https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/1494366/pga970-pga970
器件型号:PGA970工具与软件:
尊敬的 TI:
我发现数据表寄存器(AFEDIAG_CFG)和固件版本 PGA970_Generic_1_6之间存在差异。 请告诉我哪一个是正确的?
我期待你的答复
#define S1_PULL_UP_ENABLE (0 << 0)
#define S1_PULL_UP_DISABLE (1 << 0)
#define S2_PULL_UP_ENABLE (0 << 1)
#define S2_PULL_UP_DISABLE (1 << 1)
#define S3_PULL_UP_ENABLE (0 << 2)
#define S3_PULL_UP_DISABLE (1 << 2)
#define PE_PULL_UP_ENABLE (0 << 3)
#define PE_PULL_UP_DISABLE (1 << 3)
