有没有技术手册?原理,和使用方法/ 谢谢!
Eric:
C:\ti\controlSUITE\libs\app_libs\digital_power\f2803x_v3.5\Doc
The 2-pole 2-zero control block implements a second order control law using
an IIR filter structure with programmable output saturation. This type of
controller requires two delay lines: one for input data and one for output data,
each consisting of two elements.
The discrete transfer function for the basic 2P2Z control law is…
This may be expressed in difference equation form as:
u(n) a1u(n1) a2u(n 2)b0e(n)b1e(n1)b2e(n 2)
