Part Number: TMS320F28335
我用CCS7导入TSM320F2835的工程·,提示出错;、See details below.
Error: Import failed for project 'Example_2833xGpioToggle' because its compiler definition is not available. Please install the C2000v22.6 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'.
好像缺少编译器。
这个编译器哪里找呢?谢谢
