[参考译文] TDA4VH-Q1:Linux 原生驱动程序中的四个 SGMII 端口设置
Guru**** 2545620 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1216735/tda4vh-q1-four-sgmii-port-setting-in-linux-native-driver
器件型号:TDA4VH-Q1
主题中讨论的其他器件:TDA4VH
尊敬的 TI:
我们的客户板配置端口如下所示:
serdes1->sgmi1/sgmi2/sgmiii3/sgmi4
serdes2->sgmii5/sgmi6/sgmi7/sgmi8
在 DTS 中、服务1和服务2 REFCLK 默认为内部时钟还是外部时钟?
如何设置内部 REFCLK?
请指导我们如何正确配置 SerDes 端口、谢谢
QSGMII 模式:
// SPDX-License-Identifier: GPL-2.0
 * DT Overlay for CPSW9G in QSGMII mode using J7 Quad Port ETH EXP Add-On Ethernet Card with
 * J7AHP board.
 * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/mux/ti-serdes.h>
#include <dt-bindings/phy/phy-cadence.h>
#include <dt-bindings/phy/phy.h>
#include <dt-bindings/pinctrl/k3.h>
aliases {
	ethernet0 = "/bus@100000/ethernet@c000000/ethernet-ports/port@1";
	ethernet1 = "/bus@100000/ethernet@c000000/ethernet-ports/port@2";
	ethernet2 = "/bus@100000/ethernet@c000000/ethernet-ports/port@3";
	ethernet3 = "/bus@100000/ethernet@c000000/ethernet-ports/port@4";
	ethernet4 = "/bus@100000/ethernet@c000000/ethernet-ports/port@5";
	ethernet5 = "/bus@100000/ethernet@c000000/ethernet-ports/port@6";
	ethernet6 = "/bus@100000/ethernet@c000000/ethernet-ports/port@7";
	ethernet7 = "/bus@100000/ethernet@c000000/ethernet-ports/port@8";
&main_cpsw0 {
	status = "okay";
	pinctrl-names = "default";
	pinctrl-0 = <&mdio_pins_default>;
&main_cpsw0_port1 {
	status = "okay";
	phy-handle = <&cpsw9g_phy0>;
	phy-mode = "qsgmii";
	mac-address = [00 00 00 00 00 00];
	phys = <&phy_gmii_sel_cpsw0 1>, <&serdes1_qsgmii_link>;
	phy-names = "portmode", "serdes-phy";
&main_cpsw0_port2 {
	status = "okay";
	phy-handle = <&cpsw9g_phy1>;
	phys = <&phy_gmii_sel_cpsw0 2>, <&serdes1_qsgmii_link>;
&main_cpsw0_port3 {
	status = "okay";
	phy-handle = <&cpsw9g_phy2>;
	phys = <&phy_gmii_sel_cpsw0 3>, <&serdes1_qsgmii_link>;
&main_cpsw0_port4 {
	status = "okay";
	phy-handle = <&cpsw9g_phy3>;
	phys = <&phy_gmii_sel_cpsw0 4>, <&serdes1_qsgmii_link>;
&main_cpsw0_port5 {
	status = "okay";
	phy-handle = <&cpsw9g_phy4>;
	phys = <&phy_gmii_sel_cpsw0 5>, <&serdes2_qsgmii_link>;
&main_cpsw0_port6 {
	status = "okay";
	phy-handle = <&cpsw9g_phy5>;
	phys = <&phy_gmii_sel_cpsw0 6>, <&serdes2_qsgmii_link>;
&main_cpsw0_port7 {
	status = "okay";
	phy-handle = <&cpsw9g_phy6>;
	phys = <&phy_gmii_sel_cpsw0 7>, <&serdes2_qsgmii_link>;
&main_cpsw0_port8 {
	status = "okay";
	phy-handle = <&cpsw9g_phy7>;
	phys = <&phy_gmii_sel_cpsw0 8>, <&serdes2_qsgmii_link>;
&main_cpsw0_mdio {
	bus_freq = <500000>;  //设置500KB
	#address-cells = <1>;
	#size-cells = <0>;
	cpsw9g_phy0: ethernet-phy@0 {
		reg = <0>;
		compatible = "ethernet-phy-ieee802.3-c22";
		ethphy-mode = "master";
		ethphy-speed = "10000";
	cpsw9g_phy1: ethernet-phy@1 {
		reg = <1>;
	cpsw9g_phy2: ethernet-phy@2 {
		reg = <2>;
		ethphy-speed = "100";
	cpsw9g_phy3: ethernet-phy@3 {
		reg = <3>;
	cpsw9g_phy4: ethernet-phy@4 {
		reg = <4>;
	cpsw9g_phy5: ethernet-phy@5 {
		reg = <5>;
	cpsw9g_phy6: ethernet-phy@6 {
		reg = <6>;
	cpsw9g_phy7: ethernet-phy@7 {
		reg = <7>;
&cpsw9g_virt_mac {
	status = "disabled";
&cpsw9g_virt_maconly {
&main_pmx0 {
	mdio_pins_default: mdio_pins_default {
		pinctrl-single,pins = <
			J784S4_IOPAD(0x05c, PIN_INPUT, 4) /* (AC36) MCASP2_AXR0.MDIO1_MDIO */
			J784S4_IOPAD(0x058, PIN_INPUT, 4) /* (AE37) MCASP2_AFSX.MDIO1_MDC */
&main_r5fss0_core0 {
	firmware-name = "pdk-ipc/ipc_echo_test_mcu2_0_release_strip.xer5f";
&serdes_ln_ctrl {
	idle-states = <J784S4_SERDES0_LANE0_PCIE1_LANE0>, <J784S4_SERDES0_LANE1_PCIE1_LANE1>,
		      <J784S4_SERDES0_LANE2_IP3_UNUSED>, <J784S4_SERDES0_LANE3_USB>,
		      <J784S4_SERDES1_LANE0_QSGMII_LANE3>, <J784S4_SERDES1_LANE1_QSGMII_LANE4>,
		      <J784S4_SERDES1_LANE2_QSGMII_LANE1>, <J784S4_SERDES1_LANE3_QSGMII_LANE2>,
		      <J784S4_SERDES2_LANE0_QSGMII_LANE5>, <J784S4_SERDES2_LANE1_QSGMII_LANE6>,
		      <J784S4_SERDES2_LANE2_QSGMII_LANE7>, <J784S4_SERDES2_LANE3_QSGMII_LANE8>;
&serdes_wiz2 {
	status = "okay";
&serdes_wiz1 {
	status = "okay";
&serdes2 {
	status = "okay";
	serdes2_qsgmii_link: phy@0 {
		reg = <0>;
		cdns,num-lanes = <4>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_QSGMII>;
		resets = <&serdes_wiz2 1>, <&serdes_wiz2 2>, <&serdes_wiz2 3>, <&serdes_wiz2 4>;
&serdes1 {
	status = "okay";
	serdes1_qsgmii_link: phy@0 {
		reg = <0>;
		#phy-cells = <0>;
		resets = <&serdes_wiz1 1>, <&serdes_wiz1 2>, <&serdes_wiz1 3>, <&serdes_wiz1 4>;
SGMII 模式:
 * J7AHP board.
aliases {
&main_cpsw0 {
	status = "okay";
&main_cpsw0_port1 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port2 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port3 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port4 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port5 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port6 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port7 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_port8 {
	status = "okay";
	phy-mode = "sgmii";
&main_cpsw0_mdio {
	#size-cells = <0>;
		reg = <0>;
		reg = <1>;
		reg = <2>;
		reg = <3>;
		reg = <4>;
		reg = <5>;
		reg = <6>;
		reg = <7>;
&cpsw9g_virt_mac {
&main_pmx0 {
&serdes_ln_ctrl {
&serdes_wiz2 {
	status = "okay";
&serdes_wiz1 {
	status = "okay";
&serdes2 {
	status = "okay";
		reg = <0>;
		#phy-cells = <0>;
		cdns,phy-type = <PHY_TYPE_SGMII>;
&serdes1 {
	status = "okay";
		reg = <0>;
		#phy-cells = <0>;
    尊敬的 TI:
    n‘t QSGMII 模式时,可以找到 PHY 链路接通,、但执行 ping IP 地址
    但当我们设置 SGMII 模式时,找不到 eth3/eth4 /eth5/eth6节点,SGMII 模式日志 是:
    错误源代码:
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.153-yocto-standard (oe-user@oe-host) (aarch64-wrs-linux-gcc (GCC) 10.3.0, GNU ld (GNU Binutils) 2.36.1.20210703) #1 SMP PREEMPT Wed Apr 12 05:37:37 UTC 2023
    [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node c71-dma-memory@ab000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ab100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node c71-memory@ab100000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000ffffeffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000abffffff]
    [    0.000000]   node   0: [mem 0x00000000ac000000-0x00000000fffeffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x0000000ffffeffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000ffffeffff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] cma: Reserved 512 MiB at 0x00000000c0000000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 10 pages/cpu s574296 r8192 d72872 u655360
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 523774
    [    0.000000] Kernel command line:  androidboot.hardware=j784s4-evm androidboot.product=J7_EVM androidboot.hwversion=v1_1 androidboot.serialno=315e00000101dcc6 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) androidboot.boot_device_root=mmcblk0 androidboot.verifiedbootstate=orange androidboot.slot_suffix=_a root=PARTUUID=1aa75fea-36be-4992-9da6-a9bf156464b8 androidboot.vbmeta.device=PARTUUID=69d4a052-6df3-4c47-bebc-b7d3b03799be androidboot.vbmeta.avb_version=1.1 androidboot.vbmeta.device_state=unlocked androidboot.vbmeta.hash_alg=sha256 androidboot.vbmeta.size=1152 androidboot.vbmeta.digest=530aef8308de7a0c3eb469e4f120e88902c9189cd31da624a4912f0a2e6161e8 androidboot.veritymode=disabled androidboot.keystore=software androidboot.rebootreason=cold,powerkey androidboot.pm_resetreason=POR
    [    0.000000] Dentry cache hash table entries: 4194304 (order: 9, 33554432 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 2097152 (order: 8, 16777216 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbff0000-0x00000000ffff0000] (64MB)
    [    0.000000] Memory: 32623488K/33554304K available (14400K kernel code, 2252K rwdata, 3712K rodata, 4992K init, 1786K bss, 406528K reserved, 524288K cma-reserved)
    [    0.000000] S
                    [    0.003856] EFI services will not be available.
    [    0.004568] smp: Bringing up secondary CPUs ...
    [    0.013364] Detected PIPT I-cache on CPU1
    [    0.013387] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.013400] GICv3: CPU1: using allocated LPI pending table @0x0000000880320000
    [    0.013440] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.022343] Detected PIPT I-cache on CPU2
    [    0.022366] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.022380] GICv3: CPU2: using allocated LPI pending table @0x0000000880330000
    [    0.022421] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.031322] Detected PIPT I-cache on CPU3
    [    0.031349] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.031363] GICv3: CPU3: using allocated LPI pending table @0x0000000880340000
    [    0.031404] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.040354] Detected PIPT I-cache on CPU4
    [    0.040382] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.040395] GICv3: CPU4: using allocated LPI pending table @0x0000000880350000
    [    0.040437] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.049330] Detected PIPT I-cache on CPU5
    [    0.049358] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.049372] GICv3: CPU5: using allocated LPI pending table @0x0000000880360000
    [    0.049412] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.058293] Detected PIPT I-cache on CPU6
    [    0.058322] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.058335] GICv3: CPU6: using allocated LPI pending table @0x0000000880370000
    [    0.058378] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.067269] Detected PIPT I-cache on CPU7
    [    0.067301] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.067316] GICv3: CPU7: using allocated LPI pending table @0x0000000880380000
    [    0.067355] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.067473] smp: Brought up 1 node, 8 CPUs
    [    0.067570] SMP: Total of 8 processors activated.
    [    0.067578] CPU features: detected: 32-bit EL0 Support
    [    0.067584] CPU features: detected: CRC32 instructions
    [    0.067695] CPU: All CPU(s) started at EL2
    [    0.067757] alternatives: patching kernel code
    [    0.068529] devtmpfs: initialized
    [    0.074691] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.074714] futex hash table entries: 2048 (order: 1, 131072 bytes, linear)
    [    0.075283] pinctrl core: initialized pinctrl subsystem
    [    0.075775] DMI not present or invalid.
    [    0.076058] NET: Registered protocol family 16
    [    0.083624] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.084330] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.085050] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.085114] audit: initializing netlink subsys (disabled)
    [    0.085368] audit: type=2000 audit(0.084:1): state=initialized audit_enabled=0 res=1
    [    0.085740] thermal_sys: Registered thermal governor 'step_wise'
    [    0.086044] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.086271] ASID allocator initialised with 65536 entries
    [    0.113557] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.113573] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.113579] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.189010] raid6: neonx8   gen()   726 MB/s
    [    0.256864] raid6: neonx8   xor()  1089 MB/s
    [    0.325857] raid6: neonx4   gen()   369 MB/s
    [    0.393507] raid6: neonx4   xor()   380 MB/s
    [    0.461808] raid6: neonx2   gen()   375 MB/s
    [    0.529759] raid6: neonx2   xor()   331 MB/s
    [    0.597985] raid6: neault 64
    [    1.483945] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    1.485605] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    1.490295] NFS: Registering the id_resolver key type
    [    1.490343] Key type id_resolver registered
    [    1.490352] Key type id_legacy registered
    [    1.491188] Key type cifs.idmap registered
    [    1.491213] jffs2: version 2.2. (NAND) ÂCopyright 2001-2006 Red Hat, Inc.
    [    1.512278] xor: measuring software checksum speed
    [    1.513561]    8regs           :  7835 MB/sec
    [    1.514686]    32regs          :  8831 MB/sec
    [    1.516831]    arm64_neon      :  4731 MB/sec
    [    1.516842] xor: using function: 32regs (8831 MB/sec)
    [    1.516852] async_tx: api initialized (async)
    [    1.516899] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    1.517074] io scheduler mq-deadline registered
    [    1.517089] io scheduler kyber registered
    [    1.520311] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    1.520610] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    1.522905] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.523012] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.523721] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.535613] brd: module loaded
    [    1.538615] CAN device driver interface
    [    1.539787] usbcore: registered new interface driver asix
    [    1.539834] usbcore: registered new interface driver ax88179_178a
    [    1.539871] usbcore: registered new interface driver cdc_ether
    [    1.539904] usbcore: registered new interface driver net1080
    [    1.539938] usbcore: registered new interface driver cdc_subset
    [    1.539972] usbcore: registered new interface driver zaurus
    [    1.540026] usbcore: registered new interface driver cdc_ncm
    [    1.541451] usbcore: registered new interface driver usb-storage
    [    1.541686] i2c /dev entries driver
    [    1.542890] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
    [    1.543860] sdhci: Secure Digital Host Controller Interface driver
    [    1.543875] sdhci: Copyright(c) Pierre Ossman
    [    1.544143] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.544594] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.545198] usbcore: registered new interface driver usbhid
    [    1.545210] usbhid: USB HID core driver
    [    1.545712] optee: probing for conduit method.
    [    1.545737] optee: revision 3.13 (d2d49c3d)
    [    1.545997] optee: dynamic shared memory is enabled
    [    1.546185] optee: initialized driver
    [    1.547765] u32 classifier
    [    1.547779]     input device check on
    [    1.547783]     Actions configured
    [    1.548242] NET: Registered protocol family 10
    [    1.549113] Segment Routing with IPv6
    [    1.549169] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.549566] NET: Registered protocol family 17
    [    1.549636] Bridge firewalling registered
    [    1.549645] can: controller area network core
    [    1.549687] NET: Registered protocol family 29
    [    1.549697] can: raw protocol
    [    1.549705] can: broadcast manager protocol
    [    1.549716] can: netlink gateway - max_hops=1
    [    1.549853] Key type dns_resolver registered
    [    1.550021] NET: Registered protocol family 40
    [    1.550312] registered taskstats version 1
    [    1.550386] Key type ._fscrypt registered
    [    1.550398] Key type .fscrypt registered
    [    1.550405] Key type fscrypt-provisioning registered
    [    1.551561] Btrfs loaded, crc32c=crc32c-generic
    [    1.553010] Key type encrypted registered
    [    1.557846] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.558017] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.560703] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    1.605993] pca953x 0-0020: supply vcc not found, using dummy regulator
      4.703196] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    4.703202] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    4.703866] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 21, base_baud = 3000000) is a 8250
    [    6.811729] printk: console [ttyS2] enabled
    [    6.859702] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    6.869665] bcm89883_match_phy_device phydev->phy_id:0x0
    [    6.875091] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver unknown
    [    6.883179] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    6.896100] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    6.903328] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    6.947705] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 500000
    [    6.956468] mdio_bus c000f00.mdio: MDIO device at address 0 is missing.
    [    6.964534] mdio_bus c000f00.mdio: MDIO device at address 1 is missing.
    [    6.974447] bcm89883_match_phy_device phydev->phy_id:0xae02503a
    [    6.980498] bcm89883_probe ruijie
    [    6.983931] Broadcom BCM89883 c000f00.mdio:02: bcm89883_probe id = 0xffffffff
    [    6.993752] mdio_bus c000f00.mdio: MDIO device at address 3 is missing.
    [    7.003840] bcm89883_match_phy_device phydev->phy_id:0xae02503a
    [    7.009889] bcm89883_probe ruijie
    [    7.013320] Broadcom BCM89883 c000f00.mdio:04: bcm89883_probe id = 0xffffffff
    [    7.023025] mdio_bus c000f00.mdio: MDIO device at address 5 is missing.
    [    7.030914] mdio_bus c000f00.mdio: MDIO device at address 6 is missing.
    [    7.039014] mdio_bus c000f00.mdio: MDIO device at address 7 is missing.
    [    7.045641] davinci_mdio c000f00.mdio: phy[2]: device c000f00.mdio:02, driver Broadcom BCM89883
    [    7.054336] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver Broadcom BCM89883
    [    7.063116] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirks:00000000
    [    7.077076] phy-gmii-sel 104044.phy: port1: unsupported mode: "sgmii"
    [    7.083551] am65-cpsw-nuss c000000.ethernet: /bus@100000/ethernet@c000000/ethernet-ports/port@1 error setting phy mode -22
    [    7.095274] am65-cpsw-nuss: probe of c000000.ethernet failed with error -22
    [    7.143701] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    7.152125] mdio_bus c200f00.mdio: MDIO device at address 0 is missing.
    [    7.158832] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA0210
        [    7.201939] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    7.208992] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    7.216096] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    7.223136] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    7.230170] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    7.235732] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    7.237231] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    7.342693] mmc0: Command Queue Engine enabled
    [    7.347161] mmc0: new HS400 MMC card at address 0001
    [    7.352602] mmcblk0: mmc0:0001 064GB2 58.2 GiB
    [    7.357333] mmcblk0boot0: mmc0:0001 064GB2 partition 1 8.00 MiB
    [    7.363434] mmcblk0boot1: mmc0:0001 064GB2 partition 2 8.00 MiB
    [    7.369522] mmcblk0rpmb: mmc0:0001 064GB2 partition 3 4.00 MiB, chardev (245:0)
    [    7.379553] GPT:Primary header thinks Alt. header is not at the end of the disk.
    [    7.386961] GPT:29360127 != 122142719
    [    7.390627] GPT:Alternate GPT header not at the end of the disk.
    [    7.396631] GPT:29360127 != 122142719
    [    7.400292] GPT: Use GNU Parted to correct GPT errors.
    [    7.405455]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
    [    7.968261] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    7.975781] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    7.983886] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    7.991991] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.000757] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.008280] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.016407] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.024517] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.033899] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    8.045092] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    8.058980] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    8.065896] spi-nor: probe of spi0.0 failed with error -2
    [    8.138308] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.145842] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.153950] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.162056] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.170825] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.178348] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.186453] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.194559] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.206042] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [    8.213608] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [    8.221754] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [    8.229886] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.238751] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [    8.246288] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [    8.254422] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [    8.262547] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [    8.273608] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    8.280903] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    8.289045] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    8.296429] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    8.305646] printk: console [netcon0] enabled
    [    8.310029] netconsole: network logging started
    [    8.321422] ALSA device list:
    [    8.324406]   No soundcards found.
    [    8.328074] md: Waiting for all devices to be available before autodetect
    [    8.334886] md: If you don't use raid, use raid=noautodetect
    [    8.340551] md: Autodetecting RAID arrays.
    [    8.344646] md: autorun ...
    [    8.347430] md: ... autorun DONE.
    [    8.355793] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
    [    8.364042] VFS: Mounted root (ext4 filesystem) readonly on device 259:4.
    [    8.371892] devtmpfs: mounted
    [    8.377024] Freeing unused kernel memory: 4992K
    [    8.381602] Run /sbin/init as init process
    [    8.584084] SELinux:  Class rpmsg_socket not defined in policy.
    [    8.590029] SELinux: the above unknown classes and permissions will be allowed
    [    8.606171] SELinux:  policy capability network_peer_controls=1
    [    8.612122] SELinux:  policy capability open_perms=1
    [    8.617091] SELinux:  policy capability extended_socket_class=1
    [    8.623009] SELinux:  policy capability always_check_network=0
    [    8.628838] SELinux:  policy capability cgroup_seclabel=1
    [    8.634235] SELinux:  policy capability nnp_nosuid_transition=1
    [    8.640151] SELinux:  policy capability genfs_seclabel_symlinks=0
    [    8.646240] SELinux:  policy capability ioctl_skip_cloexec=0
    [    8.735762] audit: type=1403 audit(8.732:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
    [    8.742932] systemd[1]: Successfully loaded SELinux policy in 290.312ms.
    [    8.766972] systemd[1]: System time before build time, advancing clock.
    [    8.847424] systemd[1]: Relabelled /dev, /dev/shm, /run, /sys/fs/cgroup in 45.007ms.
    [    8.868899] systemd[1]: systemd 247.6+ running in system mode. (+PAM +AUDIT +SELINUX +IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    8.891860] systemd[1]: Detected architecture arm64.
    Welcome to Wind River Linux LTS 21.20 Update 13!
    [    8.909058] systemd[1]: Set hostname to <j784s4-evm>.
    [    8.918237] random: systemd: uninitialized urandom read (16 bytes read)
    [    8.924933] systemd[1]: Initializing machine ID from random generator.
    [    8.931888] systemd[1]: Installed transient /etc/machine-id file.
    [    9.192224] systemd[1]: Queued start job for default target Multi-User System.
    [    9.200382] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.208423] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    9.235861] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.243201] systemd[1]: Created slice system-modprobe.slice.
    [  OK  ] Created slice system-modprobe.slice.
    [    9.264546] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.
    [    9.288535] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [  OK  ] Created slice system-systemd\x2dfsck.slice.
    [    9.316549] systemd[1]: Created slice system-systemd\x2dmakefs.slice.
    [  OK  ] Created slice system-systemd\x2dmakefs.slice.
    [    9.340441] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    9.364070] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    9.379921] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    9.399906] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    9.415930] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    9.444602] systemd[1]: Listening on RPCbind Server Activation Socket.
    [  OK  ] Listening on RPCbind Server Activation Socket.
    [    9.467950] systemd[1]: Reached target RPC Port Mapper.
    [  OK  ] Reached target RPC Port Mapper.
    [    9.490404] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    9.505581] systemd[1]: Listening on Journal Audit Socket.
    [  OK  ] Listening on Journal Audit Socket.
    [    9.532981] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    9.557531] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    9.573220] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.
    [    9.602899] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    9.629193] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    9.657768] systemd[1]: Listening on User Database Manager Socket.
    [  OK  ] Listening on User Database Manager Socket.
    [    9.683653] systemd[1]: Mounting Huge Pages File System...
    [    9.702977] systemd[1]: Mounting POSIX Message Queue File System...
    [    9.727192] systemd[1]: Mounting Kernel Debug File System...
    [    9.751281] systemd[1]: Mounting Kernel Trace File System...
    [    9.772236] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    9.791602] systemd[1]: Starting Create list of static device nodes for the current kernel...
             Starting Create list of st…odes for the current kernel...
    [    9.818709] systemd[1]: Started Translates SELinux MCS/MLS labels to human readable form.
    [  OK  ] Started Translates SELinux…labels to human readable form.
    [    9.848112] systemd[1]: Starting Load Kernel Module configfs...
    [    9.867127] systemd[1]: Starting RPC Bind...
    [    9.886820] systemd[1]: Starting SELinux autorelabel service loading...
    [    9.911186] systemd[1]: Starting SELinux init for /dev service loading...
    [    9.940081] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.953332] systemd[1]: Starting Journal Service...
    [    9.970855] random: systemd: uninitialized urandom read (16 bytes read)
    [    9.976352] audit: type=1400 audit(1640966401.208:3): avc:  denied  { read } for  pid=214 comm="systemd-journal" name="machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [    9.980571] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    9.981641] systemd[1]: Starting Load Kernel Modules...
    [    9.999952] audit: type=1400 audit(1640966401.208:4): avc:  denied  { open } for  pid=214 comm="systemd-journal" path="/etc/machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [   10.037617] cryptodev: loading out-of-tree module taints kernel.
    [   10.048281] cryptodev: driver 1.12 loaded.
    [   10.051778] systemd[1]: Starting Remount Root and Kernel File Systems...
    [   10.081964] systemd[1]: Starting Coldplug All udev Devices...
    [   10.084819] EXT4-fs (mmcblk0p12): re-mounted. Opts: (null)
    [   10.118326] systemd[1]: Started RPC Bind.
    [  OK  ] Started RPC Bind.
    [   10.136119] audit: type=1130 audit(1640966401.368:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=rpcbind comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   10.137359] systemd[1]: Mounted Huge Pages File System.
    [  OK  ] Mounted Huge Pages File System.
    [   10.180638] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [   10.204681] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [   10.220387] audit: type=1130 audit(1640966401.452:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-journald comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  OK  ] Mounted Kernel Debug File System.
    [  OK  ] Mounted Kernel Trace File System.
    [  OK  ] Mounted Temporary Directory (/tmp).
    [  OK  ] Finished Create list of st… nodes for the current kernel.
    [   10.307915] audit: type=1130 audit(1640966401.540:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=kmod-static-nodes comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   10.329053] audit: type=1131 audit(1640966401.540:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=mcstrans comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    [  OK  ] Finished Load Kernel Module configfs.
    [   10.363922] audit: type=1130 audit(1640966401.596:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=modprobe@configfs comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   10.385060] audit: type=1131 audit(1640966401.596:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=modprobe@configfs comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [FAILED] Failed to start SELinux autorelabel service loading.
    See 'systemctl status selinux-autorelabel.service' for details.
    [   10.439908] audit: type=1130 audit(1640966401.672:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=selinux-autorelabel comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    [  OK  ] Finished SELinux init for /dev service loading.
    [  OK  ] Finished Load Kernel Modules.
    [  OK  ] Finished Remount Root and Kernel File Systems.
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting NFSD configuration filesystem...
             Mounting Kernel Configuration File System...
    [   10.569136] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
             Mounting /var/volatile...
             Starting Apply Kernel Variables...
             Starting Rule-based Manage…for Device Events and Files...
    [  OK  ] Mounted NFSD configuration filesystem.
    [  OK  ] Mounted Kernel Configuration File System.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Finished Apply Kernel Variables.
    [  OK  ] Started Rule-based Manager for Device Events and Files.
             Starting Network Service...
             Starting Bind mount volatile /var/cache...
             Starting Bind mount volatile /var/lib...
             Starting Bind mount volatile /var/spool...
             Starting Bind mount volatile /srv...
    [  OK  ] Finished Bind mount volatile /var/cache.
    [  OK  ] Finished Bind mount volatile /var/spool.
    [  OK  ] Finished Bind mount volatile /srv.
    [  OK  ] Started Network Service.
    [   11.199309] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.208862] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.216498] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.226009] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.234235] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.234737] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.242792] cdns-mhdp8546 a000000.dp-bridge: Direct firmware load for cadence/mhdp8546.bin failed with error -2
    [   11.253960] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
    [   11.254229] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   11.254283] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   11.254314] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   11.254347] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.254684] random: systemd: uninitialized urandom read (16 bytes read)
    [   11.264263] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.276447] cdns-mhdp8546 a000000.dp-bridge: cdns_mhdp_fw_cb: No firmware.
    [   11.284238] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [   11.289138] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.289163] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.289205] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.292558] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   11.304793] remoteproc remoteproc0: 64800000.dsp is available
    [   11.307073] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   11.309554] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   11.309757] platform 41000000.r5f: configured R5F for IPC-only mode
    [   11.309816] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
    [   11.316518] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
    [   11.321619] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   11.328344] remoteproc remoteproc0: powering up 64800000.dsp
    [   11.336670] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.343149] remoteproc remoteproc1: 41000000.r5f is available
    [   11.343354] remoteproc remoteproc1: attaching to 41000000.r5f
    [   11.343641] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   11.343702]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
    [   11.343872]  remoteproc1#vdev0buffer: registered virtio0 (type 7)
    [   11.343882] remoteproc remoteproc1: remote processor 41000000.r5f is now attached
    [   11.344756] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
    [   11.355915] platform 5c00000.r5f: configured R5F for remoteproc mode
    [   11.360566] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
    [   11.361412] remoteproc remoteproc0: request_firmware failed: -2
    [   11.363831] k3-dsp-rproc 65800000.dsp: assigned reserved memory node c71-dma-memory@a9000000
    [   11.364070] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [   11.376531] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
    [   11.386271] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
    [   11.390584] remoteproc remoteproc3: 65800000.dsp is available
    [   11.391978] k3-dsp-rproc 66800000.dsp: assigned reserved memory node c71-dma-memory@aa000000
    [   11.392298] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
    [   11.392465] remoteproc remoteproc4: 66800000.dsp is available
    [   11.392990] remoteproc remoteproc3: Direct firmware load for j784s4-c71_1-fw failed with error -2
    [   11.392994] remoteproc remoteproc2: 5c00000.r5f is available
    [   11.393308] remoteproc remoteproc2: Direct firmware load for pdk-ipc/ipc_echo_test_mcu2_0_release_strip.xer5f failed with error -2
    [   11.393318] remoteproc remoteproc2: powering up 5c00000.r5f
    [   11.393382] remoteproc remoteproc2: Direct firmware load for pdk-ipc/ipc_echo_test_mcu2_0_release_strip.xer5f failed with error -2
    [   11.393390] remoteproc remoteproc2: request_firmware failed: -2
    [   11.393397] k3-dsp-rproc 67800000.dsp: assigned reserved memory node c71-dma-memory@ab000000
    [   11.393823] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
    [   11.394020] remoteproc remoteproc5: 67800000.dsp is available
    [   11.395404] remoteproc remoteproc4: Direct firmware load for j784s4-c71_2-fw failed with error -2
    [   11.395423] remoteproc remoteproc4: powering up 66800000.dsp
    [   11.395508] remoteproc remoteproc4: Direct firmware load for j784s4-c71_2-fw failed with error -2
    [   11.395518] remoteproc remoteproc4: request_firmware failed: -2
    [   11.395726] remoteproc remoteproc5: Direct firmware load for j784s4-c71_3-fw failed with error -2
    [   11.395739] remoteproc remoteproc5: powering up 67800000.dsp
    [   11.395822] remoteproc remoteproc5: Direct firmware load for j784s4-c71_3-fw failed with error -2
    [   11.395834] remoteproc remoteproc5: request_firmware failed: -2
    [   11.397273] platform 5e00000.r5f: configured R5F for remoteproc mode
    [   11.397969] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
    [   11.398322] remoteproc remoteproc6: 5e00000.r5f is available
    [   11.398658] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
    [   11.398672] remoteproc remoteproc6: powering up 5e00000.r5f
    [   11.398756] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
    [   11.398767] remoteproc remoteproc6: request_firmware failed: -2
    [   11.401545] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
    [   11.402000] platform 5900000.r5f: configured R5F for remoteproc mode
    [   11.402701] platform 5900000.r5f: assigned reserved memory node r5f-dma-memory@a6000000
    [   11.402981] remoteproc remoteproc7: 5900000.r5f is available
    [   11.403261] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
    [   11.403271] remoteproc remoteproc7: powering up 5900000.r5f
    [   11.403336] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
    [   11.403347] remoteproc remoteproc7: request_firmware failed: -2
    [   11.411567] remoteproc remoteproc3: powering up 65800000.dsp
    [   11.449391] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.503398] remoteproc remoteproc3: Direct firmware load for j784s4-c71_1-fw failed with error -2
    [   11.513871] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
    [   11.526919] remoteproc remoteproc3: request_firmware failed: -2
    [   11.545192] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
    [   11.588271] am65_cpsw_nuss_ndo_slave_open ruijie
    [   11.591764] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
    [   11.603843] am65-cpsw-nuss c200000.ethernet: down msc_sl e0000000 tmo 0
    [   11.609238] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
    [   11.782694] cdns-csi2rx: probe of 4504000.csi-bridge failed with error -22
    [   11.786753] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.795417] am65-cpsw-nuss c200000.ethernet: set new flow-id-base 82
    [   11.807375] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.835056] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
    [   11.843092] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [   11.862898] phylink_of_phy_connect ruijie
    [   11.915172] fwnode_get_phy_node ruijie 1
    [   11.919164] phylink_
                           [  OK  ] Reached target Hardware activated USB gadget.
    [  OK  ] Finished Coldplug All udev Devices.
    [   12.493301] random: systemd: uninitialized urandom read (16 bytes read)
    [  OK  ] Found device /dev/disk/by-partlabel/data.
    [  OK  ] Found device /dev/disk/by-partlabel/update.
             Starting Make File System …/dev/disk/by-partlabel/data...
             Starting Make File System …ev/disk/by-partlabel/update...
    [  OK  ] Finished Make File System on /dev/disk/by-partlabel/data.
    [  OK  ] Finished Make File System …/dev/disk/by-partlabel/update.
             Starting File System Check…/dev/disk/by-partlabel/data...
             Starting File System Check…ev/disk/by-partlabel/update...
    [  OK  ] Finished Bind mount volatile /var/lib.
    [  OK  ] Finished File System Check…/dev/disk/by-partlabel/update.
             Mounting /update...
    [   12.966924] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /update.
    [  OK  ] Finished File System Check…n /dev/disk/by-partlabel/data.
             Mounting /data...
    [   13.028760] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: (null)
    [  OK  ] Mounted /data.
    [  OK  ] Reached target Local File Systems.
             Starting Mount partitions dual service loading...
             Starting SELinux init service loading...
    [   13.108424] EXT4-fs (mmcblk0p14): mounted filesystem without journal. Opts: noload
             Starting Create Volatile Files and Directories...
    [  OK  ] Finished Mount partitions dual service loading.
    [  OK  ] Finished SELinux init service loading.
    [  OK  ] Finished Create Volatile Files and Directories.
             Starting Security Auditing Service...
             Starting Network Name Resolution...
    [  OK  ] Started Security Auditing Service.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Started Daily rotation of log files.
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Configure Crash Handler...
    [  OK  ] Started Periodic Command Scheduler.
    [  OK  ] Started D-Bus System Message Bus.
             Starting Dump Pstore...
             Starting system property service...
             Starting System Logging Service...
             Starting User Login Management...
    [  OK  ] Started Network Name Resolution.
    [  OK  ] Finished Dump Pstore.
    [  OK  ] Finished Configure Crash Handler.
    [  OK  ] Started system property service.
    [  OK  ] Reached target Network.
    [  OK  ] Reached target Host and Network Name Lookups.
    [  OK  ] Started NFS Mount Daemon.
             Starting NFS server and services...
    [  OK  ] Started NFS status monitor for NFSv2/3 locking..
             Starting /etc/rc.local Compatibility...
             Starting Permit User Sessions...
    [  OK  ] Started System Logging Service.
    [  OK  ] Started /etc/rc.local Compatibility.
    [  OK  ] Finished Permit User Sessions.
    [  OK  ] Started User Login Management.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Started Serial Getty on ttyS2.
    [   13.943357] file system registered
    [  OK  ] Reached target Login Prompts.
    [  OK  ] Reached target Multi-User System.
    [   14.137050] read descriptors
    [   14.140313] read strings
    [   14.912087] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
    [   14.920000] NFSD: Using legacy client tracking operations.
    [   14.925527] NFSD: starting 90-second grace period (net f0000081)
    [  OK  ] Finished NFS server and services.
    Wind River Linux LTS 21.20 Update 13 j784s4-evm ttyS2
    尊敬的,
    我们更改 qsgmii-main-ports 值:
    使用 cpsw9g port5 ping ip、但不使用 ping
    设置 cpsw9g 环回模式、 是否可以设置 cpsw 配置? 谢谢
    root@j784s4-evm:/data# ethtool -S eth1 | grep good
         p0_rx_good_frames: 94
         p0_tx_good_frames: 0
         rx_good_frames: 0
         tx_good_frames: 46
    root@j784s4-evm:/data# ./devmem2  0xc026330
    /dev/mem opened.
    Memory mapped at address 0x3ff95810000.
    Read at address  0x0C026330 (0x3ff95816330): 0x00020002
    您好、根据下面的 PSDK Linux 用户指南、您能否检查您使用的是本机 Linux 以太网还是需要 R5上的 ethfw 来桥接设置的虚拟客户端模式?
    在本地模式下工作时、您是否遵循了"k3-j784s4-quad-port-eth1-exp.dtbo"中的示例
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/latest/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Network/CPSWng.html#cpswng
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/latest/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/Network/CPSWng-Native-Ethernet.html#cpswng-native-ethernet
    J784S4 QSGMII k3-j784s4-quad-port-eth1-exp.dtbo
    尊敬的 TI:
    设置 SGMII 控制环回后、 我们发现 SGMII 环回失败、没有 Rx 良好帧
    设置 Mac 环回时、Rx goog 帧具有数据编号
    请帮助检查这个问题、谢谢
    尊敬的 TI:
    请帮助检查这个问题、谢谢
    Ruijie、您对此问题的描述不清楚。
    1)请1)将您的原理图附加到此部分以演示连接2)选择一个主题(QSGMII 或 SGMII)并满足您的意图3)将您的更改上传至 DTS 文件、并描述您为什么要这样做(根据客户电路板调整或做什么)? 之后、我们的以太网 BU 专家会研究一下。
    Daer ti,
    我们的电路板原理图为:
    2) 2)在 Linux 本机驱动程序中使用 qsgmii、phy 可以建立链路、但不能 ping
      使用 SGMII 模式、不使用 ping
     我们测试 cpsw Mac 环回和 SGMII 环回
      MAC 备份正常、但 SGMII 环回失败
    3) DTS 是:
     * J7AHP board.
    aliases {
    &main_cpsw0 {
    	status = "okay";
    	pinctrl-0 = <&mdio_pins_default &phy_enable_default>;
    &main_cpsw0_port5 {
    	status = "okay";
    &main_cpsw0_port6 {
    	status = "okay";
    &main_cpsw0_port7 {
    	status = "okay";
    &main_cpsw0_port8 {
    	status = "okay";
    &main_cpsw0_mdio {
    	#size-cells = <0>;
    		reg = <4>;
    		ethphy-speed = <1000>;
    		reg = <5>;
    		reg = <6>;
    		reg = <7>;
    &cpsw9g_virt_mac {
    &main_pmx0 {
    	phy_enable_default: phy_enable_default {
                           J784S4_IOPAD(0x044, PIN_OUTPUT, 7)
    &serdes_ln_ctrl {
                          <J784S4_SERDES1_LANE0_PCIE0_LANE0>, <J784S4_SERDES1_LANE1_PCIE0_LANE1>,
                          <J784S4_SERDES1_LANE2_PCIE0_LANE2>, <J784S4_SERDES1_LANE3_PCIE0_LANE3>,
    &serdes_wiz2 {
    	status = "okay";
    &serdes2 {
    	status = "okay";
    		reg = <0>;
    		#phy-cells = <0>;
    尊敬的 TI:
    该寄存器是否可以使用检测 SGMII 链路状态?
    是的、第0位表示链路建立。 BTW、恐怕您不会在寻找适用于 TDA4VH 的 TRM、请仔细检查一下。 谢谢。
    尊敬的 Xu,
    您可以帮助发送适用于 TDA4VH 的 TRM 吗? 谢谢
    您可以从 TI.com 下载所有文档和应用手册、
    https://www.ti.com/product/TDA4VH-Q1#tech-docs
    尊敬的 TI:
    谢谢、我们转储寄存器、值为0x0、没有链路、对吧? 问题是 Cpsw SGMII 未正确设置?
    32 78h CPSW_NUSS_VBUSP cpsw_9xuss_j7m_status_SGMII_link_REG 0h SGMII 链路状态寄存器
    32 78h CPSW_NUSS_VBUSP cpsw_9xuss_j7m_status_SGMII_link_REG   保留 0h 保留
    32 78h CPSW_NUSS_VBUSP cpsw_9xuss_j7m_status_SGMII_link_REG 1 SGMII2_link R 0h 端口2 SGMII 链路指示器
    32 78h CPSW_NUSS_VBUSP cpsw_9xuss_j7m_status_SGMII_link_REG 0 SGMII1_LINK R 0h 端口1 SGMII 链路指示器
    尊敬的 TI:
    端口5寄存器的值为0x00000032
    root@j784s4-evm:/data#./devmem2 0xc000514
    /dev/mem 打开。
    在地址0x3ff9ff50000上映射的存储器。
    在地址0x0C000514 (0x3ff9ff50514)处读取:0x00000032
    本主题的内容摘要。
    大家好、BU 专家、在与客户进行通信并与客户保持一致后、BRCM 的4个单端口 PHY 不支持 QSGMII、因此客户需要我们团队的支持来在原生 Linux 驱动程序中启用 SGMII。
    请求本机 Linux 驱动程序的原因是、仅提供 TSN 支持、而不提供 RTOS SDK。
    请在 PSDK8.6上为 TDA4VH 提供补丁。 谢谢。
    通过 RTOS SGMII 驱动程序修复了该问题、但需要 BU 支持在 Linux 内核上提供补丁来支持4个 SGMII 而非 QSGMII。
    尊敬的 TI:
    Linux 本机驱动程序何时支持 SGMII? 我们的项目很紧急、想要制定计划、还是您能告诉我、
    哪些 CPSW 寄存器会影响 SGMII 自动协商? 因为 RTOS 代码可以、但 Linux 无法
    瑞杰
    尊敬的 Ruijie:
    您能否应用以下补丁并尝试 SGMII 模式
    补丁: e2e.ti.com/.../add_2D00_sgmii_2D00_support_2D00_j784s4.patch
    其余的支持已经存在。
    坦迈
    尊敬的 TanMay,
    我们已添加补丁来测试
    但发现 SGMII 未链接, 在 Linux 中自动协商失败,但 RTOS 代码成功
    在 Linux μ,中、寄存器值为0x32、而在 RTOS 中、寄存器值为0x3D
    比较 RTOS 和 Linux 代码、自动协商功能并不相同
    RTOS 代码为:
    但在 Linux 中,代码是:μ m
    尊敬的 Ruijie:
    您能否共享寄存器0x0c000118 +(port_num * 0x100)和 0x0c000120 +(port_num * 0x100)的值。
    坦迈
    尊敬的 TanMay,
    Linux 寄存器:
    MACPORT 4:
    root@j784s4-evm:/data#./devmem2 0xc000518
    /dev/mem 打开。
    在地址0x3ffbb140000处映射的存储器。
    在地址0x0C000518 (0x3ffbb140518)处读取:0x00000001
    root@j784s4-evm:/data#./devmem2 0xc000519
    /dev/mem 打开。
    在地址0x3ffa31f0000处映射的存储器。
    在地址0x0C000519 (0x3ffa31f0518)处读取:0x00000001
    root@j784s4-evm:/data#./devmem2 0xc000520
    /dev/mem 打开。
    在地址0x3ff9b810000处映射的存储器。
    在地址0x0C000520 (0x3ff9b810520)处读取:0x00004000
    root@j784s4-EVM:/data#
    RTOS 寄存器转储:
    root@megatron:/data#./devmem2 0xc000514
    /dev/mem 打开。
    在地址0x3ffbbab0000处映射的存储器。
    在地址0x0C000514 (0x3ffbbab0514)处读取:0x0000003D
    root@megatron:/data#./devmem2 0xc000518
    /dev/mem 打开。
    存储器映射在地址0x3ff8bb30000处。
    在地址0x0C000518 (0x3ff8bb30518)上读取:0x00009801
    root@megatron:/data#./devmem2 0xc000519
    /dev/mem 打开。
    在地址0x3ff94940000处映射存储器。
    在地址0x0C000519 (0x3ff94940518)处读取:0x00009801
    root@megatron:/data#./devmem2 0xc000520
    /dev/mem 打开。
    在地址0x3ffa8fd0000处映射的存储器。
    在地址0x0C000520 (0x3ffa8fd0520):0x00005001处读取
    根@兆位:/data#
    尊敬的 Ruijie:
    我们可以尝试使用此(e2e.ti.com/.../0724.add_2D00_sgmii_2D00_support_2D00_j784s4.patch)补丁吗?
    我正在尝试将 Linux 配置与 RTOS 相匹配、但理想情况下不需要该配置。
    坦迈
    Ruijie、请上传我的 Dtso 供 TanMay 查看、并在此处共享0x5060 040C (serdes0的内部 PLL 分配)回读。
    TanMay,我与 DTS 一起检查了内核源代码,其中不使用焊盘中的外部参考时钟,从 A72/内核转储寄存器的回读表明我们已经在内部 PLL 上。
    尊敬的 Tabmay:
    Linux DTS
     * J7AHP board.
    aliases {
    &main_cpsw0 {
    	status = "okay";
    &main_cpsw0_port5 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 5>, <&serdes2_sgmii_link1>;
    &main_cpsw0_port6 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 6>, <&serdes2_sgmii_link2>;
    &main_cpsw0_port7 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 7>, <&serdes2_sgmii_link3>;
    &main_cpsw0_port8 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 8>, <&serdes2_sgmii_link4>;
    &main_cpsw0_mdio {
    	#size-cells = <0>;
    		reg = <4>;
    		reg = <5>;
    		reg = <6>;
    		reg = <7>;
    &cpsw9g_virt_mac {
    &main_pmx0 {
    &serdes_ln_ctrl {
    &serdes_wiz2 {
    	status = "okay";
    &serdes2 {
    	status = "okay";
    	serdes2_sgmii_link1: phy@0 {
    		reg = <0>;
    		cdns,num-lanes = <1>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 1>;
    	serdes2_sgmii_link2: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 2>;
    	serdes2_sgmii_link3: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 3>;
    	serdes2_sgmii_link4: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    		resets = <&serdes_wiz2 4>;
    补丁 0724.add-SGMII-support-j784s4.patch 也失败
    当  在 Linux 中添加0724.add-SGMII-support-j784s4.patch 时、寄存器转储为:
    尊敬的 Ruijie:
    此问题出现在串行器/解串器配置中。
    您是否可以在 DTS 文件中使用以下配置:
     * J7AHP board.
    aliases {
    &main_cpsw0 {
    	status = "okay";
    &main_cpsw0_port5 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 5>, <&serdes2_sgmii_link>;
    &main_cpsw0_port6 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 6>;
    	phy-names = "portmode";
    &main_cpsw0_port7 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 7>;
    &main_cpsw0_port8 {
    	status = "okay";
    	phy-mode = "sgmii";
    	phys = <&phy_gmii_sel_cpsw0 8>;
    &main_cpsw0_mdio {
    	#size-cells = <0>;
    		reg = <4>;
    		reg = <5>;
    		reg = <6>;
    		reg = <7>;
    &cpsw9g_virt_mac {
    &main_pmx0 {
    &serdes_ln_ctrl {
    &serdes_wiz2 {
    	status = "okay";
    &serdes2 {
    	status = "okay";
    	serdes2_sgmii_link: phy@0 {
    		reg = <0>;
    		#phy-cells = <0>;
    坦迈
    尊敬的 TanMay,
    使用新的 DTS,测试也失败,寄存器转储:
    您是否使用了 Tanmay 的补丁和 DTS? 我还尝试在 J784s4的 Serdes2上配置 SGMII、
    尊敬的 Emily,
    对不起,SGMII 无法使用补丁和来自 TanMay 的 DTS,SGMII 无法链接
    尊敬的 Emily,
    您是否有 SGMII 测试? 它是否正常工作?
    您好、Tanmay、请尽可能创建一个补丁并通过 EVM 进行验证、谢谢。
    尊敬的,
    有更新吗?
    谢谢,
    瑞杰
    已验证 SGMII 能够在 EVM 上运行。
    您是否可以执行以下操作:
    1. 运行 MAC 回送测试(如何执行 MAC 回送)
    2. 运行 phy 环回测试
    3. 您能否将整个 Linux 内核引导日志
    坦迈
    尊敬的 TanMay,
    1)MACPORT 的 MAC 环回测试5
    root@megatron:/data# ./devmem2 0xc026330 w 0xA3
    /dev/mem opened.
    Memory mapped at address 0x3ff9f4f0000.
    Read at address  0x0C026330 (0x3ff9f4f6330): 0x000000A3
    Write at address 0x0C026330 (0x3ff9f4f6330): 0x000000A3, readback 0x000000A3
    root@megatron:/data# ethtool -s eth0 | grep good
    root@megatron:/data# ethtool -S eth0 | grep good
         p0_rx_good_frames: 166
         p0_tx_good_frames: 124
         rx_good_frames: 590
         tx_good_frames: 166
    root@megatron:/data# ping -c 5 192.168.11.100
    PING 192.168.11.100 (192.168.11.100) 56(84) bytes of data.
    From 192.168.11.1 icmp_seq=1 Destination Host Unreachable
    From 192.168.11.1 icmp_seq=2 Destination Host Unreachable
    From 192.168.11.1 icmp_seq=3 Destination Host Unreachable
    From 192.168.11.1 icmp_seq=4 Destination Host Unreachable
    From 192.168.11.1 icmp_seq=5 Destination Host Unreachable
    --- 192.168.11.100 ping statistics ---
    5 packets transmitted, 0 received, +5 errors, 100% packet loss, time 4078ms
    pipe 4
         p0_rx_good_frames: 172
         rx_good_frames: 596
         tx_good_frames: 172
    2)PHY 环回测试
       将 phy 驱动器本地环回设置为测试
    root@megatron:/# ethtool -S eth0 | grep good
         p0_rx_good_frames: 28
         p0_tx_good_frames: 93
         rx_good_frames: 309
         tx_good_frames: 28
    root@megatron:/# ping -c 5 192.168.11.100
    5 packets transmitted, 0 received, +3 errors, 100% packet loss, time 4102ms
    pipe 4
         p0_rx_good_frames: 35
         p0_tx_good_frames: 205
         rx_good_frames: 691
         tx_good_frames: 35
    root@megatron:/# ifconfig eth0
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.11.1  netmask 255.255.255.0  broadcast 192.168.11.255
            inet6 fe80::4c45:feff:fe56:555b  prefixlen 64  scopeid 0x20<link>
            ether 4e:45:fe:56:55:5b  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 36  bytes 2272 (2.2 KiB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    root@megatron:/#
     3)Linux 内核引导日志
    [    0.000000] Linux version 5.10.153-rt76-yocto-preempt-rt (oe-user@oe-host) (aarch64-wrs-linux-gcc (GCC) 10.3.0, GNU ld (GNU Binutils) 2.36.1.20210703) #1 SMP PREEMPT_RT Tue Jun 27 04:44:05 UTC 2023
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 48 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-rtos-ipc-memory-region@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000af000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@af000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@b4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b4100000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_0-memory@b4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7400000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-dma-memory@b7400000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b7500000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_1-memory@b7500000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba800000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-dma-memory@ba800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ba900000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_2-memory@ba900000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdc00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-dma-memory@bdc00000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000bdd00000, size 51 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71_3-memory@bdd00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: initialized node vision_apps_shared-memories, compatible id dma-heap-carveout
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e1000000, size 80 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@e1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6000000, size 8 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-queues@e6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000e6800000, size 24 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-virtual-eth-buffers@e6800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000c0ffffff]
    [    0.000000]   node   0: [mem 0x00000000c1000000-0x00000000e0ffffff]
    [    0.000000]   node   0: [mem 0x00000000e1000000-0x00000000e7ffffff]
    [    0.000000]   node   0: [mem 0x00000000e8000000-0x00000000fffeffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x0000000ffffeffff]
    [    0.000000] On node 0 totalpages: 524286
    [    0.000000]   DMA zone: 32 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 32767 pages, LIFO batch:3
    [    0.000000]   Normal zone: 480 pages used for memmap
    [    0.000000]   Normal zone: 491519 pages, LIFO batch:3
    [    0.000000] cma: Failed to reserve 512 MiB
    [    0.000000] percpu: Embedded 10 pages/cpu s553856 r8192 d93312 u655360
    [    0.000000] pcpu-alloc: s553856 r8192 d93312 u655360 alloc=10*65536
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
    [    0.000000] Kernel command line:  androidboot.hardware=megatron androidboot.product=HH25-1 androidboot.hwversion=v1_1 androidboot.soc_type=TI K3_J784S4 androidboot.vin=VINVIN12345678901 androidboot.serialno=1236574 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:512k(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) androidboot.boot_device_root=mmcblk0 androidboot.verifiedbootstate=orange androidboot.slot_suffix=_a dm-mod.create="vroot,,,ro,0 3604480 verity 1 PARTUUID=1b578af4-4f52-41ba-bf1d-3387d6ba8f4e PARTUUID=1b578af4-4f52-41ba-bf1d-3387d6ba8f4e 4096 4096 450560 450560 sha1 5cbedeaaf12e8a79e0d5ee314b7cff2a96a6123c 23e11b385efcb9c1cad1dc67932507ba13ba0df23885f99e6647f05978fb46e2 10 restart_on_corruption ignore_zero_blocks use_fec_from_device PARTUUID=1b578af4-4f52-41ba-bf1d-3387d6ba8f4e fec_roots 2 fec_blocks 454109 fec_start 454109
    [    0.000000] Memory: 31118912K/33554304K available (12992K kernel code, 2212K rwdata, 3392K rodata, 4608K init, 1337K bss, 2435392K reserved, 0K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
    [    0.000000] ftrace: allocating 41767 entries in 11 pages
    [    0.000000] ftrace: allocated 11 pages with 3 groups
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8.
    [    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu:     RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000]  No expedited grace period (rcu_normal_after_boot).
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000]  Rude variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0310000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0320000
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.000189] Console: colour dummy device 80x25
    [    0.000197] printk: console [tty0] enabled
    [    0.000257] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000263] pid_max: default: 32768 minimum: 301
    [    0.000365] LSM: Security Framework initializing
    [    0.000400] SELinux:  Initializing.
    [    0.000603] Mount-cache hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.000707] Mountpoint-cache hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.006570] rcu: Hierarchical SRCU implementation.
    [    0.008870] Platform MSI: msi-controller@1820000 domain created
    [    0.009130] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.009336] EFI services will not be available.
    [    0.010950] smp: Bringing up secondary CPUs ...
    [    0.021025] Detected PIPT I-cache on CPU1
    [    0.021050] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.021065] GICv3: CPU1: using allocated LPI pending table @0x00000008c0330000
    [    0.021110] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.031390] Detected PIPT I-cache on CPU2
    [    0.031415] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.031431] GICv3: CPU2: using allocated LPI pending table @0x00000008c0340000
    [    0.031475] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.041745] Detected PIPT I-cache on CPU3
    [    0.041773] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.041788] GICv3: CPU3: using allocated LPI pending table @0x00000008c0350000
    [    0.041831] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.052028] Detected PIPT I-cache on CPU4
    [    0.052055] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.052071] GICv3: CPU4: using allocated LPI pending table @0x00000008c0360000
    [    0.052115] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.062350] Detected PIPT I-cache on CPU5
    [    0.062381] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.062398] GICv3: CPU5: using allocated LPI pending table @0x00000008c0370000
    [    0.062442] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.072731] Detected PIPT I-cache on CPU6
    [    0.072762] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.072779] GICv3: CPU6: using allocated LPI pending table @0x00000008c0380000
    [    0.072823] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.082974] Detected PIPT I-cache on CPU7
    [    0.083008] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.083024] GICv3: CPU7: using allocated LPI pending table @0x00000008c0390000
    [    0.083069] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.083287] smp: Brought up 1 node, 8 CPUs
    [    0.083300] SMP: Total of 8 processors activated.
    [    0.083309] CPU features: detected: 32-bit EL0 Support
    [    0.083319] CPU features: detected: CRC32 instructions
    [    0.083536] CPU: All CPU(s) started at EL2
    [    0.083684] alternatives: patching kernel code
    [    0.085469] devtmpfs: initialized
    [    0.133842] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.133873] futex hash table entries: 2048 (order: 2, 262144 bytes, linear)
    [    0.134451] pinctrl core: initialized pinctrl subsystem
    [    0.136456] DMI not present or invalid.
    [    0.137414] NET: Registered protocol family 16
    [    0.140073] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.140812] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.141616] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.141871] audit: initializing netlink subsys (disabled)
    [    0.142322] audit: type=2000 audit(0.140:1): state=initialized audit_enabled=0 res=1
    [    0.143833] thermal_sys: Registered thermal governor 'step_wise'
    [    0.145013] ASID allocator initialised with 65536 entries
    [    0.303807] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.303818] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.303826] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.384009] raid6: neonx8   gen()   580 MB/s
    [    0.452197] raid6: neonx8   xor()  1045 MB/s
    [    0.521581] raid6: neonx4   gen()   351 MB/s
    [    0.589406] raid6: neonx4   xor()   413 MB/s
    [    0.658226] raid6: neonx2   gen()   345 MB/s
    [    0.725715] raid6: neonx2   xor()   313 MB/s
    [    0.794505] raid6: neonx1   gen()   222 MB/s
    [    0.862060] raid6: neonx1   xor()   249 MB/s
    [    0.930410] raid6: int64x8  gen()   380 MB/s
    [    0.998404] raid6: int64x8  xor()   454 MB/s
    [    1.067239] raid6: int64x4  gen()   216 MB/s
    [    1.135059] raid6: int64x4  xor()   240 MB/s
    [    1.204839] raid6: int64x2  gen()   169 MB/s
    [    1.271777] raid6: int64x2  xor()   216 MB/s
    [    1.339750] raid6: int64x1  gen()    93 MB/s
    [    1.410193] raid6: int64x1  xor()    73 MB/s
    [    1.410206] raid6: using algorithm neonx8 gen() 580 MB/s
    [    1.410214] raid6: .... xor() 1045 MB/s, rmw enabled
    [    1.410221] raid6: using neon recovery algorithm
    [    1.411563] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    1.414598] vsys_3v3: supplied by evm_12v0
    [    1.416398] vsys_5v0: supplied by evm_12v0
    [    1.422015] iommu: Default domain type: Translated
    [    1.422438] vgaarb: loaded
    [    1.423461] SCSI subsystem initialized
    [    1.424215] usbcore: registered new interface driver usbfs
    [    1.424359] usbcore: registered new interface driver hub
    [    1.424528] usbcore: registered new device driver usb
    [    1.425812] mc: Linux media interface: v0.10
    [    1.425903] videodev: Linux video capture interface: v2.00
    [    1.431585] Advanced Linux Sound Architecture Driver Initialized.
    [    1.434737] clocksource: Switched to clocksource arch_sys_counter
    [    2.120845] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [    2.121064] NET: Registered protocol family 2
    [    2.121814] IP idents hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    2.126998] tcp_listen_portaddr_hash hash table entries: 16384 (order: 4, 1048576 bytes, linear)
    [    2.127361] TCP established hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    2.128262] TCP bind hash table entries: 65536 (order: 5, 3670016 bytes, linear)
    [    2.129313] TCP: Hash tables configured (established 262144 bind 65536)
    [    2.130164] UDP hash table entries: 16384 (order: 5, 2097152 bytes, linear)
    [    2.131009] UDP-Lite hash table entries: 16384 (order: 5, 2097152 bytes, linear)
    [    2.132989] NET: Registered protocol family 1
    [    2.134540] RPC: Registered named UNIX socket transport module.
    [    2.134555] RPC: Registered udp transport module.
    [    2.134565] RPC: Registered tcp transport module.
    [    2.134575] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    2.134601] PCI: CLS 0 bytes, default 64
    [    2.141512] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    2.180412] NFS: Registering the id_resolver key type
    [    2.180464] Key type id_resolver registered
    [    2.180481] Key type id_legacy registered
    [    2.180633] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
    [    2.204685] xor: measuring software checksum speed
    [    2.208997]    8regs           :  2360 MB/sec
    [    2.213333]    32regs          :  2357 MB/sec
    [    2.232932]    arm64_neon      :   518 MB/sec
    [    2.232944] xor: using function: 8regs (2360 MB/sec)
    [    2.233090] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    2.233403] io scheduler mq-deadline registered
    [    2.233420] io scheduler kyber registered
    [    2.249877] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    2.251382] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    2.262269] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    2.262820] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    2.266190] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    2.308859] brd: module loaded
    [    2.323097] CAN device driver interface
    [    2.328319] usbcore: registered new interface driver asix
    [    2.328422] usbcore: registered new interface driver ax88179_178a
    [    2.328519] usbcore: registered new interface driver cdc_ether
    [    2.328615] usbcore: registered new interface driver net1080
    [    2.328712] usbcore: registered new interface driver cdc_subset
    [    2.328807] usbcore: registered new interface driver zaurus
    [    2.328961] usbcore: registered new interface driver cdc_ncm
    [    2.336031] usbcore: registered new interface driver usb-storage
    [    2.337084] i2c /dev entries driver
    [    2.340604] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
    [    2.344665] sdhci: Secure Digital Host Controller Interface driver
    [    2.344674] sdhci: Copyright(c) Pierre Ossman
    [    2.345742] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.347598] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    2.350045] usbcore: registered new interface driver usbhid
    [    2.350054] usbhid: USB HID core driver
    [    2.352249] optee: probing for conduit method.
    [    2.352275] optee: revision 3.13 (8c1ebf3d)
    [    2.352927] optee: dynamic shared memory is enabled
    [    2.353225] optee: initialized driver
    [    2.360876] u32 classifier
    [    2.360886]     input device check on
    [    2.360891]     Actions configured
    [    2.363001] NET: Registered protocol family 10
    [    2.367328] Segment Routing with IPv6
    [    2.367518] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.369027] NET: Registered protocol family 17
    [    2.369099] can: controller area network core
    [    2.369465] NET: Registered protocol family 29
    [    2.369482] can: raw protocol
    [    2.369507] can: broadcast manager protocol
    [    2.369570] can: netlink gateway - max_hops=1
    [    2.370291] Key type dns_resolver registered
    [    2.370654] NET: Registered protocol family 40
    [    2.371603] printk: console [tty0]: printing thread started
    [    2.372160] registered taskstats version 1
    [    2.372319] Key type ._fscrypt registered
    [    2.372337] Key type .fscrypt registered
    [    2.372354] Key type fscrypt-provisioning registered
    [    2.377702] Btrfs loaded, crc32c=crc32c-generic
    [    2.379740] Key type encrypted registered
    [    2.405989] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    2.407031] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    2.421061] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    2.634644] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    2.635325] pca953x 0-0020: using no AI
    [    2.658831] pca953x 0-0020: failed writing register
    [    2.659555] pca953x: probe of 0-0020 failed with error -121
    [    2.662165] pca953x 0-0022: supply vcc not found, using dummy regulator
    [    2.662866] pca953x 0-0022: using AI
    [    2.663077] pca953x 0-0022: failed writing register
    [    2.663792] pca953x: probe of 0-0022 failed with error -121
    [    2.663862] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
    [    2.672013] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [    2.672788] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [    2.673641] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    2.674946] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    2.717429] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    2.717446] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    2.717456] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.733328] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    2.733346] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    2.733355] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    2.736109] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 21, base_baud = 3000000) is a 8250
    [    2.736400] printk: console [ttyS2]: printing thread started
    [    2.736446] printk: console [ttyS2] enabled
    [    2.754805] am65_cpsw_nuss_probe ruijie
    [    2.802824] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 500000
    [    2.811269] bcm89883_probe ruijie phy_speed 1000
    [    2.811284] Broadcom BCM89883 c000f00.mdio:04: bcm89883_probe id = 0xae02503a
    [    2.821563] bcm89883_probe ruijie phy_speed 1000
    [    2.821575] Broadcom BCM89883 c000f00.mdio:05: bcm89883_probe id = 0xae02503a
    [    2.831808] bcm89883_probe ruijie phy_speed 1000
    [    2.831820] Broadcom BCM89883 c000f00.mdio:06: bcm89883_probe id = 0xae02503a
    [    2.833454] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver Broadcom BCM89883
    [    2.833466] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver Broadcom BCM89883
    [    2.833474] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver Broadcom BCM89883
    [    2.833747] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirks:00000000
    [    2.836302] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    2.836314] phy_gmii_sel_mode id:5 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    2.836700] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    2.837082] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    2.837091] phy_gmii_sel_mode id:6 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    2.837470] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    2.837835] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    2.837845] phy_gmii_sel_mode id:7 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    2.838221] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    2.838270] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.5
    [    2.838279] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
    [    2.849186] am65_cpsw_nuss_probe ruijie end
    [    2.851435] am65_cpsw_nuss_probe ruijie
    [    2.898753] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    2.901588] davinci_mdio c200f00.mdio: phy[1]: device c200f00.mdio:01, driver Micrel KSZ9031 Gigabit PHY
    [    2.901859] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    2.902214] phy_gmii_sel_mode id:1 mode:11 rgmii_id:0 rmii_clk_ext:0
    [    2.902605] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    2.902630] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    2.902638] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    2.905775] am65_cpsw_nuss_probe ruijie end
    [    2.914960] mmc0: CQHCI version 5.10
    [    2.949680] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    2.951365] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    2.953001] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    2.954608] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    2.956434] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    2.956849] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    2.958534] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    3.063124] mmc0: Command Queue Engine enabled
    [    3.063139] mmc0: new HS400 MMC card at address 0001
    [    3.063832] mmcblk0: mmc0:0001 064GB2 58.2 GiB
    [    3.064055] mmcblk0boot0: mmc0:0001 064GB2 partition 1 8.00 MiB
    [    3.064280] mmcblk0boot1: mmc0:0001 064GB2 partition 2 8.00 MiB
    [    3.064485] mmcblk0rpmb: mmc0:0001 064GB2 partition 3 4.00 MiB, chardev (246:0)
    [    3.067474] GPT:Primary header thinks Alt. header is not at the end of the disk.
    [    3.067480] GPT:117440511 != 122142719
    [    3.067484] GPT:Alternate GPT header not at the end of the disk.
    [    3.067485] GPT:117440511 != 122142719
    [    3.067486] GPT: Use GNU Parted to correct GPT errors.
    [    3.067517]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
    [    3.695668] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    3.709719] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    3.734612] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    3.734656] spi-nor: probe of spi0.0 failed with error -2
    [    3.841437] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    3.841829] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    3.850124] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    3.850521] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    3.875187] printk: console [netcon0]: printing thread started
    [    3.875349] printk: console [netcon0] enabled
    [    3.875359] netconsole: network logging started
    [    3.876345] device-mapper: init: waiting for all devices to be available before creating mapped devices
    [    3.878428] device-mapper: verity: sha1 using implementation "sha1-sa2ul"
    [    3.882430] device-mapper: ioctl: dm-0 (vroot) is ready
    [    3.899481] ALSA device list:
    [    3.899492]   No soundcards found.
    [    3.919345] md: Waiting for all devices to be available before autodetect
    [    3.919359] md: If you don't use raid, use raid=noautodetect
    [    3.919379] md: Autodetecting RAID arrays.
    [    3.919388] md: autorun ...
    [    3.919394] md: ... autorun DONE.
    [    3.943137] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [    3.943312] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
    [    3.945731] devtmpfs: mounted
    [    3.953180] Freeing unused kernel memory: 4608K
    [    3.953246] Run /sbin/init as init process
    [    3.953254]   with arguments:
    [    3.953259]     /sbin/init
    [    3.953266]     K3_J784S4
    [    3.953273]   with environment:
    [    3.953278]     HOME=/
    [    3.953285]     TERM=linux
    [    4.321036] SELinux:  Class rpmsg_socket not defined in policy.
    [    4.321061] SELinux: the above unknown classes and permissions will be allowed
    [    4.398876] SELinux:  policy capability network_peer_controls=1
    [    4.398892] SELinux:  policy capability open_perms=1
    [    4.398900] SELinux:  policy capability extended_socket_class=1
    [    4.398907] SELinux:  policy capability always_check_network=0
    [    4.398916] SELinux:  policy capability cgroup_seclabel=1
    [    4.398923] SELinux:  policy capability nnp_nosuid_transition=1
    [    4.398930] SELinux:  policy capability genfs_seclabel_symlinks=0
    [    4.398937] SELinux:  policy capability ioctl_skip_cloexec=0
    [    4.978913] audit: type=1403 audit(4.968:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
    [    4.993656] systemd[1]: Successfully loaded SELinux policy in 780.076ms.
    [    5.017047] systemd[1]: System time before build time, advancing clock.
    [    5.134127] systemd[1]: Relabelled /dev, /dev/shm, /run, /sys/fs/cgroup in 79.511ms.
    [    5.173047] systemd[1]: systemd 247.6+ running in system mode. (+PAM +AUDIT +SELINUX +IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    5.176113] systemd[1]: Detected architecture arm64.
    [    5.221040] systemd[1]: Set hostname to <megatron>.
    [    5.234669] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.234940] systemd[1]: Initializing machine ID from random generator.
    [    5.236022] systemd[1]: Installed transient /etc/machine-id file.
    [    5.414442] systemd-sysv-generator[221]: SysV service '/etc/init.d/rc.pvr' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    5.419741] audit: type=1400 audit(1640966400.400:3): avc:  denied  { getattr } for  pid=214 comm="systemd-fstab-g" path="/data" dev="dm-0" ino=159 scontext=system_u:system_r:systemd_generator_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [    5.860620] systemd[1]: Queued start job for default target Multi-User System.
    [    5.863062] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.867662] systemd[1]: Created slice system-getty.slice.
    [    5.895280] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.897263] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    5.917276] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    5.940989] systemd[1]: Created slice system-systemd\x2dmakefs.slice.
    [    5.968917] systemd[1]: Created slice User and Session Slice.
    [    5.995474] systemd[1]: Reached target Paths.
    [    6.007302] systemd[1]: Reached target Remote File Systems.
    [    6.031237] systemd[1]: Reached target Slices.
    [    6.043284] systemd[1]: Reached target Swap.
    [    6.068014] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    6.095263] systemd[1]: Reached target RPC Port Mapper.
    [    6.121642] systemd[1]: Listening on Syslog Socket.
    [    6.135532] systemd[1]: Listening on Journal Audit Socket.
    [    6.158644] systemd[1]: Listening on Journal Socket (/dev/log).
    [    6.188317] systemd[1]: Listening on Journal Socket.
    [    6.207039] systemd[1]: Listening on Network Service Netlink Socket.
    [    6.235287] systemd[1]: Listening on udev Control Socket.
    [    6.255297] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.258235] systemd[1]: Listening on udev Kernel Socket.
    [    6.287135] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.290930] systemd[1]: Listening on User Database Manager Socket.
    [    6.325186] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.335540] systemd[1]: Mounting Huge Pages File System...
    [    6.361492] systemd[1]: Mounting POSIX Message Queue File System...
    [    6.394271] systemd[1]: Mounting Kernel Configuration File System...
    [    6.426380] systemd[1]: Mounting Kernel Debug File System...
    [    6.458043] systemd[1]: Mounting Kernel Trace File System...
    [    6.490223] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    6.523902] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    6.556302] systemd[1]: Started Translates SELinux MCS/MLS labels to human readable form.
    [    6.589769] systemd[1]: Starting RPC Bind...
    [    6.618286] systemd[1]: Starting SELinux init for /dev service loading...
    [    6.648026] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    6.648064] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    6.658020] systemd[1]: Starting Journal Service...
    [    6.686636] audit: type=1400 audit(1640966401.664:4): avc:  denied  { read } for  pid=232 comm="systemd-journal" name="machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [    6.687080] audit: type=1400 audit(1640966401.664:5): avc:  denied  { open } for  pid=232 comm="systemd-journal" path="/etc/machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [    6.705924] systemd[1]: Starting Load Kernel Modules...
    [    6.743780] cryptodev: loading out-of-tree module taints kernel.
    [    6.753120] cryptodev: driver 1.12 loaded.
    [    6.761755] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    6.803916] systemd[1]: Starting Coldplug All udev Devices...
    [    6.816317] EXT4-fs (dm-0): re-mounted. Opts: (null)
    [    6.853149] systemd[1]: Started RPC Bind.
    [    6.867757] audit: type=1130 audit(1640966401.848:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=rpcbind comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.871036] systemd[1]: Mounted Huge Pages File System.
    [    6.917319] systemd[1]: Mounted POSIX Message Queue File System.
    [    6.944833] systemd[1]: Started Journal Service.
    [    6.959914] audit: type=1130 audit(1640966401.940:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-journald comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    7.095223] audit: type=1130 audit(1640966402.076:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=kmod-static-nodes comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    7.106459] audit: type=1131 audit(1640966402.084:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=mcstrans comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    [    7.155248] audit: type=1130 audit(1640966402.136:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=selinux-labeldev comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    7.155488] audit: type=1131 audit(1640966402.136:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=selinux-labeldev comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    7.211355] audit: type=1130 audit(1640966402.192:12): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-modules-load comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    7.261300] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    7.278556] random: systemd: uninitialized urandom read (16 bytes read)
    [    7.294262] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    7.350295] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    8.792481] random: systemd: uninitialized urandom read (16 bytes read)
    [   10.162023] PVR_K:  279: Read BVNC 36.53.104.796 from HW device registers
    [   10.162041] PVR_K:  279: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [   10.193810] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [   10.243830] vdec 4210000.video-codec: sram node not found
    [   10.325024] vdec 4220000.video-codec: sram node not found
    [   10.333362] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [   10.333766] k3-dsp-rproc 64800000.dsp: configured DSP for IPC-only mode
    [   10.364056] remoteproc remoteproc0: 64800000.dsp is available
    [   10.364538] remoteproc remoteproc0: attaching to 64800000.dsp
    [   10.390191] remoteproc remoteproc0: unsupported resource 65538
    [   10.391190] k3-dsp-rproc 64800000.dsp: DSP initialized in IPC-only mode
    [   10.391228]  remoteproc0#vdev0buffer: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [   10.441017]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
    [   10.441036] remoteproc remoteproc0: remote processor 64800000.dsp is now attached
    [   10.507079] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [   10.507499] k3-dsp-rproc 65800000.dsp: configured DSP for IPC-only mode
    [   10.561503] remoteproc remoteproc1: 65800000.dsp is available
    [   10.561670] remoteproc remoteproc1: attaching to 65800000.dsp
    [   10.583655] remoteproc remoteproc1: unsupported resource 65538
    [   10.584042] k3-dsp-rproc 65800000.dsp: DSP initialized in IPC-only mode
    [   10.584075]  remoteproc1#vdev0buffer: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [   10.635898]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
    [   10.635921] remoteproc remoteproc1: remote processor 65800000.dsp is now attached
    [   10.675961] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [   10.676283] k3-dsp-rproc 66800000.dsp: configured DSP for IPC-only mode
    [   10.720343] remoteproc remoteproc2: 66800000.dsp is available
    [   10.720565] remoteproc remoteproc2: attaching to 66800000.dsp
    [   10.738675] remoteproc remoteproc2: unsupported resource 65538
    [   10.739591] k3-dsp-rproc 66800000.dsp: DSP initialized in IPC-only mode
    [   10.739639]  remoteproc2#vdev0buffer: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [   10.790937]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
    [   10.790952] remoteproc remoteproc2: remote processor 66800000.dsp is now attached
    [   10.849846] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [   10.850286] k3-dsp-rproc 67800000.dsp: configured DSP for IPC-only mode
    [   10.903814] remoteproc remoteproc3: 67800000.dsp is available
    [   10.903966] remoteproc remoteproc3: attaching to 67800000.dsp
    [   10.938437] remoteproc remoteproc3: unsupported resource 65538
    [   10.939180] k3-dsp-rproc 67800000.dsp: DSP initialized in IPC-only mode
    [   10.939227]  remoteproc3#vdev0buffer: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [   11.051695]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
    [   11.051717] remoteproc remoteproc3: remote processor 67800000.dsp is now attached
    [   11.058901] random: crng init done
    [   11.058912] random: 106 urandom warning(s) missed due to ratelimiting
    [   11.195958] kauditd_printk_skb: 14 callbacks suppressed
    [   11.195970] audit: type=1130 audit(1640966406.176:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-random-seed comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.292225] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.296912] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xd
    [   11.303760] virtio_rpmsg_bus virtio1: rpmsg host is online
    [   11.308582] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xd
    [   11.309456] virtio_rpmsg_bus virtio2: rpmsg host is online
    [   11.314059] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xd
    [   11.314666] virtio_rpmsg_bus virtio3: rpmsg host is online
    [   11.319624] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xd
    [   11.422457] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [   11.422801] platform 41000000.r5f: configured R5F for IPC-only mode
    [   11.422858] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   11.446071] remoteproc remoteproc4: 41000000.r5f is available
    [   11.446268] remoteproc remoteproc4: attaching to 41000000.r5f
    [   11.453598] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [   11.453623]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [   11.466414] virtio_rpmsg_bus virtio4: rpmsg host is online
    [   11.467034]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
    [   11.467049] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [   11.481113] virtio_rpmsg_bus virtio4: creating channel ti.ipc4.ping-pong addr 0xd
    [   11.498025] virtio_rpmsg_bus virtio4: creating channel rpmsg_chrdev addr 0xe
    [   11.540284] platform 5c00000.r5f: configured R5F for IPC-only mode
    [   11.540338] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   11.556048] remoteproc remoteproc5: 5c00000.r5f is available
    [   11.556263] remoteproc remoteproc5: attaching to 5c00000.r5f
    [   11.565398] platform 5c00000.r5f: R5F core initialized in IPC-only mode
    [   11.565420]  remoteproc5#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [   11.582206] virtio_rpmsg_bus virtio5: rpmsg host is online
    [   11.582634]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
    [   11.582645] remoteproc remoteproc5: remote processor 5c00000.r5f is now attached
    [   11.583118] platform 5d00000.r5f: configured R5F for IPC-only mode
    [   11.583177] platform 5d00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   11.603692] remoteproc remoteproc6: 5d00000.r5f is available
    [   11.603981] remoteproc remoteproc6: attaching to 5d00000.r5f
    [   11.604127] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xd
    [   11.612073] platform 5d00000.r5f: R5F core initialized in IPC-only mode
    [   11.612096]  remoteproc6#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a4000000
    [   11.632216] virtio_rpmsg_bus virtio6: rpmsg host is online
    [   11.633106]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
    [   11.633117] remoteproc remoteproc6: remote processor 5d00000.r5f is now attached
    [   11.653865] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xd
    [   11.719573] platform 5e00000.r5f: configured R5F for IPC-only mode
    [   11.719627] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   11.739927] remoteproc remoteproc7: 5e00000.r5f is available
    [   11.740090] remoteproc remoteproc7: attaching to 5e00000.r5f
    [   11.755964] platform 5e00000.r5f: R5F core initialized in IPC-only mode
    [   11.755988]  remoteproc7#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [   11.786043] virtio_rpmsg_bus virtio7: rpmsg host is online
    [   11.786457]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
    [   11.786470] remoteproc remoteproc7: remote processor 5e00000.r5f is now attached
    [   11.790830] platform 5f00000.r5f: configured R5F for IPC-only mode
    [   11.790963] platform 5f00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   11.807098] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xd
    [   11.832660] remoteproc remoteproc8: 5f00000.r5f is available
    [   11.832814] remoteproc remoteproc8: attaching to 5f00000.r5f
    [   11.839725] platform 5f00000.r5f: R5F core initialized in IPC-only mode
    [   11.839748]  remoteproc8#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a7000000
    [   11.844030] audit: type=1130 audit(1640966406.824:28): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-makefs@dev-disk-by\x2dpartlabel-data comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.857612] virtio_rpmsg_bus virtio8: rpmsg host is online
    [   11.858003]  remoteproc8#vdev0buffer: registered virtio8 (type 7)
    [   11.858012] remoteproc remoteproc8: remote processor 5f00000.r5f is now attached
    [   11.878876] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0xd
    [   11.922825] platform 5900000.r5f: configured R5F for IPC-only mode
    [   11.922881] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [   11.941587] remoteproc remoteproc9: 5900000.r5f is available
    [   11.941741] remoteproc remoteproc9: attaching to 5900000.r5f
    [   11.953157] platform 5900000.r5f: R5F core initialized in IPC-only mode
    [   11.953176]  remoteproc9#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [   11.965121] virtio_rpmsg_bus virtio9: rpmsg host is online
    [   11.965494]  remoteproc9#vdev0buffer: registered virtio9 (type 7)
    [   11.965505] remoteproc remoteproc9: remote processor 5900000.r5f is now attached
    [   11.965924] platform 5a00000.r5f: configured R5F for IPC-only mode
    [   11.965979] platform 5a00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [   11.980196] remoteproc remoteproc10: 5a00000.r5f is available
    [   11.980405] remoteproc remoteproc10: attaching to 5a00000.r5f
    [   11.986248] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0xd
    [   11.991140] audit: type=1130 audit(1640966406.972:29): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-makefs@dev-disk-by\x2dpartlabel-update comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.991872] platform 5a00000.r5f: R5F core initialized in IPC-only mode
    [   11.991898]  remoteproc10#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@aa000000
    [   12.008198] virtio_rpmsg_bus virtio10: rpmsg host is online
    [   12.008865]  remoteproc10#vdev0buffer: registered virtio10 (type 7)
    [   12.008878] remoteproc remoteproc10: remote processor 5a00000.r5f is now attached
    [   12.029266] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0xd
    [   12.030018] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0x15
    [   12.030272] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
    [   12.030355] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0x15
    [   12.030835] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0x15
    [   12.031280] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0x15
    [   12.031566] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0x15
    [   12.032005] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0x15
    [   12.032313] virtio_rpmsg_bus virtio8: creating channel rpmsg_chrdev addr 0x15
    [   12.034784] virtio_rpmsg_bus virtio9: creating channel rpmsg_chrdev addr 0x15
    [   12.089941] virtio_rpmsg_bus virtio10: creating channel rpmsg_chrdev addr 0x15
    [   12.092346] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.094367] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.096564] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.098437] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.103940] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.105793] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.108437] virtio_rpmsg_bus virtio8: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.111994] virtio_rpmsg_bus virtio9: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.155549] virtio_rpmsg_bus virtio10: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.189545] virtio_rpmsg_bus virtio5: creating channel ti.ethfw.notifyservice addr 0x1e
    [   12.213692] virtio_rpmsg_bus virtio5: creating channel rpmsg-kdrv addr 0x1a
    [   12.245367] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 2
    [   12.245380] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 13/Jun/2023 SHA:cfd413d4
    [   12.323241] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xe
    [   12.540490] audit: type=1400 audit(1640966407.520:30): avc:  denied  { read } for  pid=326 comm="systemd-network" name="machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:systemd_networkd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [   12.540645] audit: type=1400 audit(1640966407.520:30): avc:  denied  { open } for  pid=326 comm="systemd-network" path="/etc/machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:systemd_networkd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [   12.542861] am65-cpsw-nuss c000000.ethernet: down msc_sl f0000008 tmo 0
    [   12.543228] audit: type=1130 audit(1640966407.524:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-fsck@dev-disk-by\x2dpartlabel-data comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   12.680372] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 82
    [   12.684004] am65-cpsw-nuss c000000.ethernet: PSI-L request err -22
    [   12.694360] bcm89883_soft_reset ruijie
    [   12.694883] bcm89883_config_init ruijie
    [   12.712441] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [   12.714117] bcm89883_soft_reset ruijie
    [   12.727640] bcm89883_config_init ruijie
    [   12.731233] audit: type=1130 audit(1640966407.712:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-fsck@dev-disk-by\x2dpartlabel-update comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   12.753122] audit: type=1400 audit(1640966407.732:33): avc:  denied  { getattr } for  pid=1 comm="systemd" path="/data" dev="dm-0" ino=159 scontext=system_u:system_r:init_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [   12.753552] audit: type=1400 audit(1640966407.732:34): avc:  denied  { read } for  pid=1 comm="systemd" name="data" dev="dm-0" ino=159 scontext=system_u:system_r:init_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [   12.753662] audit: type=1400 audit(1640966407.732:35): avc:  denied  { open } for  pid=1 comm="systemd" path="/data" dev="dm-0" ino=159 scontext=system_u:system_r:init_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [   12.762808] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [   12.762819] phylink_bringup_phy ruijie interface:4
    [   12.762830] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:05] driver [Broadcom BCM89883] (irq=POLL)
    [   12.762847] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/sgmii link mode
    [   12.762870] bcm89883_soft_reset ruijie
    [   12.778800] bcm89883_config_init ruijie
    [   12.802971] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [   12.806178] bcm89883_config_aneg ruijie master 1000M
    [   12.882594] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: (null)
    [   12.883910] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [   12.969525] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
    [   12.992712] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [   13.064719] m_can_platform 2751000.can: m_can device registered (irq=28, version=32)
    [   13.132330] m_can_platform 26a1000.can: m_can device registered (irq=30, version=32)
    [   13.324841] EXT4-fs (mmcblk0p14): mounted filesystem without journal. Opts: noload
    [   14.419843] file system registered
    [   15.223032] read descriptors
    [   15.223052] read strings
    [   15.363332] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
    [   15.363374] NFSD: Using legacy client tracking operations.
    [   15.363377] NFSD: starting 90-second grace period (net f0000081)
    [   28.023397] am65-cpsw-nuss c000000.ethernet: down msc_sl f0000018 tmo 0
    [   28.052107] bcm89883_soft_reset ruijie
    [   28.052806] bcm89883_config_init ruijie
    [   28.064349] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [   28.065894] bcm89883_soft_reset ruijie
    [   28.074806] bcm89883_config_init ruijie
    [   28.092339] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [   28.092348] phylink_bringup_phy ruijie interface:4
    [   28.092357] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:04] driver [Broadcom BCM89883] (irq=POLL)
    [   28.092369] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/sgmii link mode
    [   28.092383] bcm89883_soft_reset ruijie
    [   28.102795] bcm89883_config_init ruijie
    [   28.116373] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [   28.119567] bcm89883_config_aneg ruijie master 1000M
    [   30.190544] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [   30.190573] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    尊敬的 TanMay,
    上面的日志 正在加载哪个以太网功能正常的 MCU2_0固件,
    下面删除了 MCU2_0固件
    1) Mac 环回
    2) phy 环回
    3) Linux 日志
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Machine model: Texas Instruments J784S4 EVM
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x0000000ffffeffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000ffffeffff]
    [    0.000000] On node 0, zone Normal: 1 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] CPU features: detected: Spectre-BHB
    [    0.000000] CPU features: detected: ARM erratum 1742098
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 523774
    [    0.000000] Dentry cache hash table entries: 4194304 (order: 9, 33554432 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 2097152 (order: 8, 16777216 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000fbff0000-0x00000000ffff0000] (64MB)
    [    0.000198] Console: colour dummy device 80x25
    [    0.000206] printk: console [tty0] enabled
    [    0.000263] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.000269] pid_max: default: 32768 minimum: 301
    [    0.000370] LSM: Security Framework initializing
    [    0.000403] SELinux:  Initializing.
    [    0.000568] Mount-cache hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.000639] Mountpoint-cache hash table entries: 65536 (order: 3, 524288 bytes, linear)
    [    0.003005] rcu: Hierarchical SRCU implementation.
    [    0.003827] Platform MSI: msi-controller@1820000 domain created
    [    0.004046] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.004172] EFI services will not be available.
    [    0.004728] smp: Bringing up secondary CPUs ...
    [    0.013787] Detected PIPT I-cache on CPU1
    [    0.013812] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.013828] GICv3: CPU1: using allocated LPI pending table @0x00000008c0330000
    [    0.013870] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.023034] Detected PIPT I-cache on CPU2
    [    0.023058] GICv3: CPU2: found redistributor 2 region 0:0x0000000001940000
    [    0.023073] GICv3: CPU2: using allocated LPI pending table @0x00000008c0340000
    [    0.023113] CPU2: Booted secondary processor 0x0000000002 [0x411fd080]
    [    0.032344] Detected PIPT I-cache on CPU3
    [    0.032370] GICv3: CPU3: found redistributor 3 region 0:0x0000000001960000
    [    0.032387] GICv3: CPU3: using allocated LPI pending table @0x00000008c0350000
    [    0.032428] CPU3: Booted secondary processor 0x0000000003 [0x411fd080]
    [    0.041593] Detected PIPT I-cache on CPU4
    [    0.041621] GICv3: CPU4: found redistributor 100 region 0:0x0000000001980000
    [    0.041637] GICv3: CPU4: using allocated LPI pending table @0x00000008c0360000
    [    0.041679] CPU4: Booted secondary processor 0x0000000100 [0x411fd080]
    [    0.050848] Detected PIPT I-cache on CPU5
    [    0.050878] GICv3: CPU5: found redistributor 101 region 0:0x00000000019a0000
    [    0.050894] GICv3: CPU5: using allocated LPI pending table @0x00000008c0370000
    [    0.050934] CPU5: Booted secondary processor 0x0000000101 [0x411fd080]
    [    0.060100] Detected PIPT I-cache on CPU6
    [    0.060132] GICv3: CPU6: found redistributor 102 region 0:0x00000000019c0000
    [    0.060148] GICv3: CPU6: using allocated LPI pending table @0x00000008c0380000
    [    0.060195] CPU6: Booted secondary processor 0x0000000102 [0x411fd080]
    [    0.069362] Detected PIPT I-cache on CPU7
    [    0.069393] GICv3: CPU7: found redistributor 103 region 0:0x00000000019e0000
    [    0.069410] GICv3: CPU7: using allocated LPI pending table @0x00000008c0390000
    [    0.069452] CPU7: Booted secondary processor 0x0000000103 [0x411fd080]
    [    0.069596] smp: Brought up 1 node, 8 CPUs
    [    0.069604] SMP: Total of 8 processors activated.
    [    0.069608] CPU features: detected: 32-bit EL0 Support
    [    0.069612] CPU features: detected: CRC32 instructions
    [    0.069721] CPU: All CPU(s) started at EL2
    [    0.069774] alternatives: patching kernel code
    [    0.070498] devtmpfs: initialized
    [    0.078155] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.078170] futex hash table entries: 2048 (order: 2, 262144 bytes, linear)
    [    0.078419] pinctrl core: initialized pinctrl subsystem
    [    0.078888] DMI not present or invalid.
    [    0.079225] NET: Registered protocol family 16
    [    0.080493] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
    [    0.081158] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.081799] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.081857] audit: initializing netlink subsys (disabled)
    [    0.082107] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
    [    0.082515] thermal_sys: Registered thermal governor 'step_wise'
    [    0.082842] ASID allocator initialised with 65536 entries
    [    0.109230] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
    [    0.109236] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
    [    0.109239] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.184979] raid6: neonx8   gen()   603 MB/s
    [    0.252972] raid6: neonx8   xor()  1078 MB/s
    [    0.321769] raid6: neonx4   gen()   369 MB/s
    [    0.389485] raid6: neonx4   xor()   424 MB/s
    [    0.458007] raid6: neonx2   gen()   375 MB/s
    [    0.526292] raid6: neonx2   xor()   331 MB/s
    [    0.594442] raid6: neonx1   gen()   246 MB/s
    [    0.662787] raid6: neonx1   xor()   260 MB/s
    [    0.731114] raid6: int64x8  gen()   404 MB/s
    [    0.798844] raid6: int64x8  xor()   483 MB/s
    [    0.867057] raid6: int64x4  gen()   228 MB/s
    [    0.935750] raid6: int64x4  xor()   240 MB/s
    [    1.005126] raid6: int64x2  gen()   181 MB/s
    [    1.072139] raid6: int64x2  xor()   225 MB/s
    [    1.142945] raid6: int64x1  gen()   105 MB/s
    [    1.209100] raid6: int64x1  xor()    73 MB/s
    [    1.209107] raid6: using algorithm neonx8 gen() 603 MB/s
    [    1.209109] raid6: .... xor() 1078 MB/s, rmw enabled
    [    1.209111] raid6: using neon recovery algorithm
    [    1.209592] k3-chipinfo 43000014.chipid: Family:J784S4 rev:SR1.0 JTAGID[0x0bb8002f] Detected
    [    1.210183] vsys_3v3: supplied by evm_12v0
    [    1.210629] vsys_5v0: supplied by evm_12v0
    [    1.211686] iommu: Default domain type: Translated
    [    1.211927] vgaarb: loaded
    [    1.212239] SCSI subsystem initialized
    [    1.212423] usbcore: registered new interface driver usbfs
    [    1.212463] usbcore: registered new interface driver hub
    [    1.212539] usbcore: registered new device driver usb
    [    1.212881] mc: Linux media interface: v0.10
    [    1.212906] videodev: Linux video capture interface: v2.00
    [    1.214209] Advanced Linux Sound Architecture Driver Initialized.
    [    1.215313] clocksource: Switched to clocksource arch_sys_counter
    [    1.486983] Carveout Heap: Exported 512 MiB at 0x00000000c1000000
    [    1.487078] NET: Registered protocol family 2
    [    1.487484] IP idents hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    1.491142] tcp_listen_portaddr_hash hash table entries: 16384 (order: 4, 1048576 bytes, linear)
    [    1.491545] TCP established hash table entries: 262144 (order: 5, 2097152 bytes, linear)
    [    1.492356] TCP bind hash table entries: 65536 (order: 5, 3670016 bytes, linear)
    [    1.493230] TCP: Hash tables configured (established 262144 bind 65536)
    [    1.493374] UDP hash table entries: 16384 (order: 5, 2097152 bytes, linear)
    [    1.493930] UDP-Lite hash table entries: 16384 (order: 5, 2097152 bytes, linear)
    [    1.494683] NET: Registered protocol family 1
    [    1.495505] RPC: Registered named UNIX socket transport module.
    [    1.495512] RPC: Registered udp transport module.
    [    1.495514] RPC: Registered tcp transport module.
    [    1.495516] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.495524] PCI: CLS 0 bytes, default 64
    [    1.497534] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    1.503241] NFS: Registering the id_resolver key type
    [    1.503265] Key type id_resolver registered
    [    1.503268] Key type id_legacy registered
    [    1.503465] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
    [    1.523844] xor: measuring software checksum speed
    [    1.525121]    8regs           :  7804 MB/sec
    [    1.526242]    32regs          :  8831 MB/sec
    [    1.529675]    arm64_neon      :  3155 MB/sec
    [    1.529681] xor: using function: 32regs (8831 MB/sec)
    [    1.529728] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
    [    1.529893] io scheduler mq-deadline registered
    [    1.529899] io scheduler kyber registered
    [    1.532932] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    1.533162] pinctrl-single 11c000.pinctrl: 72 pins, size 288
    [    1.535206] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.535448] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.536102] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    1.548056] brd: module loaded
    [    1.551257] CAN device driver interface
    [    1.552316] usbcore: registered new interface driver asix
    [    1.552348] usbcore: registered new interface driver ax88179_178a
    [    1.552377] usbcore: registered new interface driver cdc_ether
    [    1.552404] usbcore: registered new interface driver net1080
    [    1.552432] usbcore: registered new interface driver cdc_subset
    [    1.552457] usbcore: registered new interface driver zaurus
    [    1.552504] usbcore: registered new interface driver cdc_ncm
    [    1.553745] usbcore: registered new interface driver usb-storage
    [    1.554031] i2c /dev entries driver
    [    1.554724] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
    [    1.555715] sdhci: Secure Digital Host Controller Interface driver
    [    1.555720] sdhci: Copyright(c) Pierre Ossman
    [    1.556181] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.556524] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.557043] usbcore: registered new interface driver usbhid
    [    1.557049] usbhid: USB HID core driver
    [    1.557532] optee: probing for conduit method.
    [    1.557546] optee: revision 3.13 (8c1ebf3d)
    [    1.557798] optee: dynamic shared memory is enabled
    [    1.557967] optee: initialized driver
    [    1.559568] u32 classifier
    [    1.559573]     input device check on
    [    1.559574]     Actions configured
    [    1.559937] NET: Registered protocol family 10
    [    1.561022] Segment Routing with IPv6
    [    1.561064] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.561442] NET: Registered protocol family 17
    [    1.561462] can: controller area network core
    [    1.561514] NET: Registered protocol family 29
    [    1.561519] can: raw protocol
    [    1.561527] can: broadcast manager protocol
    [    1.561537] can: netlink gateway - max_hops=1
    [    1.561684] Key type dns_resolver registered
    [    1.561846] NET: Registered protocol family 40
    [    1.562205] printk: console [tty0]: printing thread started
    [    1.562310] registered taskstats version 1
    [    1.562367] Key type ._fscrypt registered
    [    1.562372] Key type .fscrypt registered
    [    1.562375] Key type fscrypt-provisioning registered
    [    1.564034] Btrfs loaded, crc32c=crc32c-generic
    [    1.565494] Key type encrypted registered
    [    1.569646] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    1.569783] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    1.572500] ti-sci 44083000.system-controller: ABI: 3.1 (firmware rev 0x0008 '8.5.2--v08.05.02 (Chill Capybar')
    [    1.619851] pca953x 0-0020: supply vcc not found, using dummy regulator
    [    1.619976] pca953x 0-0020: using no AI
    [    1.635409] pca953x 0-0020: failed writing register
    [    1.635545] pca953x: probe of 0-0020 failed with error -121
    [    1.635916] pca953x 0-0022: supply vcc not found, using dummy regulator
    [    1.636036] pca953x 0-0022: using AI
    [    1.636156] pca953x 0-0022: failed writing register
    [    1.636279] pca953x: probe of 0-0022 failed with error -121
    [    1.636301] omap_i2c 2000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.637769] ti-sci-intr 42200000.interrupt-controller: Interrupt Router 177 domain created
    [    1.638098] ti-sci-intr bus@100000:interrupt-controller@a00000: Interrupt Router 10 domain created
    [    1.638425] ti-sci-intr 310e0000.interrupt-controller: Interrupt Router 283 domain created
    [    1.638767] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 321 created
    [    1.647888] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:328
    [    1.647898] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
    [    1.647901] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.651070] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[878,128] sci-dev-id:315
    [    1.651078] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
    [    1.651081] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
    [    1.651909] 2880000.serial: ttyS2 at MMIO 0x2880000 (irq = 21, base_baud = 3000000) is a 8250
    [    1.652095] printk: console [ttyS2]: printing thread started
    [    1.652108] printk: console [ttyS2] enabled
    [    1.656940] am65_cpsw_nuss_probe ruijie
    [    1.695399] davinci_mdio c000f00.mdio: davinci mdio revision 9.7, bus freq 500000
    [    1.702431] bcm89883_probe ruijie phy_speed 1000
    [    1.702440] Broadcom BCM89883 c000f00.mdio:04: bcm89883_probe id = 0xae02503a
    [    1.710626] bcm89883_probe ruijie phy_speed 1000
    [    1.710634] Broadcom BCM89883 c000f00.mdio:05: bcm89883_probe id = 0xae02503a
    [    1.718591] bcm89883_probe ruijie phy_speed 1000
    [    1.718599] Broadcom BCM89883 c000f00.mdio:06: bcm89883_probe id = 0xae02503a
    [    1.719989] davinci_mdio c000f00.mdio: phy[4]: device c000f00.mdio:04, driver Broadcom BCM89883
    [    1.719996] davinci_mdio c000f00.mdio: phy[5]: device c000f00.mdio:05, driver Broadcom BCM89883
    [    1.719998] davinci_mdio c000f00.mdio: phy[6]: device c000f00.mdio:06, driver Broadcom BCM89883
    [    1.720072] am65-cpsw-nuss c000000.ethernet: initializing am65 cpsw nuss version 0x6BA03102, cpsw version 0x6BA82902 Ports: 9 quirks:00000000
    [    1.721383] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    1.721389] phy_gmii_sel_mode id:5 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    1.721440] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    1.721532] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    1.721536] phy_gmii_sel_mode id:6 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    1.721575] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    1.721657] phy_gmii_sel_mode PHY_INTERFACE_MODE_SGMII extra:0x10040010
    [    1.721661] phy_gmii_sel_mode id:7 mode:4 rgmii_id:0 rmii_clk_ext:0
    [    1.721700] am65-cpsw-nuss c000000.ethernet: Use random MAC address
    [    1.721711] am65-cpsw-nuss c000000.ethernet: initialized cpsw ale version 1.5
    [    1.721713] am65-cpsw-nuss c000000.ethernet: ALE Table size 512
    [    1.724976] am65_cpsw_nuss_probe ruijie end
    [    1.725593] am65_cpsw_nuss_probe ruijie
    [    1.767410] davinci_mdio c200f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.768964] davinci_mdio c200f00.mdio: phy[1]: device c200f00.mdio:01, driver Micrel KSZ9031 Gigabit PHY
    [    1.769043] am65-cpsw-nuss c200000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
    [    1.769135] phy_gmii_sel_mode id:1 mode:11 rgmii_id:0 rmii_clk_ext:0
    [    1.769189] am65-cpsw-nuss c200000.ethernet: Use random MAC address
    [    1.769208] am65-cpsw-nuss c200000.ethernet: initialized cpsw ale version 1.4
    [    1.769210] am65-cpsw-nuss c200000.ethernet: ALE Table size 64
    [    1.769939] am65_cpsw_nuss_probe ruijie end
    [    1.772277] mmc0: CQHCI version 5.10
    [    1.781198] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fca100
    [    1.781743] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fca100
    [    1.782276] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fca100
    [    1.782803] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fca100
    [    1.783447] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fca100
    [    1.783994] omap-mailbox 31f85000.mailbox: omap mailbox rev 0x66fca100
    [    1.813809] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    1.920397] mmc0: Command Queue Engine enabled
    [    1.920412] mmc0: new HS400 MMC card at address 0001
    [    1.920966] mmcblk0: mmc0:0001 064GB2 58.2 GiB
    [    1.921165] mmcblk0boot0: mmc0:0001 064GB2 partition 1 8.00 MiB
    [    1.921361] mmcblk0boot1: mmc0:0001 064GB2 partition 2 8.00 MiB
    [    1.921523] mmcblk0rpmb: mmc0:0001 064GB2 partition 3 4.00 MiB, chardev (246:0)
    [    1.923548] GPT:Primary header thinks Alt. header is not at the end of the disk.
    [    1.923554] GPT:117440511 != 122142719
    [    1.923557] GPT:Alternate GPT header not at the end of the disk.
    [    1.923558] GPT:117440511 != 122142719
    [    1.923560] GPT: Use GNU Parted to correct GPT errors.
    [    1.923581]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
    [    2.504746] ti-udma 285c0000.dma-controller: Channels: 22 (tchan: 11, rchan: 11, gp-rflow: 8)
    [    2.508030] ti-udma 31150000.dma-controller: Channels: 66 (tchan: 33, rchan: 33, gp-rflow: 16)
    [    2.514492] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
    [    2.514512] spi-nor: probe of spi0.0 failed with error -2
    [    2.590766] debugfs: Directory 'pd:73' with parent 'pm_genpd' already present!
    [    2.590819] debugfs: Directory 'pd:72' with parent 'pm_genpd' already present!
    [    2.591785] debugfs: Directory 'pd:333' with parent 'pm_genpd' already present!
    [    2.591826] debugfs: Directory 'pd:332' with parent 'pm_genpd' already present!
    [    2.594096] printk: console [netcon0]: printing thread started
    [    2.594120] printk: console [netcon0] enabled
    [    2.594123] netconsole: network logging started
    [    2.594342] device-mapper: init: waiting for all devices to be available before creating mapped devices
    [    2.595105] device-mapper: verity: sha1 using implementation "sha1-sa2ul"
    [    2.596250] device-mapper: ioctl: dm-0 (vroot) is ready
    [    2.605548] ALSA device list:
    [    2.605555]   No soundcards found.
    [    2.620372] md: Waiting for all devices to be available before autodetect
    [    2.620378] md: If you don't use raid, use raid=noautodetect
    [    2.620380] md: Autodetecting RAID arrays.
    [    2.620382] md: autorun ...
    [    2.620384] md: ... autorun DONE.
    [    2.632892] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
    [    2.632946] VFS: Mounted root (ext4 filesystem) readonly on device 252:0.
    [    2.634763] devtmpfs: mounted
    [    2.636814] Freeing unused kernel memory: 4608K
    [    2.663416] Run /sbin/init as init process
    [    2.663422]   with arguments:
    [    2.663423]     /sbin/init
    [    2.663424]     K3_J784S4
    [    2.663425]   with environment:
    [    2.663426]     HOME=/
    [    2.663427]     TERM=linux
    [    2.891021] SELinux:  Class rpmsg_socket not defined in policy.
    [    2.891039] SELinux: the above unknown classes and permissions will be allowed
    [    2.898795] SELinux:  policy capability network_peer_controls=1
    [    2.898804] SELinux:  policy capability open_perms=1
    [    2.898806] SELinux:  policy capability extended_socket_class=1
    [    2.898808] SELinux:  policy capability always_check_network=0
    [    2.898810] SELinux:  policy capability cgroup_seclabel=1
    [    2.898812] SELinux:  policy capability nnp_nosuid_transition=1
    [    2.898813] SELinux:  policy capability genfs_seclabel_symlinks=0
    [    2.898814] SELinux:  policy capability ioctl_skip_cloexec=0
    [    3.023487] audit: type=1403 audit(3.016:2): auid=4294967295 ses=4294967295 lsm=selinux res=1
    [    3.030302] systemd[1]: Successfully loaded SELinux policy in 190.037ms.
    [    3.047883] systemd[1]: System time before build time, advancing clock.
    [    3.121894] systemd[1]: Relabelled /dev, /dev/shm, /run, /sys/fs/cgroup in 33.391ms.
    [    3.167990] systemd[1]: systemd 247.6+ running in system mode. (+PAM +AUDIT +SELINUX +IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
    [    3.168795] systemd[1]: Detected architecture arm64.
    [    3.289696] systemd[1]: Set hostname to <megatron>.
    [    3.297913] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.297969] systemd[1]: Initializing machine ID from random generator.
    [    3.298369] systemd[1]: Installed transient /etc/machine-id file.
    [    3.410887] systemd-sysv-generator[219]: SysV service '/etc/init.d/rc.pvr' lacks a native systemd unit file. Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it more safe and robust.
    [    3.416674] audit: type=1400 audit(1640966400.364:3): avc:  denied  { getattr } for  pid=213 comm="systemd-fstab-g" path="/data" dev="dm-0" ino=159 scontext=system_u:system_r:systemd_generator_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [    3.627813] systemd[1]: Queued start job for default target Multi-User System.
    [    3.628640] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.629810] systemd[1]: Created slice system-getty.slice.
    [    3.693446] random: systemd: uninitialized urandom read (16 bytes read)
    [    3.694090] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    3.948487] systemd[1]: Created slice system-systemd\x2dfsck.slice.
    [    3.988072] systemd[1]: Created slice system-systemd\x2dmakefs.slice.
    [    4.012021] systemd[1]: Created slice User and Session Slice.
    [    4.031747] systemd[1]: Reached target Paths.
    [    4.043669] systemd[1]: Reached target Remote File Systems.
    [    4.067623] systemd[1]: Reached target Slices.
    [    4.083608] systemd[1]: Reached target Swap.
    [    4.099237] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.123660] systemd[1]: Reached target RPC Port Mapper.
    [    4.145577] systemd[1]: Listening on Syslog Socket.
    [    4.165195] systemd[1]: Listening on Journal Audit Socket.
    [    4.188798] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.213062] systemd[1]: Listening on Journal Socket.
    [    4.228849] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.254991] systemd[1]: Listening on udev Control Socket.
    [    4.280551] systemd[1]: Listening on udev Kernel Socket.
    [    4.303611] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.304762] systemd[1]: Listening on User Database Manager Socket.
    [    4.322749] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.326222] systemd[1]: Mounting Huge Pages File System...
    [    4.343953] random: systemd: uninitialized urandom read (16 bytes read)
    [    4.346533] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.366475] systemd[1]: Mounting Kernel Configuration File System...
    [    4.395119] systemd[1]: Mounting Kernel Debug File System...
    [    4.414398] systemd[1]: Mounting Kernel Trace File System...
    [    4.431781] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.448495] systemd[1]: Starting Create list of static device nodes for the current kernel...
    [    4.474500] systemd[1]: Started Translates SELinux MCS/MLS labels to human readable form.
    [    4.502891] systemd[1]: Starting RPC Bind...
    [    4.520412] systemd[1]: Starting SELinux init for /dev service loading...
    [    4.544129] systemd[1]: systemd-journald.service: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    4.544144] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    4.547589] systemd[1]: Starting Journal Service...
    [    4.571576] audit: type=1400 audit(1640966401.520:4): avc:  denied  { read } for  pid=230 comm="systemd-journal" name="machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [    4.571606] audit: type=1400 audit(1640966401.520:5): avc:  denied  { open } for  pid=230 comm="systemd-journal" path="/etc/machine-id" dev="tmpfs" ino=12 scontext=system_u:system_r:syslogd_t tcontext=system_u:object_r:init_runtime_t tclass=file permissive=1
    [    4.604644] systemd[1]: Starting Load Kernel Modules...
    [    4.636284] cryptodev: loading out-of-tree module taints kernel.
    [    4.636814] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.638621] cryptodev: driver 1.12 loaded.
    [    4.660876] systemd[1]: Starting Coldplug All udev Devices...
    [    4.665339] EXT4-fs (dm-0): re-mounted. Opts: (null)
    [    4.687841] systemd[1]: Started RPC Bind.
    [    4.703731] audit: type=1130 audit(1640966401.652:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=rpcbind comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.704831] systemd[1]: Mounted Huge Pages File System.
    [    4.740288] systemd[1]: Started Journal Service.
    [    4.760089] audit: type=1130 audit(1640966401.708:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-journald comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.887684] audit: type=1130 audit(1640966401.836:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=kmod-static-nodes comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    4.890713] audit: type=1131 audit(1640966401.836:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=mcstrans comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    [    4.947604] audit: type=1130 audit(1640966401.896:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=selinux-labeldev comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.045846] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    [    5.128153] kauditd_printk_skb: 3 callbacks suppressed
    [    5.128165] audit: type=1130 audit(1640966402.076:14): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-sysctl comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.175668] audit: type=1130 audit(1640966402.124:15): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.276578] audit: type=1400 audit(1640966402.224:16): avc:  denied  { search } for  pid=260 comm="systemd-udevd" name="data" dev="dm-0" ino=159 scontext=system_u:system_r:udev_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [    5.278271] audit: type=1400 audit(1640966402.224:17): avc:  denied  { getattr } for  pid=260 comm="systemd-udevd" path="/data" dev="dm-0" ino=159 scontext=system_u:system_r:udev_t tcontext=system_u:object_r:data_t tclass=dir permissive=1
    [    5.335864] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.426602] random: systemd-journal: uninitialized urandom read (16 bytes read)
    [    5.434042] random: systemd: uninitialized urandom read (16 bytes read)
    [    5.637977] audit: type=1400 audit(1640966402.584:18): avc:  denied  { mounton } for  pid=312 comm="mount" path="/var/spool" dev="dm-0" ino=14860 scontext=system_u:system_r:mount_t tcontext=system_u:object_r:var_spool_t tclass=dir permissive=1
    [    5.996078] audit: type=1130 audit(1640966402.944:19): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=systemd-udevd comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.103754] audit: type=1130 audit(1640966403.052:20): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=var-volatile-cache comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.156064] audit: type=1130 audit(1640966403.104:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=var-volatile-spool comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.199686] audit: type=1130 audit(1640966403.148:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=var-volatile-srv comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.275847] audit: type=1130 audit(1640966403.224:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t msg='unit=var-volatile-lib comm="systemd" exe="/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.459210] random: systemd: uninitialized urandom read (16 bytes read)
    [    6.570763] PVR_K:  277: Read BVNC 36.53.104.796 from HW device registers
    [    6.570779] PVR_K:  277: RGX Device registered BVNC 36.53.104.796 with 1 core in the system
    [    6.610841] [drm] Initialized pvr 1.15.6133109 20170530 for 4e20000000.gpu on minor 0
    [    6.671934] vdec 4210000.video-codec: sram node not found
    [    6.684813] k3-dsp-rproc 64800000.dsp: assigned reserved memory node vision-apps-c71-dma-memory@b4000000
    [    6.685079] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
    [    6.711088] remoteproc remoteproc0: 64800000.dsp is available
    [    6.715485] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
    [    6.715500] remoteproc remoteproc0: powering up 64800000.dsp
    [    6.715532] remoteproc remoteproc0: Direct firmware load for j784s4-c71_0-fw failed with error -2
    [    6.715539] remoteproc remoteproc0: request_firmware failed: -2
    [    6.759841] k3-dsp-rproc 65800000.dsp: assigned reserved memory node vision-apps-c71_1-dma-memory@b7400000
    [    6.760118] k3-dsp-rproc 65800000.dsp: configured DSP for remoteproc mode
    [    6.790394] remoteproc remoteproc1: 65800000.dsp is available
    [    6.790699] remoteproc remoteproc1: Direct firmware load for j784s4-c71_1-fw failed with error -2
    [    6.790720] remoteproc remoteproc1: powering up 65800000.dsp
    [    6.790792] remoteproc remoteproc1: Direct firmware load for j784s4-c71_1-fw failed with error -2
    [    6.790807] remoteproc remoteproc1: request_firmware failed: -2
    [    6.816023] vdec 4220000.video-codec: sram node not found
    [    6.816513] k3-dsp-rproc 66800000.dsp: assigned reserved memory node vision-apps-c71_2-dma-memory@ba800000
    [    6.816758] k3-dsp-rproc 66800000.dsp: configured DSP for remoteproc mode
    [    6.848804] remoteproc remoteproc2: 66800000.dsp is available
    [    6.849086] remoteproc remoteproc2: Direct firmware load for j784s4-c71_2-fw failed with error -2
    [    6.849104] remoteproc remoteproc2: powering up 66800000.dsp
    [    6.849152] remoteproc remoteproc2: Direct firmware load for j784s4-c71_2-fw failed with error -2
    [    6.849162] remoteproc remoteproc2: request_firmware failed: -2
    [    6.875044] k3-dsp-rproc 67800000.dsp: assigned reserved memory node vision-apps-c71_3-dma-memory@bdc00000
    [    6.875233] k3-dsp-rproc 67800000.dsp: configured DSP for remoteproc mode
    [    6.904304] remoteproc remoteproc3: 67800000.dsp is available
    [    6.904595] remoteproc remoteproc3: Direct firmware load for j784s4-c71_3-fw failed with error -2
    [    6.904611] remoteproc remoteproc3: powering up 67800000.dsp
    [    6.904658] remoteproc remoteproc3: Direct firmware load for j784s4-c71_3-fw failed with error -2
    [    6.904667] remoteproc remoteproc3: request_firmware failed: -2
    [    7.615860] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    7.616071] platform 41000000.r5f: configured R5F for IPC-only mode
    [    7.616125] platform 41000000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    7.640839] remoteproc remoteproc4: 41000000.r5f is available
    [    7.641114] remoteproc remoteproc4: attaching to 41000000.r5f
    [    7.647774] platform 41000000.r5f: R5F core initialized in IPC-only mode
    [    7.647794]  remoteproc4#vdev0buffer: assigned reserved memory node vision-apps-r5f-dma-memory@a0000000
    [    7.658784]  remoteproc4#vdev0buffer: registered virtio0 (type 7)
    [    7.658800] remoteproc remoteproc4: remote processor 41000000.r5f is now attached
    [    7.728204] platform 5c00000.r5f: configured R5F for remoteproc mode
    [    7.728913] platform 5c00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a2000000
    [    7.757245] remoteproc remoteproc5: 5c00000.r5f is available
    [    7.757511] remoteproc remoteproc5: Direct firmware load for pdk-ipc/ipc_echo_test_mcu2_0_release_strip.xer5f failed with error -2
    [    7.757523] remoteproc remoteproc5: powering up 5c00000.r5f
    [    7.757559] remoteproc remoteproc5: Direct firmware load for pdk-ipc/ipc_echo_test_mcu2_0_release_strip.xer5f failed with error -2
    [    7.757566] remoteproc remoteproc5: request_firmware failed: -2
    [    7.851079] platform 5e00000.r5f: configured R5F for remoteproc mode
    [    7.852061] platform 5e00000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a6000000
    [    7.866658] remoteproc remoteproc6: 5e00000.r5f is available
    [    7.867040] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
    [    7.867056] remoteproc remoteproc6: powering up 5e00000.r5f
    [    7.867104] remoteproc remoteproc6: Direct firmware load for j784s4-main-r5f1_0-fw failed with error -2
    [    7.867116] remoteproc remoteproc6: request_firmware failed: -2
    [    7.937323] platform 5900000.r5f: configured R5F for remoteproc mode
    [    7.938159] platform 5900000.r5f: assigned reserved memory node vision-apps-r5f-dma-memory@a8000000
    [    7.953616] remoteproc remoteproc7: 5900000.r5f is available
    [    7.953948] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
    [    7.953972] remoteproc remoteproc7: powering up 5900000.r5f
    [    7.954038] remoteproc remoteproc7: Direct firmware load for j784s4-main-r5f2_0-fw failed with error -2
    [    7.954050] remoteproc remoteproc7: request_firmware failed: -2
    [    8.167053] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.186623] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.203700] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.327428] random: crng init done
    [    8.327440] random: 198 urandom warning(s) missed due to ratelimiting
    [    8.482605] m_can_platform 40528000.can: m_can device registered (irq=15, version=32)
    [    8.517669] am65-cpsw-nuss c000000.ethernet: down msc_sl e0000008 tmo 0
    [    8.677163] am65-cpsw-nuss c000000.ethernet: set new flow-id-base 82
    [    8.691827] bcm89883_soft_reset ruijie
    [    8.692615] bcm89883_config_init ruijie
    [    8.704949] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [    8.706477] bcm89883_soft_reset ruijie
    [    8.715429] bcm89883_config_init ruijie
    [    8.729001] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [    8.729014] phylink_bringup_phy ruijie interface:4
    [    8.729025] am65-cpsw-nuss c000000.ethernet eth1: PHY [c000f00.mdio:05] driver [Broadcom BCM89883] (irq=POLL)
    [    8.729039] am65-cpsw-nuss c000000.ethernet eth1: configuring for phy/sgmii link mode
    [    8.729062] bcm89883_soft_reset ruijie
    [    8.739418] bcm89883_config_init ruijie
    [    8.752919] Broadcom BCM89883 c000f00.mdio:05: bcm89883 master config init complete
    [    8.756162] bcm89883_config_aneg ruijie master 1000M
    [    8.813506] m_can_platform 40568000.can: m_can device registered (irq=17, version=32)
    [    8.823274] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: (null)
    [    8.861538] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
    [    8.875774] m_can_platform 2751000.can: m_can device registered (irq=28, version=32)
    [    8.973453] m_can_platform 26a1000.can: m_can device registered (irq=30, version=32)
    [    9.251990] EXT4-fs (mmcblk0p14): mounted filesystem without journal. Opts: noload
    [   10.262915] file system registered
    [   10.957549] read descriptors
    [   10.957567] read strings
    [   11.260123] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
    [   11.260165] NFSD: Using legacy client tracking operations.
    [   11.260168] NFSD: starting 90-second grace period (net f0000081)
    [   33.767413] tlv71033: disabling
    [   89.631584] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [  141.474080] am65-cpsw-nuss c000000.ethernet: down msc_sl e0000018 tmo 0
    [  141.504774] bcm89883_soft_reset ruijie
    [  141.505469] bcm89883_config_init ruijie
    [  141.516732] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [  141.518276] bcm89883_soft_reset ruijie
    [  141.531410] bcm89883_config_init ruijie
    [  141.548719] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [  141.548728] phylink_bringup_phy ruijie interface:4
    [  141.548738] am65-cpsw-nuss c000000.ethernet eth0: PHY [c000f00.mdio:04] driver [Broadcom BCM89883] (irq=POLL)
    [  141.548748] am65-cpsw-nuss c000000.ethernet eth0: configuring for phy/sgmii link mode
    [  141.548761] bcm89883_soft_reset ruijie
    [  141.559388] bcm89883_config_init ruijie
    [  141.576724] Broadcom BCM89883 c000f00.mdio:04: bcm89883 master config init complete
    [  141.579909] bcm89883_config_aneg ruijie master 1000M
    [  141.587938] am65-cpsw-nuss c000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [  141.615652] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    关于这一主题,请作出结论吗?
    默认情况下、我们是否已为即将发布的9.0版本准备好此 Linux 本机驱动程序?
    您好、Tanmay、
    我们发现 Serdes2配置导致 Linux 本机驱动程序 SGMII 链路失败,
    1 μ s)RTOS SerDes 配置
         * serdes 2
        memset(&serdesLaneEnableParams, 0, sizeof(serdesLaneEnableParams));
        serdesLaneEnableParams.serdesInstance    = (CSL_SerdesInstance)CSL_TORRENT_SERDES2;
        serdesLaneEnableParams.baseAddr          = CSL_WIZ16B8M4CT3_2_WIZ16B8M4CT3_BASE;
        serdesLaneEnableParams.refClock          = CSL_SERDES_REF_CLOCK_100M;
        serdesLaneEnableParams.refClkSrc         = CSL_SERDES_REF_CLOCK_INT0;
        serdesLaneEnableParams.linkRate          = CSL_SERDES_LINK_RATE_1p25G;
        serdesLaneEnableParams.numLanes          = numLanes;
        serdesLaneEnableParams.laneMask          = laneMask;
        serdesLaneEnableParams.SSC_mode          = CSL_SERDES_NO_SSC;
        serdesLaneEnableParams.phyType           = CSL_SERDES_PHY_TYPE_SGMII;
        serdesLaneEnableParams.operatingMode     = CSL_SERDES_FUNCTIONAL_MODE;
        serdesLaneEnableParams.phyInstanceNum    = BOARD_SERDES_LANE_SELECT_CPSW;
        serdesLaneEnableParams.pcieGenType       = CSL_SERDES_PCIE_GEN3;
        for (laneNum = 0; laneNum < numLanes; laneNum++) {
            serdesLaneEnableParams.laneCtrlRate[laneNum] = CSL_SERDES_LANE_FULL_RATE;
            serdesLaneEnableParams.loopbackMode[laneNum] = CSL_SERDES_LOOPBACK_DISABLED;
        CSL_serdesPorReset(serdesLaneEnableParams.baseAddr);
            /* Select the IP type, IP instance num, Serdes Lane Number */
            CSL_serdesIPSelect(CSL_CTRL_MMR0_CFG0_BASE,
                               serdesLaneEnableParams.phyType,
                               serdesLaneEnableParams.phyInstanceNum,
                               serdesLaneEnableParams.serdesInstance,
                               laneNum);
        result = CSL_serdesRefclkSel(CSL_CTRL_MMR0_CFG0_BASE,
                                     serdesLaneEnableParams.baseAddr,
                                     serdesLaneEnableParams.refClock,
                                     serdesLaneEnableParams.refClkSrc,
                                     serdesLaneEnableParams.phyType);
        if (result != CSL_SERDES_NO_ERR)
            return BOARD_FAIL;
        /* Assert PHY reset and disable all lanes */
        CSL_serdesDisablePllAndLanes(serdesLaneEnableParams.baseAddr,
                                     serdesLaneEnableParams.numLanes,
                                     serdesLaneEnableParams.laneMask);
        /* Load the Serdes Config File */
        result = CSL_serdesEthernetInit(&serdesLaneEnableParams);
        /* Return error if input params are invalid */
            return BOARD_FAIL;
        /* Common Lane Enable API for lane enable, pll enable etc */
        laneRetVal = CSL_serdesLaneEnable(&serdesLaneEnableParams);
        if (laneRetVal != 0)
            return BOARD_FAIL;
        return BOARD_SOK;
    SGMII 为 link,serdes2寄存器 dump:
    Read at address  0x05020000 (0x3ff96320000): 0x00007364
    Read at address  0x05020004 (0x3ffa2060004): 0x08010000
    Read at address  0x05020008 (0x3ffa04a0008): 0x00000130
    Read at address  0x0502000C (0x3ff9f20000c): 0x00000000
    Read at address  0x05020010 (0x3ff9d2b0010): 0x00160074
    Read at address  0x05020014 (0x3ff8f170014): 0x63006666
    Read at address  0x05020018 (0x3ff9a810018): 0x02020120
    Read at address  0x0502001C (0x3ff9e27001c): 0x00000000
    Read at address  0x05020020 (0x3ff9c2f0020): 0x00041020
    Read at address  0x05020024 (0x3ff98030024): 0x00200000
    Read at address  0x05020028 (0x3ff814f0028): 0x00000155
    Read at address  0x0502002C (0x3ff83da002c): 0x00000000
    Read at address  0x05020030 (0x3ff8a5d0030): 0x00000000
    Read at address  0x05020034 (0x3ff8ba90034): 0x00000000
    Read at address  0x05020038 (0x3ff85340038): 0x00000000
    Read at address  0x0502003C (0x3ffb673003c): 0x00000000
    Read at address  0x05020040 (0x3ffa6390040): 0x00010003
    Read at address  0x05020044 (0x3ffa9820044): 0x00000019
    Read at address  0x05020048 (0x3ff907a0048): 0x00000000
    Read at address  0x0502004C (0x3ffa26c004c): 0x00010000
    Read at address  0x05020050 (0x3ff7f850050): 0x00040001
    Read at address  0x05020054 (0x3ffa9160054): 0x00010032
    Read at address  0x05020058 (0x3ff8f100058): 0x000100D1
    Read at address  0x0502005C (0x3ffa71f005c): 0x00000000
    Read at address  0x05020060 (0x3ff91610060): 0x00040001
    Read at address  0x05020064 (0x3ff94de0064): 0x00010032
    Read at address  0x05020068 (0x3ff8c3c0068): 0x000100D1
    Read at address  0x0502006C (0x3ff9ed5006c): 0x00000000
    Read at address  0x05020070 (0x3ffaf350070): 0x00000000
    Read at address  0x05020074 (0x3ff96a40074): 0x00000000
    Read at address  0x05020078 (0x3ffab590078): 0x00000000
    Read at address  0x0502007C (0x3ff99c8007c): 0x00000000
    Read at address  0x05020080 (0x3ffa3a10080): 0x01240101
    Read at address  0x05020084 (0x3ff91090084): 0x0124003B
    Read at address  0x05020088 (0x3ff88250088): 0x0424003B
    Read at address  0x0502008C (0x3ffa228008c): 0x012400A6
    Read at address  0x05020090 (0x3ff8c5e0090): 0x0424003B
    Read at address  0x05020094 (0x3ffb97e0094): 0x000000A4
    Read at address  0x05020098 (0x3ffb66a0098): 0x00000108
    Read at address  0x0502009C (0x3ffa1f3009c): 0x00000005
    Read at address  0x050200A0 (0x3ffa9e200a0): 0x00000242
    Read at address  0x050200A4 (0x3ff835100a4): 0x00000000
    Read at address  0x050200A8 (0x3ff7fe500a8): 0x00000000
    Read at address  0x050200AC (0x3ff8dbc00ac): 0x00000000
    Read at address  0x050200B0 (0x3ffbc0600b0): 0x00000000
    Read at address  0x050200B4 (0x3ffb72c00b4): 0x00000000
    Read at address  0x050200B8 (0x3ff9de500b8): 0x00030000
    Read at address  0x050200BC (0x3ff7fdb00bc): 0x00000000
    Read at address  0x050200C0 (0x3ff906700c0): 0x00000000
    Read at address  0x050200C4 (0x3ff905000c4): 0x00000000
    Read at address  0x050200C8 (0x3ff888500c8): 0x007D007D
    Read at address  0x050200CC (0x3ffa63900cc): 0x00000000
    Read at address  0x050200D0 (0x3ffaeb700d0): 0x00000000
    Read at address  0x050200D4 (0x3ffb42700d4): 0x00000000
    Read at address  0x050200D8 (0x3ffad9300d8): 0x00000000
    Read at address  0x050200DC (0x3ff93ef00dc): 0x00000000
    Read at address  0x050200E0 (0x3ff9abf00e0): 0x00000000
    Read at address  0x050200E4 (0x3ff977600e4): 0x0000001F
    Read at address  0x050200E8 (0x3ffb02900e8): 0x00070019
    Read at address  0x050200EC (0x3ffb64800ec): 0x00000000
    Read at address  0x050200F0 (0x3ffa1f700f0): 0x00000000
    Read at address  0x050200F4 (0x3ffa42100f4): 0x00000000
    Read at address  0x050200F8 (0x3ffa7ad00f8): 0x00000000
    Read at address  0x050200FC (0x3ffb1b000fc): 0x00000000
    Read at address  0x05020100 (0x3ff97d70100): 0x2028002A
    Read at address  0x05020104 (0x3ff83920104): 0x00000003
    Read at address  0x05020108 (0x3ffa1890108): 0x001003E8
    Read at address  0x0502010C (0x3ffa712010c): 0x00000C5F
    Read at address  0x05020110 (0x3ffbb630110): 0x00000C5F
    Read at address  0x05020114 (0x3ff89b40114): 0x00000000
    Read at address  0x05020118 (0x3ffa6530118): 0x00000000
    Read at address  0x0502011C (0x3ff9cae011c): 0x00000000
    Read at address  0x05020120 (0x3ffa8b50120): 0x00000000
    Read at address  0x05020124 (0x3ff90470124): 0x00000000
    Read at address  0x05020128 (0x3ff8c990128): 0x001E4004
    Read at address  0x0502012C (0x3ff8264012c): 0x0000000C
    Read at address  0x05020130 (0x3ffb3a00130): 0x00000002
    Read at address  0x05020134 (0x3ff957b0134): 0x00000000
    Read at address  0x05020138 (0x3ff99480138): 0x000400C8
    Read at address  0x0502013C (0x3ffb98c013c): 0x000300C8
    Read at address  0x05020140 (0x3ff97ae0140): 0x00000000
    Read at address  0x05020144 (0x3ff88af0144): 0x00000000
    Read at address  0x05020148 (0x3ffacdc0148): 0x00104004
    Read at address  0x0502014C (0x3ffae87014c): 0x00000010
    Read at address  0x05020150 (0x3ff94070150): 0x00000002
    Read at address  0x05020154 (0x3ff92d50154): 0x00000000
    Read at address  0x05020158 (0x3ffb6840158): 0x00000000
    Read at address  0x0502015C (0x3ffba8b015c): 0x00000000
    Read at address  0x05020160 (0x3ff91870160): 0x00000000
    Read at address  0x05020164 (0x3ff86f60164): 0x00000000
    Read at address  0x05020168 (0x3ff934c0168): 0x00000000
    Read at address  0x0502016C (0x3ffbb9a016c): 0x00000000
    Read at address  0x05020170 (0x3ffa6e00170): 0x00000000
    Read at address  0x05020174 (0x3ff95710174): 0x00000000
    Read at address  0x05020178 (0x3ffa8ca0178): 0x00000000
    Read at address  0x0502017C (0x3ff8c9d017c): 0x00000000
    Read at address  0x05020180 (0x3ff8d960180): 0x2028002A
    Read at address  0x05020184 (0x3ff8bc60184): 0x00000003
    Read at address  0x05020188 (0x3ff85200188): 0x001003E8
    Read at address  0x0502018C (0x3ff9bc6018c): 0x00000C5F
    Read at address  0x05020190 (0x3ff87c70190): 0x00000C5F
    Read at address  0x05020194 (0x3ffba880194): 0x00000000
    Read at address  0x05020198 (0x3ff8b340198): 0x00000000
    Read at address  0x0502019C (0x3ff9809019c): 0x00000000
    Read at address  0x050201A0 (0x3ff8d8c01a0): 0x00000000
    Read at address  0x050201A4 (0x3ffae7b01a4): 0x00000000
    Read at address  0x050201A8 (0x3ff937a01a8): 0x001E4004
    Read at address  0x050201AC (0x3ff8a4c01ac): 0x0000000C
    Read at address  0x050201B0 (0x3ff83f601b0): 0x00000002
    Read at address  0x050201B4 (0x3ff9bce01b4): 0x00000000
    Read at address  0x050201B8 (0x3ffb27101b8): 0x000400C8
    Read at address  0x050201BC (0x3ff926d01bc): 0x000300C8
    Read at address  0x050201C0 (0x3ffad4701c0): 0x00000000
    Read at address  0x050201C4 (0x3ffa38601c4): 0x00000000
    Read at address  0x050201C8 (0x3ffb5f001c8): 0x00000000
    Read at address  0x050201CC (0x3ffb61901cc): 0x00000000
    Read at address  0x050201D0 (0x3ff965401d0): 0x00000000
    Read at address  0x050201D4 (0x3ffa47101d4): 0x00000000
    Read at address  0x050201D8 (0x3ffbe7301d8): 0x00000000
    Read at address  0x050201DC (0x3ffa98a01dc): 0x00000000
    Read at address  0x050201E0 (0x3ff95d101e0): 0x00000000
    Read at address  0x050201E4 (0x3ff8bd401e4): 0x00000000
    Read at address  0x050201E8 (0x3ffae9001e8): 0x00000000
    Read at address  0x050201EC (0x3ff8e6101ec): 0x00000000
    Read at address  0x050201F0 (0x3ff93a501f0): 0x00000000
    Read at address  0x050201F4 (0x3ffba4301f4): 0x00000000
    Read at address  0x050201F8 (0x3ffa4df01f8): 0x00000000
    Read at address  0x050201FC (0x3ff85d801fc): 0x00000000
    Read at address  0x05020200 (0x3ffa8290200): 0x00000000
    Read at address  0x05020204 (0x3ff97150204): 0x0000002D
    Read at address  0x05020208 (0x3ff990a0208): 0x0006001E
    Read at address  0x0502020C (0x3ffa924020c): 0x00000000
    Read at address  0x05020210 (0x3ffb3de0210): 0x00000000
    Read at address  0x05020214 (0x3ff9b650214): 0x0000802D
    Read at address  0x05020218 (0x3ffaa910218): 0x0006001E
    Read at address  0x0502021C (0x3ffb5c6021c): 0x00000000
    Read at address  0x05020220 (0x3ff905f0220): 0x00000000
    Read at address  0x05020224 (0x3ff7ed40224): 0x00000008
    Read at address  0x05020228 (0x3ff8fba0228): 0x000602EE
    Read at address  0x0502022C (0x3ff99b9022c): 0x00000000
    Read at address  0x05020230 (0x3ff989a0230): 0x00000000
    Read at address  0x05020234 (0x3ff98de0234): 0x00000000
    Read at address  0x05020238 (0x3ff88b50238): 0x00000000
    Read at address  0x0502023C (0x3ff881c023c): 0x00000000
    Read at address  0x05020240 (0x3ff87ae0240): 0x101E0000
    Read at address  0x05020244 (0x3ff8c750244): 0x00000001
    Read at address  0x05020248 (0x3ff8f2e0248): 0x00020006
    Read at address  0x0502024C (0x3ffaa5c024c): 0x0000000E
    Read at address  0x05020250 (0x3ffa8820250): 0x0000012B
    Read at address  0x05020254 (0x3ff89bd0254): 0x00000000
    Read at address  0x05020258 (0x3ffa3000258): 0x00000000
    Read at address  0x0502025C (0x3ff9579025c): 0x00000000
    Read at address  0x05020260 (0x3ff8b220260): 0x00000000
    Read at address  0x05020264 (0x3ffa7b70264): 0x00000000
    Read at address  0x05020268 (0x3ff86880268): 0x00000000
    Read at address  0x0502026C (0x3ff904b026c): 0x00000000
    Read at address  0x05020270 (0x3ff87140270): 0x00000000
    Read at address  0x05020274 (0x3ffb4920274): 0x00000000
    Read at address  0x05020278 (0x3ff7f070278): 0x00000000
    Read at address  0x0502027C (0x3ff9a03027c): 0x00000000
    Read at address  0x05020280 (0x3ff9fe40280): 0x00000000
    Read at address  0x05020284 (0x3ffb4c70284): 0x00000000
    Read at address  0x05020288 (0x3ff85c10288): 0x00000000
    Read at address  0x0502028C (0x3ff9472028c): 0x00000000
    Read at address  0x05020290 (0x3ffa2b30290): 0x00000000
    Read at address  0x05020294 (0x3ffa87a0294): 0x00000000
    Read at address  0x05020298 (0x3ff9e540298): 0x00000000
    Read at address  0x0502029C (0x3ffb01d029c): 0x00000000
    Read at address  0x050202A0 (0x3ff955402a0): 0x00000000
    Read at address  0x050202A4 (0x3ff976e02a4): 0x00000000
    Read at address  0x050202A8 (0x3ff8d5d02a8): 0x00000000
    Read at address  0x050202AC (0x3ffab0d02ac): 0x00000000
    Read at address  0x050202B0 (0x3ffb1b602b0): 0x00000000
    Read at address  0x050202B4 (0x3ff95c902b4): 0x00000000
    Read at address  0x050202B8 (0x3ffbc9202b8): 0x00000000
    Read at address  0x050202BC (0x3ff8c9b02bc): 0x00000000
    Read at address  0x050202C0 (0x3ff9bb002c0): 0x00000000
    Read at address  0x050202C4 (0x3ff87da02c4): 0x00000000
    Read at address  0x050202C8 (0x3ff7f8e02c8): 0x00000000
    Read at address  0x050202CC (0x3ffbc2802cc): 0x00000000
    Read at address  0x050202D0 (0x3ff82c302d0): 0x00000000
    Read at address  0x050202D4 (0x3ffb60a02d4): 0x00000000
    Read at address  0x050202D8 (0x3ff847f02d8): 0x00000000
    Read at address  0x050202DC (0x3ffa8c902dc): 0x00000000
    Read at address  0x050202E0 (0x3ffa7eb02e0): 0x00000000
    Read at address  0x050202E4 (0x3ff826402e4): 0x00000000
    Read at address  0x050202E8 (0x3ff9cb902e8): 0x00000000
    Read at address  0x050202EC (0x3ffae8f02ec): 0x00000000
    Read at address  0x050202F0 (0x3ff959d02f0): 0x00000000
    Read at address  0x050202F4 (0x3ff872802f4): 0x00000000
    Read at address  0x050202F8 (0x3ff866102f8): 0x00000000
    Read at address  0x050202FC (0x3ff830a02fc): 0x00000000
    Read at address  0x05020300 (0x3ffb8c00300): 0x00000000
    Read at address  0x05020304 (0x3ff8c0e0304): 0x00000000
    Read at address  0x05020308 (0x3ff91990308): 0x00000000
    Read at address  0x0502030C (0x3ffbc35030c): 0x00000000
    Read at address  0x05020310 (0x3ffb5580310): 0x00000000
    Read at address  0x05020314 (0x3ffb5a30314): 0x00000000
    Read at address  0x05020318 (0x3ffaca00318): 0x00000000
    Read at address  0x0502031C (0x3ffb15b031c): 0x00000000
    Read at address  0x05020320 (0x3ff9aa60320): 0x00000000
    Read at address  0x05020324 (0x3ff97a70324): 0x00000000
    Read at address  0x05020328 (0x3ff9b8c0328): 0x00000000
    Read at address  0x0502032C (0x3ff9f7f032c): 0x00000000
    Read at address  0x05020330 (0x3ffb8e00330): 0x00000000
    Read at address  0x05020334 (0x3ff8c570334): 0x00000000
    Read at address  0x05020338 (0x3ff89d70338): 0x00000000
    Read at address  0x0502033C (0x3ff8db7033c): 0x00000000
    Read at address  0x05020340 (0x3ffa5b90340): 0x06011012
    Read at address  0x05020344 (0x3ff87640344): 0x000F0000
    Read at address  0x05020348 (0x3ffb9b20348): 0x08080028
    Read at address  0x0502034C (0x3ff8f29034c): 0x00010000
    Read at address  0x05020350 (0x3ff8e1b0350): 0x00000000
    Read at address  0x05020354 (0x3ff9d2a0354): 0x00000000
    Read at address  0x05020358 (0x3ff886f0358): 0x00000000
    Read at address  0x0502035C (0x3ff9ae2035c): 0x00000000
    Read at address  0x05020360 (0x3ff7f7d0360): 0x04001012
    Read at address  0x05020364 (0x3ffb4240364): 0x000F0000
    Read at address  0x05020368 (0x3ff81650368): 0x08080128
    Read at address  0x0502036C (0x3ffafeb036c): 0x00010000
    Read at address  0x05020370 (0x3ff81da0370): 0x00000000
    Read at address  0x05020374 (0x3ffbc0c0374): 0x00000000
    Read at address  0x05020378 (0x3ff8ea20378): 0x00000000
    Read at address  0x0502037C (0x3ffadbc037c): 0x00000000
    Read at address  0x05020380 (0x3ffa4b70380): 0x04001012
    Read at address  0x05020384 (0x3ff83990384): 0x000F0000
    Read at address  0x05020388 (0x3ff8c080388): 0x08080028
    Read at address  0x0502038C (0x3ff83ad038c): 0x00010000
    Read at address  0x05020390 (0x3ff7ebc0390): 0x00000000
    Read at address  0x05020394 (0x3ff9e3a0394): 0x00000000
    Read at address  0x05020398 (0x3ff817a0398): 0x00000000
    Read at address  0x0502039C (0x3ff884f039c): 0x00000000
    Read at address  0x050203A0 (0x3ffbada03a0): 0x00000000
    Read at address  0x050203A4 (0x3ffba1b03a4): 0x00000000
    Read at address  0x050203A8 (0x3ff888f03a8): 0x00000000
    Read at address  0x050203AC (0x3ff850c03ac): 0x00000000
    Read at address  0x050203B0 (0x3ff8a5203b0): 0x00000000
    Read at address  0x050203B4 (0x3ffba9a03b4): 0x00000000
    Read at address  0x050203B8 (0x3ff973103b8): 0x00000000
    Read at address  0x050203BC (0x3ffb48b03bc): 0x00000000
    Read at address  0x050203C0 (0x3ff8a3103c0): 0x36000E05
    Read at address  0x050203C4 (0x3ffb14603c4): 0x00000000
    Read at address  0x050203C8 (0x3ff87d403c8): 0x00220000
    Read at address  0x050203CC (0x3ffac4203cc): 0x000C2D09
    Read at address  0x050203D0 (0x3ff943203d0): 0x00000000
    Read at address  0x050203D4 (0x3ffa28603d4): 0x00000000
    Read at address  0x050203D8 (0x3ffb46603d8): 0x01FF0011
    Read at address  0x050203DC (0x3ffbcde03dc): 0x00000000
    Read at address  0x050203E0 (0x3ff837003e0): 0x00000000
    Read at address  0x050203E4 (0x3ffb3b203e4): 0x00000000
    Read at address  0x050203E8 (0x3ff854503e8): 0x00000000
    Read at address  0x050203EC (0x3ffbbab03ec): 0x00000000
    Read at address  0x050203F0 (0x3ffbcb803f0): 0x00000000
    Read at address  0x050203F4 (0x3ff9f4703f4): 0x00000000
    Read at address  0x050203F8 (0x3ff81ca03f8): 0x00000000
    Read at address  0x050203FC (0x3ff812903fc): 0x00000000
    Read at address  0x05020400 (0x3ffaf6d0400): 0x698B4803
    Read at address  0x05020404 (0x3ff7f810404): 0x00000000
    Read at address  0x05020408 (0x3ffac0d0408): 0x18100000
    Read at address  0x0502040C (0x3ff9b27040c): 0xA2800000
    Read at address  0x05020410 (0x3ff98620410): 0x00000000
    Read at address  0x05020414 (0x3ff9fca0414): 0x00000000
    Read at address  0x05020418 (0x3ff98b80418): 0x00000000
    Read at address  0x0502041C (0x3ffa55e041c): 0x00000000
    Read at address  0x05020420 (0x3ff96bd0420): 0x00000000
    Read at address  0x05020424 (0x3ffb5c60424): 0x00000000
    Read at address  0x05020428 (0x3ff81f80428): 0x00000000
    Read at address  0x0502042C (0x3ffa2ba042c): 0x00000000
    Read at address  0x05020430 (0x3ff956b0430): 0x00000000
    Read at address  0x05020434 (0x3ffa87e0434): 0x00000000
    Read at address  0x05020438 (0x3ff88c70438): 0x00000000
    Read at address  0x0502043C (0x3ffaf8f043c): 0x00000000
    Read at address  0x05020440 (0x3ffa4880440): 0x00000000
    Read at address  0x05020444 (0x3ffbbab0444): 0x00000000
    Read at address  0x05020448 (0x3ffa1800448): 0x00000000
    Read at address  0x0502044C (0x3ff9000044c): 0x00000000
    Read at address  0x05020450 (0x3ff87960450): 0x00000000
    Read at address  0x05020454 (0x3ff7fdc0454): 0x00000000
    Read at address  0x05020458 (0x3ffb4690458): 0x00000000
    Read at address  0x0502045C (0x3ffa9ee045c): 0x00000000
    Read at address  0x05020460 (0x3ffb3f90460): 0x00000000
    Read at address  0x05020464 (0x3ffb5760464): 0x00000000
    Read at address  0x05020468 (0x3ffa79d0468): 0x00000000
    Read at address  0x0502046C (0x3ff8102046c): 0x00000000
    Read at address  0x05020470 (0x3ff88ab0470): 0x00000000
    Read at address  0x05020474 (0x3ffa6dd0474): 0x00000000
    Read at address  0x05020478 (0x3ffbda80478): 0x00000000
    Read at address  0x0502047C (0x3ffac80047c): 0x00000000
    Read at address  0x05020480 (0x3ff98510480): 0x70800000
    Read at address  0x05020484 (0x3ff94ad0484): 0x00010002
    Read at address  0x05020488 (0x3ff8b2e0488): 0x00000107
    Read at address  0x0502048C (0x3ffa694048c): 0x00000002
    Read at address  0x05020490 (0x3ff910e0490): 0x00000000
    Read at address  0x05020494 (0x3ff8bb70494): 0x00000000
    Read at address  0x05020498 (0x3ffa3c60498): 0x00000000
    Read at address  0x0502049C (0x3ff7f86049c): 0x00000000
    Read at address  0x050204A0 (0x3ff995504a0): 0x00000000
    Read at address  0x050204A4 (0x3ffa5f304a4): 0x00000000
    Read at address  0x050204A8 (0x3ff926804a8): 0x00000000
    Read at address  0x050204AC (0x3ff8d6104ac): 0x00000000
    Read at address  0x050204B0 (0x3ff89d404b0): 0x00000000
    Read at address  0x050204B4 (0x3ff86cf04b4): 0x00000000
    Read at address  0x050204B8 (0x3ffa8dc04b8): 0x00000000
    Read at address  0x050204BC (0x3ff9ac404bc): 0x00000000
    Read at address  0x050204C0 (0x3ff945104c0): 0x70800000
    Read at address  0x050204C4 (0x3ffb77e04c4): 0x00010002
    Read at address  0x050204C8 (0x3ffb6dd04c8): 0x00000100
    Read at address  0x050204CC (0x3ffa74904cc): 0x00000002
    Read at address  0x050204D0 (0x3ff863f04d0): 0x00000000
    Read at address  0x050204D4 (0x3ffbd1604d4): 0x00000000
    Read at address  0x050204D8 (0x3ff7f5704d8): 0x00000000
    Read at address  0x050204DC (0x3ffa1d104dc): 0x00000000
    Read at address  0x050204E0 (0x3ff876104e0): 0x00000000
    Read at address  0x050204E4 (0x3ffba6404e4): 0x00000000
    Read at address  0x050204E8 (0x3ffadbf04e8): 0x00000000
    Read at address  0x050204EC (0x3ff943604ec): 0x00000000
    Read at address  0x050204F0 (0x3ff9a9d04f0): 0x00000000
    Read at address  0x050204F4 (0x3ffa53a04f4): 0x00000000
    Read at address  0x050204F8 (0x3ffba4e04f8): 0x00000000
    Read at address  0x050204FC (0x3ffa59604fc): 0x00000000
    Read at address  0x05020500 (0x3ff962d0500): 0x70800000
    Read at address  0x05020504 (0x3ffa6d70504): 0x00010002
    Read at address  0x05020508 (0x3ffaf840508): 0x00000105
    Read at address  0x0502050C (0x3ff98d4050c): 0x00000012
    Read at address  0x05020510 (0x3ffbdf80510): 0x00000000
    Read at address  0x05020514 (0x3ffb7270514): 0x00000000
    Read at address  0x05020518 (0x3ffa5730518): 0x00000000
    Read at address  0x0502051C (0x3ff9fc0051c): 0x00000000
    Read at address  0x05020520 (0x3ffb8230520): 0x00000000
    Read at address  0x05020524 (0x3ff99af0524): 0x00000000
    Read at address  0x05020528 (0x3ff900e0528): 0x00000000
    Read at address  0x0502052C (0x3ff8f1e052c): 0x00000000
    Read at address  0x05020530 (0x3ffab780530): 0x00000000
    Read at address  0x05020534 (0x3ff877d0534): 0x00000000
    Read at address  0x05020538 (0x3ffbd560538): 0x00000000
    Read at address  0x0502053C (0x3ff94ac053c): 0x00000000
    Read at address  0x05020540 (0x3ffbd480540): 0x70800000
    Read at address  0x05020544 (0x3ff91bb0544): 0x00010002
    Read at address  0x05020548 (0x3ff8ba00548): 0x00000101
    Read at address  0x0502054C (0x3ff8c3c054c): 0x00000012
    Read at address  0x05020550 (0x3ff831c0550): 0x00000000
    Read at address  0x05020554 (0x3ff804e0554): 0x00000000
    Read at address  0x05020558 (0x3ff82a10558): 0x00000000
    Read at address  0x0502055C (0x3ffb23e055c): 0x00000000
    Read at address  0x05020560 (0x3ff8bf70560): 0x00000000
    Read at address  0x05020564 (0x3ff94d10564): 0x00000000
    Read at address  0x05020568 (0x3ffa0510568): 0x00000000
    Read at address  0x0502056C (0x3ffb7df056c): 0x00000000
    Read at address  0x05020570 (0x3ffaf980570): 0x00000000
    Read at address  0x05020574 (0x3ff9fef0574): 0x00000000
    Read at address  0x05020578 (0x3ffb75b0578): 0x00000000
    Read at address  0x0502057C (0x3ffa6e0057c): 0x00000000
    Read at address  0x05020580 (0x3ffa68c0580): 0x00000000
    Read at address  0x05020584 (0x3ff9d550584): 0x00000000
    Read at address  0x05020588 (0x3ffa4300588): 0x00000000
    Read at address  0x0502058C (0x3ffa292058c): 0x00000000
    Read at address  0x05020590 (0x3ffb6ef0590): 0x00000000
    Read at address  0x05020594 (0x3ffbdb10594): 0x00000000
    Read at address  0x05020598 (0x3ffa7750598): 0x00000000
    Read at address  0x0502059C (0x3ff8c42059c): 0x00000000
    Read at address  0x050205A0 (0x3ffae2905a0): 0x00000000
    Read at address  0x050205A4 (0x3ffbaa605a4): 0x00000000
    Read at address  0x050205A8 (0x3ff857405a8): 0x00000000
    Read at address  0x050205AC (0x3ff954505ac): 0x00000000
    Read at address  0x050205B0 (0x3ffbcfa05b0): 0x00000000
    Read at address  0x050205B4 (0x3ff8d5105b4): 0x00000000
    Read at address  0x050205B8 (0x3ff933305b8): 0x00000000
    Read at address  0x050205BC (0x3ff965b05bc): 0x00000000
    Read at address  0x050205C0 (0x3ffb11305c0): 0x00000000
    Read at address  0x050205C4 (0x3ff99ff05c4): 0x00000000
    Read at address  0x050205C8 (0x3ff944505c8): 0x00000000
    Read at address  0x050205CC (0x3ffa19005cc): 0x00000000
    Read at address  0x050205D0 (0x3ffab1405d0): 0x00000000
    Read at address  0x050205D4 (0x3ff8d4e05d4): 0x00000000
    Read at address  0x050205D8 (0x3ffb4f105d8): 0x00000000
    Read at address  0x050205DC (0x3ff9d4905dc): 0x00000000
    Read at address  0x050205E0 (0x3ff94e005e0): 0x00000000
    Read at address  0x050205E4 (0x3ffb1bf05e4): 0x00000000
    Read at address  0x050205E8 (0x3ffb0b805e8): 0x00000000
    Read at address  0x050205EC (0x3ff8b5005ec): 0x00000000
    Read at address  0x050205F0 (0x3ffb5a605f0): 0x00000000
    Read at address  0x050205F4 (0x3ffadba05f4): 0x00000000
    Read at address  0x050205F8 (0x3ffb2f705f8): 0x00000000
    Read at address  0x050205FC (0x3ff924b05fc): 0x00000000
    Read at address  0x05020600 (0x3ff81be0600): 0x00000000
    Read at address  0x05020604 (0x3ff9d260604): 0x00000000
    Read at address  0x05020608 (0x3ff9ef70608): 0x00000000
    Read at address  0x0502060C (0x3ffb3f3060c): 0x00000000
    Read at address  0x05020610 (0x3ff8a0e0610): 0x00000000
    Read at address  0x05020614 (0x3ff8a490614): 0x00000000
    Read at address  0x05020618 (0x3ffab370618): 0x00000000
    Read at address  0x0502061C (0x3ffba7a061c): 0x00000000
    Read at address  0x05020620 (0x3ffaa0d0620): 0x00000000
    Read at address  0x05020624 (0x3ffb0310624): 0x00000000
    Read at address  0x05020628 (0x3ff8c350628): 0x00000000
    Read at address  0x0502062C (0x3ffbc1c062c): 0x00000000
    Read at address  0x05020630 (0x3ff96050630): 0x00000000
    Read at address  0x05020634 (0x3ff8f990634): 0x00000000
    Read at address  0x05020638 (0x3ff9d090638): 0x00000000
    Read at address  0x0502063C (0x3ff83d0063c): 0x00000000
    Read at address  0x05020640 (0x3ff8b3c0640): 0x00000000
    Read at address  0x05020644 (0x3ffa8da0644): 0x00000000
    Read at address  0x05020648 (0x3ff815b0648): 0x00000000
    Read at address  0x0502064C (0x3ffa56a064c): 0x00000000
    Read at address  0x05020650 (0x3ff95910650): 0x00000000
    Read at address  0x05020654 (0x3ffbc840654): 0x00000000
    Read at address  0x05020658 (0x3ffa3020658): 0x00000000
    Read at address  0x0502065C (0x3ff983f065c): 0x00000000
    Read at address  0x05020660 (0x3ffa4ba0660): 0x00000000
    Read at address  0x05020664 (0x3ff96750664): 0x00000000
    Read at address  0x05020668 (0x3ffa55a0668): 0x00000000
    Read at address  0x0502066C (0x3ff965e066c): 0x00000000
    Read at address  0x05020670 (0x3ff9d8a0670): 0x00000000
    Read at address  0x05020674 (0x3ff9afd0674): 0x00000000
    Read at address  0x05020678 (0x3ffb8760678): 0x00000000
    Read at address  0x0502067C (0x3ffb648067c): 0x00000000
    Read at address  0x05020680 (0x3ff99690680): 0x00000000
    Read at address  0x05020684 (0x3ff9f230684): 0x00000000
    Read at address  0x05020688 (0x3ffadf90688): 0x00000000
    Read at address  0x0502068C (0x3ffb3d4068c): 0x00000000
    Read at address  0x05020690 (0x3ff98fc0690): 0x00000000
    Read at address  0x05020694 (0x3ff97f00694): 0x00000000
    Read at address  0x05020698 (0x3ffb8270698): 0x00000000
    Read at address  0x0502069C (0x3ff8052069c): 0x00000000
    Read at address  0x050206A0 (0x3ff88fb06a0): 0x00000000
    Read at address  0x050206A4 (0x3ff9e2d06a4): 0x00000000
    Read at address  0x050206A8 (0x3ffb38a06a8): 0x00000000
    Read at address  0x050206AC (0x3ffb27306ac): 0x00000000
    Read at address  0x050206B0 (0x3ffbc3306b0): 0x00000000
    Read at address  0x050206B4 (0x3ffb54b06b4): 0x00000000
    Read at address  0x050206B8 (0x3ff9fae06b8): 0x00000000
    Read at address  0x050206BC (0x3ff94db06bc): 0x00000000
    Read at address  0x050206C0 (0x3ffb91f06c0): 0x00000000
    Read at address  0x050206C4 (0x3ffb2eb06c4): 0x00000000
    Read at address  0x050206C8 (0x3ff99a106c8): 0x00000000
    Read at address  0x050206CC (0x3ffb10906cc): 0x00000000
    Read at address  0x050206D0 (0x3ff88b506d0): 0x00000000
    Read at address  0x050206D4 (0x3ff87fd06d4): 0x00000000
    Read at address  0x050206D8 (0x3ff820406d8): 0x00000000
    Read at address  0x050206DC (0x3ff972806dc): 0x00000000
    Read at address  0x050206E0 (0x3ffb40d06e0): 0x00000000
    Read at address  0x050206E4 (0x3ff9ccd06e4): 0x00000000
    Read at address  0x050206E8 (0x3ff7f9706e8): 0x00000000
    Read at address  0x050206EC (0x3ff80ad06ec): 0x00000000
    Read at address  0x050206F0 (0x3ff8df206f0): 0x00000000
    Read at address  0x050206F4 (0x3ffa66706f4): 0x00000000
    Read at address  0x050206F8 (0x3ff993906f8): 0x00000000
    Read at address  0x050206FC (0x3ff99d206fc): 0x00000000
    Read at address  0x05020700 (0x3ffae300700): 0x00000000
    Read at address  0x05020704 (0x3ff9cd60704): 0x00000000
    Read at address  0x05020708 (0x3ff835c0708): 0x00000000
    Read at address  0x0502070C (0x3ffb51d070c): 0x00000000
    Read at address  0x05020710 (0x3ff8d8a0710): 0x00000000
    Read at address  0x05020714 (0x3ff8b640714): 0x00000000
    Read at address  0x05020718 (0x3ffa1100718): 0x00000000
    Read at address  0x0502071C (0x3ff9600071c): 0x00000000
    Read at address  0x05020720 (0x3ffbd7a0720): 0x00000000
    Read at address  0x05020724 (0x3ffa93a0724): 0x00000000
    Read at address  0x05020728 (0x3ff84370728): 0x00000000
    Read at address  0x0502072C (0x3ff9d6e072c): 0x00000000
    Read at address  0x05020730 (0x3ffb95d0730): 0x00000000
    Read at address  0x05020734 (0x3ff91bb0734): 0x00000000
    Read at address  0x05020738 (0x3ff93890738): 0x00000000
    Read at address  0x0502073C (0x3ffb4b1073c): 0x00000000
    Read at address  0x05020740 (0x3ffbbcc0740): 0x00000000
    Read at address  0x05020744 (0x3ff842f0744): 0x00000000
    Read at address  0x05020748 (0x3ffa7d50748): 0x00000000
    Read at address  0x0502074C (0x3ff9141074c): 0x00000000
    Read at address  0x05020750 (0x3ff93760750): 0x00000000
    Read at address  0x05020754 (0x3ff9c600754): 0x00000000
    Read at address  0x05020758 (0x3ff92990758): 0x00000000
    Read at address  0x0502075C (0x3ffb81b075c): 0x00000000
    Read at address  0x05020760 (0x3ffa02b0760): 0x00000000
    Read at address  0x05020764 (0x3ffa67b0764): 0x00000000
    Read at address  0x05020768 (0x3ffaeea0768): 0x00000000
    Read at address  0x0502076C (0x3ffaef0076c): 0x00000000
    Read at address  0x05020770 (0x3ffa48c0770): 0x00000000
    Read at address  0x05020774 (0x3ff8d6a0774): 0x00000000
    Read at address  0x05020778 (0x3ff9be70778): 0x00000000
    Read at address  0x0502077C (0x3ffbb99077c): 0x00000000
    Read at address  0x05020780 (0x3ff8b650780): 0x00000000
    Read at address  0x05020784 (0x3ff9ffb0784): 0x00000000
    Read at address  0x05020788 (0x3ffae130788): 0x00000000
    Read at address  0x0502078C (0x3ff9c07078c): 0x00000000
    Read at address  0x05020790 (0x3ffa6a10790): 0x00000000
    Read at address  0x05020794 (0x3ff9faa0794): 0x00000000
    Read at address  0x05020798 (0x3ff96170798): 0x00000000
    Read at address  0x0502079C (0x3ffb84f079c): 0x00000000
    Read at address  0x050207A0 (0x3ffa5c407a0): 0x00000000
    Read at address  0x050207A4 (0x3ff9c8907a4): 0x00000000
    Read at address  0x050207A8 (0x3ffb93007a8): 0x00000000
    Read at address  0x050207AC (0x3ff9c1f07ac): 0x00000000
    Read at address  0x050207B0 (0x3ffb4ef07b0): 0x00000000
    Read at address  0x050207B4 (0x3ff880807b4): 0x00000000
    Read at address  0x050207B8 (0x3ff94cb07b8): 0x00000000
    Read at address  0x050207BC (0x3ff97d707bc): 0x00000000
    Read at address  0x050207C0 (0x3ffa8f807c0): 0x00000000
    Read at address  0x050207C4 (0x3ffb7ab07c4): 0x00000000
    Read at address  0x050207C8 (0x3ffbcc507c8): 0x00000000
    Read at address  0x050207CC (0x3ffafc707cc): 0x00000000
    Read at address  0x050207D0 (0x3ffb01c07d0): 0x00000000
    Read at address  0x050207D4 (0x3ff86ce07d4): 0x00000000
    Read at address  0x050207D8 (0x3ff8a8a07d8): 0x00000000
    Read at address  0x050207DC (0x3ff942007dc): 0x00000000
    Read at address  0x050207E0 (0x3ffaafd07e0): 0x00000000
    Read at address  0x050207E4 (0x3ffb22c07e4): 0x00000000
    Read at address  0x050207E8 (0x3ffbe1607e8): 0x00000000
    Read at address  0x050207EC (0x3ff86c207ec): 0x00000000
    Read at address  0x050207F0 (0x3ffa62107f0): 0x00000000
    Read at address  0x050207F4 (0x3ffb59607f4): 0x00000000
    Read at address  0x050207F8 (0x3ffbada07f8): 0x00000000
    Read at address  0x050207FC (0x3ffb16607fc): 0x00000000
    Read at address  0x05020800 (0x3ff90130800): 0x00000000
    Read at address  0x05020804 (0x3ff91900804): 0x00000000
    Read at address  0x05020808 (0x3ffb0870808): 0x00000000
    Read at address  0x0502080C (0x3ffa68d080c): 0x00000000
    Read at address  0x05020810 (0x3ff88b60810): 0x00000000
    Read at address  0x05020814 (0x3ff8a700814): 0x00000000
    Read at address  0x05020818 (0x3ffac270818): 0x00000000
    Read at address  0x0502081C (0x3ffab3a081c): 0x00000000
    Read at address  0x05020820 (0x3ff80df0820): 0x00000000
    Read at address  0x05020824 (0x3ff871f0824): 0x00000000
    Read at address  0x05020828 (0x3ff83240828): 0x00000000
    Read at address  0x0502082C (0x3ff9d10082c): 0x00000000
    Read at address  0x05020830 (0x3ffa96f0830): 0x00000000
    Read at address  0x05020834 (0x3ff96120834): 0x00000000
    Read at address  0x05020838 (0x3ff841e0838): 0x00000000
    Read at address  0x0502083C (0x3ffb402083c): 0x00000000
    Read at address  0x05020840 (0x3ff99920840): 0x00000000
    Read at address  0x05020844 (0x3ff97aa0844): 0x00000000
    Read at address  0x05020848 (0x3ff9c290848): 0x00000000
    Read at address  0x0502084C (0x3ff899a084c): 0x00000000
    Read at address  0x05020850 (0x3ffb6f00850): 0x00000000
    Read at address  0x05020854 (0x3ff999c0854): 0x00000000
    Read at address  0x05020858 (0x3ffbd270858): 0x00000000
    Read at address  0x0502085C (0x3ff8540085c): 0x00000000
    Read at address  0x05020860 (0x3ff88740860): 0x00000000
    Read at address  0x05020864 (0x3ffb68e0864): 0x00000000
    Read at address  0x05020868 (0x3ffbb9a0868): 0x00000000
    Read at address  0x0502086C (0x3ffab5a086c): 0x00000000
    Read at address  0x05020870 (0x3ff88540870): 0x00000000
    Read at address  0x05020874 (0x3ff9ad00874): 0x00000000
    Read at address  0x05020878 (0x3ffb9110878): 0x00000000
    Read at address  0x0502087C (0x3ff8e63087c): 0x00000000
    Read at address  0x05020880 (0x3ffbaae0880): 0x00000000
    Read at address  0x05020884 (0x3ffa5bd0884): 0x00000000
    Read at address  0x05020888 (0x3ffa69d0888): 0x00000000
    Read at address  0x0502088C (0x3ffbb6a088c): 0x00000000
    Read at address  0x05020890 (0x3ff923a0890): 0x00000000
    Read at address  0x05020894 (0x3ff9c9d0894): 0x00000000
    Read at address  0x05020898 (0x3ffacd20898): 0x00000000
    Read at address  0x0502089C (0x3ff847f089c): 0x00000000
    Read at address  0x050208A0 (0x3ff8ae208a0): 0x00000000
    Read at address  0x050208A4 (0x3ffa9bd08a4): 0x00000000
    Read at address  0x050208A8 (0x3ff9f2608a8): 0x00000000
    Read at address  0x050208AC (0x3ffb87f08ac): 0x00000000
    Read at address  0x050208B0 (0x3ff930308b0): 0x00000000
    Read at address  0x050208B4 (0x3ff962908b4): 0x00000000
    Read at address  0x050208B8 (0x3ffa29008b8): 0x00000000
    Read at address  0x050208BC (0x3ff980508bc): 0x00000000
    Read at address  0x050208C0 (0x3ffb9b408c0): 0x00000000
    Read at address  0x050208C4 (0x3ff8a8a08c4): 0x00000000
    Read at address  0x050208C8 (0x3ff958608c8): 0x00000000
    Read at address  0x050208CC (0x3ffa21f08cc): 0x00000000
    Read at address  0x050208D0 (0x3ff841608d0): 0x00000000
    Read at address  0x050208D4 (0x3ffb0f108d4): 0x00000000
    Read at address  0x050208D8 (0x3ff8de408d8): 0x00000000
    Read at address  0x050208DC (0x3ffbc7708dc): 0x00000000
    Read at address  0x050208E0 (0x3ff9e1308e0): 0x00000000
    Read at address  0x050208E4 (0x3ff944108e4): 0x00000000
    Read at address  0x050208E8 (0x3ffb9be08e8): 0x00000000
    Read at address  0x050208EC (0x3ffa9d208ec): 0x00000000
    Read at address  0x050208F0 (0x3ffb2f508f0): 0x00000000
    Read at address  0x050208F4 (0x3ff9d9c08f4): 0x00000000
    Read at address  0x050208F8 (0x3ff909408f8): 0x00000000
    Read at address  0x050208FC (0x3ff9a6d08fc): 0x00000000
    Read at address  0x05020900 (0x3ffadef0900): 0x00000000
    Read at address  0x05020904 (0x3ff82f60904): 0x00000000
    Read at address  0x05020908 (0x3ffae3e0908): 0x00000000
    Read at address  0x0502090C (0x3ff9039090c): 0x00000000
    Read at address  0x05020910 (0x3ffb8160910): 0x00000000
    Read at address  0x05020914 (0x3ff94aa0914): 0x00000000
    Read at address  0x05020918 (0x3ff9f3a0918): 0x00000000
    Read at address  0x0502091C (0x3ffaec5091c): 0x00000000
    Read at address  0x05020920 (0x3ff862b0920): 0x00000000
    Read at address  0x05020924 (0x3ff80880924): 0x00000000
    Read at address  0x05020928 (0x3ff90550928): 0x00000000
    Read at address  0x0502092C (0x3ffab81092c): 0x00000000
    Read at address  0x05020930 (0x3ffbe5e0930): 0x00000000
    Read at address  0x05020934 (0x3ff97580934): 0x00000000
    Read at address  0x05020938 (0x3ffbad60938): 0x00000000
    Read at address  0x0502093C (0x3ff8f81093c): 0x00000000
    Read at address  0x05020940 (0x3ff85a40940): 0x00000000
    Read at address  0x05020944 (0x3ff7ea00944): 0x00000000
    Read at address  0x05020948 (0x3ffbac60948): 0x00000000
    Read at address  0x0502094C (0x3ffb301094c): 0x00000000
    Read at address  0x05020950 (0x3ff9dcb0950): 0x00000000
    Read at address  0x05020954 (0x3ff8d750954): 0x00000000
    Read at address  0x05020958 (0x3ff7ede0958): 0x00000000
    Read at address  0x0502095C (0x3ff92ee095c): 0x00000000
    Read at address  0x05020960 (0x3ff97160960): 0x00000000
    Read at address  0x05020964 (0x3ff84d60964): 0x00000000
    Read at address  0x05020968 (0x3ff88ba0968): 0x00000000
    Read at address  0x0502096C (0x3ffbb8f096c): 0x00000000
    Read at address  0x05020970 (0x3ffa1040970): 0x00000000
    Read at address  0x05020974 (0x3ffa96a0974): 0x00000000
    Read at address  0x05020978 (0x3ffbc4e0978): 0x00000000
    Read at address  0x0502097C (0x3ff9589097c): 0x00000000
    Read at address  0x05020980 (0x3ffb86e0980): 0x00000000
    Read at address  0x05020984 (0x3ff91650984): 0x00000000
    Read at address  0x05020988 (0x3ff8b5e0988): 0x00000000
    Read at address  0x0502098C (0x3ff8992098c): 0x00000000
    Read at address  0x05020990 (0x3ffb26b0990): 0x00000000
    Read at address  0x05020994 (0x3ffa7f50994): 0x00000000
    Read at address  0x05020998 (0x3ffbb2f0998): 0x00000000
    Read at address  0x0502099C (0x3ff914d099c): 0x00000000
    Read at address  0x050209A0 (0x3ffae9a09a0): 0x00000000
    Read at address  0x050209A4 (0x3ffb91f09a4): 0x00000000
    Read at address  0x050209A8 (0x3ff930c09a8): 0x00000000
    Read at address  0x050209AC (0x3ff954909ac): 0x00000000
    Read at address  0x050209B0 (0x3ff96fc09b0): 0x00000000
    Read at address  0x050209B4 (0x3ff97b609b4): 0x00000000
    Read at address  0x050209B8 (0x3ffb6bf09b8): 0x00000000
    Read at address  0x050209BC (0x3ff9af309bc): 0x00000000
    Read at address  0x050209C0 (0x3ff8bda09c0): 0x00000000
    Read at address  0x050209C4 (0x3ffb8af09c4): 0x00000000
    Read at address  0x050209C8 (0x3ff85af09c8): 0x00000000
    Read at address  0x050209CC (0x3ff8eef09cc): 0x00000000
    Read at address  0x050209D0 (0x3ffae0e09d0): 0x00000000
    Read at address  0x050209D4 (0x3ffab1e09d4): 0x00000000
    Read at address  0x050209D8 (0x3ff9c2009d8): 0x00000000
    Read at address  0x050209DC (0x3ffa01c09dc): 0x00000000
    Read at address  0x050209E0 (0x3ff8f7e09e0): 0x00000000
    Read at address  0x050209E4 (0x3ffb6e609e4): 0x00000000
    Read at address  0x050209E8 (0x3ff8d3609e8): 0x00000000
    Read at address  0x050209EC (0x3ff978109ec): 0x00000000
    Read at address  0x050209F0 (0x3ffb56909f0): 0x00000000
    Read at address  0x050209F4 (0x3ff9e8309f4): 0x00000000
    Read at address  0x050209F8 (0x3ff99ca09f8): 0x00000000
    Read at address  0x050209FC (0x3ffb88309fc): 0x00000000
    Read at address  0x05020A00 (0x3ffaaa00a00): 0x00000000
    Read at address  0x05020A04 (0x3ff9ccd0a04): 0x00000000
    Read at address  0x05020A08 (0x3ff8b4a0a08): 0x00000000
    Read at address  0x05020A0C (0x3ff86860a0c): 0x00000000
    Read at address  0x05020A10 (0x3ff9dbe0a10): 0x00000000
    Read at address  0x05020A14 (0x3ff9d3a0a14): 0x00000000
    Read at address  0x05020A18 (0x3ff8c810a18): 0x00000000
    Read at address  0x05020A1C (0x3ff936e0a1c): 0x00000000
    Read at address  0x05020A20 (0x3ff9d980a20): 0x00000000
    Read at address  0x05020A24 (0x3ff92010a24): 0x00000000
    Read at address  0x05020A28 (0x3ffb8c60a28): 0x00000000
    Read at address  0x05020A2C (0x3ff9ef40a2c): 0x00000000
    Read at address  0x05020A30 (0x3ffba960a30): 0x00000000
    Read at address  0x05020A34 (0x3ffbaba0a34): 0x00000000
    Read at address  0x05020A38 (0x3ff846a0a38): 0x00000000
    Read at address  0x05020A3C (0x3ff86880a3c): 0x00000000
    Read at address  0x05020A40 (0x3ffa3d00a40): 0x00000000
    Read at address  0x05020A44 (0x3ff9e7a0a44): 0x00000000
    Read at address  0x05020A48 (0x3ff9eed0a48): 0x00000000
    Read at address  0x05020A4C (0x3ffba280a4c): 0x00000000
    Read at address  0x05020A50 (0x3ffba120a50): 0x00000000
    Read at address  0x05020A54 (0x3ffaf960a54): 0x00000000
    Read at address  0x05020A58 (0x3ffa1f30a58): 0x00000000
    Read at address  0x05020A5C (0x3ffa7cd0a5c): 0x00000000
    Read at address  0x05020A60 (0x3ffafac0a60): 0x00000000
    Read at address  0x05020A64 (0x3ff81610a64): 0x00000000
    Read at address  0x05020A68 (0x3ffbe090a68): 0x00000000
    Read at address  0x05020A6C (0x3ff8c180a6c): 0x00000000
    Read at address  0x05020A70 (0x3ffae880a70): 0x00000000
    Read at address  0x05020A74 (0x3ffb5410a74): 0x00000000
    Read at address  0x05020A78 (0x3ff95da0a78): 0x00000000
    Read at address  0x05020A7C (0x3ff91870a7c): 0x00000000
    Read at address  0x05020A80 (0x3ffb7570a80): 0x00000000
    Read at address  0x05020A84 (0x3ffbc5d0a84): 0x00000000
    Read at address  0x05020A88 (0x3ffbb490a88): 0x00000000
    Read at address  0x05020A8C (0x3ffb8980a8c): 0x00000000
    Read at address  0x05020A90 (0x3ffa2120a90): 0x00000000
    Read at address  0x05020A94 (0x3ffb6a50a94): 0x00000000
    Read at address  0x05020A98 (0x3ffa6cf0a98): 0x00000000
    Read at address  0x05020A9C (0x3ffa4f00a9c): 0x00000000
    Read at address  0x05020AA0 (0x3ff9ee90aa0): 0x00000000
    Read at address  0x05020AA4 (0x3ff97fa0aa4): 0x00000000
    Read at address  0x05020AA8 (0x3ff9b280aa8): 0x00000000
    Read at address  0x05020AAC (0x3ff94d30aac): 0x00000000
    Read at address  0x05020AB0 (0x3ff9ad60ab0): 0x00000000
    Read at address  0x05020AB4 (0x3ff90780ab4): 0x00000000
    Read at address  0x05020AB8 (0x3ff82fb0ab8): 0x00000000
    Read at address  0x05020ABC (0x3ff97330abc): 0x00000000
    Read at address  0x05020AC0 (0x3ffbe690ac0): 0x00000000
    Read at address  0x05020AC4 (0x3ff85860ac4): 0x00000000
    Read at address  0x05020AC8 (0x3ff8fb60ac8): 0x00000000
    Read at address  0x05020ACC (0x3ff93c00acc): 0x00000000
    Read at address  0x05020AD0 (0x3ffa4750ad0): 0x00000000
    Read at address  0x05020AD4 (0x3ffa0f10ad4): 0x00000000
    Read at address  0x05020AD8 (0x3ffbb120ad8): 0x00000000
    Read at address  0x05020ADC (0x3ff91b10adc): 0x00000000
    Read at address  0x05020AE0 (0x3ff94d00ae0): 0x00000000
    Read at address  0x05020AE4 (0x3ffba5a0ae4): 0x00000000
    Read at address  0x05020AE8 (0x3ff9b390ae8): 0x00000000
    Read at address  0x05020AEC (0x3ffab410aec): 0x00000000
    Read at address  0x05020AF0 (0x3ffa48d0af0): 0x00000000
    Read at address  0x05020AF4 (0x3ffabab0af4): 0x00000000
    Read at address  0x05020AF8 (0x3ff82ca0af8): 0x00000000
    Read at address  0x05020AFC (0x3ffad090afc): 0x00000000
    Read at address  0x05020B00 (0x3ffaa270b00): 0x00000000
    Read at address  0x05020B04 (0x3ffbba60b04): 0x00000000
    Read at address  0x05020B08 (0x3ffacd50b08): 0x00000000
    Read at address  0x05020B0C (0x3ffa65a0b0c): 0x00000000
    Read at address  0x05020B10 (0x3ffa91b0b10): 0x00000000
    Read at address  0x05020B14 (0x3ffae340b14): 0x00000000
    Read at address  0x05020B18 (0x3ff82bb0b18): 0x00000000
    Read at address  0x05020B1C (0x3ff9c4c0b1c): 0x00000000
    Read at address  0x05020B20 (0x3ffb95a0b20): 0x00000000
    Read at address  0x05020B24 (0x3ffb78c0b24): 0x00000000
    Read at address  0x05020B28 (0x3ffb5ff0b28): 0x00000000
    Read at address  0x05020B2C (0x3ff984f0b2c): 0x00000000
    Read at address  0x05020B30 (0x3ffa3190b30): 0x00000000
    Read at address  0x05020B34 (0x3ff94720b34): 0x00000000
    Read at address  0x05020B38 (0x3ffb19c0b38): 0x00000000
    Read at address  0x05020B3C (0x3ff9f310b3c): 0x00000000
    Read at address  0x05020B40 (0x3ffa3170b40): 0x00000000
    Read at address  0x05020B44 (0x3ff95710b44): 0x00000000
    Read at address  0x05020B48 (0x3ffa7930b48): 0x00000000
    Read at address  0x05020B4C (0x3ff8f560b4c): 0x00000000
    Read at address  0x05020B50 (0x3ffaada0b50): 0x00000000
    Read at address  0x05020B54 (0x3ffa0be0b54): 0x00000000
    Read at address  0x05020B58 (0x3ff946a0b58): 0x00000000
    Read at address  0x05020B5C (0x3ffb4210b5c): 0x00000000
    Read at address  0x05020B60 (0x3ff97b20b60): 0x00000000
    Read at address  0x05020B64 (0x3ff81e00b64): 0x00000000
    Read at address  0x05020B68 (0x3ff8baf0b68): 0x00000000
    Read at address  0x05020B6C (0x3ffbd210b6c): 0x00000000
    Read at address  0x05020B70 (0x3ff94fc0b70): 0x00000000
    Read at address  0x05020B74 (0x3ffbd020b74): 0x00000000
    Read at address  0x05020B78 (0x3ff88050b78): 0x00000000
    Read at address  0x05020B7C (0x3ff907a0b7c): 0x00000000
    Read at address  0x05020B80 (0x3ff95630b80): 0x00000000
    Read at address  0x05020B84 (0x3ffb25a0b84): 0x00000000
    Read at address  0x05020B88 (0x3ffb7530b88): 0x00000000
    Read at address  0x05020B8C (0x3ff998e0b8c): 0x00000000
    Read at address  0x05020B90 (0x3ff935b0b90): 0x00000000
    Read at address  0x05020B94 (0x3ffb5eb0b94): 0x00000000
    Read at address  0x05020B98 (0x3ffb86c0b98): 0x00000000
    Read at address  0x05020B9C (0x3ff92530b9c): 0x00000000
    Read at address  0x05020BA0 (0x3ff9c6d0ba0): 0x00000000
    Read at address  0x05020BA4 (0x3ffa2e90ba4): 0x00000000
    Read at address  0x05020BA8 (0x3ffb4310ba8): 0x00000000
    Read at address  0x05020BAC (0x3ffa2f70bac): 0x00000000
    Read at address  0x05020BB0 (0x3ffb27c0bb0): 0x00000000
    Read at address  0x05020BB4 (0x3ff9e8d0bb4): 0x00000000
    Read at address  0x05020BB8 (0x3ffa66d0bb8): 0x00000000
    Read at address  0x05020BBC (0x3ff9ae10bbc): 0x00000000
    Read at address  0x05020BC0 (0x3ff94bd0bc0): 0x00000000
    Read at address  0x05020BC4 (0x3ffa75b0bc4): 0x00000000
    Read at address  0x05020BC8 (0x3ffb8bd0bc8): 0x00000000
    Read at address  0x05020BCC (0x3ff7f350bcc): 0x00000000
    Read at address  0x05020BD0 (0x3ff99ee0bd0): 0x00000000
    Read at address  0x05020BD4 (0x3ff9ae60bd4): 0x00000000
    Read at address  0x05020BD8 (0x3ffa4ac0bd8): 0x00000000
    Read at address  0x05020BDC (0x3ff98a30bdc): 0x00000000
    Read at address  0x05020BE0 (0x3ff94880be0): 0x00000000
    Read at address  0x05020BE4 (0x3ff88cb0be4): 0x00000000
    Read at address  0x05020BE8 (0x3ffa5980be8): 0x00000000
    Read at address  0x05020BEC (0x3ffb3910bec): 0x00000000
    Read at address  0x05020BF0 (0x3ffb6b10bf0): 0x00000000
    Read at address  0x05020BF4 (0x3ffa6070bf4): 0x00000000
    Read at address  0x05020BF8 (0x3ffad240bf8): 0x00000000
    Read at address  0x05020BFC (0x3ffa3a70bfc): 0x00000000
    Read at address  0x05020C00 (0x3ffba320c00): 0x00000000
    Read at address  0x05020C04 (0x3ffa58f0c04): 0x00000000
    Read at address  0x05020C08 (0x3ffb6970c08): 0x00000000
    Read at address  0x05020C0C (0x3ff9c970c0c): 0x00000000
    Read at address  0x05020C10 (0x3ffa0ad0c10): 0x00000000
    Read at address  0x05020C14 (0x3ffbb9d0c14): 0x00000000
    Read at address  0x05020C18 (0x3ff89860c18): 0x00000000
    Read at address  0x05020C1C (0x3ff8a350c1c): 0x00000000
    Read at address  0x05020C20 (0x3ff7fe50c20): 0x00000000
    Read at address  0x05020C24 (0x3ffb03e0c24): 0x00000000
    Read at address  0x05020C28 (0x3ff8be10c28): 0x00000000
    Read at address  0x05020C2C (0x3ff90cd0c2c): 0x00000000
    Read at address  0x05020C30 (0x3ff88d60c30): 0x00000000
    Read at address  0x05020C34 (0x3ff85aa0c34): 0x00000000
    Read at address  0x05020C38 (0x3ff9fc20c38): 0x00000000
    Read at address  0x05020C3C (0x3ffa3c50c3c): 0x00000000
    Read at address  0x05020C40 (0x3ff9f840c40): 0x00000000
    Read at address  0x05020C44 (0x3ff8cdb0c44): 0x00000000
    Read at address  0x05020C48 (0x3ff85990c48): 0x00000000
    Read at address  0x05020C4C (0x3ffaea00c4c): 0x00000000
    Read at address  0x05020C50 (0x3ffbbd90c50): 0x00000000
    Read at address  0x05020C54 (0x3ffa2d50c54): 0x00000000
    Read at address  0x05020C58 (0x3ff87200c58): 0x00000000
    Read at address  0x05020C5C (0x3ffa3890c5c): 0x00000000
    Read at address  0x05020C60 (0x3ff7edb0c60): 0x00000000
    Read at address  0x05020C64 (0x3ff94fe0c64): 0x00000000
    Read at address  0x05020C68 (0x3ffa1cf0c68): 0x00000000
    Read at address  0x05020C6C (0x3ffb11c0c6c): 0x00000000
    Read at address  0x05020C70 (0x3ffa61d0c70): 0x00000000
    Read at address  0x05020C74 (0x3ff9fd10c74): 0x00000000
    Read at address  0x05020C78 (0x3ff95770c78): 0x00000000
    Read at address  0x05020C7C (0x3ffba1c0c7c): 0x00000000
    Read at address  0x05020C80 (0x3ff83740c80): 0x00000000
    Read at address  0x05020C84 (0x3ff8d5b0c84): 0x00000000
    Read at address  0x05020C88 (0x3ffbd4a0c88): 0x00000000
    Read at address  0x05020C8C (0x3ffa82c0c8c): 0x00000000
    Read at address  0x05020C90 (0x3ff852a0c90): 0x00000000
    Read at address  0x05020C94 (0x3ffb4550c94): 0x00000000
    Read at address  0x05020C98 (0x3ff921a0c98): 0x00000000
    Read at address  0x05020C9C (0x3ff7e8e0c9c): 0x00000000
    Read at address  0x05020CA0 (0x3ffb6a90ca0): 0x00000000
    Read at address  0x05020CA4 (0x3ff92590ca4): 0x00000000
    Read at address  0x05020CA8 (0x3ff95300ca8): 0x00000000
    Read at address  0x05020CAC (0x3ffb8550cac): 0x00000000
    Read at address  0x05020CB0 (0x3ffab660cb0): 0x00000000
    Read at address  0x05020CB4 (0x3ffaaa40cb4): 0x00000000
    Read at address  0x05020CB8 (0x3ff9f5e0cb8): 0x00000000
    Read at address  0x05020CBC (0x3ff87c10cbc): 0x00000000
    Read at address  0x05020CC0 (0x3ff9a1d0cc0): 0x00000000
    Read at address  0x05020CC4 (0x3ffb0200cc4): 0x00000000
    Read at address  0x05020CC8 (0x3ffa6b30cc8): 0x00000000
    Read at address  0x05020CCC (0x3ffb3d90ccc): 0x00000000
    Read at address  0x05020CD0 (0x3ff8dff0cd0): 0x00000000
    Read at address  0x05020CD4 (0x3ff826e0cd4): 0x00000000
    Read at address  0x05020CD8 (0x3ff83a80cd8): 0x00000000
    Read at address  0x05020CDC (0x3ffa7ae0cdc): 0x00000000
    Read at address  0x05020CE0 (0x3ffb2db0ce0): 0x00000000
    Read at address  0x05020CE4 (0x3ffa4840ce4): 0x00000000
    Read at address  0x05020CE8 (0x3ffaecb0ce8): 0x00000000
    Read at address  0x05020CEC (0x3ffa0c00cec): 0x00000000
    Read at address  0x05020CF0 (0x3ff854b0cf0): 0x00000000
    Read at address  0x05020CF4 (0x3ffa29a0cf4): 0x00000000
    Read at address  0x05020CF8 (0x3ffa66c0cf8): 0x00000000
    Read at address  0x05020CFC (0x3ffbad00cfc): 0x00000000
    Read at address  0x05020D00 (0x3ffae3b0d00): 0x00000000
    Read at address  0x05020D04 (0x3ff8d110d04): 0x00000000
    Read at address  0x05020D08 (0x3ff902b0d08): 0x00000000
    Read at address  0x05020D0C (0x3ff8a8e0d0c): 0x00000000
    Read at address  0x05020D10 (0x3ff8fa40d10): 0x00000000
    Read at address  0x05020D14 (0x3ff8fbb0d14): 0x00000000
    Read at address  0x05020D18 (0x3ff97f70d18): 0x00000000
    Read at address  0x05020D1C (0x3ffb5190d1c): 0x00000000
    Read at address  0x05020D20 (0x3ffb1bf0d20): 0x00000000
    Read at address  0x05020D24 (0x3ff990a0d24): 0x00000000
    Read at address  0x05020D28 (0x3ff902b0d28): 0x00000000
    Read at address  0x05020D2C (0x3ff9d0a0d2c): 0x00000000
    Read at address  0x05020D30 (0x3ff9fee0d30): 0x00000000
    Read at address  0x05020D34 (0x3ff948b0d34): 0x00000000
    Read at address  0x05020D38 (0x3ff9b560d38): 0x00000000
    Read at address  0x05020D3C (0x3ffaff10d3c): 0x00000000
    Read at address  0x05020D40 (0x3ff9ec80d40): 0x00000000
    Read at address  0x05020D44 (0x3ffb7f70d44): 0x00000000
    Read at address  0x05020D48 (0x3ffb40c0d48): 0x00000000
    Read at address  0x05020D4C (0x3ffb9290d4c): 0x00000000
    Read at address  0x05020D50 (0x3ffb4120d50): 0x00000000
    Read at address  0x05020D54 (0x3ff957c0d54): 0x00000000
    Read at address  0x05020D58 (0x3ff9fc30d58): 0x00000000
    Read at address  0x05020D5C (0x3ffbaaa0d5c): 0x00000000
    Read at address  0x05020D60 (0x3ff96f10d60): 0x00000000
    Read at address  0x05020D64 (0x3ffb0900d64): 0x00000000
    Read at address  0x05020D68 (0x3ffac590d68): 0x00000000
    Read at address  0x05020D6C (0x3ffa3040d6c): 0x00000000
    Read at address  0x05020D70 (0x3ffb0960d70): 0x00000000
    Read at address  0x05020D74 (0x3ff93130d74): 0x00000000
    Read at address  0x05020D78 (0x3ff97130d78): 0x00000000
    Read at address  0x05020D7C (0x3ff83210d7c): 0x00000000
    Read at address  0x05020D80 (0x3ff81680d80): 0x00000000
    Read at address  0x05020D84 (0x3ffb9a40d84): 0x00000000
    Read at address  0x05020D88 (0x3ff846f0d88): 0x00000000
    Read at address  0x05020D8C (0x3ff86400d8c): 0x00000000
    Read at address  0x05020D90 (0x3ff87820d90): 0x00000000
    Read at address  0x05020D94 (0x3ffb6820d94): 0x00000000
    Read at address  0x05020D98 (0x3ff81b80d98): 0x00000000
    Read at address  0x05020D9C (0x3ffae0a0d9c): 0x00000000
    Read at address  0x05020DA0 (0x3ff89970da0): 0x00000000
    Read at address  0x05020DA4 (0x3ffb8590da4): 0x00000000
    Read at address  0x05020DA8 (0x3ff9e3f0da8): 0x00000000
    Read at address  0x05020DAC (0x3ffa8270dac): 0x00000000
    Read at address  0x05020DB0 (0x3ffb9e10db0): 0x00000000
    Read at address  0x05020DB4 (0x3ffb2cc0db4): 0x00000000
    Read at address  0x05020DB8 (0x3ffab530db8): 0x00000000
    Read at address  0x05020DBC (0x3ffa7450dbc): 0x00000000
    Read at address  0x05020DC0 (0x3ff89c10dc0): 0x00000000
    Read at address  0x05020DC4 (0x3ffb3e40dc4): 0x00000000
    Read at address  0x05020DC8 (0x3ffa4a20dc8): 0x00000000
    Read at address  0x05020DCC (0x3ff896e0dcc): 0x00000000
    Read at address  0x05020DD0 (0x3ffa5dc0dd0): 0x00000000
    Read at address  0x05020DD4 (0x3ffad850dd4): 0x00000000
    Read at address  0x05020DD8 (0x3ff9caa0dd8): 0x00000000
    Read at address  0x05020DDC (0x3ff84890ddc): 0x00000000
    Read at address  0x05020DE0 (0x3ffa2ae0de0): 0x00000000
    Read at address  0x05020DE4 (0x3ff8d4f0de4): 0x00000000
    Read at address  0x05020DE8 (0x3ff8e4f0de8): 0x00000000
    Read at address  0x05020DEC (0x3ff87f40dec): 0x00000000
    Read at address  0x05020DF0 (0x3ff8b860df0): 0x00000000
    Read at address  0x05020DF4 (0x3ffbccc0df4): 0x00000000
    Read at address  0x05020DF8 (0x3ffa8320df8): 0x00000000
    Read at address  0x05020DFC (0x3ffb4e80dfc): 0x00000000
    Read at address  0x05020E00 (0x3ffb7000e00): 0x00000000
    Read at address  0x05020E04 (0x3ffbd2d0e04): 0x00000000
    Read at address  0x05020E08 (0x3ff9e4f0e08): 0x00000000
    Read at address  0x05020E0C (0x3ff8ffc0e0c): 0x00000000
    Read at address  0x05020E10 (0x3ffab160e10): 0x00000000
    Read at address  0x05020E14 (0x3ff81490e14): 0x00000000
    Read at address  0x05020E18 (0x3ff931d0e18): 0x00000000
    Read at address  0x05020E1C (0x3ff98460e1c): 0x00000000
    Read at address  0x05020E20 (0x3ff81a30e20): 0x00000000
    Read at address  0x05020E24 (0x3ffa90b0e24): 0x00000000
    Read at address  0x05020E28 (0x3ff84050e28): 0x00000000
    Read at address  0x05020E2C (0x3ffaf460e2c): 0x00000000
    Read at address  0x05020E30 (0x3ffb6630e30): 0x00000000
    Read at address  0x05020E34 (0x3ff99840e34): 0x00000000
    Read at address  0x05020E38 (0x3ffb8b90e38): 0x00000000
    Read at address  0x05020E3C (0x3ffba020e3c): 0x00000000
    Read at address  0x05020E40 (0x3ffaefe0e40): 0x00000000
    Read at address  0x05020E44 (0x3ff982d0e44): 0x00000000
    Read at address  0x05020E48 (0x3ffa48c0e48): 0x00000000
    Read at address  0x05020E4C (0x3ffada20e4c): 0x00000000
    Read at address  0x05020E50 (0x3ffae760e50): 0x00000000
    Read at address  0x05020E54 (0x3ff88f40e54): 0x00000000
    Read at address  0x05020E58 (0x3ffade10e58): 0x00000000
    Read at address  0x05020E5C (0x3ff8c7e0e5c): 0x00000000
    Read at address  0x05020E60 (0x3ff803c0e60): 0x00000000
    Read at address  0x05020E64 (0x3ffaa910e64): 0x00000000
    Read at address  0x05020E68 (0x3ff9e370e68): 0x00000000
    Read at address  0x05020E6C (0x3ffbc4a0e6c): 0x00000000
    Read at address  0x05020E70 (0x3ff82c60e70): 0x00000000
    Read at address  0x05020E74 (0x3ffb2cf0e74): 0x00000000
    Read at address  0x05020E78 (0x3ffaf8a0e78): 0x00000000
    Read at address  0x05020E7C (0x3ffa6780e7c): 0x00000000
    Read at address  0x05020E80 (0x3ffa2bb0e80): 0x00000000
    Read at address  0x05020E84 (0x3ffba7c0e84): 0x00000000
    Read at address  0x05020E88 (0x3ffa9820e88): 0x00000000
    Read at address  0x05020E8C (0x3ff9e3d0e8c): 0x00000000
    Read at address  0x05020E90 (0x3ff96ad0e90): 0x00000000
    Read at address  0x05020E94 (0x3ff9f390e94): 0x00000000
    Read at address  0x05020E98 (0x3ffaa0f0e98): 0x00000000
    Read at address  0x05020E9C (0x3ffb0420e9c): 0x00000000
    Read at address  0x05020EA0 (0x3ff86940ea0): 0x00000000
    Read at address  0x05020EA4 (0x3ffb3a20ea4): 0x00000000
    Read at address  0x05020EA8 (0x3ff9bc20ea8): 0x00000000
    Read at address  0x05020EAC (0x3ff8da80eac): 0x00000000
    Read at address  0x05020EB0 (0x3ffa5a70eb0): 0x00000000
    Read at address  0x05020EB4 (0x3ff85ea0eb4): 0x00000000
    Read at address  0x05020EB8 (0x3ffb4e40eb8): 0x00000000
    Read at address  0x05020EBC (0x3ffa3660ebc): 0x00000000
    Read at address  0x05020EC0 (0x3ff9a8e0ec0): 0x00000000
    Read at address  0x05020EC4 (0x3ffb22e0ec4): 0x00000000
    Read at address  0x05020EC8 (0x3ff84860ec8): 0x00000000
    Read at address  0x05020ECC (0x3ffa6570ecc): 0x00000000
    Read at address  0x05020ED0 (0x3ff9f850ed0): 0x00000000
    Read at address  0x05020ED4 (0x3ffbb8a0ed4): 0x00000000
    Read at address  0x05020ED8 (0x3ff8ae30ed8): 0x00000000
    Read at address  0x05020EDC (0x3ffa1270edc): 0x00000000
    Read at address  0x05020EE0 (0x3ff9cd80ee0): 0x00000000
    Read at address  0x05020EE4 (0x3ffbcd20ee4): 0x00000000
    Read at address  0x05020EE8 (0x3ffba2d0ee8): 0x00000000
    Read at address  0x05020EEC (0x3ffae620eec): 0x00000000
    Read at address  0x05020EF0 (0x3ff7f760ef0): 0x00000000
    Read at address  0x05020EF4 (0x3ff8f3a0ef4): 0x00000000
    Read at address  0x05020EF8 (0x3ffaebf0ef8): 0x00000000
    Read at address  0x05020EFC (0x3ffbb9f0efc): 0x00000000
    Read at address  0x05020F00 (0x3ffaa310f00): 0x00000000
    Read at address  0x05020F04 (0x3ff91bc0f04): 0x00000000
    Read at address  0x05020F08 (0x3ff9cba0f08): 0x00000000
    Read at address  0x05020F0C (0x3ffad800f0c): 0x00000000
    Read at address  0x05020F10 (0x3ffaa9b0f10): 0x00000000
    Read at address  0x05020F14 (0x3ff97860f14): 0x00000000
    Read at address  0x05020F18 (0x3ffa3ce0f18): 0x00000000
    Read at address  0x05020F1C (0x3ffa8940f1c): 0x00000000
    Read at address  0x05020F20 (0x3ffbab50f20): 0x00000000
    Read at address  0x05020F24 (0x3ffbd1d0f24): 0x00000000
    Read at address  0x05020F28 (0x3ffb62c0f28): 0x00000000
    Read at address  0x05020F2C (0x3ffaa950f2c): 0x00000000
    Read at address  0x05020F30 (0x3ff91d40f30): 0x00000000
    Read at address  0x05020F34 (0x3ffa5c80f34): 0x00000000
    Read at address  0x05020F38 (0x3ff8c770f38): 0x00000000
    Read at address  0x05020F3C (0x3ff9e1b0f3c): 0x00000000
    Read at address  0x05020F40 (0x3ffa9a60f40): 0x00000000
    Read at address  0x05020F44 (0x3ffaabb0f44): 0x00000000
    Read at address  0x05020F48 (0x3ff84770f48): 0x00000000
    Read at address  0x05020F4C (0x3ff7ea50f4c): 0x00000000
    Read at address  0x05020F50 (0x3ff92bc0f50): 0x00000000
    Read at address  0x05020F54 (0x3ff91220f54): 0x00000000
    Read at address  0x05020F58 (0x3ff92340f58): 0x00000000
    Read at address  0x05020F5C (0x3ff88a90f5c): 0x00000000
    Read at address  0x05020F60 (0x3ffb0360f60): 0x00000000
    Read at address  0x05020F64 (0x3ffa13b0f64): 0x00000000
    Read at address  0x05020F68 (0x3ffb1fc0f68): 0x00000000
    Read at address  0x05020F6C (0x3ff94110f6c): 0x00000000
    Read at address  0x05020F70 (0x3ffba7f0f70): 0x00000000
    Read at address  0x05020F74 (0x3ffa6740f74): 0x00000000
    Read at address  0x05020F78 (0x3ff9c210f78): 0x00000000
    Read at address  0x05020F7C (0x3ff9a770f7c): 0x00000000
    Read at address  0x05020F80 (0x3ff83630f80): 0x00000000
    Read at address  0x05020F84 (0x3ff7f6e0f84): 0x00000000
    Read at address  0x05020F88 (0x3ffa0d80f88): 0x00000000
    Read at address  0x05020F8C (0x3ff80f30f8c): 0x00000000
    Read at address  0x05020F90 (0x3ff9f5d0f90): 0x00000000
    Read at address  0x05020F94 (0x3ffb83a0f94): 0x00000000
    Read at address  0x05020F98 (0x3ff8b5d0f98): 0x00000000
    Read at address  0x05020F9C (0x3ffa0140f9c): 0x00000000
    Read at address  0x05020FA0 (0x3ff922c0fa0): 0x00000000
    Read at address  0x05020FA4 (0x3ff8a850fa4): 0x00000000
    Read at address  0x05020FA8 (0x3ffab470fa8): 0x00000000
    Read at address  0x05020FAC (0x3ff9f290fac): 0x00000000
    Read at address  0x05020FB0 (0x3ff96ea0fb0): 0x00000000
    Read at address  0x05020FB4 (0x3ff9ec30fb4): 0x00000000
    Read at address  0x05020FB8 (0x3ff8aa70fb8): 0x00000000
    Read at address  0x05020FBC (0x3ffaf550fbc): 0x00000000
    Read at address  0x05020FC0 (0x3ffa6580fc0): 0x00000000
    Read at address  0x05020FC4 (0x3ffb92e0fc4): 0x00000000
    Read at address  0x05020FC8 (0x3ff7ed60fc8): 0x00000000
    Read at address  0x05020FCC (0x3ff95970fcc): 0x00000000
    Read at address  0x05020FD0 (0x3ff80410fd0): 0x00000000
    Read at address  0x05020FD4 (0x3ff85470fd4): 0x00000000
    Read at address  0x05020FD8 (0x3ffa6c20fd8): 0x00000000
    Read at address  0x05020FDC (0x3ffb09d0fdc): 0x00000000
    Read at address  0x05020FE0 (0x3ff7fe00fe0): 0x00000000
    Read at address  0x05020FE4 (0x3ff94ef0fe4): 0x00000000
    Read at address  0x05020FE8 (0x3ffb4410fe8): 0x00000000
    Read at address  0x05020FEC (0x3ffaf0d0fec): 0x00000000
    Read at address  0x05020FF0 (0x3ffa7b00ff0): 0x00000000
    Read at address  0x05020FF4 (0x3ffb57e0ff4): 0x00000000
    Read at address  0x05020FF8 (0x3ff87830ff8): 0x00000000
    Read at address  0x05020FFC (0x3ffa5f90ffc): 0x00000000
    root@megatron:/data#
    2)执行n‘t 添加 RTOS SerDes 配置,SGMII 未链接
    serdes2寄存器转储:
    root@megatron:/data# ./test.sh
    Read at address  0x05020000 (0x3ffaa440000): 0x00007364
    Read at address  0x05020004 (0x3ffa16b0004): 0x08010000
    Read at address  0x05020008 (0x3ffb1880008): 0x00000130
    Read at address  0x0502000C (0x3ff9813000c): 0x00000000
    Read at address  0x05020010 (0x3ff8ebe0010): 0x00160074
    Read at address  0x05020014 (0x3ff8cda0014): 0x63006666
    Read at address  0x05020018 (0x3ffa8ce0018): 0x02020120
    Read at address  0x0502001C (0x3ff9c92001c): 0x00000000
    Read at address  0x05020020 (0x3ff8af00020): 0x00041020
    Read at address  0x05020024 (0x3ff84340024): 0x00200000
    Read at address  0x05020028 (0x3ff85500028): 0x00000155
    Read at address  0x0502002C (0x3ff89d4002c): 0x00000000
    Read at address  0x05020030 (0x3ff9b6b0030): 0x00000000
    Read at address  0x05020034 (0x3ffa9ef0034): 0x00000000
    Read at address  0x05020038 (0x3ffb2910038): 0x00000000
    Read at address  0x0502003C (0x3ff8756003c): 0x00000000
    Read at address  0x05020040 (0x3ff9b4b0040): 0x00010003
    Read at address  0x05020044 (0x3ff99900044): 0x00000019
    Read at address  0x05020048 (0x3ffb9fb0048): 0x00000000
    Read at address  0x0502004C (0x3ff9fb3004c): 0x00010000
    Read at address  0x05020050 (0x3ff85860050): 0x00040001
    Read at address  0x05020054 (0x3ffa5b50054): 0x00010032
    Read at address  0x05020058 (0x3ff83730058): 0x000100D1
    Read at address  0x0502005C (0x3ffaf16005c): 0x00000000
    Read at address  0x05020060 (0x3ff88890060): 0x00040001
    Read at address  0x05020064 (0x3ff9c630064): 0x00010032
    Read at address  0x05020068 (0x3ffa73f0068): 0x000100D1
    Read at address  0x0502006C (0x3ffab07006c): 0x00000000
    Read at address  0x05020070 (0x3ff93b60070): 0x00000000
    Read at address  0x05020074 (0x3ffaaa50074): 0x00000000
    Read at address  0x05020078 (0x3ff852a0078): 0x00000000
    Read at address  0x0502007C (0x3ffa4c0007c): 0x00000000
    Read at address  0x05020080 (0x3ff8e870080): 0x01240101
    Read at address  0x05020084 (0x3ffb5fe0084): 0x0124003B
    Read at address  0x05020088 (0x3ffb92f0088): 0x0424003B
    Read at address  0x0502008C (0x3ff9c72008c): 0x012400A6
    Read at address  0x05020090 (0x3ff9d4c0090): 0x0424003B
    Read at address  0x05020094 (0x3ff9e0f0094): 0x000000A4
    Read at address  0x05020098 (0x3ffa8680098): 0x00000108
    Read at address  0x0502009C (0x3ff8cb4009c): 0x00000005
    Read at address  0x050200A0 (0x3ff86c300a0): 0x00000242
    Read at address  0x050200A4 (0x3ff9ae500a4): 0x00000000
    Read at address  0x050200A8 (0x3ffafbf00a8): 0x00000000
    Read at address  0x050200AC (0x3ffb4ac00ac): 0x00000000
    Read at address  0x050200B0 (0x3ffbd2100b0): 0x00000000
    Read at address  0x050200B4 (0x3ff94c500b4): 0x00000000
    Read at address  0x050200B8 (0x3ff9f6a00b8): 0x00030000
    Read at address  0x050200BC (0x3ffbe1600bc): 0x00000000
    Read at address  0x050200C0 (0x3ffb35e00c0): 0x00000000
    Read at address  0x050200C4 (0x3ff876700c4): 0x00000000
    Read at address  0x050200C8 (0x3ff8e2f00c8): 0x007D007D
    Read at address  0x050200CC (0x3ffacf100cc): 0x00000000
    Read at address  0x050200D0 (0x3ff809400d0): 0x00000000
    Read at address  0x050200D4 (0x3ffa99900d4): 0x00000000
    Read at address  0x050200D8 (0x3ffb9f200d8): 0x00000000
    Read at address  0x050200DC (0x3ffba4800dc): 0x00000000
    Read at address  0x050200E0 (0x3ff995400e0): 0x00000000
    Read at address  0x050200E4 (0x3ff8bc600e4): 0x0000001F
    Read at address  0x050200E8 (0x3ff910400e8): 0x00070019
    Read at address  0x050200EC (0x3ffaca900ec): 0x00000000
    Read at address  0x050200F0 (0x3ffb4a000f0): 0x00000000
    Read at address  0x050200F4 (0x3ff90b800f4): 0x00000000
    Read at address  0x050200F8 (0x3ff81d000f8): 0x00000000
    Read at address  0x050200FC (0x3ff8d0900fc): 0x00000000
    Read at address  0x05020100 (0x3ffbaeb0100): 0x2028002A
    Read at address  0x05020104 (0x3ff86470104): 0x00000003
    Read at address  0x05020108 (0x3ff8c8b0108): 0x001003E8
    Read at address  0x0502010C (0x3ff93d2010c): 0x00000C5F
    Read at address  0x05020110 (0x3ff9ab60110): 0x00000C5F
    Read at address  0x05020114 (0x3ff8e520114): 0x00000000
    Read at address  0x05020118 (0x3ff95be0118): 0x00000000
    Read at address  0x0502011C (0x3ffb8eb011c): 0x00000000
    Read at address  0x05020120 (0x3ff9f920120): 0x00000000
    Read at address  0x05020124 (0x3ffb2a40124): 0x00000000
    Read at address  0x05020128 (0x3ff94180128): 0x001E4004
    Read at address  0x0502012C (0x3ffb53e012c): 0x0000000C
    Read at address  0x05020130 (0x3ffab0a0130): 0x00000002
    Read at address  0x05020134 (0x3ffab180134): 0x00000000
    Read at address  0x05020138 (0x3ff93080138): 0x000400C8
    Read at address  0x0502013C (0x3ffa9ba013c): 0x000300C8
    Read at address  0x05020140 (0x3ffae100140): 0x00000000
    Read at address  0x05020144 (0x3ff8b2b0144): 0x00000000
    Read at address  0x05020148 (0x3ff8bb40148): 0x00104004
    Read at address  0x0502014C (0x3ffb7dd014c): 0x00000010
    Read at address  0x05020150 (0x3ffa36d0150): 0x00000002
    Read at address  0x05020154 (0x3ffacb60154): 0x00000000
    Read at address  0x05020158 (0x3ffa7410158): 0x00000000
    Read at address  0x0502015C (0x3ffac59015c): 0x00000000
    Read at address  0x05020160 (0x3ff8bf60160): 0x00000000
    Read at address  0x05020164 (0x3ffa8150164): 0x00000000
    Read at address  0x05020168 (0x3ff8c820168): 0x00000000
    Read at address  0x0502016C (0x3ff8ec8016c): 0x00000000
    Read at address  0x05020170 (0x3ff9bf70170): 0x00000000
    Read at address  0x05020174 (0x3ffa7e10174): 0x00000000
    Read at address  0x05020178 (0x3ff835a0178): 0x00000000
    Read at address  0x0502017C (0x3ffbbf1017c): 0x00000000
    Read at address  0x05020180 (0x3ffa4140180): 0x2028002A
    Read at address  0x05020184 (0x3ff98230184): 0x00000003
    Read at address  0x05020188 (0x3ff8a6f0188): 0x001003E8
    Read at address  0x0502018C (0x3ff845f018c): 0x00000C5F
    Read at address  0x05020190 (0x3ffae6a0190): 0x00000C5F
    Read at address  0x05020194 (0x3ff91eb0194): 0x00000000
    Read at address  0x05020198 (0x3ffa2d10198): 0x00000000
    Read at address  0x0502019C (0x3ff8040019c): 0x00000000
    Read at address  0x050201A0 (0x3ff967c01a0): 0x00000000
    Read at address  0x050201A4 (0x3ffba8501a4): 0x00000000
    Read at address  0x050201A8 (0x3ffa71801a8): 0x001E4004
    Read at address  0x050201AC (0x3ff9c8401ac): 0x0000000C
    Read at address  0x050201B0 (0x3ff940201b0): 0x00000002
    Read at address  0x050201B4 (0x3ff89ed01b4): 0x00000000
    Read at address  0x050201B8 (0x3ffa59f01b8): 0x000400C8
    Read at address  0x050201BC (0x3ffa9ed01bc): 0x000300C8
    Read at address  0x050201C0 (0x3ffa48401c0): 0x00000000
    Read at address  0x050201C4 (0x3ffa27f01c4): 0x00000000
    Read at address  0x050201C8 (0x3ffa70001c8): 0x00000000
    Read at address  0x050201CC (0x3ff8ea601cc): 0x00000000
    Read at address  0x050201D0 (0x3ffabd501d0): 0x00000000
    Read at address  0x050201D4 (0x3ff861e01d4): 0x00000000
    Read at address  0x050201D8 (0x3ff826101d8): 0x00000000
    Read at address  0x050201DC (0x3ff83b201dc): 0x00000000
    Read at address  0x050201E0 (0x3ffbaba01e0): 0x00000000
    Read at address  0x050201E4 (0x3ffae4001e4): 0x00000000
    Read at address  0x050201E8 (0x3ff7f1201e8): 0x00000000
    Read at address  0x050201EC (0x3ff9f1a01ec): 0x00000000
    Read at address  0x050201F0 (0x3ffa33101f0): 0x00000000
    Read at address  0x050201F4 (0x3ffac3101f4): 0x00000000
    Read at address  0x050201F8 (0x3ffa78a01f8): 0x00000000
    Read at address  0x050201FC (0x3ffb8c501fc): 0x00000000
    Read at address  0x05020200 (0x3ffbbf60200): 0x00000000
    Read at address  0x05020204 (0x3ff82ed0204): 0x0000002D
    Read at address  0x05020208 (0x3ffb81d0208): 0x0006001E
    Read at address  0x0502020C (0x3ff865a020c): 0x00000000
    Read at address  0x05020210 (0x3ffa2200210): 0x00000000
    Read at address  0x05020214 (0x3ffbca10214): 0x0000802D
    Read at address  0x05020218 (0x3ff8f740218): 0x0006001E
    Read at address  0x0502021C (0x3ff808b021c): 0x00000000
    Read at address  0x05020220 (0x3ffba740220): 0x00000000
    Read at address  0x05020224 (0x3ff984a0224): 0x00000008
    Read at address  0x05020228 (0x3ff81700228): 0x000602EE
    Read at address  0x0502022C (0x3ff9ccc022c): 0x00000000
    Read at address  0x05020230 (0x3ffbe200230): 0x00000000
    Read at address  0x05020234 (0x3ff8fdf0234): 0x00000000
    Read at address  0x05020238 (0x3ff99a40238): 0x00000000
    Read at address  0x0502023C (0x3ff9d48023c): 0x00000000
    Read at address  0x05020240 (0x3ff880a0240): 0x101E0000
    Read at address  0x05020244 (0x3ff89f20244): 0x00000001
    Read at address  0x05020248 (0x3ffb5ff0248): 0x00020006
    Read at address  0x0502024C (0x3ff8665024c): 0x0000000E
    Read at address  0x05020250 (0x3ffb8420250): 0x0000012B
    Read at address  0x05020254 (0x3ffa7d50254): 0x00000000
    Read at address  0x05020258 (0x3ffa3880258): 0x00000000
    Read at address  0x0502025C (0x3ffb3ee025c): 0x00000000
    Read at address  0x05020260 (0x3ff9ddf0260): 0x00000000
    Read at address  0x05020264 (0x3ffa6680264): 0x00000000
    Read at address  0x05020268 (0x3ffa1050268): 0x00000000
    Read at address  0x0502026C (0x3ff81a2026c): 0x00000000
    Read at address  0x05020270 (0x3ff8bd40270): 0x00000000
    Read at address  0x05020274 (0x3ff8d450274): 0x00000000
    Read at address  0x05020278 (0x3ff98440278): 0x00000000
    Read at address  0x0502027C (0x3ff8fb0027c): 0x00000000
    Read at address  0x05020280 (0x3ff86470280): 0x00000000
    Read at address  0x05020284 (0x3ffb7bd0284): 0x00000000
    Read at address  0x05020288 (0x3ffa5870288): 0x00000000
    Read at address  0x0502028C (0x3ffbd67028c): 0x00000000
    Read at address  0x05020290 (0x3ffb4ad0290): 0x00000000
    Read at address  0x05020294 (0x3ff884a0294): 0x00000000
    Read at address  0x05020298 (0x3ff848b0298): 0x00000000
    Read at address  0x0502029C (0x3ff8ca3029c): 0x00000000
    Read at address  0x050202A0 (0x3ffba9d02a0): 0x00000000
    Read at address  0x050202A4 (0x3ffad5602a4): 0x00000000
    Read at address  0x050202A8 (0x3ffb38b02a8): 0x00000000
    Read at address  0x050202AC (0x3ffb95202ac): 0x00000000
    Read at address  0x050202B0 (0x3ff940902b0): 0x00000000
    Read at address  0x050202B4 (0x3ff859402b4): 0x00000000
    Read at address  0x050202B8 (0x3ff8f6c02b8): 0x00000000
    Read at address  0x050202BC (0x3ff9dd902bc): 0x00000000
    Read at address  0x050202C0 (0x3ffa91702c0): 0x00000000
    Read at address  0x050202C4 (0x3ffa37102c4): 0x00000000
    Read at address  0x050202C8 (0x3ff85a302c8): 0x00000000
    Read at address  0x050202CC (0x3ff8b8202cc): 0x00000000
    Read at address  0x050202D0 (0x3ffbb4e02d0): 0x00000000
    Read at address  0x050202D4 (0x3ff812102d4): 0x00000000
    Read at address  0x050202D8 (0x3ffb31e02d8): 0x00000000
    Read at address  0x050202DC (0x3ffac3a02dc): 0x00000000
    Read at address  0x050202E0 (0x3ffa58e02e0): 0x00000000
    Read at address  0x050202E4 (0x3ffa61502e4): 0x00000000
    Read at address  0x050202E8 (0x3ffac2802e8): 0x00000000
    Read at address  0x050202EC (0x3ffa7d102ec): 0x00000000
    Read at address  0x050202F0 (0x3ffb4ca02f0): 0x00000000
    Read at address  0x050202F4 (0x3ff991d02f4): 0x00000000
    Read at address  0x050202F8 (0x3ffb23a02f8): 0x00000000
    Read at address  0x050202FC (0x3ff9c9902fc): 0x00000000
    Read at address  0x05020300 (0x3ff963d0300): 0x00000000
    Read at address  0x05020304 (0x3ff99090304): 0x00000000
    Read at address  0x05020308 (0x3ff971b0308): 0x00000000
    Read at address  0x0502030C (0x3ff8258030c): 0x00000000
    Read at address  0x05020310 (0x3ff97740310): 0x00000000
    Read at address  0x05020314 (0x3ff97d90314): 0x00000000
    Read at address  0x05020318 (0x3ffb4c60318): 0x00000000
    Read at address  0x0502031C (0x3ff8869031c): 0x00000000
    Read at address  0x05020320 (0x3ff8dd30320): 0x00000000
    Read at address  0x05020324 (0x3ff97e80324): 0x00000000
    Read at address  0x05020328 (0x3ffb2eb0328): 0x00000000
    Read at address  0x0502032C (0x3ff9857032c): 0x00000000
    Read at address  0x05020330 (0x3ffb07f0330): 0x00000000
    Read at address  0x05020334 (0x3ff882f0334): 0x00000000
    Read at address  0x05020338 (0x3ff8db60338): 0x00000000
    Read at address  0x0502033C (0x3ff96cc033c): 0x00000000
    Read at address  0x05020340 (0x3ffa1ff0340): 0x06011012
    Read at address  0x05020344 (0x3ff85980344): 0x000F0000
    Read at address  0x05020348 (0x3ffa15d0348): 0x08080028
    Read at address  0x0502034C (0x3ff8714034c): 0x00010000
    Read at address  0x05020350 (0x3ff97cb0350): 0x00000000
    Read at address  0x05020354 (0x3ffbaf10354): 0x00000000
    Read at address  0x05020358 (0x3ff83560358): 0x00000000
    Read at address  0x0502035C (0x3ff9022035c): 0x00000000
    Read at address  0x05020360 (0x3ff9cde0360): 0x04001012
    Read at address  0x05020364 (0x3ffb3960364): 0x000F0000
    Read at address  0x05020368 (0x3ff9ffe0368): 0x08080128
    Read at address  0x0502036C (0x3ff96d9036c): 0x00010000
    Read at address  0x05020370 (0x3ffb25b0370): 0x00000000
    Read at address  0x05020374 (0x3ffbd010374): 0x00000000
    Read at address  0x05020378 (0x3ff9db60378): 0x00000000
    Read at address  0x0502037C (0x3ff964b037c): 0x00000000
    Read at address  0x05020380 (0x3ffa62a0380): 0x04001012
    Read at address  0x05020384 (0x3ff8c470384): 0x000F0000
    Read at address  0x05020388 (0x3ff9cd10388): 0x08080028
    Read at address  0x0502038C (0x3ffb69e038c): 0x00010000
    Read at address  0x05020390 (0x3ff936f0390): 0x00000000
    Read at address  0x05020394 (0x3ffb2f20394): 0x00000000
    Read at address  0x05020398 (0x3ff957d0398): 0x00000000
    Read at address  0x0502039C (0x3ff7fd5039c): 0x00000000
    Read at address  0x050203A0 (0x3ffa0b503a0): 0x00000000
    Read at address  0x050203A4 (0x3ff9b4703a4): 0x00000000
    Read at address  0x050203A8 (0x3ffb52b03a8): 0x00000000
    Read at address  0x050203AC (0x3ffad3d03ac): 0x00000000
    Read at address  0x050203B0 (0x3ffb6e103b0): 0x00000000
    Read at address  0x050203B4 (0x3ff8eab03b4): 0x00000000
    Read at address  0x050203B8 (0x3ff7e9703b8): 0x00000000
    Read at address  0x050203BC (0x3ff907d03bc): 0x00000000
    Read at address  0x050203C0 (0x3ffb5be03c0): 0x36000E05
    Read at address  0x050203C4 (0x3ffa48d03c4): 0x00000000
    Read at address  0x050203C8 (0x3ff8fb003c8): 0x00220000
    Read at address  0x050203CC (0x3ff97e803cc): 0x000C2D09
    Read at address  0x050203D0 (0x3ffa23d03d0): 0x00000000
    Read at address  0x050203D4 (0x3ffbb5503d4): 0x00000000
    Read at address  0x050203D8 (0x3ff830f03d8): 0x01FF0011
    Read at address  0x050203DC (0x3ffbcdf03dc): 0x00000000
    Read at address  0x050203E0 (0x3ff9ac003e0): 0x00000000
    Read at address  0x050203E4 (0x3ffb28503e4): 0x00000000
    Read at address  0x050203E8 (0x3ff852903e8): 0x00000000
    Read at address  0x050203EC (0x3ff8d1d03ec): 0x00000000
    Read at address  0x050203F0 (0x3ffb48003f0): 0x00000000
    Read at address  0x050203F4 (0x3ffac1003f4): 0x00000000
    Read at address  0x050203F8 (0x3ff8a4403f8): 0x00000000
    Read at address  0x050203FC (0x3ffb4c703fc): 0x00000000
    Read at address  0x05020400 (0x3ffb0150400): 0x698B4803
    Read at address  0x05020404 (0x3ff8a9c0404): 0x00000000
    Read at address  0x05020408 (0x3ffb6fd0408): 0x18100000
    Read at address  0x0502040C (0x3ffb0dc040c): 0xA2800000
    Read at address  0x05020410 (0x3ff93190410): 0x00000000
    Read at address  0x05020414 (0x3ffb3540414): 0x00000000
    Read at address  0x05020418 (0x3ff8cb00418): 0x00000000
    Read at address  0x0502041C (0x3ffb48c041c): 0x00000000
    Read at address  0x05020420 (0x3ffaf9c0420): 0x00000000
    Read at address  0x05020424 (0x3ff90310424): 0x00000000
    Read at address  0x05020428 (0x3ff8f4f0428): 0x00000000
    Read at address  0x0502042C (0x3ff8804042c): 0x00000000
    Read at address  0x05020430 (0x3ff9da40430): 0x00000000
    Read at address  0x05020434 (0x3ff8a350434): 0x00000000
    Read at address  0x05020438 (0x3ff9dcc0438): 0x00000000
    Read at address  0x0502043C (0x3ffa04a043c): 0x00000000
    Read at address  0x05020440 (0x3ffaa350440): 0x00000000
    Read at address  0x05020444 (0x3ff83320444): 0x00000000
    Read at address  0x05020448 (0x3ffb7250448): 0x00000000
    Read at address  0x0502044C (0x3ffb05a044c): 0x00000000
    Read at address  0x05020450 (0x3ff7f020450): 0x00000000
    Read at address  0x05020454 (0x3ff96100454): 0x00000000
    Read at address  0x05020458 (0x3ffae9f0458): 0x00000000
    Read at address  0x0502045C (0x3ff935f045c): 0x00000000
    Read at address  0x05020460 (0x3ffab630460): 0x00000000
    Read at address  0x05020464 (0x3ffba650464): 0x00000000
    Read at address  0x05020468 (0x3ffab4c0468): 0x00000000
    Read at address  0x0502046C (0x3ffa3bf046c): 0x00000000
    Read at address  0x05020470 (0x3ff891c0470): 0x00000000
    Read at address  0x05020474 (0x3ff97840474): 0x00000000
    Read at address  0x05020478 (0x3ffb7af0478): 0x00000000
    Read at address  0x0502047C (0x3ffb06f047c): 0x00000000
    Read at address  0x05020480 (0x3ffb6c90480): 0x70000000
    Read at address  0x05020484 (0x3ffba510484): 0x00010002
    Read at address  0x05020488 (0x3ff849e0488): 0x00000105
    Read at address  0x0502048C (0x3ffa31d048c): 0x00000002
    Read at address  0x05020490 (0x3ff87360490): 0x00000000
    Read at address  0x05020494 (0x3ff90280494): 0x00000000
    Read at address  0x05020498 (0x3ffa9960498): 0x00000000
    Read at address  0x0502049C (0x3ff9af0049c): 0x00000000
    Read at address  0x050204A0 (0x3ffaaf304a0): 0x00000000
    Read at address  0x050204A4 (0x3ff947104a4): 0x00000000
    Read at address  0x050204A8 (0x3ff890e04a8): 0x00000000
    Read at address  0x050204AC (0x3ff8a8e04ac): 0x00000000
    Read at address  0x050204B0 (0x3ffb66104b0): 0x00000000
    Read at address  0x050204B4 (0x3ffb83f04b4): 0x00000000
    Read at address  0x050204B8 (0x3ffa1e104b8): 0x00000000
    Read at address  0x050204BC (0x3ffa1e304bc): 0x00000000
    Read at address  0x050204C0 (0x3ffbd1304c0): 0x70000000
    Read at address  0x050204C4 (0x3ff8d9f04c4): 0x00010002
    Read at address  0x050204C8 (0x3ffa6c404c8): 0x00000105
    Read at address  0x050204CC (0x3ffbe5204cc): 0x00000002
    Read at address  0x050204D0 (0x3ff836f04d0): 0x00000000
    Read at address  0x050204D4 (0x3ff8f8804d4): 0x00000000
    Read at address  0x050204D8 (0x3ff983004d8): 0x00000000
    Read at address  0x050204DC (0x3ffa17804dc): 0x00000000
    Read at address  0x050204E0 (0x3ffa04704e0): 0x00000000
    Read at address  0x050204E4 (0x3ff8cd604e4): 0x00000000
    Read at address  0x050204E8 (0x3ff906504e8): 0x00000000
    Read at address  0x050204EC (0x3ff9a6504ec): 0x00000000
    Read at address  0x050204F0 (0x3ffaa1704f0): 0x00000000
    Read at address  0x050204F4 (0x3ff963c04f4): 0x00000000
    Read at address  0x050204F8 (0x3ff93f404f8): 0x00000000
    Read at address  0x050204FC (0x3ffb6e704fc): 0x00000000
    Read at address  0x05020500 (0x3ff93550500): 0x70000000
    Read at address  0x05020504 (0x3ff888e0504): 0x00010002
    Read at address  0x05020508 (0x3ff85660508): 0x00000109
    Read at address  0x0502050C (0x3ffa22f050c): 0x00000002
    Read at address  0x05020510 (0x3ff98cf0510): 0x00000000
    Read at address  0x05020514 (0x3ffa4c60514): 0x00000000
    Read at address  0x05020518 (0x3ffb1fd0518): 0x00000000
    Read at address  0x0502051C (0x3ff8921051c): 0x00000000
    Read at address  0x05020520 (0x3ffad1b0520): 0x00000000
    Read at address  0x05020524 (0x3ff993b0524): 0x00000000
    Read at address  0x05020528 (0x3ff9ba70528): 0x00000000
    Read at address  0x0502052C (0x3ff7fa0052c): 0x00000000
    Read at address  0x05020530 (0x3ffa5f40530): 0x00000000
    Read at address  0x05020534 (0x3ffbdde0534): 0x00000000
    Read at address  0x05020538 (0x3ffbd0b0538): 0x00000000
    Read at address  0x0502053C (0x3ffba44053c): 0x00000000
    Read at address  0x05020540 (0x3ff85d80540): 0x70000000
    Read at address  0x05020544 (0x3ff91700544): 0x00010002
    Read at address  0x05020548 (0x3ff88ff0548): 0x00000000
    Read at address  0x0502054C (0x3ff8081054c): 0x00000002
    Read at address  0x05020550 (0x3ffa9e90550): 0x00000000
    Read at address  0x05020554 (0x3ffa1610554): 0x00000000
    Read at address  0x05020558 (0x3ff94040558): 0x00000000
    Read at address  0x0502055C (0x3ffb83b055c): 0x00000000
    Read at address  0x05020560 (0x3ff82cc0560): 0x00000000
    Read at address  0x05020564 (0x3ff86f20564): 0x00000000
    Read at address  0x05020568 (0x3ffac700568): 0x00000000
    Read at address  0x0502056C (0x3ff8515056c): 0x00000000
    Read at address  0x05020570 (0x3ff8bbc0570): 0x00000000
    Read at address  0x05020574 (0x3ff8c070574): 0x00000000
    Read at address  0x05020578 (0x3ff811f0578): 0x00000000
    Read at address  0x0502057C (0x3ffa78f057c): 0x00000000
    Read at address  0x05020580 (0x3ff925a0580): 0x00000000
    Read at address  0x05020584 (0x3ffbb3c0584): 0x00000000
    Read at address  0x05020588 (0x3ff94a40588): 0x00000000
    Read at address  0x0502058C (0x3ffb39e058c): 0x00000000
    Read at address  0x05020590 (0x3ffb0790590): 0x00000000
    Read at address  0x05020594 (0x3ffbaf50594): 0x00000000
    Read at address  0x05020598 (0x3ff85590598): 0x00000000
    Read at address  0x0502059C (0x3ffa8cc059c): 0x00000000
    Read at address  0x050205A0 (0x3ff833705a0): 0x00000000
    Read at address  0x050205A4 (0x3ff934905a4): 0x00000000
    Read at address  0x050205A8 (0x3ff8d4d05a8): 0x00000000
    Read at address  0x050205AC (0x3ff8d8305ac): 0x00000000
    Read at address  0x050205B0 (0x3ff9d1305b0): 0x00000000
    Read at address  0x050205B4 (0x3ffad7c05b4): 0x00000000
    Read at address  0x050205B8 (0x3ffb24805b8): 0x00000000
    Read at address  0x050205BC (0x3ff9c9105bc): 0x00000000
    Read at address  0x050205C0 (0x3ffa00105c0): 0x00000000
    Read at address  0x050205C4 (0x3ff9aec05c4): 0x00000000
    Read at address  0x050205C8 (0x3ffa59405c8): 0x00000000
    Read at address  0x050205CC (0x3ff905805cc): 0x00000000
    Read at address  0x050205D0 (0x3ffa91005d0): 0x00000000
    Read at address  0x050205D4 (0x3ffa40c05d4): 0x00000000
    Read at address  0x050205D8 (0x3ffa61e05d8): 0x00000000
    Read at address  0x050205DC (0x3ffa33d05dc): 0x00000000
    Read at address  0x050205E0 (0x3ffacc505e0): 0x00000000
    Read at address  0x050205E4 (0x3ffaa6c05e4): 0x00000000
    Read at address  0x050205E8 (0x3ffba7e05e8): 0x00000000
    Read at address  0x050205EC (0x3ffa3eb05ec): 0x00000000
    Read at address  0x050205F0 (0x3ff99df05f0): 0x00000000
    Read at address  0x050205F4 (0x3ff9b8705f4): 0x00000000
    Read at address  0x050205F8 (0x3ffb6da05f8): 0x00000000
    Read at address  0x050205FC (0x3ffa97705fc): 0x00000000
    Read at address  0x05020600 (0x3ff848a0600): 0x00000000
    Read at address  0x05020604 (0x3ff990e0604): 0x00000000
    Read at address  0x05020608 (0x3ffa44d0608): 0x00000000
    Read at address  0x0502060C (0x3ff81f6060c): 0x00000000
    Read at address  0x05020610 (0x3ffa0570610): 0x00000000
    Read at address  0x05020614 (0x3ff94e20614): 0x00000000
    Read at address  0x05020618 (0x3ffa5920618): 0x00000000
    Read at address  0x0502061C (0x3ffb6bd061c): 0x00000000
    Read at address  0x05020620 (0x3ff92000620): 0x00000000
    Read at address  0x05020624 (0x3ffa1390624): 0x00000000
    Read at address  0x05020628 (0x3ffab9f0628): 0x00000000
    Read at address  0x0502062C (0x3ff8de8062c): 0x00000000
    Read at address  0x05020630 (0x3ff85d50630): 0x00000000
    Read at address  0x05020634 (0x3ff83d40634): 0x00000000
    Read at address  0x05020638 (0x3ff93a80638): 0x00000000
    Read at address  0x0502063C (0x3ffa393063c): 0x00000000
    Read at address  0x05020640 (0x3ff89ad0640): 0x00000000
    Read at address  0x05020644 (0x3ffa7e90644): 0x00000000
    Read at address  0x05020648 (0x3ffbbb30648): 0x00000000
    Read at address  0x0502064C (0x3ffb376064c): 0x00000000
    Read at address  0x05020650 (0x3ff83220650): 0x00000000
    Read at address  0x05020654 (0x3ffa9730654): 0x00000000
    Read at address  0x05020658 (0x3ffb8880658): 0x00000000
    Read at address  0x0502065C (0x3ffb871065c): 0x00000000
    Read at address  0x05020660 (0x3ffb1bb0660): 0x00000000
    Read at address  0x05020664 (0x3ffb5e10664): 0x00000000
    Read at address  0x05020668 (0x3ffbad70668): 0x00000000
    Read at address  0x0502066C (0x3ff92e9066c): 0x00000000
    Read at address  0x05020670 (0x3ffa4e60670): 0x00000000
    Read at address  0x05020674 (0x3ffa4090674): 0x00000000
    Read at address  0x05020678 (0x3ffa1c00678): 0x00000000
    Read at address  0x0502067C (0x3ff94a6067c): 0x00000000
    Read at address  0x05020680 (0x3ff7f340680): 0x00000000
    Read at address  0x05020684 (0x3ffacd20684): 0x00000000
    Read at address  0x05020688 (0x3ff8f3c0688): 0x00000000
    Read at address  0x0502068C (0x3ffb052068c): 0x00000000
    Read at address  0x05020690 (0x3ffb7190690): 0x00000000
    Read at address  0x05020694 (0x3ffb3580694): 0x00000000
    Read at address  0x05020698 (0x3ffb8e60698): 0x00000000
    Read at address  0x0502069C (0x3ff8d86069c): 0x00000000
    Read at address  0x050206A0 (0x3ffb4bf06a0): 0x00000000
    Read at address  0x050206A4 (0x3ff8ae206a4): 0x00000000
    Read at address  0x050206A8 (0x3ff911306a8): 0x00000000
    Read at address  0x050206AC (0x3ff9dea06ac): 0x00000000
    Read at address  0x050206B0 (0x3ff977f06b0): 0x00000000
    Read at address  0x050206B4 (0x3ffa08406b4): 0x00000000
    Read at address  0x050206B8 (0x3ffa33a06b8): 0x00000000
    Read at address  0x050206BC (0x3ff813c06bc): 0x00000000
    Read at address  0x050206C0 (0x3ff8e8206c0): 0x00000000
    Read at address  0x050206C4 (0x3ff9b8106c4): 0x00000000
    Read at address  0x050206C8 (0x3ff843606c8): 0x00000000
    Read at address  0x050206CC (0x3ff9e2e06cc): 0x00000000
    Read at address  0x050206D0 (0x3ffb7f606d0): 0x00000000
    Read at address  0x050206D4 (0x3ff92c806d4): 0x00000000
    Read at address  0x050206D8 (0x3ffbcfe06d8): 0x00000000
    Read at address  0x050206DC (0x3ffaa6b06dc): 0x00000000
    Read at address  0x050206E0 (0x3ffa77806e0): 0x00000000
    Read at address  0x050206E4 (0x3ffbb1206e4): 0x00000000
    Read at address  0x050206E8 (0x3ff8deb06e8): 0x00000000
    Read at address  0x050206EC (0x3ff873f06ec): 0x00000000
    Read at address  0x050206F0 (0x3ffb0e006f0): 0x00000000
    Read at address  0x050206F4 (0x3ffb52a06f4): 0x00000000
    Read at address  0x050206F8 (0x3ff90c406f8): 0x00000000
    Read at address  0x050206FC (0x3ffbb0106fc): 0x00000000
    Read at address  0x05020700 (0x3ff7faa0700): 0x00000000
    Read at address  0x05020704 (0x3ff9be00704): 0x00000000
    Read at address  0x05020708 (0x3ffba220708): 0x00000000
    Read at address  0x0502070C (0x3ffb918070c): 0x00000000
    Read at address  0x05020710 (0x3ff8f050710): 0x00000000
    Read at address  0x05020714 (0x3ffaa820714): 0x00000000
    Read at address  0x05020718 (0x3ff9f6f0718): 0x00000000
    Read at address  0x0502071C (0x3ff8b2e071c): 0x00000000
    Read at address  0x05020720 (0x3ffbbaf0720): 0x00000000
    Read at address  0x05020724 (0x3ff9a0d0724): 0x00000000
    Read at address  0x05020728 (0x3ffaea00728): 0x00000000
    Read at address  0x0502072C (0x3ffb8d5072c): 0x00000000
    Read at address  0x05020730 (0x3ffadd10730): 0x00000000
    Read at address  0x05020734 (0x3ff83830734): 0x00000000
    Read at address  0x05020738 (0x3ff9f760738): 0x00000000
    Read at address  0x0502073C (0x3ffb72b073c): 0x00000000
    Read at address  0x05020740 (0x3ff9ac10740): 0x00000000
    Read at address  0x05020744 (0x3ff91a80744): 0x00000000
    Read at address  0x05020748 (0x3ff8cf50748): 0x00000000
    Read at address  0x0502074C (0x3ff99ec074c): 0x00000000
    Read at address  0x05020750 (0x3ff80f90750): 0x00000000
    Read at address  0x05020754 (0x3ff87fb0754): 0x00000000
    Read at address  0x05020758 (0x3ffa7210758): 0x00000000
    Read at address  0x0502075C (0x3ffb65c075c): 0x00000000
    Read at address  0x05020760 (0x3ff8c8a0760): 0x00000000
    Read at address  0x05020764 (0x3ff9d5b0764): 0x00000000
    Read at address  0x05020768 (0x3ffbe5b0768): 0x00000000
    Read at address  0x0502076C (0x3ffaa23076c): 0x00000000
    Read at address  0x05020770 (0x3ff90790770): 0x00000000
    Read at address  0x05020774 (0x3ff867d0774): 0x00000000
    Read at address  0x05020778 (0x3ff87060778): 0x00000000
    Read at address  0x0502077C (0x3ffaee2077c): 0x00000000
    Read at address  0x05020780 (0x3ff95db0780): 0x00000000
    Read at address  0x05020784 (0x3ff8d540784): 0x00000000
    Read at address  0x05020788 (0x3ff9acd0788): 0x00000000
    Read at address  0x0502078C (0x3ff8a5a078c): 0x00000000
    Read at address  0x05020790 (0x3ff7e960790): 0x00000000
    Read at address  0x05020794 (0x3ff80e00794): 0x00000000
    Read at address  0x05020798 (0x3ff91750798): 0x00000000
    Read at address  0x0502079C (0x3ff8b43079c): 0x00000000
    Read at address  0x050207A0 (0x3ff9a8e07a0): 0x00000000
    Read at address  0x050207A4 (0x3ff865f07a4): 0x00000000
    Read at address  0x050207A8 (0x3ffa47707a8): 0x00000000
    Read at address  0x050207AC (0x3ff90b007ac): 0x00000000
    Read at address  0x050207B0 (0x3ffa0b007b0): 0x00000000
    Read at address  0x050207B4 (0x3ff7f3107b4): 0x00000000
    Read at address  0x050207B8 (0x3ff8ef607b8): 0x00000000
    Read at address  0x050207BC (0x3ff8a9807bc): 0x00000000
    Read at address  0x050207C0 (0x3ff93c707c0): 0x00000000
    Read at address  0x050207C4 (0x3ffa90107c4): 0x00000000
    Read at address  0x050207C8 (0x3ff87d307c8): 0x00000000
    Read at address  0x050207CC (0x3ffa4c307cc): 0x00000000
    Read at address  0x050207D0 (0x3ffa56707d0): 0x00000000
    Read at address  0x050207D4 (0x3ff85e707d4): 0x00000000
    Read at address  0x050207D8 (0x3ffb58c07d8): 0x00000000
    Read at address  0x050207DC (0x3ffb99507dc): 0x00000000
    Read at address  0x050207E0 (0x3ffb35d07e0): 0x00000000
    Read at address  0x050207E4 (0x3ff974f07e4): 0x00000000
    Read at address  0x050207E8 (0x3ff9b5107e8): 0x00000000
    Read at address  0x050207EC (0x3ff9a5107ec): 0x00000000
    Read at address  0x050207F0 (0x3ffb81d07f0): 0x00000000
    Read at address  0x050207F4 (0x3ff9eb907f4): 0x00000000
    Read at address  0x050207F8 (0x3ffa22907f8): 0x00000000
    Read at address  0x050207FC (0x3ff957d07fc): 0x00000000
    Read at address  0x05020800 (0x3ffa0ed0800): 0x00000000
    Read at address  0x05020804 (0x3ffa4ab0804): 0x00000000
    Read at address  0x05020808 (0x3ffa43a0808): 0x00000000
    Read at address  0x0502080C (0x3ffa8c2080c): 0x00000000
    Read at address  0x05020810 (0x3ff9c090810): 0x00000000
    Read at address  0x05020814 (0x3ff8ba90814): 0x00000000
    Read at address  0x05020818 (0x3ff9a460818): 0x00000000
    Read at address  0x0502081C (0x3ff7e9b081c): 0x00000000
    Read at address  0x05020820 (0x3ff93bd0820): 0x00000000
    Read at address  0x05020824 (0x3ff83370824): 0x00000000
    Read at address  0x05020828 (0x3ff8e860828): 0x00000000
    Read at address  0x0502082C (0x3ffb48c082c): 0x00000000
    Read at address  0x05020830 (0x3ff8dc90830): 0x00000000
    Read at address  0x05020834 (0x3ffa53d0834): 0x00000000
    Read at address  0x05020838 (0x3ffae440838): 0x00000000
    Read at address  0x0502083C (0x3ffa8ea083c): 0x00000000
    Read at address  0x05020840 (0x3ff97ed0840): 0x00000000
    Read at address  0x05020844 (0x3ff89910844): 0x00000000
    Read at address  0x05020848 (0x3ff96f30848): 0x00000000
    Read at address  0x0502084C (0x3ff9ea5084c): 0x00000000
    Read at address  0x05020850 (0x3ffb6a40850): 0x00000000
    Read at address  0x05020854 (0x3ff992e0854): 0x00000000
    Read at address  0x05020858 (0x3ff80be0858): 0x00000000
    Read at address  0x0502085C (0x3ffa6ab085c): 0x00000000
    Read at address  0x05020860 (0x3ffb1bf0860): 0x00000000
    Read at address  0x05020864 (0x3ff981f0864): 0x00000000
    Read at address  0x05020868 (0x3ff94f60868): 0x00000000
    Read at address  0x0502086C (0x3ff8ae3086c): 0x00000000
    Read at address  0x05020870 (0x3ffa2c20870): 0x00000000
    Read at address  0x05020874 (0x3ffa66e0874): 0x00000000
    Read at address  0x05020878 (0x3ff902d0878): 0x00000000
    Read at address  0x0502087C (0x3ff9586087c): 0x00000000
    Read at address  0x05020880 (0x3ff82bd0880): 0x00000000
    Read at address  0x05020884 (0x3ff9d6f0884): 0x00000000
    Read at address  0x05020888 (0x3ffa7e30888): 0x00000000
    Read at address  0x0502088C (0x3ff9f56088c): 0x00000000
    Read at address  0x05020890 (0x3ffa0ec0890): 0x00000000
    Read at address  0x05020894 (0x3ff95ce0894): 0x00000000
    Read at address  0x05020898 (0x3ffb5910898): 0x00000000
    Read at address  0x0502089C (0x3ffa2f5089c): 0x00000000
    Read at address  0x050208A0 (0x3ff88ba08a0): 0x00000000
    Read at address  0x050208A4 (0x3ff9ba308a4): 0x00000000
    Read at address  0x050208A8 (0x3ff838408a8): 0x00000000
    Read at address  0x050208AC (0x3ffa56b08ac): 0x00000000
    Read at address  0x050208B0 (0x3ffa29108b0): 0x00000000
    Read at address  0x050208B4 (0x3ff7f0808b4): 0x00000000
    Read at address  0x050208B8 (0x3ffbd8408b8): 0x00000000
    Read at address  0x050208BC (0x3ffa78808bc): 0x00000000
    Read at address  0x050208C0 (0x3ff8b6d08c0): 0x00000000
    Read at address  0x050208C4 (0x3ffa65208c4): 0x00000000
    Read at address  0x050208C8 (0x3ff862408c8): 0x00000000
    Read at address  0x050208CC (0x3ff875108cc): 0x00000000
    Read at address  0x050208D0 (0x3ff8e5f08d0): 0x00000000
    Read at address  0x050208D4 (0x3ff902208d4): 0x00000000
    Read at address  0x050208D8 (0x3ff83f008d8): 0x00000000
    Read at address  0x050208DC (0x3ff926808dc): 0x00000000
    Read at address  0x050208E0 (0x3ff905f08e0): 0x00000000
    Read at address  0x050208E4 (0x3ff930e08e4): 0x00000000
    Read at address  0x050208E8 (0x3ffac6b08e8): 0x00000000
    Read at address  0x050208EC (0x3ff89a208ec): 0x00000000
    Read at address  0x050208F0 (0x3ff9d0f08f0): 0x00000000
    Read at address  0x050208F4 (0x3ffb64f08f4): 0x00000000
    Read at address  0x050208F8 (0x3ff842c08f8): 0x00000000
    Read at address  0x050208FC (0x3ffa07008fc): 0x00000000
    Read at address  0x05020900 (0x3ff92e90900): 0x00000000
    Read at address  0x05020904 (0x3ff80280904): 0x00000000
    Read at address  0x05020908 (0x3ff805b0908): 0x00000000
    Read at address  0x0502090C (0x3ff9e1d090c): 0x00000000
    Read at address  0x05020910 (0x3ffa07a0910): 0x00000000
    Read at address  0x05020914 (0x3ff9b450914): 0x00000000
    Read at address  0x05020918 (0x3ff85010918): 0x00000000
    Read at address  0x0502091C (0x3ffb8cc091c): 0x00000000
    Read at address  0x05020920 (0x3ffaf280920): 0x00000000
    Read at address  0x05020924 (0x3ffa41a0924): 0x00000000
    Read at address  0x05020928 (0x3ffb8b90928): 0x00000000
    Read at address  0x0502092C (0x3ffa707092c): 0x00000000
    Read at address  0x05020930 (0x3ff91570930): 0x00000000
    Read at address  0x05020934 (0x3ffa9370934): 0x00000000
    Read at address  0x05020938 (0x3ff8ced0938): 0x00000000
    Read at address  0x0502093C (0x3ffa275093c): 0x00000000
    Read at address  0x05020940 (0x3ff9de60940): 0x00000000
    Read at address  0x05020944 (0x3ff9f010944): 0x00000000
    Read at address  0x05020948 (0x3ffabdb0948): 0x00000000
    Read at address  0x0502094C (0x3ff7f04094c): 0x00000000
    Read at address  0x05020950 (0x3ff9c9a0950): 0x00000000
    Read at address  0x05020954 (0x3ff96ae0954): 0x00000000
    Read at address  0x05020958 (0x3ffb66f0958): 0x00000000
    Read at address  0x0502095C (0x3ffba27095c): 0x00000000
    Read at address  0x05020960 (0x3ffb5db0960): 0x00000000
    Read at address  0x05020964 (0x3ffba7e0964): 0x00000000
    Read at address  0x05020968 (0x3ff91550968): 0x00000000
    Read at address  0x0502096C (0x3ff8b7c096c): 0x00000000
    Read at address  0x05020970 (0x3ffa4d70970): 0x00000000
    Read at address  0x05020974 (0x3ff9d5a0974): 0x00000000
    Read at address  0x05020978 (0x3ffb9330978): 0x00000000
    Read at address  0x0502097C (0x3ffba46097c): 0x00000000
    Read at address  0x05020980 (0x3ff937c0980): 0x00000000
    Read at address  0x05020984 (0x3ffb3a10984): 0x00000000
    Read at address  0x05020988 (0x3ff9daf0988): 0x00000000
    Read at address  0x0502098C (0x3ffb688098c): 0x00000000
    Read at address  0x05020990 (0x3ffb0750990): 0x00000000
    Read at address  0x05020994 (0x3ff99120994): 0x00000000
    Read at address  0x05020998 (0x3ff7fe90998): 0x00000000
    Read at address  0x0502099C (0x3ff8769099c): 0x00000000
    Read at address  0x050209A0 (0x3ffb5b409a0): 0x00000000
    Read at address  0x050209A4 (0x3ffb98509a4): 0x00000000
    Read at address  0x050209A8 (0x3ff9f7809a8): 0x00000000
    Read at address  0x050209AC (0x3ffa3bd09ac): 0x00000000
    Read at address  0x050209B0 (0x3ffbb5b09b0): 0x00000000
    Read at address  0x050209B4 (0x3ffaa2209b4): 0x00000000
    Read at address  0x050209B8 (0x3ffa83109b8): 0x00000000
    Read at address  0x050209BC (0x3ff967509bc): 0x00000000
    Read at address  0x050209C0 (0x3ffaa4009c0): 0x00000000
    Read at address  0x050209C4 (0x3ffbb1809c4): 0x00000000
    Read at address  0x050209C8 (0x3ff923109c8): 0x00000000
    Read at address  0x050209CC (0x3ffaf1109cc): 0x00000000
    Read at address  0x050209D0 (0x3ffa3ff09d0): 0x00000000
    Read at address  0x050209D4 (0x3ff925009d4): 0x00000000
    Read at address  0x050209D8 (0x3ff9f9109d8): 0x00000000
    Read at address  0x050209DC (0x3ffb8c209dc): 0x00000000
    Read at address  0x050209E0 (0x3ffb78509e0): 0x00000000
    Read at address  0x050209E4 (0x3ffb46309e4): 0x00000000
    Read at address  0x050209E8 (0x3ffa36b09e8): 0x00000000
    Read at address  0x050209EC (0x3ffb57109ec): 0x00000000
    Read at address  0x050209F0 (0x3ffb29409f0): 0x00000000
    Read at address  0x050209F4 (0x3ff95f209f4): 0x00000000
    Read at address  0x050209F8 (0x3ffbdc109f8): 0x00000000
    Read at address  0x050209FC (0x3ff99cc09fc): 0x00000000
    Read at address  0x05020A00 (0x3ffaf900a00): 0x00000000
    Read at address  0x05020A04 (0x3ff8dd10a04): 0x00000000
    Read at address  0x05020A08 (0x3ff8b510a08): 0x00000000
    Read at address  0x05020A0C (0x3ffb1960a0c): 0x00000000
    Read at address  0x05020A10 (0x3ff8f720a10): 0x00000000
    Read at address  0x05020A14 (0x3ffa5d30a14): 0x00000000
    Read at address  0x05020A18 (0x3ffab850a18): 0x00000000
    Read at address  0x05020A1C (0x3ffbda60a1c): 0x00000000
    Read at address  0x05020A20 (0x3ff89950a20): 0x00000000
    Read at address  0x05020A24 (0x3ff8ce20a24): 0x00000000
    Read at address  0x05020A28 (0x3ffbd000a28): 0x00000000
    Read at address  0x05020A2C (0x3ff90250a2c): 0x00000000
    Read at address  0x05020A30 (0x3ffb3a20a30): 0x00000000
    Read at address  0x05020A34 (0x3ff88520a34): 0x00000000
    Read at address  0x05020A38 (0x3ff8c6b0a38): 0x00000000
    Read at address  0x05020A3C (0x3ff9afd0a3c): 0x00000000
    Read at address  0x05020A40 (0x3ff87830a40): 0x00000000
    Read at address  0x05020A44 (0x3ffae240a44): 0x00000000
    Read at address  0x05020A48 (0x3ffad700a48): 0x00000000
    Read at address  0x05020A4C (0x3ffb6eb0a4c): 0x00000000
    Read at address  0x05020A50 (0x3ffb82a0a50): 0x00000000
    Read at address  0x05020A54 (0x3ff97930a54): 0x00000000
    Read at address  0x05020A58 (0x3ff9a9c0a58): 0x00000000
    Read at address  0x05020A5C (0x3ffb8c50a5c): 0x00000000
    Read at address  0x05020A60 (0x3ff9ac30a60): 0x00000000
    Read at address  0x05020A64 (0x3ff9b110a64): 0x00000000
    Read at address  0x05020A68 (0x3ff80610a68): 0x00000000
    Read at address  0x05020A6C (0x3ff7f010a6c): 0x00000000
    Read at address  0x05020A70 (0x3ff903b0a70): 0x00000000
    Read at address  0x05020A74 (0x3ff98be0a74): 0x00000000
    Read at address  0x05020A78 (0x3ffb3280a78): 0x00000000
    Read at address  0x05020A7C (0x3ffb16c0a7c): 0x00000000
    Read at address  0x05020A80 (0x3ffb62f0a80): 0x00000000
    Read at address  0x05020A84 (0x3ff861a0a84): 0x00000000
    Read at address  0x05020A88 (0x3ff9d5f0a88): 0x00000000
    Read at address  0x05020A8C (0x3ffbb0b0a8c): 0x00000000
    Read at address  0x05020A90 (0x3ffae970a90): 0x00000000
    Read at address  0x05020A94 (0x3ff95dd0a94): 0x00000000
    Read at address  0x05020A98 (0x3ffa8440a98): 0x00000000
    Read at address  0x05020A9C (0x3ffa6200a9c): 0x00000000
    Read at address  0x05020AA0 (0x3ffad6d0aa0): 0x00000000
    Read at address  0x05020AA4 (0x3ff8e500aa4): 0x00000000
    Read at address  0x05020AA8 (0x3ff9c540aa8): 0x00000000
    Read at address  0x05020AAC (0x3ff85cd0aac): 0x00000000
    Read at address  0x05020AB0 (0x3ffb5e80ab0): 0x00000000
    Read at address  0x05020AB4 (0x3ffb4840ab4): 0x00000000
    Read at address  0x05020AB8 (0x3ff9c740ab8): 0x00000000
    Read at address  0x05020ABC (0x3ffa5440abc): 0x00000000
    Read at address  0x05020AC0 (0x3ffb1fb0ac0): 0x00000000
    Read at address  0x05020AC4 (0x3ffa1650ac4): 0x00000000
    Read at address  0x05020AC8 (0x3ffb0640ac8): 0x00000000
    Read at address  0x05020ACC (0x3ff8d300acc): 0x00000000
    Read at address  0x05020AD0 (0x3ff92540ad0): 0x00000000
    Read at address  0x05020AD4 (0x3ffb6920ad4): 0x00000000
    Read at address  0x05020AD8 (0x3ffba0c0ad8): 0x00000000
    Read at address  0x05020ADC (0x3ffaa880adc): 0x00000000
    Read at address  0x05020AE0 (0x3ffb6fd0ae0): 0x00000000
    Read at address  0x05020AE4 (0x3ffaf500ae4): 0x00000000
    Read at address  0x05020AE8 (0x3ffbaf30ae8): 0x00000000
    Read at address  0x05020AEC (0x3ffb2680aec): 0x00000000
    Read at address  0x05020AF0 (0x3ffab590af0): 0x00000000
    Read at address  0x05020AF4 (0x3ff994e0af4): 0x00000000
    Read at address  0x05020AF8 (0x3ff9a8a0af8): 0x00000000
    Read at address  0x05020AFC (0x3ff874b0afc): 0x00000000
    Read at address  0x05020B00 (0x3ff954d0b00): 0x00000000
    Read at address  0x05020B04 (0x3ff94bc0b04): 0x00000000
    Read at address  0x05020B08 (0x3ffb3f70b08): 0x00000000
    Read at address  0x05020B0C (0x3ff98750b0c): 0x00000000
    Read at address  0x05020B10 (0x3ff83e20b10): 0x00000000
    Read at address  0x05020B14 (0x3ff9ee70b14): 0x00000000
    Read at address  0x05020B18 (0x3ff992a0b18): 0x00000000
    Read at address  0x05020B1C (0x3ff9e130b1c): 0x00000000
    Read at address  0x05020B20 (0x3ff927c0b20): 0x00000000
    Read at address  0x05020B24 (0x3ffbdf00b24): 0x00000000
    Read at address  0x05020B28 (0x3ffb13d0b28): 0x00000000
    Read at address  0x05020B2C (0x3ff88490b2c): 0x00000000
    Read at address  0x05020B30 (0x3ffbe130b30): 0x00000000
    Read at address  0x05020B34 (0x3ff9f130b34): 0x00000000
    Read at address  0x05020B38 (0x3ffa5170b38): 0x00000000
    Read at address  0x05020B3C (0x3ffb2a00b3c): 0x00000000
    Read at address  0x05020B40 (0x3ffb53e0b40): 0x00000000
    Read at address  0x05020B44 (0x3ff88ad0b44): 0x00000000
    Read at address  0x05020B48 (0x3ff81780b48): 0x00000000
    Read at address  0x05020B4C (0x3ffa3fa0b4c): 0x00000000
    Read at address  0x05020B50 (0x3ffb44a0b50): 0x00000000
    Read at address  0x05020B54 (0x3ffb72e0b54): 0x00000000
    Read at address  0x05020B58 (0x3ff83940b58): 0x00000000
    Read at address  0x05020B5C (0x3ffa2f80b5c): 0x00000000
    Read at address  0x05020B60 (0x3ffbe630b60): 0x00000000
    Read at address  0x05020B64 (0x3ffb05f0b64): 0x00000000
    Read at address  0x05020B68 (0x3ffb0f10b68): 0x00000000
    Read at address  0x05020B6C (0x3ff84d50b6c): 0x00000000
    Read at address  0x05020B70 (0x3ff8a620b70): 0x00000000
    Read at address  0x05020B74 (0x3ffa21a0b74): 0x00000000
    Read at address  0x05020B78 (0x3ffb1950b78): 0x00000000
    Read at address  0x05020B7C (0x3ff9e140b7c): 0x00000000
    Read at address  0x05020B80 (0x3ffae300b80): 0x00000000
    Read at address  0x05020B84 (0x3ffbd220b84): 0x00000000
    Read at address  0x05020B88 (0x3ffa8680b88): 0x00000000
    Read at address  0x05020B8C (0x3ff8b0e0b8c): 0x00000000
    Read at address  0x05020B90 (0x3ff89d20b90): 0x00000000
    Read at address  0x05020B94 (0x3ffa6ca0b94): 0x00000000
    Read at address  0x05020B98 (0x3ff95c50b98): 0x00000000
    Read at address  0x05020B9C (0x3ff9db20b9c): 0x00000000
    Read at address  0x05020BA0 (0x3ffb27e0ba0): 0x00000000
    Read at address  0x05020BA4 (0x3ffade30ba4): 0x00000000
    Read at address  0x05020BA8 (0x3ffa9db0ba8): 0x00000000
    Read at address  0x05020BAC (0x3ff89070bac): 0x00000000
    Read at address  0x05020BB0 (0x3ffa8440bb0): 0x00000000
    Read at address  0x05020BB4 (0x3ffa0600bb4): 0x00000000
    Read at address  0x05020BB8 (0x3ffb0490bb8): 0x00000000
    Read at address  0x05020BBC (0x3ff92470bbc): 0x00000000
    Read at address  0x05020BC0 (0x3ff90910bc0): 0x00000000
    Read at address  0x05020BC4 (0x3ffb7f00bc4): 0x00000000
    Read at address  0x05020BC8 (0x3ff970c0bc8): 0x00000000
    Read at address  0x05020BCC (0x3ffbddc0bcc): 0x00000000
    Read at address  0x05020BD0 (0x3ffa0540bd0): 0x00000000
    Read at address  0x05020BD4 (0x3ff96a20bd4): 0x00000000
    Read at address  0x05020BD8 (0x3ffadc30bd8): 0x00000000
    Read at address  0x05020BDC (0x3ff97b80bdc): 0x00000000
    Read at address  0x05020BE0 (0x3ff82de0be0): 0x00000000
    Read at address  0x05020BE4 (0x3ff94440be4): 0x00000000
    Read at address  0x05020BE8 (0x3ff843a0be8): 0x00000000
    Read at address  0x05020BEC (0x3ff83730bec): 0x00000000
    Read at address  0x05020BF0 (0x3ffabc90bf0): 0x00000000
    Read at address  0x05020BF4 (0x3ffa5f80bf4): 0x00000000
    Read at address  0x05020BF8 (0x3ff966f0bf8): 0x00000000
    Read at address  0x05020BFC (0x3ff8bec0bfc): 0x00000000
    Read at address  0x05020C00 (0x3ffad690c00): 0x00000000
    Read at address  0x05020C04 (0x3ffba500c04): 0x00000000
    Read at address  0x05020C08 (0x3ffaf0a0c08): 0x00000000
    Read at address  0x05020C0C (0x3ffb7000c0c): 0x00000000
    Read at address  0x05020C10 (0x3ffa61e0c10): 0x00000000
    Read at address  0x05020C14 (0x3ff9acb0c14): 0x00000000
    Read at address  0x05020C18 (0x3ff852c0c18): 0x00000000
    Read at address  0x05020C1C (0x3ffbca10c1c): 0x00000000
    Read at address  0x05020C20 (0x3ff97350c20): 0x00000000
    Read at address  0x05020C24 (0x3ffbc140c24): 0x00000000
    Read at address  0x05020C28 (0x3ff87eb0c28): 0x00000000
    Read at address  0x05020C2C (0x3ff88750c2c): 0x00000000
    Read at address  0x05020C30 (0x3ffb49c0c30): 0x00000000
    Read at address  0x05020C34 (0x3ffaea30c34): 0x00000000
    Read at address  0x05020C38 (0x3ffa2cf0c38): 0x00000000
    Read at address  0x05020C3C (0x3ffabd50c3c): 0x00000000
    Read at address  0x05020C40 (0x3ff80410c40): 0x00000000
    Read at address  0x05020C44 (0x3ff8bfd0c44): 0x00000000
    Read at address  0x05020C48 (0x3ffb2fb0c48): 0x00000000
    Read at address  0x05020C4C (0x3ff9cf50c4c): 0x00000000
    Read at address  0x05020C50 (0x3ff85ca0c50): 0x00000000
    Read at address  0x05020C54 (0x3ffaa860c54): 0x00000000
    Read at address  0x05020C58 (0x3ffa2370c58): 0x00000000
    Read at address  0x05020C5C (0x3ffad390c5c): 0x00000000
    Read at address  0x05020C60 (0x3ff8ec20c60): 0x00000000
    Read at address  0x05020C64 (0x3ffa68e0c64): 0x00000000
    Read at address  0x05020C68 (0x3ff9f7c0c68): 0x00000000
    Read at address  0x05020C6C (0x3ff7f4b0c6c): 0x00000000
    Read at address  0x05020C70 (0x3ff88f00c70): 0x00000000
    Read at address  0x05020C74 (0x3ff81b80c74): 0x00000000
    Read at address  0x05020C78 (0x3ff853f0c78): 0x00000000
    Read at address  0x05020C7C (0x3ff99120c7c): 0x00000000
    Read at address  0x05020C80 (0x3ffb1200c80): 0x00000000
    Read at address  0x05020C84 (0x3ffac9a0c84): 0x00000000
    Read at address  0x05020C88 (0x3ffbd860c88): 0x00000000
    Read at address  0x05020C8C (0x3ffa9fa0c8c): 0x00000000
    Read at address  0x05020C90 (0x3ffa1730c90): 0x00000000
    Read at address  0x05020C94 (0x3ff8f390c94): 0x00000000
    Read at address  0x05020C98 (0x3ff97990c98): 0x00000000
    Read at address  0x05020C9C (0x3ffa9300c9c): 0x00000000
    Read at address  0x05020CA0 (0x3ff9feb0ca0): 0x00000000
    Read at address  0x05020CA4 (0x3ffb74f0ca4): 0x00000000
    Read at address  0x05020CA8 (0x3ffadc50ca8): 0x00000000
    Read at address  0x05020CAC (0x3ffba7c0cac): 0x00000000
    Read at address  0x05020CB0 (0x3ff95410cb0): 0x00000000
    Read at address  0x05020CB4 (0x3ff92520cb4): 0x00000000
    Read at address  0x05020CB8 (0x3ff9d4b0cb8): 0x00000000
    Read at address  0x05020CBC (0x3ff8bb20cbc): 0x00000000
    Read at address  0x05020CC0 (0x3ffa6880cc0): 0x00000000
    Read at address  0x05020CC4 (0x3ffa9210cc4): 0x00000000
    Read at address  0x05020CC8 (0x3ffb29d0cc8): 0x00000000
    Read at address  0x05020CCC (0x3ff908c0ccc): 0x00000000
    Read at address  0x05020CD0 (0x3ffbae10cd0): 0x00000000
    Read at address  0x05020CD4 (0x3ffaa1a0cd4): 0x00000000
    Read at address  0x05020CD8 (0x3ffbda70cd8): 0x00000000
    Read at address  0x05020CDC (0x3ff9efb0cdc): 0x00000000
    Read at address  0x05020CE0 (0x3ffae130ce0): 0x00000000
    Read at address  0x05020CE4 (0x3ffb5e70ce4): 0x00000000
    Read at address  0x05020CE8 (0x3ff89480ce8): 0x00000000
    Read at address  0x05020CEC (0x3ffb29c0cec): 0x00000000
    Read at address  0x05020CF0 (0x3ffa47f0cf0): 0x00000000
    Read at address  0x05020CF4 (0x3ff857f0cf4): 0x00000000
    Read at address  0x05020CF8 (0x3ffb5710cf8): 0x00000000
    Read at address  0x05020CFC (0x3ff9ab50cfc): 0x00000000
    Read at address  0x05020D00 (0x3ff84ce0d00): 0x00000000
    Read at address  0x05020D04 (0x3ffafef0d04): 0x00000000
    Read at address  0x05020D08 (0x3ff97980d08): 0x00000000
    Read at address  0x05020D0C (0x3ff8f5d0d0c): 0x00000000
    Read at address  0x05020D10 (0x3ffbc5a0d10): 0x00000000
    Read at address  0x05020D14 (0x3ffb5f40d14): 0x00000000
    Read at address  0x05020D18 (0x3ff99dc0d18): 0x00000000
    Read at address  0x05020D1C (0x3ffb57a0d1c): 0x00000000
    Read at address  0x05020D20 (0x3ffa8000d20): 0x00000000
    Read at address  0x05020D24 (0x3ff95a60d24): 0x00000000
    Read at address  0x05020D28 (0x3ff970e0d28): 0x00000000
    Read at address  0x05020D2C (0x3ffa1bf0d2c): 0x00000000
    Read at address  0x05020D30 (0x3ffbb810d30): 0x00000000
    Read at address  0x05020D34 (0x3ffa0140d34): 0x00000000
    Read at address  0x05020D38 (0x3ff836a0d38): 0x00000000
    Read at address  0x05020D3C (0x3ffa4840d3c): 0x00000000
    Read at address  0x05020D40 (0x3ff8e8f0d40): 0x00000000
    Read at address  0x05020D44 (0x3ffa5800d44): 0x00000000
    Read at address  0x05020D48 (0x3ff85310d48): 0x00000000
    Read at address  0x05020D4C (0x3ffb4700d4c): 0x00000000
    Read at address  0x05020D50 (0x3ff8dc30d50): 0x00000000
    Read at address  0x05020D54 (0x3ffa2660d54): 0x00000000
    Read at address  0x05020D58 (0x3ff82560d58): 0x00000000
    Read at address  0x05020D5C (0x3ffa2d50d5c): 0x00000000
    Read at address  0x05020D60 (0x3ff9f4b0d60): 0x00000000
    Read at address  0x05020D64 (0x3ff8e450d64): 0x00000000
    Read at address  0x05020D68 (0x3ff96940d68): 0x00000000
    Read at address  0x05020D6C (0x3ff957e0d6c): 0x00000000
    Read at address  0x05020D70 (0x3ffb1850d70): 0x00000000
    Read at address  0x05020D74 (0x3ff9a670d74): 0x00000000
    Read at address  0x05020D78 (0x3ff99bc0d78): 0x00000000
    Read at address  0x05020D7C (0x3ffb4f80d7c): 0x00000000
    Read at address  0x05020D80 (0x3ffaf9b0d80): 0x00000000
    Read at address  0x05020D84 (0x3ff95fe0d84): 0x00000000
    Read at address  0x05020D88 (0x3ff9a1a0d88): 0x00000000
    Read at address  0x05020D8C (0x3ff9e910d8c): 0x00000000
    Read at address  0x05020D90 (0x3ff7ed70d90): 0x00000000
    Read at address  0x05020D94 (0x3ff88ea0d94): 0x00000000
    Read at address  0x05020D98 (0x3ff98740d98): 0x00000000
    Read at address  0x05020D9C (0x3ffb7720d9c): 0x00000000
    Read at address  0x05020DA0 (0x3ffbe300da0): 0x00000000
    Read at address  0x05020DA4 (0x3ffb8b30da4): 0x00000000
    Read at address  0x05020DA8 (0x3ffaf090da8): 0x00000000
    Read at address  0x05020DAC (0x3ff94400dac): 0x00000000
    Read at address  0x05020DB0 (0x3ff91620db0): 0x00000000
    Read at address  0x05020DB4 (0x3ff8a380db4): 0x00000000
    Read at address  0x05020DB8 (0x3ffb44e0db8): 0x00000000
    Read at address  0x05020DBC (0x3ffbbce0dbc): 0x00000000
    Read at address  0x05020DC0 (0x3ff8e850dc0): 0x00000000
    Read at address  0x05020DC4 (0x3ffbba70dc4): 0x00000000
    Read at address  0x05020DC8 (0x3ff93740dc8): 0x00000000
    Read at address  0x05020DCC (0x3ffad8a0dcc): 0x00000000
    Read at address  0x05020DD0 (0x3ffb18c0dd0): 0x00000000
    Read at address  0x05020DD4 (0x3ffb07a0dd4): 0x00000000
    Read at address  0x05020DD8 (0x3ff835c0dd8): 0x00000000
    Read at address  0x05020DDC (0x3ffb8560ddc): 0x00000000
    Read at address  0x05020DE0 (0x3ff956b0de0): 0x00000000
    Read at address  0x05020DE4 (0x3ffa5330de4): 0x00000000
    Read at address  0x05020DE8 (0x3ffa7d70de8): 0x00000000
    Read at address  0x05020DEC (0x3ffa87b0dec): 0x00000000
    Read at address  0x05020DF0 (0x3ff8d4d0df0): 0x00000000
    Read at address  0x05020DF4 (0x3ff957a0df4): 0x00000000
    Read at address  0x05020DF8 (0x3ffafc00df8): 0x00000000
    Read at address  0x05020DFC (0x3ff90770dfc): 0x00000000
    Read at address  0x05020E00 (0x3ffabc10e00): 0x00000000
    Read at address  0x05020E04 (0x3ffabb30e04): 0x00000000
    Read at address  0x05020E08 (0x3ffad370e08): 0x00000000
    Read at address  0x05020E0C (0x3ffab230e0c): 0x00000000
    Read at address  0x05020E10 (0x3ff82b10e10): 0x00000000
    Read at address  0x05020E14 (0x3ffb12c0e14): 0x00000000
    Read at address  0x05020E18 (0x3ffbc0f0e18): 0x00000000
    Read at address  0x05020E1C (0x3ff8f230e1c): 0x00000000
    Read at address  0x05020E20 (0x3ffa9560e20): 0x00000000
    Read at address  0x05020E24 (0x3ff8f080e24): 0x00000000
    Read at address  0x05020E28 (0x3ffa7cf0e28): 0x00000000
    Read at address  0x05020E2C (0x3ffa91f0e2c): 0x00000000
    Read at address  0x05020E30 (0x3ff95f90e30): 0x00000000
    Read at address  0x05020E34 (0x3ffb3310e34): 0x00000000
    Read at address  0x05020E38 (0x3ffa7a40e38): 0x00000000
    Read at address  0x05020E3C (0x3ff9b840e3c): 0x00000000
    Read at address  0x05020E40 (0x3ffa8540e40): 0x00000000
    Read at address  0x05020E44 (0x3ff92990e44): 0x00000000
    Read at address  0x05020E48 (0x3ffa3600e48): 0x00000000
    Read at address  0x05020E4C (0x3ff84290e4c): 0x00000000
    Read at address  0x05020E50 (0x3ff8be50e50): 0x00000000
    Read at address  0x05020E54 (0x3ffb3620e54): 0x00000000
    Read at address  0x05020E58 (0x3ff8e420e58): 0x00000000
    Read at address  0x05020E5C (0x3ff98eb0e5c): 0x00000000
    Read at address  0x05020E60 (0x3ffaa860e60): 0x00000000
    Read at address  0x05020E64 (0x3ffb9540e64): 0x00000000
    Read at address  0x05020E68 (0x3ff95060e68): 0x00000000
    Read at address  0x05020E6C (0x3ffb9eb0e6c): 0x00000000
    Read at address  0x05020E70 (0x3ffa6fe0e70): 0x00000000
    Read at address  0x05020E74 (0x3ffb8230e74): 0x00000000
    Read at address  0x05020E78 (0x3ffabe40e78): 0x00000000
    Read at address  0x05020E7C (0x3ff8c180e7c): 0x00000000
    Read at address  0x05020E80 (0x3ff81d80e80): 0x00000000
    Read at address  0x05020E84 (0x3ff862a0e84): 0x00000000
    Read at address  0x05020E88 (0x3ff9b8f0e88): 0x00000000
    Read at address  0x05020E8C (0x3ffb3510e8c): 0x00000000
    Read at address  0x05020E90 (0x3ff96e70e90): 0x00000000
    Read at address  0x05020E94 (0x3ffbd6e0e94): 0x00000000
    Read at address  0x05020E98 (0x3ff99e10e98): 0x00000000
    Read at address  0x05020E9C (0x3ffb04c0e9c): 0x00000000
    Read at address  0x05020EA0 (0x3ffad880ea0): 0x00000000
    Read at address  0x05020EA4 (0x3ffbc0e0ea4): 0x00000000
    Read at address  0x05020EA8 (0x3ffb0360ea8): 0x00000000
    Read at address  0x05020EAC (0x3ffaa070eac): 0x00000000
    Read at address  0x05020EB0 (0x3ffa1730eb0): 0x00000000
    Read at address  0x05020EB4 (0x3ffb0030eb4): 0x00000000
    Read at address  0x05020EB8 (0x3ff83660eb8): 0x00000000
    Read at address  0x05020EBC (0x3ff9e980ebc): 0x00000000
    Read at address  0x05020EC0 (0x3ff85060ec0): 0x00000000
    Read at address  0x05020EC4 (0x3ff843f0ec4): 0x00000000
    Read at address  0x05020EC8 (0x3ff81aa0ec8): 0x00000000
    Read at address  0x05020ECC (0x3ffa5560ecc): 0x00000000
    Read at address  0x05020ED0 (0x3ff98990ed0): 0x00000000
    Read at address  0x05020ED4 (0x3ffbd3f0ed4): 0x00000000
    Read at address  0x05020ED8 (0x3ffa4bd0ed8): 0x00000000
    Read at address  0x05020EDC (0x3ff92ef0edc): 0x00000000
    Read at address  0x05020EE0 (0x3ff80f70ee0): 0x00000000
    Read at address  0x05020EE4 (0x3ffac3f0ee4): 0x00000000
    Read at address  0x05020EE8 (0x3ffa28a0ee8): 0x00000000
    Read at address  0x05020EEC (0x3ffb9440eec): 0x00000000
    Read at address  0x05020EF0 (0x3ffa1f50ef0): 0x00000000
    Read at address  0x05020EF4 (0x3ff95df0ef4): 0x00000000
    Read at address  0x05020EF8 (0x3ffb0170ef8): 0x00000000
    Read at address  0x05020EFC (0x3ffb9730efc): 0x00000000
    Read at address  0x05020F00 (0x3ff8a560f00): 0x00000000
    Read at address  0x05020F04 (0x3ffafef0f04): 0x00000000
    Read at address  0x05020F08 (0x3ff8c940f08): 0x00000000
    Read at address  0x05020F0C (0x3ff8dd30f0c): 0x00000000
    Read at address  0x05020F10 (0x3ffa1a00f10): 0x00000000
    Read at address  0x05020F14 (0x3ff7e980f14): 0x00000000
    Read at address  0x05020F18 (0x3ff88d70f18): 0x00000000
    Read at address  0x05020F1C (0x3ff87070f1c): 0x00000000
    Read at address  0x05020F20 (0x3ff8c580f20): 0x00000000
    Read at address  0x05020F24 (0x3ff801c0f24): 0x00000000
    Read at address  0x05020F28 (0x3ffb83f0f28): 0x00000000
    Read at address  0x05020F2C (0x3ff86820f2c): 0x00000000
    Read at address  0x05020F30 (0x3ff9bdf0f30): 0x00000000
    Read at address  0x05020F34 (0x3ff99ee0f34): 0x00000000
    Read at address  0x05020F38 (0x3ffb4320f38): 0x00000000
    Read at address  0x05020F3C (0x3ffa6cd0f3c): 0x00000000
    Read at address  0x05020F40 (0x3ff92580f40): 0x00000000
    Read at address  0x05020F44 (0x3ffb4c00f44): 0x00000000
    Read at address  0x05020F48 (0x3ff8e430f48): 0x00000000
    Read at address  0x05020F4C (0x3ff81a60f4c): 0x00000000
    Read at address  0x05020F50 (0x3ff7f440f50): 0x00000000
    Read at address  0x05020F54 (0x3ffb4110f54): 0x00000000
    Read at address  0x05020F58 (0x3ff97210f58): 0x00000000
    Read at address  0x05020F5C (0x3ff85760f5c): 0x00000000
    Read at address  0x05020F60 (0x3ff9c8b0f60): 0x00000000
    Read at address  0x05020F64 (0x3ff897c0f64): 0x00000000
    Read at address  0x05020F68 (0x3ff8d850f68): 0x00000000
    Read at address  0x05020F6C (0x3ffa1a90f6c): 0x00000000
    Read at address  0x05020F70 (0x3ffba770f70): 0x00000000
    Read at address  0x05020F74 (0x3ff9a940f74): 0x00000000
    Read at address  0x05020F78 (0x3ffa2e30f78): 0x00000000
    Read at address  0x05020F7C (0x3ffab7a0f7c): 0x00000000
    Read at address  0x05020F80 (0x3ff9bd10f80): 0x00000000
    Read at address  0x05020F84 (0x3ffb0a90f84): 0x00000000
    Read at address  0x05020F88 (0x3ff959d0f88): 0x00000000
    Read at address  0x05020F8C (0x3ffb41f0f8c): 0x00000000
    Read at address  0x05020F90 (0x3ff85ba0f90): 0x00000000
    Read at address  0x05020F94 (0x3ffba400f94): 0x00000000
    Read at address  0x05020F98 (0x3ff88810f98): 0x00000000
    Read at address  0x05020F9C (0x3ffa09f0f9c): 0x00000000
    Read at address  0x05020FA0 (0x3ffaa0d0fa0): 0x00000000
    Read at address  0x05020FA4 (0x3ffb9150fa4): 0x00000000
    Read at address  0x05020FA8 (0x3ff97860fa8): 0x00000000
    Read at address  0x05020FAC (0x3ffa2020fac): 0x00000000
    Read at address  0x05020FB0 (0x3ff95900fb0): 0x00000000
    Read at address  0x05020FB4 (0x3ffafb20fb4): 0x00000000
    Read at address  0x05020FB8 (0x3ffb5110fb8): 0x00000000
    Read at address  0x05020FBC (0x3ff808b0fbc): 0x00000000
    Read at address  0x05020FC0 (0x3ff81d50fc0): 0x00000000
    Read at address  0x05020FC4 (0x3ffaeda0fc4): 0x00000000
    Read at address  0x05020FC8 (0x3ffb4030fc8): 0x00000000
    Read at address  0x05020FCC (0x3ffa9b30fcc): 0x00000000
    Read at address  0x05020FD0 (0x3ffa0b10fd0): 0x00000000
    Read at address  0x05020FD4 (0x3ffb5e40fd4): 0x00000000
    Read at address  0x05020FD8 (0x3ff99250fd8): 0x00000000
    Read at address  0x05020FDC (0x3ffb2080fdc): 0x00000000
    Read at address  0x05020FE0 (0x3ffa56e0fe0): 0x00000000
    Read at address  0x05020FE4 (0x3ff89760fe4): 0x00000000
    Read at address  0x05020FE8 (0x3ffa9ed0fe8): 0x00000000
    Read at address  0x05020FEC (0x3ff93630fec): 0x00000000
    Read at address  0x05020FF0 (0x3ff81240ff0): 0x00000000
    Read at address  0x05020FF4 (0x3ffaed60ff4): 0x00000000
    Read at address  0x05020FF8 (0x3ff96ca0ff8): 0x00000000
    Read at address  0x05020FFC (0x3ff94850ffc): 0x00000000
    建议客户从 RTOS 使用串行器/解串器寄存器配置并迁移到 Linux、因为对于当前的8.6 SDK 而言、它们的设置是不同的。 希望此原生9G 驱动程序将受到 PSDK9.0版开包即用支持。 谢谢。
    现在就结束了。
    尊敬的,
    在 SDK 8.5中,此问题已修复,衰减原因是 SerDes 寄存器错误
