[参考译文] PROCESSOR-SDK-AM62X:加载 u-boot.img 时出现 dfu-util 错误
Guru**** 2037690 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1451376/processor-sdk-am62x-dfu-util-error-while-loading-u-boot-img
器件型号:PROCESSOR-SDK-AM62X
我们在 AM62x 平台上工作的处理器 SDK 09.02.01.10。
当尝试刷写  u-boot.img.raw 映像时、我们收到错误消息"DFU state (10)= dfuERROR、status (14)=出错、但器件不知道是什么"
我们的 eMMC 定制电路板为4GB (类型:THGBMTG5D1LBAIL)。
请提供建议。
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
$ sudo dfu-util -a tiboot3.bin.raw -D tiboot3-am62x-hs-fs-evm.bin
dfu-util 0.11-dev
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to sourceforge.net/.../
dfu-util: Warning: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release
Opening DFU capable USB device...
Device ID 0451:6165
Device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Interface #2 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 0110
Device returned transfer size 4096
Copying data from PC to DFU device
Download [=========================] 100% 295502 bytes
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    UART 上的错误消息如下所示。
    MMC:块编号0x1428超过最大值(0x1000)
    MMC 操作失败#MMC:块编号0x1428超过最大值(0x1000)
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    => dfu 0 mmc 0
    generic_phy_get_bulk : no phys property
    ###############DOWNLOAD ... OK
    Ctrl+C to exit ...
    ##########################################################DOWNLOAD ... OK
    Ctrl+C to exit ...
    MMC: block number 0x1428 exceeds max(0x1000)
    MMC operation failed#MMC: block number 0x1428 exceeds max(0x1000)
    上传整个 UART 引导日志。
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    U-Boot 2023.04-00001-gf5b119738d (Jan 23 2024 - 11:51:46 +0800)
    SoC: AM62X SR1.0 HS-FS
    Model: Texas Instruments AM625 SK
    EEPROM not available at 80, trying to read at 81
    Reading on-board EEPROM at 0x51 failed -121
    DRAM: 2 GiB
    Core: 71 devices, 31 uclasses, devicetree: separate
    MMC: mmc@fa10000: 0, mmc@fa00000: 1
    Loading Environment from nowhere... OK
    In: serial
    Out: serial
    Err: serial
    Net: eth0: ethernet@8000000port@1
    Hit any key to stop autoboot: 0
    MMC: no card present
    SD/MMC found on device 1
    ** Bad device specification mmc 1 **
    我尝试 在 u-boot 中设置不同的 dfu_alt_info_emmc、 从 tiboot3.bin.raw 和 tispl.bin.raw 向 u-boot.img.raw 释放空间 、然后我可以看到 u-boot.img.raw 能够具有40%的下载过程。  因此、该问题似乎与 eMMC 或引导加载程序映像的总大小有关。  但是、我们的引导加载程序映像能够下载到  AM62X SKEVM PROC142A 板中、因此引导加载程序映像的大小应适合我们的自定义板。
    这是原始 dfu_alt_info_eMMC:
    Fullscreen
    1
    rawemmc raw 0 0x800000 mmcpart 1; rootfs part 0 1; tiboot3.bin.raw raw 0x0 0x400 mmcpart 1; tispl.bin.raw raw 0x400 0x1000 mmcpart 1; u-boot.img.raw raw 0x1400 0x2000 mmcpart 1; u-env.raw raw 0x3400 0x100 mmcpart 1; sysfw.itb.raw raw 0x3600 0x800 mmcpart 1
    然后、我修改  dfu_alt_info_eMMC:
    Fullscreen
    1
    rawemmc raw 0 0x800000 mmcpart 1; rootfs part 0 1; tiboot3.bin.raw raw 0x0 0x300 mmcpart 1; tispl.bin.raw raw 0x300 0x0a00 mmcpart 1; u-boot.img.raw raw 0x0d00 0x0800 mmcpart 1; u-env.raw raw 0x1500 0x100 mmcpart 1; sysfw.itb.raw raw 0x1600 0x800 mmcpart 1
    并执行 dfu-util 下载 u-boot.img、我可以看到下载过程的40%。
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    $ sudo dfu-util -a u-boot.img.raw -D u-boot.img
    dfu-util 0.11-dev
    Device ID 0451:6165
    Setting Alternate Interface #4 ...
    Download [========== ] 40% 397312 bytes failed!
    下面是我们定制电路板上的 mmcinfo、 引导容量为2MiB ENH。
    您知道这是 引导区域0和1的总大小吗? 还是单个引导区域?
    如果是单个引导区域、我可以将 tiboot3.bin 和 tispl.bin 放在引导区域0中、将 u-boot.img 放在另一个引导区域中吗?
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    => mmcinfo
    Device: mmc@fa10000
    Manufacturer ID: 11
    OEM: 0
    Bus Speed: 200000000
    Mode: HS200 (200MHz)
    Rd Block Len: 512
    MMC version 5.0
    High Capacity: Yes
    Capacity: 3.7 GiB
    Bus Width: 8-bit
    Erase Group Size: 512 KiB
    HC WP Group Size: 4 MiB
    User Capacity: 3.7 GiB WRREL
    Boot Capacity: 2 MiB ENH
    RPMB Capacity: 512 KiB ENH
    Boot area 0 is not write protected
    Boot area 1 is not write protected
    嗨、专家
    我们有任何更新吗?
    谢谢你。
    Gibbs
    嗨、Gibbs、
    我要把这个分配给另一位专家。 请允许我们随时讨论这个问题。
    Vaibhav
    嗨、Gibbs、
    在继续讨论时结束本主题帖: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1452406/am625-q1-could-we-boot-u-boot-from-emmc-user-partition
    开会。
