_RK3X
    未设置# CONFIG_I2C_SIMTEC
    未设置# CONFIG_I2C_Xilinx
    编号
    #外部 I2C/SMBus 适配器驱动程序
    编号
    未设置# CONFIG_I2C_DIOLAN_U2C
    未设置# CONFIG_I2C_PARPORT_LIGHT
    # CONFIG_I2C_ROBOTFUZZ_OSIF 未设置
    未设置# CONFIG_I2C_TOS_EVM
    未设置# CONFIG_I2C_Tiny_USB
    编号
    #其他 I2C/SMBus 总线驱动器
    编号
    未设置# CONFIG_I2C_STUK_SET
    未设置# CONFIG_I2C_SLAVE
    未设置# CONFIG_I2C_DEBUG_CORE
    未设置# CONFIG_I2C_DEBUG_ALGO
    未设置# CONFIG_I2C_DEBUG_BUS
    CONFIG_SPI=y
    未设置# CONFIG_SPI_DEBUG
    CONFIG_SPI_MASTER=y
    # CONFIG_SPI_MEM 未设置
    编号
    # SPI 主控制器驱动程序
    编号
    # CONFIG_SPI_Altera 未设置
    # CONFIG_SPI_AXI_SPI_ENGINE 未设置
    # CONFIG_SPI_BIBANG 未设置
    未设置# CONFIG_SPI_Cadence
    # CONFIG_SPI_DESIGWARE 未设置
    未设置# CONFIG_SPI_GPIO
    未设置# CONFIG_SPI_FSL_SPI
    未设置# CONFIG_SPI_OC_Tiny
    CONFIG_SPI_OMAP24xx=y
    未设置# CONFIG_SPI_TI_QSPI
    # CONFIG_SPI_Rockchip 未设置
    # CONFIG_SPI_SC18IS602未设置
    # CONFIG_SPI_XCOMM 未设置
    未设置# CONFIG_SPI_Xilinx
    # CONFIG_SPI_ZYNQMP_GQSPI 未设置
    编号
    # SPI 协议主器件
    编号
    # CONFIG_SPI_SPIDEV 未设置
    未设置# CONFIG_SPI_LOOP_TEST
    # CONFIG_SPI_TLE62X0未设置
    未设置# CONFIG_SPI_SLAVE
    CONFIG_SPMI=y
    未设置# CONFIG_HSI
    CONFIG_PSP=y
    未设置# CONFIG_PPS_DEBUG
    编号
    # PPS 客户端支持
    编号
    未设置# CONFIG_PPS_CLIENT_KTIMER
    未设置# CONFIG_PPS_CLIENT_LDISC
    未设置# CONFIG_PPS_CLIENT_GPIO
    编号
    支持# PPS 发生器
    编号
    编号
    支持# PTP 时钟
    编号
    CONFIG_PTP_1588_CLOCK = y
    编号
    #启用 PHYLIB 和 NETWORK_PHY_TIMETALK 以查看其他时钟。
    编号
    CONFIG_PINCTRL=y
    CONFIG_GENERIC_PINCTRL_Groups=y
    CONFIG_PINMUX=y
    CONFIG_GENERIC_PINMUX_Functions=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    未设置# CONFIG_DEBUG_PINCTRL
    未设置# CONFIG_PINCTRL_AMD
    未设置# CONFIG_PINCTRL_MCP23S08
    CONFIG_PINCTRL_SINGLE=y
    未设置# CONFIG_PINCTRL_SX150X
    CONFIG_PINCTRL_PALMAS = y
    CONFIG_PINCTRL_TI_IODELAY=y
    CONFIG_ARCH_HASE_CUSTOM_GPIO_H=y
    CONFIG_GPIOLIB=y
    CONFIG_GPIOLIB_FastPath_Limit=512
    CONFIG_of_GPIO=y
    CONFIG_GPIOLIB_IRQCHIP=y
    未设置# CONFIG_DEBUG_GPIO
    CONFIG_GPIO_SYSFS=y
    编号
    #存储器映射 GPIO 驱动程序
    编号
    未设置# CONFIG_GPIO_74xx_MMIO
    # CONFIG_GPIO_Altera 未设置
    # CONFIG_GPIO_DWAPB 未设置
    # CONFIG_GPIO_FTGPIO010未设置
    未设置# CONFIG_GPIO_general_platform
    未设置# CONFIG_GPIO_GRGPIO
    未设置# CONFIG_GPIO_HLWD
    未设置# CONFIG_GPIO_MB86S7X
    未设置# CONFIG_GPIO_MOTUP
    未设置# CONFIG_GPIO_MPC8XXX
    CONFIG_GPIO_OMAP-y
    CONFIG_GPIO_SYSCON=y
    未设置# CONFIG_GPIO_Xilinx
    未设置# CONFIG_GPIO_ZEVIO
    编号
    # I2C GPIO 扩展器
    编号
    未设置# CONFIG_GPIO_ADP5588
    未设置# CONFIG_GPIO_ADNP
    未设置# CONFIG_GPIO_MAX7300
    # CONFIG_GPIO_MAX732X 未设置
    CONFIG_GPIO_PCA953X=y
    CONFIG_GPIO_PCA953X_IRQ=y
    CONFIG_GPIO_PCF857X=y
    未设置# CONFIG_GPIO_TPIC2810
    编号
    MFD GPIO 扩展器
    编号
    未设置# CONFIG_HTC_EGPIO
    未设置# CONFIG_GPIO_LP873X
    未设置# CONFIG_GPIO_LP87565
    CONFIG_GPIO_PALMAS = y
    未设置# CONFIG_GPIO_TPS65218
    未设置# CONFIG_GPIO_TPS6586X
    CONFIG_GPIO_TPS65910=y
    编号
    # SPI GPIO 扩展器
    编号
    未设置# CONFIG_GPIO_74X164
    # CONFIG_GPIO_MAX3191X 未设置
    未设置# CONFIG_GPIO_MAX7301
    未设置# CONFIG_GPIO_MC33880
    未设置# CONFIG_GPIO_PISOSR
    # CONFIG_GPIO_XRA1403未设置
    编号
    #个 USB GPIO 扩展器
    编号
    未设置# CONFIG_W1
    CONFIG_POWER_AVS=y
    CONFIG_POWER_RESET=y
    # CONFIG_POWER_RESET_BRCMKONA 未设置
    未设置# CONFIG_POWER_RESET_BRCMSTB
    CONFIG_POWER_RESET_GPIO=y
    CONFIG_POWER_RESET_GPIO_REST=y
    未设置# CONFIG_POWER_RESET_LTC2952
    未设置# CONFIG_POWER_RESET_RESTART
    未设置# CONFIG_POWER_RESET_ADULLETATE
    未设置# CONFIG_POWER_RESET_SYSCON
    未设置# CONFIG_POWER_RESET_SYSCON_POWERROFF
    未设置# CONFIG_SYSCON_REBOOT_MODE
    CONFIG_POWER_SUPPLY=y
    未设置# CONFIG_POWER_SUPPLY_DEBUG
    未设置# CONFIG_PDA_POWER
    未设置# CONFIG_GENERIC_ADC_BATTERY
    未设置# CONFIG_TEST_POWER
    未设置# CONFIG_CHARER_ADP5061
    CONFIG_BATTERY_ACT8945A=y
    未设置# CONFIG_BATTERY_CPCAP
    未设置# CONFIG_BATTERY_DS2780
    未设置# CONFIG_BATTERY_DS2781
    未设置# CONFIG_BATTERY_DS2782
    未设置# CONFIG_BATTERY_LEGO_EV3
    CONFIG_BATTERY_SBS=y
    未设置# CONFIG_CHARER_SBS
    未设置# CONFIG_MANAGER_SBS
    未设置# CONFIG_BATTERY_BQ27XXX
    未设置# CONFIG_BATTERY_MAX17040
    未设置# CONFIG_BATTERY_MAX17042
    未设置# CONFIG_CHARER_CPCAP
    未设置# CONFIG_CHARER_ISP1704
    未设置# CONFIG_CHARER_MAX8903
    未设置# CONFIG_CHARER_LP8727
    未设置# CONFIG_CHARY_GPIO
    未设置# CONFIG_CHARER_Manager
    未设置# CONFIG_CHARER_LTC3651
    未设置# CONFIG_CHARGER DETECTOR_MAX14656
    未设置# CONFIG_CHARER_BQ2415X
    未设置# CONFIG_CHARER_BQ24190
    未设置# CONFIG_CHARER_BQ24257
    # CONFIG_CHARER_BQ24735未设置
    未设置# CONFIG_CHARGER _BQ25890
    未设置# CONFIG_CHARER_SMB347
    CONFIG_CHARGER TPS65090=y
    未设置# CONFIG_CHARER_TPS65217
    未设置# CONFIG_BATTERY_Gauge LTC2941
    未设置# CONFIG_CHARER_RT9455
    CONFIG_HWMON=y
    未设置# CONFIG_HWMON_DEBUG_CHIP
    编号
    #本机驱动程序
    编号
    未设置# CONFIG_SENSORS_AD7314
    未设置# CONFIG_SENSORS_AD7414
    未设置# CONFIG_SENSORS_AD7418
    未设置# CONFIG_SENSORS_ADM1021
    未设置# CONFIG_SENSORS_ADM1025
    未设置# CONFIG_SENSORS_ADM1026
    未设置# CONFIG_SENSORS_ADM1029
    未设置# CONFIG_SENSORS_ADM1031
    未设置# CONFIG_SENSORS_ADM9240
    未设置# CONFIG_SENSORS_ADT7310
    未设置# CONFIG_SENSORS_ADT7410
    未设置# CONFIG_SENSORS_ADT7411
    未设置# CONFIG_SENSORS_ADT7462
    未设置# CONFIG_SENSORS_ADT7470
    未设置# CONFIG_SENSORS_ADT7475
    # CONFIG_SENSORS_ASC7621未设置
    未设置# CONFIG_SENSORS_ASPEED
    # CONFIG_SENSORS_ATXP1未设置
    未设置# CONFIG_SENSORS_DS620
    未设置# CONFIG_SENSORS_DS1621
    未设置# CONFIG_SENSORS_F71805F
    未设置# CONFIG_SENSORS_F71882FG
    未设置# CONFIG_SENSORS_F75375S
    未设置# CONFIG_SENSORS_FTSTEUSTATES
    未设置# CONFIG_SENSORS_GL518SM
    未设置# CONFIG_SENSORS_GL520SM
    未设置# CONFIG_SENSORS_G760A
    未设置# CONFIG_SENSORS_G762
    未设置# CONFIG_SENSORS_GPIO_FAN
    未设置# CONFIG_SENSORS_HIH6130
    CONFIG_SENSORS_IIO_HWMON=y
    未设置# CONFIG_SENSORS_IT87
    # CONFIG_SENSORS_JC42未设置
    未设置# CONFIG_SENSORS_POWERR1220
    未设置# CONFIG_SENSORS_LINUeage
    未设置# CONFIG_SENSORS_LTC2945
    未设置# CONFIG_SENSORS_LTC2990
    未设置# CONFIG_SENSORS_LTC4151
    未设置# CONFIG_SENSORS_LTC4215
    未设置# CONFIG_SENSORS_LTC4222
    未设置# CONFIG_SENSORS_LTC4245
    未设置# CONFIG_SENSORS_LTC4260
    未设置# CONFIG_SENSORS_LTC4261
    # CONFIG_SENSORS_MAX1111未设置
    未设置# CONFIG_SENSORS_MAX16065
    未设置# CONFIG_SENSORS_MAX1619
    未设置# CONFIG_SENSORS_MAX1668
    未设置# CONFIG_SENSORS_MAX197
    未设置# CONFIG_SENSORS_MAX31722
    未设置# CONFIG_SENSORS_MAX6621
    未设置# CONFIG_SENSORS_MAX6639
    未设置# CONFIG_SENSORS_MAX6642
    未设置# CONFIG_SENSORS_MAX6650
    未设置# CONFIG_SENSORS_MAX6697
    # CONFIG_SENSORS_MAX31790未设置
    未设置# CONFIG_SENSORS_MCP3021
    未设置# CONFIG_SENSORS_TC654
    未设置# CONFIG_SENSORS_ADCXX
    未设置# CONFIG_SENSORS_LM63
    未设置# CONFIG_SENSORS_LM70
    未设置# CONFIG_SENSORS_LM73
    未设置# CONFIG_SENSORS_LM75
    未设置# CONFIG_SENSORS_LM77
    未设置# CONFIG_SENSORS_LM78
    未设置# CONFIG_SENSORS_LM80
    未设置# CONFIG_SENSORS_LM83
    未设置# CONFIG_SENSORS_LM85
    未设置# CONFIG_SENSORS_LM87
    未设置# CONFIG_SENSORS_LM90
    未设置# CONFIG_SENSORS_LM92
    未设置# CONFIG_SENSORS_LM93
    未设置# CONFIG_SENSORS_LM95234
    未设置# CONFIG_SENSORS_LM95241
    未设置# CONFIG_SENSORS_LM95245
    未设置# CONFIG_SENSORS_PC87360
    未设置# CONFIG_SENSORS_PC87427
    未设置# CONFIG_SENSORS_NTC_Thermistor
    未设置# CONFIG_SENSORS_NCT6683
    未设置# CONFIG_SENSORS_NCT6775
    未设置# CONFIG_SENSORS_NCT7802
    未设置# CONFIG_SENSORS_NCT7904
    # CONFIG_SENSORS_NPCM7XX 未设置
    未设置# CONFIG_SENSORS_PCF8591
    未设置# CONFIG_PMBus
    未设置# CONFIG_SENSORS_PWM_FAN
    未设置# CONFIG_SENSORS_SHT15
    未设置# CONFIG_SENSORS_SHT21
    未设置# CONFIG_SENSORS_SHT3x
    未设置# CONFIG_SENSORS_SHTC1
    未设置# CONFIG_SENSORS_DME1737
    未设置# CONFIG_SENSORS_EMC1403
    未设置# CONFIG_SENSORS_EMC2103
    未设置# CONFIG_SENSORS_EMC6W201
    未设置# CONFIG_SENSORS_SMSC47M1
    未设置# CONFIG_SENSORS_SMSC47M192
    未设置# CONFIG_SENSORS_SMSC47B397
    未设置# CONFIG_SENSORS_SCH5627
    未设置# CONFIG_SENSORS_SCH5636
    未设置# CONFIG_SENSORS_STTS751
    未设置# CONFIG_SENSORS_SMM665
    未设置# CONFIG_SENSORS_ADC128D818
    未设置# CONFIG_SENSORS_ADS1015
    未设置# CONFIG_SENSORS_ADS7828
    未设置# CONFIG_SENSORS_ADS7871
    未设置# CONFIG_SENSORS_AMC6821
    未设置# CONFIG_SENSORS_INA209
    未设置# CONFIG_SENSORS_INA2XX
    未设置# CONFIG_SENSORS_INA3221
    未设置# CONFIG_SENSORS_TC74
    未设置# CONFIG_SENSORS_THMC50
    未设置# CONFIG_SENSORS_TMP102
    未设置# CONFIG_SENSORS_TMP103
    未设置# CONFIG_SENSORS_TMP108
    未设置# CONFIG_SENSORS_TMP401
    未设置# CONFIG_SENSORS_TMP421
    未设置# CONFIG_SENSORS_VT1211
    # CONFIG_SENSORS_W83773G 未设置
    # CONFIG_SENSORS_W83781D 未设置
    # CONFIG_SENSORS_W83791D 未设置
    未设置# CONFIG_SENSORS_W83792D
    未设置# CONFIG_SENSORS_W83793
    未设置# CONFIG_SENSORS_W83795
    未设置# CONFIG_SENSORS_W83L785TS
    未设置# CONFIG_SENSORS_W83L786NG
    # CONFIG_SENSORS_W83627HF 未设置
    # CONFIG_SENSORS_W83627EHF 未设置
    CONFIG_热力= y
    未设置# CONFIG_热力 统计信息
    CONFIG_热力 紧急状态 POWER_POWEROFF_DELAY_MS=0
    CONFIG_热力 HWMON=y
    CONFIG_Thermal of=y
    CONFIG_热力 可写跳闸= y
    CONFIG_热力 默认值 GOV_STEP_WISE = y
    未设置# CONFIG_热力 默认值 GOV_FICE_SHARE
    未设置# CONFIG_热力 默认值 GOV_USER_SPACE
    未设置# CONFIG_热力 默认值 GOV_POWER_LOADator
    CONFIG_热力 GOV_FER_SHARE=y
    CONFIG_热力 GOV_STEP_WISE = y
    CONFIG_热力 GOV_BON_BON=y
    CONFIG_热力 GOV_USER_SPACE = y
    CONFIG_热力 GOV_POWER_LOADTER=y
    CONFIG_CPU_Thermal = y
    未设置# CONFIG_CLOCK_热力
    未设置# CONFIG_DEVFREQ_热力
    CONFIG_热力 仿真= y
    未设置# CONFIG_QorIQ_Thermal
    编号
    # ACPI INT340X 热驱动器
    编号
    编号
    #德州仪器散热驱动器
    编号
    CONFIG_TI_SOC_热力= y
    CONFIG_TI_热力= y
    CONFIG_DRA752_热力= y
    # CONFIG_QCOM_SPMI_TEMP_ALARM 未设置
    未设置# CONFIG_GENERIC_ADC_热力
    CONFIG_Watchdog=y
    CONFIG_安全 装置_CORE=y
    未设置# CONFIG_Watchdog_NOWAYOUT
    CONFIG_WATCHDOG_Handle_BOOT_ENABLE=y
    未设置# CONFIG_Watchdog_SYSFS
    编号
    #看门狗设备驱动程序
    编号
    未设置# CONFIG_SOFT_WATCHDOG
    未设置# CONFIG_GPIO_WATCHDOG
    未设置# CONFIG_Xilinx 安全装置
    # CONFIG_ZIIRAVE_安全 装置未设置
    未设置# CONFIG_Cadence_Watchdog
    # CONFIG_FTWDT010_Watchdog 未设置
    未设置# CONFIG_DW_TATCHDOG
    未设置# CONFIG_OMAP-Watchdog
    未设置# CONFIG_MAX63XX_Watchdog
    未设置# CONFIG_MEN A21_WDT
    编号
    #个基于 USB 的看门狗卡
    编号
    # CONFIG_USBPCWATCHDOG 未设置
    编号
    #看门狗预超时控制器
    编号
    # CONFIG_WATCHDOG_FERPRECIMEOUT_GOV 未置位
    CONFIG_SSB_Possible = y
    未设置# CONFIG_SSB
    CONFIG_BCMA_Possible = y
    # CONFIG_BCMA 未设置
    编号
    #多功能设备驱动程序
    编号
    CONFIG_MFD_CORE=y
    CONFIG_MFD_ACT8945A=y
    # CONFIG_MFD_AS3711未设置
    # CONFIG_MFD_AS3722未设置
    未设置# CONFIG_PMIC_ADP5520
    # CONFIG_MFD_AAT2870_CORE 未设置
    # CONFIG_MFD_Atmel_FLEXCOM 未设置
    # CONFIG_MFD_ATMEL_HLCDC 未设置
    # CONFIG_MFD_BCM590XX 未设置
    未设置# CONFIG_MFD_BD9571MWV
    # CONFIG_MFD_AXP20X_I2C 未设置
    # CONFIG_MFD_CROS_EC 未设置
    # CONFIG_MFD_MADERA 未设置
    # CONFIG_MFD_ASIC3未设置
    未设置# CONFIG_PMIC_DA903X
    # CONFIG_MFD_DA9052_SPI 未设置
    # CONFIG_MFD_DA9052_I2C 未设置
    # CONFIG_MFD_DA9055未设置
    # CONFIG_MFD_DA9062未设置
    # CONFIG_MFD_DA9063未设置
    # CONFIG_MFD_DA9150未设置
    # CONFIG_MFD_DLN2未设置
    # CONFIG_MFD_MC13XXX_SPI 未设置
    # CONFIG_MFD_MC13XXX_I2C 未设置
    # CONFIG_MFD_HI6421_PMIC 未设置
    未设置# CONFIG_HTC_PASIC3
    未设置# CONFIG_HTC_I2CPLD
    # CONFIG_MFD_KEMPLD 未设置
    # CONFIG_MFD_88PM800未设置
    # CONFIG_MFD_88PM805未设置
    # CONFIG_MFD_88PM860X 未设置
    # CONFIG_MFD_MAX14577未设置
    # CONFIG_MFD_MAX77620未设置
    # CONFIG_MFD_MAX77686未设置
    # CONFIG_MFD_MAX77693未设置
    # CONFIG_MFD_MAX77843未设置
    # CONFIG_MFD_MAX8907未设置
    # CONFIG_MFD_MAX8925未设置
    # CONFIG_MFD_MAX8997未设置
    # CONFIG_MFD_MAX8998未设置
    # CONFIG_MFD_MT6397未设置
    # CONFIG_MFD_MENF21BMC 未设置
    # CONFIG_EZX_PCAP 未设置
    CONFIG_MFD_CPCAP=y
    未设置# CONFIG_MFD_VIPERBOARD
    # CONFIG_MFD_RETU 未设置
    # CONFIG_MFD_PCF50633未设置
    # CONFIG_MFD_PM8XXX 未设置
    # CONFIG_MFD_RT5033未设置
    # CONFIG_MFD_RC5T583未设置
    # CONFIG_MFD_RK808未设置
    # CONFIG_MFD_RN5T618未设置
    # CONFIG_MFD_SEC_CORE 未设置
    # CONFIG_MFD_SI476X_CORE 未设置
    # CONFIG_MFD_SM501未设置
    # CONFIG_MFD_SKY81452未设置
    # CONFIG_MFD_SMSC 未设置
    未设置# CONFIG_ABX500_CORE
    # CONFIG_MFD_STMPE 未设置
    CONFIG_MFD_SYSCON=y
    # CONFIG_MFD_TI_AM335X_TSCADC 未设置
    未设置# CONFIG_MFD_LP3943
    # CONFIG_MFD_LP8788未设置
    # CONFIG_MFD_TI_LMU 未设置
    CONFIG_MFD_PALMAS = y
    未设置# CONFIG_TPS6105X
    未设置# CONFIG_TPS65010
    未设置# CONFIG_TPS6507X
    # CONFIG_MFD_TPS65086未设置
    CONFIG_MFD_TPS65090=y
    CONFIG_MFD_TPS65217=y
    CONFIG_MFD_TI_LP873X=y
    CONFIG_MFD_TI_LP87565=y
    CONFIG_MFD_TPS65218=y
    CONFIG_MFD_TPS6586X=y
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912_I2C 未设置
    # CONFIG_MFD_TPS65912_SPI 未设置
    # CONFIG_MFD_TPS80031未设置
    # CONFIG_TWL4030_CORE 未设置
    # CONFIG_TWL6040_CORE 未设置
    # CONFIG_MFD_WL1273_CORE 未设置
    # CONFIG_MFD_LM3533未设置
    # CONFIG_MFD_TC3589X 未设置
    # CONFIG_MFD_T7L66XB 未设置
    # CONFIG_MFD_TC6387XB 未设置
    # CONFIG_MFD_TC6393XB 未设置
    未设置# CONFIG_MFD_Arizona I2C
    未设置# CONFIG_MFD_Arizona SPI
    # CONFIG_MFD_WM8400未设置
    # CONFIG_MFD_WM831X_I2C 未设置
    # CONFIG_MFD_WM831X_SPI 未设置
    # CONFIG_MFD_WM8350_I2C 未设置
    # CONFIG_MFD_WM8994未设置
    # CONFIG_MFD_ROHM_BD718XX 未设置
    未设置# CONFIG_RAW_SP_CORE
    CONFIG_电脑 控制器=y
    未设置# CONFIG_CONGER_DEBUG
    CONFIG_CONGER_FIXED_VOLT=y
    未设置# CONFIG_电脑 控制器_virtual_consumer
    未设置# CONFIG_电脑 控制器_userspace_consumer
    未设置# CONFIG_电脑 控制器_88PG86X
    未设置# CONFIG_电脑 控制器_ACT8865
    CONFIG_电脑 控制器_ACT8945A=y
    未设置# CONFIG_电脑 控制器_AD5398
    未设置# CONFIG_电脑 控制器_ANATOP
    CONFIG_电脑 控制器_CPCAP=y
    未设置# CONFIG_电脑 控制器_DA9210
    未设置# CONFIG_电脑 控制器_DA9211
    未设置# CONFIG_电脑 控制器_FAN53555
    CONFIG_电脑 控制器_GPIO=y
    未设置# CONFIG_电脑 控制器_ISL9305
    未设置# CONFIG_电脑 控制器_ISL6271A
    未设置# CONFIG_电脑 控制器_LP3971
    未设置# CONFIG_电脑 控制器_LP3972
    未设置# CONFIG_电脑 控制器_LP872X
    CONFIG_电脑 控制器 LP873X=y
    未设置# CONFIG_CONGER_LP8755
    CONFIG_电脑 控制器 LP87565=y
    未设置# CONFIG_CONGER_LTC3589
    未设置# CONFIG_CONGER_LTC3676
    未设置# CONFIG_电脑 控制器_MAX1586
    未设置# CONFIG_电脑 控制器_MAX8649
    未设置# CONFIG_电脑 控制器_MAX8660
    未设置# CONFIG_电脑 控制器_MAX8952
    未设置# CONFIG_电脑 控制器_MAX8973
    未设置# CONFIG_电脑 控制器_MT6311
    CONFIG_电脑 控制器_PALMAS = y
    CONFIG_CONGER_PBIAS=y
    未设置# CONFIG_电脑 控制器_PFUZE100
    未设置# CONFIG_电脑 控制器_PV88060
    未设置# CONFIG_电脑 控制器_PV88080
    未设置# CONFIG_电脑 控制器_PV88090
    未设置# CONFIG_电脑 控制器_PWM
    未设置# CONFIG_电脑 控制器_QCOM_SPMI
    CONFIG_电脑 控制器_TI_ABB = y
    未设置# CONFIG_电脑 控制器_SY8106A
    未设置# CONFIG_电脑 控制器_TPS51632
    CONFIG_电脑 控制器_TPS62360=y
    未设置# CONFIG_电脑 控制器_TPS65023
    未设置# CONFIG_电脑 控制器_TPS6507X
    CONFIG_电脑 控制器 TPS65090=y
    未设置# CONFIG_电脑 控制器_TPS65132
    未设置# CONFIG_电脑 控制器_TPS65217
    未设置# CONFIG_电脑 控制器_TPS65218
    CONFIG_电脑 控制器 TPS6524X=y
    CONFIG_电脑 控制器_TPS6586X=y
    未设置# CONFIG_电脑 控制器_TPS65910
    未设置# CONFIG_电脑 控制器_VCTRL
    CONFIG_CEC_CORE=y
    未设置# CONFIG_RC_CORE
    CONFIG_MEDIA 支持= y
    编号
    #多媒体内核支持
    编号
    CONFIG_MEASE_CAMER_SUPPT=y
    未设置# CONFIG_MEASE_ANALOG_TV_support
    未设置# CONFIG_MEDIA 数字电视支持
    未设置# CONFIG_MEASE_RADIO_SUPPTATION
    未设置# CONFIG_MEASE_SDR_support
    CONFIG_MEASE_CEC_support=y
    CONFIG_MEASE_CONTROLLER=y
    CONFIG_VIDEO_DEV_y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    CONFIG_VIDEO_V4L2=y
    未设置# CONFIG_VIDEO ADV_DEBUG
    未设置# CONFIG_VIDEO FIXED_MINOR 范围
    CONFIG_V4L2_MEM2MEM_DEV_y
    编号
    #介质驱动程序
    编号
    CONFIG_MEASE_USB_support=y
    编号
    #网络摄像头设备
    编号
    未设置# CONFIG_USB_VIDEO 类
    未设置# CONFIG_USB_GSPCA
    未设置# CONFIG_USB_PWC
    未设置# CONFIG_VIDEO CPUA2
    未设置# CONFIG_USB_ZR364XX
    # CONFIG_USB_STKWEBCAM 未设置
    未设置# CONFIG_USB_S2255
    未设置# CONFIG_VIDEO_USBTV
    编号
    #网络摄像头、电视(模拟/数字) USB 设备
    编号
    未设置# CONFIG_VIDEO EM28XX
    编号
    #个 USB HDMI CEC 适配器
    编号
    CONFIG_V4L_Platform_drivers=y
    未设置# CONFIG_VIDEO Cadence
    未设置# CONFIG_VIDEO MUX
    未设置# CONFIG_SOC_CAMER_SECONFIG
    未设置# CONFIG_VIDEO_Xilinx
    未设置# CONFIG_VIDEO TI_CAL
    未设置# CONFIG_VIDEO TI_VIP
    CONFIG_V4L_MEM2MEM_DRIVERs=y
    # CONFIG_VIDEO_MEM2MEM_DEINTERLACE 未设置
    未设置# CONFIG_VIDEO_SH_VEU
    未设置# CONFIG_VIDEO_TI_VPE
    CONFIG_V4L_TEST_DRIVERS=y
    未设置# CONFIG_VIDEO VIMC
    未设置# CONFIG_VIDEO
    未设置# CONFIG_VIDEO VIM2M
    # CONFIG_VIDEO_VICODEC 未设置
    CONFIG_CEC_Platform_drivers=y
    未设置# CONFIG_CEC_GPIO
    编号
    支持的 MMC/SDIO 适配器数
    编号
    未设置# CONFIG_Cypress_firmware
    CONFIG_VIDEOBUF2_CORE=y
    CONFIG_VIDEOBUF2_V4L2=y
    CONFIG_VIDEOBUF2_MEMOPS=y
    CONFIG_VIDEOBUF2_DMA_CONTIG=y
    CONFIG_VIDEOBUF2_DMA_SG=y
    编号
    #媒体辅助驱动器(调谐器、传感器、i2c、SPI、前端)
    编号
    # CONFIG_MEDIA_SUBDRV_AutoSelect 未设置
    编号
    # I2C 编码器、解码器、传感器和其他辅助芯片
    编号
    编号
    #音频解码器、处理器和混频器
    编号
    未设置# CONFIG_VIDEO TVAUDIO
    未设置# CONFIG_VIDEO TDA7432
    未设置# CONFIG_VIDEO TDA9840
    # CONFIG_VIDEO TDA1997未设置
    未设置# CONFIG_VIDEO_TEA6415C
    # CONFIG_VIDEO_TEA6420未设置
    未设置# CONFIG_VIDEO MSP3400
    未设置# CONFIG_VIDEO CS3308
    未设置# CONFIG_VIDEO CS5345
    未设置# CONFIG_VIDEO CS53L32A
    未设置# CONFIG_VIDEO TLV320AIC23B
    未设置# CONFIG_VIDEO UDA1342
    未设置# CONFIG_VIDEO WM8775
    未设置# CONFIG_VIDEO WM8739
    未设置# CONFIG_VIDEO VP27SMPX
    # CONFIG_VIDEO_SONY_BTF_MPX 未设置
    编号
    Rds 解码器
    编号
    未设置# CONFIG_VIDEO SAA6588
    编号
    #视频解码器
    编号
    未设置# CONFIG_VIDEO ADV7180
    未设置# CONFIG_VIDO_ADV7183
    未设置# CONFIG_VIDEO ADV748X
    未设置# CONFIG_VIDEO ADV7604
    未设置# CONFIG_VIDEO ADV7842
    未设置# CONFIG_VIDEO BT819
    未设置# CONFIG_VIDEO BT856
    未设置# CONFIG_VIDEO BT866
    未设置# CONFIG_VIDEO KS0127
    未设置# CONFIG_VIDEO _ML86V7667
    未设置# CONFIG_VIDEO AD5820
    未设置# CONFIG_VIDEO AK7375
    未设置# CONFIG_VIDEO DW9714
    未设置# CONFIG_VIDEO DW9807_VCM
    未设置# CONFIG_VIDEO SAA7110
    未设置# CONFIG_VIDEO SAA711X
    未设置# CONFIG_VIDEO TC358743
    未设置# CONFIG_VIDEO TVP514X
    未设置# CONFIG_VIDEO TVP5150
    未设置# CONFIG_VIDEO TVP7002
    # CONFIG_VIDUO_TW2804未设置
    # CONFIG_VIDEO TW9903未设置
    # CONFIG_VIDEO TW9906未设置
    未设置# CONFIG_VIDEO TW9910
    未设置# CONFIG_VIDEO_VPX3220
    编号
    #视频和音频解码器
    编号
    未设置# CONFIG_VIDEO SAA717X
    未设置# CONFIG_VIDEO CX25840
    编号
    #视频编码器
    编号
    未设置# CONFIG_VIDEO SAA7127
    未设置# CONFIG_VIDEO SAA7185
    未设置# CONFIG_VIDO_ADV7170
    未设置# CONFIG_VIDO_ADV7175
    未设置# CONFIG_VIDEO ADV7343
    未设置# CONFIG_VIDEO ADV7393
    未设置# CONFIG_VIDUO_ADV7511
    未设置# CONFIG_VIDEO AD9389B
    未设置# CONFIG_VIDEO AK881X
    未设置# CONFIG_VIDEO_THS8200
    编号
    #摄像头传感器器件
    编号
    未设置# CONFIG_VIDEO_IMX258
    未设置# CONFIG_VIDEO_IMX274
    未设置# CONFIG_VIDEO OV2640
    未设置# CONFIG_VIDEO OV2659
    未设置# CONFIG_VIDEO OV2680
    未设置# CONFIG_VIDEO OV2685
    未设置# CONFIG_VIDEO OV5640
    未设置# CONFIG_VIDEO OV5645
    未设置# CONFIG_VIDEO OV5647
    未设置# CONFIG_VIDEO OV6650
    未设置# CONFIG_VIDEO OV5670
    未设置# CONFIG_VIDEO OV5695
    未设置# CONFIG_VIDEO OV7251
    未设置# CONFIG_VIDEO OV772X
    未设置# CONFIG_VIDEO OV7640
    未设置# CONFIG_VIDEO OV7670
    未设置# CONFIG_VIDEO OV7740
    未设置# CONFIG_VIDEO OV9650
    未设置# CONFIG_VIDEO OV13858
    未设置# CONFIG_VIDEO OV1063X
    未设置# CONFIG_VIDEO OV490
    未设置# CONFIG_VIDEO VS6624
    未设置# CONFIG_VIDEO MT9M032
    未设置# CONFIG_VIDEO MT9M111
    未设置# CONFIG_VIDEO MT9P031
    未设置# CONFIG_VIDEO MT9T001
    未设置# CONFIG_VIDEO MT9T112
    未设置# CONFIG_VIDEO MT9V011
    未设置# CONFIG_VIDEO MT9V032
    未设置# CONFIG_VIDEO MT9V111
    未设置# CONFIG_VIDEO MT9T11X
    未设置# CONFIG_VIDEO SR030PC30
    # CONFIG_VIDEO NOON010PC30未设置
    未设置# CONFIG_VIDEO M5MOLS
    未设置# CONFIG_VIDEO RJ54N1
    未设置# CONFIG_VIDEO S5K6AA
    未设置# CONFIG_VIDEO S5K6A3
    未设置# CONFIG_VIDEO_S5K4ECGX
    # CONFIG_VIDEO S5K5BAF 未设置
    未设置# CONFIG_VIDEO SMIAPP
    # CONFIG_VIDEO_ET8EK8未设置
    未设置# CONFIG_VIDEO S5C73M3
    编号
    #闪存器件
    编号
    未设置# CONFIG_VIDEO ADP1653
    未设置# CONFIG_VIDEO LM3560
    未设置# CONFIG_VIDEO LM3646
    编号
    #视频改进芯片
    编号
    未设置# CONFIG_VIDEO UPD64031A
    未设置# CONFIG_VIDEO UPD64083
    编号
    #音频/视频压缩芯片
    编号
    未设置# CONFIG_VIDEO SAA6752HS
    编号
    # SDR 调谐器芯片
    编号
    编号
    #杂项辅助芯片
    编号
    未设置# CONFIG_VIDEO THS7303
    未设置# CONFIG_VIDEO M52790
    未设置# CONFIG_VIDEO I2C
    编号
    SoC_CAMER_DRIVER 上使用的传感器#
    编号
    编号
    # SPI 辅助芯片
    编号
    未设置# CONFIG_VIDEO GS1662
    编号
    #介质 SPI 适配器
    编号
    编号
    #自定义 DVB 前向
    编号
    编号
    #开发新前沿的工具
    编号
    编号
    #图形支持
    编号
    未设置# CONFIG_IMX_IPUV3_CORE
    CONFIG_DRM=y
    # CONFIG_DRM_DP_AUX_CHARDEV 未设置
    未设置# CONFIG_DRM_DEBUG_MM
    未设置# CONFIG_DRM_DEBUG_SEseltest
    CONFIG_DRM_KMS_helper=y
    CONFIG_DRM_KMS_Fb_helper=y
    CONFIG_DRM_fbDEV_emulation=y
    CONFIG_DRM_fbDEV_OVERALLOC=100
    未设置# CONFIG_DRM_fbDEV_leare_phys_SMEM
    未设置# CONFIG_DRM_LOAD_EDID_firmware
    未设置# CONFIG_DRM_DP_CEC
    CONFIG_DRM_GEM_CMA_helper=y
    CONFIG_DRM_KMS_CMA_helper=y
    CONFIG_DRM_VM=y
    编号
    # I2C 编码器或辅助芯片
    编号
    未设置# CONFIG_DRM_I2C_CH7006
    未设置# CONFIG_DRM_I2C_SIL164
    CONFIG_DRM_I2C_NXP_TDA998X=y
    # CONFIG_DRM_I2C_NXP_TDA9950未设置
    未设置# CONFIG_DRM_HDLLCD
    未设置# CONFIG_DRM_Mali_display
    编号
    # ACP (音频协处理器)配置
    编号
    编号
    # AMD 库例程
    编号
    未设置# CONFIG_DRM_VGEM
    未设置# CONFIG_DRM_VKMS
    CONFIG_DRM_vDRM=y
    # CONFIG_DRM_EXYNOS 未设置
    未设置# CONFIG_DRM_UDL
    未设置# CONFIG_DRM_Armada
    # CONFIG_DRM_RCAR_DW_HDMI 未设置
    # CONFIG_DRM_RCAR_LVDS 未设置
    CONFIG_DRM_OMAP-y
    CONFIG_DRM_OMAP-WB=y
    CONFIG_OMAP2_DSS_INIT=y
    CONFIG_OMAP_DSS_BAS=y
    CONFIG_OMAP2_DSS=y
    未设置# CONFIG_OMAP2_DSS_DEBUG
    CONFIG_OMAP2_DSS_DebugFS=y
    未设置# CONFIG_OMAP2_DSS_Collect_IRQ_STATS
    CONFIG_OMAP2_DSS_DPI=y
    未设置# CONFIG_OMAP2_DSS_VENC
    CONFIG_OMAP2_DSS_HDMI_common=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP4_DSS_HDMI_CEC=y
    CONFIG_OMAP5_DSS_HDMI=y
    未设置# CONFIG_OMAP2_DSS_SDI
    未设置# CONFIG_OMAP2_DSS_DSI
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_After _VENC_RESET=y
    编号
    # OMAPDRM 外部显示设备驱动程序
    编号
    未设置# CONFIG_DRM_OMAP-ENCODER_OPA362
    CONFIG_DRM_OMA_ENCODER_TPD12S015=y
    CONFIG_DRM_OMAP-DRA7EVM_ENCODER_TPD12S015=y
    CONFIG_DRM_OMAP-CONNECT_HDMI=y
    未设置# CONFIG_DRM_OMAP-CONNECT_ANALOG_TV
    未设置# CONFIG_DRM_OMAP-PANE_DSI_CM
    未设置# CONFIG_DRM_OMAP-PANE_SONY_ACX565AKM
    # CONFIG_DRM_OMAP-PANE_LGPHILIPS_LB035Q02未设置
    # CONFIG_DRM_OMAP-PANEL_SHART_LS037V7DW01未设置
    # CONFIG_DRM_OMAP-PAGE_TPO_TD028TTEC1未设置
    # CONFIG_DRM_OMAP-PAGE_TPO_TD043MTEA1未设置
    未设置# CONFIG_DRM_OMAP-PANEC_NL8048HL11
    CONFIG_DRM_TILCDC=y
    未设置# CONFIG_DRM_Virtio_GPU
    未设置# CONFIG_DRM_FSL_DCU
    未设置# CONFIG_DRM_STM
    CONFIG_DRM_PANEL = y
    编号
    #显示面板
    编号
    未设置# CONFIG_DRM_PAGE_ARM_ADULESDULATION
    未设置# CONFIG_DRM_PAGE_LVDS
    # CONFIG_DRM_PAGE_SIMPLE 未设置
    # CONFIG_DRM_PAGE_ILITEK_IL9322未设置
    未设置# CONFIG_DRM_PAGE_Samsung LD9040
    # CONFIG_DRM_PAGE_LG_LG4573未设置
    未设置# CONFIG_DRM_PAGE_Samsung S6E8AA0
    # CONFIG_DRM_PAGE_SEIKO_43WVF1G 未设置
    # CONFIG_DRM_PAGE_SITORONIX_ST7789V 未设置
    CONFIG_DRM_BRIDGE=y
    CONFIG_DRM_Panel_Bridge=y
    编号
    #显示接口桥接器
    编号
    # CONFIG_DRM_ANALOGUEIX_ANX78XX 未设置
    未设置# CONFIG_DRM_CDNS_DSI
    未设置# CONFIG_DRM_CDNS_MSDP
    未设置# CONFIG_DRM_Dumb_VGA_DAC
    未设置# CONFIG_DRM_LVDS_ENCODER
    # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW 未设置
    未设置# CONFIG_DRM_NXP_PTN3460
    未设置# CONFIG_DRM_parade_PS8622
    未设置# CONFIG_DRM_SIL_SIIII8620
    未设置# CONFIG_DRM_SII902X
    未设置# CONFIG_DRM_SII9234
    未设置# CONFIG_DRM_THIN_THC63LVD1024
    # CONFIG_DRM_Toshiba TC358767未设置
    # CONFIG_DRM_Toshiba TC358768未设置
    未设置# CONFIG_DRM_TI_TFP410
    # CONFIG_DRM_I2C_ADV7511未设置
    未设置# CONFIG_DRM_STI
    未设置# CONFIG_DRM_ARCPGU
    # CONFIG_DRM_MXSFB 未设置
    未设置# CONFIG_DRM_TINYDRM
    未设置# CONFIG_DRM_PL111
    未设置# CONFIG_DRM_TVE200
    未设置# CONFIG_DRM_TIDSS
    CONFIG_DRM_LEGACE=y
    CONFIG_DRM_Panel_oriention_quirks=y
    编号
    #帧缓冲器器件
    编号
    CONFIG_FB=y
    未设置# CONFIG_firmware_EDID
    CONFIG_FB_CMDLINE=y
    CONFIG_FB_NOTIFY=y
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_SYS_FILLRECT = y
    CONFIG_FB_SYS_COPYAREA=y
    CONFIG_FB_SYS_IMAGEBLIT=y
    未设置# CONFIG_FB_Foreign _ENDIAN
    CONFIG_FB_SYS_FOPS=y
    CONFIG_FB_DERAD_IO=y
    未设置# CONFIG_FB_MODE_APERs
    # CONFIG_FB_TILEBLITTING 未设置
    编号
    #帧缓冲硬件驱动程序
    编号
    未设置# CONFIG_FB_EFI
    未设置# CONFIG_FB_OPENCORES
    未设置# CONFIG_FB_S1D13XXX
    # CONFIG_FB_SMSCUFX 未设置
    未设置# CONFIG_FB_UDL
    未设置# CONFIG_FB_IBM_GXT4500
    未设置# CONFIG_FB_virtual
    # CONFIG_FB_Metronome 未设置
    未设置# CONFIG_FB_broadsheet
    未设置# CONFIG_FB_SIMPLE
    # CONFIG_FB_SSD1307未设置
    CONFIG_背 光_LCD_support=y
    未设置# CONFIG_LCD_CLASS_DEVICE
    CONFIG_背 光_class_device=y
    CONFIG_背 光_generic=y
    CONFIG_背 光_PWM=y
    未设置# CONFIG_背 光_PM8941_WLED
    未设置# CONFIG_背 光_ADP8860
    未设置# CONFIG_背 光_ADP8870
    未设置# CONFIG_背 光_LM3630A
    未设置# CONFIG_背 光_LM3639
    未设置# CONFIG_BRAY_LP855X
    未设置# CONFIG_背 光_TPS65217
    CONFIG_背 光_GPIO=y
    未设置# CONFIG_背 光_LV5207LP
    未设置# CONFIG_BRELOAD_BD6107
    未设置# CONFIG_背 光_ARCXCNN
    CONFIG_VIDEOMODE_AIDENS=y
    CONFIG_HDMI=y
    编号
    #控制台显示驱动程序支持
    编号
    CONFIG_虚设 控制台= y
    未设置# CONFIG_framebuffer_console
    未设置# CONFIG_LOGO
    CONFIG_sound=y
    CONFIG_SND=y
    CONFIG_SND_TIMER = y
    CONFIG_SND_PCM=y
    CONFIG_SND_PCM_ELD=y
    CONFIG_SND_PCM_IEC958=y
    CONFIG_SND_DMAENGINE_PCM=y
    CONFIG_SND_JACK = y
    CONFIG_SND_JACK_INPUT_DEV_y
    未设置# CONFIG_SND_OSSEMUL
    CONFIG_SND_PCM_TIMER=y
    未设置# CONFIG_SND_HRTIMER
    未设置# CONFIG_SND_DYNAMIC
    CONFIG_SND_SUPPING_OLD_API=y
    CONFIG_SND_PROC_FS=y
    CONFIG_Snd_verbose_procfgs=y
    未设置# CONFIG_SND_VERSE_PRINTK
    未设置# CONFIG_SND_DEBUG
    未设置# CONFIG_SND_SEQUENCER_D
    CONFIG_SND_DRIVERS=y
    未设置# CONFIG_SND_Dummid
    未设置# CONFIG_SND_ALOOP
    未设置# CONFIG_SND_MTPAV
    未设置# CONFIG_SND_SERIAL_U16550
    未设置# CONFIG_SND_MPU401
    编号
    # HD 音频
    编号
    CONFIG_SND_HDA_PREALLOC_SIZE=64
    未设置# CONFIG_SND_ARM
    未设置# CONFIG_SND_SPI
    CONFIG_SND_USB=y
    未设置# CONFIG_SND_USB_AUDIO
    未设置# CONFIG_SND_USB_UA101
    未设置# CONFIG_SND_USB_CAIAR
    未设置# CONFIG_SND_USB_6FIRE
    未设置# CONFIG_SND_USB_HIFACE
    未设置# CONFIG_SND_BCD2000
    未设置# CONFIG_SND_USB_POD
    未设置# CONFIG_SND_USB_PODHD
    未设置# CONFIG_SND_USB_TONEPORT
    未设置# CONFIG_SND_USB_VARIAX
    CONFIG_SND_SOC=y
    CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
    未设置# CONFIG_SND_SOC_AMD_ACP
    未设置# CONFIG_SND_ATMEL_SOC
    # CONFIG_SND_DESIGWARE_I2S 未设置
    编号
    用于 Freescale CPU 的# SoC 音频
    编号
    编号
    # Freescale CPU 的通用 SoC 音频选项:
    编号
    未设置# CONFIG_SND_SOC_FSL_ASRC
    未设置# CONFIG_SND_SOC_FSL_SAI
    # CONFIG_SND_SOC_FSL_SSI 未设置
    # CONFIG_SND_SOC_FSL_SPDIF 未设置
    # CONFIG_SND_SOC_FSL_ESAI 未设置
    未设置# CONFIG_SND_SOC_IMX_AUDMUX
    未设置# CONFIG_SND_I2S_HI6210_I2S
    未设置# CONFIG_SND_SOC_IMG
    编号
    # STMicroelectronics STM32 SOC 音频支持
    编号
    编号
    #德州仪器 SoC 的音频支持
    编号
    CONFIG_SND_SOC_TI_EDMA_PCM=y
    CONFIG_SND_SOC_TI_SDMA_PCM=y
    编号
    #德州仪器 DAI 支持:
    编号
    CONFIG_SND_SOC_Davinci_MCASP=y
    未设置# CONFIG_SND_SOC_OMAP_McBSP
    编号
    #为采用德州仪器 SoC 的电路板提供音频支持
    编号
    CONFIG_SND_SOC_OMAP_HDMI=y
    未设置# CONFIG_SND_SOC_XTFPGA_I2S
    # CONFIG_ZX_TDM 未设置
    CONFIG_SND_SOC_I2C_AND_SPI=y
    编号
    #编解码器驱动程序
    编号
    # CONFIG_SND_SOC_AC97_CODEC 未设置
    未设置# CONFIG_SND_SOC_ADAU1701
    未设置# CONFIG_SND_SOC_ADA1761_I2C
    未设置# CONFIG_SND_SOC_ADA1761_SPI
    未设置# CONFIG_SND_SOC_ADA7002
    未设置# CONFIG_SND_SOC_AK4104
    未设置# CONFIG_SND_SOC_AK4458
    未设置# CONFIG_SND_SOC_AK4554
    未设置# CONFIG_SND_SOC_AK4613
    未设置# CONFIG_SND_SOC_AK4642
    未设置# CONFIG_SND_SOC_AK5386
    未设置# CONFIG_SND_SOC_AK5558
    未设置# CONFIG_SND_SOC_ALC5623
    未设置# CONFIG_SND_SOC_BD28623
    # CONFIG_SND_SOC_BT_SCO 未设置
    未设置# CONFIG_SND_SOC_CPCAP
    未设置# CONFIG_SND_SOC_CS35L32
    未设置# CONFIG_SND_SOC_CS35L33
    未设置# CONFIG_SND_SOC_CS35L34
    未设置# CONFIG_SND_SOC_CS35L35
    未设置# CONFIG_SND_SOC_CS42L42
    未设置# CONFIG_SND_SOC_CS42L51_I2C
    未设置# CONFIG_SND_SOC_CS42L52
    未设置# CONFIG_SND_SOC_CS42L56
    未设置# CONFIG_SND_SOC_CS42L73
    未设置# CONFIG_SND_SOC_CS4265
    未设置# CONFIG_SND_SOC_CS4270
    # CONFIG_SND_SOC_CS4271_I2C 未设置
    # CONFIG_SND_SOC_CS4271_SPI 未设置
    未设置# CONFIG_SND_SOC_CS42XX8_I2C
    未设置# CONFIG_SND_SOC_CS43130
    未设置# CONFIG_SND_SOC_CS4349
    未设置# CONFIG_SND_SOC_CS53L30
    CONFIG_SND_SOC_HDMI_CODEC = y
    未设置# CONFIG_SND_SOC_ES7134
    未设置# CONFIG_SND_SOC_ES7241
    未设置# CONFIG_SND_SOC_ES8316
    未设置# CONFIG_SND_SOC_ES8328_I2C
    未设置# CONFIG_SND_SOC_ES8328_SPI
    未设置# CONFIG_SND_SOC_GTM601
    未设置# CONFIG_SND_SOC_Inno_RK3036
    未设置# CONFIG_SND_SOC_MAX98504
    未设置# CONFIG_SND_SOC_MAX9867
    # CONFIG_SND_SOC_MAX98927未设置
    未设置# CONFIG_SND_SOC_MAX98373
    未设置# CONFIG_SND_SOC_MAX9860
    未设置# CONFIG_SND_SOC_MSM8916_WCD_ANALOG
    未设置# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL
    未设置# CONFIG_SND_SOC_PCM1681
    未设置# CONFIG_SND_SOC_PCM1789_I2C
    未设置# CONFIG_SND_SOC_PCM179X_I2C
    未设置# CONFIG_SND_SOC_PCM179X_SPI
    未设置# CONFIG_SND_SOC_PCM186X_I2C
    未设置# CONFIG_SND_SOC_PCM186X_SPI
    未设置# CONFIG_SND_SOC_PCM3168A_I2C
    未设置# CONFIG_SND_SOC_PCM3168A_SPI
    未设置# CONFIG_SND_SOC_PCM512x_I2C
    未设置# CONFIG_SND_SOC_PCM512x_SPI
    未设置# CONFIG_SND_SOC_RT5616
    未设置# CONFIG_SND_SOC_RT5631
    未设置# CONFIG_SND_SOC_SGTL5000
    未设置# CONFIG_SND_SOC_SIMPLE_MOAUL放大 器
    # CONFIG_SND_SOC_SiRF_AUDIO_CODEC 未设置
    未设置# CONFIG_SND_SOC_SPDIF
    未设置# CONFIG_SND_SOC_SSM2305
    未设置# CONFIG_SND_SOC_SSM2602_SPI
    未设置# CONFIG_SND_SOC_SSM2602_I2C
    未设置# CONFIG_SND_SOC_SSM4567
    未设置# CONFIG_SND_SOC_STA32X
    未设置# CONFIG_SND_SOC_STA350
    未设置# CONFIG_SND_SOC_STI_SAS
    未设置# CONFIG_SND_SOC_TAS2552
    未设置# CONFIG_SND_SOC_TAS5086
    未设置# CONFIG_SND_SOC_TAS571X
    未设置# CONFIG_SND_SOC_TAS5720
    未设置# CONFIG_SND_SOC_TAS6424
    # CONFIG_SND_SOC_TDA7419未设置
    未设置# CONFIG_SND_SOC_TFA9879
    未设置# CONFIG_SND_SOC_TLV320AIC23_I2C
    未设置# CONFIG_SND_SOC_TLV320AIC23_SPI
    未设置# CONFIG_SND_SOC_TLV320AIC31XX
    未设置# CONFIG_SND_SOC_TLV320AIC32X4_I2C
    未设置# CONFIG_SND_SOC_TLV320AIC32X4_SPI
    CONFIG_SND_SOC_TLV320AIC3X=y
    未设置# CONFIG_SND_SOC_TS3A227E
    未设置# CONFIG_SND_SOC_TSCS42XX
    未设置# CONFIG_SND_SOC_TSCS454
    # CONFIG_SND_SOC_WM8510未设置
    # CONFIG_SND_SOC_WM8523未设置
    # CONFIG_SND_SOC_WM8524未设置
    # CONFIG_SND_SOC_WM8580未设置
    # CONFIG_SND_SOC_WM8711未设置
    # CONFIG_SND_SOC_WM8728未设置
    # CONFIG_SND_SOC_WM8731未设置
    # CONFIG_SND_SOC_WM8737未设置
    # CONFIG_SND_SOC_WM8741未设置
    # CONFIG_SND_SOC_WM8750未设置
    # CONFIG_SND_SOC_WM8753未设置
    # CONFIG_SND_SOC_WM8770未设置
    # CONFIG_SND_SOC_WM8776未设置
    # CONFIG_SND_SOC_WM8782未设置
    # CONFIG_SND_SOC_WM8804_I2C 未设置
    # CONFIG_SND_SOC_WM8804_SPI 未设置
    # CONFIG_SND_SOC_WM8903未设置
    # CONFIG_SND_SOC_WM8960未设置
    # CONFIG_SND_SOC_WM8962未设置
    # CONFIG_SND_SOC_WM8974未设置
    # CONFIG_SND_SOC_WM8978未设置
    # CONFIG_SND_SOC_WM8985未设置
    未设置# CONFIG_SND_SOC_ZX_AUD96P22
    未设置# CONFIG_SND_SOC_MAX9759
    未设置# CONFIG_SND_SOC_MT6351
    # CONFIG_SND_SOC_NAU8540未设置
    # CONFIG_SND_SOC_NAU8810未设置
    # CONFIG_SND_SOC_NAU8824未设置
    未设置# CONFIG_SND_SOC_TPA6130A2
    CONFIG_SND_SIMPLE_CARD_UTILS=y
    CONFIG_SND_SIMPLE_CARD=y
    # CONFIG_SND_SIMPLE_SCU_CARD 未设置
    未设置# CONFIG_SND_AUDIO_graph_CARD
    # CONFIG_SND_AUDIO_graph_SCU_CARD 未设置
    编号
    # HID 支持
    编号
    CONFIG_HID=y
    未设置# CONFIG_HID_BATTERY_Strength
    # CONFIG_HIDRAW 未设置
    # CONFIG_UHID 未设置
    CONFIG_HID_generic=y
    编号
    #专用 HID 驱动器
    编号
    # CONFIG_HID_A4TECH 未设置
    # CONFIG_HID_ACCUCH 未设置
    未设置# CONFIG_HID_ACRUX
    未设置# CONFIG_HID_Apple
    # CONFIG_HID_APPLEIR 未设置
    # CONFIG_HID_AUREAL 未设置
    # CONFIG_HID_Belkin 未设置
    未设置# CONFIG_HID_BETOP_FF
    未设置# CONFIG_HID_CHERRY
    # CONFIG_HID_Chicony 未设置
    # CONFIG_HID_Cougar 未设置
    # CONFIG_HID_PRODYKEYS 未设置
    未设置# CONFIG_HID_CMEDIA
    未设置# CONFIG_HID_Cypress
    # CONFIG_HID_DRAGONRISE 未设置
    未设置# CONFIG_HID_EMS_FF
    # CONFIG_HID_ELECOM 未设置
    # CONFIG_HID_ELO 未设置
    # CONFIG_HID_EZKEY 未设置
    # CONFIG_HID_GEMBIRD 未设置
    # CONFIG_HID_GFRM 未设置
    # CONFIG_HID_HOLTEK 未设置
    # CONFIG_HID_KEYTOUCH 未设置
    # CONFIG_HID_Kee 未设置
    # CONFIG_HID_UCLOGIC 未设置
    # CONFIG_HID_WALTOP 未设置
    未设置# CONFIG_HID_GYRAID
    # CONFIG_HID_ICADE 未设置
    未设置# CONFIG_HID_ITE
    # CONFIG_HID_Jabra 未设置
    # CONFIG_HID_TWINHAN 未设置
    未设置# CONFIG_HID_Kensington
    未设置# CONFIG_HID_LCPOWER
    未设置# CONFIG_HID_Lenovo
    未设置# CONFIG_HID_Logitech
    未设置# CONFIG_HID_MAGICMOUSE
    # CONFIG_HID_MAYFLASH 未设置
    # CONFIG_HID_REDRAGON 未设置
    未设置# CONFIG_HID_Microsoft
    # CONFIG_HID_Monterey 未设置
    未设置# CONFIG_HID_MULTITOUCH
    # CONFIG_HID_NTI 未设置
    未设置# CONFIG_HID_NTRIG
    # CONFIG_HID_ORTEK 未设置
    # CONFIG_HID_PANTHERLORD 未置位
    # CONFIG_HID_PENMOUNT 未设置
    # CONFIG_HID_PETALYNX 未设置
    # CONFIG_HID_PICOLCD 未设置
    # CONFIG_HID_Plantronics 未设置
    # CONFIG_HID_PRIMAX 未设置
    # CONFIG_HID_RETRODE 未设置
    # CONFIG_HID_ROCCAT 未设置
    # CONFIG_HID_SAITEK 未设置
    未设置# CONFIG_HID_Samsung
    未设置# CONFIG_HID_SPEEDLINK
    未设置# CONFIG_HID_STEAM
    # CONFIG_HID_SteelSeries 未设置
    未设置# CONFIG_HID_SunPlus
    # CONFIG_HID_RMI 未设置
    # CONFIG_HID_GREENASIA 未设置
    # CONFIG_HID_SMARTJOYPLUS 未设置
    # CONFIG_HID_TiVo 未设置
    # CONFIG_HID_TOPSEED 未设置
    # CONFIG_HID_THRUSTMASTER 未设置
    # CONFIG_HID_UDRAW_PS3未设置
    # CONFIG_HID_WACOM 未设置
    未设置# CONFIG_HID_XINMO
    # CONFIG_HID_ZEROPLUS 未设置
    # CONFIG_HID_ZYDACRON 未被置位
    未设置# CONFIG_HID_SENSOR_HUB
    未设置# CONFIG_HID_ALPS
    编号
    # USB HID 支持
    编号
    CONFIG_USB_HID=y
    # CONFIG_HID_PID 未设置
    未设置# CONFIG_USB_HIDDEV
    编号
    # I2C HID 支持
    编号
    # CONFIG_I2C_HID 未设置
    CONFIG_USB_OHCCI_LOW_ENDIAN=y
    CONFIG_USB_support=y
    CONFIG_USB_common=y
    CONFIG_USB_ARCH_HASE_HCD=y
    CONFIG_USB=y
    CONFIG_USB_Announce_new_devices=y
    编号
    #其他 USB 选项
    编号
    CONFIG_USB_DEFAULT_SENCE=y
    未设置# CONFIG_USB_DYNAMIC
    CONFIG_USB_OTG=y
    未设置# CONFIG_USB_OTG_WHITELIST
    未设置# CONFIG_USB_OTG_黑名单 集线器
    未设置# CONFIG_USB_OTG_FSM
    未设置# CONFIG_USB_MON
    # CONFIG_USB_WUSB_CBAF 未设置
    编号
    # USB 主机控制器驱动程序
    编号
    # CONFIG_USB_C67X00_HCD 未设置
    CONFIG_USB_XHCCI_HCD=y
    未设置# CONFIG_USB_XHCCI_DBGCAP
    CONFIG_USB_XHCCI_PLANAIN=y
    CONFIG_USB_EHCI_HCD=y
    # CONFIG_USB_EHCI_ROOT_HUD_TT 未设置
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    未设置# CONFIG_USB_EHCI_HCD_PLAND
    # CONFIG_USB_OXU210HP_HCD 未设置
    未设置# CONFIG_USB_ISP116X_HCD
    # CONFIG_USB_FOTG210_HCD 未设置
    未设置# CONFIG_USB_MAX3421_HCD
    CONFIG_USB_OHCCI_HCD=y
    未设置# CONFIG_USB_OHCCI_HCD_PLAND
    未设置# CONFIG_USB_SL811_HCD
    未设置# CONFIG_USB_R8A66597_HCD
    未设置# CONFIG_USB_HCD_TEST_MODE
    编号
    # USB Device Class 驱动程序
    编号
    未设置# CONFIG_USB_ACM
    未设置# CONFIG_USB_printer
    未设置# CONFIG_USB_WDM
    # CONFIG_USB_TMC 未设置
    编号
    #注:USB_storage 取决于 SCSI、但 BLK_DEV_SD 可能
    编号
    编号
    也需要#;有关更多信息、请参阅 USB_storage 帮助
    编号
    CONFIG_USB_STORAGE=y
    未设置# CONFIG_USB_STORAGE_DEBUG
    未设置# CONFIG_USB_STORAGE_Realtek
    未设置# CONFIG_USB_STORAGE_DATAAB
    未设置# CONFIG_USB_STORAGE_FREECOM
    未设置# CONFIG_USB_STORAGE_ISD200
    未设置# CONFIG_USB_STORAGE_USBAT
    未设置# CONFIG_USB_STORAGE_SDDR09
    未设置# CONFIG_USB_STORAGE_SDDR55
    未设置# CONFIG_USB_STORAGE_JUMPHOT
    未设置# CONFIG_USB_STORAGE_ALAUDA
    未设置# CONFIG_USB_STORAGE_OneTouch
    未设置# CONFIG_USB_STORAGE_Karma
    # CONFIG_USB_STORAGE_Cypress_ATACB 未设置
    未设置# CONFIG_USB_STORAGE_ENE_UB6250
    CONFIG_USB_UAS=y
    编号
    # USB 成像设备
    编号
    未设置# CONFIG_USB_MDC800
    未设置# CONFIG_USB_Microtek
    未设置# CONFIG_USBIP_CORE
    # CONFIG_USB_CDNS3未设置
    未设置# CONFIG_USB_MUSB_HDRC
    CONFIG_USB_DWC3=y
    CONFIG_USB_DWC3_HOST=y
    编号
    #平台胶合驱动程序支持
    编号
    CONFIG_USB_DWC3_OMAP=y
    CONFIG_USB_DWC3_of_simple=y
    未设置# CONFIG_USB_DWC2
    未设置# CONFIG_USB_CHIPIDEA
    CONFIG_USB_ISP1760=y
    CONFIG_USB_ISP1760_HCD=y
    CONFIG_USB_ISP1760_HOST_Role=y
    编号
    # USB 端口驱动程序
    编号
    未设置# CONFIG_USB_serial
    编号
    # USB 其他驱动程序
    编号
    # CONFIG_USB_EMI62未设置
    # CONFIG_USB_EMI26未设置
    未设置# CONFIG_USB_ADUTUX
    未设置# CONFIG_USB_SEVSEG
    未设置# CONFIG_USB_RIO500
    未设置# CONFIG_USB_LEGOTOWER
    未设置# CONFIG_USB_LCD
    # CONFIG_USB_Cypress_CY7C63未设置
    # CONFIG_USB_CYTHERM 未设置
    未设置# CONFIG_USB_IDMOUSE
    未设置# CONFIG_USB_FTDI_ELAN
    # CONFIG_USB_APPLEDISPLAY 未设置
    未设置# CONFIG_USB_SISUSBVGA
    未设置# CONFIG_USB_LD
    未设置# CONFIG_USB_TRANCEVIBRATOR
    未设置# CONFIG_USB_IOWARRIOR
    未设置# CONFIG_USB_TEST
    未设置# CONFIG_USB_EHSET_TEST_PLETONG
    未设置# CONFIG_USB_ISIGHTFW
    未设置# CONFIG_USB_YUREX
    未设置# CONFIG_USB_EZUSB_FX2
    # CONFIG_USB_HUD_USB251XB 未设置
    CONFIG_USB_HSIC_USB3503=y
    未设置# CONFIG_USB_HSIC_USB4604
    未设置# CONFIG_USB_LINK_LAYER_TEST
    # CONFIG_USB_CHAOSKEY 未设置
    编号
    # USB 物理层驱动程序
    编号
    CONFIG_USB_PHY=y
    # CONFIG_NOP_USB_XCEIV 未设置
    CONFIG_USB_GPIO_VBUS=y
    CONFIG_USB_ISP1301=y
    未设置# CONFIG_USB_ULPI
    未设置# CONFIG_USB_Gadget
    未设置# CONFIG_TYPEC
    未设置# CONFIG_USB_Role_switch
    未设置# CONFIG_USB_ULPI_BUS
    未设置# CONFIG_UWB
    CONFIG_MMC=y
    CONFIG_PWRSEQ_EMMC=y
    CONFIG_PWRSEQ_SIMPLE = y
    CONFIG_MMC_BLOC=y
    CONFIG_MMC_BLOCK_未成年人= 16
    未设置# CONFIG_SDIO_UART
    未设置# CONFIG_MMC_TEST
    编号
    MMC/SD/SDIO 主机控制器驱动程序
    编号
    未设置# CONFIG_MMC_DEBUG
    CONFIG_MMC_SDHCI=y
    CONFIG_MMC_SDHCI_IO_accessors=y
    CONFIG_MMC_SDHCI_pltfm=y
    CONFIG_MMC_SDHCI_of_ARASAN=y
    CONFIG_MMC_SDHCI_of_AT91=y
    未设置# CONFIG_MMC_SDHCI_TO_DWCMHC
    未设置# CONFIG_MMC_SDHCI_Cadence
    # CONFIG_MMC_SDHCI_F_SDH30未设置
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP-Hs=y
    未设置# CONFIG_MMC_SPI
    未设置# CONFIG_MMC_DW
    未设置# CONFIG_MMC_VUB300
    未设置# CONFIG_MMC_USHC
    # CONFIG_MMC_USDHI6ROL0未设置
    CONFIG_MMC_CQHCI=y
    未设置# CONFIG_MMC_MTK
    # CONFIG_MMC_SDHCI_Xenon 未设置
    CONFIG_MMC_SDHCI_OMAP-y
    CONFIG_MMC_SDHCI_AM654=y
    未设置# CONFIG_Memstick
    未设置# CONFIG_NEW _LED
    未设置# CONFIG_accessibility
    未设置# CONFIG_InfiniBand
    CONFIG_EDAC_Atom_Scrub = y
    CONFIG_EDAC_support=y
    CONFIG_EDAC=y
    CONFIG_EDAC_LEGAC_SYSFS=y
    未设置# CONFIG_EDAC_DEBUG
    CONFIG_EDAC_TI=y
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTSYS=y
    CONFIG_RTC_HCTSYS_DEVICE_="rtc0"
    # CONFIG_RTC_SYSTOHC 未设置
    CONFIG_RTC_DEBUG=y
    CONFIG_RTC_NVMEM=y
    编号
    RTC 接口
    编号
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV_y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL 未设置
    未设置# CONFIG_RTC_DRV_TEST
    编号
    I2C RTC 驱动器
    编号
    # CONFIG_RTC_DRV_ABB5ZES3未设置
    # CONFIG_RTC_DRV_ABX80X 未设置
    未设置# CONFIG_RTC_DRV_DS1307
    未设置# CONFIG_RTC_DRV_DS1374
    未设置# CONFIG_RTC_DRV_DS1672
    # CONFIG_RTC_DRV_HYM8563未设置
    未设置# CONFIG_RTC_DRV_MAX6900
    未设置# CONFIG_RTC_DRV_RS5C372
    # CONFIG_RTC_DRV_ISL1208未设置
    # CONFIG_RTC_DRV_ISL12022未设置
    # CONFIG_RTC_DRV_ISL12026未设置
    # CONFIG_RTC_DRV_X1205未设置
    # CONFIG_RTC_DRV_PCF8523未设置
    # CONFIG_RTC_DRV_PCF85063未设置
    # CONFIG_RTC_DRV_PCF85363未设置
    # CONFIG_RTC_DRV_PCF8563未设置
    未设置# CONFIG_RTC_DRV_PCF8583
    # CONFIG_RTC_DRV_M41T80未设置
    # CONFIG_RTC_DRV_BQ32K 未设置
    未设置# CONFIG_RTC_DRV_PALMAS
    # CONFIG_RTC_DRV_TPS6586X 未设置
    未设置# CONFIG_RTC_DRV_TPS65910
    # CONFIG_RTC_DRV_S35390A 未设置
    # CONFIG_RTC_DRV_FM3130未设置
    # CONFIG_RTC_DRV_RX8010未设置
    # CONFIG_RTC_DRV_RX8581未设置
    # CONFIG_RTC_DRV_RX8025未设置
    # CONFIG_RTC_DRV_EM3027未设置
    未设置# CONFIG_RTC_DRV_RV8803
    编号
    # SPI RTC 驱动器
    编号
    # CONFIG_RTC_DRV_M41T93未设置
    # CONFIG_RTC_DRV_M41T94未设置
    未设置# CONFIG_RTC_DRV_DS1302
    未设置# CONFIG_RTC_DRV_DS1305
    未设置# CONFIG_RTC_DRV_DS1343
    未设置# CONFIG_RTC_DRV_DS1347
    # CONFIG_RTC_DRV_DS1390未设置
    # CONFIG_RTC_DRV_MAX6916未设置
    未设置# CONFIG_RTC_DRV_R9701
    # CONFIG_RTC_DRV_RX4581未设置
    # CONFIG_RTC_DRV_RX6110未设置
    # CONFIG_RTC_DRV_RS5C348未设置
    未设置# CONFIG_RTC_DRV_MAX6902
    # CONFIG_RTC_DRV_PCF2123未设置
    未设置# CONFIG_RTC_DRV_MCP795
    CONFIG_RTC_I2C_AND_SPI=y
    编号
    # SPI 和 I2C RTC 驱动器
    编号
    未设置# CONFIG_RTC_DRV_DS3232
    # CONFIG_RTC_DRV_PCF2127未设置
    未设置# CONFIG_RTC_DRV_RV3029C2
    编号
    #平台 RTC 驱动程序
    编号
    未设置# CONFIG_RTC_DRV_CMOS
    未设置# CONFIG_RTC_DRV_DS1286
    未设置# CONFIG_RTC_DRV_DS1511
    未设置# CONFIG_RTC_DRV_DS1553
    未设置# CONFIG_RTC_DRV_DS1685_family
    未设置# CONFIG_RTC_DRV_DS1742
    未设置# CONFIG_RTC_DRV_DS2404
    未设置# CONFIG_RTC_DRV_EFI
    # CONFIG_RTC_DRV_STK17TA8未设置
    # CONFIG_RTC_DRV_M48T86未设置
    # CONFIG_RTC_DRV_M48T35未设置
    # CONFIG_RTC_DRV_M48T59未设置
    # CONFIG_RTC_DRV_MSM6242未设置
    未设置# CONFIG_RTC_DRV_BQ4802
    # CONFIG_RTC_DRV_RP5C01未设置
    未设置# CONFIG_RTC_DRV_V3020
    # CONFIG_RTC_DRV_ZYNQMP 未设置
    编号
    #个 CPU RTC 驱动程序
    编号
    未设置# CONFIG_RTC_DRV_OMAP
    # CONFIG_RTC_DRV_FTRTC010未设置
    未设置# CONFIG_RTC_DRV_SNVS
    未设置# CONFIG_RTC_DRV_R7301
    # CONFIG_RTC_DRV_CPCAP 未设置
    编号
    # HID 传感器 RTC 驱动器
    编号
    # CONFIG_RTC_DRV_HID_SENSOR_TIME 未设置
    CONFIG_DMADEVICES=y
    未设置# CONFIG_DMADEVICES_DEBUG
    编号
    # DMA 器件
    编号
    CONFIG_DMA_ENGINER=y
    CONFIG_DMA_virtual_channels=y
    CONFIG_DMA_of=y
    # CONFIG_Altera_MSGDMA 未设置
    未设置# CONFIG_DW_AXI_DMAC
    CONFIG_FSL_EDMA=y
    未设置# CONFIG_Intel_IDMA64
    # CONFIG_NBPFAXI_DMA 未设置
    未设置# CONFIG_QCOM_HIDMA_Mgmt
    CONFIG_DW_DMAC_CORE=y
    CONFIG_DW_DMAC=y
    CONFIG_TI_CPPI41=y
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_DMA_crossbar=y
    编号
    # DMA 客户端
    编号
    未设置# CONFIG_ASYNC_TX_DMA
    # CONFIG_DMATEST 未设置
    编号
    # DMABUF 选项
    编号
    CONFIG_SYNC_FILE=y
    未设置# CONFIG_SW_SYNC
    # CONFIG_AUXDISPLAY 未设置
    CONFIG_UIO=y
    CONFIG_UIO_PDRV_GENIRQ=y
    # CONFIG_UIO_DMEM_GENIRQ 未设置
    未设置# CONFIG_UIO_PRUSS
    未设置# CONFIG_VFIO
    未设置# CONFIG_virt_drivers
    CONFIG_virtiio=y
    CONFIG_virtio_menu=y
    # CONFIG_virtio_气球 未设置
    未设置# CONFIG_virtio_input
    CONFIG_virtio_MMIO=y
    未设置# CONFIG_virtio_MMIO_CMDLINE_DEVICES
    编号
    # Microsoft Hyper-V 来宾支持
    编号
    CONFIG_STACTION=y
    未设置# CONFIG_COMEDI
    未设置# CONFIG_RTLLIB
    # CONFIG_R8712U 未设置
    编号
    # IIO 分段驱动程序
    编号
    编号
    #加速计
    编号
    未设置# CONFIG_ADIS16203
    # CONFIG_ADIS16240未设置
    编号
    #模数转换器
    编号
    未设置# CONFIG_AD7606
    未设置# CONFIG_AD7780
    未设置# CONFIG_AD7816
    未设置# CONFIG_AD7192
    未设置# CONFIG_AD7280
    编号
    #模拟数字双向转换器
    编号
    # CONFIG_ADT7316未设置
    编号
    #电容数字转换器
    编号
    未设置# CONFIG_AD7150
    未设置# CONFIG_AD7152
    未设置# CONFIG_AD7746
    编号
    #直接数字合成
    编号
    未设置# CONFIG_AD9832
    未设置# CONFIG_AD9834
    编号
    #网络分析器、阻抗转换器
    编号
    未设置# CONFIG_AD5933
    编号
    #有源电能计量 IC
    编号
    未设置# CONFIG_ADE7854
    编号
    #旋转变压器数字转换器
    编号
    # CONFIG_AD2S90未设置
    # CONFIG_AD2S1210未设置
    编号
    # Speakup 控制台语音
    编号
    未设置# CONFIG_SPEAKUP
    未设置# CONFIG_STACT_MEDIA
    编号
    # Android
    编号
    未设置# CONFIG_ASHMEM
    CONFIG_ION=y
    CONFIG_ON_SYSTEM_HEAP = y
    CONFIG_ON_CARVEOUT_HEAP = y
    CONFIG_ION_CHUNK_HEAP = y
    # CONFIG_ON_CMA_HEAP 未设置
    CONFIG_ON_TI=y
    CONFIG_STACT_Board=y
    # CONFIG_LTE_GDM724X 未设置
    未设置# CONFIG_GS_FPGABOOT
    # CONFIG_UNISYSPAR 未设置
    未设置# CONFIG_COMON_CLK_XLNX_CLKWZRD
    # CONFIG_FB_TFT 未设置
    未设置# CONFIG_MOST
    未设置# CONFIG_KS7010
    # CONFIG_GRAYBUS 未设置
    未设置# CONFIG_PI433
    未设置# CONFIG_MTK_MMC
    编号
    #垫片设备
    编号
    未设置# CONFIG_XIL_AXIS _FIFO
    未设置# CONFIG_EROFS_FS
    未设置# CONFIG_Goldfish
    未设置# CONFIG_Chrome_platforms
    未设置# CONFIG_Mellanox 平台
    CONFIG_CLKDEV_Lookup = y
    CONFIG_LAY_CLK_PREPARE=y
    CONFIG_COMON_CLK=y
    编号
    #通用时钟框架
    编号
    未设置# CONFIG_CLK_HSDK
    未设置# CONFIG_COMON_CLK_MAX9485
    未设置# CONFIG_COMON_CLK_SI5351
    未设置# CONFIG_COMON_CLK_SI514
    未设置# CONFIG_COMON_CLK_SI544
    未设置# CONFIG_COMON_CLK_SI570
    未设置# CONFIG_COMON_CLK_CDCE706
    未设置# CONFIG_COMON_CLK_CDCE925
    未设置# CONFIG_COMON_CLK_CS2000_CP
    未设置# CONFIG_CLK_QorIQ
    CONFIG_COMON_CLK_PALMAS = y
    未设置# CONFIG_COMON_CLK_PWM
    未设置# CONFIG_COMON_CLK_VC5
    未设置# CONFIG_COMON_CLK_TI_ADPLL
    CONFIG_HWSPINLOCK=y
    CONFIG_HWSPINLOCK_OMAP=y
    编号
    #时钟源驱动器
    编号
    CONFIG_TIMER_of=y
    CONFIG_TIMER_PROBE = y
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_CLKSRC_TI_32K=y
    CONFIG_ARM_ARCH_TIMER=y
    CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
    未设置# CONFIG_ARM_GLOBAL_TIMER
    未设置# CONFIG_ARM_TIMER_SP804
    CONFIG_mailbox=y
    # CONFIG_PLAND_MHU 未设置
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    # CONFIG_Altera_MBOX 未设置
    未设置# CONFIG_MAILBOL_TEST
    CONFIG_IOMMU_API=y
    CONFIG_IOMMU_support=y
    编号
    #通用 IOMMU 可页面支持
    编号
    未设置# CONFIG_IOMMU_IO_PGTABLE_LPAE
    未设置# CONFIG_IOMMU_IO_PGTABLE_ARMV7S
    未设置# CONFIG_IOMMU_DebugFS
    未设置# CONFIG_IOMMU_DEFAULT_passthrough
    CONFIG_OF_IOMMU=y
    CONFIG_OMAP_IOMMU=y
    CONFIG_OMAP_IOMMU_DEBUG=y
    未设置# CONFIG_ARM_SMMU
    编号
    # Remoteproc 驱动程序
    编号
    CONFIG_REMOTEPROC=m
    CONFIG_OMAP_REMOTEPROC=m
    CONFIG_OMAP_REMOTEPROC_Watchdog=y
    编号
    # Rpmsg 驱动程序
    编号
    CONFIG_RPMSG=y
    # CONFIG_RPMSG_CHAR 未设置
    # CONFIG_RPMSG_QCOM_GRING_RPM 未设置
    CONFIG_RPMSG_virtio=m
    CONFIG_RPMSG_RPC=m
    编号
    # Rpmsg 虚拟设备驱动程序
    编号
    CONFIG_RPMSG_KDRV=y
    CONFIG_RPMSG_KDRV_DISPLAY=y
    CONFIG_RPMSG_KDRV_ETH_SWITCH=m
    # CONFIG_SOUNDWIRE 未设置
    编号
    # SOC (片上系统)专用驱动程序
    编号
    编号
    # AMLOGIC SoC 驱动程序
    编号
    编号
    # Broadcom SoC 驱动程序
    编号
    # CONFIG_SOC_BRCMSTB 未设置
    编号
    # NXP/Freescale QorIQ SoC 驱动程序
    编号
    编号
    # i.MX SoC 驱动程序
    编号
    编号
    # Qualcomm SoC 驱动程序
    编号
    CONFIG_SOC_TI=y
    未设置# CONFIG_TI_PRUSS
    编号
    Xilinx SoC 驱动程序
    编号
    未设置# CONFIG_Xilinx VCU
    CONFIG_PM_DEVFREQ=y
    编号
    # DEVFREQ 调量器
    编号
    CONFIG_DEVFREQ_GOV_SIMPLE_OnDemand=y
    未设置# CONFIG_DEVFREQ_GOV_performance
    # CONFIG_DEVFREQ_GOV_POWERSAVE 未设置
    # CONFIG_DEVFREQ_GOV_userspace 未设置
    # CONFIG_DEVFREQ_GOV_PASSIVE 未设置
    编号
    # DEVFREQ 驱动器
    编号
    未设置# CONFIG_PM_DEVFREQ_EVENT
    CONFIG_EXTCON=y
    编号
    # Extcon 设备驱动程序
    编号
    # CONFIG_EXTCON_ADC_JACK 未设置
    # CONFIG_EXTCON_GPIO 未设置
    # CONFIG_EXTCON_MAX3355未设置
    CONFIG_EXTCON_PALMAS = y
    # CONFIG_EXTCON_RT8973A 未设置
    # CONFIG_EXTCON_SM5502未设置
    CONFIG_EXTCON_USB_GPIO=y
    CONFIG_MEMORY = y
    # CONFIG_TI_EMIF 未设置
    CONFIG_OMAP_GPMC=y
    未设置# CONFIG_OMAP-GPMC_DEBUG
    CONFIG_IIO=y
    CONFIG_IIO_buffer=y
    未设置# CONFIG_IIO_buffer_CB
    未设置# CONFIG_IIO_buffer_HW_consumer
    CONFIG_IIO_KFIFO_BUF=y
    CONFIG_IIO_Trigged_buffer=y
    CONFIG_IIO_CONFIGFS=y
    CONFIG_IIO_TRIGG=y
    CONFIG_IIO_Consumer_per_TRIGG=2
    未设置# CONFIG_IIO_SW_DEVICE
    CONFIG_IIO_SW_TRIGGER=y
    编号
    #加速计
    编号
    # CONFIG_ADIS16201未设置
    # CONFIG_ADIS16209未设置
    未设置# CONFIG_ADXL345_I2C
    未设置# CONFIG_ADXL345_SPI
    未设置# CONFIG_BMA180
    未设置# CONFIG_BMA220
    # CONFIG_BMC150_ACCEL 未设置
    未设置# CONFIG_DA280
    未设置# CONFIG_DA311
    # CONFIG_DMARD06未设置
    # CONFIG_DMARD09未设置
    # CONFIG_DMARD10未设置
    未设置# CONFIG_IIO_CROS_EC_ACCEL_LEGACK
    未设置# CONFIG_IIO_ST_ACCEL_3AXIS
    # CONFIG_KXSD9未设置
    # CONFIG_KXCJK1013未设置
    未设置# CONFIG_MC3230
    未设置# CONFIG_MMA7455_I2C
    未设置# CONFIG_MMA7455_SPI
    # CONFIG_MMA7660未设置
    未设置# CONFIG_MMA8452
    未设置# CONFIG_MMA9551
    未设置# CONFIG_MMA9553
    未设置# CONFIG_MXC4005
    未设置# CONFIG_MXC6255
    未设置# CONFIG_SCA3000
    # CONFIG_STK8312未设置
    # CONFIG_STK8BA50未设置
    编号
    #模数转换器
    编号
    未设置# CONFIG_AD7266
    未设置# CONFIG_AD7291
    未设置# CONFIG_AD7298
    未设置# CONFIG_AD7476
    未设置# CONFIG_AD7766
    未设置# CONFIG_AD7791
    未设置# CONFIG_AD7793
    未设置# CONFIG_AD7887
    未设置# CONFIG_AD7923
    # CONFIG_AD799X 未设置
    未设置# CONFIG_CC10001_ADC
    # CONFIG_CPCAP_ADC 未设置
    未设置# CONFIG_ENBOL_DETECTOR
    未设置# CONFIG_HI8435
    # CONFIG_HX711未设置
    未设置# CONFIG_INA2XX_ADC
    未设置# CONFIG_LTC2471
    未设置# CONFIG_LTC2485
    未设置# CONFIG_LTC2497
    # CONFIG_MAX1027未设置
    # CONFIG_MAX11100未设置
    # CONFIG_MAX1118未设置
    # CONFIG_MAX1363未设置
    # CONFIG_MAX9611未设置
    未设置# CONFIG_MCP320X
    未设置# CONFIG_MCP3422
    # CONFIG_NAU7802未设置
    未设置# CONFIG_PALMAS GPADC
    # CONFIG_QCOM_SPMI_IADC 未设置
    # CONFIG_QCOM_SPMI_VADC 未设置
    未设置# CONFIG_SD_ADC_MODULator
    未设置# CONFIG_TI_ADC081C
    未设置# CONFIG_TI_ADC0832
    # CONFIG_TI_ADC084S021未设置
    未设置# CONFIG_TI_ADC12138
    # CONFIG_TI_ADC108S102未设置
    # CONFIG_TI_ADC128S052未设置
    未设置# CONFIG_TI_ADC161S626
    # CONFIG_TI_ADS1015未设置
    未设置# CONFIG_TI_ADS7950
    # CONFIG_TI_ADS8688未设置
    未设置# CONFIG_TI_TLC4541
    未设置# CONFIG_VF610_ADC
    编号
    #模拟前端
    编号
    未设置# CONFIG_IIO_重新 扫描
    编号
    #个放大器
    编号
    未设置# CONFIG_AD8366
    编号
    #化学传感器
    编号
    未设置# CONFIG_ATLAS PH_SENSOR
    # CONFIG_BME680未设置
    # CONFIG_CCS811未设置
    未设置# CONFIG_IAQCORE
    未设置# CONFIG_VZ89X
    编号
    # HID 传感器 IIO 常见
    编号
    编号
    # SSP 传感器常见
    编号
    # CONFIG_IIO_SSP_SENSORHUB 未设置
    编号
    #计数器
    编号
    编号
    #数模转换器
    编号
    未设置# CONFIG_AD5064
    # CONFIG_AD5360未设置
    未设置# CONFIG_AD5380
    未设置# CONFIG_AD5421
    未设置# CONFIG_AD5446
    未设置# CONFIG_AD5449
    未设置# CONFIG_AD5592R
    未设置# CONFIG_AD5593R
    未设置# CONFIG_AD5504
    未设置# CONFIG_AD5624R_SPI
    未设置# CONFIG_LTC2632
    未设置# CONFIG_AD5668_SPI
    未设置# CONFIG_AD596_I2C
    未设置# CONFIG_AD5755
    未设置# CONFIG_AD5758
    未设置# CONFIG_AD5761
    未设置# CONFIG_AD5764
    未设置# CONFIG_AD5791
    未设置# CONFIG_AD7303
    未设置# CONFIG_AD8801
    # CONFIG_DPOT_DAC 未设置
    未设置# CONFIG_DS4424
    未设置# CONFIG_M62332
    未设置# CONFIG_MAX517
    # CONFIG_MAX5821未设置
    未设置# CONFIG_MCP4725
    未设置# CONFIG_MCP4922
    # CONFIG_TI_DAC082S085未设置
    # CONFIG_TI_DAC5571未设置
    未设置# CONFIG_VF610_DAC
    编号
    # IIO 虚拟驱动程序
    编号
    编号
    #频率合成器 DDS/PLL
    编号
    编号
    #时钟发生器/分配
    编号
    未设置# CONFIG_AD9523
    编号
    #锁相环(PLL)频率合成器
    编号
    未设置# CONFIG_ADF4350
    编号
    #数字回转仪传感器
    编号
    # CONFIG_ADIS16080未设置
    # CONFIG_ADIS16130未设置
    # CONFIG_ADIS16136未设置
    # CONFIG_ADIS16260未设置
    # CONFIG_ADXRS450未设置
    未设置# CONFIG_BMG160
    CONFIG_MPU3050=y
    CONFIG_MPU3050_I2C=y
    # CONFIG_IIO_ST_GYRO_3AXIS 未设置
    未设置# CONFIG_ITG3200
    编号
    #健康传感器
    编号
    编号
    #心率监护仪
    编号
    未设置# CONFIG_AFE4403
    未设置# CONFIG_AFE4404
    # CONFIG_MAX30100未设置
    # CONFIG_MAX30102未设置
    编号
    湿度传感器
    编号
    未设置# CONFIG_AM2315
    # CONFIG_DHT11未设置
    # CONFIG_HDC100X 未设置
    # CONFIG_HTS221未设置
    未设置# CONFIG_HTU21
    未设置# CONFIG_SI7005
    # CONFIG_SI7020未设置
    编号
    #初始测量单位
    编号
    # CONFIG_ADIS16400未设置
    # CONFIG_ADIS16480未设置
    未设置# CONFIG_BMI160_I2C
    # CONFIG_BMI160_SPI 未设置
    未设置# CONFIG_TMX61
    未设置# CONFIG_INV_MPU6050_I2C
    未设置# CONFIG_INV_MPU6050_SPI
    未设置# CONFIG_IIO_ST_LSM6DSX
    编号
    #光传感器
    编号
    未设置# CONFIG_ADJD_S311
    未设置# CONFIG_AL3320A
    未设置# CONFIG_APDS9300
    未设置# CONFIG_APDS9960
    未设置# CONFIG_BH1750
    未设置# CONFIG_BH1780
    未设置# CONFIG_CM32181
    未设置# CONFIG_CM3232
    未设置# CONFIG_CM3323
    未设置# CONFIG_CM3605
    未设置# CONFIG_CM36651
    # CONFIG_GP2AP020A00F 未设置
    CONFIG_SENSORS_ISL29018=y
    CONFIG_SENSORS_ISL29028=y
    未设置# CONFIG_ISL29125
    # CONFIG_JSA1212未设置
    未设置# CONFIG_RPR0521
    未设置# CONFIG_LTR501
    未设置# CONFIG_LV0104CS
    未设置# CONFIG_MAX44000
    未设置# CONFIG_OPT3001
    未设置# CONFIG_PA12203001
    未设置# CONFIG_SI1133
    未设置# CONFIG_SI1145
    # CONFIG_STK3310未设置
    # CONFIG_ST_UVIS25未设置
    未设置# CONFIG_TCS3414
    未设置# CONFIG_TCS3472
    未设置# CONFIG_SENSORS_TSL2563
    未设置# CONFIG_TSL2583
    未设置# CONFIG_TSL2772
    未设置# CONFIG_TSL4531
    未设置# CONFIG_US5182D
    未设置# CONFIG_VCNL4000
    未设置# CONFIG_VEML6070
    # CONFIG_VL6180未设置
    未设置# CONFIG_ZOPT2201
    编号
    #磁力计传感器
    编号
    未设置# CONFIG_AK8974
    CONFIG_AK8975=y
    未设置# CONFIG_AK09911
    未设置# CONFIG_BMC150_MAGN_I2C
    未设置# CONFIG_BMC150_MAGN_SPI
    未设置# CONFIG_MAG3110
    未设置# CONFIG_MMC35240
    未设置# CONFIG_IIO_ST_MAGN_3AXIS
    未设置# CONFIG_SENSORS_HMC5843_I2C
    未设置# CONFIG_SENSORS_HMC5843_SPI
    编号
    #多路复用器
    编号
    未设置# CONFIG_IIO_MUX
    编号
    #倾角计传感器
    编号
    编号
    #触发器-独立
    编号
    CONFIG_IIO_HRTIME_TRIGG=y
    未设置# CONFIG_IIO_INTERRUPT_TRIGGER
    未设置# CONFIG_IIO_TIGHTLOOP_TRIGGER
    未设置# CONFIG_IIO_SYSFS_TRIGGER
    编号
    #数字电位器
    编号
    未设置# CONFIG_AD5272
    未设置# CONFIG_DS1803
    未设置# CONFIG_MAX5481
    未设置# CONFIG_MAX5487
    未设置# CONFIG_MCP4018
    未设置# CONFIG_MCP4131
    未设置# CONFIG_MCP4531
    未设置# CONFIG_TPL0102
    编号
    #数字电位器
    编号
    未设置# CONFIG_LMP91000
    编号
    #压力传感器
    编号
    未设置# CONFIG_ABP060MG
    未设置# CONFIG_BMP280
    未设置# CONFIG_HP03
    未设置# CONFIG_MPL115_I2C
    未设置# CONFIG_MPL115_SPI
    未设置# CONFIG_MPL3115
    未设置# CONFIG_MS5611
    未设置# CONFIG_MS5637
    未设置# CONFIG_IIO_ST_PRESS
    未设置# CONFIG_T5403
    # CONFIG_HP206C 未设置
    未设置# CONFIG_ZPA2326
    编号
    #照明传感器
    编号
    未设置# CONFIG_AS3935
    编号
    #接近和距离传感器
    编号
    未设置# CONFIG_ISL29501
    未设置# CONFIG_LIDAR_Lite_V2
    未设置# CONFIG_RFD77402
    未设置# CONFIG_SRF04
    未设置# CONFIG_SX9500
    # CONFIG_SRF08未设置
    编号
    #旋转变压器数字转换器
    编号
    未设置# CONFIG_AD2S1200
    编号
    #温度传感器
    编号
    未设置# CONFIG_Maxim_THUATE
    # CONFIG_MLX90614未设置
    # CONFIG_MLX90632未设置
    未设置# CONFIG_TMP006
    未设置# CONFIG_TMP007
    未设置# CONFIG_TSYS01
    未设置# CONFIG_TSYS02D
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    未设置# CONFIG_PWM_FSL_FTM
    未设置# CONFIG_PWM_OMAP-DMTIMER
    # CONFIG_PWM_PCA9685未设置
    未设置# CONFIG_PWM_TIECAP
    # CONFIG_PWM_TIEHRPWM 未设置
    编号
    # IRQ 芯片支持
    编号
    CONFIG_IRQCHIP=y
    CONFIG_ARM_GIC=y
    CONFIG_ARM_GIC_MAX_NR=1
    CONFIG_OMAP_IRQCHIP=y
    CONFIG_IRQ_crossbar=y
    未设置# CONFIG_IPACK_BUS
    CONFIG_RESET_CONTROLLER=y
    CONFIG_RESET_TI_SYSCON=y
    未设置# CONFIG_FMC
    编号
    # PHY 子系统
    编号
    CONFIG_GENERIC_PHY=y
    # CONFIG_BCM_BON_USB2_PHY 未设置
    CONFIG_PHY_cadence_DP=y
    CONFIG_PHY_cadence_Sierra = y
    # CONFIG_PHY_PXA_28NM_HIC 未设置
    # CONFIG_PHY_PXA_28NM_USB2未设置
    未设置# CONFIG_PHY_CPCAP_USB
    # CONFIG_PHY_MAPPHONE_MDM6600未设置
    未设置# CONFIG_PHY_DM816X_USB
    CONFIG_OMAP_CONTRAL_PHY=y
    CONFIG_OMAP_USB2=y
    CONFIG_TI_PIPE3=y
    未设置# CONFIG_POWERCAP
    未设置# CONFIG_MCB
    编号
    #性能监视器支持
    编号
    # CONFIG_ARM_CCI_PMU 未设置
    未设置# CONFIG_ARM_CCN
    CONFIG_ARM_PMU=y
    CONFIG_RAS=y
    编号
    # Android
    编号
    CONFIG_Android=y
    未设置# CONFIG_Android_binder_IPC
    未设置# CONFIG_LIBNVDIMM
    未设置# CONFIG_DAX
    CONFIG_NVMEM=y
    编号
    #硬件跟踪支持
    编号
    未设置# CONFIG_STM
    未设置# CONFIG_Intel_TH
    未设置# CONFIG_FPGA
    未设置# CONFIG_FSI
    CONFIG_TEE=y
    编号
    #个 T 形驱动器
    编号
    CONFIG_OPTEE=y
    CONFIG_OPTEE_SHM_NUM_PRIV_PAGE=1
    CONFIG_PM_OPP=y
    未设置# CONFIG_SIRX
    未设置# CONFIG_SLIMBUS
    CONFIG_ARCH_AIT=y
    未设置# CONFIG_ATP_B4MK
    CONFIG_ATP_B5MK=y
    编号
    # I2C 支持
    编号
    # CONFIG_RTC_ISL1218未设置
    未设置# CONFIG_RTC_MULTI_IDT1338
    未设置# CONFIG_RTC_DS1307_PDR
    CONFIG_RTC_RA8900=y
    CONFIG_SND_SOC_WM8974_AIT=y
    CONFIG_AIT_DCI=y
    CONFIG_DCI_STREAME_BUFFER_SIZE=40
    CONFIG_DCI_MDEC_STREAME_BUFFER_SIZE=20
    # CONFIG_AIT_DCI_SKUTERD 未设置
    编号
    #其他驱动程序
    编号
    CONFIG_TM1K_TS=y
    CONFIG_exFAT_FS=y
    CONFIG_exFAT_DEFAULT_CTION=437
    CONFIG_exFAT_DEFAULT_IOCHARSET="utf8"
    CONFIG_exFAT_virtual_xattr=y
    CONFIG_exFAT_virtual_xattr_SELinux_label="u:object_r:exFAT:s0"
    未设置# CONFIG_exFAT_DEBUG
    未设置# CONFIG_exFAT_UEVENT
    编号
    # ATP TI 驱动程序
    编号
    CONFIG_ATP_TI_HDMI_AUDIO=y
    CONFIG_EMLOG=y
    CONFIG_EMLOG_BUFFER_SIZE=32
    CONFIG_EMLOG_DEVICE_COUNT=2
    未设置# CONFIG_TI_FASTBOOT
    编号
    #文件系统
    编号
    CONFIG_DCache 字访问= y
    CONFIG_FS_iomap=y
    # CONFIG_EXT2_FS 未设置
    # CONFIG_EXT3_FS 未设置
    CONFIG_EXT4_FS=y
    CONFIG_EXT4_USE_for_EXT2=y
    CONFIG_EXT4_FS_POSIX_ACL=y
    CONFIG_EXT4_FS_SECURITY=y
    未设置# CONFIG_EXT4_encryption
    未设置# CONFIG_EXT4_DEBUG
    CONFIG_JBD2=y
    未设置# CONFIG_JBD2_DEBUG
    CONFIG_FS_MBCACHE=y
    未设置# CONFIG_REISERFS_FS
    未设置# CONFIG_JFS_FS
    未设置# CONFIG_XFS_FS
    # CONFIG_GFS2_FS 未设置
    # CONFIG_OCFS2_FS 未设置
    未设置# CONFIG_BTRFS_FS
    # CONFIG_NILFS2_FS 未设置
    # CONFIG_F2FS_FS 未设置
    CONFIG_FS_POSIX_ACL=y
    CONFIG_exportfs=y
    未设置# CONFIG_EXPORTfs_BLOCK_OPS
    CONFIG_FILE_LOCIN=y
    CONFIG_CONFILE_LOCK_LOCIN=y
    未设置# CONFIG_FS_encryption
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY 未设置
    未设置# CONFIG_Quota
    CONFIG_AUTOFS4_FS=y
    CONFIG_AutoFS_FS=y
    CONFIG_FUSE_FS=y
    未设置# CONFIG_Cuse
    未设置# CONFIG_OVERLAY_FS
    编号
    #高速缓存
    编号
    # CONFIG_FSCACHE 未设置
    编号
    # CD-ROM/DVD 文件系统
    编号
    未设置# CONFIG_ISO9660_FS
    # CONFIG_UDF_FS 未设置
    编号
    # DOS/FAT/NT 文件系统
    编号
    CONFIG_FAT_FS=y
    未设置# CONFIG_MSDOS_FS
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CTION=437
    CONFIG_FAT_DEFAULT_IOCHARSET="ISO8859-1"
    未设置# CONFIG_FAT_DEFAULT_UTF8
    CONFIG_NTFS_FS=y
    未设置# CONFIG_NTFS_DEBUG
    未设置# CONFIG_NTFS_RW
    编号
    #伪文件系统
    编号
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR = y
    CONFIG_PROC_children = y
    CONFIG_KERNFS=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    CONFIG_TMPFS_xattr=y
    # CONFIG_HUGETLBFS 未设置
    CONFIG_MEMF_CREATE = y
    CONFIG_CONFIGFS_FS=y
    未设置# CONFIG_EFIVAR_FS
    CONFIG_MISC_filesystems=y
    未设置# CONFIG_ORANGEFS_FS
    未设置# CONFIG_ADFS_FS
    未设置# CONFIG_AFFS_FS
    # CONFIG_ECRYPT_FS 未设置
    未设置# CONFIG_HFS_FS
    # CONFIG_HFSPLUS_FS 未设置
    未设置# CONFIG_BEFS_FS
    未设置# CONFIG_BFS_FS
    未设置# CONFIG_EFS_FS
    CONFIG_CRAMFS=y
    CONFIG_CRAMFS_BLOCKDEV=y
    CONFIG_SQUASHFS=y
    CONFIG_SQUASHFS_FILE_CACHE=y
    # CONFIG_SQUASHFS_FILE_DIRECT 未设置
    CONFIG_SQUASHFS_DECOMP_SINGLE=y
    # CONFIG_SQUASHFS_DECOMP_MULTI 未设置
    未设置# CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU
    # CONFIG_SQUASHFS_xattr 未设置
    CONFIG_SQUASHFS_ZLIB=y
    # CONFIG_SQUASHFS_LZ4未设置
    CONFIG_SQUASHFS_LZO=y
    CONFIG_SQUASHFS_XZ=y
    # CONFIG_SQUASHFS_ZSTD 未设置
    # CONFIG_SQUASHFS_4K_DEVBLK_SIZE 未设置
    未设置# CONFIG_SQUASHFS_INDED
    CONFIG_SQUASHFS_片段_cache_size=3
    未设置# CONFIG_VxFS_FS
    # CONFIG_MINIX_FS 未设置
    未设置# CONFIG_OMFS_FS
    未设置# CONFIG_HPFS_FS
    未设置# CONFIG_QNX4FS_FS
    未设置# CONFIG_QNX6FS_FS
    未设置# CONFIG_ROMFS_FS
    CONFIG_PSTORE=y
    CONFIG_PSTORE_FLOG_COMFOR=y
    # CONFIG_PSTORE_LZO_COMpress 未设置
    # CONFIG_PSTORE_LZ4_COMpress 未设置
    # CONFIG_PSTORE_LZ4HC_COMpress 未设置
    未设置# CONFIG_PSTORE_842_COMpress
    # CONFIG_PSTORE_ZSTD_COMpress 未设置
    CONFIG_PSTORE_COMFOR=y
    CONFIG_PSTORE_DEFLATE_COMFOR_DEFAULT=y
    CONFIG_PSTORE_COMFOR_DEFAULT="放气"
    CONFIG_PSTORE_CONSOLE=y
    CONFIG_PSTORE_PMSG=y
    CONFIG_PSTORE_RAM=y
    # CONFIG_SYSV_FS 未设置
    未设置# CONFIG_UFS_FS
    CONFIG_NETWORK_filesystem=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    未设置# CONFIG_NFS_SWAP
    未设置# CONFIG_NFS_V4_1
    CONFIG_ROOT_NFS=y
    未设置# CONFIG_NFS_USE_LEGACY_DNS
    CONFIG_NFS_USE_kernel_dns=y
    未设置# CONFIG_NFSD
    CONFIG_GRACE_PERIOD=y
    CONFIG_LOCd=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_support=y
    CONFIG_NFS_COMON=y
    CONFIG_SUNPPC=y
    CONFIG_SUNPPC_GSS=y
    未设置# CONFIG_SUNPPC_DEBUG
    未设置# CONFIG_Ceph FS
    未设置# CONFIG_CIFS
    未设置# CONFIG_CODA_FS
    # CONFIG_AFS_FS 未设置
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="ISO8859-1"
    CONFIG_NLS_Cepage_437=y
    未设置# CONFIG_NLS_Cepage_737
    未设置# CONFIG_NLS_Cepage_775
    未设置# CONFIG_NLS_Cepage_850
    未设置# CONFIG_NLS_Cepage_852
    未设置# CONFIG_NLS_Cepage_855
    未设置# CONFIG_NLS_Cepage_857
    未设置# CONFIG_NLS_Cepage_860
    未设置# CONFIG_NLS_Cepage_861
    未设置# CONFIG_NLS_Cepage_862
    未设置# CONFIG_NLS_Cepage_863
    未设置# CONFIG_NLS_Cepage_864
    未设置# CONFIG_NLS_Cepage_865
    未设置# CONFIG_NLS_Cepage_866
    未设置# CONFIG_NLS_Cepage_869
    未设置# CONFIG_NLS_Cepage_936
    未设置# CONFIG_NLS_Cepage_950
    未设置# CONFIG_NLS_Cepage_932
    未设置# CONFIG_NLS_Cepage_949
    未设置# CONFIG_NLS_Cepage_874
    未设置# CONFIG_NLS_ISO8859_8
    未设置# CONFIG_NLS_Cepage_1250
    未设置# CONFIG_NLS_Cepage_1251
    未设置# CONFIG_NLS_ASCII
    CONFIG_NLS_ISO8859_1=y
    未设置# CONFIG_NLS_ISO8859_2
    未设置# CONFIG_NLS_ISO8859_3
    未设置# CONFIG_NLS_ISO8859_4
    未设置# CONFIG_NLS_ISO8859_5
    未设置# CONFIG_NLS_ISO8859_6
    未设置# CONFIG_NLS_ISO8859_7
    未设置# CONFIG_NLS_ISO8859_9
    未设置# CONFIG_NLS_ISO8859_13
    未设置# CONFIG_NLS_ISO8859_14
    未设置# CONFIG_NLS_ISO8859_15
    未设置# CONFIG_NLS_KOI8_R
    # CONFIG_NLS_KOI8_U 未设置
    未设置# CONFIG_NLS_MAC_ROMAN
    未设置# CONFIG_NLS_MAC_Celtic
    未设置# CONFIG_NLS_MAC_CENTEURO
    # CONFIG_NLS_MAC_Croatian 未设置
    未设置# CONFIG_NLS_MAC_Cyrillic
    未设置# CONFIG_NLS_MAC_Gaelic
    未设置# CONFIG_NLS_MAC_Greek
    未设置# CONFIG_NLS_MAC_Iceland
    未设置# CONFIG_NLS_MAC_In纽特
    # CONFIG_NLS_MAC_Romanian 未设置
    未设置# CONFIG_NLS_MAC_土耳其 语
    CONFIG_NLS_UTF8=y
    未设置# CONFIG_DLM
    编号
    #安全选项
    编号
    CONFIG_KEYs=y
    未设置# CONFIG_PERSISTENT_KEYRINGS
    未设置# CONFIG_BIG_KEYs
    未设置# CONFIG_encrypted_keys
    未设置# CONFIG_KEY_DH_operations
    未设置# CONFIG_SECURITY_dmesg_restrict
    # CONFIG_SECURITYFS 未设置
    CONFIG_BUSINCODE_LOADTER=y
    未设置# CONFIG_CONSTD_USERCOPY
    未设置# CONFIG_FORENSE_SOURCE
    # CONFIG_STATUS_USERMODEHELPER 未置1
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_DEFAULT_SECURIT=""
    CONFIG_crypto=y
    编号
    # Crypto 内核或辅助器
    编号
    CONFIG_crypto_ALGAPI=y
    CONFIG_crypto_ALGAPI2=y
    CONFIG_crypto_AEAD=y
    CONFIG_crypto_AEAD2=y
    CONFIG_crypto_BLKCIPHER=y
    CONFIG_crypto_BLKCIPHER2=y
    CONFIG_crypto_hash-y
    CONFIG_crypto_HASH2=y
    CONFIG_crypto_RNG=y
    CONFIG_crypto_RNG2=y
    CONFIG_crypto_RNG_default=y
    CONFIG_crypto_AKCIPHER2=y
    CONFIG_crypto_KPP2=y
    CONFIG_crypto_ACOMP2=y
    未设置# CONFIG_crypto_RSA
    未设置# CONFIG_crypto_dh
    未设置# CONFIG_crypto_ECDH
    CONFIG_crypto_Manager=y
    CONFIG_crypto_Manager2=y
    CONFIG_crypto_user=y
    CONFIG_crypto_Manager_disable_tests=y
    未设置# CONFIG_crypto_GF128MUL
    CONFIG_crypto_NULL=y
    CONFIG_crypto_NUL2=y
    未设置# CONFIG_crypto_PCRYPT
    CONFIG_crypto_workqueue=y
    CONFIG_crypto_CRYPTD=y
    未设置# CONFIG_crypto_MCRYPTD
    CONFIG_crypto_AUTHENC=y
    CONFIG_crypto_test=m
    CONFIG_crypto_SIMD = y
    CONFIG_crypto_engine=y
    编号
    #使用关联数据进行身份验证的加密
    编号
    未设置# CONFIG_crypto_CCM
    未设置# CONFIG_Crypto_GCM
    # CONFIG_crypto_CHACHA20POLY1305未设置
    # CONFIG_Crypto_AEGIS128未设置
    # CONFIG_crypto_AEGIS128L 未设置
    未设置# CONFIG_crypto_AEGIS256
    未设置# CONFIG_crypto_MORUS640
    未设置# CONFIG_crypto_MORUS1280
    CONFIG_crypto_SEQIV=y
    CONFIG_crypto_ECHAINIV=y
    编号
    #块模式
    编号
    CONFIG_crypto_CBC=y
    未设置# CONFIG_crypto_CFB
    CONFIG_crypto_CTR=y
    未设置# CONFIG_crypto_CTS
    CONFIG_crypto_ECB = y
    未设置# CONFIG_crypto_LRW
    未设置# CONFIG_crypto_PCBC
    未设置# CONFIG_crypto_XTS
    # CONFIG_crypto_KEYWRAP 未设置
    编号
    #散列模式
    编号
    未设置# CONFIG_crypto_cmac
    CONFIG_crypto_HMAC=y
    未设置# CONFIG_crypto_XCBC
    未设置# CONFIG_crypto_VMAC
    编号
    #摘要
    编号
    CONFIG_crypto_CRC32C=y
    未设置# CONFIG_crypto_CRC32
    未设置# CONFIG_crypto_CRC10DIF
    未设置# CONFIG_Crypto_GHASH
    未设置# CONFIG_crypto_POLY1305
    未设置# CONFIG_crypto_MD4
    CONFIG_crypto_MD5=y
    未设置# CONFIG_Crypto_Michael_MIC
    未设置# CONFIG_crypto_RMD128
    未设置# CONFIG_crypto_RMD160
    未设置# CONFIG_crypto_RMD256
    未设置# CONFIG_crypto_RMD320
    CONFIG_Crypto SHA1=y
    CONFIG_crypto_SHA256=y
    CONFIG_crypto_SHA512=y
    未设置# CONFIG_crypto_SHA3
    未设置# CONFIG_crypto_SM3
    未设置# CONFIG_Crypto_TGR192
    未设置# CONFIG_crypto_WP512
    编号
    #个 Ciphers
    编号
    CONFIG_crypto_AES=y
    未设置# CONFIG_crypto_AES_TI
    未设置# CONFIG_crypto_ANUBIS
    未设置# CONFIG_Crypto_ARC4
    未设置# CONFIG_crypto_BLOWfish
    未设置# CONFIG_crypto_Camellia
    未设置# CONFIG_Crypto_CAST5
    未设置# CONFIG_crypto_CAST6
    CONFIG_crypto_DES=y
    未设置# CONFIG_crypto_FCRYPT
    未设置# CONFIG_crypto_KHAZAD
    # CONFIG_crypto_SALSA20未设置
    CONFIG_crypto_CHACHA20=y
    未设置# CONFIG_crypto_seed
    未设置# CONFIG_crypto_serpent
    未设置# CONFIG_crypto_SM4
    未设置# CONFIG_crypto_TEa
    未设置# CONFIG_crypto_Twofish
    编号
    #压缩
    编号
    CONFIG_Crypto 放气= y
    未设置# CONFIG_crypto_LZO
    未设置# CONFIG_crypto_842
    未设置# CONFIG_crypto_LZ4
    未设置# CONFIG_crypto_LZ4HC
    未设置# CONFIG_crypto_ZSTD
    编号
    #随机数生成
    编号
    未设置# CONFIG_Crypto_ANSI_CPRNG
    CONFIG_crypto_DRBG_menu=y
    CONFIG_crypto_DRBG_HMAC=y
    未设置# CONFIG_crypto_DRBG_Hash
    未设置# CONFIG_Crypto_DRBG_CTR
    CONFIG_crypto_DRBG=y
    CONFIG_crypto_JITTERENTROPY=y
    CONFIG_crypto_USER_API=y
    CONFIG_crypto_USER_API_hash-y
    CONFIG_crypto_USER_API_SKCIPHER=y
    CONFIG_crypto_USER_API_RNG=y
    CONFIG_crypto_USER_API_AEAD=y
    CONFIG_crypto_hw=y
    CONFIG_crypto_dev_omap=y
    CONFIG_crypto_dev_omap_SHAR=y
    CONFIG_crypto_dev_omap_AES=y
    CONFIG_crypto_dev_omap_DES=y
    CONFIG_crypto_dev_virtiio=m
    未设置# CONFIG_crypto_DEV_CCREE
    未设置# CONFIG_INREGICAL_KEY_TYPE
    编号
    #用于签名检查的证书
    编号
    未设置# CONFIG_SYSTEM_blacklist_keyring
    编号
    #库例程
    编号
    CONFIG_BITREVERSE=y
    CONFIG_WASE_ARCH_BITREVERSE=y
    CONFIG_Rational = y
    CONFIG_GENERIC_STRNCPY_FER_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_GENERIC_PCI_iomap=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    # CONFIG_CRC_CCITT 未设置
    CONFIG_CRC16=y
    # CONFIG_CRC_T10DIF 未设置
    # CONFIG_CRC_ITU_T 未设置
    CONFIG_CRC32=y
    未设置# CONFIG_CRC32_selftest
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4未设置
    # CONFIG_CRC32_SARWATE 未设置
    未设置# CONFIG_CRC32_BIT
    未设置# CONFIG_CRC64
    未设置# CONFIG_CRC4
    未设置# CONFIG_CRC7
    CONFIG_LIBCRC32C=y
    未设置# CONFIG_CRC8
    # CONFIG_RANDOM32_selftest 未设置
    CONFIG_ZLIB_FLIN=y
    CONFIG_ZLIB_DELL=y
    CONFIG_LZO_decompress=y
    CONFIG_LZ4_decompress=y
    CONFIG_XZ_DEC=y
    CONFIG_XZ_DEC_X86=y
    CONFIG_XZ_DEC_PowerPC=y
    CONFIG_XZ_DEC_IA64=y
    CONFIG_XZ_DEC_ARM=y
    CONFIG_XZ_DEC_ARMTHUMB=y
    CONFIG_XZ_DEC_SPARC=y
    CONFIG_XZ_DEC_BCJ=y
    未设置# CONFIG_XZ_DEC_TEST
    CONFIG_decompress_GZIP = y
    CONFIG_decompress_Bzip2=y
    CONFIG_decompress_LZMA=y
    CONFIG_decompress_XZ=y
    CONFIG_decompress_LZO=y
    CONFIG_decompress_LZ4=y
    CONFIG_general_allocator=y
    CONFIG_RED_SOLOON=y
    CONFIG_RED_SOLOON_ENC8=y
    CONFIG_RED_SOLOON_DEC8=y
    CONFIG_TEXTSEARCH = y
    CONFIG_TEXTSEARCH_KMP=y
    CONFIG_TEXTSEARCH_BM=y
    CONFIG_TEXTSEARCH_FSM=y
    CONFIG_associate_array=y
    CONFIG_WAS_IOMEM=y
    CONFIG_FAS_IOPORT_MAP=y
    CONFIG_has _DMA=y
    CONFIG_Need_DMA_MAP_State=y
    CONFIG_ARCH_DMA_ADDR_T_64位= y
    CONFIG_have 通用_DMA 相干= y
    CONFIG_SGL_ALLOC=y
    CONFIG_CPU_RMAP=y
    CONFIG_DQL=y
    CONFIG_GLOB=y
    未设置# CONFIG_GLOB_selftest
    CONFIG_NLATTR=y
    未设置# CONFIG_CORDIC
    未设置# CONFIG_DDR
    未设置# CONFIG_IRQ_POLL
    CONFIG_LIBFDT=y
    CONFIG_OID_REGANCE=y
    CONFIG_UCS2_STRING=y
    CONFIG_SG_SPLIT=y
    CONFIG_SG_POOL=y
    CONFIG_ARCH_H_ASG_CHAIN=y
    CONFIG_SBITMAP = y
    未设置# CONFIG_STRING_selftest
    编号
    #内核黑客攻击
    编号
    编号
    # printk 和 dmesg 选项
    编号
    未设置# CONFIG_PRINTK_TIME
    CONFIG_CONTOK_LogLevel 默认值=7
    CONFIG_CONTOLE_LogLevel 安静= 4
    CONFIG_MESSAGE_LogLevel 默认值=4
    # CONFIG_BOOT_PRINTK_DELAY 未设置
    未设置# CONFIG_DYNAMIC_DEBUG
    编号
    #编译时检查和编译器选项
    编号
    未设置# CONFIG_DEBUG_INFO
    CONFIG_ENABLE_MUST_CHECK_y
    CONFIG_FRAME_WARN=4096
    未设置# CONFIG_STrip_ASM_Syms
    未设置# CONFIG_readable_asm
    未设置# CONFIG_UNUSE_symbols
    未设置# CONFIG_PAGE_Owner
    CONFIG_DEBUG_FS=y
    未设置# CONFIG_HEADER_CHECK
    未设置# CONFIG_DEBUG_SECTION 不匹配
    CONFIG_SECTION 不匹配_WARN_ONLY = y
    CONFIG_FRAME_POINTER=y
    未设置# CONFIG_DEBUG_FORCE_WEAK PER_CPU
    CONFIG_魔术_SYSRQ=y
    CONFIG_魔术_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_魔术_SYSRQ_SERIAL=y
    CONFIG_DEBUG_kernel=y
    编号
    #内存调试
    编号
    未设置# CONFIG_PAGE_EXTENSION
    # CONFIG_DEBUG_PAGEALLOC 未设置
    未设置# CONFIG_PAGE_T毒害
    未设置# CONFIG_DEBUG_RODATA_TEST
    未设置# CONFIG_DEBUG_objects
    未设置# CONFIG_slub_stats
    CONFIG_WASE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK 未设置
    未设置# CONFIG_DEBUG_STACK_USAGE
    未设置# CONFIG_DEBUG_VM
    CONFIG_ARCH_USE_DEBUG_virtual=y
    未设置# CONFIG_DEBUG_virtual
    未设置# CONFIG_DEBUG_MEMORY_INIT
    未设置# CONFIG_DEBUG_PER_CPU_MAPPS
    未设置# CONFIG_DEBUG_HIGHMEM
    CONFIG_ARCH_USE_KCOV=y
    CONFIG_CC_has _SANCOV_TRACE_PC=y
    未设置# CONFIG_KCOV
    # CONFIG_DEBUG_SHIRQ 未设置
    编号
    #调试锁定和挂起
    编号
    未设置# CONFIG_SOFTLOCKUP_DETECTOR
    未设置# CONFIG_DETACT_HON_TASK
    未设置# CONFIG_WQ_Watchdog
    未设置# CONFIG_RAM_ON_Oops
    CONFIG_RAM_ON_OOPS_VALUE = 0
    CONFIG_RAM_TIMEOUT=0
    CONFIG_SCHED_DEBUG=y
    CONFIG_SCHED_INFO=y
    CONFIG_SCHEDSTATS=y
    未设置# CONFIG_SCHED_STACK_END_CHECK
    未设置# CONFIG_DEBUG_TIMEGing
    未设置# CONFIG_DEBUG_PRETER
    编号
    #锁定调试(自旋锁、互斥锁等)
    编号
    CONFIG_LOCK_debuging_support=y
    未设置# CONFIG_FICE_LOCing
    未设置# CONFIG_LOCK_STAT
    未设置# CONFIG_DEBUG_RT_互 斥量
    # CONFIG_DEBUG_SPINLOCK 未设置
    未设置# CONFIG_DEBUG_互 斥量
    未设置# CONFIG_DEBUG_WW_MUTEX_SLOWPATH
    未设置# CONFIG_DEBUG_RWSEMS
    未设置# CONFIG_DEBUG_LOCK_ALLOC
    # CONFIG_DEBUG_Atom_SLEEP 未设置
    未设置# CONFIG_DEBUG_LOCK_API_SEARTESTS
    未设置# CONFIG_LOCK_Torture_test
    未设置# CONFIG_WW_mutex_selftest
    未设置# CONFIG_stacktrace
    未设置# CONFIG_WARN_ALL 未查看随机
    # CONFIG_DEBUG_KOBJECT 未设置
    # CONFIG_DEBUGERBOSE 未设置
    未设置# CONFIG_DEBUG_LIST
    未设置# CONFIG_DEBUG_PI_LIST
    未设置# CONFIG_DEBUG_SG
    未设置# CONFIG_DEBUG_NOTIACers
    未设置# CONFIG_DEBUG_凭 据
    编号
    # RCU 调试
    编号
    未设置# CONFIG_RCU_PERF_TEST
    未设置# CONFIG_RCU_Torture_test
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    未设置# CONFIG_RCU_TRACE
    未设置# CONFIG_RCU_EQS_DEBUG
    # CONFIG_DEBUG_WQ_FORCE_RR_CPU 未设置
    未设置# CONFIG_DEBUG_BLOCK EXT_DEVT
    未设置# CONFIG_CPU_HOTPLUG_STATE_CONTROL
    未设置# CONFIG_NOVICER_ERROR_INMOATION
    未设置# CONFIG_FAULT_INMODATION
    # CONFIG_LATENCYTOP 未设置
    CONFIG_WASE_FUNCTION_Tracer = y
    CONFIG_WASE_FUNCTION_graph_Tracer = y
    CONFIG_WASE_DYNAL_FTRACE=y
    CONFIG_WASE_DYNAL_FTRACE_WIT_REGs=y
    CONFIG_WASE_FTRACE_MCOUNT_RECODE=y
    CONFIG_WASE_SYSCall_TRACEPOINTS=y
    CONFIG_WASE_C_RECORDMCOUNT=y
    CONFIG_REPORTING_SUPPINS=y
    未设置# CONFIG_FTRACE
    未设置# CONFIG_DMA_API_DEBUG
    CONFIG_RUNTIME_TESTing_menu=y
    未设置# CONFIG_LKDTM
    未设置# CONFIG_TEST_LIST_Sort
    未设置# CONFIG_TEST_Sort
    未设置# CONFIG_backtrace_self_test
    未设置# CONFIG_RBTREE_TEST
    未设置# CONFIG_INTERVE_TRE_TEST
    未设置# CONFIG_PERCPU_TEST
    # CONFIG_ATOMIC64_selftest 未设置
    # CONFIG_TEST_HEXDUMP 未设置
    未设置# CONFIG_TEST_STRING_ALEVENSER
    # CONFIG_TEST_KSTRTOX 未设置
    未设置# CONFIG_TEST_printf
    未设置# CONFIG_TEST_BITMAP
    未设置# CONFIG_TEST_BITFIELD
    未设置# CONFIG_TEST_UUID
    未设置# CONFIG_TEST_OVERflow
    未设置# CONFIG_TEST_RHASHTABLE
    未设置# CONFIG_TEST_HASH
    未设置# CONFIG_TEST_IDA
    未设置# CONFIG_TEST_LKM
    未设置# CONFIG_TEST_USER_COPY
    未设置# CONFIG_TEST_BPF
    未设置# CONFIG_FIND_BIT_Benchmark
    未设置# CONFIG_TEST_firmware
    未设置# CONFIG_TEST_SYSCTL
    未设置# CONFIG_TEST_UDELAY
    未设置# CONFIG_TEST_STATUS_KEYs
    未设置# CONFIG_TEST_KMOD
    未设置# CONFIG_MEMTEST
    未设置# CONFIG_Bug_ON_DATA_corruption
    未设置# CONFIG_SAples
    CONFIG_WASE_ARCH_KGDB=y
    # CONFIG_KGDB 未设置
    未设置# CONFIG_UBSAN
    CONFIG_ARCH_HAS_DEVMEM_IS_allowed=y
    未设置# CONFIG_STRICT_DEVMEM
    未设置# CONFIG_ARM_PTDUMP_DebugFS
    # CONFIG_DEBUG_WX 未设置
    未设置# CONFIG_ARM_DELETATE
    未设置# CONFIG_DEBUG_USER
    CONFIG_DEBUG_LL=y
    CONFIG_DEBUG_OMAP2UART1 = y
    未设置# CONFIG_DEBUG_OMAP2UART2
    未设置# CONFIG_DEBUG_OMAP2UART3
    未设置# CONFIG_DEBUG_OMAP3UART3
    未设置# CONFIG_DEBUG_OMAP4UART3
    未设置# CONFIG_DEBUG_OMAP3UART4
    未设置# CONFIG_DEBUG_OMAP4UART4
    未设置# CONFIG_DEBUG_TI81XXUART1
    未设置# CONFIG_DEBUG_TI81XXUART2
    未设置# CONFIG_DEBUG_TI81XXUART3
    未设置# CONFIG_DEBUG_AM33XXUART1
    未设置# CONFIG_DEBUG_Zoom_UART
    未设置# CONFIG_DEBUG_ICEDCC
    未设置# CONFIG_DEBUG_semihosting
    未设置# CONFIG_DEBUG_LL_UART_8250
    # CONFIG_DEBUG_LL_UART_PL01X 未设置
    CONFIG_DEBUG_LL_INCLUDE="debug/825.S"
    CONFIG_DEBUG_UART_8250=y
    CONFIG_DEBUT_UART_PHYS=0x4806a000
    CONFIG_DEBUT_UART_virt=0xfa06a000
    CONFIG_DEBUT_UART_8250_SHIFT=2
    未设置# CONFIG_DEBUT_UART_8250_WORD
    未设置# CONFIG_DEBUT_UART_8250_PALMCHIP
    未设置# CONFIG_DEBUT_UART_8250_FLOG_CONTROL
    未设置# CONFIG_DEBUG_UNCOMpress
    CONFIG_UNcompress_include="调试/uncompress.h"
    CONFIG_EARE_PRINTK_= y
    # CONFIG_PID_IN_CONTEXTIDR 未设置
    # CONFIG_CORESIGHT 未设置
    3. omap_sham.c 日志(将 dev_dbg 更改为 dev_err)
    # cURL https://www.google.co.kr
    OMAP-SHIM 4b101000.sham:init:Digest Size:16
    OMAP-SHIM 4b101000.sham:init:Digest Size:20
    OMAP-SHIM 4b101000.sham:init:Digest Size:28
    OMAP-SHIM 4b101000.sham:init:Digest Size:32
    OMAP-SHIM 4b101000.sham:init:Digest Size:48
    OMAP-SHIM 4b101000.sham:init:Digest Size:64
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=48、bs=128、total=176、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:48
    omap-sham 4b101000.sham:update_req:总计:128、digcnt:0、final:0
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:0、length:128、final:0
    OMAP-SHIM 4b101000.sham:Ctrl:00000009、flags:00040020
    omap-sham 4b101000.sham:omap_sham_don_task:flags=b9
    OMAP-SHIM 4b101000.sham:更新完成:错误:0
    OMAP-SHIM 4b101000.sham:更新:错误:-115、数字:128
    omap-sham 4b101000.sham:exit、错误:-115
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=48、offset=0、bufcnt=48
    OMAP-SHIM 4b101000.sham:处理新请求、op:2、nbytes:0
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:48、final:1.
    omap-sham 4b101000.sham:ctrl:00000011、flags:00050020
    omap-sham 4b101000.sham:omap_sham_don_task:flags=bb
    omap-sham 4b101000.sham:digcnt:176、bufcnt:0
    omap-sham 4b101000.sham:final_req:错误:-115
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=65、bs=128、total=193、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:65
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=66、offset=0、bufcnt=66
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:66、final:1.
    omap-sham 4b101000.sham:digcnt:194、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=32、bs=128、total=160、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:32
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=32、offset=0、bufcnt=32
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:32、final:1.
    omap-sham 4b101000.sham:digcnt:160、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=634、bs=128、total=634、offset=0、bufcnt=0
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:634
    omap-sham 4b101000.sham:update_req:总计:512、digcnt:0、final:0
    omap-sham 4b101000.sham:Xmit_dma:digcnt:0、length:512、final:0
    OMAP-SHIM 4b101000.sham:Ctrl:00000009、flags:00040000
    omap-sham 4b101000.sham:更新:错误:-115、digcnt:512
    omap-sham 4b101000.sham:omap_sham_don_task:flags=29D
    omap-sham 4b101000.sham:omap_sham_don_task:flags=2dd
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=122、offset=0、bufcnt=122
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:512、length:122、final:1.
    omap-sham 4b101000.sham:ctrl:00000011、flags:00050000
    omap-sham 4b101000.sham:digcnt:634、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=70、bs=128、total=198、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:70
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=71、offset=0、bufcnt=71
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:71、final:1.
    omap-sham 4b101000.sham:digcnt:199、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=13、bs=128、total=141、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:13.
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=14、offset=0、bufcnt=14
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:14、final:1.
    omap-sham 4b101000.sham:digcnt:142、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=12、bs=128、total=140、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:12
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=13、offset=0、bufcnt=13
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:13、final:1.
    omap-sham 4b101000.sham:digcnt:141、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=18、bs=128、total=146、offset=0、bufcnt=128
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:18
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=0、bs=128、total=19、offset=0、bufcnt=19
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:128、length:19、final:1.
    omap-sham 4b101000.sham:digcnt:147、bufcnt:0
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=21、bs=128、total=143、offset=0、bufcnt=122
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:21.
    omap-sham 4b101000.sham:update_req:总计:128、digcnt:512、final:0
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:512、length:128、final:0
    omap-sham 4b101000.sham:ctrl:00000001、flags:00040020
    omap-sham 4b101000.sham:更新:错误:-115、数字:640
    omap-sham 4b101000.sham:omap_sham_prepare_request:nbytes=2386、bs=128、total=2401、offset=0、bufcnt=15
    OMAP-SHIM 4b101000.sham:处理新请求、op:1、nbytes:2386.
    omap-sham 4b101000.sham:update_req:总计:2304、digcnt:640、final:0
    OMAP-SHIM 4b101000.sham:Xmit_CPU:digcnt:640、length:2304、final:0
    omap_sham_xmit_cpu:sg miter 失败。
    omap-sham 4b101000.sham:更新:错误:-22、digcnt:2944
    omap-sham 4b101000.sham:exit、错误:-22
    cryptodev:c卷[769](waitfor:294):异步请求出错:-22
    cryptodev:c卷[769](hash-n_crypt:98):CryptoAPI 失败:-22
    cURL:(35) error:02015016: system library:ioctl: Invalid arge.(卷曲:(35)错误:02015016:系统库:ioctl:无效
    编号
    Yusik、您好!
    最新内核上的 OMAP-SHIM 驱动程序有许多修复:
    以上也有其他修复程序。 在主题中搜索 OMAP-SHIM。
    https://marc.info/?l=linux-omap&m=159058228429461&w=2
    这使得 OMAP-SHIM 非常强大。 请告诉我他们是否能为您提供帮助。
    基尔西
    大家好、Keerty。
    感谢您提供相关信息。
    但是、这是 Linux 内核5.x 的补丁
    PROCESSOR_SDK_VISION_03_08_00_00仅提供 Linux 内核4.x (4.19.73)。
    因此、很难应用它们。
    在哪里可以找到 Linux 内核4.x 的修补程序?
    此致。
    Yoesik。
    大家好、Keerty。
    我在 OMAP-shim.c、crypto.h、OMAP-crypto.c 上应用了"加密:OMAP:SHA/AES 修复"系列的补丁
    现在不会出现"omap_sham_xmit_cpu: sg miter failure"错误。
    但会出现以下错误。
    # cURL -k https://www.google.co.kr
    卷曲:(35)错误:1417B07B:SSL 例程:tls_process_cert_verify:错误签名
    以下命令正常。
    # rmmod cryptodev
    cryptotdev:驱动程序已卸载。
    此致。
    Yoesik。
    您好、Yoesik、
    太棒了! 我认为修补程序是直接的端口。
    是否可以再次附加完整的日志文本文件? 请勿复制粘贴整个日志。
    它的滚动时间会更长。
    " 错误:1417B07B:SSL 例程:TLS_PROCESS_CERT_VERIFY:错误签名"似乎是应用程序级错误?
    详细信息?
    -凯尔西
    大家好、Keerty。
    我认为"错误:1417B07B:SSL 例程:TLS_PROCESS_CERT_VERIFY:BAD 签名"是 OMAP 加密引擎的错误。
    我使用以下 openssl 命令进行了测试。
    # openssl s_client -servername www.google.co.kr -connect www.google.co.kr:443 -m
    SG
    我随附了文件 openssl_tls_log.txt 和 openssl_tls_no_cryptodev_log.txt.e2e.ti.com/.../openssl_5F00_tls_5F00_log.txte2e.ti.com/.../openssl_5F00_tls_5F00_no_5F00_cryptodev_5F00_log.txt
    如果 openssl 使用 cryptodev、则会发生"fatal decrype_error"。
    此致。
    Yoesik。
    您好、Yoesik、
    您能否启用驱动程序调试消息并共享日志。 它会有所帮助
    检查驱动程序中的确切故障位置。
    基尔西
    大家好、Keerty。
    我附加了日志文件。
    e2e.ti.com/.../openssl_5F00_tls_5F00_log_5F00_omap_5F00_sham_5F00_debug.txt
    我在 OMAP-SHAN.c 中将 DEV_dbg 更改为 DEV_ERR
    此致。
    Yoesik。
    大家好、Keerty。
    我进行了额外的测试。
    我在 Linux 内核 DTS 文件中添加了以下代码。
    disable_complete (sham);
    它工作正常。
    我认为这只是 OMAP-SHIM 问题、而不是 OMAP-AES、OMAP-DES。
    此致。
    Yoesik。
    您好、Yoesik、
    非常感谢您缩小该范围。 我将在下周再回来。
    为了便于我重现、您能否提及您使用的确切命令?
    -凯尔西
    大家好、Keerty。
    以下是 OpenSSL 命令。
    OpenSSL s_client -connect www.google.com:443 -msg
    如果使用 cURL、
    cURL -kV https://www.google.com
    将出现以下错误。
    解密错误
    此致。
    Yoesik。
    Yoesik、
    我正在尝试使用与 TDA2P 类似的 SoC 的 am574x-idk。
    卷曲输出:
    OpenSSL 输出:
    我使用的是一个具有基于4.19的内核的不同 SDK。
    lsmod | grep sham
    OMAP-SHIM             28672 0
    这是预期的输出吗?
    -凯尔西
    大家好、Keerty。
    是的、它是预期输出。
    但我想检查一下。
    您确定 openssl 是否正在使用 cryptodev 和 OMAP-sham 驱动程序?
    处理器 SDK 中的 OpenSSL 不使用 cryptotdev。
    我再次构建了 openssl。
    此致。
    Yoesik。
    您好、Yoesik、
    我将咨询 OMAP 加密专家、下周初再见。
    基尔西
    您好、Yoesik、
    您使用的 openssl 版本是什么? 我正在尝试重现问题。 我知道失败的命令
    但是、如果您还指导我使用 openssl 版本以及如何确保 openssl 使用 OMAP-sham
    这将非常有帮助。 对长期沉默表示歉意。
    -凯尔西
    大家好、Keerty。
    1.在此处下载 cryptodev。
    github.com/.../cryptodev-linux
    2.构建用于获取 cryptotdev.ko 的 cryptodev。
    3. OpenSSL 版本为1.1.1g,可从此处下载。
    www.openssl.org/.../
    4. OpenSSL 构建
     -tar xvf openssl-1.1.1g.tar.gz
     -CD openssl-1.1.1 g
     -./Configure --cross-compile-prefix=arm-linux-gnueabihf---prefix=$(prefix_path) shared linux-armv4 -March =armv7-a enable-devcryptoeng
      - prefix_path 是 sysroot 用户路径(安装路径)。
     - CFLAGS=-i$(cryptotdev_path)/include make
      - cryptodev_path 是 cryptodev 源路径。
    在使用 openssl 之前、您需要执行"insmod cryptodev.ko"。
    如果您需要更多信息、请回复。
    此致。
    Yoesik。
    您好、Yoesik、
    我使用的是使用 OMAP-SHAM 的 AM57xx SDK。 默认情况下、我已经有 cryptotdev.ko
    AM5xx SDK。 默认情况下具有 openssl 1.1.1b。
    您的 SDK 默认没有 cryptotdev.ko? 为什么不让它被默许?
    Keerhy
    大家好、Keerty。
    我使用的是 PROCESSOR_SDK_VISION_03_08_00_00。
    此 SDK 不包含 cryptotdev.ko。
    我必须使用该 SDK、因为它具有早期启动功能。
    Yoesik。
    您好、Yoesik、
    此调试正在进行、将需要更多时间。 您现在是否可以不使用 cryptotdev
    发生故障的用例有何影响?
    基尔西
    大家好、Keerty。
    是的、我可以。
    我目前正在使用不带 cryptodev 的 openssl。
    当然、我也在等待您的解决方案。
    Yoesik。
    大家好、Keerty。
    是否有任何更新?
    或者您需要更多时间吗?
    在我的附加测试中、TLS 1.1成功、但 TLS 1.2 1.3失败。
    测试命令如下所示。
    TLS 1.1:openssl s_client -connect www.google.com:443 -tls1_1 -debug
    TLS 1.2:openssl s_client -connect www.google.com:443 -tls1_2 -debug
    Yoesik。
    您好、Yoesik、
    专家的更新是、它应该使用具有最新主线的 openssl 1.1
    内核。 4.19已知1.1有问题。 我恐怕修复程序需要更多时间。 抱歉
    进行比较。
    基尔西
    您好、Yoesik、
    我从 OMAP-Crypto 专家那里获得了相关信息。 我们能够根据4.19查看 openssl 1.1的问题
    但遗憾的是、即使是基于最新5.7的内核。 因此、问题出在 openssl 1.1、而不是
    OpenSSL 1.0但 openssl 1.0不再受支持并已弃用。 修复程序不会立即出现
    它不会是一个直接的。 感谢您提出这个问题。 我们将在下一个版本中尝试解决此问题。 目前
    因为您已在不使用 OMAP-SHIM 的情况下使用 openssl。
    感谢您的耐心等待。 您还有其他要检查的内容吗?
    基尔西
    大家好、Keerty。
    感谢您的更新。
    我将等待下一个版本。
    Yoesik。
    您好、Yoesik、
    您能解决这个问题吗?
    基尔西
    您好、Yoesik、
    OMAP-SHIM 驱动程序已有一些新的修复。 我在 tar 中附加这两个修补程序。
    您可以尽可能尝试一下它们、并检查它们是否对您的测试有所帮助? 它们位于顶部
    最新 OMAP-SHIM 主线驱动程序。 这需要一些移植、以防您尝试它们。
    基尔西
    e2e.ti.com/.../sha_2D00_fixes.tar.gz
    大家好、Keerty。
    感谢您的补丁。
    它工作得非常好。
    Yoesik。
    你好,Yoesik,
    很高兴这对我们有所帮助。 关闭此主题。
    基尔西
