我们有一款带有 AM6442.A PSRAM (MRAM)的定制电路板、通过16位 GPMC 异步非多路复用数据/地址连接。
我根据代码部分基于 AM26xx PSRAM GPMC 示例、部分基于 AM64xx NAND 闪存示例。
很遗憾、当尝试从 PSRAM 中读取时、我收到数据中止错误。 对于我的生命,我不知道这个问题。
我收到同步外部中止:
而 GPMC 的 ERRORNOTSUPPADD 错误:
我假设 BASEADDRESS 配置错误、但这是由 GPMC 驱动程序"自动"完成的:
下面是我的代码片段:
/* GPMC attributes */ static GPMC_HwAttrs gGpmcAttrs[CONFIG_GPMC_NUM_INSTANCES] = { { .gpmcBaseAddr = CSL_GPMC0_CFG_BASE, .dataBaseAddr = CSL_GPMC0_DATA_BASE, .inputClkFreq = 133333333U, .intrNum = CSLR_R5FSS0_CORE0_INTR_GPMC0_GPMC_SINTERRUPT_0, .intrPriority = 4U, .chipSelBaseAddr = CSL_GPMC0_DATA_BASE, .chipSelAddrSize = GPMC_CS_MASK_ADDR_SIZE_16MB, .clkDivider = CSL_GPMC_CONFIG1_GPMCFCLKDIVIDER_DIVBY4, .waitPinNum = CSL_GPMC_CONFIG1_WAITPINSELECT_W0, .addrDataMux = CSL_GPMC_CONFIG1_MUXADDDATA_NONMUX, .timeLatency = CSL_GPMC_CONFIG1_TIMEPARAGRANULARITY_X1, .waitPinPol = CSL_GPMC_CONFIG_WAIT0PINPOLARITY_W0ACTIVEL, .timingParams = { .csOnTime = GPMC_PSRAM_CS_ON_TIME, .csRdOffTime = GPMC_PSRAM_CS_RD_OFF_TIME, .csWrOffTime = GPMC_PSRAM_CS_WR_OFF_TIME, .advOnTime = GPMC_PSRAM_ADV_ON_TIME, .advRdOffTime = GPMC_PSRAM_ADV_RD_OFF_TIME, .advWrOffTime = GPMC_PSRAM_ADV_WR_OFF_TIME, .advAadMuxOnTime = GPMC_PSRAM_ADV_AADMUX_ON_TIME, .advAadMuxRdOffTime = GPMC_PSRAM_ADV_AADMUX_RD_OFF_TIME, .advAadMuxWrOffTime = GPMC_PSRAM_ADV_AADMUX_WR_OFF_TIME, .weOnTtime = GPMC_PSRAM_WE_ON_TIME, .weOffTime = GPMC_PSRAM_WE_OFF_TIME, .oeOnTime = GPMC_PSRAM_OE_ON_TIME, .oeOffTime = GPMC_PSRAM_OE_OFF_TIME, .oeAadMuxOnTime = GPMC_PSRAM_OE_AADMUX_ON_TIME, .oeAadMuxOffTime = GPMC_PSRAM_OE_AADMUX_OFF_TIME, .pageBurstAccess = GPMC_PSRAM_PAGEBURST_ACCESS_TIME, .rdAccessTime = GPMC_PSRAM_RD_ACCESS_TIME, .wrAcessTime = GPMC_PSRAM_WR_ACCESS_TIME, .rdCycleTime = GPMC_PSRAM_RD_CYCLE_TIME, .wrCycleTime = GPMC_PSRAM_WR_CYCLE_TIME, .wrDataOnMuxBusTime = GPMC_PSRAM_ADMUX_DATA_VALID, .cycle2CycleDelay = GPMC_PSRAM_C2C_DELAY, .cycleDelaySameChipSel = CSL_GPMC_CONFIG6_CYCLE2CYCLESAMECSEN_NOC2CDELAY, .cycleDelayDiffChipSel = CSL_GPMC_CONFIG6_CYCLE2CYCLEDIFFCSEN_NOC2CDELAY, .busTurnAroundTime = GPMC_PSRAM_BRST_TAROUND_TIME, }, .readType = CSL_GPMC_CONFIG1_READTYPE_RDASYNC, .csExDelay = CSL_GPMC_CONFIG2_CSEXTRADELAY_NOTDELAYED, .accessType = CSL_GPMC_CONFIG1_READMULTIPLE_RDSINGLE, }, };
/* GPMC Driver Parameters */ GPMC_Params gGpmcParams[CONFIG_GPMC_NUM_INSTANCES] = { { .gpmcDmaChIndex = -1, .devType = CSL_GPMC_CONFIG1_DEVICETYPE_NORLIKE, .devSize = CSL_GPMC_CONFIG1_DEVICESIZE_SIXTEENBITS, .chipSel = GPMC_CHIP_SELECT_CS0, .intrEnable = FALSE, .dmaEnable = FALSE, .transferMode = GPMC_TRANSFER_MODE_BLOCKING, .transferCallBckFunc = NULL, .memDevice = GPMC_MEM_TYPE_PSRAM, }, };
int32_t mram_gpmcRead (uint32_t offset, uint8_t *buf, uint32_t len) { int32_t status = SystemP_SUCCESS; uint32_t size = len; /*if(offset + len > config->attrs->psramSize) { status = SystemP_FAILURE; }*/ uint32_t baseAddress = GPMC_DATA_BASE_ADDRESS; volatile uint16_t *pSrc = (volatile uint16_t *)(offset+baseAddress); volatile uint16_t *pDst = (volatile uint16_t *)buf; uint32_t remain = size & 0x1; if (remain != 0U) { size = size - remain + 2U; } while (size != 0U) { *pDst = *pSrc; pSrc++; pDst++; size -= 2U; } return status; }
我非常感谢您的支持。
您好
斯特凡
