这个中断主要干嘛的?
interrupt void SECONDARY_ISR(void)
EINT;
if (VbusAvg > VBUS_OVP_THRSHLD)//Check for Vbus OV Condition VBUS_OVP_THRSHLD= 440V
OV_flag = 1;
EALLOW;
EPwm1Regs.TZFRC.bit.OST = 1;//Turn off PWM for OV condition
EPwm2Regs.TZFRC.bit.OST = 1;//Turn off PWM for OV condition
EDIS;
VbusTargetSlewed = 0;
VbusTarget = 0;
Gui_Vbus_set = 0;
//Calculate RMS input voltage and input frequency
sine_mainsV.Vin = Vrect >> 9; // input in IQ15 format
SineAnalyzer_MACRO (sine_mainsV);
VrectRMS = (sine_mainsV.Vrms)<< 9;// Convert sine_mainsV.Vrms from Q15 to Q24 and save as VrectRMS
Freq_Vin = sine_mainsV.SigFreq;// Q15
//VrmsReal = _IQ15mpy (KvInv, sine_mainsV.Vrms);
EINT;
OV_flag = 1;
EALLOW;
EDIS;
VbusTarget = 0;
Gui_Vbus_set = 0;
//Start of Non-linear Volt loop control
if (run_flag == 1 && flag_NL_Vloop == 1) //If soft-start is over, PFC running normally & NL Vloop flag is set
error_v = VbusTargetSlewed - Vbus;
if (error_v > VBUS_ERROR_NL_CNTRL_THRSHLD || ((-1)*(error_v))> VBUS_ERROR_NL_CNTRL_THRSHLD)
// (15V/519V)*4095*4095 = 484654.0
//(12V/519V)*4095*4095 = 387912.0
CNTL_2P2Z_CoefStruct2.b1 =_IQ26(-4.495);//(-0.7495);//(Igain_V-Pgain_V-Dgain_V-Dgain_V); // 2.5, 0.005, B1
CNTL_2P2Z_CoefStruct2.b0 =_IQ26(4.505);//(0.7505);//(Pgain_V + Igain_V + Dgain_V); // B0 ;//Use NL v loop coefficients
else
CNTL_2P2Z_CoefStruct2.b1 =_IQ26(-0.2495);//Otherwise use normal v loop coefficients
CNTL_2P2Z_CoefStruct2.b0 =_IQ26(0.2505);//KP=0.25, KI=0.0005
} //End of NL V loop Control
else
//Start of Adaptive Current control loop
if (disable_auto_cloop_coeff_change == 0)
if (VrectRMS <= 7588716)
//(185/409)*2e24 = 7588716,
//KP=73750
CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.9722);// B1
CNTL_2P2Z_CoefStruct1.b0 =_IQ26(1.7097); // B0
if (VrectRMS > 7588716 && VrectRMS <= 9639721)
//(235/409)*2e24 = 9639721,
//(225/409)*2e24 = 9229520,Use this lower limit for modified RC filter in CS ckt
//KP=53750
//CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.7085);// B1
//CNTL_2P2Z_CoefStruct1.b0 =_IQ26(1.246); // B0
//KP=63750
CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.8403);// B1
CNTL_2P2Z_CoefStruct1.b0 =_IQ26(1.4778); // B0
if (VrectRMS > 9639721 && VrectRMS <= 10049922)
// (235/409)*2e24 = 9639721,
//(245/409)*2e24 = 10049922,
//KP=33750
//CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.4449);// B1
//CNTL_2P2Z_CoefStruct1.b0 =_IQ26(0.7824); // B0
//KP=13750
CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.1812);// B1
CNTL_2P2Z_CoefStruct1.b0 =_IQ26(0.3187); // B0
if (VrectRMS > 10049922 && VrectRMS <= 10255022)
// (245/409)*2e24 = 10049922,
//(250/409)*2e24 = 10255022,
//KP=23750
//CNTL_2P2Z_CoefStruct1.b1 =_IQ26(-0.3131);// B1
//CNTL_2P2Z_CoefStruct1.b0 =_IQ26(0.5506); // B0
//KP=13750
if (VrectRMS > 10255022)
//KP=13750
}//End of Adaptive Current control loop
EPwm7Regs.ETCLR.bit.INT = 1; // Enable ePWM7 INTN pulse
PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
return;
return;
