下面 LCR _main运行完后,EntryAddr不是应该放在RPC里吗,为何在ACC里?PUSH ACC, POP RPC又是何意?
_InitBoot:
; Initalize the stack pointer.
__stack: .usect ".stack",0
MOV SP, #__stack ; Initalize the stack pointer
; Initalize the device for running in C28x mode.
C28OBJ ; Select C28x object mode
C28ADDR ; Select C27x/C28x addressing
C28MAP ; Set blocks M0/M1 for C28x mode
CLRC PAGE0 ; Always use stack addressing mode
MOVW DP,#0 ; Initialize DP to point to the low 64 K
CLRC OVM
; Set PM shift of 0
SPM 0
; Decide which boot mode to use
LCR _main
; Cleanup and exit. At this point the EntryAddr
; is located in the ACC register
BF _ExitBoot,UNC
; _ExitBoot
;This module cleans up after the boot loader
; 1) Make sure the stack is deallocated.
; SP = 0x400 after exiting the boot
; loader
; 2) Push 0 onto the stack so RPC will be
; 0 after using LRETR to jump to the
; entry point
; 2) Load RPC with the entry point
; 3) Clear all XARn registers
; 4) Clear ACC, P and XT registers
; 5) LRETR - this will also clear the RPC
; register since 0 was on the stack
_ExitBoot:
; Insure that the stack is deallocated
MOV SP,#__stack
; Clear the bottom of the stack. This will endup
; in RPC when we are finished
MOV *SP++,#0
MOV *SP++,#0
; Load RPC with the entry point as determined
; by the boot mode. This address will be returned
; in the ACC register.
PUSH ACC
POP RPC
; Put registers back in their reset state.
; Clear all the XARn, ACC, XT, and P and DP
; registers
; NOTE: Leave the device in C28x operating mode
; (OBJMODE = 1, AMODE = 0)
ZAPA
MOVL XT,ACC
MOVZ AR0,AL
MOVZ AR1,AL
MOVZ AR2,AL
MOVZ AR3,AL
MOVZ AR4,AL
MOVZ AR5,AL
MOVZ AR6,AL
MOVZ AR7,AL
MOVW DP, #0
MOV *SP++,#0
MOV *SP++,#0x0A0B
POP ST1
POP ST0
; Jump to the EntryAddr as defined by the
; boot mode selected and continue execution
LRETR
;eof ----------
