[参考译文] LAUNCHXL-CC1352P:我想为传感器添加输入、为 GPIO 上的传动器添加输出
Guru**** 2595805 points
Other Parts Discussed in Thread: LPSTK-CC1352R, LAUNCHXL-CC1352P, SYSCONFIG
https://e2e.ti.com/support/wireless-connectivity/sub-1-ghz-group/sub-1-ghz/f/sub-1-ghz-forum/1110519/launchxl-cc1352p-i-want-to-add-inputs-for-sensors-and-outputs-for-actuators-on-the-gpios
器件型号:LAUNCHXL-CC1352P
主题中讨论的其他部件:LPSTK-CC1352RSysConfig
我使用 LAUNCHXL-CC1352P 和 LPSTK-CC1352R 开发低于1GHz 的通信平台。
我使用了您的传感器和收集器示例来获取 TI 15.4堆栈。
我想在 LPSTK-CC1352R 的 GPIO 上添加传感器输入和传动器输出、但我无法这么做。
例如、每次从 LPSTK-CC1352R 发送消息时、我希望 LED 闪烁:
我标识了 GPIO_write 函数、并在 sensor.c 中包含的 sendSensorMessage 中调用了该函数、但在编译结束时会出现以下错误:exected an expression.
我不理解、因为我调用得很好:#include 我通过 SysConfig 创建了一个新变量 CONFIG_GPIO_new_LED。
您是否有任何建议、以便我可以开始开发我的应用?
还是添加符合传感器收集器原理的代码?
请帮帮我
祝你度过美好的一天!
Corentin
    您好、 Corentin、
    是否可以共享更新 的 sendSensorMessage 实现?
    尼古拉伊
    Nikolaj、您好!
    以下是修改后的 sensor.c 文件、您将找到修改后的 sendsensormessage 函数。
     @file sensor.c
     @brief TIMAC 2.0 Sensor Example Application
     Group: WCS LPC
     Target Device: cc13xx_cc26xx
     Copyright (c) 2016-2022, Texas Instruments Incorporated
     All rights reserved.
     Redistribution and use in source and binary forms, with or without
     modification, are permitted provided that the following conditions
     are met:
     *  Redistributions of source code must retain the above copyright
        notice, this list of conditions and the following disclaimer.
     *  Redistributions in binary form must reproduce the above copyright
        notice, this list of conditions and the following disclaimer in the
        documentation and/or other materials provided with the distribution.
     *  Neither the name of Texas Instruments Incorporated nor the names of
        its contributors may be used to endorse or promote products derived
        from this software without specific prior written permission.
     THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     Includes
    #include <string.h>
    #include <stdint.h>
    #include "mac_util.h"
    #include "api_mac.h"
    #include "jdllc.h"
    #include "ssf.h"
    #include "smsgs.h"
    #include "sensor.h"
    #include <advanced_config.h>
    #include "ti_154stack_config.h"
    #include <ti/drivers/GPIO.h>
    #ifdef FEATURE_NATIVE_OAD
    #include "oad_client.h"
    #endif /* FEATURE_NATIVE_OAD */
    #ifdef OSAL_PORT2TIRTOS
    #include <ti/sysbios/knl/Clock.h>
    #else
    #include "icall.h"
    #endif
    #ifdef USE_DMM
    #ifdef DMM_CENTRAL
    #include "central_display.h"
    #else
    #include "remote_display.h"
    #endif /* DMM_CENTRAL */
    #include "ti_dmm_application_policy.h"
    #ifdef FEATURE_SECURE_COMMISSIONING
    #include "sm_commissioning_gatt_profile.h"
    #endif /* FEATURE_SECURE_COMMISSIONING */
    #endif /* USE_DMM */
    #ifdef LPSTK
    #include "lpstk/lpstk.h"
    #endif /* LPSTK */
    #ifndef CUI_DISABLE
    #include "cui.h"
    #endif /* CUI_DISABLE */
    #ifdef DEVICE_TYPE_MSG
    #include <ti/devices/DeviceFamily.h>
    #include "device_type.h"
    #endif /* DEVICE_TYPE_MSG */
    #include "sm_ti154.h"
    #ifdef MAC_DUTY_CYCLE_CHECKING
    #include "mac_duty_cycle/mac_duty_cycle.h"
    #endif
    #ifdef MAC_OVERRIDE_TX_DELAY
    #include "mac_api.h"
    #endif
     Constants and definitions
    #if !defined(CONFIG_AUTO_START)
    #if defined(AUTO_START)
    #define CONFIG_AUTO_START 1
    #else
    #define CONFIG_AUTO_START 0
    #endif
    #endif
    //me
    #define CONFIG_GPIO_NEW_LED
    /* default MSDU Handle rollover */
    #define MSDU_HANDLE_MAX 0x1F
    /* App marker in MSDU handle */
    #define APP_MARKER_MSDU_HANDLE 0x80
    /* App Message Tracking Mask */
    #define APP_MASK_MSDU_HANDLE 0x60
    /* App Sensor Data marker for the MSDU handle */
    #define APP_SENSOR_MSDU_HANDLE 0x40
    /* App tracking response marker for the MSDU handle */
    #define APP_TRACKRSP_MSDU_HANDLE 0x20
    /* App config response marker for the MSDU handle */
    #define APP_CONFIGRSP_MSDU_HANDLE 0x60
    /* Reporting Interval Min and Max (in milliseconds) */
    #define MIN_REPORTING_INTERVAL 1000
    #define MAX_REPORTING_INTERVAL 360000
    /* Polling Interval Min and Max (in milliseconds) */
    #define MIN_POLLING_INTERVAL 1000
    #define MAX_POLLING_INTERVAL 10000
    /* Blink Time for Identify LED Request (in seconds) */
    #define IDENTIFY_LED_TIME 1
    /* Inter packet interval in certification test mode */
    #if CERTIFICATION_TEST_MODE
    #if (((CONFIG_PHY_ID >= APIMAC_MRFSK_STD_PHY_ID_BEGIN) && (CONFIG_PHY_ID <= APIMAC_MRFSK_GENERIC_PHY_ID_BEGIN)) || \
        ((CONFIG_PHY_ID >= APIMAC_200KBPS_915MHZ_PHY_132) && (CONFIG_PHY_ID <= APIMAC_200KBPS_868MHZ_PHY_133)) || \
        (CONFIG_PHY_ID == APIMAC_200KBPS_920MHZ_PHY_136))
    /*! Regular Mode */
    #define CERT_MODE_INTER_PKT_INTERVAL 50
    #elif ((CONFIG_PHY_ID >= APIMAC_MRFSK_GENERIC_PHY_ID_BEGIN + 1) && (CONFIG_PHY_ID <= APIMAC_5KBPS_868MHZ_PHY_131))
    /*! LRM Mode */
    #define CERT_MODE_INTER_PKT_INTERVAL 300
    #else
    #error "PHY ID is wrong."
    #endif
    #endif
     Global variables
    /* MAC's IEEE address. This is only for Sensor */
    extern ApiMac_sAddrExt_t ApiMac_extAddr;
    /* Task pending events */
    uint16_t Sensor_events = 0;
    /* accumulated total E2E delay */
    uint32_t totalE2EDelaySum = 0;
    /* saved end to end delay */
    uint32_t endToEndDelay = 0;
    /*! Sensor statistics */
    Smsgs_msgStatsField_t Sensor_msgStats =
        { 0 };
    extern bool initBroadcastMsg;
    extern bool parentFound;
    #ifdef POWER_MEAS
    /*! Power Meas Stats fields */
    Smsgs_powerMeastatsField_t Sensor_pwrMeasStats =
        { 0 };
    #endif
     Local variables
    static void *sem;
    /*! Rejoined flag */
    static bool rejoining = false;
    /*! Collector's address */
    static ApiMac_sAddr_t collectorAddr = {0};
    /* Join Time Ticks (used for average join time calculations) */
    static uint_fast32_t joinTimeTicks = 0;
    /* End to end delay statistics timestamp */
    static uint32_t startSensorMsgTimeStamp = 0;
    /*! Device's Outgoing MSDU Handle values */
    STATIC uint8_t deviceTxMsduHandle = 0;
    STATIC Smsgs_configReqMsg_t configSettings;
    #if !defined(OAD_IMG_A) && !defined(POWER_MEAS)
     Temp Sensor field - valid only if Smsgs_dataFields_tempSensor
     is set in frameControl.
    STATIC Smsgs_tempSensorField_t tempSensor =
        { 0 };
     Light Sensor field - valid only if Smsgs_dataFields_lightSensor
    STATIC Smsgs_lightSensorField_t lightSensor =
        { 0 };
     Humidity Sensor field - valid only if Smsgs_dataFields_humiditySensor
    STATIC Smsgs_humiditySensorField_t humiditySensor =
        { 0 };
    #ifdef LPSTK
     Hall Effect Sensor field - valid only if Smsgs_dataFields_hallEffectSensor
    STATIC Smsgs_hallEffectSensorField_t hallEffectSensor =
        { 0 };
     Accelerometer Sensor field - valid only if Smsgs_dataFields_accelSensor
    STATIC Smsgs_accelSensorField_t accelerometerSensor =
        { 0 };
    #endif /* LPSTK */
    #ifdef DMM_CENTRAL
     BLE Sensor field - valid only if Smsgs_dataFields_bleSensor
    STATIC Smsgs_bleSensorField_t bleSensor =
        { 0 };
    #endif
    #endif /* !defined(OAD_IMG_A) && !defined(POWER_MEAS) */
    STATIC Llc_netInfo_t parentInfo = {0};
    STATIC uint16_t lastRcvdBroadcastMsgId = 0;
    /* variable to store the current setting of auto Request Pib attribute
     * before it gets modified by SM module, in beacon mode
    static bool currAutoReq = 0;
    SMMsgs_authMethod_t smAuthMethod = SM_SENSOR_DEFAULT_AUTH_METHOD;
    #ifdef DMM_OAD
    ApiMac_deviceDescriptor_t cacheddevInfo = {0};
    Llc_netInfo_t cachedparentInfo = {0};
    #endif
     Local function prototypes
    static void initializeClocks(void);
    static void commStatusIndCB(ApiMac_mlmeCommStatusInd_t *pCommStatusInd);
    static void dataCnfCB(ApiMac_mcpsDataCnf_t *pDataCnf);
    static void dataIndCB(ApiMac_mcpsDataInd_t *pDataInd);
    static uint8_t getMsduHandle(Smsgs_cmdIds_t msgType);
    static void processSensorMsgEvt(void);
    static bool sendSensorMessage(ApiMac_sAddr_t *pDstAddr,
                                  Smsgs_sensorMsg_t *pMsg);
    static void readSensors(void);
    #if SENSOR_TEST_RAMP_DATA_SIZE && (CERTIFICATION_TEST_MODE || defined(POWER_MEAS))
    static void processSensorRampMsgEvt(void);
    #endif
    #ifdef LPSTK
    static void lpstkAccelerometerTiltCb(void);
    #endif /* LPSTK */
    static void processConfigRequest(ApiMac_mcpsDataInd_t *pDataInd);
    static void processBroadcastCtrlMsg(ApiMac_mcpsDataInd_t *pDataInd);
    static bool sendConfigRsp(ApiMac_sAddr_t *pDstAddr, Smsgs_configRspMsg_t *pMsg);
    static uint16_t validateFrameControl(uint16_t frameControl);
    #if defined(DEVICE_TYPE_MSG)
    static void Sensor_sendDeviceTypeResponse(void);
    static void jdllcJoinedCb(ApiMac_deviceDescriptor_t *pDevInfo,
                              Llc_netInfo_t  *pStartedInfo);
    static void jdllcDisassocIndCb(ApiMac_sAddrExt_t *extAddress,
                                   ApiMac_disassocateReason_t reason);
    static void jdllcDisassocCnfCb(ApiMac_sAddrExt_t *extAddress,
                                   ApiMac_status_t status);
    static void jdllcStateChangeCb(Jdllc_states_t state);
    /* Security Manager callback functions */
    static void smFailCMProcessCb(ApiMac_deviceDescriptor_t *devInfo,
                                  bool rxOnIdle, bool keyRefreshment,
                                  SMMsgs_errorCode_t errorCode);
    static void smSuccessCMProcessCb(ApiMac_deviceDescriptor_t *devInfo,
                                     bool keyRefreshment);
    #if (USE_DMM)
    static void macSyncLossCb(ApiMac_mlmeSyncLossInd_t *pSyncLossInd);
    #if !(DMM_CENTRAL)
    // Remote display callback functions
    static void setRDAttrCb(RemoteDisplayAttr_t remoteDisplayAttr, void *const value, uint8_t len);
    static void getRDAttrCb(RemoteDisplayAttr_t remoteDisplayAttr, void *value, uint8_t len);
    // Provisioning callback functions
    static void provisionConnectCb(void);
    static void provisionDisconnectCb(void);
    static void setProvisioningCb(ProvisionAttr_t provisioningAttr, void *const value, uint8_t len);
    static void getProvisioningCb(ProvisionAttr_t provisioningAttr, void *value, uint8_t len);
    // Helper functions
    void swapBytes(uint8_t *arr, uint8_t len);
    #endif /* !DMM_CENTRAL */
    #ifdef DMM_OAD
    static void Sensor_dmmPausePolicyCb(uint16_t pause);
    #endif /* DMM_OAD */
     Callback tables
    /*! API MAC Callback table */
    STATIC ApiMac_callbacks_t Sensor_macCallbacks =
          /*! Associate Indicated callback */
          NULL,
          /*! Associate Confirmation callback */
          NULL,
          /*! Disassociate Indication callback */
          NULL,
          /*! Disassociate Confirmation callback */
          NULL,
          /*! Beacon Notify Indication callback */
          NULL,
          /*! Orphan Indication callback */
          NULL,
          /*! Scan Confirmation callback */
          NULL,
          /*! Start Confirmation callback */
          NULL,
    #if (USE_DMM)
          /*! Sync Loss Indication callback */
          macSyncLossCb,
    #else
          NULL,
          /*! Poll Confirm callback */
          NULL,
          /*! Comm Status Indication callback */
          commStatusIndCB,
          /*! Poll Indication Callback */
          NULL,
          /*! Data Confirmation callback */
          dataCnfCB,
          /*! Data Indication callback */
          dataIndCB,
          /*! Purge Confirm callback */
          NULL,
          /*! WiSUN Async Indication callback */
          NULL,
          /*! WiSUN Async Confirmation callback */
          NULL,
          /*! Unprocessed message callback */
          NULL
    STATIC Jdllc_callbacks_t jdllcCallbacks =
          /*! Network Joined Indication callback */
          jdllcJoinedCb,
          /* Disassociation Indication callback */
          jdllcDisassocIndCb,
          /* Disassociation Confirm callback */
          jdllcDisassocCnfCb,
          /*! State Changed indication callback */
          jdllcStateChangeCb
    STATIC SM_callbacks_t SMCallbacks =
          /*! Request passkey callback */
          Ssf_SmPasskeyEntry,
          /*! Security authentication failed callback */
          smFailCMProcessCb,
          /* Security authentication successful callback */
    #if (USE_DMM) && !(DMM_CENTRAL)
    RemoteDisplay_clientProvisioningtCbs_t provisioning_sensorCbs =
        setProvisioningCb,
        getProvisioningCb,
        provisionConnectCb,
    RemoteDisplayCbs_t remoteDisplay_sensorCbs =
        setRDAttrCb,
        getRDAttrCb
    #endif /* USE_DMM && !DMM_CENTRAL */
    #ifdef DMM_OAD
     * DMM Policy Callbacks
    static DMMPolicy_AppCbs_t dmmPolicyAppCBs =
    #endif
     Public Functions
    #ifdef USE_DMM
     Initialize MAC level security for this application.
     Public function defined in sensor.h
    void Sensor_securityInit(uint32_t frameCounter)
        Ssf_getFrameCounter(NULL, &frameCounter);
    #ifdef FEATURE_MAC_SECURITY
        /* Initialize the MAC Security */
        Jdllc_securityInit(frameCounter, NULL);
    #endif /* FEATURE_MAC_SECURITY */
     Initialize this application.
    void Sensor_init(uint8_t macTaskId)
    #else
    void Sensor_init(void)
    #endif
        ApiMac_deviceDescriptor_t devInfo;
        Llc_netInfo_t parentInfo;
    #ifndef USE_DMM
        uint32_t frameCounter = 0;
        /* Initialize the sensor's structures */
        memset(&configSettings, 0, sizeof(Smsgs_configReqMsg_t));
    #if defined(TEMP_SENSOR)
        configSettings.frameControl |= Smsgs_dataFields_tempSensor;
    #endif
    #if defined(LIGHT_SENSOR)
        configSettings.frameControl |= Smsgs_dataFields_lightSensor;
    #endif
    #if defined(HUMIDITY_SENSOR)
        configSettings.frameControl |= Smsgs_dataFields_humiditySensor;
    #endif
    #ifdef LPSTK
        configSettings.frameControl |= Smsgs_dataFields_humiditySensor   |
                                       Smsgs_dataFields_lightSensor      |
                                       Smsgs_dataFields_hallEffectSensor |
                                       Smsgs_dataFields_accelSensor;
    #endif /* LPSTK */
        configSettings.frameControl |= Smsgs_dataFields_msgStats;
        configSettings.frameControl |= Smsgs_dataFields_configSettings;
    #ifdef DMM_CENTRAL
        configSettings.frameControl |= Smsgs_dataFields_bleSensor;
    #endif
        if(!CERTIFICATION_TEST_MODE)
            configSettings.reportingInterval = CONFIG_REPORTING_INTERVAL;
        else
            /* start back to back data transmission at the earliest */
            configSettings.reportingInterval = 100;
        configSettings.pollingInterval = CONFIG_POLLING_INTERVAL;
        /* Initialize the MAC */
        sem = ApiMac_init(macTaskId, CONFIG_FH_ENABLE);
    #else
        sem = ApiMac_init(CONFIG_FH_ENABLE);
    #endif
        /* Initialize the Joining Device Logical Link Controller */
        Jdllc_init(&Sensor_macCallbacks, &jdllcCallbacks);
        /* Register the MAC Callbacks */
        ApiMac_registerCallbacks(&Sensor_macCallbacks);
        /* Initialize the platform specific functions */
        Ssf_init(sem);
    #ifdef LPSTK
    #ifdef BLE_START
         * NOTE!!
         * OAD_open() must be called before the LPSTK sensors are initialized because there
         * is no arbitration between the Flash and Accelerometer SPI writes.
         * OAD_open() is called in remote_display.c, see RemoteDisplay_init().
         * Here we refer to BLE OAD, not 15.4 OAD.
        /* Wait for BLE application to finish initializing the BLE OAD Module */
        Ssf_PendAppSem();
    #endif /* BLE_START */
        /* This initializes all LPSTK's sensors, LEDs, and Buttons */
        Lpstk_init(sem, lpstkAccelerometerTiltCb);
        /* Set up a periodic read for sensors specified by the sensor mask */
        Lpstk_initSensorReadTimer((Lpstk_SensorMask)(LPSTK_HUMIDITY|
                                                    LPSTK_TEMPERATURE|
                                                    LPSTK_LIGHT|
                                                    //LPSTK_HALL_EFFECT
                                                    LPSTK_ACCELEROMETER),
                                                    2000);
    #endif /* LPSTK */
        /* Intialize the security manager and register callbacks */
        SM_registerCallback(&SMCallbacks);
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_phyCurrentDescriptorId,
                               (uint8_t)CONFIG_PHY_ID);
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_channelPage,
                               (uint8_t)CONFIG_CHANNEL_PAGE);
    #ifndef USE_DMM
    #endif /* !USE_DMM */
        /* Set the transmit power */
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_phyTransmitPowerSigned,
                               (uint8_t)CONFIG_TRANSMIT_POWER);
        /* Set Min BE */
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_backoffExponent,
                                  (uint8_t)CONFIG_MIN_BE);
        /* Set Max BE */
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxBackoffExponent,
                                  (uint8_t)CONFIG_MAX_BE);
        /* Set MAC MAX CSMA Backoffs */
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxCsmaBackoffs,
                                  (uint8_t)CONFIG_MAC_MAX_CSMA_BACKOFFS);
        /* Set MAC MAX Frame Retries */
        ApiMac_mlmeSetReqUint8(ApiMac_attribute_maxFrameRetries,
                                  (uint8_t)CONFIG_MAX_RETRIES);
    #ifdef FCS_TYPE16
        /* Set the fcs type */
        ApiMac_mlmeSetReqBool(ApiMac_attribute_fcsType,
                               (bool)1);
    #endif
        ApiMac_mlmeSetReqBool(ApiMac_attribute_dutyCycleEnabled, true);
        ApiMac_mlmeSetReqUint32(ApiMac_attribute_dutyCycleRegulated,
                                DUTY_CYCLE_MEAS_PERIOD*MAC_DUTY_CYCLE_THRESHOLD/100);
        /* Critical and limited duty cycle modes unused, set to max
         * value to avoid entering state */
        ApiMac_mlmeSetReqUint32(ApiMac_attribute_dutyCycleCritical,
                                UINT32_MAX);
        ApiMac_mlmeSetReqUint32(ApiMac_attribute_dutyCycleLimited,
                                UINT32_MAX);
    #endif
        ApiMac_mlmeSetReqBool(ApiMac_attribute_customMinTxOffEnabled, true);
        ApiMac_mlmeSetReqUint32(ApiMac_attribute_minTxOffTime,
                                (uint32_t)MAC_CONFIG_MIN_TX_OFF);
    #endif
        /* Initialize the app clocks */
        initializeClocks();
    #if defined(BLE_START) && defined(USE_DMM) && !(DMM_CENTRAL)
        RemoteDisplay_registerRDCbs(remoteDisplay_sensorCbs);
        RemoteDisplay_registerClientProvCbs(provisioning_sensorCbs);
    #endif /* BLE_START && USE_DMM */
        if(Ssf_getNetworkInfo(&devInfo, &parentInfo) == true)
    #if USE_DMM
            /* Update policy */
            DMMPolicy_updateApplicationState(DMMPolicy_StackRole_154Sensor, DMMPOLICY_154_PROVISIONING);
    #endif
            /* Update Channel Mask to show the previous network channel */
            if (!CONFIG_FH_ENABLE)
                uint8_t channelMask[APIMAC_154G_CHANNEL_BITMAP_SIZ] = {0};
                uint8_t idx = parentInfo.channel / 8;
                uint8_t shift = (parentInfo.channel % 8);
                uint8_t chan = (0x01) << shift;
                channelMask[idx] = chan;
                Jdllc_setChanMask(channelMask);
            /* Start the device */
            Util_setEvent(&Sensor_events, SENSOR_START_EVT);
        else if (CONFIG_AUTO_START)
    #if USE_DMM
            /* Update policy */
    #endif
        /* Update BLE remote display with initial state, which will trigger a read
         * of the default JDLLC setting
        RemoteDisplay_updateSensorJoinState(Jdllc_states_initWaiting);
    #endif
    #ifdef DMM_OAD
        // register the app callbacks
        DMMPolicy_registerAppCbs(dmmPolicyAppCBs, DMMPolicy_StackRole_154Sensor);
    #endif
     Application task processing.
    void Sensor_process(void)
        /* Start the collector device in the network */
        if(Sensor_events & SENSOR_START_EVT)
    #ifdef USE_DMM
            /* update policy */
            Sensor_securityInit(frameCounter);
                rejoining = true;
                Ssf_configSettings_t configInfo;
                ApiMac_status_t stat;
                /* Do we have config settings? */
                if(Ssf_getConfigInfo(&configInfo) == true)
                    /* Save the config information */
                    configSettings.frameControl = configInfo.frameControl;
                    configSettings.reportingInterval = configInfo.reportingInterval;
                    configSettings.pollingInterval = configInfo.pollingInterval;
                    /* Update the polling interval in the LLC */
                    Jdllc_setPollRate(configSettings.pollingInterval);
                /* Initially, setup the parent as the collector */
                if(parentInfo.fh == true && CONFIG_RX_ON_IDLE)
                    collectorAddr.addrMode = ApiMac_addrType_extended;
                    memcpy(&collectorAddr.addr.extAddr,
                           parentInfo.devInfo.extAddress, APIMAC_SADDR_EXT_LEN);
                else
                    collectorAddr.addrMode = ApiMac_addrType_short;
                    collectorAddr.addr.shortAddr = parentInfo.devInfo.shortAddress;
                /* Put the parent in the security device list */
                stat = Jdllc_addSecDevice(parentInfo.devInfo.panID,
                                          parentInfo.devInfo.shortAddress,
                                          &parentInfo.devInfo.extAddress, 0);
                if(stat != ApiMac_status_success)
                    Ssf_displayError("Auth Error: 0x", (uint8_t)stat);
                if(!CONFIG_FH_ENABLE)
                    nvDeviceKeyInfo_t devKeyInfo;
                    if(Ssf_getDeviceKeyInfo(&devKeyInfo) == TRUE)
                        SM_recoverKeyInfo(devInfo, parentInfo, devKeyInfo);
    #ifdef USE_DMM
                        RemoteDisplay_updateSmState(SMCOMMISSIONSTATE_SUCCESS);
                Jdllc_rejoin(&devInfo, &parentInfo);
            else
                /* Reset flag when joining a new network */
                rejoining = false;
                /* Get Start Timestamp */
                joinTimeTicks = Clock_getTicks();
    #else
                joinTimeTicks = ICall_getTicks();
    #endif
                Jdllc_join();
            /* Clear the event */
            Util_clearEvent(&Sensor_events, SENSOR_START_EVT);
        /* Is it time to send the next sensor data message? */
        if(Sensor_events & SENSOR_READING_TIMEOUT_EVT)
            /* In certification test mode, back to back data shall be sent */
                /* Setup for the next message */
                Ssf_setReadingClock(configSettings.reportingInterval);
            /* if secure Commissioning feature is enabled, read
             * sensor data and send it only after the secure
             * commissioning process is done successfully.
             * else, do not read and send sensor data.
            if(SM_Current_State != SM_CM_InProgress)
            processSensorRampMsgEvt();
    #endif /* SENSOR_TEST_RAMP_DATA_SIZE */
    #if !defined(POWER_MEAS)
            /* Read sensors */
            readSensors();
            /* Process Sensor Reading Message Event */
            processSensorMsgEvt();
    #endif /* POWER_MEAS */
    #endif //OAD_IMG_A
            Util_clearEvent(&Sensor_events, SENSOR_READING_TIMEOUT_EVT);
    #if defined(OAD_IMG_A)
        if(Sensor_events & SENSOR_OAD_SEND_RESET_RSP_EVT)
            OADClient_processEvent(&Sensor_events);
    #endif //OAD_IMG_A
    #ifdef DISPLAY_PER_STATS
        /* Is it time to update the PER display? */
        if(Sensor_events & SENSOR_UPDATE_STATS_EVT)
            Ssf_displayPerStats(&Sensor_msgStats);
            Util_clearEvent(&Sensor_events, SENSOR_UPDATE_STATS_EVT);
    #endif /* DISPLAY_PER_STATS */
    #ifdef LPSTK
        /* Process Launchpad Sensortag specific events */
        Lpstk_processEvents();
    #endif /* LPSTK */
        /* Is it provision start event? */
        if(Sensor_events & SENSOR_PROV_EVT)
            /* update policy */
            Util_clearEvent(&Sensor_events, SENSOR_PROV_EVT);
    #endif /* USE_DMM && !(DMM_CENTRAL) */
        /* Is it disassociate event? */
        if(Sensor_events & SENSOR_DISASSOC_EVT)
            Jdllc_sendDisassociationRequest();
    #ifdef USE_DMM
            RemoteDisplay_updateSmState(SMCOMMISSIONSTATE_IDLE);
            Util_clearEvent(&Sensor_events, SENSOR_DISASSOC_EVT);
    #ifdef DMM_OAD
        if(Sensor_events & SENSOR_PAUSE_EVT)
            /* Turn off timers to temporarily stop transmissions */
            Ssf_setPollClock(0);
            Ssf_setReadingClock(0);
            if(CONFIG_FH_ENABLE)
                Ssf_setTrickleClock(0, ApiMac_wisunAsyncFrame_advertisementSolicit);
                Ssf_setTrickleClock(0, ApiMac_wisunAsyncFrame_configSolicit);
            Util_clearEvent(&Sensor_events, SENSOR_PAUSE_EVT);
        if(Sensor_events & SENSOR_RESUME_EVT)
            /* Call SENSOR_START_EVT to re-associate with collector if BLE-OAD fails */
            /* Wake up the application thread when it waits for clock event */
            Ssf_PostAppSem();
            Util_clearEvent(&Sensor_events, SENSOR_RESUME_EVT);
        /* Process LLC Events */
        Jdllc_process();
        /* Allow the Specific functions to process */
        Ssf_processEvents();
        /* Allow the security manager specific functions to process */
        SM_process();
         Don't process ApiMac messages until all of the sensor events
         are processed.
        /*only if there are no sensor events and security manager events to handle*/
        if((Sensor_events == 0) && (SM_events == 0))
    #else
        if(Sensor_events == 0)
            /* Wait for response message or events */
            ApiMac_processIncoming();
    #ifdef TX_POWER_TEST
    uint32_t txPowerLimitTest = 0;
    uint8_t txTestPower1 = 0;
    uint8_t txTestPower2 = 5;
    #endif
     * @brief   Send MAC data request
     * @param   type - message type
     * @param   pDstAddr - destination address
     * @param   rxOnIdle - true if not a sleepy device
     * @param   len - length of payload
     * @param   pData - pointer to the buffer
     * @return  true if sent, false if not
    bool Sensor_sendMsg(Smsgs_cmdIds_t type, ApiMac_sAddr_t *pDstAddr,
                        bool rxOnIdle, uint16_t len, uint8_t *pData)
        bool ret = false;
        /* information about the network */
        ApiMac_mcpsDataReq_t dataReq;
        /* Timestamp to compute end to end delay */
        startSensorMsgTimeStamp = Clock_getTicks();
    #else
        startSensorMsgTimeStamp = ICall_getTicks();
    #endif
        /* Construct the data request field */
        memset(&dataReq, 0, sizeof(ApiMac_mcpsDataReq_t));
        memcpy(&dataReq.dstAddr, pDstAddr, sizeof(ApiMac_sAddr_t));
        /* set the correct address mode. */
        if(pDstAddr->addrMode == ApiMac_addrType_extended)
            dataReq.srcAddrMode = ApiMac_addrType_extended;
        else
            dataReq.srcAddrMode = ApiMac_addrType_short;
        if(rejoining == true)
            /* get the new panID from the mac */
            ApiMac_mlmeGetReqUint16(ApiMac_attribute_panId,
                                    &(parentInfo.devInfo.panID));
        dataReq.dstPanId = parentInfo.devInfo.panID;
        dataReq.msduHandle = getMsduHandle(type);
        dataReq.txOptions.ack = true;
        if(CERTIFICATION_TEST_MODE)
            dataReq.txOptions.ack = false;
        if(rxOnIdle == false)
            dataReq.txOptions.indirect = true;
        dataReq.msdu.len = len;
        dataReq.msdu.p = pData;
            SM_getSrcDeviceSecurityInfo(ApiMac_extAddr, SM_Sensor_SAddress, &dataReq.sec);
    #else
        Jdllc_securityFill(&dataReq.sec);
        if(type == Smsgs_cmdIds_sensorData || type == Smsgs_cmdIds_rampdata)
            Sensor_msgStats.msgsAttempted++;
        else if(type == Smsgs_cmdIds_trackingRsp)
            Sensor_msgStats.trackingResponseAttempts++;
        else if(type == Smsgs_cmdIds_configRsp)
            Sensor_msgStats.configResponseAttempts++;
        if (txPowerLimitTest % 2 == 0)
            dataReq.power = txTestPower1;
        else
            dataReq.power = txTestPower2;
    #endif
        /* Send the message */
        if(ApiMac_mcpsDataReq(&dataReq) == ApiMac_status_success)
            ret = true;
        else
            /* handle transaction overflow by retrying */
        txPowerLimitTest++;
    #endif
        return (ret);
     Send LED Identify Request to collector
    void Sensor_sendIdentifyLedRequest(void)
        uint8_t cmdBytes[SMSGS_INDENTIFY_LED_REQUEST_MSG_LEN];
        /* send the response message directly */
        cmdBytes[0] = (uint8_t) Smsgs_cmdIds_IdentifyLedReq;
        cmdBytes[1] = (uint8_t) IDENTIFY_LED_TIME;
        Sensor_sendMsg(Smsgs_cmdIds_IdentifyLedReq,
                &collectorAddr, true,
                SMSGS_INDENTIFY_LED_REQUEST_MSG_LEN,
                cmdBytes);
     * @brief Sets the Security Authentication Mode
     *  Public function defined in sensor.h
    extern void Sensor_setSmAuthMethod(SMMsgs_authMethod_t authMethod)
        smAuthMethod = authMethod;
     * @brief Gets the Security Authentication Mode
    extern SMMsgs_authMethod_t Sensor_getSmAuthMethod(void)
        return smAuthMethod;
     Local Functions
     * @brief       Initialize the clocks.
    #ifndef DMM_CENTRAL
        /* Initialize the reading clock */
        Ssf_initializeReadingClock();
    #if (USE_DMM)
        Ssf_initializeProvisioningClock();
     * @brief      Process the MAC Comm Status Indication Callback
     * @param      pCommStatusInd - Comm Status indication
        uint32_t stat;
        /* Frame received with security error */
        if (pCommStatusInd->reason == ApiMac_commStatusReason_rxSecure)
            ApiMac_mlmeGetReqUint32(ApiMac_attribute_diagRxSecureFail, &stat);
            Sensor_msgStats.rxDecryptFailures = (uint16_t)stat;
    #ifndef MAC_OVERRIDE_TX_DELAY
            /* Enabling the minimum custom TX off-time feature in SysConfig
             * will overwrite ApiMac_attribute_diagTxSecureFail MAC PIB. See
             * api_mac.c/h
            ApiMac_mlmeGetReqUint32(ApiMac_attribute_diagTxSecureFail, &stat);
            Sensor_msgStats.txEncryptFailures = (uint16_t)stat;
    #endif
            Ssf_displayError("Security Error: ", pCommStatusInd->status);
     * @brief      MAC Data Confirm callback.
     * @param      pDataCnf - pointer to the data confirm information
        /* Record statistics */
        if(pDataCnf->status == ApiMac_status_channelAccessFailure)
            Sensor_msgStats.channelAccessFailures++;
        else if(pDataCnf->status == ApiMac_status_noAck)
            Sensor_msgStats.macAckFailures++;
            Util_setEvent(&Sensor_events, SENSOR_UPDATE_STATS_EVT);
        else if(pDataCnf->status != ApiMac_status_success)
            Sensor_msgStats.otherDataRequestFailures++;
            Ssf_displayError("dataCnf: ", pDataCnf->status);
        else if(pDataCnf->status == ApiMac_status_success)
            Ssf_updateFrameCounter(NULL, pDataCnf->frameCntr);
        /* Strictly ensure that the message did not come from the app */
        if(!(pDataCnf->msduHandle & APP_MARKER_MSDU_HANDLE))
            if ((SM_CM_InProgress == SM_Current_State) && (true == useSendPktStatus))
                /* Make sure the message came from the SM module */
                if (pDataCnf->msduHandle & SM_FAIL_MSDU_HANDLE)
                        /* Set an event that failure status from previous packet sent is seen */
                        Util_setEvent(&SM_events, SM_SEND_PKT_FB_EVT);
                    else
                        /* Switch to fail state once fail packet is received */
                        Util_setEvent(&SM_events, SM_SENT_CM_FAIL_EVT);
                else if(pDataCnf->msduHandle & SM_DATA_MSDU_HANDLE)
        /* Make sure the message came from the app */
        if(pDataCnf->msduHandle & APP_MARKER_MSDU_HANDLE)
            /* What message type was the original request? */
            if((pDataCnf->msduHandle & APP_MASK_MSDU_HANDLE)
               == APP_SENSOR_MSDU_HANDLE)
                    Sensor_msgStats.msgsSent++;
                    if (Sensor_msgStats.msgsSent == 0)
                        /* the count is wrapped around, set to 1 to avoid divided by zero */
                        Sensor_msgStats.msgsSent = 1;
                    /* Calculate end to end delay */
                    if(Clock_getTicks() < startSensorMsgTimeStamp)
                        endToEndDelay = Clock_getTicks() +
                                        (0xFFFFFFFF-startSensorMsgTimeStamp);
                    else
                        endToEndDelay = Clock_getTicks() - startSensorMsgTimeStamp;
    #else
                    if(ICall_getTicks() < startSensorMsgTimeStamp)
                        endToEndDelay = ICall_getTicks() +
                    else
                        endToEndDelay = ICall_getTicks() - startSensorMsgTimeStamp;
    #endif
                    endToEndDelay = endToEndDelay/TICKPERIOD_MS_US;
                    if ( (totalE2EDelaySum + endToEndDelay ) < totalE2EDelaySum)
                        /* totalE2EDelaySum is wrapped around,reset the sent count 1 */
                        totalE2EDelaySum = endToEndDelay;
                    else
                        totalE2EDelaySum += endToEndDelay;
                    Sensor_msgStats.worstCaseE2EDelay =
                       (Sensor_msgStats.worstCaseE2EDelay > endToEndDelay) ?
                        Sensor_msgStats.worstCaseE2EDelay:endToEndDelay;
                    Sensor_msgStats.avgE2EDelay=totalE2EDelaySum/Sensor_msgStats.msgsSent;
                    Ssf_setReadingClock(CERT_MODE_INTER_PKT_INTERVAL);
    #endif
               == APP_TRACKRSP_MSDU_HANDLE)
                    Sensor_msgStats.trackingResponseSent++;
               == APP_CONFIGRSP_MSDU_HANDLE)
                    Sensor_msgStats.configResponseSent++;
     * @brief      MAC Data Indication callback.
     * @param      pDataInd - pointer to the data indication information
        uint8_t cmdBytes[SMSGS_TOGGLE_LED_RESPONSE_MSG_LEN];
        if((pDataInd != NULL) && (pDataInd->msdu.p != NULL)
           && (pDataInd->msdu.len > 0))
            Smsgs_cmdIds_t cmdId = (Smsgs_cmdIds_t)*(pDataInd->msdu.p);
                if(Jdllc_securityCheck(&(pDataInd->sec)) == false)
                    /* reject the message */
                    return;
            switch(cmdId)
                case Smsgs_cmdIds_configReq:
                    processConfigRequest(pDataInd);
                    Sensor_msgStats.configRequests++;
                    break;
                case Smsgs_cmdIds_trackingReq:
                    /* Make sure the message is the correct size */
                    if(pDataInd->msdu.len == SMSGS_TRACKING_REQUEST_MSG_LENGTH)
                        /* only send data if sensor is in the network */
                        if ((Jdllc_getProvState() == Jdllc_states_joined) ||
                                (Jdllc_getProvState() == Jdllc_states_rejoined))
                            /* Update stats */
                            Sensor_msgStats.trackingRequests++;
                            /* Indicate tracking message received */
                            Ssf_trackingUpdate(&pDataInd->srcAddr);
                            cmdBytes[0] = (uint8_t) Smsgs_cmdIds_trackingRsp;
                            Sensor_sendMsg(Smsgs_cmdIds_trackingRsp,
                                               &pDataInd->srcAddr, true,
                                               1, cmdBytes);
                    break;
                case Smsgs_cmdIds_toggleLedReq:
                    if(pDataInd->msdu.len == SMSGS_TOGGLE_LED_REQUEST_MSG_LEN)
                            cmdBytes[0] = (uint8_t) Smsgs_cmdIds_toggleLedRsp;
                            cmdBytes[1] = Ssf_toggleLED();
                            Sensor_sendMsg(Smsgs_cmdIds_toggleLedRsp,
                                SMSGS_TOGGLE_LED_RESPONSE_MSG_LEN,
                                cmdBytes);
                    break;
                case Smgs_cmdIds_broadcastCtrlMsg:
                    if(parentFound)
                        /* Node has successfully associated with the network */
                        processBroadcastCtrlMsg(pDataInd);
                    break;
    #ifdef POWER_MEAS
                case Smsgs_cmdIds_rampdata:
                    Sensor_pwrMeasStats.rampDataRcvd++;
                    break;
    #endif
                case Smsgs_cmdIds_oad:
                    //Index past the Smsgs_cmdId
                    OADProtocol_ParseIncoming((void*) &(pDataInd->srcAddr), pDataInd->msdu.p + 1);
                    break;
    #endif //FEATURE_NATIVE_OAD
                case Smgs_cmdIds_CommissionStart:
                        ApiMac_sec_t devSec;
                        /* Obtain MAC level security information. Use network key for SM */
                        Jdllc_securityFill(&devSec);
                        uint8_t *pBuf = pDataInd->msdu.p;
                        pBuf += sizeof(Smsgs_cmdIds_t);
                        SMMsgs_cmdIds_t CMMsgId = (SMMsgs_cmdIds_t)Util_buildUint16(pBuf[0], pBuf[1]);
                        /* read the current value */
                        ApiMac_mlmeGetReqBool(ApiMac_attribute_autoRequest, &currAutoReq);
                        /* beacon-mode of operation and autoRequest is set to true and sleepy device  */
                        if((CONFIG_MAC_BEACON_ORDER != 15) && (currAutoReq == true) && (!CONFIG_RX_ON_IDLE))
                            /* set autoRequest to false and enable explicit polling */
                            ApiMac_mlmeSetReqBool(ApiMac_attribute_autoRequest, false);
                            Util_setEvent(&Jdllc_events, JDLLC_POLL_EVT);
                        if (CMMsgId == SMMsgs_cmdIds_keyRefreshRequest)
                                /* Kick off key refreshment process if SM state machine is not being run */
                                SM_startKeyRefreshProcess(&parentInfo.devInfo, &devSec,
        parentInfo.fh, true);
                        else if(CMMsgId == SMMsgs_cmdIds_processRequest)
    #ifdef USE_DMM
                            /* Kick off commissioning process to obtain security information */
                            RemoteDisplay_updateSmState(SMCOMMISSIONSTATE_STARTING);
                            SM_startCMProcess(&parentInfo.devInfo, &devSec, parentInfo.fh,
                                              true, SM_type_device, smAuthMethod);
                    break;
                case Smgs_cmdIds_CommissionMsg:
                        /* Process Security manager commissioning data */
                        SM_processCommData(pDataInd);
                    break;
                case Smsgs_cmdIds_DeviceTypeReq:
                    if(pDataInd->msdu.len == SMSGS_DEVICE_TYPE_REQUEST_MSG_LEN)
                        /* Only send data if sensor is in the network */
                            Sensor_sendDeviceTypeResponse();
                    break;
                default:
                    /* Should not receive other messages */
                    break;
     * @brief      Get the next MSDU Handle
     *             <BR>
     *             The MSDU handle has 3 parts:<BR>
     *             - The MSBit(7), when set means the the application sent the
     *               message
     *             - Bit 6, when set means that the app message is a config request
     *             - Bits 0-5, used as a message counter that rolls over.
     * @param      msgType - message command id needed
     * @return     msdu Handle
        uint8_t msduHandle = deviceTxMsduHandle;
        /* Increment for the next msdu handle, or roll over */
        if(deviceTxMsduHandle >= MSDU_HANDLE_MAX)
        else
            deviceTxMsduHandle++;
        /* Add the App specific bit */
        msduHandle |= APP_MARKER_MSDU_HANDLE;
        /* Add the message type bit */
        if(msgType == Smsgs_cmdIds_sensorData || msgType == Smsgs_cmdIds_rampdata)
            msduHandle |= APP_SENSOR_MSDU_HANDLE;
        else if(msgType == Smsgs_cmdIds_trackingRsp)
            msduHandle |= APP_TRACKRSP_MSDU_HANDLE;
        else if(msgType == Smsgs_cmdIds_configRsp)
            msduHandle |= APP_CONFIGRSP_MSDU_HANDLE;
        return (msduHandle);
     @brief  Build and send fixed size ramp data
        uint8_t *pMsgBuf;
        uint16_t index;
        pMsgBuf = (uint8_t *)Ssf_malloc(SENSOR_TEST_RAMP_DATA_SIZE);
        if(pMsgBuf)
            uint8_t *pBuf = pMsgBuf;
            *pBuf++ = (uint8_t)Smsgs_cmdIds_rampdata;
            for(index = 1; index < SENSOR_TEST_RAMP_DATA_SIZE; index++)
                *pBuf++ = (uint8_t) (index & 0xFF);
    #if !defined(POWER_MEAS) && !defined(USE_DMM)
            //Toggle Sensor reading LED
            Ssf_sensorReadingUpdate(NULL);
    #endif
            Sensor_sendMsg(Smsgs_cmdIds_rampdata, &collectorAddr, true,
                    SENSOR_TEST_RAMP_DATA_SIZE, pMsgBuf);
            Ssf_free(pMsgBuf);
    #endif
     @brief   Build and send sensor data message
        Smsgs_sensorMsg_t sensor;
        memset(&sensor, 0, sizeof(Smsgs_sensorMsg_t));
        ApiMac_mlmeGetReqArray(ApiMac_attribute_extendedAddress,
                               sensor.extAddress);
        /* fill in the message */
        sensor.frameControl = configSettings.frameControl;
        if(sensor.frameControl & Smsgs_dataFields_tempSensor)
            memcpy(&sensor.tempSensor, &tempSensor,
                   sizeof(Smsgs_tempSensorField_t));
        if(sensor.frameControl & Smsgs_dataFields_lightSensor)
            memcpy(&sensor.lightSensor, &lightSensor,
                   sizeof(Smsgs_lightSensorField_t));
        if(sensor.frameControl & Smsgs_dataFields_humiditySensor)
            memcpy(&sensor.humiditySensor, &humiditySensor,
                   sizeof(Smsgs_humiditySensorField_t));
        if(sensor.frameControl & Smsgs_dataFields_msgStats)
            memcpy(&sensor.msgStats, &Sensor_msgStats,
                   sizeof(Smsgs_msgStatsField_t));
        if(sensor.frameControl & Smsgs_dataFields_configSettings)
            sensor.configSettings.pollingInterval = configSettings.pollingInterval;
            sensor.configSettings.reportingInterval = configSettings
                            .reportingInterval;
    #ifdef LPSTK
        if(sensor.frameControl & Smsgs_dataFields_hallEffectSensor)
            sensor.hallEffectSensor.fluxLevel = hallEffectSensor.fluxLevel;
        if(sensor.frameControl & Smsgs_dataFields_accelSensor)
            memcpy(&sensor.accelerometerSensor, &accelerometerSensor,
                           sizeof(Smsgs_accelSensorField_t));
    #endif /* LPSTK */
    #ifdef DMM_CENTRAL
        if(sensor.frameControl & Smsgs_dataFields_bleSensor)
            memcpy(&sensor.bleSensor, &bleSensor,
                                   sizeof(Smsgs_bleSensorField_t));
    #endif
        /* inform the user interface */
        Ssf_sensorReadingUpdate(&sensor);
    #if defined(BLE_START) && (USE_DMM) && !(DMM_CENTRAL)
        /* Sync BLE application with new data */
        RemoteDisplay_updateSensorData();
    #endif /* BLE_START && USE_DMM && !(DMM_CENTRAL) */
        /* send the data to the collector */
        sendSensorMessage(&collectorAddr, &sensor);
     * @brief   Manually read the sensors
        /* Read the temp sensor values */
        tempSensor.ambienceTemp = Ssf_readTempSensor();
        tempSensor.objectTemp =  tempSensor.ambienceTemp;
    #endif
    #ifdef LPSTK
        Lpstk_Accelerometer accel;
        humiditySensor.temp = (uint16_t)Lpstk_getTemperature();
        humiditySensor.humidity = (uint16_t)Lpstk_getHumidity();
        hallEffectSensor.fluxLevel = Lpstk_getHallEffectSwitch();
        lightSensor.rawData = (uint16_t)Lpstk_getLux();
        Lpstk_getAccelerometer(&accel);
        accelerometerSensor.xAxis = accel.x;
        accelerometerSensor.yAxis = accel.y;
        accelerometerSensor.zAxis = accel.z;
        accelerometerSensor.xTiltDet = accel.xTiltDet;
        accelerometerSensor.yTiltDet = accel.yTiltDet;
    #endif /* LPSTK */
     * @brief   Build and send sensor data message
     * @param   pDstAddr - Where to send the message
     * @param   pMsg - pointer to the sensor data
     * @return  true if message was sent, false if not
    static bool sendSensorMessage(ApiMac_sAddr_t *pDstAddr, Smsgs_sensorMsg_t *pMsg)
        bool ret = false;
        uint8_t *pMsgBuf;
        uint16_t len = SMSGS_BASIC_SENSOR_LEN;
        /* Figure out the length */
        if(pMsg->frameControl & Smsgs_dataFields_tempSensor)
            len += SMSGS_SENSOR_TEMP_LEN;
        if(pMsg->frameControl & Smsgs_dataFields_lightSensor)
            len += SMSGS_SENSOR_LIGHT_LEN;
        if(pMsg->frameControl & Smsgs_dataFields_humiditySensor)
            len += SMSGS_SENSOR_HUMIDITY_LEN;
        if(pMsg->frameControl & Smsgs_dataFields_msgStats)
            //len += SMSGS_SENSOR_MSG_STATS_LEN;
            len += sizeof(Smsgs_msgStatsField_t);
        if(pMsg->frameControl & Smsgs_dataFields_configSettings)
            len += SMSGS_SENSOR_CONFIG_SETTINGS_LEN;
    #ifdef LPSTK
        if(pMsg->frameControl & Smsgs_dataFields_hallEffectSensor)
            len += sizeof(Smsgs_hallEffectSensorField_t);
        if(pMsg->frameControl & Smsgs_dataFields_accelSensor)
            len += sizeof(Smsgs_accelSensorField_t);
    #endif /* LPSTK */
    #ifdef DMM_CENTRAL
        if(pMsg-> frameControl & Smsgs_dataFields_bleSensor)
            len += SMSGS_SENSOR_BLE_LEN;
            if(pMsg->bleSensor.dataLength > MAX_BLE_DATA_LEN)
                pMsg->bleSensor.dataLength = MAX_BLE_DATA_LEN;
            len += pMsg->bleSensor.dataLength;
    #endif
        pMsgBuf = (uint8_t *)Ssf_malloc(len);
        if(pMsgBuf)
            *pBuf++ = (uint8_t)Smsgs_cmdIds_sensorData;
            memcpy(pBuf, pMsg->extAddress, SMGS_SENSOR_EXTADDR_LEN);
            pBuf += SMGS_SENSOR_EXTADDR_LEN;
            pBuf  = Util_bufferUint16(pBuf,pMsg->frameControl);
            /* Buffer data in order of frameControl mask, starting with LSB */
                pBuf = Util_bufferUint16(pBuf, pMsg->tempSensor.ambienceTemp);
                pBuf = Util_bufferUint16(pBuf, pMsg->tempSensor.objectTemp);
                pBuf = Util_bufferUint16(pBuf, pMsg->lightSensor.rawData);
                pBuf = Util_bufferUint16(pBuf, pMsg->humiditySensor.temp);
                pBuf = Util_bufferUint16(pBuf, pMsg->humiditySensor.humidity);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinAttempts);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinFails);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.msgsAttempted);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.msgsSent);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.trackingRequests);
                                         pMsg->msgStats.trackingResponseAttempts);
                                         pMsg->msgStats.trackingResponseSent);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.configRequests);
                                         pMsg->msgStats.configResponseAttempts);
                                         pMsg->msgStats.configResponseSent);
                                         pMsg->msgStats.channelAccessFailures);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.macAckFailures);
                                         pMsg->msgStats.otherDataRequestFailures);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.syncLossIndications);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.rxDecryptFailures);
                pBuf = Util_bufferUint16(pBuf,  pMsg->msgStats.txEncryptFailures);
                pBuf = Util_bufferUint16(pBuf, Ssf_resetCount);
                pBuf = Util_bufferUint16(pBuf,  Ssf_resetReseason);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.joinTime);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.interimDelay);
                pBuf = Util_bufferUint16(pBuf, pMsg->msgStats.numBroadcastMsgRcvd);
                pBuf = Util_bufferUint16(pBuf,  pMsg->msgStats.numBroadcastMsglost);
                pBuf = Util_bufferUint16(pBuf,  pMsg->msgStats.avgE2EDelay);
                pBuf = Util_bufferUint16(pBuf,  pMsg->msgStats.worstCaseE2EDelay);
                pBuf = Util_bufferUint32(pBuf,
                                         pMsg->configSettings.reportingInterval);
                                         pMsg->configSettings.pollingInterval);
    #ifdef LPSTK
                *pBuf++ = (uint8_t)pMsg->hallEffectSensor.fluxLevel;
                                         pMsg->accelerometerSensor.xAxis);
                                         pMsg->accelerometerSensor.yAxis);
                                         pMsg->accelerometerSensor.zAxis);
                *pBuf++ = pMsg->accelerometerSensor.xTiltDet;
                *pBuf++ = pMsg->accelerometerSensor.yTiltDet;
    #endif /* LPSTK */
    #ifdef DMM_CENTRAL
            if(pMsg->frameControl & Smsgs_dataFields_bleSensor)
                uint8_t i;
                for(i= 0; i < B_ADDR_LEN; i++)
                    *pBuf++ = pMsg->bleSensor.bleAddr[i];
                                         pMsg->bleSensor.manFacID);
                                         pMsg->bleSensor.uuid);
                *pBuf++ = pMsg->bleSensor.dataLength;
                i = pMsg->bleSensor.dataLength;
                while(i != 0)
                    i--;
                    *pBuf++ = pMsg->bleSensor.data[i];
    #endif
            ret = Sensor_sendMsg(Smsgs_cmdIds_sensorData, pDstAddr, true, len, pMsgBuf);
            GPIO_write(CONFIG_GPIO_NEW_LED, 1);
            Ssf_free(pMsgBuf);
        return (ret);
     * @brief      Process the Config Request message.
        Smsgs_statusValues_t stat = Smsgs_statusValues_invalid;
        Smsgs_configRspMsg_t configRsp;
        memset(&configRsp, 0, sizeof(Smsgs_configRspMsg_t));
        if(pDataInd->msdu.len == SMSGS_CONFIG_REQUEST_MSG_LENGTH)
            uint16_t frameControl;
            uint32_t reportingInterval;
            uint32_t pollingInterval;
            /* Parse the message */
            configSettings.cmdId = (Smsgs_cmdIds_t)*pBuf++;
            frameControl = Util_parseUint16(pBuf);
            pBuf += 2;
            reportingInterval = Util_parseUint32(pBuf);
            pBuf += 4;
            pollingInterval = Util_parseUint32(pBuf);
            stat = Smsgs_statusValues_success;
            collectorAddr.addrMode = pDataInd->srcAddr.addrMode;
            if(collectorAddr.addrMode == ApiMac_addrType_short)
                collectorAddr.addr.shortAddr = pDataInd->srcAddr.addr.shortAddr;
            else
                memcpy(collectorAddr.addr.extAddr, pDataInd->srcAddr.addr.extAddr,
                       (APIMAC_SADDR_EXT_LEN));
            configSettings.frameControl = validateFrameControl(frameControl);
            if(configSettings.frameControl != frameControl)
                stat = Smsgs_statusValues_partialSuccess;
            configRsp.frameControl = configSettings.frameControl;
            if((reportingInterval < MIN_REPORTING_INTERVAL)
               || (reportingInterval > MAX_REPORTING_INTERVAL))
            else
    #ifndef POWER_MEAS
                configSettings.reportingInterval = reportingInterval;
    #endif
                    uint32_t randomNum;
                    randomNum = ((ApiMac_randomByte() << 16) +
                                 (ApiMac_randomByte() << 8) + ApiMac_randomByte());
                    randomNum = (randomNum % reportingInterval) +
                            SENSOR_MIN_POLL_TIME;
                    Ssf_setReadingClock(randomNum);
    #ifdef LPSTK
                    Lpstk_setSensorReadTimer((Lpstk_SensorMask)(LPSTK_HUMIDITY|
        LPSTK_TEMPERATURE|
        LPSTK_LIGHT|
        LPSTK_HALL_EFFECT|
        reportingInterval);
    #endif /* LPSTK */
            configRsp.reportingInterval = configSettings.reportingInterval;
            if((pollingInterval < MIN_POLLING_INTERVAL)
               || (pollingInterval > MAX_POLLING_INTERVAL))
            else
                configSettings.pollingInterval = pollingInterval;
            configRsp.pollingInterval = configSettings.pollingInterval;
        /* Send the response message */
        configRsp.cmdId = Smsgs_cmdIds_configRsp;
        configRsp.status = stat;
        /* Update the user */
        Ssf_configurationUpdate(&configRsp);
        /* Response the the source device */
        sendConfigRsp(&pDataInd->srcAddr, &configRsp);
     * @brief      Process the Broadcast Control Msg.
        Smsgs_broadcastcmdmsg_t broadcastCmd;
        memset(&broadcastCmd, 0, sizeof(Smsgs_broadcastcmdmsg_t));
        if(pDataInd->msdu.len == SMSGS_BROADCAST_CMD_LENGTH)
            uint16_t broadcastMsgId;
            uint8_t cmdId = (Smsgs_cmdIds_t)*pBuf++;
            broadcastMsgId = Util_parseUint16(pBuf);
            /* Process Broadcast Command Message */
            Sensor_msgStats.numBroadcastMsgRcvd++;
            if(!initBroadcastMsg)
                /* Not the first broadcast msg rcvdd after join or a rejoin*/
                if((broadcastMsgId - lastRcvdBroadcastMsgId) > 1)
                    Sensor_msgStats.numBroadcastMsglost +=
                                    ((broadcastMsgId - lastRcvdBroadcastMsgId) -1);
            lastRcvdBroadcastMsgId = broadcastMsgId;
            /*To handle the very first broadcast msg rcvdd after join or a rejoin*/
            initBroadcastMsg = false;
            /* Switch On or Off LED based on broadcast Msg Id */
            if((broadcastMsgId % 2) == 0)
                Ssf_OnLED();
            else
                Ssf_OffLED();
     * @brief   Build and send Config Response message
     * @param   pMsg - pointer to the Config Response
        uint8_t msgBuf[SMSGS_CONFIG_RESPONSE_MSG_LENGTH];
        uint8_t *pBuf = msgBuf;
        *pBuf++ = (uint8_t) Smsgs_cmdIds_configRsp;
        pBuf = Util_bufferUint16(pBuf, pMsg->status);
        pBuf = Util_bufferUint16(pBuf, pMsg->frameControl);
        pBuf = Util_bufferUint32(pBuf, pMsg->reportingInterval);
        pBuf = Util_bufferUint32(pBuf, pMsg->pollingInterval);
        return (Sensor_sendMsg(Smsgs_cmdIds_configRsp, pDstAddr, true,
                        SMSGS_CONFIG_RESPONSE_MSG_LENGTH, msgBuf));
     * @brief   Filter the frameControl with readings supported by this device.
     * @param   frameControl - suggested frameControl
     * @return  new frame control settings supported
        uint16_t newFrameControl = 0;
        if(frameControl & Smsgs_dataFields_tempSensor)
            newFrameControl |= Smsgs_dataFields_tempSensor;
    #endif
    #if defined(LIGHT_SENSOR) || defined(LPSTK)
        if(frameControl & Smsgs_dataFields_lightSensor)
            newFrameControl |= Smsgs_dataFields_lightSensor;
    #endif
    #if defined(HUMIDITY_SENSOR) || defined(LPSTK)
        if(frameControl & Smsgs_dataFields_humiditySensor)
            newFrameControl |= Smsgs_dataFields_humiditySensor;
    #ifdef LPSTK
        if(frameControl & Smsgs_dataFields_hallEffectSensor)
            newFrameControl |= Smsgs_dataFields_hallEffectSensor;
        if(frameControl & Smsgs_dataFields_accelSensor)
            newFrameControl |= Smsgs_dataFields_accelSensor;
    #endif /* LPSTK */
    #endif
        if(frameControl & Smsgs_dataFields_msgStats)
            newFrameControl |= Smsgs_dataFields_msgStats;
        if(frameControl & Smsgs_dataFields_configSettings)
            newFrameControl |= Smsgs_dataFields_configSettings;
    #ifdef DMM_CENTRAL
        if(frameControl & Smsgs_dataFields_bleSensor)
            newFrameControl |= Smsgs_dataFields_bleSensor;
    #endif
        return (newFrameControl);
        uint8_t cmdBytes[SMSGS_DEVICE_TYPE_RESPONSE_MSG_LEN];
        cmdBytes[0] = (uint8_t) Smsgs_cmdIds_DeviceTypeRsp;
        cmdBytes[1] = DeviceFamily_ID;
        cmdBytes[2] = DeviceType_ID;
        Sensor_sendMsg(Smsgs_cmdIds_DeviceTypeRsp,
                SMSGS_DEVICE_TYPE_RESPONSE_MSG_LEN, cmdBytes);
     * @brief   The device joined callback.
     * @param   pDevInfo - This device's information
     * @param   pParentInfo - This is the parent's information
                              Llc_netInfo_t *pParentInfo)
        uint32_t randomNum = 0;
        /* Copy the parent information */
        memcpy(&parentInfo, pParentInfo, sizeof(Llc_netInfo_t));
        /* Set the collector's address as the parent's address */
        if (pParentInfo->fh && CONFIG_RX_ON_IDLE)
            memcpy(collectorAddr.addr.extAddr, pParentInfo->devInfo.extAddress,
        else
            collectorAddr.addr.shortAddr = pParentInfo->devInfo.shortAddress;
        /* Start the reporting timer */
            randomNum = (randomNum % configSettings.reportingInterval) +
        else
           uint32_t randomNum;
           randomNum = (randomNum % configSettings.reportingInterval ) +
        /* Inform the user of the joined information */
        Ssf_networkUpdate(rejoining, pDevInfo, pParentInfo);
            SM_Sensor_SAddress = pDevInfo->shortAddress;
        if((rejoining == false) && (pParentInfo->fh == false))
            /* Add the parent to the security device list */
            stat = Jdllc_addSecDevice(pParentInfo->devInfo.panID,
                                      pParentInfo->devInfo.shortAddress,
                                      &pParentInfo->devInfo.extAddress, 0);
    #if (CONFIG_MAC_SUPERFRAME_ORDER != 15) && defined(MAC_NO_AUTO_REQ)
         * Set MAC Auto Request to false to enable multiple poll requests
         * per beacon interval
    #endif
        /* Calculate Join Time */
        if(Clock_getTicks() < joinTimeTicks)
            joinTimeTicks = Clock_getTicks() + (0xFFFFFFFF-joinTimeTicks);
        else
            joinTimeTicks = Clock_getTicks() - joinTimeTicks;
    #else
        if(ICall_getTicks() < joinTimeTicks)
            joinTimeTicks = ICall_getTicks() + (0xFFFFFFFF-joinTimeTicks);
        else
            joinTimeTicks = ICall_getTicks() - joinTimeTicks;
    #endif
        Sensor_msgStats.joinTime = joinTimeTicks / TICKPERIOD_MS_US;
        /* clear the stats used for PER so that we start out at a
         * zeroed state
        Sensor_msgStats.macAckFailures = 0;
        Sensor_msgStats.otherDataRequestFailures = 0;
        Sensor_msgStats.msgsSent = 0;
    #endif
     * @brief   Disassociation indication callback.
     * @param   pExtAddress - extended address
     * @param   reason - reason for disassociation
    static void jdllcDisassocIndCb(ApiMac_sAddrExt_t *pExtAddress,
        /* Stop the reporting timer */
        Ssf_clearNetworkInfo();
        ApiMac_secDeleteDevice(pExtAddress);
    #endif
        SM_removeEntryFromSeedKeyTable(&ApiMac_extAddr);
        Ssf_clearDeviceKeyInfo();
    #ifdef USE_DMM
        /* OAD abort with no auto resume */
        OADClient_abort(false);
     * @brief   Disassociation confirm callback to an application intiated
     *          disassociation request.
     * @param   status - status of disassociation
    static void jdllcDisassocCnfCb(ApiMac_sAddrExt_t *pExtAddress,
    #endif
    #ifdef USE_DMM
     * @brief   JDLLC state change callback.
     * @param   state - new state
        if( (state == Jdllc_states_joined) || (state == Jdllc_states_rejoined))
    #if (CONFIG_MAC_SUPERFRAME_ORDER == 15)
            /* resume an OAD that may have aborted */
            OADClient_resume(30000);
    #else
            OADClient_resume(60000);
    #endif
        else if(state == Jdllc_states_orphan)
    #if USE_DMM
        if(state == Jdllc_states_initRestoring)
        else if( (state == Jdllc_states_joined) || (state == Jdllc_states_rejoined))
            DMMPolicy_updateApplicationState(DMMPolicy_StackRole_154Sensor, DMMPOLICY_154_CONNECTED);
        else if( (state == Jdllc_states_initWaiting) || (state == Jdllc_states_accessDenied) )
            DMMPolicy_updateApplicationState(DMMPolicy_StackRole_154Sensor, DMMPOLICY_154_UNINIT);
        RemoteDisplay_updateSensorJoinState(state);
    #endif /* BLE_START && USE_DMM && !DMM_CENTRAL */
    #ifndef CUI_DISABLE
        Ssf_stateChangeUpdate(state);
    #ifdef OAD_IMG_A
            Util_setEvent(&Sensor_events, SENSOR_OAD_SEND_RESET_RSP_EVT);
    #endif /* OAD_IMG_A */
    #ifdef USE_DMM
     * @brief   Sync Loss callback indication beacon sync has been lost.
     * @param   pSyncLossInd - Sync Loss Indication
        /* Update policy */
        RemoteDisplay_updateSensorJoinState((Jdllc_states_t)RemoteDisplay_JOIN_STATE_SYNC_LOSS);
    #endif
    #if !(DMM_CENTRAL)
     * @brief      DMM Provisioning connect (Association) callback function
        Ssf_setProvisioningClock(true);
     * @brief      DMM Provisioning disconnect (Disassocation) callback function
        Ssf_setProvisioningClock(false);
     * @brief      Security manager failure processing function
    void smFailCMProcessCb(ApiMac_deviceDescriptor_t *devInfo, bool rxOnIdle,
                           bool keyRefreshment, SMMsgs_errorCode_t errorCode)
        /* restore, write back current Pib value for auto request attribute */
        ApiMac_mlmeSetReqBool(ApiMac_attribute_autoRequest, currAutoReq);
        if (SM_forceStopped == true)
            Util_setEvent(&Sensor_events, SENSOR_DISASSOC_EVT);
    #ifdef USE_DMM
        RemoteDisplay_updateSmState(SMCOMMISSIONSTATE_FAIL);
     * @brief      Security manager success processing function
    void smSuccessCMProcessCb(ApiMac_deviceDescriptor_t *devInfo, bool keyRefreshment)
    #ifdef USE_DMM
    #endif
    /** @brief  Set remote display callback functions
     *  @param  remoteDisplayAttr  Remote display attribute value to set
     *  @param  value  pointer to data from remote dispaly application
     *  @param  len  length of data from remote display application
        switch(remoteDisplayAttr)
            case RemoteDisplayAttr_ReportInterval:
                uint8_t *byteArr = (uint8_t*)value;
                uint32_t randomNum;
                reportingInterval = Util_buildUint32(byteArr[3], byteArr[2], byteArr[1], byteArr[0]);
                break;
            case RemoteDisplayAttr_CollLed:
                cmdBytes[1] = *((uint8_t*)value);
                        cmdBytes);
                break;
            default:
                return;
    /** @brief  Get remote display callback functions
     *  @return  void *  Current value of data present in 15.4 application
                Util_bufferUint32(value, configSettings.reportingInterval);
                // Fix byte order
                swapBytes((uint8_t *)value, len);
                break;
                break;
            case RemoteDisplayAttr_SensorData:
    #if defined(TEMP_SENSOR) && !defined(POWER_MEAS)
                memcpy(value, &tempSensor.ambienceTemp, len);
    #endif
                break;
            default:
                // Attribute not found
                break;
    /** @brief  Set provisioning callback functions
     *  @param  ProvisionAttr_t  Remote display attribute value to set
        uint8_t *byteArr = (uint8_t *)value;
        switch(provisioningAttr)
            case ProvisionAttr_PanId:
                uint16_t newPanId;
                newPanId = Util_buildUint16(byteArr[1], byteArr[0]);
                Jdllc_setJoiningPanId(newPanId);
                break;
            case ProvisionAttr_SensorChannelMask:
    #ifndef CUI_DISABLE
                // Validate and correct the channel mask received over BLE
                for (uint8_t i = 0; i < APIMAC_154G_CHANNEL_BITMAP_SIZ; i++)
                    Ssf_validateChMask(byteArr, i);
                Jdllc_setChanMask(byteArr);
    #if CONFIG_FH_ENABLE
                Jdllc_setAsyncChanMask(byteArr);
    #endif
                break;
            case ProvisionAttr_NtwkKey:
                Jdllc_setDefaultKey(byteArr);
    #endif
                break;
            default:
                return;
    /** @brief  Get provisioning callback functions
     *  @return  uint8_t  Current value of data present in 15.4 application
                if(len == 2)
                    uint16_t panId;
                    uint8_t tmpByteSwap;
                    Jdllc_getJoiningPanId(&panId);
                    Util_bufferUint16(value, panId);
                    // Switch byte order
                    tmpByteSwap = ((uint8_t*)value)[0];
                    ((uint8_t *)value)[0] = ((uint8_t *)value)[1];
                    ((uint8_t *)value)[1] = tmpByteSwap;
                break;
            case ProvisionAttr_Freq:
                *(uint8_t*)value = Jdllc_getFreq();
                break;
                Jdllc_getChanMask((uint8_t *)value);
                break;
            case ProvisionAttr_FFDAddr:
                Jdllc_getFfdAddr((uint8_t *)value);
                break;
                Jdllc_getDefaultKey((uint8_t *)value);
    #endif
                break;
            case ProvisionAttr_ProvState:
                *(uint8_t *)value = Jdllc_getProvState();
                break;
            default:
                break;
     * @brief   Helper function to swap the byte order for an input array
        uint8_t i,j, tmp;
        for (i = 0, j = len - 1; i < len/2 ; i++,j--)
            tmp = arr[i];
            arr[i] = arr[j];
            arr[j] = tmp;
    #ifdef DMM_OAD
     * @fn      Sensor_dmmPausePolicyCb
     * @brief   DMM Policy callback to pause 154 Stack
        if (pause)
        {   //pause 154sensor
            Util_setEvent(&Sensor_events, SENSOR_PAUSE_EVT);
        else
        {   //unpause 154sensor
            Util_setEvent(&Sensor_events, SENSOR_RESUME_EVT);
        Ssf_PostAppSem();
    #endif
    #ifdef LPSTK
     * @fn      lpstkAccelerometerTiltCb
     * @brief   SENSOR CONTROLLER Accelerometer CB when Tilt is detected
        uint16_t tempFrameCtrl = configSettings.frameControl;
        configSettings.frameControl = Smsgs_dataFields_accelSensor;
        configSettings.frameControl = tempFrameCtrl;
    #endif /* LPSTK */
    #ifdef DMM_CENTRAL
     * @fn      Sensor_forwardBleData
     * @brief   Forward BLE data to collector
    void Sensor_forwardBleData(const Smsgs_bleSensorField_t *bleInfo)
        // Update sensor data to be sent
        memcpy(&bleSensor, bleInfo, sizeof(Smsgs_bleSensorField_t));
        // If connected forward BLE sensor data
            // Ensure Frame Control is set as Config Messages set frame control to default
    #endif
    Corentin
    您好、 Corentin、
    我看到您已将`#define CONFIG_GPIO_NEW_LED`添加 到 sensor.c 中的第124行、不应执行此操作。 这将使第1812行上的`GPIO_write (CONFIG_GPIO_NEW _LED、1);`语句等效于`GPIO_write(、1);`这是一个无效语句、以及为什么您收到`需要表达式`错误。
    SysConfig 负责定义`CONFIG_GPIO_NEW _LED`。 您是否正确配置了 SysConfig? 如果遇到进一步的问题、您可以共享 SysConfig 文件。
    尼古拉伊
    非常感谢您解决我的问题。
    最后一个问题:如果要在 GPIO 上添加温度传感器、我必须修改传感器和收集器项目中的哪些文件?
    我认为我必须在 SysConfig 中启用 GPIO、然后修改文件:sensor.c 和 sensor.h? 或者还有其他类型的呢?
    祝你度过美好的一天!
    Corentin
    您好、Corentin、
    我建议您浏览 TI 15.4-Stack -添加新的传感器 SimpleLink Academy 实验。 这说明了添加新传感器的一般步骤。
    很难准确地说您需要为特定温度传感器做什么。 这取决于温度传感器接口。 通常、您需要修改 SysConfig 以启用将用于读取温度的必要模块(例如 ADC、I2C 或类似模块)、然后需要更新应用以在必要时读取温度。 您可以查看 sensor.c 中的 readSensors 函数、该函数显示了如何针对已支持的传感器执行此操作。
    尼古拉伊
