我尝试在 Linux 主机中安装 CCS10、但收到以下错误:
WARNING: ccs10-native-1.0-r0 do_configure: [14:11:30] CCS_INFO: Done installing repository INSTALLER 10.4.0.00006.zip WARNING: ccs10-native-1.0-r0 do_configure: [14:11:30] CCS_INFO: Looking for binaries to install... WARNING: ccs10-native-1.0-r0 do_configure: Creating directory /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS WARNING: ccs10-native-1.0-r0 do_configure: Creating directory /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/features WARNING: ccs10-native-1.0-r0 do_configure: Unpacking files WARNING: ccs10-native-1.0-r0 do_configure: Unpacking /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/artifacts.xml WARNING: ccs10-native-1.0-r0 do_configure: Unpacking /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/content.xml WARNING: ccs10-native-1.0-r0 do_configure: Unpacking /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run WARNING: ccs10-native-1.0-r0 do_configure: Unpacking /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/features/com.ti.ccstudio.debugserver.linux_10.4.0.2437.jar WARNING: ccs10-native-1.0-r0 do_configure: [14:11:30] CCS_INFO: Installing DS WARNING: ccs10-native-1.0-r0 do_configure: Executing chmod -R 755 "/tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run" WARNING: ccs10-native-1.0-r0 do_configure: Script exit code: 0 WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: Script output: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: Script stderr: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: [14:11:31] showprogress = false WARNING: ccs10-native-1.0-r0 do_configure: [14:11:31] CCS_INFO: Installing /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run WARNING: ccs10-native-1.0-r0 do_configure: [14:11:31] CCS_INFO: Actual executable /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run WARNING: ccs10-native-1.0-r0 do_configure: Executing /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run --prefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs" --eclipseprefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/eclipse" --mode unattended --installer-log "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/install_logs/20241205141027" --ccs true WARNING: ccs10-native-1.0-r0 do_configure: Script exit code: 1 WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: Script output: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: Script stderr: WARNING: ccs10-native-1.0-r0 do_configure: child process exited abnormally WARNING: ccs10-native-1.0-r0 do_configure: WARNING: ccs10-native-1.0-r0 do_configure: Error running /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run --prefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs" --eclipseprefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/eclipse" --mode unattended --installer-log "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/install_logs/20241205141027" --ccs true: child process exited abnormally WARNING: ccs10-native-1.0-r0 do_configure: CCS_ERROR: Unable to install executable /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run: Error running /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run --prefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs" --eclipseprefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/eclipse" --mode unattended --installer-log "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/install_logs/20241205141027" --ccs true: child process exited abnormally. WARNING: ccs10-native-1.0-r0 do_configure: Do you want to retry? WARNING: ccs10-native-1.0-r0 do_configure: [14:12:13] CCS_ERROR: Unable to install executable /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run: Error running /tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run --prefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs" --eclipseprefix "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/eclipse" --mode unattended --installer-log "/__w/1/s/build/tmp/work/x86_64-linux/ccs10-native/1.0-r0/ti/ccs1040/ccs/install_logs/20241205141027" --ccs true: child process exited abnormally: 1 WARNING: ccs10-native-1.0-r0 do_configure: [14:12:13] CCS_INFO: In installationAbortedActionList WARNING: ccs10-native-1.0-r0 do_configure: An issue was encountered while installing CCS. Would you like to submit the installation logs to help us diagnose and fix the issue? WARNING: ccs10-native-1.0-r0 do_configure: no
似乎是我在尝试安装以下软件包时导致的错误:
警告:ccs10-native-1.0-r0 do_configure:正在执行/tmp/ccs_eab761c4-4a57-4b51-543d-420b5840055b/DS/ti_dspack_ibsetup_linux-x64_10.4.0.2437.run --prefix "/__w/1/s/build/tmp/work/ccs10-native/1.0-r0/ti/ccs1040/ccs"--
警告:ccs10-native-1.0-r0 DO_configure:脚本退出代码:1.
警告:ccs10-native-1.0-r0 DO_configure:脚本输出:
警告:ccs10-native-1.0-r0 DO_configure:脚本 stderr:
警告:ccs10-native-1.0-r0 DO_configure: 子进程异常退出
你有什么想法吗?
